[geos-commits] [SCM] geos branch master updated.	0f722dc002ff8f907078193548b9ce8e028b5da2
    git at osgeo.org
    git at osgeo.org
    Sat Jan 20 22:26:41 PST 2018
the project "geos".
       via  0f722dc002ff8f907078193548b9ce8e028b5da2 (commit)
       via  4b23f09c8e0ff3d178cc6538c3bf4e52b80e33cf (commit)
      from  759255faaeb946e59266460d41a08e1eb70233e8 (commit)
revisions in full, below.
commit 0f722dc002ff8f907078193548b9ce8e028b5da2
Merge: 759255f 4b23f09
Author: robe <lr at pcorp.us>
Date:   Sat Jan 20 22:26:40 2018 -0800
    Merge branch 'ticket853-from-master' of cvvergara/geos into master
commit 4b23f09c8e0ff3d178cc6538c3bf4e52b80e33cf
Author: cvvergara <vicky at georepublic.de>
Date:   Sat Jan 20 11:33:12 2018 -0600
    Updating platform.h.cmake Close #853
diff --git a/include/geos/platform.h.cmake b/include/geos/platform.h.cmake
index 035a48a..9640966 100644
--- a/include/geos/platform.h.cmake
+++ b/include/geos/platform.h.cmake
@@ -5,13 +5,14 @@
  * GEOS - Geometry Engine Open Source
  * http://geos.osgeo.org
+ * Copyright (C) 2018 Vicky Vergara
  * Copyright (C) 2009 Mateusz Loskot
  * Copyright (C) 2005-2009 Refractions Research Inc.
  * Copyright (C) 2001-2009 Vivid Solutions Inc.
  * This is free software; you can redistribute and/or modify it under
  * the terms of the GNU Lesser General Public Licence as published
- * by the Free Software Foundation.
+ * by the Free Software Foundation.
  * See the COPYING file for more information.
@@ -28,138 +29,58 @@
 /* Disable inclusion of platform.h not generated by CMake */
 #define GEOS_PLATFORM_H 1
-/* Set to 1 if you have stdint.h */
-#cmakedefine HAVE_STDINT_H 1
-/* Set to 1 if you have inttypes.h */
-#cmakedefine HAVE_INTTYPES_H 1
 /* Set to 1 if you have ieeefp.h */
 #cmakedefine HAVE_IEEEFP_H 1
-/* Set to 1 if you have `int64_t' type */
-#cmakedefine HAVE_INT64_T_64 1
-/* Set to 1 if `long int' is 64 bits */
-#cmakedefine HAVE_LONG_INT_64 1
-/* Set to 1 if `long long int' is 64 bits */
-#cmakedefine HAVE_LONG_LONG_INT_64 1
-/* Set to 1 if C++/C99 std::isnan is defined */
-#cmakedefine HAVE_STD_ISNAN 1
-/* Set to 1 if C99 isnan is defined */
-#cmakedefine HAVE_ISNAN 1
-/* Set to 1 if XCode __isnand is defined */
-#cmakedefine HAVE_ISNAND_XCODE 1
-/* Set to 1 if XCode __inline_isnand is defined */
-#cmakedefine HAVE_INLINE_ISNAND_XCODE 1
-/* Set to 1 if C++/C99 std::isfinite is defined */
-#cmakedefine HAVE_STD_ISFINITE 1
-/* Set to 1 if C99 isfinite is defined */
-#cmakedefine HAVE_ISFINITE 1
-/* Set to 1 if Visual C++ finite is defined */
-#cmakedefine HAVE_FINITE 1
-#ifdef HAVE_IEEEFP_H
-extern "C"
-#include <ieeefp.h>
-#endif
-#ifdef HAVE_INTTYPES_H
-extern "C"
-#include <inttypes.h>
-# ifndef HAVE_INT64_T_64
-#  error Warning: inttypes.h included but HAVE_INT64_T_64 not defined
-# endif
-#endif
-/* We need M_PI, but on MSVC you need to define _USE_MATH_DEFINES before
- * including math.h to get it.  If we are too late (math.h already included)
- * we will define it manually.
 #ifdef _MSC_VER
-#define _USE_MATH_DEFINES
-#include <cmath>
-#include <float.h>
-#else
-#include <cmath>
+#  define _USE_MATH_DEFINES
 #endif
+#include <cmath>
 #include <limits>
+#include <cinttypes>
 #ifndef M_PI
 #define M_PI 3.14159265358979323846
 #endif
-/* For MingW the appropriate definitions are included in math.h
- * and float.h but the definitions in math.h are only included
- * if __STRICT_ANSI__ is not defined. Since GEOS is compiled
- * with -ansi that means those definitions are not available.
-#if defined(__GNUC__) && defined(_WIN32)
-#include <float.h>
-#endif
+typedef int64_t int64;
-#ifdef HAVE_INT64_T_64
-# ifdef _MSC_VER
-   typedef __int64 int64;
-# else
-   typedef int64_t int64;
-# endif
+#if defined(_MSC_VER) && _MSC_VER >= 1200 // VC++ 6.0 and above
+#  include <float.h>
+#  ifndef FINITE
+#    define FINITE(x) _finite(x)
+#  endif
+#  ifndef ISNAN
+#    define ISNAN(x) _isnan(x)
+#  endif
+#elif !defined(HAVE_IEEEFP_H)
+#  include <cmath>
+#  ifndef FINITE
+#    define FINITE(x) std::isfinite(x)
+#  endif
+#  ifndef ISNAN
+#    define ISNAN(x) std::isnan(x)
+#  endif
 #else
-# ifdef HAVE_LONG_LONG_INT_64
-   typedef long long int int64;
-# else
-   typedef long int int64;
-#  ifndef HAVE_LONG_INT_64
-#   define INT64_IS_REALLY32 1
-#   warning "Could not find 64bit integer definition!"
+#  include <ieeefp.h>
+#  ifndef FINITE
+#    define FINITE(x) finite(x)
+#  endif
+#  ifndef ISNAN
+#    define ISNAN(x) isnan(x)
 #  endif
-# endif
 #endif
-#if defined(HAVE_STD_ISNAN)
-# define ISNAN(x) (std::isnan)(x)
-#elif defined(HAVE_INLINE_ISNAND_XCODE)
-# define ISNAN(x) __inline_isnand(static_cast<double>(x))
-#elif defined(HAVE_ISNAND_XCODE)
-# define ISNAN(x) __isnand(static_cast<double>(x))
-#elif defined(HAVE_ISNAN)
-# if defined(_MSC_VER)
-#  define ISNAN(x) _isnan(static_cast<double>(x))
-# else
-#  define ISNAN(x) isnan(x)
-# endif
-#else
-# error "Could not find isnan function or macro!"
-#endif
-#if defined(HAVE_STD_ISFINITE)
-# define FINITE(x) (std::isfinite)(x)
-#elif defined(HAVE_ISFINITE)
-# define FINITE(x) isfinite(x)
-#elif defined(HAVE_FINITE)
-# define FINITE(x) _finite(static_cast<double>(x))
-#else
-# error "Could not find finite or isfinite function or macro!"
-#endif
+// Some handy constants
+constexpr double DoubleNotANumber = std::numeric_limits<double>::quiet_NaN();
+constexpr double DoubleMax = (std::numeric_limits<double>::max)();
+constexpr double DoubleInfinity = (std::numeric_limits<double>::infinity)();
+constexpr double DoubleNegInfinity = (-(std::numeric_limits<double>::infinity)());
-#define DoubleNegInfinity (-(std::numeric_limits<double>::infinity)())
-#define DoubleMax (std::numeric_limits<double>::max)()
-// Defines NaN for Intel platforms
-#define DoubleNotANumber std::numeric_limits<double>::quiet_NaN()
-// Don't forget to define infinities
-#define DoubleInfinity (std::numeric_limits<double>::infinity)()
 #endif // GEOS_PLATFORM_H_INCLUDED
Summary of changes:
 include/geos/platform.h.cmake |  153 ++++++++++-------------------------------
 1 file changed, 37 insertions(+), 116 deletions(-)
hooks/post-receive
geos
More information about the geos-commits
