[geos-commits] [SCM] GEOS branch master updated. 7eb3369032d42425fafd4defe799f43f352215ec
Fri Jun 22 22:38:48 PDT 2018
the project "GEOS".
       via  7eb3369032d42425fafd4defe799f43f352215ec (commit)
       via  fe5b4d41ed19fc8c076a6482f60e10c50b488e0f (commit)
      from  681d852f9a12b3d0c03d90075f6c42aaf60a199f (commit)
revisions in full, below.
commit 7eb3369032d42425fafd4defe799f43f352215ec
Merge: 681d852 fe5b4d4
Author: Regina Obe <lr at pcorp.us>
Date:   Fri Jun 22 22:38:47 2018 -0700
    Merge branch 'add-GEOSGeomGetZ' of darkpanda/geos into master
commit fe5b4d41ed19fc8c076a6482f60e10c50b488e0f
Author: J Smith <dark.panda at gmail.com>
Date:   Tue Jan 19 12:54:05 2016 -0500
    Expose getZ to the CAPI via GEOSGeomGetZ.
diff --git a/capi/geos_c.cpp b/capi/geos_c.cpp
index 901556e..cd22cd4 100644
--- a/capi/geos_c.cpp
+++ b/capi/geos_c.cpp
@@ -666,6 +666,16 @@ GEOSGeomGetY(const Geometry *g, double *y)
+ * For POINT
+ * returns 0 on exception, otherwise 1
+int
+GEOSGeomGetZ(const Geometry *g1, double *z)
+	return GEOSGeomGetZ_r(handle, g1, z);
  * Call only on polygon
  * Return a copy of the internal Geometry.
diff --git a/capi/geos_c.h.in b/capi/geos_c.h.in
index 0c81f31..639aa67 100644
--- a/capi/geos_c.h.in
+++ b/capi/geos_c.h.in
@@ -1069,6 +1069,7 @@ extern int GEOS_DLL GEOSGeomGetNumPoints_r(GEOSContextHandle_t handle,
 /* Return -1 on exception, Geometry must be a Point. */
 extern int GEOS_DLL GEOSGeomGetX_r(GEOSContextHandle_t handle, const GEOSGeometry *g, double *x);
 extern int GEOS_DLL GEOSGeomGetY_r(GEOSContextHandle_t handle, const GEOSGeometry *g, double *y);
+extern int GEOS_DLL GEOSGeomGetZ_r(GEOSContextHandle_t handle, const GEOSGeometry *g, double *z);
  * Return NULL on exception, Geometry must be a Polygon.
@@ -1993,6 +1994,7 @@ extern int GEOS_DLL GEOSGeomGetNumPoints(const GEOSGeometry* g);
 extern int GEOS_DLL GEOSGeomGetX(const GEOSGeometry *g, double *x);
 extern int GEOS_DLL GEOSGeomGetY(const GEOSGeometry *g, double *y);
+extern int GEOS_DLL GEOSGeomGetZ(const GEOSGeometry *g, double *z);
diff --git a/capi/geos_ts_c.cpp b/capi/geos_ts_c.cpp
index 533b097..47cda5a 100644
--- a/capi/geos_ts_c.cpp
+++ b/capi/geos_ts_c.cpp
@@ -3199,6 +3199,49 @@ GEOSGeomGetY_r(GEOSContextHandle_t extHandle, const Geometry *g1, double *y)
+ * For POINT
+int
+GEOSGeomGetZ_r(GEOSContextHandle_t extHandle, const Geometry *g1, double *z)
+    if ( 0 == extHandle )
+        return 0;
+    GEOSContextHandleInternal_t *handle = 0;
+    handle = reinterpret_cast<GEOSContextHandleInternal_t*>(extHandle);
+    if ( 0 == handle->initialized )
+        return 0;
+    try
+        using geos::geom::Point;
+        const Point *po = dynamic_cast<const Point *>(g1);
+        if ( ! po )
+            handle->ERROR_MESSAGE("Argument is not a Point");
+            return 0;
+        *z = po->getZ();
+        return 1;
+    catch (const std::exception &e)
+        handle->ERROR_MESSAGE("%s", e.what());
+    catch (...)
+        handle->ERROR_MESSAGE("Unknown exception thrown");
+    return 0;
diff --git a/include/geos/geom/Point.h b/include/geos/geom/Point.h
index 7360caa..000b348 100644
--- a/include/geos/geom/Point.h
+++ b/include/geos/geom/Point.h
@@ -113,6 +113,7 @@ public:
 	double getX() const;
 	double getY() const;
+  double getZ() const;
 	const Coordinate* getCoordinate() const override;
 	std::string getGeometryType() const override;
 	GeometryTypeId getGeometryTypeId() const override;
diff --git a/src/geom/Point.cpp b/src/geom/Point.cpp
index 0f02d68..a602d05 100644
--- a/src/geom/Point.cpp
+++ b/src/geom/Point.cpp
@@ -126,6 +126,15 @@ Point::getY() const
 	return getCoordinate()->y;
+double
+Point::getZ() const
+	if (isEmpty()) {
+		throw util::UnsupportedOperationException("getZ called on empty Point\n");
+	return getCoordinate()->z;
 const Coordinate *
 Point::getCoordinate() const
diff --git a/tests/unit/capi/GEOSLineString_PointTest.cpp b/tests/unit/capi/GEOSLineString_PointTest.cpp
index 1bc2572..8db60fe 100644
--- a/tests/unit/capi/GEOSLineString_PointTest.cpp
+++ b/tests/unit/capi/GEOSLineString_PointTest.cpp
@@ -7,6 +7,7 @@
 #include <cstdarg>
 #include <cstdio>
 #include <cstdlib>
+#include <cmath>
 namespace tut
@@ -61,7 +62,7 @@ namespace tut
         geom1_ = GEOSGeomFromWKT("LINESTRING(0 0, 5 5, 10 10)");
         GEOSGeometry *geom2;
-        double x, y;
+        double x, y, z;
         ensure( nullptr != geom1_ );
         char const r1 = GEOSisClosed(geom1_);
@@ -71,27 +72,33 @@ namespace tut
         geom2 = GEOSGeomGetPointN(geom1_, 0);
         GEOSGeomGetX(geom2, &x);
         GEOSGeomGetY(geom2, &y);
+        GEOSGeomGetZ(geom2, &z);
         ensure_equals(x, 0);
         ensure_equals(y, 0);
+        ensure(std::isnan(z));
         GEOSGeom_destroy(geom2);
         geom2 = GEOSGeomGetStartPoint(geom1_);
         geom2 = GEOSGeomGetEndPoint(geom1_);
         ensure_equals(x, 10);
         ensure_equals(y, 10);
@@ -119,4 +126,20 @@ namespace tut
         points = GEOSGeomGetNumPoints(geom1_);
         ensure_equals(points, 3);
+    template<>
+    template<>
+    void object::test<4>()
+        geom1_ = GEOSGeomFromWKT("POINT Z(0 10 20)");
+        double x, y, z;
+        GEOSGeomGetX(geom1_, &x);
+        GEOSGeomGetY(geom1_, &y);
+        GEOSGeomGetZ(geom1_, &z);
+        ensure_equals(x, 0);
+        ensure_equals(y, 10);
+        ensure_equals(z, 20);
 } // namespace tut
Summary of changes:
 capi/geos_c.cpp                              | 10 +++++++
 capi/geos_c.h.in                             |  2 ++
 capi/geos_ts_c.cpp                           | 43 ++++++++++++++++++++++++++++
 include/geos/geom/Point.h                    |  1 +
 src/geom/Point.cpp                           |  9 ++++++
 tests/unit/capi/GEOSLineString_PointTest.cpp | 25 +++++++++++++++-
 6 files changed, 89 insertions(+), 1 deletion(-)
hooks/post-receive
More information about the geos-commits mailing list
