[geos-commits] [SCM] GEOS branch master updated. de4927dfa262c31f439191ea2bb6aae9f707b689
Mon Jul 30 18:05:24 PDT 2018
the project "GEOS".
       via  de4927dfa262c31f439191ea2bb6aae9f707b689 (commit)
      from  3de3ccc96a22030e65d0200f4d35a076617361d9 (commit)
revisions in full, below.
commit de4927dfa262c31f439191ea2bb6aae9f707b689
Author: Daniel Baston <dbaston at gmail.com>
Date:   Mon Jul 30 21:04:41 2018 -0400
    Fix infinite loop in GEOSClipByRect
    Fixes #865
    Closes https://github.com/libgeos/geos/pull/110
diff --git a/src/operation/intersection/RectangleIntersection.cpp b/src/operation/intersection/RectangleIntersection.cpp
index 850fb0b..04f5615 100644
--- a/src/operation/intersection/RectangleIntersection.cpp
+++ b/src/operation/intersection/RectangleIntersection.cpp
@@ -60,6 +60,11 @@ bool different(double x1, double y1, double x2, double y2)
 inline
 void clip_one_edge(double & x1, double & y1, double x2, double y2, double limit)
+  if (x2 == limit) {
+  	y1 = y2;
+    x1 = x2;
   if(x1 != x2)
 	  y1 += (y2-y1)*(limit-x1)/(x2-x1);
diff --git a/src/operation/intersection/RectangleIntersectionBuilder.cpp b/src/operation/intersection/RectangleIntersectionBuilder.cpp
index ec61493..5bd0c4e 100644
--- a/src/operation/intersection/RectangleIntersectionBuilder.cpp
+++ b/src/operation/intersection/RectangleIntersectionBuilder.cpp
@@ -22,6 +22,7 @@
 #include <geos/geom/LineString.h>
 #include <geos/geom/LinearRing.h>
 #include <geos/algorithm/CGAlgorithms.h>
+#include <geos/util/IllegalArgumentException.h>
 #include <cmath> // for fabs()
@@ -184,6 +185,13 @@ double distance(const Rectangle & rect,
   Rectangle::Position pos = rect.position(x1,y1);
   Rectangle::Position endpos = rect.position(x2,y2);
+  if (pos & Rectangle::Position::Outside ||
+      endpos & Rectangle::Position::Outside ||
+	  pos & Rectangle::Position::Inside ||
+	  endpos & Rectangle::Position::Inside) {
+  	throw geos::util::IllegalArgumentException("Can't compute distance to non-boundary position.");
   while(true)
 	  // Close up when we have the same edge and the
diff --git a/tests/unit/operation/intersection/RectangleIntersectionTest.cpp b/tests/unit/operation/intersection/RectangleIntersectionTest.cpp
index 0bd73eb..89c60ed 100644
--- a/tests/unit/operation/intersection/RectangleIntersectionTest.cpp
+++ b/tests/unit/operation/intersection/RectangleIntersectionTest.cpp
@@ -101,7 +101,6 @@ namespace tut
     typedef group::object object;
     group test_rectangleintersectiontest_group("geos::operation::intersection::RectangleIntersection");
     // inside
     template<> template<> void object::test<1>()
@@ -1514,4 +1513,19 @@ namespace tut
         "POLYGON((0 0,0 10,10 10,10 0,0 0))";
       doClipTest(inp, exp, r);
+    // PostGIS hanging unit test
+    template<> template<> void object::test<208>()
+      Rectangle r(3.0481343214686657e-14, -20000000.000000, 20000000.000000, -1.000000);
+      const char *clip =
+        "POLYGON((3.0481343214686657e-14 -20000000, 200000000 -20000000, 200000000 -1, 3.0481343214686657e-14 -1, 3.0481343214686657e-14 -20000000))";
+      const char *inp =
+        "POLYGON((3.0481343214686657e-14 -20000000, 3.0481343214686657e-14 -1, 1.570795680861262382313481289e-3 -0.999998766299703523152686557296, 3.141587485909849188081555127e-3 -0.999995065201858102099663483386, 3.0481343214686657e-14 -20000000))";
+      GeomPtr isect{readWKT(clip)->intersection(readWKT(inp).get())};
+      std::string exp = wktwriter.write(isect.get());
+      doClipTest(inp, exp, r, 1e-20);
Summary of changes:
 src/operation/intersection/RectangleIntersection.cpp     |  5 +++++
 .../intersection/RectangleIntersectionBuilder.cpp        |  8 ++++++++
 .../operation/intersection/RectangleIntersectionTest.cpp | 16 +++++++++++++++-
 3 files changed, 28 insertions(+), 1 deletion(-)
hooks/post-receive
More information about the geos-commits mailing list
