[geos-commits] [SCM] GEOS branch master updated. c8297015f0c50e36f00939152531e8e918b2f578
git at osgeo.org
git at osgeo.org
Mon Dec 17 11:33:22 PST 2018
the project "GEOS".
via c8297015f0c50e36f00939152531e8e918b2f578 (commit)
from 6fa6d65247829c1ba120015d4a59bd648b536a18 (commit)
revisions in full, below.
commit c8297015f0c50e36f00939152531e8e918b2f578
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Mon Dec 17 11:33:08 2018 -0800
Change buffer unit failures to more correct message
diff --git a/tests/unit/capi/GEOSBufferTest.cpp b/tests/unit/capi/GEOSBufferTest.cpp
index 2dd8e3c..26ab0e1 100644
--- a/tests/unit/capi/GEOSBufferTest.cpp
+++ b/tests/unit/capi/GEOSBufferTest.cpp
@@ -152,7 +152,7 @@ namespace tut
ensure_equals(GEOSGetNumCoordinates(geom2_), 7);
ensure(0 != GEOSArea(geom2_, &area_));
- ensure_distance(area_, 161.803, 0.001);
+ ensure_area(area_, 161.803, 0.001);
@@ -174,7 +174,7 @@ namespace tut
ensure_equals(GEOSGetNumCoordinates(geom2_), 11);
- ensure_distance(area_, 182.514, 0.001);
+ ensure_area(area_, 182.514, 0.001);
// Buffer with square end caps on a 2-vertices line (no matter quadSegs)
@@ -196,7 +196,7 @@ namespace tut
- ensure_distance(area_, 211.803, 0.001);
+ ensure_area(area_, 211.803, 0.001);
@@ -219,7 +219,7 @@ namespace tut
ensure_equals(GEOSGetNumCoordinates(geom2_), 5);
- ensure_distance(area_, 111.803, 0.001);
+ ensure_area(area_, 111.803, 0.001);
// Buffer with flat end cap on a 2-vertices horizontal line
@@ -241,7 +241,7 @@ namespace tut
- ensure_distance(area_, 50.0, 0.001);
+ ensure_area(area_, 50.0, 0.001);
ensure_equals(std::string(wkt_), std::string(
"POLYGON ((10.0000000000000000 15.0000000000000000, 10.0000000000000000 5.0000000000000000, 5.0000000000000000 5.0000000000000000, 5.0000000000000000 15.0000000000000000, 10.0000000000000000 15.0000000000000000))"
@@ -267,7 +267,7 @@ namespace tut
- ensure_distance(area_, 150.0, 0.001);
+ ensure_area(area_, 150.0, 0.001);
"POLYGON ((10.0000000000000000 15.0000000000000000, 15.0000000000000000 15.0000000000000000, 15.0000000000000000 5.0000000000000000, 5.0000000000000000 5.0000000000000000, 0.0000000000000000 5.0000000000000009, 0.0000000000000000 15.0000000000000000, 10.0000000000000000 15.0000000000000000))"
@@ -294,7 +294,7 @@ namespace tut
ensure_equals(GEOSGetNumCoordinates(geom2_), 29);
- ensure_distance(area_, 244.615, 0.001);
+ ensure_area(area_, 244.615, 0.001);
@@ -318,7 +318,7 @@ namespace tut
ensure_equals(GEOSGetNumCoordinates(geom2_), 9);
- ensure_distance(area_, 250.0, 0.001);
+ ensure_area(area_, 250.0, 0.001);
"POLYGON ((5.0000000000000000 15.0000000000000000, 5.0000000000000000 20.0000000000000000, 5.0000000000000000 25.0000000000000000, 15.0000000000000000 25.0000000000000000, 15.0000000000000000 5.0000000000000000, 5.0000000000000000 5.0000000000000000, 0.0000000000000000 5.0000000000000009, 0.0000000000000000 15.0000000000000000, 5.0000000000000000 15.0000000000000000))"
@@ -345,7 +345,7 @@ namespace tut
ensure_equals(GEOSGetNumCoordinates(geom2_), 10);
- ensure_distance(area_, 237.5, 0.001);
+ ensure_area(area_, 237.5, 0.001);
"POLYGON ((5.0000000000000000 15.0000000000000000, 5.0000000000000000 20.0000000000000000, 5.0000000000000000 25.0000000000000000, 15.0000000000000000 25.0000000000000000, 15.0000000000000000 10.0000000000000000, 10.0000000000000000 5.0000000000000000, 5.0000000000000000 5.0000000000000000, 0.0000000000000000 5.0000000000000009, 0.0000000000000000 15.0000000000000000, 5.0000000000000000 15.0000000000000000))"
@@ -373,7 +373,7 @@ namespace tut
@@ -399,7 +399,7 @@ namespace tut
- ensure_distance(area_, 127.452, 0.001);
+ ensure_area(area_, 127.452, 0.001);
@@ -422,7 +422,7 @@ namespace tut
ensure_equals(GEOSGetNumCoordinates(geom2_), 6);
- ensure_distance(area_, 139.043, 0.001);
+ ensure_area(area_, 139.043, 0.001);
@@ -445,7 +445,7 @@ namespace tut
ensure_equals(GEOSGetNumCoordinates(geom2_), 4);
- ensure_distance(area_, 141.598, 0.001);
+ ensure_area(area_, 141.598, 0.001);
diff --git a/tests/unit/tut/tut_assert.hpp b/tests/unit/tut/tut_assert.hpp
index eb8b2db..faf10b8 100644
--- a/tests/unit/tut/tut_assert.hpp
+++ b/tests/unit/tut/tut_assert.hpp
@@ -230,7 +230,7 @@ void ensure_equals(const LhsType *lhs_begin, const LhsType *lhs_end,
* TODO: domains are wrong, T - T might not yield T, but Q
template <typename M, class T>
-void ensure_distance(const M& msg, const T& actual, const T& expected, const T& distance)
+void ensure_measurement(const M& msg, const T& actual, const T& expected, const T& distance)
if (expected-distance >= actual || expected+distance <= actual)
@@ -250,7 +250,13 @@ void ensure_distance(const M& msg, const T& actual, const T& expected, const T&
template <class T>
void ensure_distance(const T& actual, const T& expected, const T& distance)
- ensure_distance<>("Distance is wrong", actual, expected, distance);
+ ensure_measurement<>("Distance is wrong", actual, expected, distance);
+template <class T>
+void ensure_area(const T& actual, const T& expected, const T& distance)
+ ensure_measurement<>("Area is wrong", actual, expected, distance);
template<typename M>
Summary of changes:
tests/unit/capi/GEOSBufferTest.cpp | 26 +++++++++++++-------------
tests/unit/tut/tut_assert.hpp | 10 ++++++++--
2 files changed, 21 insertions(+), 15 deletions(-)
hooks/post-receive
More information about the geos-commits
