[geos-commits] [SCM] GEOS branch master updated. 4ff201dfd885b00dd3e6cdf38d3a918fbde32a7b
git at osgeo.org
git at osgeo.org
Sun Oct 7 09:28:36 PDT 2018
the project "GEOS".
via 4ff201dfd885b00dd3e6cdf38d3a918fbde32a7b (commit)
via 95d0ec97727dc8fc8defafb8977edcba3e58ce2b (commit)
from a67b6f8656ede68317d0a42e9b8a9e078281684a (commit)
revisions in full, below.
commit 4ff201dfd885b00dd3e6cdf38d3a918fbde32a7b
Author: Sandro Santilli <strk at kbt.io>
Date: Sun Oct 7 18:28:23 2018 +0200
Put building prerequisite in a common section
diff --git a/README.md b/README.md
index a43f331..c48fd69 100644
--- a/README.md
+++ b/README.md
@@ -15,11 +15,11 @@ More on: https://trac.osgeo.org/geos#BuildandInstall
## Building, testing, installing
-### Unix
+### Prerequisites
-#### Prerequisites
+Building GEOS requires a C++11 compiler
-geos requires a C++11 compiler
+### Unix
#### Using Autotools:
commit 95d0ec97727dc8fc8defafb8977edcba3e58ce2b
Author: Greg Troxel <gdt at lexort.com>
Date: Sat Oct 6 19:29:57 2018 -0400
README.md: Clarify installation instructions
index f0032f4..a43f331 100644
--- a/README.md
+++ b/README.md
@@ -17,22 +17,27 @@ More on: https://trac.osgeo.org/geos#BuildandInstall
### Unix
-Using Autotools:
+#### Prerequisites
+geos requires a C++11 compiler
+#### Using Autotools:
./autogen.sh # in ${srcdir}, if obtained from SVN or GIT
- ${srcdir}/configure # in build dir
+ (mkdir obj && cd obj && ../configure)
-Using CMake:
+#### Using CMake:
- cmake ${srcdir} # in build dir
+ (mkdir build && cd build && cmake ..)
-Now, all versions:
+#### Either Autotools or CMake
make
make check
- make install # as root
- ldconfig # as root
+ make install # (as root, assuming PREFIX is not writable by the build user)
+ On a GNU/Linux system, if installed in a system prefix:
+ ldconfig # as root
### Microsoft Windows
Summary of changes:
README.md | 19 ++++++++++++-------
1 file changed, 12 insertions(+), 7 deletions(-)
hooks/post-receive
More information about the geos-commits
