[geos-commits] [SCM] GEOS branch master updated. c13f07516098e0cb4b4fe5c58c678d27b38b580e
git at osgeo.org
git at osgeo.org
Tue Jul 17 13:00:15 PDT 2018
the project "GEOS".
via c13f07516098e0cb4b4fe5c58c678d27b38b580e (commit)
from 311989f1586a58a66f21f3da51880ecabcb7a96c (commit)
revisions in full, below.
commit c13f07516098e0cb4b4fe5c58c678d27b38b580e
Author: Daniel Baston <dbaston at gmail.com>
Date: Tue Jul 17 15:59:59 2018 -0400
Fix typos
diff --git a/capi/geos_c.h.in b/capi/geos_c.h.in
index 639aa67..db48e15 100644
--- a/capi/geos_c.h.in
+++ b/capi/geos_c.h.in
@@ -21,7 +21,7 @@
* functions, and call finishGEOS() when done.
* - Currently you have to explicitly GEOSGeom_destroy() all
- * GEOSGeom objects to avoid memory leaks, and to GEOSFree()
+ * GEOSGeom objects to avoid memory leaks, and GEOSFree()
* all returned char * (unless const).
* - Functions ending with _r are thread safe; see details in RFC 3
@@ -146,7 +146,7 @@ enum GEOSGeomTypes {
GEOS_GEOMETRYCOLLECTION
-/* Byte oders exposed via the c api */
+/* Byte orders exposed via the C API */
enum GEOSByteOrders {
GEOS_WKB_XDR = 0, /* Big Endian */
GEOS_WKB_NDR = 1 /* Little Endian */
@@ -706,7 +706,7 @@ extern GEOSGeometry GEOS_DLL * GEOSDelaunayTriangulation_r(
* @param g the input geometry whose vertex will be used as sites.
* @param tolerance snapping tolerance to use for improved robustness
- * @param onlyEdges whether to return only edges of the voronoi cells
+ * @param onlyEdges whether to return only edges of the Voronoi cells
* @param env clipping envelope for the returned diagram, automatically
* determined if NULL.
* The diagram will be clipped to the larger
Summary of changes:
capi/geos_c.h.in | 6 +++---
1 file changed, 3 insertions(+), 3 deletions(-)
hooks/post-receive
More information about the geos-commits
