[geos-commits] [SCM] GEOS branch master updated. 6ca3f4c20514e2b8b80e57d09da924297b6a6dd1
git at osgeo.org
git at osgeo.org
Thu Dec 27 17:48:31 PST 2018
the project "GEOS".
via 6ca3f4c20514e2b8b80e57d09da924297b6a6dd1 (commit)
via 33c1e7bc78dbfffcaf9a05744e49b76d91d21d2f (commit)
from 1866159c644fb5c74f13f0714ebaba8e5c3e65ff (commit)
revisions in full, below.
commit 6ca3f4c20514e2b8b80e57d09da924297b6a6dd1
Merge: 1866159 33c1e7b
Author: Daniel Baston <dbaston at gmail.com>
Date: Thu Dec 27 20:48:03 2018 -0500
Merge remote-tracking branch 'sir-sigurd/geometry-item-srid'
diff --cc tests/unit/geom/GeometryCollectionTest.cpp
index 89860f7,b906ba1..d49a230
--- a/tests/unit/geom/GeometryCollectionTest.cpp
+++ b/tests/unit/geom/GeometryCollectionTest.cpp
@@@ -1,56 -1,56 +1,83 @@@
// Test Suite for geos::geom::GeometryCollection class.
-// tut
#include <tut/tut.hpp>
#include <utility.h>
-// geos
-#include <geos/geom/GeometryFactory.h>
-#include <geos/geom/GeometryCollection.h>
-// std
-#include <vector>
-namespace tut
+namespace tut {
- // Test Group
+ // Test Group
+ // Common data used by tests
- struct test_geometrycollection_data {};
++ struct test_geometry_collection_data {
++ typedef geos::geom::GeometryFactory GeometryFactory;
++ geos::geom::PrecisionModel pm_;
++ GeometryFactory::Ptr factory_;
- typedef test_group<test_geometrycollection_data> group;
++ test_geometry_collection_data()
++ : pm_(1000), factory_(GeometryFactory::create(&pm_, 0))
++ typedef test_group<test_geometry_collection_data> group;
+ typedef group::object object;
- // Common data used by tests
- struct test_geometry_collection_data {
- typedef geos::geom::GeometryFactory GeometryFactory;
- group test_geometrycollection_group("geos::geom::GeometryCollection");
++ group test_geometry_collection_group("geos::geom::GeometryCollection");
- geos::geom::PrecisionModel pm_;
- GeometryFactory::Ptr factory_;
+ // Test Cases
- test_geometry_collection_data()
- : pm_(1000), factory_(GeometryFactory::create(&pm_, 0))
++#if 0
++ // Test of user's constructor to build empty Point
++ template<>
++ template<>
++ void object::test<1>()
++ GeometryPtr empty_point = factory_->createPoint();
++ ensure( empty_point != nullptr );
- typedef test_group<test_geometry_collection_data> group;
- typedef group::object object;
++ geos::geom::Coordinate coord(1, 2);
++ GeometryPtr point = factory_->createPoint(coord);
++ ensure( point != nullptr );
- group test_geometry_collection_group("geos::geom::GeometryCollection");
++ std::vector<GeometryPtr> geoms{empty_point, point};
++ GeometryColPtr col = factory_->createGeometryCollection(geoms);
++ ensure( col != nullptr );
- // Test Cases
++ ensure( col->getCoordinate() != nullptr );
++ ensure_equals( col->getCoordinate()->x, 1 );
++ ensure_equals( col->getCoordinate()->y, 2 );
- // Test of user's constructor to build empty Point
- template<>
- template<>
- void object::test<1>()
- GeometryPtr empty_point = factory_->createPoint();
- ensure( empty_point != nullptr );
+ // Test of default constructor
+ template<>
+ template<>
++ void object::test<2>()
- using geos::geom::GeometryFactory;
+ geos::geom::PrecisionModel pm;
+ auto gf = GeometryFactory::create(&pm, 1);
+ auto g = gf->createEmptyGeometry();
- geos::geom::Coordinate coord(1, 2);
- GeometryPtr point = factory_->createPoint(coord);
- ensure( point != nullptr );
+ g->setSRID(0);
+ std::vector<decltype(g)> v = {g};
+ auto geom_col = gf->createGeometryCollection(v);
+ ensure_equals(geom_col->getGeometryN(0)->getSRID(), 1);
- std::vector<GeometryPtr> geoms{empty_point, point};
- GeometryColPtr col = factory_->createGeometryCollection(geoms);
- ensure( col != nullptr );
+ geom_col->setSRID(2);
+ ensure_equals(geom_col->getGeometryN(0)->getSRID(), 2);
- ensure( col->getCoordinate() != nullptr );
- ensure_equals( col->getCoordinate()->x, 1 );
- ensure_equals( col->getCoordinate()->y, 2 );
+ auto clone = geom_col->clone();
+ ensure_equals(clone->getGeometryN(0)->getSRID(), 2);
+ // FREE MEMORY
+ gf->destroyGeometry(geom_col);
+ gf->destroyGeometry(clone);
++#endif
} // namespace tut
commit 33c1e7bc78dbfffcaf9a05744e49b76d91d21d2f
Author: Sergey Fedoseev <fedoseev.sergey at gmail.com>
Date: Sun Sep 16 18:07:06 2018 +0500
Fix #924: Geometries returned by getGeometryN() now have the same SRID as collection.
diff --git a/include/geos/geom/GeometryCollection.h b/include/geos/geom/GeometryCollection.h
index c255ecf..7832d26 100644
--- a/include/geos/geom/GeometryCollection.h
+++ b/include/geos/geom/GeometryCollection.h
@@ -78,6 +78,8 @@ public:
~GeometryCollection() override;
+ void setSRID(int) override;
* \brief
* Collects all coordinates of all subgeometries into a
diff --git a/src/geom/GeometryCollection.cpp b/src/geom/GeometryCollection.cpp
index 3ead8fa..d893d9e 100644
--- a/src/geom/GeometryCollection.cpp
+++ b/src/geom/GeometryCollection.cpp
@@ -53,8 +53,6 @@ GeometryCollection::GeometryCollection(const GeometryCollection &gc)
for(size_t i=0; i<ngeoms; ++i)
(*geometries)[i]=(*gc.geometries)[i]->clone();
- // Drop SRID from inner geoms
- (*geometries)[i]->setSRID(0);
@@ -72,11 +70,21 @@ GeometryCollection::GeometryCollection(vector<Geometry *> *newGeoms, const Geome
geometries=newGeoms;
+ // Set SRID for inner geoms
size_t ngeoms=geometries->size();
+ (*geometries)[i]->setSRID(getSRID());
+void
+GeometryCollection::setSRID(int newSRID)
+ Geometry::setSRID(newSRID);
+ for (size_t i = 0; i < geometries->size(); i++)
+ (*geometries)[i]->setSRID(newSRID);
diff --git a/src/io/WKBWriter.cpp b/src/io/WKBWriter.cpp
index dbc0d4c..f9bd7ff 100644
--- a/src/io/WKBWriter.cpp
+++ b/src/io/WKBWriter.cpp
@@ -203,6 +203,8 @@ WKBWriter::writeGeometryCollection(const GeometryCollection &g,
auto ngeoms = g.getNumGeometries();
writeInt(static_cast<int>(ngeoms));
+ auto orig_includeSRID = includeSRID;
+ includeSRID = false;
assert(outStream);
for (std::size_t i=0; i<ngeoms; i++)
@@ -212,6 +214,7 @@ WKBWriter::writeGeometryCollection(const GeometryCollection &g,
write(*elem, *outStream);
+ includeSRID = orig_includeSRID;
void
diff --git a/tests/unit/Makefile.am b/tests/unit/Makefile.am
index 8f02cc4..bcfaf6e 100644
--- a/tests/unit/Makefile.am
+++ b/tests/unit/Makefile.am
@@ -58,6 +58,7 @@ geos_unit_SOURCES = \
geom/CoordinateTest.cpp \
geom/DimensionTest.cpp \
geom/EnvelopeTest.cpp \
+ geom/GeometryCollectionTest.cpp \
geom/Geometry/clone.cpp \
geom/Geometry/coversTest.cpp \
geom/Geometry/equalsTest.cpp \
diff --git a/tests/unit/geom/GeometryCollectionTest.cpp b/tests/unit/geom/GeometryCollectionTest.cpp
new file mode 100644
index 0000000..b906ba1
--- /dev/null
@@ -0,0 +1,56 @@
+// Test Suite for geos::geom::GeometryCollection class.
+// tut
+#include <tut/tut.hpp>
+#include <utility.h>
+// geos
+#include <geos/geom/GeometryFactory.h>
+#include <geos/geom/GeometryCollection.h>
+// std
+#include <vector>
+namespace tut
+ // Test Group
+ struct test_geometrycollection_data {};
+ typedef test_group<test_geometrycollection_data> group;
+ group test_geometrycollection_group("geos::geom::GeometryCollection");
+ // Test Cases
+ template<>
+ template<>
+ using geos::geom::GeometryFactory;
+ g->setSRID(0);
+ // FREE MEMORY
+} // namespace tut
Summary of changes:
include/geos/geom/GeometryCollection.h | 2 +
src/geom/GeometryCollection.cpp | 16 +++--
src/io/WKBWriter.cpp | 3 +
tests/unit/Makefile.am | 2 +-
tests/unit/geom/GeometryCollectionTest.cpp | 97 +++++++++++++++++++-----------
5 files changed, 80 insertions(+), 40 deletions(-)
hooks/post-receive
More information about the geos-commits
