[geos-commits] [SCM] GEOS branch master updated. 6fa30ee64b91f3456c4b6435cb6713ad1c6cdebc
git at osgeo.org
git at osgeo.org
Thu Dec 13 15:28:17 PST 2018
the project "GEOS".
via 6fa30ee64b91f3456c4b6435cb6713ad1c6cdebc (commit)
from 949b1eba15df850437a805497accccdaaaf99bac (commit)
revisions in full, below.
commit 6fa30ee64b91f3456c4b6435cb6713ad1c6cdebc
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Thu Dec 13 15:27:49 2018 -0800
Remove CentroidArea, CentroidLine, CentroidPoint as per
JTS 0a775496322c11bc6d838acf99d0106b926a13aa
diff --git a/include/geos/algorithm/CentroidArea.h b/include/geos/algorithm/CentroidArea.h
deleted file mode 100644
index 186d792..0000000
--- a/include/geos/algorithm/CentroidArea.h
+++ /dev/null
@@ -1,147 +0,0 @@
- * GEOS - Geometry Engine Open Source
- * http://geos.osgeo.org
- * Copyright (C) 2005-2006 Refractions Research Inc.
- * Copyright (C) 2001-2002 Vivid Solutions Inc.
- * This is free software; you can redistribute and/or modify it under
- * the terms of the GNU Lesser General Public Licence as published
- * by the Free Software Foundation.
- * See the COPYING file for more information.
- * Last port: algorithm/CentroidArea.java r612
-#ifndef GEOS_ALGORITHM_CENTROIDAREA_H
-#define GEOS_ALGORITHM_CENTROIDAREA_H
-#include <geos/export.h>
-#include <geos/geom/Coordinate.h>
-// Forward declarations
-namespace geos {
- namespace geom {
- class CoordinateSequence;
- class Geometry;
- class Polygon;
-namespace geos {
-namespace algorithm { // geos::algorithm
- * \class CentroidArea geosAlgorithm.h geos/geosAlgorithm.h
- * \brief Computes the centroid of an area geometry.
- * Algorithm:
- * Based on the usual algorithm for calculating
- * the centroid as a weighted sum of the centroids
- * of a decomposition of the area into (possibly overlapping) triangles.
- * The algorithm has been extended to handle holes and multi-polygons.
- * See <code>http://www.faqs.org/faqs/graphics/algorithms-faq/</code>
- * for further details of the basic approach.
- * The code has also be extended to handle degenerate (zero-area) polygons.
- * In this case, the centroid of the line segments in the polygon
- * will be returned.
- * @deprecated use Centroid instead
-class GEOS_DLL CentroidArea {
-public:
- CentroidArea()
- basePt(0.0, 0.0),
- areasum2(0.0),
- totalLength(0.0)
- ~CentroidArea() {}
- * Adds the area defined by a Geometry to the centroid total.
- * If the geometry has no area it does not contribute to the centroid.
- * @param geom the geometry to add
- void add(const geom::Geometry *geom);
- * Adds the area defined by an array of
- * coordinates. The array must be a ring;
- * i.e. end with the same coordinate as it starts with.
- * @param ring an array of {@link Coordinate}s
- void add(const geom::CoordinateSequence *ring);
- // TODO: deprecate
- geom::Coordinate* getCentroid() const;
- /// Return false if a centroid couldn't be computed ( empty polygon )
- bool getCentroid(geom::Coordinate& ret) const;
-private:
- /// the point all triangles are based at
- geom::Coordinate basePt;
- // temporary variable to hold centroid of triangle
- geom::Coordinate triangleCent3;
- /// Partial area sum
- double areasum2;
- /// partial centroid sum
- geom::Coordinate cg3;
- // data for linear centroid computation, if needed
- geom::Coordinate centSum;
- double totalLength;
- void setBasePoint(const geom::Coordinate &newbasePt);
- void add(const geom::Polygon *poly);
- void addShell(const geom::CoordinateSequence *pts);
- void addHole(const geom::CoordinateSequence *pts);
- void addTriangle(const geom::Coordinate &p0, const geom::Coordinate &p1,
- const geom::Coordinate &p2,bool isPositiveArea);
- static void centroid3(const geom::Coordinate &p1, const geom::Coordinate &p2,
- const geom::Coordinate &p3, geom::Coordinate &c);
- static double area2(const geom::Coordinate &p1, const geom::Coordinate &p2,
- const geom::Coordinate &p3);
- * Adds the linear segments defined by an array of coordinates
- * to the linear centroid accumulators.
- * This is done in case the polygon(s) have zero-area,
- * in which case the linear centroid is computed instead.
- * @param pts an array of {@link Coordinate}s
- void addLinearSegments(const geom::CoordinateSequence& pts);
-} // namespace geos::algorithm
-#endif // GEOS_ALGORITHM_CENTROIDAREA_H
diff --git a/include/geos/algorithm/CentroidLine.h b/include/geos/algorithm/CentroidLine.h
index 8d58ffd..0000000
--- a/include/geos/algorithm/CentroidLine.h
+++ /dev/null
@@ -1,77 +0,0 @@
-#ifndef GEOS_ALGORITHM_CENTROIDLINE_H
-#define GEOS_ALGORITHM_CENTROIDLINE_H
-namespace geos {
- namespace geom {
- class Geometry;
-namespace geos {
-/// @deprecated use Centroid instead
-class GEOS_DLL CentroidLine {
-private:
-public:
- CentroidLine()
- centSum(0.0, 0.0),
- totalLength(0.0)
- ~CentroidLine() {}
- /** \brief
- * Adds the linestring(s) defined by a Geometry to the centroid total.
- * If the geometry is not linear it does not contribute to the centroid
- /** \brief
- * Adds the length defined by an array of coordinates.
- * @param pts an array of {@link geom::Coordinate}s
- void add(const geom::CoordinateSequence *pts);
- /// return false if centroid could not be computed
-#endif // GEOS_ALGORITHM_CENTROIDLINE_H
diff --git a/include/geos/algorithm/CentroidPoint.h b/include/geos/algorithm/CentroidPoint.h
index ef2fee2..0000000
--- a/include/geos/algorithm/CentroidPoint.h
+++ /dev/null
@@ -1,72 +0,0 @@
-#ifndef GEOS_ALGORITHM_CENTROIDPOINT_H
-#define GEOS_ALGORITHM_CENTROIDPOINT_H
-namespace geos {
- namespace geom {
- class Geometry;
-namespace geos {
-class GEOS_DLL CentroidPoint {
-private:
- int ptCount;
-public:
- CentroidPoint()
- ptCount(0),
- centSum(0.0, 0.0)
- ~CentroidPoint()
- * Adds the point(s) defined by a Geometry to the centroid total.
- * If the geometry is not of dimension 0 it does not contribute to the
- * centroid.
- void add(const geom::Coordinate *pt);
- /// Return false if centroid could not be computed
-#endif // GEOS_ALGORITHM_CENTROIDPOINT_H
diff --git a/include/geos/algorithm/Makefile.am b/include/geos/algorithm/Makefile.am
index 6abf2f5..19f13c9 100644
--- a/include/geos/algorithm/Makefile.am
+++ b/include/geos/algorithm/Makefile.am
@@ -15,9 +15,6 @@ geos_HEADERS = \
BoundaryNodeRule.h \
CentralEndpointIntersector.h \
Centroid.h \
- CentroidArea.h \
- CentroidLine.h \
- CentroidPoint.h \
CGAlgorithms.h \
ConvexHull.h \
ConvexHull.inl \
diff --git a/include/geos/geosAlgorithm.h b/include/geos/geosAlgorithm.h
index 006da80..1a93e24 100644
--- a/include/geos/geosAlgorithm.h
+++ b/include/geos/geosAlgorithm.h
@@ -27,9 +27,6 @@
#define GEOS_ALGORITHM_H
//#include <geos/algorithm/CGAlgorithms.h>
-//#include <geos/algorithm/CentroidArea.h>
-//#include <geos/algorithm/CentroidLine.h>
-//#include <geos/algorithm/CentroidPoint.h>
//#include <geos/algorithm/ConvexHull.h>
//#include <geos/algorithm/HCoordinate.h>
//#include <geos/algorithm/InteriorPointArea.h>
diff --git a/src/Makefile.vc b/src/Makefile.vc
index 3874378..803d3bd 100644
--- a/src/Makefile.vc
+++ b/src/Makefile.vc
@@ -33,9 +33,6 @@ OBJ = \
algorithm\Angle.$(EXT) \
algorithm\BoundaryNodeRule.$(EXT) \
algorithm\Centroid.$(EXT) \
- algorithm\CentroidArea.$(EXT) \
- algorithm\CentroidLine.$(EXT) \
- algorithm\CentroidPoint.$(EXT) \
algorithm\CGAlgorithms.$(EXT) \
algorithm\ConvexHull.$(EXT) \
algorithm\HCoordinate.$(EXT) \
diff --git a/src/algorithm/CentroidArea.cpp b/src/algorithm/CentroidArea.cpp
index 607d98e..0000000
--- a/src/algorithm/CentroidArea.cpp
+++ /dev/null
@@ -1,175 +0,0 @@
- * Copyright (C) 2006 Refractions Research Inc.
-#include <geos/algorithm/CentroidArea.h>
-#include <geos/algorithm/CGAlgorithms.h>
-#include <geos/geom/CoordinateSequence.h>
-#include <geos/geom/Geometry.h>
-#include <geos/geom/GeometryCollection.h>
-#include <geos/geom/LineString.h>
-#include <geos/geom/Polygon.h>
-#include <typeinfo>
-using namespace geos::geom;
-namespace geos {
-namespace algorithm { // geos.algorithm
-/*public*/
-void
-CentroidArea::add(const Geometry *geom)
- if(geom->isEmpty()) return;
- else if(const Polygon *poly=dynamic_cast<const Polygon*>(geom)) {
- setBasePoint(poly->getExteriorRing()->getCoordinateN(0));
- add(poly);
- else if(const GeometryCollection *gc=dynamic_cast<const GeometryCollection*>(geom))
- for(std::size_t i=0, n=gc->getNumGeometries(); i<n; ++i)
- add(gc->getGeometryN(i));
-/*public*/
-void
-CentroidArea::add(const CoordinateSequence *ring)
- setBasePoint(ring->getAt(0));
- addShell(ring);
-/* TODO: deprecate this */
-Coordinate*
-CentroidArea::getCentroid() const
- Coordinate *cent = new Coordinate();
- getCentroid(*cent); // or return NULL on failure !
- return cent;
-bool
-CentroidArea::getCentroid(Coordinate& ret) const
- if ( areasum2 ) {
- ret = Coordinate(cg3.x/3.0/areasum2, cg3.y/3.0/areasum2);
- } else if ( totalLength ) {
- ret = Coordinate(centSum.x/totalLength, centSum.y/totalLength);
- } else {
- return false;
- return true;
-void
-CentroidArea::setBasePoint(const Coordinate &newbasePt)
- basePt=newbasePt;
-void
-CentroidArea::add(const Polygon *poly)
- addShell(poly->getExteriorRing()->getCoordinatesRO());
- for(size_t i=0, n=poly->getNumInteriorRing(); i<n; ++i)
- addHole(poly->getInteriorRingN(i)->getCoordinatesRO());
-void
-CentroidArea::addShell(const CoordinateSequence *pts)
- bool isPositiveArea=!CGAlgorithms::isCCW(pts);
- std::size_t const n=pts->getSize()-1;
- for(std::size_t i=0; i<n; ++i)
- addTriangle(basePt, pts->getAt(i), pts->getAt(i+1), isPositiveArea);
- addLinearSegments(*pts);
-void
-CentroidArea::addHole(const CoordinateSequence *pts)
- bool isPositiveArea=CGAlgorithms::isCCW(pts);
-void
-CentroidArea::addTriangle(const Coordinate &p0, const Coordinate &p1,
- const Coordinate &p2, bool isPositiveArea)
- double sign=(isPositiveArea)?1.0:-1.0;
- centroid3(p0,p1,p2,triangleCent3);
- double area2res=area2(p0,p1,p2);
- cg3.x+=sign*area2res*triangleCent3.x;
- cg3.y+=sign*area2res*triangleCent3.y;
- areasum2+=sign*area2res;
- * Returns three times the centroid of the triangle p1-p2-p3.
- * The factor of 3 is
- * left in to permit division to be avoided until later.
-void
-CentroidArea::centroid3(const Coordinate &p1, const Coordinate &p2,
- const Coordinate &p3, Coordinate &c)
- c.x=p1.x+p2.x+p3.x;
- c.y=p1.y+p2.y+p3.y;
- * Returns twice the signed area of the triangle p1-p2-p3,
- * positive if a,b,c are oriented ccw, and negative if cw.
-double
-CentroidArea::area2(const Coordinate &p1, const Coordinate &p2, const Coordinate &p3)
- return (p2.x-p1.x)*(p3.y-p1.y)-(p3.x-p1.x)*(p2.y-p1.y);
-void
-CentroidArea::addLinearSegments(const geom::CoordinateSequence& pts)
- std::size_t const n = pts.size()-1;
- for (std::size_t i = 0; i < n; ++i) {
- double segmentLen = pts[i].distance(pts[i + 1]);
- totalLength += segmentLen;
- double midx = (pts[i].x + pts[i + 1].x) / 2;
- centSum.x += segmentLen * midx;
- double midy = (pts[i].y + pts[i + 1].y) / 2;
- centSum.y += segmentLen * midy;
-} // namespace geos.algorithm
-} //namespace geos
diff --git a/src/algorithm/CentroidLine.cpp b/src/algorithm/CentroidLine.cpp
index 7577fd4..0000000
--- a/src/algorithm/CentroidLine.cpp
+++ /dev/null
@@ -1,87 +0,0 @@
- * Copyright (C) 2005 Refractions Research Inc.
-#include <geos/algorithm/CentroidLine.h>
-namespace geos {
-/*public*/
-void
-CentroidLine::add(const Geometry *geom)
- const LineString* ls = dynamic_cast<const LineString*>(geom);
- if ( ls )
- add(ls->getCoordinatesRO());
- return;
- const GeometryCollection* gc = dynamic_cast<const GeometryCollection*>(geom);
- if (gc)
- for(std::size_t i=0, n=gc->getNumGeometries(); i<n; i++) {
-/*public*/
-void
-CentroidLine::add(const CoordinateSequence *pts)
- std::size_t const npts=pts->getSize();
- for(std::size_t i=1; i<npts; ++i)
- const Coordinate &p1=pts->getAt(i-1);
- const Coordinate &p2=pts->getAt(i);
- double segmentLen=p1.distance(p2);
- totalLength+=segmentLen;
- double midx=(p1.x+p2.x)/2;
- centSum.x+=segmentLen*midx;
- double midy=(p1.y+p2.y)/2;
- centSum.y+=segmentLen*midy;
-Coordinate *
-CentroidLine::getCentroid() const
- return new Coordinate(centSum.x/totalLength, centSum.y/totalLength);
-bool
-CentroidLine::getCentroid(Coordinate& c) const
- if ( totalLength == 0.0 ) return false;
- c=Coordinate(centSum.x/totalLength, centSum.y/totalLength);
- return true;
diff --git a/src/algorithm/CentroidPoint.cpp b/src/algorithm/CentroidPoint.cpp
index 49fd57c..0000000
--- a/src/algorithm/CentroidPoint.cpp
+++ /dev/null
@@ -1,70 +0,0 @@
-#include <geos/algorithm/CentroidPoint.h>
-#include <geos/geom/MultiPoint.h>
-#include <geos/geom/Point.h>
-namespace geos {
-void
-CentroidPoint::add(const Geometry *geom)
- if ( const Point *p = dynamic_cast<const Point*>(geom) )
- add(p->getCoordinate());
- else if ( const GeometryCollection *gc =
- dynamic_cast<const GeometryCollection*>(geom) )
- for(std::size_t i=0, n=gc->getNumGeometries(); i<n; ++i) {
-void
-CentroidPoint::add(const Coordinate *pt)
- ptCount+=1;
- centSum.x += pt->x;
- centSum.y += pt->y;
-Coordinate*
-CentroidPoint::getCentroid() const
- return new Coordinate(centSum.x/ptCount, centSum.y/ptCount);
-bool
-CentroidPoint::getCentroid(Coordinate& ret) const
- if ( ptCount == 0.0 ) return false;
- ret=Coordinate(centSum.x/ptCount, centSum.y/ptCount);
- return true;
diff --git a/src/algorithm/Makefile.am b/src/algorithm/Makefile.am
index 082a2a9..062d835 100644
--- a/src/algorithm/Makefile.am
+++ b/src/algorithm/Makefile.am
@@ -13,9 +13,6 @@ libalgorithm_la_SOURCES = \
Angle.cpp \
BoundaryNodeRule.cpp \
Centroid.cpp \
- CentroidArea.cpp \
- CentroidLine.cpp \
- CentroidPoint.cpp \
CGAlgorithms.cpp \
CGAlgorithmsDD.cpp \
ConvexHull.cpp \
Summary of changes:
include/geos/algorithm/CentroidArea.h | 147 ---------------------------
include/geos/algorithm/CentroidLine.h | 77 ---------------
include/geos/algorithm/CentroidPoint.h | 72 --------------
include/geos/algorithm/Makefile.am | 3 -
include/geos/geosAlgorithm.h | 3 -
src/Makefile.vc | 3 -
src/algorithm/CentroidArea.cpp | 175 ---------------------------------
src/algorithm/CentroidLine.cpp | 87 ----------------
src/algorithm/CentroidPoint.cpp | 70 -------------
src/algorithm/Makefile.am | 3 -
10 files changed, 640 deletions(-)
delete mode 100644 include/geos/algorithm/CentroidArea.h
delete mode 100644 include/geos/algorithm/CentroidLine.h
delete mode 100644 include/geos/algorithm/CentroidPoint.h
delete mode 100644 src/algorithm/CentroidArea.cpp
delete mode 100644 src/algorithm/CentroidLine.cpp
delete mode 100644 src/algorithm/CentroidPoint.cpp
hooks/post-receive
More information about the geos-commits
