[geos-commits] [SCM] GEOS branch master updated. 02d67f53b479a07e8488d9ad8a51012902e5ae66
git at osgeo.org
git at osgeo.org
Tue Jun 26 13:42:47 PDT 2018
the project "GEOS".
via 02d67f53b479a07e8488d9ad8a51012902e5ae66 (commit)
via 375f1f15fe38b8ad14001efbcb0ba89a76937025 (commit)
from 5bf8baeea27e734711ed51215665c26127d7b995 (commit)
revisions in full, below.
commit 02d67f53b479a07e8488d9ad8a51012902e5ae66
Merge: 5bf8bae 375f1f1
Author: Kurt Schwehr <schwehr at google.com>
Date: Tue Jun 26 13:42:47 2018 -0700
Merge branch 'readhex-b4945003-862' of goatbar/geos into master
commit 375f1f15fe38b8ad14001efbcb0ba89a76937025
Date: Mon Jun 11 12:51:17 2018 -0700
WKBReader::readHEX: Fix checking of char_traits<char>::eof of istream
Additional changes:
- Factored out the switch statements into HexToUChar
- Localize vars
- Added const
Fixes https://trac.osgeo.org/geos/ticket/862
diff --git a/src/io/WKBReader.cpp b/src/io/WKBReader.cpp
index 7796c83..615e8df 100644
--- a/src/io/WKBReader.cpp
+++ b/src/io/WKBReader.cpp
@@ -75,143 +75,83 @@ WKBReader::printHEX(istream &is, ostream &os)
+namespace {
+unsigned char ASCIIHexToUChar(char val)
+ switch ( val )
+ case '0' :
+ return 0;
+ case '1' :
+ return 1;
+ case '2' :
+ return 2;
+ case '3' :
+ return 3;
+ case '4' :
+ return 4;
+ case '5' :
+ return 5;
+ case '6' :
+ return 6;
+ case '7' :
+ return 7;
+ case '8' :
+ return 8;
+ case '9' :
+ return 9;
+ case 'A' :
+ case 'a' :
+ return 10;
+ case 'B' :
+ case 'b' :
+ return 11;
+ case 'C' :
+ case 'c' :
+ return 12;
+ case 'D' :
+ case 'd' :
+ return 13;
+ case 'E' :
+ case 'e' :
+ return 14;
+ case 'F' :
+ case 'f' :
+ return 15;
+ default:
+ throw ParseException("Invalid HEX char");
+} // namespace
+// Must be an even number of characters in the istream.
+// Throws a ParseException if there are an odd number of characters.
Geometry *
WKBReader::readHEX(istream &is)
// setup input/output stream
stringstream os(ios_base::binary|ios_base::in|ios_base::out);
- unsigned char result_high, result_low, value;
- char high, low;
- while( (high = static_cast<char>(is.get())) != char_traits<char>::eof() )
+ while( true )
- // geth the low part of the byte
- low = static_cast<char>(is.get());
- if ( low == char_traits<char>::eof() )
- throw ParseException("Premature end of HEX string");
+ const int input_high = is.get();
+ if (input_high == char_traits<char>::eof())
+ break;
- switch (high)
- case '0' :
- result_high = 0;
- break;
- case '1' :
- result_high = 1;
- break;
- case '2' :
- result_high = 2;
- break;
- case '3' :
- result_high = 3;
- break;
- case '4' :
- result_high = 4;
- break;
- case '5' :
- result_high = 5;
- break;
- case '6' :
- result_high = 6;
- break;
- case '7' :
- result_high = 7;
- break;
- case '8' :
- result_high = 8;
- break;
- case '9' :
- result_high = 9;
- break;
- case 'A' :
- case 'a' :
- result_high = 10;
- break;
- case 'B' :
- case 'b' :
- result_high = 11;
- break;
- case 'C' :
- case 'c' :
- result_high = 12;
- break;
- case 'D' :
- case 'd' :
- result_high = 13;
- break;
- case 'E' :
- case 'e' :
- result_high = 14;
- break;
- case 'F' :
- case 'f' :
- result_high = 15;
- break;
- default:
- throw ParseException("Invalid HEX char");
+ const int input_low = is.get();
+ if (input_low == char_traits<char>::eof())
+ throw ParseException("Premature end of HEX string");
- switch (low)
- case '0' :
- result_low = 0;
- break;
- case '1' :
- result_low = 1;
- break;
- case '2' :
- result_low = 2;
- break;
- case '3' :
- result_low = 3;
- break;
- case '4' :
- result_low = 4;
- break;
- case '5' :
- result_low = 5;
- break;
- case '6' :
- result_low = 6;
- break;
- case '7' :
- result_low = 7;
- break;
- case '8' :
- result_low = 8;
- break;
- case '9' :
- result_low = 9;
- break;
- case 'A' :
- case 'a' :
- result_low = 10;
- break;
- case 'B' :
- case 'b' :
- result_low = 11;
- break;
- case 'C' :
- case 'c' :
- result_low = 12;
- break;
- case 'D' :
- case 'd' :
- result_low = 13;
- break;
- case 'E' :
- case 'e' :
- result_low = 14;
- break;
- case 'F' :
- case 'f' :
- result_low = 15;
- break;
- default:
+ const char high = static_cast<char>(input_high);
+ const char low = static_cast<char>(input_low);
+ const unsigned char result_high = ASCIIHexToUChar(high);
+ const unsigned char result_low = ASCIIHexToUChar(low);
- value = static_cast<char>((result_high<<4) + result_low);
+ const unsigned char value =
+ static_cast<char>((result_high<<4) + result_low);
#if DEBUG_HEX_READER
cout<<"HEX "<<high<<low<<" -> DEC "<<(int)value<<endl;
Summary of changes:
src/io/WKBReader.cpp | 194 ++++++++++++++++++---------------------------------
1 file changed, 67 insertions(+), 127 deletions(-)
hooks/post-receive
More information about the geos-commits
