[geos-commits] [SCM] GEOS branch master updated. 9ffadc117040ab58a68e3a6b4f4b05da9ca4c61c
git at osgeo.org
git at osgeo.org
Wed Dec 12 15:30:48 PST 2018
the project "GEOS".
via 9ffadc117040ab58a68e3a6b4f4b05da9ca4c61c (commit)
via 9674b7de0c95f9c9976621b8024759b4dcbf334b (commit)
from f5230e57d46ee3793e157979e8e36633ec96a833 (commit)
revisions in full, below.
commit 9ffadc117040ab58a68e3a6b4f4b05da9ca4c61c
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Wed Dec 12 15:30:40 2018 -0800
Remove MCPointInRing
diff --git a/include/geos/algorithm/MCPointInRing.h b/include/geos/algorithm/MCPointInRing.h
deleted file mode 100644
index 6a833e7..0000000
--- a/include/geos/algorithm/MCPointInRing.h
+++ /dev/null
@@ -1,85 +0,0 @@
- * GEOS - Geometry Engine Open Source
- * http://geos.osgeo.org
- * Copyright (C) 2005-2006 Refractions Research Inc.
- * Copyright (C) 2001-2002 Vivid Solutions Inc.
- * This is free software; you can redistribute and/or modify it under
- * the terms of the GNU Lesser General Public Licence as published
- * by the Free Software Foundation.
- * See the COPYING file for more information.
-#ifndef GEOS_ALGORITHM_MCPOINTINRING_H
-#define GEOS_ALGORITHM_MCPOINTINRING_H
-#include <geos/export.h>
-#include <geos/index/chain/MonotoneChainSelectAction.h> // for inheritance
-#include <geos/algorithm/PointInRing.h> // for inheritance
-#include <geos/geom/Coordinate.h> // for composition
-#include <geos/index/bintree/Interval.h> // for composition
-#include <memory>
-#include <vector>
-// Forward declarations
-namespace geos {
- namespace geom {
- class Coordinate;
- class LineSegment;
- class LinearRing;
- class CoordinateSequence;
- namespace index {
- namespace bintree {
- class Bintree;
- class Interval;
-namespace geos {
-namespace algorithm { // geos::algorithm
-class GEOS_DLL MCPointInRing: public PointInRing {
-public:
- MCPointInRing(const geom::LinearRing *newRing);
- ~MCPointInRing() override;
- bool isInside(const geom::Coordinate& pt) override;
- void testLineSegment(const geom::Coordinate& p,
- const geom::LineSegment& seg);
- class MCSelecter: public index::chain::MonotoneChainSelectAction {
- using MonotoneChainSelectAction::select;
- private:
- geom::Coordinate p;
- MCPointInRing *parent;
- public:
- MCSelecter(const geom::Coordinate& newP, MCPointInRing *prt);
- void select(const geom::LineSegment& ls) override;
-private:
- const geom::LinearRing *ring;
- index::bintree::Interval interval;
- std::unique_ptr<geom::CoordinateSequence> pts;
- std::unique_ptr<index::bintree::Bintree> tree;
- std::unique_ptr<std::vector<std::unique_ptr<index::chain::MonotoneChain>>> chains;
- int crossings; // number of segment/ray crossings
- void buildIndex();
- void testMonotoneChain(geom::Envelope *rayEnv,
- MCSelecter *mcSelecter,
- index::chain::MonotoneChain *mc);
-} // namespace geos::algorithm
-#endif // GEOS_ALGORITHM_MCPOINTINRING_H
diff --git a/include/geos/algorithm/Makefile.am b/include/geos/algorithm/Makefile.am
index 5df8b26..6abf2f5 100644
--- a/include/geos/algorithm/Makefile.am
+++ b/include/geos/algorithm/Makefile.am
@@ -26,7 +26,6 @@ geos_HEADERS = \
InteriorPointLine.h \
InteriorPointPoint.h \
LineIntersector.h \
- MCPointInRing.h \
MinimumDiameter.h \
NotRepresentableException.h \
PointInRing.h \
diff --git a/src/Makefile.vc b/src/Makefile.vc
index 97152ca..3874378 100644
--- a/src/Makefile.vc
+++ b/src/Makefile.vc
@@ -1,400 +1,399 @@
-# Building on Win32 with Visual C++ 7.0, 7.1, 8.0 or 9.0
-# Produces:
-# geos.lib: static library for use of C or C++ API.
-# geos.dll: DLL - only exports the C API
-# geos_i.lib: stub library to link against for use of geos.dll.
-# geos_d.lib: debug static library for use of C or C++ API.
-# geos_d.dll: debug DLL - only exports the C API
-# geos_i_d.lib: debug stub library to link against for use of geos.dll.
-# This makefile mostly maintained by Frank Warmerdam <warmerdam at pobox.com>
-# with support by Mateusz Loskot <mateusz at loskot.net>
-GEOS_ROOT=..
-!INCLUDE $(GEOS_ROOT)\nmake.opt
-!INCLUDE dirlist.mk
-# Output location
-# TODO: not yet supported
-#OUT_DIR = $(GEOS_ROOT)\bin\$(BUILD_DIR)
-# List of objects
-OBJ_EXT = obj
-EXT = $(OBJ_EXT)
-OBJ = \
- algorithm\Angle.$(EXT) \
- algorithm\BoundaryNodeRule.$(EXT) \
- algorithm\Centroid.$(EXT) \
- algorithm\CentroidArea.$(EXT) \
- algorithm\CentroidLine.$(EXT) \
- algorithm\CentroidPoint.$(EXT) \
- algorithm\CGAlgorithms.$(EXT) \
- algorithm\ConvexHull.$(EXT) \
- algorithm\HCoordinate.$(EXT) \
- algorithm\InteriorPointArea.$(EXT) \
- algorithm\InteriorPointLine.$(EXT) \
- algorithm\InteriorPointPoint.$(EXT) \
- algorithm\LineIntersector.$(EXT) \
- algorithm\MCPointInRing.$(EXT) \
- algorithm\MinimumDiameter.$(EXT) \
- algorithm\NotRepresentableException.$(EXT) \
- algorithm\PointLocator.$(EXT) \
- algorithm\RayCrossingCounter.$(EXT) \
- algorithm\RobustDeterminant.$(EXT) \
- algorithm\SimplePointInRing.$(EXT) \
- algorithm\SIRtreePointInRing.$(EXT) \
- algorithm\distance\DiscreteHausdorffDistance.$(EXT) \
- algorithm\distance\DiscreteFrechetDistance.$(EXT) \
- algorithm\distance\DistanceToPoint.$(EXT) \
- algorithm\locate\IndexedPointInAreaLocator.$(EXT) \
- algorithm\locate\PointOnGeometryLocator.$(EXT) \
- algorithm\locate\SimplePointInAreaLocator.$(EXT) \
- geom\Coordinate.$(EXT) \
- geom\CoordinateArraySequence.$(EXT) \
- geom\CoordinateArraySequenceFactory.$(EXT) \
- geom\CoordinateSequence.$(EXT) \
- geom\CoordinateSequenceFactory.$(EXT) \
- geom\Dimension.$(EXT) \
- geom\Envelope.$(EXT) \
- geom\Geometry.$(EXT) \
- geom\GeometryCollection.$(EXT) \
- geom\GeometryComponentFilter.$(EXT) \
- geom\GeometryFactory.$(EXT) \
- geom\IntersectionMatrix.$(EXT) \
- geom\LinearRing.$(EXT) \
- geom\LineSegment.$(EXT) \
- geom\LineString.$(EXT) \
- geom\Location.$(EXT) \
- geom\MultiLineString.$(EXT) \
- geom\MultiPoint.$(EXT) \
- geom\MultiPolygon.$(EXT) \
- geom\Point.$(EXT) \
- geom\Polygon.$(EXT) \
- geom\PrecisionModel.$(EXT) \
- geom\Triangle.$(EXT) \
- geom\util\ComponentCoordinateExtracter.$(EXT) \
- geom\util\CoordinateOperation.$(EXT) \
- geom\util\GeometryEditor.$(EXT) \
- geom\util\GeometryTransformer.$(EXT) \
- geom\util\GeometryCombiner.$(EXT) \
- geom\util\ShortCircuitedGeometryVisitor.$(EXT) \
- geom\util\SineStarFactory.$(EXT) \
- geom\util\LinearComponentExtracter.$(EXT) \
- geom\util\PolygonExtracter.$(EXT) \
- geom\util\PointExtracter.$(EXT) \
- geom\prep\AbstractPreparedPolygonContains.$(EXT) \
- geom\prep\BasicPreparedGeometry.$(EXT) \
- geom\prep\PreparedGeometry.$(EXT) \
- geom\prep\PreparedGeometryFactory.$(EXT) \
- geom\prep\PreparedLineString.$(EXT) \
- geom\prep\PreparedLineStringIntersects.$(EXT) \
- geom\prep\PreparedPoint.$(EXT) \
- geom\prep\PreparedPolygon.$(EXT) \
- geom\prep\PreparedPolygonContains.$(EXT) \
- geom\prep\PreparedPolygonContainsProperly.$(EXT) \
- geom\prep\PreparedPolygonCovers.$(EXT) \
- geom\prep\PreparedPolygonIntersects.$(EXT) \
- geom\prep\PreparedPolygonPredicate.$(EXT) \
- geomgraph\Depth.$(EXT) \
- geomgraph\DirectedEdge.$(EXT) \
- geomgraph\DirectedEdgeStar.$(EXT) \
- geomgraph\Edge.$(EXT) \
- geomgraph\EdgeEnd.$(EXT) \
- geomgraph\EdgeEndStar.$(EXT) \
- geomgraph\EdgeIntersectionList.$(EXT) \
- geomgraph\EdgeList.$(EXT) \
- geomgraph\EdgeNodingValidator.$(EXT) \
- geomgraph\EdgeRing.$(EXT) \
- geomgraph\GeometryGraph.$(EXT) \
- geomgraph\GraphComponent.$(EXT) \
- geomgraph\Label.$(EXT) \
- geomgraph\Node.$(EXT) \
- geomgraph\NodeFactory.$(EXT) \
- geomgraph\NodeMap.$(EXT) \
- geomgraph\PlanarGraph.$(EXT) \
- geomgraph\Position.$(EXT) \
- geomgraph\Quadrant.$(EXT) \
- geomgraph\TopologyLocation.$(EXT) \
- geomgraph\index\MonotoneChainEdge.$(EXT) \
- geomgraph\index\MonotoneChainIndexer.$(EXT) \
- geomgraph\index\SegmentIntersector.$(EXT) \
- geomgraph\index\SimpleEdgeSetIntersector.$(EXT) \
- geomgraph\index\SimpleMCSweepLineIntersector.$(EXT) \
- geomgraph\index\SimpleSweepLineIntersector.$(EXT) \
- geomgraph\index\SweepLineEvent.$(EXT) \
- geomgraph\index\SweepLineSegment.$(EXT) \
- index\bintree\Bintree.$(EXT) \
- index\bintree\Interval.$(EXT) \
- index\bintree\Key.$(EXT) \
- index\bintree\Node.$(EXT) \
- index\bintree\NodeBase.$(EXT) \
- index\bintree\Root.$(EXT) \
- index\chain\MonotoneChain.$(EXT) \
- index\chain\MonotoneChainBuilder.$(EXT) \
- index\chain\MonotoneChainOverlapAction.$(EXT) \
- index\chain\MonotoneChainSelectAction.$(EXT) \
- index\intervalrtree\IntervalRTreeBranchNode.$(EXT) \
- index\intervalrtree\IntervalRTreeLeafNode.$(EXT) \
- index\intervalrtree\SortedPackedIntervalRTree.$(EXT) \
- index\quadtree\DoubleBits.$(EXT) \
- index\quadtree\IntervalSize.$(EXT) \
- index\quadtree\Key.$(EXT) \
- index\quadtree\Node.$(EXT) \
- index\quadtree\NodeBase.$(EXT) \
- index\quadtree\Root.$(EXT) \
- index\quadtree\Quadtree.$(EXT) \
- index\strtree\AbstractNode.$(EXT) \
- index\strtree\AbstractSTRtree.$(EXT) \
- index\strtree\BoundablePair.$(EXT) \
- index\strtree\GeometryItemDistance.$(EXT) \
- index\strtree\Interval.$(EXT) \
- index\strtree\ItemBoundable.$(EXT) \
- index\strtree\SIRtree.$(EXT) \
- index\strtree\STRtree.$(EXT) \
- index\sweepline\SweepLineEvent.$(EXT) \
- index\sweepline\SweepLineIndex.$(EXT) \
- index\sweepline\SweepLineInterval.$(EXT) \
- io\ByteOrderDataInStream.$(EXT) \
- io\ByteOrderValues.$(EXT) \
- io\CLocalizer.$(EXT) \
- io\ParseException.$(EXT) \
- io\StringTokenizer.$(EXT) \
- io\Unload.$(EXT) \
- io\WKBReader.$(EXT) \
- io\WKBWriter.$(EXT) \
- io\WKTReader.$(EXT) \
- io\WKTWriter.$(EXT) \
- io\Writer.$(EXT) \
- noding\BasicSegmentString.$(EXT) \
- noding\FastNodingValidator.$(EXT) \
- noding\FastSegmentSetIntersectionFinder.$(EXT) \
- noding\GeometryNoder.$(EXT) \
- noding\IntersectionAdder.$(EXT) \
- noding\IntersectionFinderAdder.$(EXT) \
- noding\IteratedNoder.$(EXT) \
- noding\MCIndexNoder.$(EXT) \
- noding\MCIndexSegmentSetMutualIntersector.$(EXT) \
- noding\NodedSegmentString.$(EXT) \
- noding\NodingValidator.$(EXT) \
- noding\Octant.$(EXT) \
- noding\OrientedCoordinateArray.$(EXT) \
- noding\ScaledNoder.$(EXT) \
- noding\SegmentIntersectionDetector.$(EXT) \
- noding\SegmentNode.$(EXT) \
- noding\SegmentNodeList.$(EXT) \
- noding\SegmentString.$(EXT) \
- noding\SegmentStringUtil.$(EXT) \
- noding\SimpleNoder.$(EXT) \
- noding\SingleInteriorIntersectionFinder.$(EXT) \
- noding\snapround\HotPixel.$(EXT) \
- noding\snapround\MCIndexPointSnapper.$(EXT) \
- noding\snapround\MCIndexSnapRounder.$(EXT) \
- noding\snapround\SimpleSnapRounder.$(EXT) \
- operation\GeometryGraphOperation.$(EXT) \
- operation\IsSimpleOp.$(EXT) \
- operation\buffer\BufferBuilder.$(EXT) \
- operation\buffer\BufferInputLineSimplifier.$(EXT) \
- operation\buffer\BufferParameters.$(EXT) \
- operation\buffer\BufferOp.$(EXT) \
- operation\buffer\BufferSubgraph.$(EXT) \
- operation\buffer\OffsetCurveBuilder.$(EXT) \
- operation\buffer\OffsetCurveSetBuilder.$(EXT) \
- operation\buffer\OffsetSegmentGenerator.$(EXT) \
- operation\buffer\RightmostEdgeFinder.$(EXT) \
- operation\buffer\SubgraphDepthLocater.$(EXT) \
- operation\distance\ConnectedElementLocationFilter.$(EXT) \
- operation\distance\ConnectedElementPointFilter.$(EXT) \
- operation\distance\DistanceOp.$(EXT) \
- operation\distance\FacetSequence.$(EXT) \
- operation\distance\FacetSequenceTreeBuilder.$(EXT) \
- operation\distance\GeometryLocation.$(EXT) \
- operation\distance\IndexedFacetDistance.$(EXT) \
- operation\intersection\Rectangle.$(EXT) \
- operation\intersection\RectangleIntersection.$(EXT) \
- operation\intersection\RectangleIntersectionBuilder.$(EXT) \
- operation\linemerge\EdgeString.$(EXT) \
- operation\linemerge\LineMergeDirectedEdge.$(EXT) \
- operation\linemerge\LineMergeEdge.$(EXT) \
- operation\linemerge\LineMergeGraph.$(EXT) \
- operation\linemerge\LineMerger.$(EXT) \
- operation\linemerge\LineSequencer.$(EXT) \
- operation\overlay\EdgeSetNoder.$(EXT) \
- operation\overlay\ElevationMatrix.$(EXT) \
- operation\overlay\ElevationMatrixCell.$(EXT) \
- operation\overlay\LineBuilder.$(EXT) \
- operation\overlay\MaximalEdgeRing.$(EXT) \
- operation\overlay\MinimalEdgeRing.$(EXT) \
- operation\overlay\OverlayNodeFactory.$(EXT) \
- operation\overlay\OverlayOp.$(EXT) \
- operation\overlay\PointBuilder.$(EXT) \
- operation\overlay\PolygonBuilder.$(EXT) \
- operation\overlay\snap\GeometrySnapper.$(EXT) \
- operation\overlay\snap\LineStringSnapper.$(EXT) \
- operation\overlay\snap\SnapOverlayOp.$(EXT) \
- operation\overlay\snap\SnapIfNeededOverlayOp.$(EXT) \
- operation\overlay\validate\FuzzyPointLocator.$(EXT) \
- operation\overlay\validate\OffsetPointGenerator.$(EXT) \
- operation\overlay\validate\OverlayResultValidator.$(EXT) \
- operation\polygonize\PolygonizeDirectedEdge.$(EXT) \
- operation\polygonize\PolygonizeEdge.$(EXT) \
- operation\polygonize\EdgeRing.$(EXT) \
- operation\polygonize\PolygonizeGraph.$(EXT) \
- operation\polygonize\Polygonizer.$(EXT) \
- operation\predicate\RectangleContains.$(EXT) \
- operation\predicate\RectangleIntersects.$(EXT) \
- operation\predicate\SegmentIntersectionTester.$(EXT) \
- operation\relate\EdgeEndBuilder.$(EXT) \
- operation\relate\EdgeEndBundle.$(EXT) \
- operation\relate\EdgeEndBundleStar.$(EXT) \
- operation\relate\RelateComputer.$(EXT) \
- operation\relate\RelateNode.$(EXT) \
- operation\relate\RelateNodeFactory.$(EXT) \
- operation\relate\RelateNodeGraph.$(EXT) \
- operation\relate\RelateOp.$(EXT) \
- operation\sharedpaths\SharedPathsOp.$(EXT) \
- operation\union\CascadedPolygonUnion.$(EXT) \
- operation\union\CascadedUnion.$(EXT) \
- operation\union\PointGeometryUnion.$(EXT) \
- operation\union\UnaryUnionOp.$(EXT) \
- operation\valid\ConnectedInteriorTester.$(EXT) \
- operation\valid\ConsistentAreaTester.$(EXT) \
- operation\valid\IndexedNestedRingTester.$(EXT) \
- operation\valid\IsValidOp.$(EXT) \
- operation\valid\QuadtreeNestedRingTester.$(EXT) \
- operation\valid\RepeatedPointTester.$(EXT) \
- operation\valid\SimpleNestedRingTester.$(EXT) \
- operation\valid\SweeplineNestedRingTester.$(EXT) \
- operation\valid\TopologyValidationError.$(EXT) \
- planargraph\DirectedEdge.$(EXT) \
- planargraph\DirectedEdgeStar.$(EXT) \
- planargraph\Edge.$(EXT) \
- planargraph\Node.$(EXT) \
- planargraph\NodeMap.$(EXT) \
- planargraph\PlanarGraph.$(EXT) \
- planargraph\Subgraph.$(EXT) \
- planargraph\algorithm\ConnectedSubgraphFinder.$(EXT) \
- precision\CommonBits.$(EXT) \
- precision\CommonBitsOp.$(EXT) \
- precision\CommonBitsRemover.$(EXT) \
- precision\EnhancedPrecisionOp.$(EXT) \
- precision\GeometryPrecisionReducer.$(EXT) \
- precision\MinimumClearance.$(EXT) \
- precision\PrecisionReducerCoordinateOperation.$(EXT) \
- precision\SimpleGeometryPrecisionReducer.$(EXT) \
- simplify\DouglasPeuckerLineSimplifier.$(EXT) \
- simplify\DouglasPeuckerSimplifier.$(EXT) \
- simplify\LineSegmentIndex.$(EXT) \
- simplify\TaggedLineSegment.$(EXT) \
- simplify\TaggedLinesSimplifier.$(EXT) \
- simplify\TaggedLineString.$(EXT) \
- simplify\TaggedLineStringSimplifier.$(EXT) \
- simplify\TopologyPreservingSimplifier.$(EXT) \
- triangulate\DelaunayTriangulationBuilder.$(EXT) \
- triangulate\IncrementalDelaunayTriangulator.$(EXT) \
- triangulate\VoronoiDiagramBuilder.$(EXT) \
- triangulate\quadedge\LastFoundQuadEdgeLocator.$(EXT) \
- triangulate\quadedge\LocateFailureException.$(EXT) \
- triangulate\quadedge\QuadEdge.$(EXT) \
- triangulate\quadedge\QuadEdgeLocator.$(EXT) \
- triangulate\quadedge\QuadEdgeSubdivision.$(EXT) \
- triangulate\quadedge\TrianglePredicate.$(EXT) \
- triangulate\quadedge\TriangleVisitor.$(EXT) \
- triangulate\quadedge\Vertex.$(EXT) \
- util\Assert.$(EXT) \
- util\GeometricShapeFactory.$(EXT) \
- util\Interrupt.$(EXT) \
- util\math.$(EXT) \
- util\Profiler.$(EXT) \
- linearref\ExtractLineByLocation.$(EXT) \
- linearref\LengthIndexOfPoint.$(EXT) \
- linearref\LengthIndexedLine.$(EXT) \
- linearref\LengthLocationMap.$(EXT) \
- linearref\LinearGeometryBuilder.$(EXT) \
- linearref\LinearIterator.$(EXT) \
- linearref\LinearLocation.$(EXT) \
- linearref\LocationIndexOfLine.$(EXT) \
- linearref\LocationIndexOfPoint.$(EXT) \
- ..\capi\geos_c.$(EXT) \
- ..\capi\geos_ts_c.$(EXT) \
- inlines.$(EXT)
-TEST_EXE = TestSweepLineSpeed.exe
-# Build targets
-default: $(LIBNAME) $(DLLNAME) $(CDLLNAME)
-all: $(LIBNAME) $(DLLNAME) $(CDLLNAME) TestSweepLineSpeed.exe geostest.exe
-check: all
- TestSweepLineSpeed.exe
-$(LIBNAME): $(GEOS_ROOT)\include\geos\platform.h $(GEOS_ROOT)\include\geos\version.h ..\capi\geos_c.h $(OBJ)
- if exist $(LIBNAME) del $(LIBNAME)
- $(LINK) /lib /out:$(LIBNAME) $(OBJ)
-$(DLLNAME): $(OBJ)
- $(LINK) /dll /debug $(LINKER_FLAGS) $(OBJ) /out:$(DLLNAME) /implib:$(SLIBNAME)
- if exist $(DLLNAME).manifest mt -manifest $(DLLNAME).manifest -outputresource:$(DLLNAME);2
-$(CDLLNAME): ..\capi\geos_c.obj ..\capi\geos_ts_c.obj $(DLLNAME)
- $(LINK) /dll /debug $(LINKER_FLAGS) ..\capi\geos_c.obj ..\capi\geos_ts_c.obj $(LIBNAME) /out:$(CDLLNAME) /implib:$(CLIBNAME)
- if exist $(CDLLNAME).manifest mt -manifest $(CDLLNAME).manifest -outputresource:$(CDLLNAME);2
-$(GEOS_ROOT)\include\geos\platform.h: $(GEOS_ROOT)\include\geos\platform.h.vc
- $(CP) $(GEOS_ROOT)\include\geos\platform.h.vc $(GEOS_ROOT)\include\geos\platform.h
-$(GEOS_ROOT)\include\geos\version.h: $(GEOS_ROOT)\include\geos\version.h.vc
- if not exist $(GEOS_ROOT)\include\geos\version.h $(CP) $(GEOS_ROOT)\include\geos\version.h.vc $(GEOS_ROOT)\include\geos\version.h
-# geos_c.h should already be in distribution, if is not you'll
-# have to run ./configure to recreate
-../capi/geos_c.h: ../capi/geos_c.h.in.
- $(CP) ..\capi\geos_c.h.in ..\capi\geos_c.h
-.cpp.obj:
- $(CC) $(CFLAGS) /c $*.cpp /Fo$@
-{..\capi}.cpp.obj:
- $(CC) $(CFLAGS) /D "GEOS_DLL_EXPORT" /c $*.cpp /Fo$@
-.c.obj:
- $(CC) $(CFLAGS) /c $*.c /Fo$@
-clean:
- @ECHO "*** Cleaning GEOS source tree"
- @IF EXIST $(LIBNAME) $(RM) $(LIBNAME)
- @IF EXIST $(SLIBNAME) $(RM) $(SLIBNAME)
- @IF EXIST $(DLLNAME) $(RM) $(DLLNAME)
- @IF EXIST $(CLIBNAME) $(RM) $(CLIBNAME)
- @IF EXIST $(CDLLNAME) $(RM) $(CDLLNAME)
- - at del /s *.exe
- - at del /s *.exp
- - at del /s *.ilk
- - at del /s *.manifest
- - at del /s *.obj
- - at del /s *.pdb
-TestSweepLineSpeed.exe: $(LIBNAME) \
- ..\tests\bigtest\GeometryTestFactory.obj \
- ..\tests\bigtest\TestSweepLineSpeed.obj
- $(LINK) /debug /out:TestSweepLineSpeed.exe \
- ..\tests\bigtest\TestSweepLineSpeed.obj \
- $(LIBNAME)
-geostest.exe: $(CDLLNAME) ..\tests\unit\capi\geostest.obj
- $(LINK) /debug ..\tests\unit\capi\geostest.obj $(CLIBNAME)
-# EOF
+# Building on Win32 with Visual C++ 7.0, 7.1, 8.0 or 9.0
+# Produces:
+# geos.lib: static library for use of C or C++ API.
+# geos.dll: DLL - only exports the C API
+# geos_i.lib: stub library to link against for use of geos.dll.
+# geos_d.lib: debug static library for use of C or C++ API.
+# geos_d.dll: debug DLL - only exports the C API
+# geos_i_d.lib: debug stub library to link against for use of geos.dll.
+# This makefile mostly maintained by Frank Warmerdam <warmerdam at pobox.com>
+# with support by Mateusz Loskot <mateusz at loskot.net>
+GEOS_ROOT=..
+!INCLUDE $(GEOS_ROOT)\nmake.opt
+!INCLUDE dirlist.mk
+# Output location
+# TODO: not yet supported
+#OUT_DIR = $(GEOS_ROOT)\bin\$(BUILD_DIR)
+# List of objects
+OBJ_EXT = obj
+EXT = $(OBJ_EXT)
+OBJ = \
+ algorithm\Angle.$(EXT) \
+ algorithm\BoundaryNodeRule.$(EXT) \
+ algorithm\Centroid.$(EXT) \
+ algorithm\CentroidArea.$(EXT) \
+ algorithm\CentroidLine.$(EXT) \
+ algorithm\CentroidPoint.$(EXT) \
+ algorithm\CGAlgorithms.$(EXT) \
+ algorithm\ConvexHull.$(EXT) \
+ algorithm\HCoordinate.$(EXT) \
+ algorithm\InteriorPointArea.$(EXT) \
+ algorithm\InteriorPointLine.$(EXT) \
+ algorithm\InteriorPointPoint.$(EXT) \
+ algorithm\LineIntersector.$(EXT) \
+ algorithm\MinimumDiameter.$(EXT) \
+ algorithm\NotRepresentableException.$(EXT) \
+ algorithm\PointLocator.$(EXT) \
+ algorithm\RayCrossingCounter.$(EXT) \
+ algorithm\RobustDeterminant.$(EXT) \
+ algorithm\SimplePointInRing.$(EXT) \
+ algorithm\SIRtreePointInRing.$(EXT) \
+ algorithm\distance\DiscreteHausdorffDistance.$(EXT) \
+ algorithm\distance\DiscreteFrechetDistance.$(EXT) \
+ algorithm\distance\DistanceToPoint.$(EXT) \
+ algorithm\locate\IndexedPointInAreaLocator.$(EXT) \
+ algorithm\locate\PointOnGeometryLocator.$(EXT) \
+ algorithm\locate\SimplePointInAreaLocator.$(EXT) \
+ geom\Coordinate.$(EXT) \
+ geom\CoordinateArraySequence.$(EXT) \
+ geom\CoordinateArraySequenceFactory.$(EXT) \
+ geom\CoordinateSequence.$(EXT) \
+ geom\CoordinateSequenceFactory.$(EXT) \
+ geom\Dimension.$(EXT) \
+ geom\Envelope.$(EXT) \
+ geom\Geometry.$(EXT) \
+ geom\GeometryCollection.$(EXT) \
+ geom\GeometryComponentFilter.$(EXT) \
+ geom\GeometryFactory.$(EXT) \
+ geom\IntersectionMatrix.$(EXT) \
+ geom\LinearRing.$(EXT) \
+ geom\LineSegment.$(EXT) \
+ geom\LineString.$(EXT) \
+ geom\Location.$(EXT) \
+ geom\MultiLineString.$(EXT) \
+ geom\MultiPoint.$(EXT) \
+ geom\MultiPolygon.$(EXT) \
+ geom\Point.$(EXT) \
+ geom\Polygon.$(EXT) \
+ geom\PrecisionModel.$(EXT) \
+ geom\Triangle.$(EXT) \
+ geom\util\ComponentCoordinateExtracter.$(EXT) \
+ geom\util\CoordinateOperation.$(EXT) \
+ geom\util\GeometryEditor.$(EXT) \
+ geom\util\GeometryTransformer.$(EXT) \
+ geom\util\GeometryCombiner.$(EXT) \
+ geom\util\ShortCircuitedGeometryVisitor.$(EXT) \
+ geom\util\SineStarFactory.$(EXT) \
+ geom\util\LinearComponentExtracter.$(EXT) \
+ geom\util\PolygonExtracter.$(EXT) \
+ geom\util\PointExtracter.$(EXT) \
+ geom\prep\AbstractPreparedPolygonContains.$(EXT) \
+ geom\prep\BasicPreparedGeometry.$(EXT) \
+ geom\prep\PreparedGeometry.$(EXT) \
+ geom\prep\PreparedGeometryFactory.$(EXT) \
+ geom\prep\PreparedLineString.$(EXT) \
+ geom\prep\PreparedLineStringIntersects.$(EXT) \
+ geom\prep\PreparedPoint.$(EXT) \
+ geom\prep\PreparedPolygon.$(EXT) \
+ geom\prep\PreparedPolygonContains.$(EXT) \
+ geom\prep\PreparedPolygonContainsProperly.$(EXT) \
+ geom\prep\PreparedPolygonCovers.$(EXT) \
+ geom\prep\PreparedPolygonIntersects.$(EXT) \
+ geom\prep\PreparedPolygonPredicate.$(EXT) \
+ geomgraph\Depth.$(EXT) \
+ geomgraph\DirectedEdge.$(EXT) \
+ geomgraph\DirectedEdgeStar.$(EXT) \
+ geomgraph\Edge.$(EXT) \
+ geomgraph\EdgeEnd.$(EXT) \
+ geomgraph\EdgeEndStar.$(EXT) \
+ geomgraph\EdgeIntersectionList.$(EXT) \
+ geomgraph\EdgeList.$(EXT) \
+ geomgraph\EdgeNodingValidator.$(EXT) \
+ geomgraph\EdgeRing.$(EXT) \
+ geomgraph\GeometryGraph.$(EXT) \
+ geomgraph\GraphComponent.$(EXT) \
+ geomgraph\Label.$(EXT) \
+ geomgraph\Node.$(EXT) \
+ geomgraph\NodeFactory.$(EXT) \
+ geomgraph\NodeMap.$(EXT) \
+ geomgraph\PlanarGraph.$(EXT) \
+ geomgraph\Position.$(EXT) \
+ geomgraph\Quadrant.$(EXT) \
+ geomgraph\TopologyLocation.$(EXT) \
+ geomgraph\index\MonotoneChainEdge.$(EXT) \
+ geomgraph\index\MonotoneChainIndexer.$(EXT) \
+ geomgraph\index\SegmentIntersector.$(EXT) \
+ geomgraph\index\SimpleEdgeSetIntersector.$(EXT) \
+ geomgraph\index\SimpleMCSweepLineIntersector.$(EXT) \
+ geomgraph\index\SimpleSweepLineIntersector.$(EXT) \
+ geomgraph\index\SweepLineEvent.$(EXT) \
+ geomgraph\index\SweepLineSegment.$(EXT) \
+ index\bintree\Bintree.$(EXT) \
+ index\bintree\Interval.$(EXT) \
+ index\bintree\Key.$(EXT) \
+ index\bintree\Node.$(EXT) \
+ index\bintree\NodeBase.$(EXT) \
+ index\bintree\Root.$(EXT) \
+ index\chain\MonotoneChain.$(EXT) \
+ index\chain\MonotoneChainBuilder.$(EXT) \
+ index\chain\MonotoneChainOverlapAction.$(EXT) \
+ index\chain\MonotoneChainSelectAction.$(EXT) \
+ index\intervalrtree\IntervalRTreeBranchNode.$(EXT) \
+ index\intervalrtree\IntervalRTreeLeafNode.$(EXT) \
+ index\intervalrtree\SortedPackedIntervalRTree.$(EXT) \
+ index\quadtree\DoubleBits.$(EXT) \
+ index\quadtree\IntervalSize.$(EXT) \
+ index\quadtree\Key.$(EXT) \
+ index\quadtree\Node.$(EXT) \
+ index\quadtree\NodeBase.$(EXT) \
+ index\quadtree\Root.$(EXT) \
+ index\quadtree\Quadtree.$(EXT) \
+ index\strtree\AbstractNode.$(EXT) \
+ index\strtree\AbstractSTRtree.$(EXT) \
+ index\strtree\BoundablePair.$(EXT) \
+ index\strtree\GeometryItemDistance.$(EXT) \
+ index\strtree\Interval.$(EXT) \
+ index\strtree\ItemBoundable.$(EXT) \
+ index\strtree\SIRtree.$(EXT) \
+ index\strtree\STRtree.$(EXT) \
+ index\sweepline\SweepLineEvent.$(EXT) \
+ index\sweepline\SweepLineIndex.$(EXT) \
+ index\sweepline\SweepLineInterval.$(EXT) \
+ io\ByteOrderDataInStream.$(EXT) \
+ io\ByteOrderValues.$(EXT) \
+ io\CLocalizer.$(EXT) \
+ io\ParseException.$(EXT) \
+ io\StringTokenizer.$(EXT) \
+ io\Unload.$(EXT) \
+ io\WKBReader.$(EXT) \
+ io\WKBWriter.$(EXT) \
+ io\WKTReader.$(EXT) \
+ io\WKTWriter.$(EXT) \
+ io\Writer.$(EXT) \
+ noding\BasicSegmentString.$(EXT) \
+ noding\FastNodingValidator.$(EXT) \
+ noding\FastSegmentSetIntersectionFinder.$(EXT) \
+ noding\GeometryNoder.$(EXT) \
+ noding\IntersectionAdder.$(EXT) \
+ noding\IntersectionFinderAdder.$(EXT) \
+ noding\IteratedNoder.$(EXT) \
+ noding\MCIndexNoder.$(EXT) \
+ noding\MCIndexSegmentSetMutualIntersector.$(EXT) \
+ noding\NodedSegmentString.$(EXT) \
+ noding\NodingValidator.$(EXT) \
+ noding\Octant.$(EXT) \
+ noding\OrientedCoordinateArray.$(EXT) \
+ noding\ScaledNoder.$(EXT) \
+ noding\SegmentIntersectionDetector.$(EXT) \
+ noding\SegmentNode.$(EXT) \
+ noding\SegmentNodeList.$(EXT) \
+ noding\SegmentString.$(EXT) \
+ noding\SegmentStringUtil.$(EXT) \
+ noding\SimpleNoder.$(EXT) \
+ noding\SingleInteriorIntersectionFinder.$(EXT) \
+ noding\snapround\HotPixel.$(EXT) \
+ noding\snapround\MCIndexPointSnapper.$(EXT) \
+ noding\snapround\MCIndexSnapRounder.$(EXT) \
+ noding\snapround\SimpleSnapRounder.$(EXT) \
+ operation\GeometryGraphOperation.$(EXT) \
+ operation\IsSimpleOp.$(EXT) \
+ operation\buffer\BufferBuilder.$(EXT) \
+ operation\buffer\BufferInputLineSimplifier.$(EXT) \
+ operation\buffer\BufferParameters.$(EXT) \
+ operation\buffer\BufferOp.$(EXT) \
+ operation\buffer\BufferSubgraph.$(EXT) \
+ operation\buffer\OffsetCurveBuilder.$(EXT) \
+ operation\buffer\OffsetCurveSetBuilder.$(EXT) \
+ operation\buffer\OffsetSegmentGenerator.$(EXT) \
+ operation\buffer\RightmostEdgeFinder.$(EXT) \
+ operation\buffer\SubgraphDepthLocater.$(EXT) \
+ operation\distance\ConnectedElementLocationFilter.$(EXT) \
+ operation\distance\ConnectedElementPointFilter.$(EXT) \
+ operation\distance\DistanceOp.$(EXT) \
+ operation\distance\FacetSequence.$(EXT) \
+ operation\distance\FacetSequenceTreeBuilder.$(EXT) \
+ operation\distance\GeometryLocation.$(EXT) \
+ operation\distance\IndexedFacetDistance.$(EXT) \
+ operation\intersection\Rectangle.$(EXT) \
+ operation\intersection\RectangleIntersection.$(EXT) \
+ operation\intersection\RectangleIntersectionBuilder.$(EXT) \
+ operation\linemerge\EdgeString.$(EXT) \
+ operation\linemerge\LineMergeDirectedEdge.$(EXT) \
+ operation\linemerge\LineMergeEdge.$(EXT) \
+ operation\linemerge\LineMergeGraph.$(EXT) \
+ operation\linemerge\LineMerger.$(EXT) \
+ operation\linemerge\LineSequencer.$(EXT) \
+ operation\overlay\EdgeSetNoder.$(EXT) \
+ operation\overlay\ElevationMatrix.$(EXT) \
+ operation\overlay\ElevationMatrixCell.$(EXT) \
+ operation\overlay\LineBuilder.$(EXT) \
+ operation\overlay\MaximalEdgeRing.$(EXT) \
+ operation\overlay\MinimalEdgeRing.$(EXT) \
+ operation\overlay\OverlayNodeFactory.$(EXT) \
+ operation\overlay\OverlayOp.$(EXT) \
+ operation\overlay\PointBuilder.$(EXT) \
+ operation\overlay\PolygonBuilder.$(EXT) \
+ operation\overlay\snap\GeometrySnapper.$(EXT) \
+ operation\overlay\snap\LineStringSnapper.$(EXT) \
+ operation\overlay\snap\SnapOverlayOp.$(EXT) \
+ operation\overlay\snap\SnapIfNeededOverlayOp.$(EXT) \
+ operation\overlay\validate\FuzzyPointLocator.$(EXT) \
+ operation\overlay\validate\OffsetPointGenerator.$(EXT) \
+ operation\overlay\validate\OverlayResultValidator.$(EXT) \
+ operation\polygonize\PolygonizeDirectedEdge.$(EXT) \
+ operation\polygonize\PolygonizeEdge.$(EXT) \
+ operation\polygonize\EdgeRing.$(EXT) \
+ operation\polygonize\PolygonizeGraph.$(EXT) \
+ operation\polygonize\Polygonizer.$(EXT) \
+ operation\predicate\RectangleContains.$(EXT) \
+ operation\predicate\RectangleIntersects.$(EXT) \
+ operation\predicate\SegmentIntersectionTester.$(EXT) \
+ operation\relate\EdgeEndBuilder.$(EXT) \
+ operation\relate\EdgeEndBundle.$(EXT) \
+ operation\relate\EdgeEndBundleStar.$(EXT) \
+ operation\relate\RelateComputer.$(EXT) \
+ operation\relate\RelateNode.$(EXT) \
+ operation\relate\RelateNodeFactory.$(EXT) \
+ operation\relate\RelateNodeGraph.$(EXT) \
+ operation\relate\RelateOp.$(EXT) \
+ operation\sharedpaths\SharedPathsOp.$(EXT) \
+ operation\union\CascadedPolygonUnion.$(EXT) \
+ operation\union\CascadedUnion.$(EXT) \
+ operation\union\PointGeometryUnion.$(EXT) \
+ operation\union\UnaryUnionOp.$(EXT) \
+ operation\valid\ConnectedInteriorTester.$(EXT) \
+ operation\valid\ConsistentAreaTester.$(EXT) \
+ operation\valid\IndexedNestedRingTester.$(EXT) \
+ operation\valid\IsValidOp.$(EXT) \
+ operation\valid\QuadtreeNestedRingTester.$(EXT) \
+ operation\valid\RepeatedPointTester.$(EXT) \
+ operation\valid\SimpleNestedRingTester.$(EXT) \
+ operation\valid\SweeplineNestedRingTester.$(EXT) \
+ operation\valid\TopologyValidationError.$(EXT) \
+ planargraph\DirectedEdge.$(EXT) \
+ planargraph\DirectedEdgeStar.$(EXT) \
+ planargraph\Edge.$(EXT) \
+ planargraph\Node.$(EXT) \
+ planargraph\NodeMap.$(EXT) \
+ planargraph\PlanarGraph.$(EXT) \
+ planargraph\Subgraph.$(EXT) \
+ planargraph\algorithm\ConnectedSubgraphFinder.$(EXT) \
+ precision\CommonBits.$(EXT) \
+ precision\CommonBitsOp.$(EXT) \
+ precision\CommonBitsRemover.$(EXT) \
+ precision\EnhancedPrecisionOp.$(EXT) \
+ precision\GeometryPrecisionReducer.$(EXT) \
+ precision\MinimumClearance.$(EXT) \
+ precision\PrecisionReducerCoordinateOperation.$(EXT) \
+ precision\SimpleGeometryPrecisionReducer.$(EXT) \
+ simplify\DouglasPeuckerLineSimplifier.$(EXT) \
+ simplify\DouglasPeuckerSimplifier.$(EXT) \
+ simplify\LineSegmentIndex.$(EXT) \
+ simplify\TaggedLineSegment.$(EXT) \
+ simplify\TaggedLinesSimplifier.$(EXT) \
+ simplify\TaggedLineString.$(EXT) \
+ simplify\TaggedLineStringSimplifier.$(EXT) \
+ simplify\TopologyPreservingSimplifier.$(EXT) \
+ triangulate\DelaunayTriangulationBuilder.$(EXT) \
+ triangulate\IncrementalDelaunayTriangulator.$(EXT) \
+ triangulate\VoronoiDiagramBuilder.$(EXT) \
+ triangulate\quadedge\LastFoundQuadEdgeLocator.$(EXT) \
+ triangulate\quadedge\LocateFailureException.$(EXT) \
+ triangulate\quadedge\QuadEdge.$(EXT) \
+ triangulate\quadedge\QuadEdgeLocator.$(EXT) \
+ triangulate\quadedge\QuadEdgeSubdivision.$(EXT) \
+ triangulate\quadedge\TrianglePredicate.$(EXT) \
+ triangulate\quadedge\TriangleVisitor.$(EXT) \
+ triangulate\quadedge\Vertex.$(EXT) \
+ util\Assert.$(EXT) \
+ util\GeometricShapeFactory.$(EXT) \
+ util\Interrupt.$(EXT) \
+ util\math.$(EXT) \
+ util\Profiler.$(EXT) \
+ linearref\ExtractLineByLocation.$(EXT) \
+ linearref\LengthIndexOfPoint.$(EXT) \
+ linearref\LengthIndexedLine.$(EXT) \
+ linearref\LengthLocationMap.$(EXT) \
+ linearref\LinearGeometryBuilder.$(EXT) \
+ linearref\LinearIterator.$(EXT) \
+ linearref\LinearLocation.$(EXT) \
+ linearref\LocationIndexOfLine.$(EXT) \
+ linearref\LocationIndexOfPoint.$(EXT) \
+ ..\capi\geos_c.$(EXT) \
+ ..\capi\geos_ts_c.$(EXT) \
+ inlines.$(EXT)
+TEST_EXE = TestSweepLineSpeed.exe
+# Build targets
+default: $(LIBNAME) $(DLLNAME) $(CDLLNAME)
+all: $(LIBNAME) $(DLLNAME) $(CDLLNAME) TestSweepLineSpeed.exe geostest.exe
+check: all
+ TestSweepLineSpeed.exe
+$(LIBNAME): $(GEOS_ROOT)\include\geos\platform.h $(GEOS_ROOT)\include\geos\version.h ..\capi\geos_c.h $(OBJ)
+ if exist $(LIBNAME) del $(LIBNAME)
+ $(LINK) /lib /out:$(LIBNAME) $(OBJ)
+$(DLLNAME): $(OBJ)
+ $(LINK) /dll /debug $(LINKER_FLAGS) $(OBJ) /out:$(DLLNAME) /implib:$(SLIBNAME)
+ if exist $(DLLNAME).manifest mt -manifest $(DLLNAME).manifest -outputresource:$(DLLNAME);2
+$(CDLLNAME): ..\capi\geos_c.obj ..\capi\geos_ts_c.obj $(DLLNAME)
+ $(LINK) /dll /debug $(LINKER_FLAGS) ..\capi\geos_c.obj ..\capi\geos_ts_c.obj $(LIBNAME) /out:$(CDLLNAME) /implib:$(CLIBNAME)
+ if exist $(CDLLNAME).manifest mt -manifest $(CDLLNAME).manifest -outputresource:$(CDLLNAME);2
+$(GEOS_ROOT)\include\geos\platform.h: $(GEOS_ROOT)\include\geos\platform.h.vc
+ $(CP) $(GEOS_ROOT)\include\geos\platform.h.vc $(GEOS_ROOT)\include\geos\platform.h
+$(GEOS_ROOT)\include\geos\version.h: $(GEOS_ROOT)\include\geos\version.h.vc
+ if not exist $(GEOS_ROOT)\include\geos\version.h $(CP) $(GEOS_ROOT)\include\geos\version.h.vc $(GEOS_ROOT)\include\geos\version.h
+# geos_c.h should already be in distribution, if is not you'll
+# have to run ./configure to recreate
+../capi/geos_c.h: ../capi/geos_c.h.in.
+ $(CP) ..\capi\geos_c.h.in ..\capi\geos_c.h
+.cpp.obj:
+ $(CC) $(CFLAGS) /c $*.cpp /Fo$@
+{..\capi}.cpp.obj:
+ $(CC) $(CFLAGS) /D "GEOS_DLL_EXPORT" /c $*.cpp /Fo$@
+.c.obj:
+ $(CC) $(CFLAGS) /c $*.c /Fo$@
+clean:
+ @ECHO "*** Cleaning GEOS source tree"
+ @IF EXIST $(LIBNAME) $(RM) $(LIBNAME)
+ @IF EXIST $(SLIBNAME) $(RM) $(SLIBNAME)
+ @IF EXIST $(DLLNAME) $(RM) $(DLLNAME)
+ @IF EXIST $(CLIBNAME) $(RM) $(CLIBNAME)
+ @IF EXIST $(CDLLNAME) $(RM) $(CDLLNAME)
+ - at del /s *.exe
+ - at del /s *.exp
+ - at del /s *.ilk
+ - at del /s *.manifest
+ - at del /s *.obj
+ - at del /s *.pdb
+TestSweepLineSpeed.exe: $(LIBNAME) \
+ ..\tests\bigtest\GeometryTestFactory.obj \
+ ..\tests\bigtest\TestSweepLineSpeed.obj
+ $(LINK) /debug /out:TestSweepLineSpeed.exe \
+ ..\tests\bigtest\TestSweepLineSpeed.obj \
+ $(LIBNAME)
+geostest.exe: $(CDLLNAME) ..\tests\unit\capi\geostest.obj
+ $(LINK) /debug ..\tests\unit\capi\geostest.obj $(CLIBNAME)
+# EOF
diff --git a/src/algorithm/MCPointInRing.cpp b/src/algorithm/MCPointInRing.cpp
index d085908..0000000
--- a/src/algorithm/MCPointInRing.cpp
+++ /dev/null
@@ -1,151 +0,0 @@
- * Copyright (C) 2006 Refractions Research Inc.
-#include <geos/algorithm/MCPointInRing.h>
-#include <geos/algorithm/RobustDeterminant.h>
-#include <geos/index/bintree/Bintree.h>
-#include <geos/geom/LineSegment.h>
-#include <geos/geom/LinearRing.h>
-#include <geos/geom/CoordinateSequence.h>
-#include <geos/geom/Envelope.h>
-#include <geos/index/chain/MonotoneChain.h>
-#include <geos/index/chain/MonotoneChainBuilder.h>
-#include <vector>
-using namespace std;
-using namespace geos::geom;
-using namespace geos::index;
-namespace geos {
-namespace algorithm { // geos.algorithm
-MCPointInRing::MCSelecter::MCSelecter(const Coordinate& newP,
- MCPointInRing *prt)
- MonotoneChainSelectAction()
- p=newP;
- parent=prt;
-/* public overridden */
-void
-MCPointInRing::MCSelecter::select(const LineSegment& ls)
- parent->testLineSegment(p, ls);
-MCPointInRing::MCPointInRing(const LinearRing *newRing)
- ring(newRing),
- interval(),
- pts(nullptr),
- tree(nullptr),
- crossings(0)
- buildIndex();
-MCPointInRing::~MCPointInRing() = default;
-void
-MCPointInRing::buildIndex()
- tree.reset(new bintree::Bintree());
- pts.reset(CoordinateSequence::removeRepeatedPoints(ring->getCoordinatesRO()));
- chains = chain::MonotoneChainBuilder::getChains(pts.get());
- for(const auto& mc : *chains)
- const Envelope& mcEnv = mc->getEnvelope();
- interval.min = mcEnv.getMinY();
- interval.max = mcEnv.getMaxY();
- tree->insert(&interval, mc.get());
-bool
-MCPointInRing::isInside(const Coordinate& pt)
- crossings=0;
- // test all segments intersected by ray from pt in positive x direction
- Envelope rayEnv(DoubleNegInfinity,DoubleInfinity,pt.y,pt.y);
- interval.min=pt.y;
- interval.max=pt.y;
- std::unique_ptr<vector<void*>> segs{tree->query(&interval)};
- MCSelecter mcSelecter(pt,this);
- for(auto& seg : *segs) {
- chain::MonotoneChain *mc= reinterpret_cast<chain::MonotoneChain*>(seg);
- testMonotoneChain(&rayEnv,&mcSelecter,mc);
- * p is inside if number of crossings is odd.
- return crossings % 2 == 1;
-void
-MCPointInRing::testMonotoneChain(Envelope *rayEnv,
- chain::MonotoneChain *mc)
- mc->select(*rayEnv, *mcSelecter);
-void
-MCPointInRing::testLineSegment(const Coordinate& p, const LineSegment& seg)
- double xInt; // x intersection of segment with ray
- double x1; // translated coordinates
- double y1;
- double x2;
- double y2;
- * Test if segment crosses ray from test point in positive x direction.
- const Coordinate& p1 = seg.p0;
- const Coordinate& p2 = seg.p1;
- x1 = p1.x - p.x;
- y1 = p1.y - p.y;
- x2 = p2.x - p.x;
- y2 = p2.y - p.y;
- if (((y1>0)&&(y2<=0)) || ((y2>0)&&(y1<=0)))
- * segment straddles x axis, so compute intersection.
- xInt=RobustDeterminant::signOfDet2x2(x1,y1,x2,y2)/(y2-y1);
- * crosses ray if strictly positive intersection.
- if (0.0<xInt) {
- crossings++;
-} // namespace geos.algorithm
diff --git a/src/algorithm/Makefile.am b/src/algorithm/Makefile.am
index f735bce..082a2a9 100644
--- a/src/algorithm/Makefile.am
+++ b/src/algorithm/Makefile.am
@@ -24,7 +24,6 @@ libalgorithm_la_SOURCES = \
InteriorPointLine.cpp \
InteriorPointPoint.cpp \
LineIntersector.cpp \
- MCPointInRing.cpp \
MinimumDiameter.cpp \
NotRepresentableException.cpp \
PointLocator.cpp \
commit 9674b7de0c95f9c9976621b8024759b4dcbf334b
Date: Wed Dec 12 14:55:01 2018 -0800
A little clean up, but not quite full deprecation
as indicated in JTS 95f19c41741a5261c324f038f355549cab8be5a8
index 61ebd59..6a833e7 100644
+++ b/include/geos/algorithm/MCPointInRing.h
@@ -22,6 +22,7 @@
#include <memory>
#include <vector>
diff --git a/include/geos/geosAlgorithm.h b/include/geos/geosAlgorithm.h
index c70af39..006da80 100644
--- a/include/geos/geosAlgorithm.h
+++ b/include/geos/geosAlgorithm.h
@@ -36,7 +36,6 @@
//#include <geos/algorithm/InteriorPointLine.h>
//#include <geos/algorithm/InteriorPointPoint.h>
#include <geos/algorithm/LineIntersector.h>
-//#include <geos/algorithm/MCPointInRing.h>
//#include <geos/algorithm/MinimumDiameter.h>
//#include <geos/algorithm/NotRepresentableException.h>
//#include <geos/algorithm/PointInRing.h>
diff --git a/src/operation/valid/IsValidOp.cpp b/src/operation/valid/IsValidOp.cpp
index 08b3149..a77732f 100644
--- a/src/operation/valid/IsValidOp.cpp
+++ b/src/operation/valid/IsValidOp.cpp
@@ -21,10 +21,10 @@
#include "IndexedNestedRingTester.h" // TODO: private header>? --mloskot
+#include <geos/export.h>
#include <geos/platform.h>
#include <geos/algorithm/CGAlgorithms.h>
#include <geos/algorithm/locate/IndexedPointInAreaLocator.h>
#include <geos/operation/valid/ConnectedInteriorTester.h>
#include <geos/operation/valid/ConsistentAreaTester.h>
@@ -40,8 +40,10 @@
#include <geos/geomgraph/GeometryGraph.h>
#include <geos/geomgraph/Edge.h>
#include <geos/geomgraph/index/SegmentIntersector.h>
+#include <geos/index/chain/MonotoneChainSelectAction.h>
#include <geos/util/UnsupportedOperationException.h>
#include <cassert>
#include <cmath>
#include <typeinfo>
@@ -396,9 +398,6 @@ IsValidOp::checkHolesInShell(const Polygon *p, GeometryGraph *graph)
return;
- //SimplePointInRing pir(shell);
- //SIRtreePointInRing pir(shell);
- // MCPointInRing pir(shell);
locate::IndexedPointInAreaLocator ipial(*shellgeom);
for(size_t i = 0; i < nholes; ++i) {
Summary of changes:
include/geos/algorithm/MCPointInRing.h | 84 ----
include/geos/algorithm/Makefile.am | 1 -
include/geos/geosAlgorithm.h | 1 -
src/Makefile.vc | 799 ++++++++++++++++-----------------
src/algorithm/MCPointInRing.cpp | 151 -------
src/algorithm/Makefile.am | 1 -
src/operation/valid/IsValidOp.cpp | 7 +-
7 files changed, 402 insertions(+), 642 deletions(-)
delete mode 100644 include/geos/algorithm/MCPointInRing.h
delete mode 100644 src/algorithm/MCPointInRing.cpp
hooks/post-receive
More information about the geos-commits
