[geos-commits] [SCM] GEOS branch master updated. 0a306ee487120730bfe2688db2f79bf0635dd128
git at osgeo.org
git at osgeo.org
Wed Dec 19 14:09:14 PST 2018
the project "GEOS".
via 0a306ee487120730bfe2688db2f79bf0635dd128 (commit)
from 07249559a60569deb511fe07e4accd0471ef5ce0 (commit)
revisions in full, below.
commit 0a306ee487120730bfe2688db2f79bf0635dd128
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Wed Dec 19 14:08:59 2018 -0800
Deprecate CGAlgorithms and remove all references
JTS b1c0a1e2992c3f3d523dcfb3c0158fbac72b6928
diff --git a/include/geos/algorithm/CGAlgorithms.h b/include/geos/algorithm/CGAlgorithms.h
deleted file mode 100644
index 203890c..0000000
--- a/include/geos/algorithm/CGAlgorithms.h
+++ /dev/null
@@ -1,230 +0,0 @@
- * GEOS - Geometry Engine Open Source
- * http://geos.osgeo.org
- * Copyright (C) 2011 Sandro Santilli <strk at kbt.io>
- * Copyright (C) 2005-2006 Refractions Research Inc.
- * Copyright (C) 2001-2002 Vivid Solutions Inc.
- * This is free software; you can redistribute and/or modify it under
- * the terms of the GNU Lesser General Public Licence as published
- * by the Free Software Foundation.
- * See the COPYING file for more information.
- * Last port: algorithm/CGAlgorithms.java r378 (JTS-1.12)
-#ifndef GEOS_ALGORITHM_CGALGORITHM_H
-#define GEOS_ALGORITHM_CGALGORITHM_H
-#include <geos/export.h>
-#include <vector>
-// Forward declarations
-namespace geos {
- namespace geom {
- class Coordinate;
- class CoordinateSequence;
-namespace geos {
-namespace algorithm { // geos::algorithm
- * \brief
- * Specifies and implements various fundamental Computational Geometric
- * algorithms.
- * The algorithms supplied in this class are robust for double-precision
- * floating point.
-class GEOS_DLL CGAlgorithms {
-public:
- enum {
- CLOCKWISE=-1,
- COLLINEAR=0,
- COUNTERCLOCKWISE=1
- enum {
- RIGHT=-1,
- LEFT=1,
- STRAIGHT=0
- CGAlgorithms(){}
- /** \brief
- * Tests whether a point lies inside a ring.
- * The ring may be oriented in either direction.
- * A point lying exactly on the ring boundary is considered
- * to be inside the ring.
- * This algorithm does not first check the
- * point against the envelope of the ring.
- * @param p point to check for ring inclusion
- * @param ring is assumed to have first point identical to last point
- * @return <code>true</code> if p is inside ring
- * @see locatePointInRing
- static bool isPointInRing(const geom::Coordinate& p,
- const geom::CoordinateSequence* ring);
- /// Same as above, but taking a vector of const Coordinates (faster)
- const std::vector<const geom::Coordinate*>& ring);
- /** \brief
- * Determines whether a point lies in the interior,
- * on the boundary, or in the exterior of a ring.
- * This method does <i>not</i> first check the point against
- * the envelope of the ring.
- * @param ring an array of coordinates representing the ring
- * (which must have first point identical to last point)
- * @return the {@link Location} of p relative to the ring
- static int locatePointInRing(const geom::Coordinate& p,
- const geom::CoordinateSequence& ring);
- /** \brief
- * Test whether a point lies on the given line segment
- * @return true true if
- * the point is a vertex of the line or lies in the interior of a line
- * segment in the linestring
- static bool isOnLine(const geom::Coordinate& p,
- const geom::CoordinateSequence* pt);
- /** \brief
- * Computes whether a ring defined by an array of Coordinate is
- * oriented counter-clockwise.
- * - The list of points is assumed to have the first and last
- * points equal.
- * - This will handle coordinate lists which contain repeated points.
- * This algorithm is <b>only</b> guaranteed to work with valid rings.
- * If the ring is invalid (e.g. self-crosses or touches),
- * the computed result <b>may</b> not be correct.
- * @param ring an array of coordinates forming a ring
- * @return <code>true</code> if the ring is oriented counter-clockwise.
- static bool isCCW(const geom::CoordinateSequence* ring);
- /** \brief
- * Computes the orientation of a point q to the directed line
- * segment p1-p2.
- * The orientation of a point relative to a directed line
- * segment indicates which way you turn to get to q after
- * travelling from p1 to p2.
- * @return 1 if q is counter-clockwise from p1-p2
- * @return -1 if q is clockwise from p1-p2
- * @return 0 if q is collinear with p1-p2
- static int computeOrientation(const geom::Coordinate& p1,
- const geom::Coordinate& p2,
- const geom::Coordinate& q);
- /** \brief
- * Computes the distance from a point p to a line segment AB
- * Note: NON-ROBUST!
- * @param p the point to compute the distance for
- * @param A one point of the line
- * @param B another point of the line (must be different to A)
- * @return the distance from p to line segment AB
- static double distancePointLine(const geom::Coordinate& p,
- const geom::Coordinate& A,
- const geom::Coordinate& B);
- /** \brief
- * Computes the perpendicular distance from a point p
- * to the (infinite) line containing the points AB
- * @return the distance from p to line AB
- static double distancePointLinePerpendicular(const geom::Coordinate& p,
- /** \brief
- * Computes the distance from a line segment AB to a line segment CD
- * @param A a point of one line
- * @param B the second point of (must be different to A)
- * @param C one point of the line
- * @param D another point of the line (must be different to A)
- static double distanceLineLine(const geom::Coordinate& A,
- const geom::Coordinate& B,
- const geom::Coordinate& C,
- const geom::Coordinate& D);
- /** \brief
- * Returns the signed area for a ring. The area is positive if
- * the ring is oriented CW.
- static double signedArea(const geom::CoordinateSequence* ring);
- /** \brief
- * Computes the length of a linestring specified by a sequence
- * of points.
- * @param pts the points specifying the linestring
- * @return the length of the linestring
- static double length(const geom::CoordinateSequence* pts);
- /** \brief
- * Returns the index of the direction of the point <code>q</code>
- * relative to a vector specified by <code>p1-p2</code>.
- * @param p1 the origin point of the vector
- * @param p2 the final point of the vector
- * @param q the point to compute the direction to
- * @return 1 if q is counter-clockwise (left) from p1-p2
- * @return -1 if q is clockwise (right) from p1-p2
- static int orientationIndex(const geom::Coordinate& p1,
-} // namespace geos::algorithm
-#endif // GEOS_ALGORITHM_CGALGORITHM_H
diff --git a/include/geos/algorithm/Makefile.am b/include/geos/algorithm/Makefile.am
index 77232f4..519e709 100644
--- a/include/geos/algorithm/Makefile.am
+++ b/include/geos/algorithm/Makefile.am
@@ -16,7 +16,6 @@ geos_HEADERS = \
BoundaryNodeRule.h \
CentralEndpointIntersector.h \
Centroid.h \
- CGAlgorithms.h \
ConvexHull.h \
ConvexHull.inl \
Distance.h \
diff --git a/src/algorithm/CGAlgorithms.cpp b/src/algorithm/CGAlgorithms.cpp
index 7ab8599..0000000
--- a/src/algorithm/CGAlgorithms.cpp
+++ /dev/null
@@ -1,354 +0,0 @@
- * Copyright (C) 2005 2006 Refractions Research Inc.
-#include <geos/algorithm/CGAlgorithms.h>
-#include <geos/algorithm/LineIntersector.h>
-#include <geos/algorithm/RayCrossingCounter.h>
-#include <geos/geom/CoordinateSequence.h>
-#include <geos/geom/Coordinate.h>
-#include <geos/geom/Location.h>
-#include <geos/util/IllegalArgumentException.h>
-#include <algorithm>
-//#include <cstdio>
-#include <cmath>
-using namespace std;
-using namespace geos::geom;
-namespace geos {
-namespace algorithm { // geos.algorithm
-/*public static*/
-int
-CGAlgorithms::orientationIndex(const Coordinate& p1,const Coordinate& p2,const Coordinate& q)
- return RayCrossingCounter::orientationIndex(p1, p2, q);
-/*public static*/
-bool
-CGAlgorithms::isPointInRing(const Coordinate& p, const CoordinateSequence* ring)
- return locatePointInRing(p, *ring) != Location::EXTERIOR;
-/*public static*/
-bool
- const Coordinate::ConstVect& ring)
- return locatePointInRing(p, ring) != Location::EXTERIOR;
-/*public static*/
-int
-CGAlgorithms::locatePointInRing(const Coordinate& p,
- const CoordinateSequence& ring)
- return RayCrossingCounter::locatePointInRing(p, ring);
-/*public static*/
-int
-/*public static*/
-bool
-CGAlgorithms::isOnLine(const Coordinate& p, const CoordinateSequence* pt)
- //LineIntersector lineIntersector;
- size_t ptsize = pt->getSize();
- if ( ptsize == 0 ) return false;
- const Coordinate *pp=&(pt->getAt(0));
- for(size_t i=1; i<ptsize; ++i)
- const Coordinate &p1=pt->getAt(i);
- if ( LineIntersector::hasIntersection(p, *pp, p1) )
- return true;
- pp=&p1;
- return false;
-/*public static*/
-bool
-CGAlgorithms::isCCW(const CoordinateSequence* ring)
- // sanity check
- if (ring->getSize() < 4)
- throw util::IllegalArgumentException("Ring has fewer than 3 points, so orientation cannot be determined");
- // # of points without closing endpoint
- const std::size_t nPts=ring->getSize()-1;
- // find highest point
- const Coordinate *hiPt=&ring->getAt(0);
- size_t hiIndex = 0;
- for (std::size_t i = 1; i <= nPts; ++i)
- const Coordinate *p=&ring->getAt(i);
- if (p->y > hiPt->y) {
- hiPt = p;
- hiIndex = i;
- // find distinct point before highest point
- auto iPrev = hiIndex;
- do {
- if (iPrev == 0)
- iPrev = nPts;
- iPrev = iPrev - 1;
- } while (ring->getAt(iPrev) == *hiPt && iPrev != hiIndex);
- // find distinct point after highest point
- auto iNext = hiIndex;
- do {
- iNext = (iNext + 1) % nPts;
- } while (ring->getAt(iNext)==*hiPt && iNext != hiIndex);
- const Coordinate *prev=&ring->getAt(iPrev);
- const Coordinate *next=&ring->getAt(iNext);
- * This check catches cases where the ring contains an A-B-A
- * configuration of points.
- * This can happen if the ring does not contain 3 distinct points
- * (including the case where the input array has fewer than 4 elements),
- * or it contains coincident line segments.
- if ( prev->equals2D(*hiPt) || next->equals2D(*hiPt) ||
- prev->equals2D(*next) )
- return false;
- // MD - don't bother throwing exception,
- // since this isn't a complete check for ring validity
- //throw IllegalArgumentException("degenerate ring (does not contain 3 distinct points)");
- int disc = computeOrientation(*prev, *hiPt, *next);
- * If disc is exactly 0, lines are collinear.
- * There are two possible cases:
- * (1) the lines lie along the x axis in opposite directions
- * (2) the lines lie on top of one another
- * (1) is handled by checking if next is left of prev ==> CCW
- * (2) should never happen, so we're going to ignore it!
- * (Might want to assert this)
- bool isCCW=false;
- if (disc == 0) {
- // poly is CCW if prev x is right of next x
- isCCW = (prev->x > next->x);
- } else {
- // if area is positive, points are ordered CCW
- isCCW = (disc > 0);
- return isCCW;
-/*public static*/
-int
-CGAlgorithms::computeOrientation(const Coordinate& p1, const Coordinate& p2,
- const Coordinate& q)
- return orientationIndex(p1,p2,q);
-/*public static*/
-double
-CGAlgorithms::distancePointLine(const Coordinate& p, const Coordinate& A,
- const Coordinate& B)
- //if start==end, then use pt distance
- if (A==B) return p.distance(A);
- // otherwise use comp.graphics.algorithms Frequently Asked Questions method
- /*(1) AC dot AB
- r = ---------
- ||AB||^2
- r has the following meaning:
- r=0 P = A
- r=1 P = B
- r<0 P is on the backward extension of AB
- r>1 P is on the forward extension of AB
- 0<r<1 P is interior to AB
- double r=((p.x-A.x)*(B.x-A.x)+(p.y-A.y)*(B.y-A.y))/
- ((B.x-A.x)*(B.x-A.x)+(B.y-A.y)*(B.y-A.y));
- if (r<=0.0) return p.distance(A);
- if (r>=1.0) return p.distance(B);
- /*(2)
- (Ay-Cy)(Bx-Ax)-(Ax-Cx)(By-Ay)
- s = -----------------------------
- L^2
- Then the distance from C to P = |s|*L.
- double s=((A.y-p.y)*(B.x-A.x)-(A.x-p.x)*(B.y-A.y))/
- return fabs(s)*sqrt(((B.x-A.x)*(B.x-A.x)+(B.y-A.y)*(B.y-A.y)));
-/*public static*/
-double
-CGAlgorithms::distancePointLinePerpendicular(const Coordinate& p,const Coordinate& A,const Coordinate& B)
- // use comp.graphics.algorithms Frequently Asked Questions method
- /*(2)
- L^2
- double s = ((A.y - p.y) *(B.x - A.x) - (A.x - p.x)*(B.y - A.y) )
- ((B.x - A.x) * (B.x - A.x) + (B.y - A.y) * (B.y - A.y) );
- return fabs(s)*sqrt(((B.x - A.x) * (B.x - A.x) + (B.y - A.y) * (B.y - A.y)));
-/*public static*/
-double
-CGAlgorithms::distanceLineLine(const Coordinate& A, const Coordinate& B,
- const Coordinate& C, const Coordinate& D)
- // check for zero-length segments
- if (A==B) return distancePointLine(A,C,D);
- if (C==D) return distancePointLine(D,A,B);
- // AB and CD are line segments
- /* from comp.graphics.algo
- Solving the above for r and s yields
- (Ay-Cy)(Dx-Cx)-(Ax-Cx)(Dy-Cy)
- r = ----------------------------- (eqn 1)
- (Bx-Ax)(Dy-Cy)-(By-Ay)(Dx-Cx)
- s = ----------------------------- (eqn 2)
- Let P be the position vector of the intersection point, then
- P=A+r(B-A) or
- Px=Ax+r(Bx-Ax)
- Py=Ay+r(By-Ay)
- By examining the values of r & s, you can also determine some other
-limiting conditions:
- If 0<=r<=1 & 0<=s<=1, intersection exists
- r<0 or r>1 or s<0 or s>1 line segments do not intersect
- If the denominator in eqn 1 is zero, AB & CD are parallel
- If the numerator in eqn 1 is also zero, AB & CD are collinear.
- double r_top=(A.y-C.y)*(D.x-C.x)-(A.x-C.x)*(D.y-C.y);
- double r_bot=(B.x-A.x)*(D.y-C.y)-(B.y-A.y)*(D.x-C.x);
- double s_top=(A.y-C.y)*(B.x-A.x)-(A.x-C.x)*(B.y-A.y);
- double s_bot=(B.x-A.x)*(D.y-C.y)-(B.y-A.y)*(D.x-C.x);
- if ((r_bot==0)||(s_bot==0)) {
- return std::min(distancePointLine(A,C,D),
- std::min(distancePointLine(B,C,D),
- std::min(distancePointLine(C,A,B), distancePointLine(D,A,B))));
- double s=s_top/s_bot;
- double r=r_top/r_bot;
- if ((r<0)||( r>1)||(s<0)||(s>1)) {
- //no intersection
- return 0.0; //intersection exists
-/*public static*/
-double
-CGAlgorithms::signedArea(const CoordinateSequence* ring)
- size_t npts=ring->getSize();
- if (npts<3) return 0.0;
- Coordinate pp;
- Coordinate cp = ring->getAt(0);
- Coordinate np = ring->getAt(1);
- double x0 = cp.x;
- np.x -= x0;
- double sum=0.0;
- for (size_t i=1; i<npts; ++i)
- pp.y = cp.y;
- cp.x = np.x;
- cp.y = np.y;
- ring->getAt(i, np);
- np.x -= x0;
- sum += cp.x * (np.y - pp.y);
- return -sum/2.0;
-/*public static*/
-double
-CGAlgorithms::length(const CoordinateSequence* pts)
- // optimized for processing CoordinateSequences
- size_t npts=pts->getSize();
- if (npts <= 1) return 0.0;
- double len = 0.0;
- const Coordinate& p0 = pts->getAt(0);
- double x0 = p0.x;
- double y0 = p0.y;
- for(size_t i = 1; i < npts; ++i)
- const Coordinate& p = pts->getAt(i);
- double x1 = p.x;
- double y1 = p.y;
- double dx = x1 - x0;
- double dy = y1 - y0;
- len += sqrt(dx * dx + dy * dy);
- x0 = x1;
- y0 = y1;
- return len;
-} // namespace geos.algorithm
diff --git a/src/algorithm/Makefile.am b/src/algorithm/Makefile.am
index 520364e..f48c0bf 100644
--- a/src/algorithm/Makefile.am
+++ b/src/algorithm/Makefile.am
@@ -14,7 +14,6 @@ libalgorithm_la_SOURCES = \
Area.cpp \
BoundaryNodeRule.cpp \
Centroid.cpp \
- CGAlgorithms.cpp \
CGAlgorithmsDD.cpp \
ConvexHull.cpp \
Distance.cpp \
Summary of changes:
include/geos/algorithm/CGAlgorithms.h | 230 ----------------------
include/geos/algorithm/Makefile.am | 1 -
src/algorithm/CGAlgorithms.cpp | 354 ----------------------------------
src/algorithm/Makefile.am | 1 -
4 files changed, 586 deletions(-)
delete mode 100644 include/geos/algorithm/CGAlgorithms.h
delete mode 100644 src/algorithm/CGAlgorithms.cpp
hooks/post-receive
More information about the geos-commits
