[geos-commits] [SCM] GEOS branch master updated. 2ff10b8e4536e8fb430d2de9e80f5b2075a4ed8e
git at osgeo.org
git at osgeo.org
Thu Nov 29 11:40:20 PST 2018
the project "GEOS".
via 2ff10b8e4536e8fb430d2de9e80f5b2075a4ed8e (commit)
via 8476094fcbfc787d4e5541c5b3bde9a72edfb990 (commit)
from 893eaca5c492856535f7a0619f426cd868bb1aca (commit)
revisions in full, below.
commit 2ff10b8e4536e8fb430d2de9e80f5b2075a4ed8e
Merge: 8476094 893eaca
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Thu Nov 29 11:40:11 2018 -0800
Merge branch 'master' of https://git.osgeo.org/gogs/geos/geos
commit 8476094fcbfc787d4e5541c5b3bde9a72edfb990
Date: Thu Nov 29 11:39:41 2018 -0800
Reorder XML tests in CMakeFile to sort order
and add in tests to harmonize with autotools
diff --git a/tests/xmltester/CMakeLists.txt b/tests/xmltester/CMakeLists.txt
index d60ac34..d68189f 100644
--- a/tests/xmltester/CMakeLists.txt
+++ b/tests/xmltester/CMakeLists.txt
@@ -46,66 +46,98 @@ if(GEOS_ENABLE_TESTS)
set(XMLTESTS_DIR ${CMAKE_CURRENT_SOURCE_DIR}/tests)
set(SAVE_XMLTESTS
- ${XMLTESTS_DIR}/testLeaksBig.xml
- ${XMLTESTS_DIR}/split.xml
+ ${XMLTESTS_DIR}/TestBufferExternal.xml
+ ${XMLTESTS_DIR}/TestBufferExternal2.xml
+ ${XMLTESTS_DIR}/TestIsValid.xml
+ ${XMLTESTS_DIR}/badguy3.xml
+ ${XMLTESTS_DIR}/buffer.xml
+ ${XMLTESTS_DIR}/fme.xml
+ ${XMLTESTS_DIR}/heisenbugs.xml
${XMLTESTS_DIR}/hexwkb.xml
- ${XMLTESTS_DIR}/test.xml
+ ${XMLTESTS_DIR}/hole_from_shell.xml
+ ${XMLTESTS_DIR}/hole_red.xml
${XMLTESTS_DIR}/linemerge.xml
- ${XMLTESTS_DIR}/TestIsValid.xml
${XMLTESTS_DIR}/robustness.xml
- ${XMLTESTS_DIR}/buffer.xml
${XMLTESTS_DIR}/singlesidedbuffer.xml
- ${XMLTESTS_DIR}/ticket/bug176.xml
- ${XMLTESTS_DIR}/ticket/bug188.xml
- ${XMLTESTS_DIR}/ticket/bug244.xml
- ${XMLTESTS_DIR}/ticket/bug275.xml
+ ${XMLTESTS_DIR}/split.xml
+ ${XMLTESTS_DIR}/test.xml
+ ${XMLTESTS_DIR}/testLeaksBig.xml
${XMLTESTS_DIR}/general/TestBoundary.xml
${XMLTESTS_DIR}/general/TestBuffer.xml
${XMLTESTS_DIR}/general/TestBufferMitredJoin.xml
${XMLTESTS_DIR}/general/TestCentroid.xml
- ${XMLTESTS_DIR}/general/TestConvexHull.xml
${XMLTESTS_DIR}/general/TestConvexHull-big.xml
- ${XMLTESTS_DIR}/general/TestFunctionAAPrec.xml
+ ${XMLTESTS_DIR}/general/TestConvexHull.xml
+ ${XMLTESTS_DIR}/general/TestDistance.xml
${XMLTESTS_DIR}/general/TestFunctionAA.xml
- ${XMLTESTS_DIR}/general/TestFunctionLAPrec.xml
+ ${XMLTESTS_DIR}/general/TestFunctionAAPrec.xml
${XMLTESTS_DIR}/general/TestFunctionLA.xml
- ${XMLTESTS_DIR}/general/TestFunctionLLPrec.xml
+ ${XMLTESTS_DIR}/general/TestFunctionLAPrec.xml
${XMLTESTS_DIR}/general/TestFunctionLL.xml
+ ${XMLTESTS_DIR}/general/TestFunctionLLPrec.xml
${XMLTESTS_DIR}/general/TestFunctionPA.xml
- ${XMLTESTS_DIR}/general/TestFunctionPLPrec.xml
${XMLTESTS_DIR}/general/TestFunctionPL.xml
+ ${XMLTESTS_DIR}/general/TestFunctionPLPrec.xml
${XMLTESTS_DIR}/general/TestFunctionPP.xml
${XMLTESTS_DIR}/general/TestInteriorPoint.xml
+ ${XMLTESTS_DIR}/general/TestPreparedPointPredicate.xml
+ ${XMLTESTS_DIR}/general/TestPreparedPolygonPredicate.xml
+ ${XMLTESTS_DIR}/general/TestPreparedPredicatesWithGeometryCollection.xml
${XMLTESTS_DIR}/general/TestRectanglePredicate.xml
${XMLTESTS_DIR}/general/TestRelateAA.xml
- ${XMLTESTS_DIR}/general/TestRelateLA.xml
- ${XMLTESTS_DIR}/general/TestRelateLL.xml
- ${XMLTESTS_DIR}/general/TestRelatePL.xml
${XMLTESTS_DIR}/general/TestRelateAC.xml
+ ${XMLTESTS_DIR}/general/TestRelateLA.xml
${XMLTESTS_DIR}/general/TestRelateLC.xml
+ ${XMLTESTS_DIR}/general/TestRelateLL.xml
${XMLTESTS_DIR}/general/TestRelatePA.xml
+ ${XMLTESTS_DIR}/general/TestRelatePL.xml
${XMLTESTS_DIR}/general/TestRelatePP.xml
${XMLTESTS_DIR}/general/TestSimple.xml
+ ${XMLTESTS_DIR}/general/TestUnaryUnion.xml
+ ${XMLTESTS_DIR}/general/TestUnaryUnionFloating.xml
${XMLTESTS_DIR}/general/TestValid.xml
- ${XMLTESTS_DIR}/general/TestValid2.xml
${XMLTESTS_DIR}/general/TestValid2-big.xml
+ ${XMLTESTS_DIR}/general/TestValid2.xml
${XMLTESTS_DIR}/general/TestWithinDistance.xml
- ${XMLTESTS_DIR}/stmlf/stmlf-cases-20061020.xml
- ${XMLTESTS_DIR}/stmlf/stmlf-cases-20070119.xml
${XMLTESTS_DIR}/robust/TestRobustOverlayFixed.xml
${XMLTESTS_DIR}/robust/TestRobustRelate.xml
- ${XMLTESTS_DIR}/fme.xml
- ${XMLTESTS_DIR}/TestBufferExternal.xml
- ${XMLTESTS_DIR}/TestBufferExternal2.xml
- ${XMLTESTS_DIR}/heisenbugs.xml
- ${XMLTESTS_DIR}/badguy3.xml
- ${XMLTESTS_DIR}/hole_from_shell.xml
- ${XMLTESTS_DIR}/hole_red.xml
${XMLTESTS_DIR}/safe/16595.xml
- ${XMLTESTS_DIR}/safe/16596.xml)
+ ${XMLTESTS_DIR}/safe/16596.xml
+ ${XMLTESTS_DIR}/safe/TestBufferJagged.xml
+ ${XMLTESTS_DIR}/stmlf/stmlf-cases-20061020.xml
+ ${XMLTESTS_DIR}/stmlf/stmlf-cases-20070119.xml
+ ${XMLTESTS_DIR}/ticket/bug176.xml
+ ${XMLTESTS_DIR}/ticket/bug188.xml
+ ${XMLTESTS_DIR}/ticket/bug244.xml
+ ${XMLTESTS_DIR}/ticket/bug275.xml
+ ${XMLTESTS_DIR}/ticket/bug350.xml
+ ${XMLTESTS_DIR}/ticket/bug356.xml
+ ${XMLTESTS_DIR}/ticket/bug358.xml
+ ${XMLTESTS_DIR}/ticket/bug360.xml
+ ${XMLTESTS_DIR}/ticket/bug366.xml
+ ${XMLTESTS_DIR}/ticket/bug392.xml
+ ${XMLTESTS_DIR}/ticket/bug398.xml
+ ${XMLTESTS_DIR}/ticket/bug434.xml
+ ${XMLTESTS_DIR}/ticket/bug459.xml
+ ${XMLTESTS_DIR}/ticket/bug527.xml
+ ${XMLTESTS_DIR}/ticket/bug569.xml
+ ${XMLTESTS_DIR}/ticket/bug582.xml
+ ${XMLTESTS_DIR}/ticket/bug586.xml
+ ${XMLTESTS_DIR}/ticket/bug599.xml
+ ${XMLTESTS_DIR}/ticket/bug605.xml
+ ${XMLTESTS_DIR}/ticket/bug615.xml
+ ${XMLTESTS_DIR}/ticket/bug716.xml
+ ${XMLTESTS_DIR}/ticket/bug837.xml
+ set(FAILING_XMLTESTS
+ ${XMLTESTS_DIR}/ticket/bug488.xml
+ ${XMLTESTS_DIR}/ticket/bug344.xml
+ ${XMLTESTS_DIR}/TestBigNastyBuffer.xml
+ ${XMLTESTS_DIR}/failure/TestOverlay.xml
- add_test(test_xmltester ${CMAKE_RUNTIME_OUTPUT_DIRECTORY}/test_xmltester --test-valid-output ${SAVE_XMLTESTS})
+ add_test(test_xmltester ${CMAKE_RUNTIME_OUTPUT_DIRECTORY}/test_xmltester -v --test-valid-output ${SAVE_XMLTESTS})
set(STATUS_RESULT "ON")
endif()
Summary of changes:
tests/xmltester/CMakeLists.txt | 92 ++++++++++++++++++++++++++++--------------
1 file changed, 62 insertions(+), 30 deletions(-)
hooks/post-receive
More information about the geos-commits
