[geos-commits] [SCM] GEOS branch master updated. b36f6f2f7ef2e8f1cbf7c9387b3f4a51fb575e13
git at osgeo.org
git at osgeo.org
Mon Dec 17 10:45:08 PST 2018
the project "GEOS".
via b36f6f2f7ef2e8f1cbf7c9387b3f4a51fb575e13 (commit)
from 694aa42d9e0905ac44809a79da0afac34f9fb1c7 (commit)
revisions in full, below.
commit b36f6f2f7ef2e8f1cbf7c9387b3f4a51fb575e13
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Mon Dec 17 10:44:47 2018 -0800
Move area functions to Area class
JTS e06c0c9ce27abdf84f8dc897baac06cc70a2eed7
diff --git a/include/geos/algorithm/Area.h b/include/geos/algorithm/Area.h
new file mode 100644
index 0000000..7608c3f
--- /dev/null
+++ b/include/geos/algorithm/Area.h
@@ -0,0 +1,81 @@
+ * GEOS - Geometry Engine Open Source
+ * http://geos.osgeo.org
+ * Copyright (C) 2018 Paul Ramsey <pramsey at cleverlephant.ca>
+ * This is free software; you can redistribute and/or modify it under
+ * the terms of the GNU Lesser General Public Licence as published
+ * by the Free Software Foundation.
+ * See the COPYING file for more information.
+ * Last port: algorithm/Area.java @ 2017-09-04
+#ifndef GEOS_ALGORITHM_AREA_H
+#define GEOS_ALGORITHM_AREA_H
+#include <geos/export.h>
+#include <geos/geom/Coordinate.h>
+#include <geos/geom/CoordinateSequence.h>
+namespace geos {
+namespace algorithm { // geos::algorithm
+/// Utility functions for working with angles.
+/// Unless otherwise noted, methods in this class express angles in radians.
+class GEOS_DLL Area {
+public:
+ * Computes the area for a ring.
+ * @param ring the coordinates forming the ring
+ * @return the area of the ring
+ static double ofRing(const std::vector<geom::Coordinate> &ring);
+ static double ofRing(const geom::CoordinateSequence *ring);
+ * Computes the signed area for a ring. The signed area is positive if the
+ * ring is oriented CW, negative if the ring is oriented CCW, and zero if the
+ * ring is degenerate or flat.
+ * @param ring
+ * the coordinates forming the ring
+ * @return the signed area of the ring
+ static double ofRingSigned(const std::vector<geom::Coordinate> &ring);
+ * @param ring
+ static double ofRingSigned(const geom::CoordinateSequence *ring);
+} // namespace geos::algorithm
+#endif // GEOS_ALGORITHM_AREA_H
diff --git a/include/geos/algorithm/Makefile.am b/include/geos/algorithm/Makefile.am
index 6309cec..0c9d319 100644
--- a/include/geos/algorithm/Makefile.am
+++ b/include/geos/algorithm/Makefile.am
@@ -12,6 +12,7 @@ geosdir = $(includedir)/geos/algorithm
geos_HEADERS = \
Angle.h \
+ Area.h \
BoundaryNodeRule.h \
CentralEndpointIntersector.h \
Centroid.h \
diff --git a/src/algorithm/Area.cpp b/src/algorithm/Area.cpp
index 0000000..e203953
--- /dev/null
+++ b/src/algorithm/Area.cpp
@@ -0,0 +1,96 @@
+#include <cmath>
+#include <vector>
+#include <geos/algorithm/Area.h>
+namespace geos {
+namespace algorithm { // geos.algorithm
+/* public static */
+double
+Area::ofRing(const std::vector<geom::Coordinate> &ring)
+ return abs(ofRingSigned(ring));
+double
+Area::ofRing(const geom::CoordinateSequence *ring)
+double
+Area::ofRingSigned(const std::vector<geom::Coordinate> &ring)
+ size_t rlen = ring.size();
+ if (rlen < 3)
+ return 0.0;
+ double sum = 0.0;
+ * Based on the Shoelace formula.
+ * http://en.wikipedia.org/wiki/Shoelace_formula
+ double x0 = ring[0].x;
+ for (size_t i = 1; i < rlen - 1; i++) {
+ double x = ring[i].x - x0;
+ double y1 = ring[i + 1].y;
+ double y2 = ring[i - 1].y;
+ sum += x * (y2 - y1);
+ return sum / 2.0;
+double
+Area::ofRingSigned(const geom::CoordinateSequence *ring)
+ size_t n = ring->size();
+ if (n < 3)
+ return 0.0;
+ geom::Coordinate p0, p1, p2;
+ p1 = ring->getAt(0);
+ p2 = ring->getAt(1);
+ double x0 = p1.x;
+ p2.x -= x0;
+ double sum = 0.0;
+ for (size_t i = 1; i < n - 1; i++) {
+ p0.y = p1.y;
+ p1.x = p2.x;
+ p1.y = p2.y;
+ p2 = ring->getAt(i + 1);
+ p2.x -= x0;
+ sum += p1.x * (p0.y - p2.y);
+ return sum / 2.0;
+} // namespace geos.algorithm
+} //namespace geos
diff --git a/src/algorithm/Makefile.am b/src/algorithm/Makefile.am
index 749cbe5..7f84e78 100644
--- a/src/algorithm/Makefile.am
+++ b/src/algorithm/Makefile.am
@@ -11,6 +11,7 @@ AM_CPPFLAGS = -I$(top_srcdir)/include
libalgorithm_la_SOURCES = \
Angle.cpp \
+ Area.cpp \
BoundaryNodeRule.cpp \
Centroid.cpp \
CGAlgorithms.cpp \
diff --git a/src/geom/Polygon.cpp b/src/geom/Polygon.cpp
index 85082c7..7b8fea5 100644
--- a/src/geom/Polygon.cpp
+++ b/src/geom/Polygon.cpp
@@ -18,6 +18,7 @@
#include <geos/algorithm/CGAlgorithms.h>
#include <geos/util/IllegalArgumentException.h>
@@ -366,13 +367,13 @@ Polygon::getCoordinate() const
double
Polygon::getArea() const
- double area=0.0;
- area+=fabs(algorithm::CGAlgorithms::signedArea(shell->getCoordinatesRO()));
+ double area = 0.0;
+ area += fabs(algorithm::Area::ofRing(shell->getCoordinatesRO()));
for(size_t i=0, n=holes->size(); i<n; ++i)
const LinearRing *lr = dynamic_cast<const LinearRing *>((*holes)[i]);
- const CoordinateSequence *h=lr->getCoordinatesRO();
- area-=fabs(algorithm::CGAlgorithms::signedArea(h));
+ const CoordinateSequence *h = lr->getCoordinatesRO();
+ area -= fabs(algorithm::Area::ofRing(h));
return area;
diff --git a/tests/unit/Makefile.am b/tests/unit/Makefile.am
index 9c48b02..9064b1f 100644
--- a/tests/unit/Makefile.am
+++ b/tests/unit/Makefile.am
@@ -40,6 +40,7 @@ geos_unit_LDADD = \
geos_unit_SOURCES = \
geos_unit.cpp \
algorithm/AngleTest.cpp \
+ algorithm/AreaTest.cpp \
algorithm/CGAlgorithms/computeOrientationTest.cpp \
algorithm/CGAlgorithms/isCCWTest.cpp \
algorithm/CGAlgorithms/isPointInRingTest.cpp \
diff --git a/tests/unit/algorithm/AreaTest.cpp b/tests/unit/algorithm/AreaTest.cpp
index 0000000..361ac4b
--- /dev/null
+++ b/tests/unit/algorithm/AreaTest.cpp
@@ -0,0 +1,153 @@
+// Test Suite for geos::algorithm::Area
+// Ported from JTS junit/algorithm/AreaTest.java
+#include <tut/tut.hpp>
+// geos
+#include <geos/geom/CoordinateArraySequence.h>
+#include <geos/geom/Dimension.h>
+#include <geos/geom/Geometry.h>
+#include <geos/geom/GeometryFactory.h>
+#include <geos/geom/LineString.h>
+#include <geos/geom/PrecisionModel.h>
+#include <geos/io/WKTReader.h>
+// std
+#include <sstream>
+#include <string>
+#include <memory>
+using namespace geos;
+using namespace geos::geom;
+namespace tut
+ // Test Group
+ // dummy data, not used
+ struct test_area_data {
+ geos::geom::Geometry *geom_;
+ geos::geom::PrecisionModel pm_;
+ geos::geom::GeometryFactory::Ptr factory_;
+ geos::io::WKTReader reader_;
+ test_area_data():
+ geom_(nullptr),
+ pm_(1),
+ factory_(GeometryFactory::create(&pm_, 0)), reader_(factory_.get())
+ assert(nullptr == geom_);
+ ~test_area_data()
+ factory_->destroyGeometry(geom_);
+ geom_ = nullptr;
+ void checkAreaOfRing(std::string wkt, double expectedArea) {
+ std::unique_ptr<Geometry> lineGeom(reader_.read(wkt));
+ std::unique_ptr<LineString> line(dynamic_cast<LineString*>(lineGeom.release()));
+ ensure(nullptr != line.get());
+ const CoordinateSequence *ringSeq = line->getCoordinatesRO();
+ std::vector<Coordinate> ringCoords;
+ ringSeq->toVector(ringCoords);
+ double actual1 = algorithm::Area::ofRing(ringCoords);
+ double actual2 = algorithm::Area::ofRing(ringSeq);
+ ensure_equals(actual1, expectedArea);
+ ensure_equals(actual2, expectedArea);
+ void checkAreaOfRingSigned(std::string wkt, double expectedArea) {
+ double actual1 = algorithm::Area::ofRingSigned(ringCoords);
+ double actual2 = algorithm::Area::ofRingSigned(ringSeq);
+ // using geos::geom::LineString;
+ // Geometry::Ptr lineGeom(reader_.read("LINESTRING (30 220, 240 220, 240 220)"));
+ // LineString::Ptr line(dynamic_cast<LineString*>(lineGeom.release()));
+ // ensure(nullptr != line.get());
+ // Geometry::Ptr hullGeom(reader_.read("LINESTRING (30 220, 240 220)"));
+ // LineString::Ptr convexHull(dynamic_cast<LineString*>(hullGeom.release()));
+ // ensure(nullptr != convexHull.get());
+ // geom_ = line->convexHull();
+ // ensure( convexHull->equalsExact(geom_) );
+ typedef test_group<test_area_data> group;
+ typedef group::object object;
+ group test_area_group("geos::algorithm::Area");
+ // Test Cases
+ template<>
+ template<>
+ void object::test<1>()
+ checkAreaOfRing("LINESTRING (100 200, 200 200, 200 100, 100 100, 100 200)", 10000.0);
+ template<>
+ template<>
+ void object::test<2>()
+ checkAreaOfRingSigned("LINESTRING (100 200, 200 200, 200 100, 100 100, 100 200)", 10000.0);
+ template<>
+ template<>
+ void object::test<3>()
+ checkAreaOfRingSigned("LINESTRING (100 200, 100 100, 200 100, 200 200, 100 200)", -10000.0);
+ // // testIsAcute()
+ // template<>
+ // template<>
+ // void object::test<2>()
+ // ensure_equals("7", Angle::angle(Coordinate(-10,-10)), -0.75*PI, TOL);
+ // ensure(Area::isAcute(
+ // Coordinate(10,0), Coordinate(0,0), Coordinate(5,10)));
+ // Coordinate(10,0), Coordinate(0,0), Coordinate(5,-10)));
+ // // angle of 0
+ // Coordinate(10,0), Coordinate(0,0), Coordinate(10,0)));
+ // ensure_not(Area::isAcute(
+ // Coordinate(10,0), Coordinate(0,0), Coordinate(-5,10)));
+ // Coordinate(10,0), Coordinate(0,0), Coordinate(-5,-10)));
+} // namespace tut
Summary of changes:
include/geos/algorithm/Area.h | 81 ++++++++++++++++++++
include/geos/algorithm/Makefile.am | 1 +
src/algorithm/Area.cpp | 96 +++++++++++++++++++++++
src/algorithm/Makefile.am | 1 +
src/geom/Polygon.cpp | 9 ++-
tests/unit/Makefile.am | 1 +
tests/unit/algorithm/AreaTest.cpp | 153 +++++++++++++++++++++++++++++++++++++
7 files changed, 338 insertions(+), 4 deletions(-)
create mode 100644 include/geos/algorithm/Area.h
create mode 100644 src/algorithm/Area.cpp
create mode 100644 tests/unit/algorithm/AreaTest.cpp
hooks/post-receive
More information about the geos-commits
