[geos-commits] [SCM] GEOS branch master updated. 5de2cf16e9c461689edf9c65c0f4c572dbbac09b
git at osgeo.org
git at osgeo.org
Fri Nov 9 14:07:39 PST 2018
the project "GEOS".
via 5de2cf16e9c461689edf9c65c0f4c572dbbac09b (commit)
via 5edd79d585b2ee8245aa5f397d58bab712b71044 (commit)
from bfe6b8bb635163a96bfba7a17383eb386486ec60 (commit)
revisions in full, below.
commit 5de2cf16e9c461689edf9c65c0f4c572dbbac09b
Merge: bfe6b8b 5edd79d
Author: pramsey <pramsey at cleverelephant.ca>
Date: Fri Nov 9 14:07:38 2018 -0800
Merge branch 'tinyxml2' of strk/geos into master
I'm going to merge this and then do the minor cosmetic changes.
commit 5edd79d585b2ee8245aa5f397d58bab712b71044
Author: Sandro Santilli <strk at kbt.io>
Date: Fri Sep 21 23:11:06 2018 +0200
Switch from tinyxml to tinyxml2
diff --git a/tests/xmltester/Makefile.am b/tests/xmltester/Makefile.am
index b631260..eef563a 100644
--- a/tests/xmltester/Makefile.am
+++ b/tests/xmltester/Makefile.am
@@ -123,12 +123,8 @@ SimpleWKTTester_LDADD = $(LIBS)
XMLTester_SOURCES = \
XMLTester.cpp \
XMLTester.h \
- tinyxml/tinyxml.h \
- tinyxml/tinyxml.cpp \
- tinyxml/tinystr.h \
- tinyxml/tinystr.cpp \
- tinyxml/tinyxmlerror.cpp \
- tinyxml/tinyxmlparser.cpp \
+ tinyxml2/tinyxml2.h \
+ tinyxml2/tinyxml2.cpp \
BufferResultMatcher.h \
BufferResultMatcher.cpp \
SingleSidedBufferResultMatcher.h \
diff --git a/tests/xmltester/XMLTester.cpp b/tests/xmltester/XMLTester.cpp
index ec31bc1..14cc3a3 100644
--- a/tests/xmltester/XMLTester.cpp
+++ b/tests/xmltester/XMLTester.cpp
@@ -136,38 +136,45 @@ const char * getIndent( unsigned int numIndents )
-void dump_to_stdout( const TiXmlNode * pParent, unsigned int indent = 0 )
+void dump_to_stdout( const tinyxml2::XMLNode * pParent, unsigned int indent = 0 )
if ( !pParent ) return;
- const TiXmlText *pText;
+ const tinyxml2::XMLText *pText;
+#if 0
int t = pParent->Type();
+#endif
printf( "%s", getIndent( indent));
+ tinyxml2::XMLPrinter printer;
+ pParent->Accept(&printer);
+#if 0
switch ( t )
- case TiXmlNode::DOCUMENT:
+ case tinyxml2::XMLNode::DOCUMENT:
printf( "Document" );
break;
- case TiXmlNode::ELEMENT:
+ case tinyxml2::XMLNode::ELEMENT:
printf( "Element \"%s\"", pParent->Value() );
break;
- case TiXmlNode::COMMENT:
+ case tinyxml2::XMLNode::COMMENT:
printf( "Comment: \"%s\"", pParent->Value());
break;
- case TiXmlNode::UNKNOWN:
+ case tinyxml2::XMLNode::UNKNOWN:
printf( "Unknown" );
break;
- case TiXmlNode::TEXT:
+ case tinyxml2::XMLNode::TEXT:
pText = pParent->ToText();
printf( "Text: [%s]", pText->Value() );
break;
- case TiXmlNode::DECLARATION:
+ case tinyxml2::XMLNode::DECLARATION:
printf( "Declaration" );
break;
default:
@@ -175,12 +182,13 @@ void dump_to_stdout( const TiXmlNode * pParent, unsigned int indent = 0 )
printf( "\n" );
- const TiXmlNode * pChild;
+ const tinyxml2::XMLNode * pChild;
for ( pChild = pParent->FirstChild(); pChild != nullptr; pChild = pChild->NextSibling())
dump_to_stdout( pChild, indent+2 );
+#endif
@@ -429,16 +437,17 @@ XMLTester::run(const std::string &source)
caseCount=0;
- if ( ! xml.LoadFile(source.c_str()) )
+ tinyxml2::XMLError e = xml.LoadFile(source.c_str());
+ if ( e )
std::stringstream err;
- err << "Could not load " << source << ": " << xml.ErrorDesc();
+ err << "Could not load " << source << ": " << e << std::endl;
throw runtime_error(err.str());
//dump_to_stdout(&xml);
- const TiXmlNode* node = xml.FirstChild("run");
+ const tinyxml2::XMLNode* node = xml.FirstChildElement("run");
if ( ! node )
throw(runtime_error("Document has no childs"));
@@ -463,7 +472,7 @@ XMLTester::resetCounters()
void
-XMLTester::parseRun(const TiXmlNode* node)
+XMLTester::parseRun(const tinyxml2::XMLNode* node)
using geos::geom::PrecisionModel;
@@ -472,7 +481,7 @@ XMLTester::parseRun(const TiXmlNode* node)
//dump_to_stdout(node);
// Look for precisionModel element
- const TiXmlElement* el = node->FirstChildElement("precisionModel");
+ const tinyxml2::XMLElement* el = node->FirstChildElement("precisionModel");
if ( el ) parsePrecisionModel(el);
else pm.reset(new PrecisionModel());
@@ -480,7 +489,7 @@ XMLTester::parseRun(const TiXmlNode* node)
usePrepared = false;
el = node->FirstChildElement("geometryOperation");
if ( el ) {
- const TiXmlNode* txt = el->FirstChild();
+ const tinyxml2::XMLNode* txt = el->FirstChild();
if ( txt ) {
std::string op = trimBlanks(txt->Value());
if ( op.find("PreparedGeometryOperation") ) {
@@ -507,10 +516,10 @@ XMLTester::parseRun(const TiXmlNode* node)
wkbreader.reset(new io::WKBReader(*factory));
wkbwriter.reset(new io::WKBWriter());
- const TiXmlNode* casenode;
- for ( casenode = node->FirstChild("case");
+ const tinyxml2::XMLNode* casenode;
+ for ( casenode = node->FirstChildElement("case");
casenode;
- casenode = casenode->NextSibling("case") )
+ casenode = casenode->NextSiblingElement("case") )
try {
parseCase(casenode);
@@ -522,7 +531,7 @@ XMLTester::parseRun(const TiXmlNode* node)
void
-XMLTester::parsePrecisionModel(const TiXmlElement* el)
+XMLTester::parsePrecisionModel(const tinyxml2::XMLElement* el)
@@ -643,7 +652,7 @@ XMLTester::trimBlanks(const std::string &in)
void
-XMLTester::parseCase(const TiXmlNode* node)
+XMLTester::parseCase(const tinyxml2::XMLNode* node)
assert(node);
@@ -658,7 +667,7 @@ XMLTester::parseCase(const TiXmlNode* node)
curr_case_desc.clear();
- const TiXmlNode* txt = node->FirstChild("desc");
+ const tinyxml2::XMLNode* txt = node->FirstChildElement("desc");
if ( txt ) {
txt = txt->FirstChild();
if ( txt ) curr_case_desc = trimBlanks(txt->Value());
@@ -668,12 +677,12 @@ XMLTester::parseCase(const TiXmlNode* node)
try {
- const TiXmlNode *el = node->FirstChild("a");
+ const tinyxml2::XMLNode *el = node->FirstChildElement("a");
geomAin = el->FirstChild()->Value();
geomAin = trimBlanks(geomAin);
gA = parseGeometry(geomAin, "Geometry A");
- if ( nullptr != (el = node->FirstChild("b")) )
+ if ( nullptr != (el = node->FirstChildElement("b")) )
geomBin = el->FirstChild()->Value();
geomBin = trimBlanks(geomBin);
@@ -702,10 +711,10 @@ XMLTester::parseCase(const TiXmlNode* node)
++caseCount;
testCount=0;
- const TiXmlNode* testnode;
- for ( testnode = node->FirstChild("test");
+ const tinyxml2::XMLNode* testnode;
+ for ( testnode = node->FirstChildElement("test");
testnode;
- testnode = testnode->NextSibling("test") )
+ testnode = testnode->NextSiblingElement("test") )
parseTest(testnode);
@@ -741,7 +750,7 @@ XMLTester::printGeom(const geom::Geometry *g)
void
-XMLTester::parseTest(const TiXmlNode* node)
+XMLTester::parseTest(const tinyxml2::XMLNode* node)
using namespace operation::overlay;
@@ -757,12 +766,12 @@ XMLTester::parseTest(const TiXmlNode* node)
++testCount;
- const TiXmlNode* opnode = node->FirstChild("op");
+ const tinyxml2::XMLNode* opnode = node->FirstChildElement("op");
if ( ! opnode ) throw(runtime_error("case has no op"));
//dump_to_stdout(opnode);
- const TiXmlElement* opel = opnode->ToElement();
+ const tinyxml2::XMLElement* opel = opnode->ToElement();
const char* tmp = opel->Attribute("name");
if ( tmp ) opName = tmp;
@@ -779,7 +788,7 @@ XMLTester::parseTest(const TiXmlNode* node)
tmp = opel->Attribute("arg4");
if ( tmp ) opArg4 = tmp;
- const TiXmlNode* resnode = opnode->FirstChild();
+ const tinyxml2::XMLNode* resnode = opnode->FirstChild();
if ( ! resnode )
std::stringstream p_tmp;
diff --git a/tests/xmltester/XMLTester.h b/tests/xmltester/XMLTester.h
index 1b0db32..e780721 100644
--- a/tests/xmltester/XMLTester.h
+++ b/tests/xmltester/XMLTester.h
@@ -18,7 +18,7 @@
#include <geos/geom/GeometryFactory.h>
#include <geos/geom/PrecisionModel.h>
#include <geos/profiler.h>
-#include "tinyxml/tinyxml.h"
+#include "tinyxml2/tinyxml2.h"
using namespace geos;
@@ -35,10 +35,10 @@ private:
PRED
- void parsePrecisionModel(const TiXmlElement* el);
- void parseRun(const TiXmlNode* node);
- void parseCase(const TiXmlNode* node);
- void parseTest(const TiXmlNode* node);
+ void parsePrecisionModel(const tinyxml2::XMLElement* el);
+ void parseRun(const tinyxml2::XMLNode* node);
+ void parseCase(const tinyxml2::XMLNode* node);
+ void parseTest(const tinyxml2::XMLNode* node);
void runPredicates(const geom::Geometry *a, const geom::Geometry *b);
geom::Geometry *parseGeometry(const std::string &in, const char* label="parsed");
static std::string trimBlanks(const std::string &in);
@@ -57,7 +57,7 @@ private:
std::unique_ptr<io::WKTWriter> wktwriter;
std::unique_ptr<io::WKBReader> wkbreader;
std::unique_ptr<io::WKBWriter> wkbwriter;
- TiXmlDocument xml;
+ tinyxml2::XMLDocument xml;
int verbose;
int test_predicates;
diff --git a/tests/xmltester/tinyxml2/README b/tests/xmltester/tinyxml2/README
new file mode 100644
index 0000000..7e40f48
--- /dev/null
+++ b/tests/xmltester/tinyxml2/README
@@ -0,0 +1 @@
+Code imported from https://github.com/leethomason/tinyxml2
diff --git a/tests/xmltester/tinyxml2/tinyxml2.cpp b/tests/xmltester/tinyxml2/tinyxml2.cpp
new file mode 100755
index 0000000..8297159
--- /dev/null
+++ b/tests/xmltester/tinyxml2/tinyxml2.cpp
@@ -0,0 +1,2244 @@
+Original code by Lee Thomason (www.grinninglizard.com)
+This software is provided 'as-is', without any express or implied
+warranty. In no event will the authors be held liable for any
+damages arising from the use of this software.
+Permission is granted to anyone to use this software for any
+purpose, including commercial applications, and to alter it and
+redistribute it freely, subject to the following restrictions:
+1. The origin of this software must not be misrepresented; you must
+not claim that you wrote the original software. If you use this
+software in a product, an acknowledgment in the product documentation
+would be appreciated but is not required.
+2. Altered source versions must be plainly marked as such, and
+must not be misrepresented as being the original software.
+3. This notice may not be removed or altered from any source
+distribution.
+#include "tinyxml2.h"
+#include <new> // yes, this one new style header, is in the Android SDK.
+# ifdef ANDROID_NDK
+# include <stddef.h>
+#else
+# include <cstddef>
+#endif
+static const char LINE_FEED = (char)0x0a; // all line endings are normalized to LF
+static const char LF = LINE_FEED;
+static const char CARRIAGE_RETURN = (char)0x0d; // CR gets filtered out
+static const char CR = CARRIAGE_RETURN;
+static const char SINGLE_QUOTE = '\'';
+static const char DOUBLE_QUOTE = '\"';
+// Bunch of unicode info at:
+// http://www.unicode.org/faq/utf_bom.html
+// ef bb bf (Microsoft "lead bytes") - designates UTF-8
+static const unsigned char TIXML_UTF_LEAD_0 = 0xefU;
+static const unsigned char TIXML_UTF_LEAD_1 = 0xbbU;
+static const unsigned char TIXML_UTF_LEAD_2 = 0xbfU;
+namespace tinyxml2
+struct Entity {
+ const char* pattern;
+ int length;
+ char value;
+static const int NUM_ENTITIES = 5;
+static const Entity entities[NUM_ENTITIES] = {
+ { "quot", 4, DOUBLE_QUOTE },
+ { "amp", 3, '&' },
+ { "apos", 4, SINGLE_QUOTE },
+ { "lt", 2, '<' },
+ { "gt", 2, '>' }
+StrPair::~StrPair()
+ Reset();
+void StrPair::Reset()
+ if ( _flags & NEEDS_DELETE ) {
+ delete [] _start;
+ _flags = 0;
+ _start = 0;
+ _end = 0;
+void StrPair::SetStr( const char* str, int flags )
+ Reset();
+ size_t len = strlen( str );
+ _start = new char[ len+1 ];
+ memcpy( _start, str, len+1 );
+ _end = _start + len;
+ _flags = flags | NEEDS_DELETE;
+char* StrPair::ParseText( char* p, const char* endTag, int strFlags )
+ TIXMLASSERT( endTag && *endTag );
+ char* start = p;
+ char endChar = *endTag;
+ size_t length = strlen( endTag );
+ // Inner loop of text parsing.
+ while ( *p ) {
+ if ( *p == endChar && strncmp( p, endTag, length ) == 0 ) {
+ Set( start, p, strFlags );
+ return p + length;
+ ++p;
+ return 0;
+char* StrPair::ParseName( char* p )
+ char* start = p;
+ if ( !start || !(*start) ) {
+ return 0;
+ while( *p && ( p == start ? XMLUtil::IsNameStartChar( *p ) : XMLUtil::IsNameChar( *p ) )) {
+ ++p;
+ if ( p > start ) {
+ Set( start, p, 0 );
+ return p;
+ return 0;
+void StrPair::CollapseWhitespace()
+ // Adjusting _start would cause undefined behavior on delete[]
+ TIXMLASSERT( ( _flags & NEEDS_DELETE ) == 0 );
+ // Trim leading space.
+ _start = XMLUtil::SkipWhiteSpace( _start );
+ if ( _start && *_start ) {
+ char* p = _start; // the read pointer
+ char* q = _start; // the write pointer
+ while( *p ) {
+ if ( XMLUtil::IsWhiteSpace( *p )) {
+ p = XMLUtil::SkipWhiteSpace( p );
+ if ( *p == 0 ) {
+ break; // don't write to q; this trims the trailing space.
+ *q = ' ';
+ ++q;
+ *q = *p;
+ ++q;
+ ++p;
+ *q = 0;
+const char* StrPair::GetStr()
+ if ( _flags & NEEDS_FLUSH ) {
+ *_end = 0;
+ _flags ^= NEEDS_FLUSH;
+ if ( _flags ) {
+ while( p < _end ) {
+ if ( (_flags & NEEDS_NEWLINE_NORMALIZATION) && *p == CR ) {
+ // CR-LF pair becomes LF
+ // CR alone becomes LF
+ // LF-CR becomes LF
+ if ( *(p+1) == LF ) {
+ p += 2;
+ else {
+ ++p;
+ *q++ = LF;
+ else if ( (_flags & NEEDS_NEWLINE_NORMALIZATION) && *p == LF ) {
+ if ( *(p+1) == CR ) {
+ p += 2;
+ else {
+ ++p;
+ *q++ = LF;
+ else if ( (_flags & NEEDS_ENTITY_PROCESSING) && *p == '&' ) {
+ // Entities handled by tinyXML2:
+ // - special entities in the entity table [in/out]
+ // - numeric character reference [in]
+ // 中 or 中
+ if ( *(p+1) == '#' ) {
+ const int buflen = 10;
+ char buf[buflen] = { 0 };
+ int len = 0;
+ p = const_cast<char*>( XMLUtil::GetCharacterRef( p, buf, &len ) );
+ TIXMLASSERT( 0 <= len && len <= buflen );
+ TIXMLASSERT( q + len <= p );
+ memcpy( q, buf, len );
+ q += len;
+ else {
+ int i=0;
+ for(; i<NUM_ENTITIES; ++i ) {
+ if ( strncmp( p+1, entities[i].pattern, entities[i].length ) == 0
+ && *(p+entities[i].length+1) == ';' ) {
+ // Found an entity convert;
+ *q = entities[i].value;
+ ++q;
+ p += entities[i].length + 2;
+ break;
+ if ( i == NUM_ENTITIES ) {
+ // fixme: treat as error?
+ ++p;
+ ++q;
+ else {
+ *q = *p;
+ ++p;
+ ++q;
+ *q = 0;
+ // The loop below has plenty going on, and this
+ // is a less useful mode. Break it out.
+ if ( _flags & COLLAPSE_WHITESPACE ) {
+ CollapseWhitespace();
+ _flags = (_flags & NEEDS_DELETE);
+ return _start;
+// --------- XMLUtil ----------- //
+const char* XMLUtil::ReadBOM( const char* p, bool* bom )
+ *bom = false;
+ const unsigned char* pu = reinterpret_cast<const unsigned char*>(p);
+ // Check for BOM:
+ if ( *(pu+0) == TIXML_UTF_LEAD_0
+ && *(pu+1) == TIXML_UTF_LEAD_1
+ && *(pu+2) == TIXML_UTF_LEAD_2 ) {
+ *bom = true;
+ p += 3;
+ return p;
+void XMLUtil::ConvertUTF32ToUTF8( unsigned long input, char* output, int* length )
+ const unsigned long BYTE_MASK = 0xBF;
+ const unsigned long BYTE_MARK = 0x80;
+ const unsigned long FIRST_BYTE_MARK[7] = { 0x00, 0x00, 0xC0, 0xE0, 0xF0, 0xF8, 0xFC };
+ if (input < 0x80) {
+ *length = 1;
+ else if ( input < 0x800 ) {
+ *length = 2;
+ else if ( input < 0x10000 ) {
+ *length = 3;
+ else if ( input < 0x200000 ) {
+ *length = 4;
+ else {
+ *length = 0; // This code won't covert this correctly anyway.
+ return;
+ output += *length;
+ // Scary scary fall throughs.
+ switch (*length) {
+ case 4:
+ --output;
+ *output = (char)((input | BYTE_MARK) & BYTE_MASK);
+ input >>= 6;
+ case 3:
+ --output;
+ input >>= 6;
+ case 2:
+ --output;
+ input >>= 6;
+ case 1:
+ --output;
+ *output = (char)(input | FIRST_BYTE_MARK[*length]);
+ default:
+ break;
+const char* XMLUtil::GetCharacterRef( const char* p, char* value, int* length )
+ // Presume an entity, and pull it out.
+ *length = 0;
+ if ( *(p+1) == '#' && *(p+2) ) {
+ unsigned long ucs = 0;
+ ptrdiff_t delta = 0;
+ unsigned mult = 1;
+ if ( *(p+2) == 'x' ) {
+ // Hexadecimal.
+ if ( !*(p+3) ) {
+ return 0;
+ const char* q = p+3;
+ q = strchr( q, ';' );
+ if ( !q || !*q ) {
+ return 0;
+ delta = q-p;
+ --q;
+ while ( *q != 'x' ) {
+ if ( *q >= '0' && *q <= '9' ) {
+ ucs += mult * (*q - '0');
+ else if ( *q >= 'a' && *q <= 'f' ) {
+ ucs += mult * (*q - 'a' + 10);
+ else if ( *q >= 'A' && *q <= 'F' ) {
+ ucs += mult * (*q - 'A' + 10 );
+ else {
+ return 0;
+ mult *= 16;
+ --q;
+ else {
+ // Decimal.
+ if ( !*(p+2) ) {
+ return 0;
+ const char* q = p+2;
+ return 0;
+ delta = q-p;
+ --q;
+ while ( *q != '#' ) {
+ else {
+ return 0;
+ mult *= 10;
+ --q;
+ // convert the UCS to UTF-8
+ ConvertUTF32ToUTF8( ucs, value, length );
+ return p + delta + 1;
+ return p+1;
+void XMLUtil::ToStr( int v, char* buffer, int bufferSize )
+ TIXML_SNPRINTF( buffer, bufferSize, "%d", v );
+void XMLUtil::ToStr( unsigned v, char* buffer, int bufferSize )
+ TIXML_SNPRINTF( buffer, bufferSize, "%u", v );
+void XMLUtil::ToStr( bool v, char* buffer, int bufferSize )
+ TIXML_SNPRINTF( buffer, bufferSize, "%d", v ? 1 : 0 );
+ ToStr() of a number is a very tricky topic.
+ https://github.com/leethomason/tinyxml2/issues/106
+void XMLUtil::ToStr( float v, char* buffer, int bufferSize )
+ TIXML_SNPRINTF( buffer, bufferSize, "%.8g", v );
+void XMLUtil::ToStr( double v, char* buffer, int bufferSize )
+ TIXML_SNPRINTF( buffer, bufferSize, "%.17g", v );
+bool XMLUtil::ToInt( const char* str, int* value )
+ if ( TIXML_SSCANF( str, "%d", value ) == 1 ) {
+ return true;
+ return false;
+bool XMLUtil::ToUnsigned( const char* str, unsigned *value )
+ if ( TIXML_SSCANF( str, "%u", value ) == 1 ) {
+ return true;
+ return false;
+bool XMLUtil::ToBool( const char* str, bool* value )
+ int ival = 0;
+ if ( ToInt( str, &ival )) {
+ *value = (ival==0) ? false : true;
+ return true;
+ if ( StringEqual( str, "true" ) ) {
+ *value = true;
+ return true;
+ else if ( StringEqual( str, "false" ) ) {
+ *value = false;
+ return true;
+ return false;
+bool XMLUtil::ToFloat( const char* str, float* value )
+ if ( TIXML_SSCANF( str, "%f", value ) == 1 ) {
+ return true;
+ return false;
+bool XMLUtil::ToDouble( const char* str, double* value )
+ if ( TIXML_SSCANF( str, "%lf", value ) == 1 ) {
+ return true;
+ return false;
+char* XMLDocument::Identify( char* p, XMLNode** node )
+ XMLNode* returnNode = 0;
+ char* start = p;
+ if( !p || !*p ) {
+ return p;
+ // What is this thing?
+ // These strings define the matching patters:
+ static const char* xmlHeader = { "<?" };
+ static const char* commentHeader = { "<!--" };
+ static const char* dtdHeader = { "<!" };
+ static const char* cdataHeader = { "<![CDATA[" };
+ static const char* elementHeader = { "<" }; // and a header for everything else; check last.
+ static const int xmlHeaderLen = 2;
+ static const int commentHeaderLen = 4;
+ static const int dtdHeaderLen = 2;
+ static const int cdataHeaderLen = 9;
+ static const int elementHeaderLen = 1;
+#if defined(_MSC_VER)
+#pragma warning ( push )
+#pragma warning ( disable : 4127 )
+#endif
+ TIXMLASSERT( sizeof( XMLComment ) == sizeof( XMLUnknown ) ); // use same memory pool
+ TIXMLASSERT( sizeof( XMLComment ) == sizeof( XMLDeclaration ) ); // use same memory pool
+#pragma warning (pop)
+#endif
+ if ( XMLUtil::StringEqual( p, xmlHeader, xmlHeaderLen ) ) {
+ returnNode = new (_commentPool.Alloc()) XMLDeclaration( this );
+ returnNode->_memPool = &_commentPool;
+ p += xmlHeaderLen;
+ else if ( XMLUtil::StringEqual( p, commentHeader, commentHeaderLen ) ) {
+ returnNode = new (_commentPool.Alloc()) XMLComment( this );
+ p += commentHeaderLen;
+ else if ( XMLUtil::StringEqual( p, cdataHeader, cdataHeaderLen ) ) {
+ XMLText* text = new (_textPool.Alloc()) XMLText( this );
+ returnNode = text;
+ returnNode->_memPool = &_textPool;
+ p += cdataHeaderLen;
+ text->SetCData( true );
+ else if ( XMLUtil::StringEqual( p, dtdHeader, dtdHeaderLen ) ) {
+ returnNode = new (_commentPool.Alloc()) XMLUnknown( this );
+ p += dtdHeaderLen;
+ else if ( XMLUtil::StringEqual( p, elementHeader, elementHeaderLen ) ) {
+ returnNode = new (_elementPool.Alloc()) XMLElement( this );
+ returnNode->_memPool = &_elementPool;
+ p += elementHeaderLen;
+ else {
+ returnNode = new (_textPool.Alloc()) XMLText( this );
+ p = start; // Back it up, all the text counts.
+ *node = returnNode;
+ return p;
+bool XMLDocument::Accept( XMLVisitor* visitor ) const
+ if ( visitor->VisitEnter( *this ) ) {
+ for ( const XMLNode* node=FirstChild(); node; node=node->NextSibling() ) {
+ if ( !node->Accept( visitor ) ) {
+ break;
+ return visitor->VisitExit( *this );
+// --------- XMLNode ----------- //
+XMLNode::XMLNode( XMLDocument* doc ) :
+ _document( doc ),
+ _parent( 0 ),
+ _firstChild( 0 ), _lastChild( 0 ),
+ _prev( 0 ), _next( 0 ),
+ _memPool( 0 )
+XMLNode::~XMLNode()
+ DeleteChildren();
+ if ( _parent ) {
+ _parent->Unlink( this );
+const char* XMLNode::Value() const
+ return _value.GetStr();
+void XMLNode::SetValue( const char* str, bool staticMem )
+ if ( staticMem ) {
+ _value.SetInternedStr( str );
+ else {
+ _value.SetStr( str );
+void XMLNode::DeleteChildren()
+ while( _firstChild ) {
+ XMLNode* node = _firstChild;
+ Unlink( node );
+ DeleteNode( node );
+ _firstChild = _lastChild = 0;
+void XMLNode::Unlink( XMLNode* child )
+ if ( child == _firstChild ) {
+ _firstChild = _firstChild->_next;
+ if ( child == _lastChild ) {
+ _lastChild = _lastChild->_prev;
+ if ( child->_prev ) {
+ child->_prev->_next = child->_next;
+ if ( child->_next ) {
+ child->_next->_prev = child->_prev;
+ child->_parent = 0;
+void XMLNode::DeleteChild( XMLNode* node )
+ TIXMLASSERT( node->_parent == this );
+XMLNode* XMLNode::InsertEndChild( XMLNode* addThis )
+ if (addThis->_document != _document)
+ return 0;
+ if (addThis->_parent)
+ addThis->_parent->Unlink( addThis );
+ else
+ addThis->_memPool->SetTracked();
+ if ( _lastChild ) {
+ TIXMLASSERT( _firstChild );
+ TIXMLASSERT( _lastChild->_next == 0 );
+ _lastChild->_next = addThis;
+ addThis->_prev = _lastChild;
+ _lastChild = addThis;
+ addThis->_next = 0;
+ else {
+ TIXMLASSERT( _firstChild == 0 );
+ _firstChild = _lastChild = addThis;
+ addThis->_prev = 0;
+ addThis->_parent = this;
+ return addThis;
+XMLNode* XMLNode::InsertFirstChild( XMLNode* addThis )
+ return 0;
+ else
+ if ( _firstChild ) {
+ TIXMLASSERT( _lastChild );
+ TIXMLASSERT( _firstChild->_prev == 0 );
+ _firstChild->_prev = addThis;
+ addThis->_next = _firstChild;
+ _firstChild = addThis;
+ else {
+ TIXMLASSERT( _lastChild == 0 );
+ return addThis;
+XMLNode* XMLNode::InsertAfterChild( XMLNode* afterThis, XMLNode* addThis )
+ return 0;
+ TIXMLASSERT( afterThis->_parent == this );
+ if ( afterThis->_parent != this ) {
+ return 0;
+ if ( afterThis->_next == 0 ) {
+ // The last node or the only node.
+ return InsertEndChild( addThis );
+ else
+ addThis->_prev = afterThis;
+ addThis->_next = afterThis->_next;
+ afterThis->_next->_prev = addThis;
+ afterThis->_next = addThis;
+ return addThis;
+const XMLElement* XMLNode::FirstChildElement( const char* value ) const
+ for( XMLNode* node=_firstChild; node; node=node->_next ) {
+ XMLElement* element = node->ToElement();
+ if ( element ) {
+ if ( !value || XMLUtil::StringEqual( element->Name(), value ) ) {
+ return element;
+ return 0;
+const XMLElement* XMLNode::LastChildElement( const char* value ) const
+ for( XMLNode* node=_lastChild; node; node=node->_prev ) {
+ if ( element ) {
+ return element;
+ return 0;
+const XMLElement* XMLNode::NextSiblingElement( const char* value ) const
+ for( XMLNode* node=this->_next; node; node = node->_next ) {
+ const XMLElement* element = node->ToElement();
+ if ( element
+ && (!value || XMLUtil::StringEqual( value, node->Value() ))) {
+ return element;
+ return 0;
+const XMLElement* XMLNode::PreviousSiblingElement( const char* value ) const
+ for( XMLNode* node=_prev; node; node = node->_prev ) {
+ if ( element
+ return element;
+ return 0;
+char* XMLNode::ParseDeep( char* p, StrPair* parentEnd )
+ // This is a recursive method, but thinking about it "at the current level"
+ // it is a pretty simple flat list:
+ // <foo/>
+ // <!-- comment -->
+ // With a special case:
+ // <foo>
+ // </foo>
+ // Where the closing element (/foo) *must* be the next thing after the opening
+ // element, and the names must match. BUT the tricky bit is that the closing
+ // element will be read by the child.
+ // 'endTag' is the end tag for this node, it is returned by a call to a child.
+ // 'parentEnd' is the end tag for the parent, which is filled in and returned.
+ while( p && *p ) {
+ XMLNode* node = 0;
+ p = _document->Identify( p, &node );
+ if ( p == 0 || node == 0 ) {
+ break;
+ StrPair endTag;
+ p = node->ParseDeep( p, &endTag );
+ if ( !p ) {
+ node = 0;
+ if ( !_document->Error() ) {
+ _document->SetError( XML_ERROR_PARSING, 0, 0 );
+ break;
+ XMLElement* ele = node->ToElement();
+ // We read the end tag. Return it to the parent.
+ if ( ele && ele->ClosingType() == XMLElement::CLOSING ) {
+ if ( parentEnd ) {
+ *parentEnd = static_cast<XMLElement*>(node)->_value;
+ node->_memPool->SetTracked(); // created and then immediately deleted.
+ return p;
+ // Handle an end tag returned to this level.
+ // And handle a bunch of annoying errors.
+ if ( ele ) {
+ if ( endTag.Empty() && ele->ClosingType() == XMLElement::OPEN ) {
+ _document->SetError( XML_ERROR_MISMATCHED_ELEMENT, node->Value(), 0 );
+ p = 0;
+ else if ( !endTag.Empty() && ele->ClosingType() != XMLElement::OPEN ) {
+ p = 0;
+ else if ( !endTag.Empty() ) {
+ if ( !XMLUtil::StringEqual( endTag.GetStr(), node->Value() )) {
+ p = 0;
+ if ( p == 0 ) {
+ node = 0;
+ if ( node ) {
+ this->InsertEndChild( node );
+ return 0;
+void XMLNode::DeleteNode( XMLNode* node )
+ if ( node == 0 ) {
+ return;
+ MemPool* pool = node->_memPool;
+ node->~XMLNode();
+ pool->Free( node );
+// --------- XMLText ---------- //
+char* XMLText::ParseDeep( char* p, StrPair* )
+ const char* start = p;
+ if ( this->CData() ) {
+ p = _value.ParseText( p, "]]>", StrPair::NEEDS_NEWLINE_NORMALIZATION );
+ if ( !p ) {
+ _document->SetError( XML_ERROR_PARSING_CDATA, start, 0 );
+ return p;
+ else {
+ int flags = _document->ProcessEntities() ? StrPair::TEXT_ELEMENT : StrPair::TEXT_ELEMENT_LEAVE_ENTITIES;
+ if ( _document->WhitespaceMode() == COLLAPSE_WHITESPACE ) {
+ flags |= StrPair::COLLAPSE_WHITESPACE;
+ p = _value.ParseText( p, "<", flags );
+ if ( !p ) {
+ _document->SetError( XML_ERROR_PARSING_TEXT, start, 0 );
+ if ( p && *p ) {
+ return p-1;
+ return 0;
+XMLNode* XMLText::ShallowClone( XMLDocument* doc ) const
+ if ( !doc ) {
+ doc = _document;
+ XMLText* text = doc->NewText( Value() ); // fixme: this will always allocate memory. Intern?
+ text->SetCData( this->CData() );
+ return text;
+bool XMLText::ShallowEqual( const XMLNode* compare ) const
+ return ( compare->ToText() && XMLUtil::StringEqual( compare->ToText()->Value(), Value() ));
+bool XMLText::Accept( XMLVisitor* visitor ) const
+ return visitor->Visit( *this );
+// --------- XMLComment ---------- //
+XMLComment::XMLComment( XMLDocument* doc ) : XMLNode( doc )
+XMLComment::~XMLComment()
+char* XMLComment::ParseDeep( char* p, StrPair* )
+ // Comment parses as text.
+ p = _value.ParseText( p, "-->", StrPair::COMMENT );
+ if ( p == 0 ) {
+ _document->SetError( XML_ERROR_PARSING_COMMENT, start, 0 );
+ return p;
+XMLNode* XMLComment::ShallowClone( XMLDocument* doc ) const
+ if ( !doc ) {
+ doc = _document;
+ XMLComment* comment = doc->NewComment( Value() ); // fixme: this will always allocate memory. Intern?
+ return comment;
+bool XMLComment::ShallowEqual( const XMLNode* compare ) const
+ const XMLComment* comment = compare->ToComment();
+ return ( comment && XMLUtil::StringEqual( comment->Value(), Value() ));
+bool XMLComment::Accept( XMLVisitor* visitor ) const
+// --------- XMLDeclaration ---------- //
+XMLDeclaration::XMLDeclaration( XMLDocument* doc ) : XMLNode( doc )
+XMLDeclaration::~XMLDeclaration()
+ //printf( "~XMLDeclaration\n" );
+char* XMLDeclaration::ParseDeep( char* p, StrPair* )
+ // Declaration parses as text.
+ p = _value.ParseText( p, "?>", StrPair::NEEDS_NEWLINE_NORMALIZATION );
+ if ( p == 0 ) {
+ _document->SetError( XML_ERROR_PARSING_DECLARATION, start, 0 );
+ return p;
+XMLNode* XMLDeclaration::ShallowClone( XMLDocument* doc ) const
+ if ( !doc ) {
+ doc = _document;
+ XMLDeclaration* dec = doc->NewDeclaration( Value() ); // fixme: this will always allocate memory. Intern?
+ return dec;
+bool XMLDeclaration::ShallowEqual( const XMLNode* compare ) const
+ const XMLDeclaration* declaration = compare->ToDeclaration();
+ return ( declaration && XMLUtil::StringEqual( declaration->Value(), Value() ));
+bool XMLDeclaration::Accept( XMLVisitor* visitor ) const
+// --------- XMLUnknown ---------- //
+XMLUnknown::XMLUnknown( XMLDocument* doc ) : XMLNode( doc )
+XMLUnknown::~XMLUnknown()
+char* XMLUnknown::ParseDeep( char* p, StrPair* )
+ // Unknown parses as text.
+ p = _value.ParseText( p, ">", StrPair::NEEDS_NEWLINE_NORMALIZATION );
+ if ( !p ) {
+ _document->SetError( XML_ERROR_PARSING_UNKNOWN, start, 0 );
+ return p;
+XMLNode* XMLUnknown::ShallowClone( XMLDocument* doc ) const
+ if ( !doc ) {
+ doc = _document;
+ XMLUnknown* text = doc->NewUnknown( Value() ); // fixme: this will always allocate memory. Intern?
+ return text;
+bool XMLUnknown::ShallowEqual( const XMLNode* compare ) const
+ const XMLUnknown* unknown = compare->ToUnknown();
+ return ( unknown && XMLUtil::StringEqual( unknown->Value(), Value() ));
+bool XMLUnknown::Accept( XMLVisitor* visitor ) const
+// --------- XMLAttribute ---------- //
+const char* XMLAttribute::Name() const
+ return _name.GetStr();
+const char* XMLAttribute::Value() const
+char* XMLAttribute::ParseDeep( char* p, bool processEntities )
+ // Parse using the name rules: bug fix, was using ParseText before
+ p = _name.ParseName( p );
+ if ( !p || !*p ) {
+ return 0;
+ // Skip white space before =
+ if ( !p || *p != '=' ) {
+ return 0;
+ ++p; // move up to opening quote
+ if ( *p != '\"' && *p != '\'' ) {
+ return 0;
+ char endTag[2] = { *p, 0 };
+ ++p; // move past opening quote
+ p = _value.ParseText( p, endTag, processEntities ? StrPair::ATTRIBUTE_VALUE : StrPair::ATTRIBUTE_VALUE_LEAVE_ENTITIES );
+ return p;
+void XMLAttribute::SetName( const char* n )
+ _name.SetStr( n );
+XMLError XMLAttribute::QueryIntValue( int* value ) const
+ if ( XMLUtil::ToInt( Value(), value )) {
+ return XML_NO_ERROR;
+ return XML_WRONG_ATTRIBUTE_TYPE;
+XMLError XMLAttribute::QueryUnsignedValue( unsigned int* value ) const
+ if ( XMLUtil::ToUnsigned( Value(), value )) {
+XMLError XMLAttribute::QueryBoolValue( bool* value ) const
+ if ( XMLUtil::ToBool( Value(), value )) {
+XMLError XMLAttribute::QueryFloatValue( float* value ) const
+ if ( XMLUtil::ToFloat( Value(), value )) {
+XMLError XMLAttribute::QueryDoubleValue( double* value ) const
+ if ( XMLUtil::ToDouble( Value(), value )) {
+void XMLAttribute::SetAttribute( const char* v )
+ _value.SetStr( v );
+void XMLAttribute::SetAttribute( int v )
+ char buf[BUF_SIZE];
+ XMLUtil::ToStr( v, buf, BUF_SIZE );
+ _value.SetStr( buf );
+void XMLAttribute::SetAttribute( unsigned v )
+void XMLAttribute::SetAttribute( bool v )
+void XMLAttribute::SetAttribute( double v )
+void XMLAttribute::SetAttribute( float v )
+// --------- XMLElement ---------- //
+XMLElement::XMLElement( XMLDocument* doc ) : XMLNode( doc ),
+ _closingType( 0 ),
+ _rootAttribute( 0 )
+XMLElement::~XMLElement()
+ while( _rootAttribute ) {
+ XMLAttribute* next = _rootAttribute->_next;
+ DeleteAttribute( _rootAttribute );
+ _rootAttribute = next;
+XMLAttribute* XMLElement::FindAttribute( const char* name )
+ for( XMLAttribute* a = _rootAttribute; a; a = a->_next ) {
+ if ( XMLUtil::StringEqual( a->Name(), name ) ) {
+ return a;
+ return 0;
+const XMLAttribute* XMLElement::FindAttribute( const char* name ) const
+ return a;
+ return 0;
+const char* XMLElement::Attribute( const char* name, const char* value ) const
+ const XMLAttribute* a = FindAttribute( name );
+ if ( !a ) {
+ return 0;
+ if ( !value || XMLUtil::StringEqual( a->Value(), value )) {
+ return a->Value();
+ return 0;
+const char* XMLElement::GetText() const
+ if ( FirstChild() && FirstChild()->ToText() ) {
+ return FirstChild()->ToText()->Value();
+ return 0;
+void XMLElement::SetText( const char* inText )
+ FirstChild()->SetValue( inText );
+ else {
+ XMLText* theText = GetDocument()->NewText( inText );
+ InsertFirstChild( theText );
+void XMLElement::SetText( int v )
+ SetText( buf );
+void XMLElement::SetText( unsigned v )
+ SetText( buf );
+void XMLElement::SetText( bool v )
+ SetText( buf );
+void XMLElement::SetText( float v )
+ SetText( buf );
+void XMLElement::SetText( double v )
+ SetText( buf );
+XMLError XMLElement::QueryIntText( int* ival ) const
+ const char* t = FirstChild()->ToText()->Value();
+ if ( XMLUtil::ToInt( t, ival ) ) {
+ return XML_SUCCESS;
+ return XML_CAN_NOT_CONVERT_TEXT;
+ return XML_NO_TEXT_NODE;
+XMLError XMLElement::QueryUnsignedText( unsigned* uval ) const
+ if ( XMLUtil::ToUnsigned( t, uval ) ) {
+XMLError XMLElement::QueryBoolText( bool* bval ) const
+ if ( XMLUtil::ToBool( t, bval ) ) {
+XMLError XMLElement::QueryDoubleText( double* dval ) const
+ if ( XMLUtil::ToDouble( t, dval ) ) {
+XMLError XMLElement::QueryFloatText( float* fval ) const
+ if ( XMLUtil::ToFloat( t, fval ) ) {
+XMLAttribute* XMLElement::FindOrCreateAttribute( const char* name )
+ XMLAttribute* last = 0;
+ XMLAttribute* attrib = 0;
+ for( attrib = _rootAttribute;
+ attrib;
+ last = attrib, attrib = attrib->_next ) {
+ if ( XMLUtil::StringEqual( attrib->Name(), name ) ) {
+ break;
+ if ( !attrib ) {
+ attrib = new (_document->_attributePool.Alloc() ) XMLAttribute();
+ attrib->_memPool = &_document->_attributePool;
+ if ( last ) {
+ last->_next = attrib;
+ else {
+ _rootAttribute = attrib;
+ attrib->SetName( name );
+ attrib->_memPool->SetTracked(); // always created and linked.
+ return attrib;
+void XMLElement::DeleteAttribute( const char* name )
+ XMLAttribute* prev = 0;
+ for( XMLAttribute* a=_rootAttribute; a; a=a->_next ) {
+ if ( XMLUtil::StringEqual( name, a->Name() ) ) {
+ if ( prev ) {
+ prev->_next = a->_next;
+ else {
+ _rootAttribute = a->_next;
+ DeleteAttribute( a );
+ break;
+ prev = a;
+char* XMLElement::ParseAttributes( char* p )
+ XMLAttribute* prevAttribute = 0;
+ // Read the attributes.
+ while( p ) {
+ if ( !p || !(*p) ) {
+ _document->SetError( XML_ERROR_PARSING_ELEMENT, start, Name() );
+ return 0;
+ // attribute.
+ if (XMLUtil::IsNameStartChar( *p ) ) {
+ XMLAttribute* attrib = new (_document->_attributePool.Alloc() ) XMLAttribute();
+ p = attrib->ParseDeep( p, _document->ProcessEntities() );
+ if ( !p || Attribute( attrib->Name() ) ) {
+ DeleteAttribute( attrib );
+ _document->SetError( XML_ERROR_PARSING_ATTRIBUTE, start, p );
+ return 0;
+ // There is a minor bug here: if the attribute in the source xml
+ // document is duplicated, it will not be detected and the
+ // attribute will be doubly added. However, tracking the 'prevAttribute'
+ // avoids re-scanning the attribute list. Preferring performance for
+ // now, may reconsider in the future.
+ if ( prevAttribute ) {
+ prevAttribute->_next = attrib;
+ else {
+ prevAttribute = attrib;
+ // end of the tag
+ else if ( *p == '/' && *(p+1) == '>' ) {
+ _closingType = CLOSED;
+ return p+2; // done; sealed element.
+ // end of the tag
+ else if ( *p == '>' ) {
+ ++p;
+ break;
+ else {
+ _document->SetError( XML_ERROR_PARSING_ELEMENT, start, p );
+ return 0;
+ return p;
+void XMLElement::DeleteAttribute( XMLAttribute* attribute )
+ if ( attribute == 0 ) {
+ return;
+ MemPool* pool = attribute->_memPool;
+ attribute->~XMLAttribute();
+ pool->Free( attribute );
+// <ele></ele>
+// <ele>foo<b>bar</b></ele>
+char* XMLElement::ParseDeep( char* p, StrPair* strPair )
+ // Read the element name.
+ if ( !p ) {
+ return 0;
+ // The closing element is the </element> form. It is
+ // parsed just like a regular element then deleted from
+ // the DOM.
+ if ( *p == '/' ) {
+ _closingType = CLOSING;
+ ++p;
+ p = _value.ParseName( p );
+ if ( _value.Empty() ) {
+ return 0;
+ p = ParseAttributes( p );
+ if ( !p || !*p || _closingType ) {
+ return p;
+ p = XMLNode::ParseDeep( p, strPair );
+ return p;
+XMLNode* XMLElement::ShallowClone( XMLDocument* doc ) const
+ if ( !doc ) {
+ doc = _document;
+ XMLElement* element = doc->NewElement( Value() ); // fixme: this will always allocate memory. Intern?
+ for( const XMLAttribute* a=FirstAttribute(); a; a=a->Next() ) {
+ element->SetAttribute( a->Name(), a->Value() ); // fixme: this will always allocate memory. Intern?
+ return element;
+bool XMLElement::ShallowEqual( const XMLNode* compare ) const
+ const XMLElement* other = compare->ToElement();
+ if ( other && XMLUtil::StringEqual( other->Value(), Value() )) {
+ const XMLAttribute* a=FirstAttribute();
+ const XMLAttribute* b=other->FirstAttribute();
+ while ( a && b ) {
+ if ( !XMLUtil::StringEqual( a->Value(), b->Value() ) ) {
+ return false;
+ a = a->Next();
+ b = b->Next();
+ if ( a || b ) {
+ // different count
+ return false;
+ return true;
+ return false;
+bool XMLElement::Accept( XMLVisitor* visitor ) const
+ if ( visitor->VisitEnter( *this, _rootAttribute ) ) {
+ break;
+// --------- XMLDocument ----------- //
+// Warning: List must match 'enum XMLError'
+const char* XMLDocument::_errorNames[XML_ERROR_COUNT] = {
+ "XML_SUCCESS",
+ "XML_NO_ATTRIBUTE",
+ "XML_WRONG_ATTRIBUTE_TYPE",
+ "XML_ERROR_FILE_NOT_FOUND",
+ "XML_ERROR_FILE_COULD_NOT_BE_OPENED",
+ "XML_ERROR_FILE_READ_ERROR",
+ "XML_ERROR_ELEMENT_MISMATCH",
+ "XML_ERROR_PARSING_ELEMENT",
+ "XML_ERROR_PARSING_ATTRIBUTE",
+ "XML_ERROR_IDENTIFYING_TAG",
+ "XML_ERROR_PARSING_TEXT",
+ "XML_ERROR_PARSING_CDATA",
+ "XML_ERROR_PARSING_COMMENT",
+ "XML_ERROR_PARSING_DECLARATION",
+ "XML_ERROR_PARSING_UNKNOWN",
+ "XML_ERROR_EMPTY_DOCUMENT",
+ "XML_ERROR_MISMATCHED_ELEMENT",
+ "XML_ERROR_PARSING",
+ "XML_CAN_NOT_CONVERT_TEXT",
+ "XML_NO_TEXT_NODE"
+XMLDocument::XMLDocument( bool processEntities, Whitespace whitespace ) :
+ XMLNode( 0 ),
+ _writeBOM( false ),
+ _processEntities( processEntities ),
+ _errorID( XML_NO_ERROR ),
+ _whitespace( whitespace ),
+ _errorStr1( 0 ),
+ _errorStr2( 0 ),
+ _charBuffer( 0 )
+ _document = this; // avoid warning about 'this' in initializer list
+XMLDocument::~XMLDocument()
+ DeleteChildren();
+ delete [] _charBuffer;
+#if 0
+ _textPool.Trace( "text" );
+ _elementPool.Trace( "element" );
+ _commentPool.Trace( "comment" );
+ _attributePool.Trace( "attribute" );
+#endif
+#ifdef DEBUG
+ if ( Error() == false ) {
+ TIXMLASSERT( _elementPool.CurrentAllocs() == _elementPool.Untracked() );
+ TIXMLASSERT( _attributePool.CurrentAllocs() == _attributePool.Untracked() );
+ TIXMLASSERT( _textPool.CurrentAllocs() == _textPool.Untracked() );
+ TIXMLASSERT( _commentPool.CurrentAllocs() == _commentPool.Untracked() );
+#endif
+void XMLDocument::Clear()
+ DeleteChildren();
+ _errorID = XML_NO_ERROR;
+ _errorStr1 = 0;
+ _errorStr2 = 0;
+ _charBuffer = 0;
+XMLElement* XMLDocument::NewElement( const char* name )
+ XMLElement* ele = new (_elementPool.Alloc()) XMLElement( this );
+ ele->_memPool = &_elementPool;
+ ele->SetName( name );
+ return ele;
+XMLComment* XMLDocument::NewComment( const char* str )
+ XMLComment* comment = new (_commentPool.Alloc()) XMLComment( this );
+ comment->_memPool = &_commentPool;
+ comment->SetValue( str );
+ return comment;
+XMLText* XMLDocument::NewText( const char* str )
+ text->_memPool = &_textPool;
+ text->SetValue( str );
+ return text;
+XMLDeclaration* XMLDocument::NewDeclaration( const char* str )
+ XMLDeclaration* dec = new (_commentPool.Alloc()) XMLDeclaration( this );
+ dec->_memPool = &_commentPool;
+ dec->SetValue( str ? str : "xml version=\"1.0\" encoding=\"UTF-8\"" );
+ return dec;
+XMLUnknown* XMLDocument::NewUnknown( const char* str )
+ XMLUnknown* unk = new (_commentPool.Alloc()) XMLUnknown( this );
+ unk->_memPool = &_commentPool;
+ unk->SetValue( str );
+ return unk;
+static FILE* callfopen( const char* filepath, const char* mode )
+#if defined(_MSC_VER) && (_MSC_VER >= 1400 ) && (!defined WINCE)
+ FILE* fp = 0;
+ errno_t err = fopen_s( &fp, filepath, mode );
+ if ( err ) {
+ return 0;
+#else
+ FILE* fp = fopen( filepath, mode );
+#endif
+ return fp;
+XMLError XMLDocument::LoadFile( const char* filename )
+ Clear();
+ FILE* fp = callfopen( filename, "rb" );
+ if ( !fp ) {
+ SetError( XML_ERROR_FILE_NOT_FOUND, filename, 0 );
+ return _errorID;
+ LoadFile( fp );
+ fclose( fp );
+ return _errorID;
+XMLError XMLDocument::LoadFile( FILE* fp )
+ Clear();
+ fseek( fp, 0, SEEK_SET );
+ if ( fgetc( fp ) == EOF && ferror( fp ) != 0 ) {
+ SetError( XML_ERROR_FILE_READ_ERROR, 0, 0 );
+ return _errorID;
+ fseek( fp, 0, SEEK_END );
+ const long filelength = ftell( fp );
+ if ( filelength == -1L ) {
+ return _errorID;
+ const size_t size = filelength;
+ if ( size == 0 ) {
+ SetError( XML_ERROR_EMPTY_DOCUMENT, 0, 0 );
+ return _errorID;
+ _charBuffer = new char[size+1];
+ size_t read = fread( _charBuffer, 1, size, fp );
+ if ( read != size ) {
+ return _errorID;
+ _charBuffer[size] = 0;
+ const char* p = _charBuffer;
+ p = XMLUtil::ReadBOM( p, &_writeBOM );
+ return _errorID;
+ ParseDeep( _charBuffer + (p-_charBuffer), 0 );
+ return _errorID;
+XMLError XMLDocument::SaveFile( const char* filename, bool compact )
+ FILE* fp = callfopen( filename, "w" );
+ if ( !fp ) {
+ SetError( XML_ERROR_FILE_COULD_NOT_BE_OPENED, filename, 0 );
+ return _errorID;
+ SaveFile(fp, compact);
+ fclose( fp );
+ return _errorID;
+XMLError XMLDocument::SaveFile( FILE* fp, bool compact )
+ XMLPrinter stream( fp, compact );
+ Print( &stream );
+ return _errorID;
+XMLError XMLDocument::Parse( const char* p, size_t len )
+ Clear();
+ if ( len == 0 || !p || !*p ) {
+ return _errorID;
+ if ( len == (size_t)(-1) ) {
+ len = strlen( p );
+ _charBuffer = new char[ len+1 ];
+ memcpy( _charBuffer, p, len );
+ _charBuffer[len] = 0;
+ return _errorID;
+ ptrdiff_t delta = p - start; // skip initial whitespace, BOM, etc.
+ ParseDeep( _charBuffer+delta, 0 );
+ return _errorID;
+void XMLDocument::Print( XMLPrinter* streamer ) const
+ XMLPrinter stdStreamer( stdout );
+ if ( !streamer ) {
+ streamer = &stdStreamer;
+ Accept( streamer );
+void XMLDocument::SetError( XMLError error, const char* str1, const char* str2 )
+ _errorID = error;
+ _errorStr1 = str1;
+ _errorStr2 = str2;
+const char* XMLDocument::ErrorName() const
+ TIXMLASSERT(_errorID >= 0 && _errorID < XML_ERROR_COUNT );
+ return _errorNames[_errorID];
+void XMLDocument::PrintError() const
+ if ( _errorID ) {
+ static const int LEN = 20;
+ char buf1[LEN] = { 0 };
+ char buf2[LEN] = { 0 };
+ if ( _errorStr1 ) {
+ TIXML_SNPRINTF( buf1, LEN, "%s", _errorStr1 );
+ if ( _errorStr2 ) {
+ TIXML_SNPRINTF( buf2, LEN, "%s", _errorStr2 );
+ printf( "XMLDocument error id=%d '%s' str1=%s str2=%s\n",
+ _errorID, ErrorName(), buf1, buf2 );
+XMLPrinter::XMLPrinter( FILE* file, bool compact, int depth ) :
+ _elementJustOpened( false ),
+ _firstElement( true ),
+ _fp( file ),
+ _depth( depth ),
+ _textDepth( -1 ),
+ _processEntities( true ),
+ _compactMode( compact )
+ for( int i=0; i<ENTITY_RANGE; ++i ) {
+ _entityFlag[i] = false;
+ _restrictedEntityFlag[i] = false;
+ for( int i=0; i<NUM_ENTITIES; ++i ) {
+ TIXMLASSERT( entities[i].value < ENTITY_RANGE );
+ if ( entities[i].value < ENTITY_RANGE ) {
+ _entityFlag[ (int)entities[i].value ] = true;
+ _restrictedEntityFlag[(int)'&'] = true;
+ _restrictedEntityFlag[(int)'<'] = true;
+ _restrictedEntityFlag[(int)'>'] = true; // not required, but consistency is nice
+ _buffer.Push( 0 );
+void XMLPrinter::Print( const char* format, ... )
+ va_list va;
+ va_start( va, format );
+ if ( _fp ) {
+ vfprintf( _fp, format, va );
+ else {
+ #if defined(WINCE)
+ int len = 512;
+ do {
+ len = len*2;
+ char* str = new char[len]();
+ len = _vsnprintf(str, len, format, va);
+ delete[] str;
+ }while (len < 0);
+ #else
+ int len = _vscprintf( format, va );
+ #endif
+#else
+ int len = vsnprintf( 0, 0, format, va );
+#endif
+ // Close out and re-start the va-args
+ va_end( va );
+ char* p = _buffer.PushArr( len ) - 1; // back up over the null terminator.
+ _vsnprintf( p, len+1, format, va );
+ #else
+ vsnprintf_s( p, len+1, _TRUNCATE, format, va );
+ #endif
+#else
+ vsnprintf( p, len+1, format, va );
+#endif
+ va_end( va );
+void XMLPrinter::PrintSpace( int depth )
+ for( int i=0; i<depth; ++i ) {
+ Print( " " );
+void XMLPrinter::PrintString( const char* p, bool restricted )
+ // Look for runs of bytes between entities to print.
+ const char* q = p;
+ const bool* flag = restricted ? _restrictedEntityFlag : _entityFlag;
+ if ( _processEntities ) {
+ while ( *q ) {
+ // Remember, char is sometimes signed. (How many times has that bitten me?)
+ if ( *q > 0 && *q < ENTITY_RANGE ) {
+ // Check for entities. If one is found, flush
+ // the stream up until the entity, write the
+ // entity, and keep looking.
+ if ( flag[(unsigned)(*q)] ) {
+ while ( p < q ) {
+ Print( "%c", *p );
+ ++p;
+ if ( entities[i].value == *q ) {
+ Print( "&%s;", entities[i].pattern );
+ break;
+ ++p;
+ ++q;
+ // Flush the remaining string. This will be the entire
+ // string if an entity wasn't found.
+ if ( !_processEntities || (q-p > 0) ) {
+ Print( "%s", p );
+void XMLPrinter::PushHeader( bool writeBOM, bool writeDec )
+ if ( writeBOM ) {
+ static const unsigned char bom[] = { TIXML_UTF_LEAD_0, TIXML_UTF_LEAD_1, TIXML_UTF_LEAD_2, 0 };
+ Print( "%s", bom );
+ if ( writeDec ) {
+ PushDeclaration( "xml version=\"1.0\"" );
+void XMLPrinter::OpenElement( const char* name, bool compactMode )
+ if ( _elementJustOpened ) {
+ SealElement();
+ _stack.Push( name );
+ if ( _textDepth < 0 && !_firstElement && !compactMode ) {
+ Print( "\n" );
+ if ( !compactMode ) {
+ PrintSpace( _depth );
+ Print( "<%s", name );
+ _elementJustOpened = true;
+ _firstElement = false;
+ ++_depth;
+void XMLPrinter::PushAttribute( const char* name, const char* value )
+ TIXMLASSERT( _elementJustOpened );
+ Print( " %s=\"", name );
+ PrintString( value, false );
+ Print( "\"" );
+void XMLPrinter::PushAttribute( const char* name, int v )
+ PushAttribute( name, buf );
+void XMLPrinter::PushAttribute( const char* name, unsigned v )
+void XMLPrinter::PushAttribute( const char* name, bool v )
+void XMLPrinter::PushAttribute( const char* name, double v )
+void XMLPrinter::CloseElement( bool compactMode )
+ --_depth;
+ const char* name = _stack.Pop();
+ Print( "/>" );
+ else {
+ if ( _textDepth < 0 && !compactMode) {
+ Print( "\n" );
+ Print( "</%s>", name );
+ if ( _textDepth == _depth ) {
+ _textDepth = -1;
+ if ( _depth == 0 && !compactMode) {
+ Print( "\n" );
+ _elementJustOpened = false;
+void XMLPrinter::SealElement()
+ Print( ">" );
+void XMLPrinter::PushText( const char* text, bool cdata )
+ _textDepth = _depth-1;
+ SealElement();
+ if ( cdata ) {
+ Print( "<![CDATA[" );
+ Print( "%s", text );
+ Print( "]]>" );
+ else {
+ PrintString( text, true );
+void XMLPrinter::PushText( int value )
+ XMLUtil::ToStr( value, buf, BUF_SIZE );
+ PushText( buf, false );
+void XMLPrinter::PushText( unsigned value )
+void XMLPrinter::PushText( bool value )
+void XMLPrinter::PushText( float value )
+void XMLPrinter::PushText( double value )
+void XMLPrinter::PushComment( const char* comment )
+ SealElement();
+ if ( _textDepth < 0 && !_firstElement && !_compactMode) {
+ Print( "\n" );
+ Print( "<!--%s-->", comment );
+void XMLPrinter::PushDeclaration( const char* value )
+ SealElement();
+ Print( "\n" );
+ Print( "<?%s?>", value );
+void XMLPrinter::PushUnknown( const char* value )
+ SealElement();
+ Print( "\n" );
+ Print( "<!%s>", value );
+bool XMLPrinter::VisitEnter( const XMLDocument& doc )
+ _processEntities = doc.ProcessEntities();
+ if ( doc.HasBOM() ) {
+ PushHeader( true, false );
+ return true;
+bool XMLPrinter::VisitEnter( const XMLElement& element, const XMLAttribute* attribute )
+ const XMLElement* parentElem = element.Parent()->ToElement();
+ bool compactMode = parentElem ? CompactMode(*parentElem) : _compactMode;
+ OpenElement( element.Name(), compactMode );
+ while ( attribute ) {
+ PushAttribute( attribute->Name(), attribute->Value() );
+ attribute = attribute->Next();
+ return true;
+bool XMLPrinter::VisitExit( const XMLElement& element )
+ CloseElement( CompactMode(element) );
+ return true;
+bool XMLPrinter::Visit( const XMLText& text )
+ PushText( text.Value(), text.CData() );
+ return true;
+bool XMLPrinter::Visit( const XMLComment& comment )
+ PushComment( comment.Value() );
+ return true;
+bool XMLPrinter::Visit( const XMLDeclaration& declaration )
+ PushDeclaration( declaration.Value() );
+ return true;
+bool XMLPrinter::Visit( const XMLUnknown& unknown )
+ PushUnknown( unknown.Value() );
+ return true;
+} // namespace tinyxml2
diff --git a/tests/xmltester/tinyxml2/tinyxml2.h b/tests/xmltester/tinyxml2/tinyxml2.h
index 0000000..cfb2d65
--- /dev/null
+++ b/tests/xmltester/tinyxml2/tinyxml2.h
@@ -0,0 +1,2082 @@
+distribution.
+#ifndef TINYXML2_INCLUDED
+#define TINYXML2_INCLUDED
+#if defined(ANDROID_NDK) || defined(__BORLANDC__)
+# include <ctype.h>
+# include <limits.h>
+# include <stdio.h>
+# include <stdlib.h>
+# include <string.h>
+# include <stdarg.h>
+#else
+# include <cctype>
+# include <climits>
+# include <cstdio>
+# include <cstdlib>
+# include <cstring>
+# include <cstdarg>
+#endif
+ TODO: intern strings instead of allocation.
+ gcc:
+ g++ -Wall -DDEBUG tinyxml2.cpp xmltest.cpp -o gccxmltest.exe
+ Formatting, Artistic Style:
+ AStyle.exe --style=1tbs --indent-switches --break-closing-brackets --indent-preprocessor tinyxml2.cpp tinyxml2.h
+#if defined( _DEBUG ) || defined( DEBUG ) || defined (__DEBUG__)
+# ifndef DEBUG
+# define DEBUG
+# endif
+#endif
+#ifdef _MSC_VER
+# pragma warning(push)
+# pragma warning(disable: 4251)
+#endif
+#ifdef _WIN32
+# ifdef TINYXML2_EXPORT
+# define TINYXML2_LIB __declspec(dllexport)
+# elif defined(TINYXML2_IMPORT)
+# define TINYXML2_LIB __declspec(dllimport)
+# else
+# endif
+#else
+#endif
+#if defined(DEBUG)
+# if defined(_MSC_VER)
+# define TIXMLASSERT( x ) if ( !(x)) { __debugbreak(); } //if ( !(x)) WinDebugBreak()
+# elif defined (ANDROID_NDK)
+# include <android/log.h>
+# define TIXMLASSERT( x ) if ( !(x)) { __android_log_assert( "assert", "grinliz", "ASSERT in '%s' at %d.", __FILE__, __LINE__ ); }
+# else
+# include <assert.h>
+# define TIXMLASSERT assert
+# endif
+# else
+# define TIXMLASSERT( x ) {}
+#endif
+// Microsoft visual studio, version 2005 and higher.
+/*int _snprintf_s(
+ char *buffer,
+ size_t sizeOfBuffer,
+ size_t count,
+ const char *format [,
+ argument] ...
+inline int TIXML_SNPRINTF( char* buffer, size_t size, const char* format, ... )
+ va_list va;
+ int result = vsnprintf_s( buffer, size, _TRUNCATE, format, va );
+ va_end( va );
+ return result;
+#define TIXML_SSCANF sscanf_s
+#elif defined WINCE
+#define TIXML_SNPRINTF _snprintf
+#else
+// GCC version 3 and higher
+//#warning( "Using sn* functions." )
+#define TIXML_SNPRINTF snprintf
+#endif
+/* Versioning, past 1.0.14:
+ http://semver.org/
+static const int TIXML2_MAJOR_VERSION = 2;
+static const int TIXML2_MINOR_VERSION = 2;
+static const int TIXML2_PATCH_VERSION = 0;
+namespace tinyxml2
+class XMLDocument;
+class XMLElement;
+class XMLAttribute;
+class XMLComment;
+class XMLText;
+class XMLDeclaration;
+class XMLUnknown;
+class XMLPrinter;
+ A class that wraps strings. Normally stores the start and end
+ pointers into the XML file itself, and will apply normalization
+ and entity translation if actually read. Can also store (and memory
+ manage) a traditional char[]
+class StrPair
+public:
+ enum {
+ NEEDS_ENTITY_PROCESSING = 0x01,
+ NEEDS_NEWLINE_NORMALIZATION = 0x02,
+ COLLAPSE_WHITESPACE = 0x04,
+ TEXT_ELEMENT = NEEDS_ENTITY_PROCESSING | NEEDS_NEWLINE_NORMALIZATION,
+ TEXT_ELEMENT_LEAVE_ENTITIES = NEEDS_NEWLINE_NORMALIZATION,
+ ATTRIBUTE_NAME = 0,
+ ATTRIBUTE_VALUE = NEEDS_ENTITY_PROCESSING | NEEDS_NEWLINE_NORMALIZATION,
+ ATTRIBUTE_VALUE_LEAVE_ENTITIES = NEEDS_NEWLINE_NORMALIZATION,
+ COMMENT = NEEDS_NEWLINE_NORMALIZATION
+ StrPair() : _flags( 0 ), _start( 0 ), _end( 0 ) {}
+ ~StrPair();
+ void Set( char* start, char* end, int flags ) {
+ Reset();
+ _start = start;
+ _end = end;
+ _flags = flags | NEEDS_FLUSH;
+ const char* GetStr();
+ bool Empty() const {
+ return _start == _end;
+ void SetInternedStr( const char* str ) {
+ Reset();
+ _start = const_cast<char*>(str);
+ void SetStr( const char* str, int flags=0 );
+ char* ParseText( char* in, const char* endTag, int strFlags );
+ char* ParseName( char* in );
+private:
+ void Reset();
+ void CollapseWhitespace();
+ enum {
+ NEEDS_FLUSH = 0x100,
+ NEEDS_DELETE = 0x200
+ // After parsing, if *_end != 0, it can be set to zero.
+ int _flags;
+ char* _start;
+ char* _end;
+ A dynamic array of Plain Old Data. Doesn't support constructors, etc.
+ Has a small initial memory pool, so that low or no usage will not
+ cause a call to new/delete
+template <class T, int INIT>
+class DynArray
+public:
+ DynArray< T, INIT >() {
+ _mem = _pool;
+ _allocated = INIT;
+ _size = 0;
+ ~DynArray() {
+ if ( _mem != _pool ) {
+ delete [] _mem;
+ void Clear() {
+ _size = 0;
+ void Push( T t ) {
+ EnsureCapacity( _size+1 );
+ _mem[_size++] = t;
+ T* PushArr( int count ) {
+ EnsureCapacity( _size+count );
+ T* ret = &_mem[_size];
+ _size += count;
+ return ret;
+ T Pop() {
+ return _mem[--_size];
+ void PopArr( int count ) {
+ TIXMLASSERT( _size >= count );
+ _size -= count;
+ return _size == 0;
+ T& operator[](int i) {
+ TIXMLASSERT( i>= 0 && i < _size );
+ return _mem[i];
+ const T& operator[](int i) const {
+ return _mem[i];
+ const T& PeekTop() const {
+ TIXMLASSERT( _size > 0 );
+ return _mem[ _size - 1];
+ int Size() const {
+ return _size;
+ int Capacity() const {
+ return _allocated;
+ const T* Mem() const {
+ return _mem;
+ T* Mem() {
+ return _mem;
+private:
+ void EnsureCapacity( int cap ) {
+ if ( cap > _allocated ) {
+ int newAllocated = cap * 2;
+ T* newMem = new T[newAllocated];
+ memcpy( newMem, _mem, sizeof(T)*_size ); // warning: not using constructors, only works for PODs
+ delete [] _mem;
+ _mem = newMem;
+ _allocated = newAllocated;
+ T* _mem;
+ T _pool[INIT];
+ int _allocated; // objects allocated
+ int _size; // number objects in use
+ Parent virtual class of a pool for fast allocation
+ and deallocation of objects.
+class MemPool
+public:
+ MemPool() {}
+ virtual ~MemPool() {}
+ virtual int ItemSize() const = 0;
+ virtual void* Alloc() = 0;
+ virtual void Free( void* ) = 0;
+ virtual void SetTracked() = 0;
+ Template child class to create pools of the correct type.
+template< int SIZE >
+class MemPoolT : public MemPool
+public:
+ MemPoolT() : _root(0), _currentAllocs(0), _nAllocs(0), _maxAllocs(0), _nUntracked(0) {}
+ ~MemPoolT() {
+ // Delete the blocks.
+ for( int i=0; i<_blockPtrs.Size(); ++i ) {
+ delete _blockPtrs[i];
+ virtual int ItemSize() const {
+ return SIZE;
+ int CurrentAllocs() const {
+ return _currentAllocs;
+ virtual void* Alloc() {
+ if ( !_root ) {
+ // Need a new block.
+ Block* block = new Block();
+ _blockPtrs.Push( block );
+ for( int i=0; i<COUNT-1; ++i ) {
+ block->chunk[i].next = &block->chunk[i+1];
+ block->chunk[COUNT-1].next = 0;
+ _root = block->chunk;
+ void* result = _root;
+ _root = _root->next;
+ ++_currentAllocs;
+ if ( _currentAllocs > _maxAllocs ) {
+ _maxAllocs = _currentAllocs;
+ _nAllocs++;
+ _nUntracked++;
+ return result;
+ virtual void Free( void* mem ) {
+ if ( !mem ) {
+ return;
+ --_currentAllocs;
+ Chunk* chunk = static_cast<Chunk*>( mem );
+#ifdef DEBUG
+ memset( chunk, 0xfe, sizeof(Chunk) );
+#endif
+ chunk->next = _root;
+ _root = chunk;
+ void Trace( const char* name ) {
+ printf( "Mempool %s watermark=%d [%dk] current=%d size=%d nAlloc=%d blocks=%d\n",
+ name, _maxAllocs, _maxAllocs*SIZE/1024, _currentAllocs, SIZE, _nAllocs, _blockPtrs.Size() );
+ void SetTracked() {
+ _nUntracked--;
+ int Untracked() const {
+ return _nUntracked;
+ // This number is perf sensitive. 4k seems like a good tradeoff on my machine.
+ // The test file is large, 170k.
+ // Release: VS2010 gcc(no opt)
+ // 1k: 4000
+ // 2k: 4000
+ // 4k: 3900 21000
+ // 16k: 5200
+ // 32k: 4300
+ // 64k: 4000 21000
+ enum { COUNT = (4*1024)/SIZE }; // Some compilers do not accept to use COUNT in private part if COUNT is private
+private:
+ union Chunk {
+ Chunk* next;
+ char mem[SIZE];
+ struct Block {
+ Chunk chunk[COUNT];
+ DynArray< Block*, 10 > _blockPtrs;
+ Chunk* _root;
+ int _currentAllocs;
+ int _nAllocs;
+ int _maxAllocs;
+ int _nUntracked;
+ Implements the interface to the "Visitor pattern" (see the Accept() method.)
+ If you call the Accept() method, it requires being passed a XMLVisitor
+ class to handle callbacks. For nodes that contain other nodes (Document, Element)
+ you will get called with a VisitEnter/VisitExit pair. Nodes that are always leafs
+ are simply called with Visit().
+ If you return 'true' from a Visit method, recursive parsing will continue. If you return
+ false, <b>no children of this node or its siblings</b> will be visited.
+ All flavors of Visit methods have a default implementation that returns 'true' (continue
+ visiting). You need to only override methods that are interesting to you.
+ Generally Accept() is called on the XMLDocument, although all nodes support visiting.
+ You should never change the document from a callback.
+ @sa XMLNode::Accept()
+class TINYXML2_LIB XMLVisitor
+public:
+ virtual ~XMLVisitor() {}
+ /// Visit a document.
+ virtual bool VisitEnter( const XMLDocument& /*doc*/ ) {
+ return true;
+ virtual bool VisitExit( const XMLDocument& /*doc*/ ) {
+ return true;
+ /// Visit an element.
+ virtual bool VisitEnter( const XMLElement& /*element*/, const XMLAttribute* /*firstAttribute*/ ) {
+ return true;
+ virtual bool VisitExit( const XMLElement& /*element*/ ) {
+ return true;
+ /// Visit a declaration.
+ virtual bool Visit( const XMLDeclaration& /*declaration*/ ) {
+ return true;
+ /// Visit a text node.
+ virtual bool Visit( const XMLText& /*text*/ ) {
+ return true;
+ /// Visit a comment node.
+ virtual bool Visit( const XMLComment& /*comment*/ ) {
+ return true;
+ /// Visit an unknown node.
+ virtual bool Visit( const XMLUnknown& /*unknown*/ ) {
+ return true;
+// WARNING: must match XMLErrorNames[]
+enum XMLError {
+ XML_SUCCESS = 0,
+ XML_NO_ERROR = 0,
+ XML_NO_ATTRIBUTE,
+ XML_WRONG_ATTRIBUTE_TYPE,
+ XML_ERROR_FILE_NOT_FOUND,
+ XML_ERROR_FILE_COULD_NOT_BE_OPENED,
+ XML_ERROR_FILE_READ_ERROR,
+ XML_ERROR_ELEMENT_MISMATCH,
+ XML_ERROR_PARSING_ELEMENT,
+ XML_ERROR_PARSING_ATTRIBUTE,
+ XML_ERROR_IDENTIFYING_TAG,
+ XML_ERROR_PARSING_TEXT,
+ XML_ERROR_PARSING_CDATA,
+ XML_ERROR_PARSING_COMMENT,
+ XML_ERROR_PARSING_DECLARATION,
+ XML_ERROR_PARSING_UNKNOWN,
+ XML_ERROR_EMPTY_DOCUMENT,
+ XML_ERROR_MISMATCHED_ELEMENT,
+ XML_ERROR_PARSING,
+ XML_CAN_NOT_CONVERT_TEXT,
+ XML_NO_TEXT_NODE,
+ XML_ERROR_COUNT
+ Utility functionality.
+class XMLUtil
+public:
+ // Anything in the high order range of UTF-8 is assumed to not be whitespace. This isn't
+ // correct, but simple, and usually works.
+ static const char* SkipWhiteSpace( const char* p ) {
+ while( !IsUTF8Continuation(*p) && isspace( *reinterpret_cast<const unsigned char*>(p) ) ) {
+ ++p;
+ return p;
+ static char* SkipWhiteSpace( char* p ) {
+ while( !IsUTF8Continuation(*p) && isspace( *reinterpret_cast<unsigned char*>(p) ) ) {
+ ++p;
+ return p;
+ static bool IsWhiteSpace( char p ) {
+ return !IsUTF8Continuation(p) && isspace( static_cast<unsigned char>(p) );
+ inline static bool IsNameStartChar( unsigned char ch ) {
+ return ( ( ch < 128 ) ? isalpha( ch ) : 1 )
+ || ch == ':'
+ || ch == '_';
+ inline static bool IsNameChar( unsigned char ch ) {
+ return IsNameStartChar( ch )
+ || isdigit( ch )
+ || ch == '.'
+ || ch == '-';
+ inline static bool StringEqual( const char* p, const char* q, int nChar=INT_MAX ) {
+ int n = 0;
+ if ( p == q ) {
+ return true;
+ while( *p && *q && *p == *q && n<nChar ) {
+ ++p;
+ ++q;
+ ++n;
+ if ( (n == nChar) || ( *p == 0 && *q == 0 ) ) {
+ return true;
+ return false;
+ inline static int IsUTF8Continuation( const char p ) {
+ return p & 0x80;
+ static const char* ReadBOM( const char* p, bool* hasBOM );
+ // p is the starting location,
+ // the UTF-8 value of the entity will be placed in value, and length filled in.
+ static const char* GetCharacterRef( const char* p, char* value, int* length );
+ static void ConvertUTF32ToUTF8( unsigned long input, char* output, int* length );
+ // converts primitive types to strings
+ static void ToStr( int v, char* buffer, int bufferSize );
+ static void ToStr( unsigned v, char* buffer, int bufferSize );
+ static void ToStr( bool v, char* buffer, int bufferSize );
+ static void ToStr( float v, char* buffer, int bufferSize );
+ static void ToStr( double v, char* buffer, int bufferSize );
+ // converts strings to primitive types
+ static bool ToInt( const char* str, int* value );
+ static bool ToUnsigned( const char* str, unsigned* value );
+ static bool ToBool( const char* str, bool* value );
+ static bool ToFloat( const char* str, float* value );
+ static bool ToDouble( const char* str, double* value );
+/** XMLNode is a base class for every object that is in the
+ XML Document Object Model (DOM), except XMLAttributes.
+ Nodes have siblings, a parent, and children which can
+ be navigated. A node is always in a XMLDocument.
+ The type of a XMLNode can be queried, and it can
+ be cast to its more defined type.
+ A XMLDocument allocates memory for all its Nodes.
+ When the XMLDocument gets deleted, all its Nodes
+ will also be deleted.
+ @verbatim
+ A Document can contain: Element (container or leaf)
+ Comment (leaf)
+ Unknown (leaf)
+ Declaration( leaf )
+ An Element can contain: Element (container or leaf)
+ Text (leaf)
+ Attributes (not on tree)
+ Comment (leaf)
+ Unknown (leaf)
+ @endverbatim
+class TINYXML2_LIB XMLNode
+ friend class XMLDocument;
+ friend class XMLElement;
+public:
+ /// Get the XMLDocument that owns this XMLNode.
+ const XMLDocument* GetDocument() const {
+ return _document;
+ XMLDocument* GetDocument() {
+ return _document;
+ /// Safely cast to an Element, or null.
+ virtual XMLElement* ToElement() {
+ return 0;
+ /// Safely cast to Text, or null.
+ virtual XMLText* ToText() {
+ return 0;
+ /// Safely cast to a Comment, or null.
+ virtual XMLComment* ToComment() {
+ return 0;
+ /// Safely cast to a Document, or null.
+ virtual XMLDocument* ToDocument() {
+ return 0;
+ /// Safely cast to a Declaration, or null.
+ virtual XMLDeclaration* ToDeclaration() {
+ return 0;
+ /// Safely cast to an Unknown, or null.
+ virtual XMLUnknown* ToUnknown() {
+ return 0;
+ virtual const XMLElement* ToElement() const {
+ return 0;
+ virtual const XMLText* ToText() const {
+ return 0;
+ virtual const XMLComment* ToComment() const {
+ return 0;
+ virtual const XMLDocument* ToDocument() const {
+ return 0;
+ virtual const XMLDeclaration* ToDeclaration() const {
+ return 0;
+ virtual const XMLUnknown* ToUnknown() const {
+ return 0;
+ /** The meaning of 'value' changes for the specific type.
+ @verbatim
+ Document: empty
+ Element: name of the element
+ Comment: the comment text
+ Unknown: the tag contents
+ Text: the text string
+ @endverbatim
+ const char* Value() const;
+ /** Set the Value of an XML node.
+ @sa Value()
+ void SetValue( const char* val, bool staticMem=false );
+ /// Get the parent of this node on the DOM.
+ const XMLNode* Parent() const {
+ return _parent;
+ XMLNode* Parent() {
+ return _parent;
+ /// Returns true if this node has no children.
+ bool NoChildren() const {
+ return !_firstChild;
+ /// Get the first child node, or null if none exists.
+ const XMLNode* FirstChild() const {
+ return _firstChild;
+ XMLNode* FirstChild() {
+ /** Get the first child element, or optionally the first child
+ element with the specified name.
+ const XMLElement* FirstChildElement( const char* value=0 ) const;
+ XMLElement* FirstChildElement( const char* value=0 ) {
+ return const_cast<XMLElement*>(const_cast<const XMLNode*>(this)->FirstChildElement( value ));
+ /// Get the last child node, or null if none exists.
+ const XMLNode* LastChild() const {
+ return _lastChild;
+ XMLNode* LastChild() {
+ return const_cast<XMLNode*>(const_cast<const XMLNode*>(this)->LastChild() );
+ /** Get the last child element or optionally the last child
+ const XMLElement* LastChildElement( const char* value=0 ) const;
+ XMLElement* LastChildElement( const char* value=0 ) {
+ return const_cast<XMLElement*>(const_cast<const XMLNode*>(this)->LastChildElement(value) );
+ /// Get the previous (left) sibling node of this node.
+ const XMLNode* PreviousSibling() const {
+ return _prev;
+ XMLNode* PreviousSibling() {
+ return _prev;
+ /// Get the previous (left) sibling element of this node, with an optionally supplied name.
+ const XMLElement* PreviousSiblingElement( const char* value=0 ) const ;
+ XMLElement* PreviousSiblingElement( const char* value=0 ) {
+ return const_cast<XMLElement*>(const_cast<const XMLNode*>(this)->PreviousSiblingElement( value ) );
+ /// Get the next (right) sibling node of this node.
+ const XMLNode* NextSibling() const {
+ return _next;
+ XMLNode* NextSibling() {
+ return _next;
+ /// Get the next (right) sibling element of this node, with an optionally supplied name.
+ const XMLElement* NextSiblingElement( const char* value=0 ) const;
+ XMLElement* NextSiblingElement( const char* value=0 ) {
+ return const_cast<XMLElement*>(const_cast<const XMLNode*>(this)->NextSiblingElement( value ) );
+ Add a child node as the last (right) child.
+ If the child node is already part of the document,
+ it is moved from its old location to the new location.
+ Returns the addThis argument or 0 if the node does not
+ belong to the same document.
+ XMLNode* InsertEndChild( XMLNode* addThis );
+ XMLNode* LinkEndChild( XMLNode* addThis ) {
+ Add a child node as the first (left) child.
+ XMLNode* InsertFirstChild( XMLNode* addThis );
+ Add a node after the specified child node.
+ Returns the addThis argument or 0 if the afterThis node
+ is not a child of this node, or if the node does not
+ XMLNode* InsertAfterChild( XMLNode* afterThis, XMLNode* addThis );
+ Delete all the children of this node.
+ void DeleteChildren();
+ Delete a child of this node.
+ void DeleteChild( XMLNode* node );
+ Make a copy of this node, but not its children.
+ You may pass in a Document pointer that will be
+ the owner of the new Node. If the 'document' is
+ null, then the node returned will be allocated
+ from the current Document. (this->GetDocument())
+ Note: if called on a XMLDocument, this will return null.
+ virtual XMLNode* ShallowClone( XMLDocument* document ) const = 0;
+ Test if 2 nodes are the same, but don't test children.
+ The 2 nodes do not need to be in the same Document.
+ Note: if called on a XMLDocument, this will return false.
+ virtual bool ShallowEqual( const XMLNode* compare ) const = 0;
+ /** Accept a hierarchical visit of the nodes in the TinyXML-2 DOM. Every node in the
+ XML tree will be conditionally visited and the host will be called back
+ via the XMLVisitor interface.
+ This is essentially a SAX interface for TinyXML-2. (Note however it doesn't re-parse
+ the XML for the callbacks, so the performance of TinyXML-2 is unchanged by using this
+ interface versus any other.)
+ The interface has been based on ideas from:
+ - http://www.saxproject.org/
+ - http://c2.com/cgi/wiki?HierarchicalVisitorPattern
+ Which are both good references for "visiting".
+ An example of using Accept():
+ @verbatim
+ XMLPrinter printer;
+ tinyxmlDoc.Accept( &printer );
+ const char* xmlcstr = printer.CStr();
+ @endverbatim
+ virtual bool Accept( XMLVisitor* visitor ) const = 0;
+ // internal
+ virtual char* ParseDeep( char*, StrPair* );
+protected:
+ XMLNode( XMLDocument* );
+ virtual ~XMLNode();
+ XMLNode( const XMLNode& ); // not supported
+ XMLNode& operator=( const XMLNode& ); // not supported
+ XMLDocument* _document;
+ XMLNode* _parent;
+ mutable StrPair _value;
+ XMLNode* _firstChild;
+ XMLNode* _lastChild;
+ XMLNode* _prev;
+ XMLNode* _next;
+private:
+ MemPool* _memPool;
+ void Unlink( XMLNode* child );
+ static void DeleteNode( XMLNode* node );
+/** XML text.
+ Note that a text node can have child element nodes, for example:
+ @verbatim
+ <root>This is <b>bold</b></root>
+ @endverbatim
+ A text node can have 2 ways to output the next. "normal" output
+ and CDATA. It will default to the mode it was parsed from the XML file and
+ you generally want to leave it alone, but you can change the output mode with
+ SetCData() and query it with CData().
+class TINYXML2_LIB XMLText : public XMLNode
+ friend class XMLBase;
+public:
+ virtual bool Accept( XMLVisitor* visitor ) const;
+ return this;
+ return this;
+ /// Declare whether this should be CDATA or standard text.
+ void SetCData( bool isCData ) {
+ _isCData = isCData;
+ /// Returns true if this is a CDATA text element.
+ bool CData() const {
+ return _isCData;
+ char* ParseDeep( char*, StrPair* endTag );
+ virtual XMLNode* ShallowClone( XMLDocument* document ) const;
+ virtual bool ShallowEqual( const XMLNode* compare ) const;
+protected:
+ XMLText( XMLDocument* doc ) : XMLNode( doc ), _isCData( false ) {}
+ virtual ~XMLText() {}
+ XMLText( const XMLText& ); // not supported
+ XMLText& operator=( const XMLText& ); // not supported
+private:
+ bool _isCData;
+/** An XML Comment. */
+class TINYXML2_LIB XMLComment : public XMLNode
+public:
+ return this;
+ return this;
+protected:
+ XMLComment( XMLDocument* doc );
+ virtual ~XMLComment();
+ XMLComment( const XMLComment& ); // not supported
+ XMLComment& operator=( const XMLComment& ); // not supported
+private:
+/** In correct XML the declaration is the first entry in the file.
+ @verbatim
+ <?xml version="1.0" standalone="yes"?>
+ @endverbatim
+ TinyXML-2 will happily read or write files without a declaration,
+ however.
+ The text of the declaration isn't interpreted. It is parsed
+ and written as a string.
+class TINYXML2_LIB XMLDeclaration : public XMLNode
+public:
+ return this;
+ return this;
+protected:
+ XMLDeclaration( XMLDocument* doc );
+ virtual ~XMLDeclaration();
+ XMLDeclaration( const XMLDeclaration& ); // not supported
+ XMLDeclaration& operator=( const XMLDeclaration& ); // not supported
+/** Any tag that TinyXML-2 doesn't recognize is saved as an
+ unknown. It is a tag of text, but should not be modified.
+ It will be written back to the XML, unchanged, when the file
+ is saved.
+ DTD tags get thrown into XMLUnknowns.
+class TINYXML2_LIB XMLUnknown : public XMLNode
+public:
+ return this;
+ return this;
+protected:
+ XMLUnknown( XMLDocument* doc );
+ virtual ~XMLUnknown();
+ XMLUnknown( const XMLUnknown& ); // not supported
+ XMLUnknown& operator=( const XMLUnknown& ); // not supported
+/** An attribute is a name-value pair. Elements have an arbitrary
+ number of attributes, each with a unique name.
+ @note The attributes are not XMLNodes. You may only query the
+ Next() attribute in a list.
+class TINYXML2_LIB XMLAttribute
+public:
+ /// The name of the attribute.
+ const char* Name() const;
+ /// The value of the attribute.
+ /// The next attribute in the list.
+ const XMLAttribute* Next() const {
+ return _next;
+ /** IntValue interprets the attribute as an integer, and returns the value.
+ If the value isn't an integer, 0 will be returned. There is no error checking;
+ use QueryIntValue() if you need error checking.
+ int IntValue() const {
+ int i=0;
+ QueryIntValue( &i );
+ return i;
+ /// Query as an unsigned integer. See IntValue()
+ unsigned UnsignedValue() const {
+ unsigned i=0;
+ QueryUnsignedValue( &i );
+ return i;
+ /// Query as a boolean. See IntValue()
+ bool BoolValue() const {
+ bool b=false;
+ QueryBoolValue( &b );
+ return b;
+ /// Query as a double. See IntValue()
+ double DoubleValue() const {
+ double d=0;
+ QueryDoubleValue( &d );
+ return d;
+ /// Query as a float. See IntValue()
+ float FloatValue() const {
+ float f=0;
+ QueryFloatValue( &f );
+ return f;
+ /** QueryIntValue interprets the attribute as an integer, and returns the value
+ in the provided parameter. The function will return XML_NO_ERROR on success,
+ and XML_WRONG_ATTRIBUTE_TYPE if the conversion is not successful.
+ XMLError QueryIntValue( int* value ) const;
+ /// See QueryIntValue
+ XMLError QueryUnsignedValue( unsigned int* value ) const;
+ XMLError QueryBoolValue( bool* value ) const;
+ XMLError QueryDoubleValue( double* value ) const;
+ XMLError QueryFloatValue( float* value ) const;
+ /// Set the attribute to a string value.
+ void SetAttribute( const char* value );
+ /// Set the attribute to value.
+ void SetAttribute( int value );
+ void SetAttribute( unsigned value );
+ void SetAttribute( bool value );
+ void SetAttribute( double value );
+ void SetAttribute( float value );
+private:
+ enum { BUF_SIZE = 200 };
+ XMLAttribute() : _next( 0 ), _memPool( 0 ) {}
+ virtual ~XMLAttribute() {}
+ XMLAttribute( const XMLAttribute& ); // not supported
+ void operator=( const XMLAttribute& ); // not supported
+ void SetName( const char* name );
+ char* ParseDeep( char* p, bool processEntities );
+ mutable StrPair _name;
+ XMLAttribute* _next;
+/** The element is a container class. It has a value, the element name,
+ and can contain other elements, text, comments, and unknowns.
+ Elements also contain an arbitrary number of attributes.
+class TINYXML2_LIB XMLElement : public XMLNode
+public:
+ /// Get the name of an element (which is the Value() of the node.)
+ const char* Name() const {
+ return Value();
+ /// Set the name of the element.
+ void SetName( const char* str, bool staticMem=false ) {
+ SetValue( str, staticMem );
+ return this;
+ return this;
+ /** Given an attribute name, Attribute() returns the value
+ for the attribute of that name, or null if none
+ exists. For example:
+ @verbatim
+ const char* value = ele->Attribute( "foo" );
+ @endverbatim
+ The 'value' parameter is normally null. However, if specified,
+ the attribute will only be returned if the 'name' and 'value'
+ match. This allow you to write code:
+ @verbatim
+ if ( ele->Attribute( "foo", "bar" ) ) callFooIsBar();
+ @endverbatim
+ rather than:
+ @verbatim
+ if ( ele->Attribute( "foo" ) ) {
+ if ( strcmp( ele->Attribute( "foo" ), "bar" ) == 0 ) callFooIsBar();
+ @endverbatim
+ const char* Attribute( const char* name, const char* value=0 ) const;
+ /** Given an attribute name, IntAttribute() returns the value
+ of the attribute interpreted as an integer. 0 will be
+ returned if there is an error. For a method with error
+ checking, see QueryIntAttribute()
+ int IntAttribute( const char* name ) const {
+ int i=0;
+ QueryIntAttribute( name, &i );
+ return i;
+ /// See IntAttribute()
+ unsigned UnsignedAttribute( const char* name ) const {
+ unsigned i=0;
+ QueryUnsignedAttribute( name, &i );
+ return i;
+ bool BoolAttribute( const char* name ) const {
+ bool b=false;
+ QueryBoolAttribute( name, &b );
+ return b;
+ double DoubleAttribute( const char* name ) const {
+ double d=0;
+ QueryDoubleAttribute( name, &d );
+ return d;
+ float FloatAttribute( const char* name ) const {
+ float f=0;
+ QueryFloatAttribute( name, &f );
+ return f;
+ /** Given an attribute name, QueryIntAttribute() returns
+ XML_NO_ERROR, XML_WRONG_ATTRIBUTE_TYPE if the conversion
+ can't be performed, or XML_NO_ATTRIBUTE if the attribute
+ doesn't exist. If successful, the result of the conversion
+ will be written to 'value'. If not successful, nothing will
+ be written to 'value'. This allows you to provide default
+ value:
+ @verbatim
+ int value = 10;
+ QueryIntAttribute( "foo", &value ); // if "foo" isn't found, value will still be 10
+ @endverbatim
+ XMLError QueryIntAttribute( const char* name, int* value ) const {
+ if ( !a ) {
+ return XML_NO_ATTRIBUTE;
+ return a->QueryIntValue( value );
+ /// See QueryIntAttribute()
+ XMLError QueryUnsignedAttribute( const char* name, unsigned int* value ) const {
+ if ( !a ) {
+ return a->QueryUnsignedValue( value );
+ XMLError QueryBoolAttribute( const char* name, bool* value ) const {
+ if ( !a ) {
+ return a->QueryBoolValue( value );
+ XMLError QueryDoubleAttribute( const char* name, double* value ) const {
+ if ( !a ) {
+ return a->QueryDoubleValue( value );
+ XMLError QueryFloatAttribute( const char* name, float* value ) const {
+ if ( !a ) {
+ return a->QueryFloatValue( value );
+ /** Given an attribute name, QueryAttribute() returns
+ doesn't exist. It is overloaded for the primitive types,
+ and is a generally more convenient replacement of
+ QueryIntAttribute() and related functions.
+ If successful, the result of the conversion
+ value:
+ @verbatim
+ int value = 10;
+ QueryAttribute( "foo", &value ); // if "foo" isn't found, value will still be 10
+ @endverbatim
+ int QueryAttribute( const char* name, int* value ) const {
+ return QueryIntAttribute( name, value );
+ int QueryAttribute( const char* name, unsigned int* value ) const {
+ return QueryUnsignedAttribute( name, value );
+ int QueryAttribute( const char* name, bool* value ) const {
+ return QueryBoolAttribute( name, value );
+ int QueryAttribute( const char* name, double* value ) const {
+ return QueryDoubleAttribute( name, value );
+ int QueryAttribute( const char* name, float* value ) const {
+ return QueryFloatAttribute( name, value );
+ /// Sets the named attribute to value.
+ void SetAttribute( const char* name, const char* value ) {
+ XMLAttribute* a = FindOrCreateAttribute( name );
+ a->SetAttribute( value );
+ void SetAttribute( const char* name, int value ) {
+ void SetAttribute( const char* name, unsigned value ) {
+ void SetAttribute( const char* name, bool value ) {
+ void SetAttribute( const char* name, double value ) {
+ void SetAttribute( const char* name, float value ) {
+ Delete an attribute.
+ void DeleteAttribute( const char* name );
+ /// Return the first attribute in the list.
+ const XMLAttribute* FirstAttribute() const {
+ return _rootAttribute;
+ /// Query a specific attribute in the list.
+ const XMLAttribute* FindAttribute( const char* name ) const;
+ /** Convenience function for easy access to the text inside an element. Although easy
+ and concise, GetText() is limited compared to getting the XMLText child
+ and accessing it directly.
+ If the first child of 'this' is a XMLText, the GetText()
+ returns the character string of the Text node, else null is returned.
+ This is a convenient method for getting the text of simple contained text:
+ @verbatim
+ <foo>This is text</foo>
+ const char* str = fooElement->GetText();
+ @endverbatim
+ 'str' will be a pointer to "This is text".
+ Note that this function can be misleading. If the element foo was created from
+ this XML:
+ @verbatim
+ <foo><b>This is text</b></foo>
+ @endverbatim
+ then the value of str would be null. The first child node isn't a text node, it is
+ another element. From this XML:
+ @verbatim
+ <foo>This is <b>text</b></foo>
+ @endverbatim
+ GetText() will return "This is ".
+ const char* GetText() const;
+ and concise, SetText() is limited compared to creating an XMLText child
+ and mutating it directly.
+ If the first child of 'this' is a XMLText, SetText() sets its value to
+ the given string, otherwise it will create a first child that is an XMLText.
+ This is a convenient method for setting the text of simple contained text:
+ @verbatim
+ fooElement->SetText( "Hullaballoo!" );
+ <foo>Hullaballoo!</foo>
+ @endverbatim
+ this XML:
+ @verbatim
+ @endverbatim
+ then it will not change "This is text", but rather prefix it with a text element:
+ @verbatim
+ <foo>Hullaballoo!<b>This is text</b></foo>
+ @endverbatim
+ For this XML:
+ @verbatim
+ <foo />
+ @endverbatim
+ SetText() will generate
+ @verbatim
+ @endverbatim
+ void SetText( const char* inText );
+ /// Convenience method for setting text inside and element. See SetText() for important limitations.
+ void SetText( int value );
+ void SetText( unsigned value );
+ void SetText( bool value );
+ void SetText( double value );
+ void SetText( float value );
+ Convenience method to query the value of a child text node. This is probably best
+ shown by example. Given you have a document is this form:
+ @verbatim
+ <point>
+ <x>1</x>
+ <y>1.4</y>
+ </point>
+ @endverbatim
+ The QueryIntText() and similar functions provide a safe and easier way to get to the
+ "value" of x and y.
+ @verbatim
+ int x = 0;
+ float y = 0; // types of x and y are contrived for example
+ const XMLElement* xElement = pointElement->FirstChildElement( "x" );
+ const XMLElement* yElement = pointElement->FirstChildElement( "y" );
+ xElement->QueryIntText( &x );
+ yElement->QueryFloatText( &y );
+ @endverbatim
+ @returns XML_SUCCESS (0) on success, XML_CAN_NOT_CONVERT_TEXT if the text cannot be converted
+ to the requested type, and XML_NO_TEXT_NODE if there is no child text to query.
+ XMLError QueryIntText( int* ival ) const;
+ /// See QueryIntText()
+ XMLError QueryUnsignedText( unsigned* uval ) const;
+ XMLError QueryBoolText( bool* bval ) const;
+ XMLError QueryDoubleText( double* dval ) const;
+ XMLError QueryFloatText( float* fval ) const;
+ // internal:
+ enum {
+ OPEN, // <foo>
+ CLOSED, // <foo/>
+ CLOSING // </foo>
+ int ClosingType() const {
+ return _closingType;
+ char* ParseDeep( char* p, StrPair* endTag );
+private:
+ XMLElement( XMLDocument* doc );
+ virtual ~XMLElement();
+ XMLElement( const XMLElement& ); // not supported
+ void operator=( const XMLElement& ); // not supported
+ XMLAttribute* FindAttribute( const char* name );
+ XMLAttribute* FindOrCreateAttribute( const char* name );
+ //void LinkAttribute( XMLAttribute* attrib );
+ char* ParseAttributes( char* p );
+ static void DeleteAttribute( XMLAttribute* attribute );
+ int _closingType;
+ // The attribute list is ordered; there is no 'lastAttribute'
+ // because the list needs to be scanned for dupes before adding
+ // a new attribute.
+ XMLAttribute* _rootAttribute;
+enum Whitespace {
+ PRESERVE_WHITESPACE,
+/** A Document binds together all the functionality.
+ It can be saved, loaded, and printed to the screen.
+ All Nodes are connected and allocated to a Document.
+ If the Document is deleted, all its Nodes are also deleted.
+class TINYXML2_LIB XMLDocument : public XMLNode
+public:
+ /// constructor
+ XMLDocument( bool processEntities = true, Whitespace = PRESERVE_WHITESPACE );
+ ~XMLDocument();
+ return this;
+ return this;
+ Parse an XML file from a character string.
+ Returns XML_NO_ERROR (0) on success, or
+ an errorID.
+ You may optionally pass in the 'nBytes', which is
+ the number of bytes which will be parsed. If not
+ specified, TinyXML-2 will assume 'xml' points to a
+ null terminated string.
+ XMLError Parse( const char* xml, size_t nBytes=(size_t)(-1) );
+ Load an XML file from disk.
+ an errorID.
+ XMLError LoadFile( const char* filename );
+ Load an XML file from disk. You are responsible
+ for providing and closing the FILE*.
+ an errorID.
+ XMLError LoadFile( FILE* );
+ Save the XML file to disk.
+ an errorID.
+ XMLError SaveFile( const char* filename, bool compact = false );
+ Save the XML file to disk. You are responsible
+ an errorID.
+ XMLError SaveFile( FILE* fp, bool compact = false );
+ bool ProcessEntities() const {
+ return _processEntities;
+ Whitespace WhitespaceMode() const {
+ return _whitespace;
+ Returns true if this document has a leading Byte Order Mark of UTF8.
+ bool HasBOM() const {
+ return _writeBOM;
+ /** Sets whether to write the BOM when writing the file.
+ void SetBOM( bool useBOM ) {
+ _writeBOM = useBOM;
+ /** Return the root element of DOM. Equivalent to FirstChildElement().
+ To get the first node, use FirstChild().
+ XMLElement* RootElement() {
+ return FirstChildElement();
+ const XMLElement* RootElement() const {
+ /** Print the Document. If the Printer is not provided, it will
+ print to stdout. If you provide Printer, this can print to a file:
+ @verbatim
+ XMLPrinter printer( fp );
+ doc.Print( &printer );
+ @endverbatim
+ Or you can use a printer to print to memory:
+ @verbatim
+ // printer.CStr() has a const char* to the XML
+ @endverbatim
+ void Print( XMLPrinter* streamer=0 ) const;
+ Create a new Element associated with
+ this Document. The memory for the Element
+ is managed by the Document.
+ XMLElement* NewElement( const char* name );
+ Create a new Comment associated with
+ this Document. The memory for the Comment
+ XMLComment* NewComment( const char* comment );
+ Create a new Text associated with
+ this Document. The memory for the Text
+ XMLText* NewText( const char* text );
+ Create a new Declaration associated with
+ this Document. The memory for the object
+ If the 'text' param is null, the standard
+ declaration is used.:
+ @verbatim
+ <?xml version="1.0" encoding="UTF-8"?>
+ @endverbatim
+ XMLDeclaration* NewDeclaration( const char* text=0 );
+ Create a new Unknown associated with
+ XMLUnknown* NewUnknown( const char* text );
+ Delete a node associated with this document.
+ It will be unlinked from the DOM.
+ void DeleteNode( XMLNode* node ) {
+ node->_parent->DeleteChild( node );
+ void SetError( XMLError error, const char* str1, const char* str2 );
+ /// Return true if there was an error parsing the document.
+ bool Error() const {
+ return _errorID != XML_NO_ERROR;
+ /// Return the errorID.
+ XMLError ErrorID() const {
+ return _errorID;
+ const char* ErrorName() const;
+ /// Return a possibly helpful diagnostic location or string.
+ const char* GetErrorStr1() const {
+ return _errorStr1;
+ /// Return a possibly helpful secondary diagnostic location or string.
+ const char* GetErrorStr2() const {
+ return _errorStr2;
+ /// If there is an error, print it to stdout.
+ void PrintError() const;
+ /// Clear the document, resetting it to the initial state.
+ void Clear();
+ // internal
+ char* Identify( char* p, XMLNode** node );
+ virtual XMLNode* ShallowClone( XMLDocument* /*document*/ ) const {
+ return 0;
+ virtual bool ShallowEqual( const XMLNode* /*compare*/ ) const {
+ return false;
+private:
+ XMLDocument( const XMLDocument& ); // not supported
+ void operator=( const XMLDocument& ); // not supported
+ bool _writeBOM;
+ bool _processEntities;
+ XMLError _errorID;
+ Whitespace _whitespace;
+ const char* _errorStr1;
+ const char* _errorStr2;
+ char* _charBuffer;
+ MemPoolT< sizeof(XMLElement) > _elementPool;
+ MemPoolT< sizeof(XMLAttribute) > _attributePool;
+ MemPoolT< sizeof(XMLText) > _textPool;
+ MemPoolT< sizeof(XMLComment) > _commentPool;
+ static const char* _errorNames[XML_ERROR_COUNT];
+ A XMLHandle is a class that wraps a node pointer with null checks; this is
+ an incredibly useful thing. Note that XMLHandle is not part of the TinyXML-2
+ DOM structure. It is a separate utility class.
+ Take an example:
+ @verbatim
+ <Document>
+ <Element attributeA = "valueA">
+ <Child attributeB = "value1" />
+ <Child attributeB = "value2" />
+ </Element>
+ </Document>
+ @endverbatim
+ Assuming you want the value of "attributeB" in the 2nd "Child" element, it's very
+ easy to write a *lot* of code that looks like:
+ @verbatim
+ XMLElement* root = document.FirstChildElement( "Document" );
+ if ( root )
+ XMLElement* element = root->FirstChildElement( "Element" );
+ if ( element )
+ XMLElement* child = element->FirstChildElement( "Child" );
+ if ( child )
+ XMLElement* child2 = child->NextSiblingElement( "Child" );
+ if ( child2 )
+ // Finally do something useful.
+ @endverbatim
+ And that doesn't even cover "else" cases. XMLHandle addresses the verbosity
+ of such code. A XMLHandle checks for null pointers so it is perfectly safe
+ and correct to use:
+ @verbatim
+ XMLHandle docHandle( &document );
+ XMLElement* child2 = docHandle.FirstChild( "Document" ).FirstChild( "Element" ).FirstChild().NextSibling().ToElement();
+ if ( child2 )
+ // do something useful
+ @endverbatim
+ Which is MUCH more concise and useful.
+ It is also safe to copy handles - internally they are nothing more than node pointers.
+ @verbatim
+ XMLHandle handleCopy = handle;
+ @endverbatim
+ See also XMLConstHandle, which is the same as XMLHandle, but operates on const objects.
+class TINYXML2_LIB XMLHandle
+public:
+ /// Create a handle from any node (at any depth of the tree.) This can be a null pointer.
+ XMLHandle( XMLNode* node ) {
+ _node = node;
+ /// Create a handle from a node.
+ XMLHandle( XMLNode& node ) {
+ _node = &node;
+ /// Copy constructor
+ XMLHandle( const XMLHandle& ref ) {
+ _node = ref._node;
+ /// Assignment
+ XMLHandle& operator=( const XMLHandle& ref ) {
+ return *this;
+ /// Get the first child of this handle.
+ XMLHandle FirstChild() {
+ return XMLHandle( _node ? _node->FirstChild() : 0 );
+ /// Get the first child element of this handle.
+ XMLHandle FirstChildElement( const char* value=0 ) {
+ return XMLHandle( _node ? _node->FirstChildElement( value ) : 0 );
+ /// Get the last child of this handle.
+ XMLHandle LastChild() {
+ return XMLHandle( _node ? _node->LastChild() : 0 );
+ /// Get the last child element of this handle.
+ XMLHandle LastChildElement( const char* _value=0 ) {
+ return XMLHandle( _node ? _node->LastChildElement( _value ) : 0 );
+ /// Get the previous sibling of this handle.
+ XMLHandle PreviousSibling() {
+ return XMLHandle( _node ? _node->PreviousSibling() : 0 );
+ /// Get the previous sibling element of this handle.
+ XMLHandle PreviousSiblingElement( const char* _value=0 ) {
+ return XMLHandle( _node ? _node->PreviousSiblingElement( _value ) : 0 );
+ /// Get the next sibling of this handle.
+ XMLHandle NextSibling() {
+ return XMLHandle( _node ? _node->NextSibling() : 0 );
+ /// Get the next sibling element of this handle.
+ XMLHandle NextSiblingElement( const char* _value=0 ) {
+ return XMLHandle( _node ? _node->NextSiblingElement( _value ) : 0 );
+ /// Safe cast to XMLNode. This can return null.
+ XMLNode* ToNode() {
+ return _node;
+ /// Safe cast to XMLElement. This can return null.
+ XMLElement* ToElement() {
+ return ( ( _node == 0 ) ? 0 : _node->ToElement() );
+ /// Safe cast to XMLText. This can return null.
+ XMLText* ToText() {
+ return ( ( _node == 0 ) ? 0 : _node->ToText() );
+ /// Safe cast to XMLUnknown. This can return null.
+ XMLUnknown* ToUnknown() {
+ return ( ( _node == 0 ) ? 0 : _node->ToUnknown() );
+ /// Safe cast to XMLDeclaration. This can return null.
+ XMLDeclaration* ToDeclaration() {
+ return ( ( _node == 0 ) ? 0 : _node->ToDeclaration() );
+private:
+ XMLNode* _node;
+ A variant of the XMLHandle class for working with const XMLNodes and Documents. It is the
+ same in all regards, except for the 'const' qualifiers. See XMLHandle for API.
+class TINYXML2_LIB XMLConstHandle
+public:
+ XMLConstHandle( const XMLNode* node ) {
+ _node = node;
+ XMLConstHandle( const XMLNode& node ) {
+ _node = &node;
+ XMLConstHandle( const XMLConstHandle& ref ) {
+ XMLConstHandle& operator=( const XMLConstHandle& ref ) {
+ return *this;
+ const XMLConstHandle FirstChild() const {
+ return XMLConstHandle( _node ? _node->FirstChild() : 0 );
+ const XMLConstHandle FirstChildElement( const char* value=0 ) const {
+ return XMLConstHandle( _node ? _node->FirstChildElement( value ) : 0 );
+ const XMLConstHandle LastChild() const {
+ return XMLConstHandle( _node ? _node->LastChild() : 0 );
+ const XMLConstHandle LastChildElement( const char* _value=0 ) const {
+ return XMLConstHandle( _node ? _node->LastChildElement( _value ) : 0 );
+ const XMLConstHandle PreviousSibling() const {
+ return XMLConstHandle( _node ? _node->PreviousSibling() : 0 );
+ const XMLConstHandle PreviousSiblingElement( const char* _value=0 ) const {
+ return XMLConstHandle( _node ? _node->PreviousSiblingElement( _value ) : 0 );
+ const XMLConstHandle NextSibling() const {
+ return XMLConstHandle( _node ? _node->NextSibling() : 0 );
+ const XMLConstHandle NextSiblingElement( const char* _value=0 ) const {
+ return XMLConstHandle( _node ? _node->NextSiblingElement( _value ) : 0 );
+ const XMLNode* ToNode() const {
+ return _node;
+ const XMLElement* ToElement() const {
+ const XMLText* ToText() const {
+ const XMLUnknown* ToUnknown() const {
+ const XMLDeclaration* ToDeclaration() const {
+private:
+ const XMLNode* _node;
+ Printing functionality. The XMLPrinter gives you more
+ options than the XMLDocument::Print() method.
+ It can:
+ -# Print to memory.
+ -# Print to a file you provide.
+ -# Print XML without a XMLDocument.
+ Print to Memory
+ @verbatim
+ SomeFunction( printer.CStr() );
+ @endverbatim
+ Print to a File
+ You provide the file pointer.
+ @verbatim
+ @endverbatim
+ Print without a XMLDocument
+ When loading, an XML parser is very useful. However, sometimes
+ when saving, it just gets in the way. The code is often set up
+ for streaming, and constructing the DOM is just overhead.
+ The Printer supports the streaming case. The following code
+ prints out a trivially simple XML file without ever creating
+ an XML document.
+ @verbatim
+ printer.OpenElement( "foo" );
+ printer.PushAttribute( "foo", "bar" );
+ printer.CloseElement();
+ @endverbatim
+class TINYXML2_LIB XMLPrinter : public XMLVisitor
+public:
+ /** Construct the printer. If the FILE* is specified,
+ this will print to the FILE. Else it will print
+ to memory, and the result is available in CStr().
+ If 'compact' is set to true, then output is created
+ with only required whitespace and newlines.
+ XMLPrinter( FILE* file=0, bool compact = false, int depth = 0 );
+ virtual ~XMLPrinter() {}
+ /** If streaming, write the BOM and declaration. */
+ void PushHeader( bool writeBOM, bool writeDeclaration );
+ /** If streaming, start writing an element.
+ The element must be closed with CloseElement()
+ void OpenElement( const char* name, bool compactMode=false );
+ /// If streaming, add an attribute to an open element.
+ void PushAttribute( const char* name, const char* value );
+ void PushAttribute( const char* name, int value );
+ void PushAttribute( const char* name, unsigned value );
+ void PushAttribute( const char* name, bool value );
+ void PushAttribute( const char* name, double value );
+ /// If streaming, close the Element.
+ virtual void CloseElement( bool compactMode=false );
+ /// Add a text node.
+ void PushText( const char* text, bool cdata=false );
+ /// Add a text node from an integer.
+ void PushText( int value );
+ /// Add a text node from an unsigned.
+ void PushText( unsigned value );
+ /// Add a text node from a bool.
+ void PushText( bool value );
+ /// Add a text node from a float.
+ void PushText( float value );
+ /// Add a text node from a double.
+ void PushText( double value );
+ /// Add a comment
+ void PushComment( const char* comment );
+ void PushDeclaration( const char* value );
+ void PushUnknown( const char* value );
+ virtual bool VisitEnter( const XMLDocument& /*doc*/ );
+ return true;
+ virtual bool VisitEnter( const XMLElement& element, const XMLAttribute* attribute );
+ virtual bool VisitExit( const XMLElement& element );
+ virtual bool Visit( const XMLText& text );
+ virtual bool Visit( const XMLComment& comment );
+ virtual bool Visit( const XMLDeclaration& declaration );
+ virtual bool Visit( const XMLUnknown& unknown );
+ If in print to memory mode, return a pointer to
+ the XML file in memory.
+ const char* CStr() const {
+ return _buffer.Mem();
+ If in print to memory mode, return the size
+ of the XML file in memory. (Note the size returned
+ includes the terminating null.)
+ int CStrSize() const {
+ return _buffer.Size();
+ If in print to memory mode, reset the buffer to the
+ beginning.
+ void ClearBuffer() {
+ _buffer.Clear();
+ _buffer.Push(0);
+protected:
+ virtual bool CompactMode( const XMLElement& ) { return _compactMode; }
+ /** Prints out the space before an element. You may override to change
+ the space and tabs used. A PrintSpace() override should call Print().
+ virtual void PrintSpace( int depth );
+ void Print( const char* format, ... );
+ void SealElement();
+ bool _elementJustOpened;
+ DynArray< const char*, 10 > _stack;
+private:
+ void PrintString( const char*, bool restrictedEntitySet ); // prints out, after detecting entities.
+ bool _firstElement;
+ FILE* _fp;
+ int _depth;
+ int _textDepth;
+ bool _compactMode;
+ enum {
+ ENTITY_RANGE = 64,
+ BUF_SIZE = 200
+ bool _entityFlag[ENTITY_RANGE];
+ bool _restrictedEntityFlag[ENTITY_RANGE];
+ DynArray< char, 20 > _buffer;
+} // tinyxml2
+# pragma warning(pop)
+#endif
+#endif // TINYXML2_INCLUDED
Summary of changes:
tests/xmltester/Makefile.am | 8 +-
tests/xmltester/XMLTester.cpp | 69 +-
tests/xmltester/XMLTester.h | 12 +-
tests/xmltester/tinyxml2/README | 1 +
tests/xmltester/tinyxml2/tinyxml2.cpp | 2244 +++++++++++++++++++++++++++++++++
tests/xmltester/tinyxml2/tinyxml2.h | 2082 ++++++++++++++++++++++++++++++
6 files changed, 4374 insertions(+), 42 deletions(-)
create mode 100644 tests/xmltester/tinyxml2/README
create mode 100755 tests/xmltester/tinyxml2/tinyxml2.cpp
create mode 100755 tests/xmltester/tinyxml2/tinyxml2.h
hooks/post-receive
More information about the geos-commits
