[geos-commits] [SCM] GEOS branch master updated. 81ff4c0359100dcdb8c89109e65f0c265b451ca6
git at osgeo.org
git at osgeo.org
Mon Nov 19 17:51:03 PST 2018
the project "GEOS".
via 81ff4c0359100dcdb8c89109e65f0c265b451ca6 (commit)
via 9b5462970c21c26df93aea83cb0181675b9663cd (commit)
from 7dd3d0b243b30c69e4ac425bb76fa9dd731389e0 (commit)
revisions in full, below.
commit 81ff4c0359100dcdb8c89109e65f0c265b451ca6
Author: Raul Marin <rmrodriguez at cartodb.com>
Date: Fri Sep 28 19:48:31 2018 +0200
GeometryFactory: Refactor buildGeometry to use int ids
diff --git a/src/geom/GeometryFactory.cpp b/src/geom/GeometryFactory.cpp
index 2832ae8..3d88631 100644
--- a/src/geom/GeometryFactory.cpp
+++ b/src/geom/GeometryFactory.cpp
@@ -653,55 +653,46 @@ GeometryFactory::createLineString(const CoordinateSequence &fromCoords)
Geometry*
GeometryFactory::buildGeometry(vector<Geometry *> *newGeoms) const
- string geomClass;
+ if (!newGeoms->size())
+ // we do not need the vector anymore
+ delete newGeoms;
+ return createGeometryCollection();
bool isHeterogeneous=false;
bool hasGeometryCollection=false;
+ GeometryTypeId type = (*newGeoms)[0]->getGeometryTypeId();
- for (size_t i=0, n=newGeoms->size(); i<n; ++i)
+ for (Geometry* gp : *newGeoms)
- Geometry* geom = (*newGeoms)[i];
- string partClass(typeid(*geom).name());
- if (geomClass.empty())
- geomClass=partClass;
- else if (geomClass!=partClass)
+ GeometryTypeId geometryType = gp->getGeometryTypeId();
+ if (type != geometryType)
- isHeterogeneous = true;
+ isHeterogeneous=true;
- if ( dynamic_cast<GeometryCollection*>(geom) )
+ if (geometryType == GEOS_GEOMETRYCOLLECTION)
hasGeometryCollection=true;
- // for the empty geometry, return an empty GeometryCollection
- // we do not need the vector anymore
- delete newGeoms;
- return createGeometryCollection();
if (isHeterogeneous || hasGeometryCollection)
return createGeometryCollection(newGeoms);
// At this point we know the collection is not hetereogenous.
- // Determine the type of the result from the first Geometry in the
- // list. This should always return a geometry, since otherwise
- // an empty collection would have already been returned
- Geometry *geom0=(*newGeoms)[0];
bool isCollection=newGeoms->size()>1;
if (isCollection)
- if (typeid(*geom0)==typeid(Polygon)) {
+ if (type == GEOS_POLYGON) {
return createMultiPolygon(newGeoms);
- } else if (typeid(*geom0)==typeid(LineString)) {
+ } else if (type == GEOS_LINESTRING) {
return createMultiLineString(newGeoms);
- } else if (typeid(*geom0)==typeid(LinearRing)) {
+ } else if (type == GEOS_LINEARRING) {
- } else if (typeid(*geom0)==typeid(Point)) {
+ } else if (type == GEOS_POINT) {
return createMultiPoint(newGeoms);
} else {
@@ -709,6 +700,7 @@ GeometryFactory::buildGeometry(vector<Geometry *> *newGeoms) const
// since this is not a collection we can delete vector
+ Geometry *geom0=(*newGeoms)[0];
delete newGeoms;
return geom0;
@@ -717,48 +709,44 @@ GeometryFactory::buildGeometry(vector<Geometry *> *newGeoms) const
Geometry*
GeometryFactory::buildGeometry(const vector<Geometry *> &fromGeoms) const
- string geomClass;
+ size_t geomsSize = fromGeoms.size();
+ if (geomsSize == 0)
+ if (geomsSize == 1)
+ return fromGeoms[0]->clone();
- bool isCollection=fromGeoms.size()>1;
- size_t i;
- for (i=0; i<fromGeoms.size(); i++) {
- Geometry *geom = fromGeoms[i];
- if (geomClass.empty()) {
- } else if (geomClass!=partClass) {
+ GeometryTypeId type = fromGeoms[0]->getGeometryTypeId();
+ for (const Geometry *gp : fromGeoms)
- if (isHeterogeneous) {
+ if (isHeterogeneous)
return createGeometryCollection(fromGeoms);
- // At this point we know the collection is not hetereogenous.
- Geometry *geom0=fromGeoms[0];
- if (isCollection) {
- return createMultiPolygon(fromGeoms);
- return createMultiLineString(fromGeoms);
- return createMultiPoint(fromGeoms);
- assert(0); // buildGeomtry encountered an unkwnon geometry type
+ return createMultiPolygon(fromGeoms);
+ return createMultiLineString(fromGeoms);
+ return createMultiPoint(fromGeoms);
- return geom0->clone();
+ assert(0); // buildGeomtry encountered an unkwnon geometry type
/*public*/
commit 9b5462970c21c26df93aea83cb0181675b9663cd
Date: Thu Sep 27 17:05:02 2018 +0200
Address memory warnings in buildGeometry
Suite: buildarea
Test: buildarea1 ...Uninitialized bytes in __interceptor_memcmp at offset 0 inside [0x7fffae24fa80, 4)
==19345==WARNING: MemorySanitizer: use-of-uninitialized-value
#0 0x7f5ed6768c5f in std::char_traits<char>::compare(char const*, char const*, unsigned long) /build/gcc/src/gcc-build/x86_64-pc-linux-gnu/libstdc++-v3/include/bits/char_traits.h:310:25
#1 0x7f5ed6768c5f in std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >::compare(char const*) const /build/gcc/src/gcc-build/x86_64-pc-linux-gnu/libstdc++-v3/include/bits/basic_string.tcc:1424:37
#2 0x7f5ed6892f40 in bool std::operator==<char, std::char_traits<char>, std::allocator<char> >(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, char const*) /usr/include/c++/8.2.1/bits/basic_string.h:6075:35
#3 0x7f5ed6892f40 in geos::geom::GeometryFactory::buildGeometry(std::vector<geos::geom::Geometry*, std::allocator<geos::geom::Geometry*> >*) const /usr/src/debug/geos/src/geom/GeometryFactory.cpp:664:16
#4 0x7f5ed690dd48 in geos::operation::overlay::OverlayOp::computeOverlay(geos::operation::overlay::OverlayOp::OpCode) /usr/src/debug/geos/src/operation/overlay/OverlayOp.cpp:839:28
#5 0x7f5ed690dee1 in geos::operation::overlay::OverlayOp::getResultGeometry(geos::operation::overlay::OverlayOp::OpCode) /usr/src/debug/geos/src/operation/overlay/OverlayOp.cpp:187:16
#6 0x7f5ed690e281 in geos::operation::overlay::OverlayOp::overlayOp(geos::geom::Geometry const*, geos::geom::Geometry const*, geos::operation::overlay::OverlayOp::OpCode) /usr/src/debug/geos/src/operation/overlay/OverlayOp.cpp:93:30
#7 0x7f5ed688d11f in geos::operation::overlay::overlayOp::operator()(geos::geom::Geometry const*, geos::geom::Geometry const*) /usr/src/debug/geos/src/geom/../../include/geos/operation/overlay/OverlayOp.h:388:44
#8 0x7f5ed688d11f in std::unique_ptr<geos::geom::Geometry, std::default_delete<geos::geom::Geometry> > geos::geom::BinaryOp<geos::operation::overlay::overlayOp>(geos::geom::Geometry const*, geos::geom::Geometry const*, geos::operation::overlay::overlayOp) /usr/src/debug/geos/src/geom/../../include/geos/geom/BinaryOp.h:357:3
#9 0x7f5ed688b16f in geos::geom::Geometry::Union(geos::geom::Geometry const*) const /usr/src/debug/geos/src/geom/Geometry.cpp:586:17
#10 0x7f5ed691885d in geos::operation::geounion::CascadedPolygonUnion::unionActual(geos::geom::Geometry*, geos::geom::Geometry*) /usr/src/debug/geos/src/operation/union/CascadedPolygonUnion.cpp:370:36
#11 0x7f5ed6919080 in geos::operation::geounion::CascadedPolygonUnion::unionOptimized(geos::geom::Geometry*, geos::geom::Geometry*) /usr/src/debug/geos/src/operation/union/CascadedPolygonUnion.cpp:236:27
#12 0x7f5ed6919252 in geos::operation::geounion::CascadedPolygonUnion::unionTree(geos::index::strtree::ItemsList*) /usr/src/debug/geos/src/operation/union/CascadedPolygonUnion.cpp:162:23
#13 0x7f5ed6919630 in geos::operation::geounion::CascadedPolygonUnion::Union() /usr/src/debug/geos/src/operation/union/CascadedPolygonUnion.cpp:151:21
#14 0x7f5ed691983d in geos::operation::geounion::CascadedPolygonUnion::Union(geos::geom::MultiPolygon const*) /usr/src/debug/geos/src/operation/union/CascadedPolygonUnion.cpp:124:20
#15 0x7f5ed71db6a8 in GEOSUnionCascaded_r /usr/src/debug/geos/capi/geos_ts_c.cpp:2497:43
#16 0x7f5ed7332ed6 in LWGEOM_GEOS_buildArea /home/raul/dev/public/postgis/liblwgeom/lwgeom_geos.c:1124:8
#17 0x7f5ed7333164 in lwgeom_buildarea /home/raul/dev/public/postgis/liblwgeom/lwgeom_geos.c:1155:7
#18 0x55b755e00bfa in buildarea1 /un/dev_public/postgis/liblwgeom/cunit/cu_buildarea.c:66:9
#19 0x7f5ed6fb1117 (/usr/lib/libcunit.so.1+0x4117)
#20 0x7f5ed6fb13b1 (/usr/lib/libcunit.so.1+0x43b1)
#21 0x7f5ed6fb17b6 in CU_run_all_tests (/usr/lib/libcunit.so.1+0x47b6)
#22 0x55b755e7f6b7 in main /un/dev_public/postgis/liblwgeom/cunit/cu_tester.c:177:13
#23 0x7f5ed6c3c222 in __libc_start_main (/usr/lib/libc.so.6+0x24222)
#24 0x55b755d7f0bd in _start (/un/dev_public/postgis/liblwgeom/cunit/.libs/lt-cu_tester+0x250bd)
SUMMARY: MemorySanitizer: use-of-uninitialized-value /build/gcc/src/gcc-build/x86_64-pc-linux-gnu/libstdc++-v3/include/bits/char_traits.h:310:25 in std::char_traits<char>::compare(char const*, char const*, unsigned long)
index 896b457..2832ae8 100644
@@ -653,7 +653,7 @@ GeometryFactory::createLineString(const CoordinateSequence &fromCoords)
Geometry*
- string geomClass("NULL");
+ string geomClass;
@@ -661,7 +661,7 @@ GeometryFactory::buildGeometry(vector<Geometry *> *newGeoms) const
- if (geomClass=="NULL")
+ if (geomClass.empty())
@@ -676,7 +676,7 @@ GeometryFactory::buildGeometry(vector<Geometry *> *newGeoms) const
delete newGeoms;
@@ -717,7 +717,7 @@ GeometryFactory::buildGeometry(vector<Geometry *> *newGeoms) const
Geometry*
+ string geomClass;
size_t i;
@@ -725,7 +725,7 @@ GeometryFactory::buildGeometry(const vector<Geometry *> &fromGeoms) const
- if (geomClass=="NULL") {
+ if (geomClass.empty()) {
@@ -733,7 +733,7 @@ GeometryFactory::buildGeometry(const vector<Geometry *> &fromGeoms) const
Summary of changes:
src/geom/GeometryFactory.cpp | 108 +++++++++++++++++++------------------------
1 file changed, 48 insertions(+), 60 deletions(-)
hooks/post-receive
More information about the geos-commits
