[geos-commits] [SCM] GEOS branch master updated. 678955984311120319e88062f19e2ba32121150e
git at osgeo.org
git at osgeo.org
Fri Dec 14 10:10:31 PST 2018
the project "GEOS".
via 678955984311120319e88062f19e2ba32121150e (commit)
from 327680c9fb644b6370274d9486f2756e7892f367 (commit)
revisions in full, below.
commit 678955984311120319e88062f19e2ba32121150e
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Fri Dec 14 10:10:15 2018 -0800
Delete obsolete PointInRing classes
JTS 55fb1113655db08a9a4ce4c17c9ee5912b6aa0f2
diff --git a/include/geos/algorithm/Makefile.am b/include/geos/algorithm/Makefile.am
index 19f13c9..6309cec 100644
--- a/include/geos/algorithm/Makefile.am
+++ b/include/geos/algorithm/Makefile.am
@@ -25,10 +25,7 @@ geos_HEADERS = \
LineIntersector.h \
MinimumDiameter.h \
NotRepresentableException.h \
- PointInRing.h \
PointLocator.h \
RayCrossingCounter.h \
RayCrossingCounterDD.h \
- RobustDeterminant.h \
- SimplePointInRing.h \
- SIRtreePointInRing.h
+ RobustDeterminant.h
diff --git a/include/geos/algorithm/SIRtreePointInRing.h b/include/geos/algorithm/SIRtreePointInRing.h
deleted file mode 100644
index 6b1e0c3..0000000
--- a/include/geos/algorithm/SIRtreePointInRing.h
+++ /dev/null
@@ -1,60 +0,0 @@
- * GEOS - Geometry Engine Open Source
- * http://geos.osgeo.org
- * Copyright (C) 2005-2006 Refractions Research Inc.
- * Copyright (C) 2001-2002 Vivid Solutions Inc.
- * This is free software; you can redistribute and/or modify it under
- * the terms of the GNU Lesser General Public Licence as published
- * by the Free Software Foundation.
- * See the COPYING file for more information.
-#ifndef GEOS_ALGORITHM_SIRTREEPOINTINRING_H
-#define GEOS_ALGORITHM_SIRTREEPOINTINRING_H
-#include <geos/export.h>
-#include <geos/algorithm/PointInRing.h> // for inheritance
-#include <geos/index/strtree/SIRtree.h>
-#include <geos/geom/LineSegment.h>
-#include <memory>
-#include <vector>
-// Forward declarations
-namespace geos {
- namespace geom {
- class Coordinate;
- class LineSegment;
- class LinearRing;
-namespace geos {
-namespace algorithm { // geos::algorithm
-class GEOS_DLL SIRtreePointInRing: public PointInRing {
-private:
- geom::LinearRing *ring;
- index::strtree::SIRtree sirTree;
- std::vector<std::unique_ptr<geom::LineSegment>> segments;
- int crossings; // number of segment/ray crossings
- void buildIndex();
- void testLineSegment(const geom::Coordinate& p,
- geom::LineSegment *seg);
-public:
- SIRtreePointInRing(geom::LinearRing *newRing);
- ~SIRtreePointInRing() override = default;
- bool isInside(const geom::Coordinate& pt) override;
-} // namespace geos::algorithm
-#endif // GEOS_ALGORITHM_SIRTREEPOINTINRING_H
diff --git a/include/geos/geosAlgorithm.h b/include/geos/geosAlgorithm.h
index 1a93e24..5dc6c33 100644
--- a/include/geos/geosAlgorithm.h
+++ b/include/geos/geosAlgorithm.h
@@ -35,12 +35,9 @@
#include <geos/algorithm/LineIntersector.h>
//#include <geos/algorithm/MinimumDiameter.h>
//#include <geos/algorithm/NotRepresentableException.h>
-//#include <geos/algorithm/PointInRing.h>
#include <geos/algorithm/PointLocator.h>
//#include <geos/algorithm/RobustDeterminant.h>
-//#include <geos/algorithm/SIRtreePointInRing.h>
//#include <geos/algorithm/SimplePointInAreaLocator.h>
-//#include <geos/algorithm/SimplePointInRing.h>
namespace geos {
diff --git a/src/Makefile.vc b/src/Makefile.vc
index 803d3bd..f67802d 100644
--- a/src/Makefile.vc
+++ b/src/Makefile.vc
@@ -45,8 +45,6 @@ OBJ = \
algorithm\PointLocator.$(EXT) \
algorithm\RayCrossingCounter.$(EXT) \
algorithm\RobustDeterminant.$(EXT) \
- algorithm\SimplePointInRing.$(EXT) \
- algorithm\SIRtreePointInRing.$(EXT) \
algorithm\distance\DiscreteHausdorffDistance.$(EXT) \
algorithm\distance\DiscreteFrechetDistance.$(EXT) \
algorithm\distance\DistanceToPoint.$(EXT) \
diff --git a/src/algorithm/Makefile.am b/src/algorithm/Makefile.am
index 062d835..749cbe5 100644
--- a/src/algorithm/Makefile.am
+++ b/src/algorithm/Makefile.am
@@ -26,9 +26,7 @@ libalgorithm_la_SOURCES = \
PointLocator.cpp \
RayCrossingCounter.cpp \
RayCrossingCounterDD.cpp \
- RobustDeterminant.cpp \
- SimplePointInRing.cpp \
- SIRtreePointInRing.cpp
+ RobustDeterminant.cpp
libalgorithm_la_LIBADD = \
diff --git a/src/algorithm/SIRtreePointInRing.cpp b/src/algorithm/SIRtreePointInRing.cpp
index f4b5baf..0000000
--- a/src/algorithm/SIRtreePointInRing.cpp
+++ /dev/null
@@ -1,113 +0,0 @@
-#include <geos/algorithm/CGAlgorithmsDD.h>
-#include <geos/algorithm/SIRtreePointInRing.h>
-#include <geos/algorithm/RobustDeterminant.h>
-#include <geos/geom/LinearRing.h>
-#include <geos/geom/CoordinateSequence.h>
-#include <geos/geom/Coordinate.h>
-#include <vector>
-using namespace std;
-using namespace geos::index::strtree;
-using namespace geos::geom;
-namespace geos {
-namespace algorithm { // geos.algorithm
-SIRtreePointInRing::SIRtreePointInRing(LinearRing *newRing):
- PointInRing(),
- ring(newRing),
- crossings(0)
- buildIndex();
-void
-SIRtreePointInRing::buildIndex()
- const CoordinateSequence *pts = ring->getCoordinatesRO();
- const std::size_t npts=pts->getSize();
- for(std::size_t i=1; i<npts; ++i)
- if(pts->getAt(i-1)==pts->getAt(i)) continue; // Optimization suggested by MD. [Jon Aquino]
- std::unique_ptr<LineSegment> seg{new LineSegment(pts->getAt(i-1), pts->getAt(i))};
- sirTree.insert(seg->p0.y, seg->p1.y, seg.get());
- segments.push_back(std::move(seg));
-bool
-SIRtreePointInRing::isInside(const Coordinate& pt)
- crossings=0;
- // test all segments intersected by vertical ray at pt
- std::unique_ptr<vector<void*>> segs{sirTree.query(pt.y)};
- for(const auto& hit : *segs) {
- LineSegment *seg = static_cast<LineSegment*>(hit);
- testLineSegment(pt,seg);
- * p is inside if number of crossings is odd.
- return (crossings % 2) == 1;
-void
-SIRtreePointInRing::testLineSegment(const Coordinate& p,LineSegment *seg)
- double xInt; // x intersection of segment with ray
- double x1; // translated coordinates
- double y1;
- double x2;
- double y2;
- * Test if segment crosses ray from test point in positive x direction.
- Coordinate& p1=seg->p0;
- Coordinate& p2=seg->p1;
- x1=p1.x-p.x;
- y1=p1.y-p.y;
- x2=p2.x-p.x;
- y2=p2.y-p.y;
- if (((y1>0) && (y2<=0)) ||
- ((y2>0) && (y1<=0))) {
- * segment straddles x axis,so compute intersection.
- xInt = CGAlgorithmsDD::signOfDet2x2(x1,y1,x2,y2)/(y2-y1);
- * crosses ray if strictly positive intersection.
- if (0.0<xInt) {
- crossings++;
-} // namespace geos.algorithm
diff --git a/tests/unit/Makefile.am b/tests/unit/Makefile.am
index b3db843..9c48b02 100644
--- a/tests/unit/Makefile.am
+++ b/tests/unit/Makefile.am
@@ -54,7 +54,6 @@ geos_unit_SOURCES = \
algorithm/PointLocatorTest.cpp \
algorithm/RobustLineIntersectionTest.cpp \
algorithm/RobustLineIntersectorTest.cpp \
- algorithm/SIRtreePointInRingTest.cpp \
geom/CoordinateArraySequenceFactoryTest.cpp \
geom/CoordinateArraySequenceTest.cpp \
geom/CoordinateListTest.cpp \
diff --git a/tests/unit/algorithm/SIRtreePointInRingTest.cpp b/tests/unit/algorithm/SIRtreePointInRingTest.cpp
index 2ec04c5..0000000
--- a/tests/unit/algorithm/SIRtreePointInRingTest.cpp
+++ /dev/null
@@ -1,56 +0,0 @@
-// Test Suite for geos::algorithm::SIRtreePointInRing
-#include <tut/tut.hpp>
-// geos
-#include <geos/io/WKTReader.h>
-#include <geos/geom/Geometry.h>
-// std
-#include <sstream>
-#include <string>
-#include <memory>
-namespace tut
- // Test Group
- // dummy data, not used
- struct test_sirtreepointinring_data {
- using SIRtreePointInRing = geos::algorithm::SIRtreePointInRing;
- using Geometry = geos::geom::Geometry;
- using Coordinate = geos::geom::Coordinate;
- geos::io::WKTReader reader;
- std::unique_ptr<Geometry> geom;
- typedef test_group<test_sirtreepointinring_data> group;
- typedef group::object object;
- group test_sirtreepointinring_data("geos::algorithm::SIRtreePointInRing");
- // Test Cases
- template<>
- template<>
- void object::test<1>()
- using geos::geom::LinearRing;
- geom.reset(reader.read("LINEARRING (0 0, 1 0, 1 1, 0 1, 0 0)"));
- SIRtreePointInRing pir{dynamic_cast<LinearRing*>(geom.get())};
- Coordinate c{0.5, 0.5};
- ensure(pir.isInside(c));
-} // namespace tut
Summary of changes:
include/geos/algorithm/Makefile.am | 5 +-
include/geos/algorithm/SIRtreePointInRing.h | 60 -------------
include/geos/geosAlgorithm.h | 3 -
src/Makefile.vc | 2 -
src/algorithm/Makefile.am | 4 +-
src/algorithm/SIRtreePointInRing.cpp | 113 ------------------------
tests/unit/Makefile.am | 1 -
tests/unit/algorithm/SIRtreePointInRingTest.cpp | 56 ------------
8 files changed, 2 insertions(+), 242 deletions(-)
delete mode 100644 include/geos/algorithm/SIRtreePointInRing.h
delete mode 100644 src/algorithm/SIRtreePointInRing.cpp
delete mode 100644 tests/unit/algorithm/SIRtreePointInRingTest.cpp
hooks/post-receive
More information about the geos-commits
