[geos-commits] [SCM] GEOS branch master updated. f35ce0deffcc4eb7d804f1cd6436a7fa66372a0a
git at osgeo.org
git at osgeo.org
Mon Dec 17 13:06:49 PST 2018
the project "GEOS".
via f35ce0deffcc4eb7d804f1cd6436a7fa66372a0a (commit)
from 858123648c93a0868ebf456badd20a5fa0ab4f42 (commit)
revisions in full, below.
commit f35ce0deffcc4eb7d804f1cd6436a7fa66372a0a
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Mon Dec 17 13:06:39 2018 -0800
Quiet warnings from GCC 4.8
diff --git a/src/geom/util/Densifier.cpp b/src/geom/util/Densifier.cpp
index ff427a5..9a3fb40 100644
--- a/src/geom/util/Densifier.cpp
+++ b/src/geom/util/Densifier.cpp
@@ -48,8 +48,8 @@ namespace geom { // geos.geom
namespace util { // geos.geom.util
/* geom::util::Densifier::DensifyTransformer */
-Densifier::DensifyTransformer::DensifyTransformer(double distanceTolerance):
- distanceTolerance(distanceTolerance)
+Densifier::DensifyTransformer::DensifyTransformer(double distTol):
+ distanceTolerance(distTol)
CoordinateSequence::Ptr
@@ -73,7 +73,7 @@ Densifier::DensifyTransformer::transformPolygon(const Polygon *geom, const Geome
Geometry::Ptr roughGeom = GeometryTransformer::transformPolygon(geom, parent);
// don't try and correct if the parent is going to do this
- if (const MultiPolygon* mp=dynamic_cast<const MultiPolygon*>(parent) )
+ if (parent && parent->getGeometryTypeId() == GEOS_MULTIPOLYGON)
return roughGeom;
@@ -140,10 +140,10 @@ Densifier::densifyPoints(const Coordinate::Vect pts, double distanceTolerance, c
* @return the densified geometry
Geometry::Ptr
-Densifier::densify(const Geometry *geom, double distanceTolerance)
+Densifier::densify(const Geometry *geom, double distTol)
util::Densifier densifier(geom);
- densifier.setDistanceTolerance(distanceTolerance);
+ densifier.setDistanceTolerance(distTol);
return densifier.getResultGeometry();
diff --git a/src/operation/IsSimpleOp.cpp b/src/operation/IsSimpleOp.cpp
index 614a6dc..be361ee 100644
--- a/src/operation/IsSimpleOp.cpp
+++ b/src/operation/IsSimpleOp.cpp
@@ -214,28 +214,28 @@ IsSimpleOp::hasNonEndpointIntersection(GeometryGraph &graph)
/*private*/
bool
-IsSimpleOp::computeSimple(const geom::Geometry *geom)
+IsSimpleOp::computeSimple(const geom::Geometry *g)
nonSimpleLocation.reset();
- if (dynamic_cast<const LineString*>(geom))
- return isSimpleLinearGeometry(geom);
+ if (dynamic_cast<const LineString*>(g))
+ return isSimpleLinearGeometry(g);
- if (dynamic_cast<const LinearRing*>(geom))
+ if (dynamic_cast<const LinearRing*>(g))
- if (dynamic_cast<const MultiLineString*>(geom))
+ if (dynamic_cast<const MultiLineString*>(g))
- if (dynamic_cast<const Polygon*>(geom))
- return isSimplePolygonal(geom);
+ if (dynamic_cast<const Polygon*>(g))
+ return isSimplePolygonal(g);
- const MultiPoint* mp = dynamic_cast<const MultiPoint*>(geom);
+ const MultiPoint* mp = dynamic_cast<const MultiPoint*>(g);
if (mp) return isSimpleMultiPoint(*mp);
// This must be after MultiPoint test, as MultiPoint can
// cast cleanly into GeometryCollection
- const GeometryCollection* gc = dynamic_cast<const GeometryCollection*>(geom);
+ const GeometryCollection* gc = dynamic_cast<const GeometryCollection*>(g);
if (gc)
return isSimpleGeometryCollection(gc);
@@ -250,19 +250,19 @@ IsSimpleOp::isSimpleGeometryCollection(const geom::GeometryCollection *col)
GeometryCollection::const_iterator it;
for (it = col->begin(); it < col->end(); ++it)
- const geom::Geometry *geom = *it;
- if (!computeSimple(geom)) return false;
+ const geom::Geometry *g = *it;
+ if (!computeSimple(g)) return false;
return true;
/*private*/
bool
-IsSimpleOp::isSimplePolygonal(const geom::Geometry *geom)
+IsSimpleOp::isSimplePolygonal(const geom::Geometry *g)
LineString::ConstVect rings;
- LinearComponentExtracter::getLines(*geom, rings);
+ LinearComponentExtracter::getLines(*g, rings);
for (const geom::LineString *ring : rings)
if(!isSimpleLinearGeometry(ring))
diff --git a/tests/xmltester/XMLTester.cpp b/tests/xmltester/XMLTester.cpp
index 3bf734a..d2a8c9e 100644
--- a/tests/xmltester/XMLTester.cpp
+++ b/tests/xmltester/XMLTester.cpp
@@ -146,10 +146,9 @@ void dump_to_stdout( const tinyxml2::XMLNode * pParent, unsigned int indent = 0
tinyxml2::XMLPrinter printer;
pParent->Accept(&printer);
void
diff --git a/tests/xmltester/tinyxml2/tinyxml2.cpp b/tests/xmltester/tinyxml2/tinyxml2.cpp
index 23a3a6c..ea0b125 100755
--- a/tests/xmltester/tinyxml2/tinyxml2.cpp
+++ b/tests/xmltester/tinyxml2/tinyxml2.cpp
@@ -1034,10 +1034,10 @@ char* XMLNode::ParseDeep( char* p, StrPair* parentEndTag, int* curLineNumPtr )
// Declarations are only allowed at document level
// Multiple declarations are allowed but all declarations
- // must occur before anything else.
+ // must occur before anything else.
- // Optimized due to a security test case. If the first node is
- // a declaration, and the last node is a declaration, then only
+ // Optimized due to a security test case. If the first node is
+ // a declaration, and the last node is a declaration, then only
// declarations have so far been addded.
bool wellLocated = false;
Summary of changes:
src/geom/util/Densifier.cpp | 10 +++++-----
src/operation/IsSimpleOp.cpp | 30 +++++++++++++++---------------
tests/xmltester/XMLTester.cpp | 3 +--
tests/xmltester/tinyxml2/tinyxml2.cpp | 6 +++---
4 files changed, 24 insertions(+), 25 deletions(-)
hooks/post-receive
More information about the geos-commits
