[geos-commits] [SCM] GEOS branch master updated. 24652fb98c4da0ef41d8f21d6dd021b680e62fcd
git at osgeo.org
git at osgeo.org
Mon Dec 10 07:39:57 PST 2018
the project "GEOS".
via 24652fb98c4da0ef41d8f21d6dd021b680e62fcd (commit)
from 4ae0648ae8f23952a9ca30b57f2706f3492b1e28 (commit)
revisions in full, below.
commit 24652fb98c4da0ef41d8f21d6dd021b680e62fcd
Author: Daniel Baston <dbaston at gmail.com>
Date: Tue Dec 4 14:36:55 2018 -0500
Fix mem leaks in SIRtreePointInRing
Fixes #944
diff --git a/include/geos/algorithm/SIRtreePointInRing.h b/include/geos/algorithm/SIRtreePointInRing.h
index cb29a69..6b1e0c3 100644
--- a/include/geos/algorithm/SIRtreePointInRing.h
+++ b/include/geos/algorithm/SIRtreePointInRing.h
@@ -18,7 +18,10 @@
#include <geos/export.h>
#include <geos/algorithm/PointInRing.h> // for inheritance
+#include <geos/index/strtree/SIRtree.h>
+#include <geos/geom/LineSegment.h>
+#include <memory>
#include <vector>
// Forward declarations
@@ -28,11 +31,6 @@ namespace geos {
class LineSegment;
class LinearRing;
- namespace index {
- namespace strtree {
- class SIRtree;
@@ -42,14 +40,15 @@ namespace algorithm { // geos::algorithm
class GEOS_DLL SIRtreePointInRing: public PointInRing {
private:
geom::LinearRing *ring;
- index::strtree::SIRtree *sirTree;
+ index::strtree::SIRtree sirTree;
+ std::vector<std::unique_ptr<geom::LineSegment>> segments;
int crossings; // number of segment/ray crossings
void buildIndex();
void testLineSegment(const geom::Coordinate& p,
geom::LineSegment *seg);
public:
SIRtreePointInRing(geom::LinearRing *newRing);
- ~SIRtreePointInRing() override;
+ ~SIRtreePointInRing() override = default;
bool isInside(const geom::Coordinate& pt) override;
diff --git a/src/algorithm/SIRtreePointInRing.cpp b/src/algorithm/SIRtreePointInRing.cpp
index 18087e5..19adc14 100644
--- a/src/algorithm/SIRtreePointInRing.cpp
+++ b/src/algorithm/SIRtreePointInRing.cpp
@@ -35,30 +35,23 @@ namespace algorithm { // geos.algorithm
SIRtreePointInRing::SIRtreePointInRing(LinearRing *newRing):
PointInRing(),
ring(newRing),
- sirTree(nullptr),
crossings(0)
buildIndex();
-SIRtreePointInRing::~SIRtreePointInRing()
- delete sirTree;
void
SIRtreePointInRing::buildIndex()
- //Envelope *env=ring->getEnvelopeInternal();
- sirTree=new SIRtree();
- const CoordinateSequence *pts=ring->getCoordinatesRO();
+ const CoordinateSequence *pts = ring->getCoordinatesRO();
const std::size_t npts=pts->getSize();
for(std::size_t i=1; i<npts; ++i)
if(pts->getAt(i-1)==pts->getAt(i)) continue; // Optimization suggested by MD. [Jon Aquino]
- LineSegment *seg=new LineSegment(pts->getAt(i-1), pts->getAt(i));
- sirTree->insert(seg->p0.y, seg->p1.y, seg);
+ std::unique_ptr<LineSegment> seg{new LineSegment(pts->getAt(i-1), pts->getAt(i))};
+ sirTree.insert(seg->p0.y, seg->p1.y, seg.get());
+ segments.push_back(std::move(seg));
@@ -67,20 +60,17 @@ SIRtreePointInRing::isInside(const Coordinate& pt)
crossings=0;
// test all segments intersected by vertical ray at pt
- vector<void*> *segs=sirTree->query(pt.y);
- //System.out.println("query size=" + segs.size());
- for(int i=0;i<(int)segs->size();i++) {
- LineSegment *seg=(LineSegment*) (*segs)[i];
+ std::unique_ptr<vector<void*>> segs{sirTree.query(pt.y)};
+ for(const auto& hit : *segs) {
+ LineSegment *seg = static_cast<LineSegment*>(hit);
testLineSegment(pt,seg);
* p is inside if number of crossings is odd.
- if ((crossings%2)==1) {
- return true;
- return false;
+ return (crossings % 2) == 1;
void
@@ -108,7 +98,6 @@ SIRtreePointInRing::testLineSegment(const Coordinate& p,LineSegment *seg)
* segment straddles x axis,so compute intersection.
xInt=RobustDeterminant::signOfDet2x2(x1,y1,x2,y2)/(y2-y1);
- //xsave=xInt;
* crosses ray if strictly positive intersection.
diff --git a/tests/unit/Makefile.am b/tests/unit/Makefile.am
index 17efa4d..9af1fd3 100644
--- a/tests/unit/Makefile.am
+++ b/tests/unit/Makefile.am
@@ -52,6 +52,7 @@ geos_unit_SOURCES = \
algorithm/PointLocatorTest.cpp \
algorithm/RobustLineIntersectionTest.cpp \
algorithm/RobustLineIntersectorTest.cpp \
+ algorithm/SIRtreePointInRingTest.cpp \
geom/CoordinateArraySequenceFactoryTest.cpp \
geom/CoordinateArraySequenceTest.cpp \
geom/CoordinateListTest.cpp \
diff --git a/tests/unit/algorithm/SIRtreePointInRingTest.cpp b/tests/unit/algorithm/SIRtreePointInRingTest.cpp
new file mode 100644
index 0000000..2ec04c5
--- /dev/null
+++ b/tests/unit/algorithm/SIRtreePointInRingTest.cpp
@@ -0,0 +1,56 @@
+// Test Suite for geos::algorithm::SIRtreePointInRing
+#include <tut/tut.hpp>
+// geos
+#include <geos/geom/Coordinate.h>
+#include <geos/algorithm/SIRtreePointInRing.h>
+#include <geos/io/WKTReader.h>
+#include <geos/geom/Geometry.h>
+#include <geos/geom/LinearRing.h>
+// std
+#include <sstream>
+#include <string>
+#include <memory>
+namespace tut
+ // Test Group
+ // dummy data, not used
+ struct test_sirtreepointinring_data {
+ using SIRtreePointInRing = geos::algorithm::SIRtreePointInRing;
+ using Geometry = geos::geom::Geometry;
+ using Coordinate = geos::geom::Coordinate;
+ geos::io::WKTReader reader;
+ std::unique_ptr<Geometry> geom;
+ typedef test_group<test_sirtreepointinring_data> group;
+ typedef group::object object;
+ group test_sirtreepointinring_data("geos::algorithm::SIRtreePointInRing");
+ // Test Cases
+ template<>
+ template<>
+ void object::test<1>()
+ using geos::geom::LinearRing;
+ geom.reset(reader.read("LINEARRING (0 0, 1 0, 1 1, 0 1, 0 0)"));
+ SIRtreePointInRing pir{dynamic_cast<LinearRing*>(geom.get())};
+ Coordinate c{0.5, 0.5};
+ ensure(pir.isInside(c));
+} // namespace tut
Summary of changes:
include/geos/algorithm/SIRtreePointInRing.h | 13 +++---
src/algorithm/SIRtreePointInRing.cpp | 29 ++++---------
tests/unit/Makefile.am | 1 +
tests/unit/algorithm/SIRtreePointInRingTest.cpp | 56 +++++++++++++++++++++++++
4 files changed, 72 insertions(+), 27 deletions(-)
create mode 100644 tests/unit/algorithm/SIRtreePointInRingTest.cpp
hooks/post-receive
More information about the geos-commits
