[geos-commits] [SCM] GEOS branch master updated. 9c4f95f9f38788cab222c1037972ea4cb660a923
git at osgeo.org
git at osgeo.org
Fri Nov 16 14:29:28 PST 2018
the project "GEOS".
via 9c4f95f9f38788cab222c1037972ea4cb660a923 (commit)
from aefa49cbc3d096b98333332c12faff26f6fae02e (commit)
revisions in full, below.
commit 9c4f95f9f38788cab222c1037972ea4cb660a923
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Fri Nov 16 14:29:16 2018 -0800
Formatting changes to please make check (hm)
diff --git a/include/geos/operation/overlay/OverlayOp.h b/include/geos/operation/overlay/OverlayOp.h
index 0ed54cf..9352344 100644
--- a/include/geos/operation/overlay/OverlayOp.h
+++ b/include/geos/operation/overlay/OverlayOp.h
@@ -329,27 +329,27 @@ private:
bool isCovered(const geom::Coordinate& coord,
std::vector<geom::LineString*> *geomList);
- * For empty result, what is the correct geometry type to apply to
+ * For empty result, what is the correct geometry type to apply to
* the empty?
- geom::Dimension::DimensionType resultDimension(OverlayOp::OpCode overlayOpCode,
+ geom::Dimension::DimensionType resultDimension(OverlayOp::OpCode overlayOpCode,
const geom::Geometry *g0, const geom::Geometry *g1);
* Creates an empty result geometry of the appropriate dimension,
* based on the given overlay operation and the dimensions of the inputs.
- * The created geometry is always an atomic geometry,
+ * The created geometry is always an atomic geometry,
* not a collection.
* The empty result is constructed using the following rules:
* * #opINTERSECTION result has the dimension of the lowest input dimension
* * #opUNION - result has the dimension of the highest input dimension
* * #opDIFFERENCE - result has the dimension of the left-hand input
* * #opSYMDIFFERENCE - result has the dimension of the highest input dimension
geom::Geometry* createEmptyResult(
- OverlayOp::OpCode overlayOpCode, const geom::Geometry *a,
+ OverlayOp::OpCode overlayOpCode, const geom::Geometry *a,
const geom::Geometry *b, const geom::GeometryFactory *geomFact);
diff --git a/src/operation/overlay/OverlayOp.cpp b/src/operation/overlay/OverlayOp.cpp
index 11a858a..56ed803 100644
--- a/src/operation/overlay/OverlayOp.cpp
+++ b/src/operation/overlay/OverlayOp.cpp
@@ -640,25 +640,25 @@ OverlayOp::isCovered(const Coordinate& coord,vector<Polygon*> *geomList)
-OverlayOp::resultDimension(OverlayOp::OpCode overlayOpCode,
+OverlayOp::resultDimension(OverlayOp::OpCode overlayOpCode,
const Geometry *g0, const Geometry *g1)
Dimension::DimensionType dim0 = g0->getDimension();
Dimension::DimensionType dim1 = g1->getDimension();
Dimension::DimensionType resultDimension = Dimension::False;
- switch (overlayOpCode)
+ switch (overlayOpCode)
- case OverlayOp::opINTERSECTION:
+ case OverlayOp::opINTERSECTION:
resultDimension = min(dim0, dim1);
break;
- case OverlayOp::opUNION:
+ case OverlayOp::opUNION:
resultDimension = max(dim0, dim1);
break;
- case OverlayOp::opDIFFERENCE:
+ case OverlayOp::opDIFFERENCE:
resultDimension = dim0;
break;
- case OverlayOp::opSYMDIFFERENCE:
+ case OverlayOp::opSYMDIFFERENCE:
break;
@@ -666,12 +666,12 @@ OverlayOp::resultDimension(OverlayOp::OpCode overlayOpCode,
geom::Geometry*
-OverlayOp::createEmptyResult(OverlayOp::OpCode overlayOpCode,
- const geom::Geometry *a, const geom::Geometry *b,
+OverlayOp::createEmptyResult(OverlayOp::OpCode overlayOpCode,
+ const geom::Geometry *a, const geom::Geometry *b,
const GeometryFactory *geomFact)
geom::Geometry *result = nullptr;
- switch (resultDimension(overlayOpCode, a, b))
+ switch (resultDimension(overlayOpCode, a, b))
case Dimension::P:
result = geomFact->createPoint();
@@ -719,7 +719,7 @@ OverlayOp::computeGeometry(vector<Point*> *nResultPointList,
if (geomList->empty())
- return createEmptyResult(opCode, arg[0]->getGeometry(),
+ return createEmptyResult(opCode, arg[0]->getGeometry(),
arg[1]->getGeometry(), geomFact);
// build the most specific geometry possible
Summary of changes:
include/geos/operation/overlay/OverlayOp.h | 12 ++++++------
src/operation/overlay/OverlayOp.cpp | 20 ++++++++++----------
2 files changed, 16 insertions(+), 16 deletions(-)
hooks/post-receive
More information about the geos-commits
