[geos-commits] [SCM] GEOS branch master updated. 851b9161b3291bd6c44ffddd83793bf6995409ec
git at osgeo.org
git at osgeo.org
Thu Jun 14 21:44:11 PDT 2018
the project "GEOS".
via 851b9161b3291bd6c44ffddd83793bf6995409ec (commit)
via 5ac4db28a53cc8762afd976e57fe9ebd565fc8fd (commit)
from 94da3a382001f63b1516bf54df1ebbd4c6bc463a (commit)
revisions in full, below.
commit 851b9161b3291bd6c44ffddd83793bf6995409ec
Merge: 94da3a3 5ac4db2
Author: Regina Obe <lr at pcorp.us>
Date: Thu Jun 14 21:44:10 2018 -0700
Merge branch 'issue742' of cvvergara/geos into master
commit 5ac4db28a53cc8762afd976e57fe9ebd565fc8fd
Author: cvvergara <vicky at georepublic.de>
Date: Thu Jun 14 09:08:12 2018 -0500
Applying patches for Closes #742
* 01-geos-config.patch
* Description: Fix library paths.
* Author: Francesco Paolo Lovergine <frankie at debian.org>
* 02-ruby2.patch
* Description: Update include and libraries paths for Ruby 2.x.
* Fix linking with libruby.
* Author: Bas Couwenberg <sebastic at debian.org>
* 03-disable-docygen-html-timestamp.patch
* Description: Disable HTML timestamps in Doxygen to allow reproducible builds.
* https://wiki.debian.org/ReproducibleBuilds/
diff --git a/doc/Doxyfile.in b/doc/Doxyfile.in
index 084b1d7..5798cc6 100644
--- a/doc/Doxyfile.in
+++ b/doc/Doxyfile.in
@@ -472,6 +472,12 @@ HTML_FOOTER =
HTML_STYLESHEET =
+# If the HTML_TIMESTAMP tag is set to YES then the footer of each generated HTML
+# page will contain the date and time when the page was generated. Setting
+# this to NO can help when comparing the output of multiple runs.
+HTML_TIMESTAMP = NO
# If the HTML_ALIGN_MEMBERS tag is set to YES, the members of classes,
# files or namespaces will be aligned in HTML using tables. If set to
# NO a bullet list will be used.
diff --git a/macros/ruby.m4 b/macros/ruby.m4
index f599e1f..c2e581e 100644
--- a/macros/ruby.m4
+++ b/macros/ruby.m4
@@ -1,4 +1,4 @@
## Ruby file handling
## From Charlie Savage
@@ -12,9 +12,9 @@
AC_DEFUN([AC_RUBY_DEVEL],
- dnl Find a Ruby interpreter
+ dnl Find a Ruby interpreter
AC_PATH_PROG([RUBY],[ruby])
if test -z "$RUBY" ; then
AC_MSG_ERROR([Could not find ruby interpreter.])
RUBY=''
@@ -25,39 +25,49 @@ AC_DEFUN([AC_RUBY_DEVEL],
dnl Get Ruby bin directory
RUBY_BIN_DIR=`$RUBY -rrbconfig -e 'puts RbConfig::CONFIG[["bindir"]] || Config::CONFIG[["bindir"]]'`
- dnl Get Ruby site arch
+ dnl Get Ruby site arch
RUBY_SITE_ARCH=`$RUBY -rrbconfig -e 'puts RbConfig::CONFIG[["sitearch"]] || Config::CONFIG[["sitearch"]]'`
dnl Get Ruby include directory
RUBY_INCLUDE_DIR=`$RUBY -rrbconfig -e 'puts RbConfig::CONFIG[["rubyhdrdir"]] || Config::CONFIG[["archdir"]]'`
+ dnl Get Ruby config.h include directory
+ RUBY_ARCH_INCLUDE_DIR=`$RUBY -rrbconfig -e 'puts RbConfig::CONFIG[["rubyarchhdrdir"]] || Config::CONFIG[["archdir"]]'`
dnl Get Ruby lib directory
RUBY_LIB_DIR=`$RUBY -rrbconfig -e 'puts RbConfig::CONFIG[["libdir"]] || Config::CONFIG[["libdir"]]'`
+ dnl Get Ruby arch lib directory
+ RUBY_ARCH_LIB_DIR=`$RUBY -rrbconfig -e 'puts RbConfig::CONFIG[["archlibdir"]] || Config::CONFIG[["archlibdir"]]'`
dnl Get Ruby extensions directory
RUBY_EXTENSION_DIR=`$RUBY -rrbconfig -e 'puts RbConfig::CONFIG[["sitearchdir"]] || Config::CONFIG[["sitearchdir"]]'`
dnl Get Ruby shared library name, this does not include the lib prefix or extension name
RUBY_SO_NAME=`$RUBY -rrbconfig -e 'puts RbConfig::CONFIG[["RUBY_SO_NAME"]] || Config::CONFIG[["RUBY_SO_NAME"]]'`
dnl Get Ruby shared libary name
RUBY_SHARED_LIB=`$RUBY -rrbconfig -e 'puts RbConfig::CONFIG[["LIBRUBY"]] || Config::CONFIG[["LIBRUBY"]]'`
AC_MSG_NOTICE([Ruby executable is '$RUBY'])
AC_MSG_NOTICE([Ruby version is '$RUBY_VERSION'])
AC_MSG_NOTICE([Ruby bin directory is '$RUBY_BIN_DIR'])
AC_MSG_NOTICE([Ruby site arch is '$RUBY_SITE_ARCH'])
AC_MSG_NOTICE([Ruby include directory is '$RUBY_INCLUDE_DIR'])
+ AC_MSG_NOTICE([Ruby config.h include directory is '$RUBY_ARCH_INCLUDE_DIR'])
AC_MSG_NOTICE([Ruby library directory is '$RUBY_LIB_DIR'])
+ AC_MSG_NOTICE([Ruby architecture library directory is '$RUBY_ARCH_LIB_DIR'])
AC_MSG_NOTICE([Ruby extension directory is '$RUBY_EXTENSION_DIR'])
AC_MSG_NOTICE([Ruby library is '$RUBY_SO_NAME'])
AC_MSG_NOTICE([Ruby import library is '$RUBY_SHARED_LIB'])
AC_SUBST([RUBY_VERSION])
AC_SUBST([RUBY_BIN_DIR])
AC_SUBST([RUBY_SITE_ARCH])
AC_SUBST([RUBY_INCLUDE_DIR])
+ AC_SUBST([RUBY_ARCH_INCLUDE_DIR])
AC_SUBST([RUBY_LIB_DIR])
+ AC_SUBST([RUBY_ARCH_LIB_DIR])
AC_SUBST([RUBY_EXTENSION_DIR])
AC_SUBST([RUBY_SO_NAME])
AC_SUBST([RUBY_SHARED_LIB])
diff --git a/swig/ruby/Makefile.am b/swig/ruby/Makefile.am
index 54070f4..fb29bdd 100644
--- a/swig/ruby/Makefile.am
+++ b/swig/ruby/Makefile.am
@@ -17,18 +17,18 @@ BUILT_SOURCES = geos_wrap.cxx
rubyextensiondirdir = $(RUBY_EXTENSION_DIR)
# Setup includes
-AM_CPPFLAGS = -I$(RUBY_INCLUDE_DIR) -I$(RUBY_INCLUDE_DIR)/$(RUBY_SITE_ARCH)
+AM_CPPFLAGS = -I$(RUBY_INCLUDE_DIR) -I$(RUBY_INCLUDE_DIR)/$(RUBY_SITE_ARCH) -I$(RUBY_ARCH_INCLUDE_DIR)
# Build Ruby module as shared library
rubyextensiondir_LTLIBRARIES = geos.la
geos_la_SOURCES = geos_wrap.cxx
-geos_la_LIBADD = $(top_builddir)/capi/libgeos_c.la $(RUBY_SO_NAME)
+geos_la_LIBADD = $(top_builddir)/capi/libgeos_c.la -l$(RUBY_SO_NAME)
# Only need to grab the capi header files
geos_la_CPPFLAGS = $(AM_CPPFLAGS) -I$(top_builddir)/capi
# Specify -module and -avoid-version so we can create a file called geos.dll/so which is what Ruby wants
-geos_la_LDFLAGS = -no-undefined -module -avoid-version -L$(RUBY_LIB_DIR)
+geos_la_LDFLAGS = -no-undefined -module -avoid-version -L$(RUBY_LIB_DIR) -L$(RUBY_ARCH_LIB_DIR)
if ENABLE_SWIG
diff --git a/tools/geos-config.in b/tools/geos-config.in
index 5af6cb7..8fc98df 100644
--- a/tools/geos-config.in
+++ b/tools/geos-config.in
@@ -43,7 +43,7 @@ case $1 in
--libs)
# TODO: make an alias for --clibs
# see http://trac.osgeo.org/geos/ticket/497
- echo -L${libdir} -lgeos
+ echo -L${libdir} -lgeos- at VERSION@
--clibs)
echo -L${libdir} -lgeos_c
Summary of changes:
doc/Doxyfile.in | 6 ++++++
macros/ruby.m4 | 26 ++++++++++++++++++--------
swig/ruby/Makefile.am | 6 +++---
tools/geos-config.in | 2 +-
4 files changed, 28 insertions(+), 12 deletions(-)
hooks/post-receive
More information about the geos-commits
