[geos-commits] [SCM] GEOS branch 3.7 updated. 5f4f0655f85bab14fd114a1df6127f1abc80d27c
git at osgeo.org
git at osgeo.org
Fri Oct 19 11:28:40 PDT 2018
the project "GEOS".
The branch, 3.7 has been updated
via 5f4f0655f85bab14fd114a1df6127f1abc80d27c (commit)
via e3c97184ea75aeb3d03ebf74076c866dcdefeca8 (commit)
from 6ad5952695787f112c4de9728887228f3d312b36 (commit)
revisions in full, below.
commit 5f4f0655f85bab14fd114a1df6127f1abc80d27c
Merge: 6ad5952 e3c9718
Author: pramsey <pramsey at cleverelephant.ca>
Date: Fri Oct 19 11:28:39 2018 -0700
Merge branch '3.7' of johnkharvey/geos into 3.7
Going to merge and manually add NEWS entry so it's done (tm)
commit e3c97184ea75aeb3d03ebf74076c866dcdefeca8
Author: John K. Harvey <john.harvey at crunchydata.com>
Date: Tue Oct 2 14:07:26 2018 -0400
'make check' passes with autoconf 2.63.
diff --git a/configure.ac b/configure.ac
index 2fa505f..43b163c 100644
--- a/configure.ac
+++ b/configure.ac
@@ -2,7 +2,7 @@ dnl
dnl configure.in - autoconf input template to produce ./configure script
dnl
dnl version 2.52 is required for Cygwin libtool support
-AC_PREREQ([2.52])
+AC_PREREQ([2.63])
dnl local vars to hold user's preferences --------------------------------
AC_INIT([include/geos.h])
diff --git a/macros/ax_check_compile_flag.m4 b/macros/ax_check_compile_flag.m4
index ca36397..89d3b93 100755
--- a/macros/ax_check_compile_flag.m4
+++ b/macros/ax_check_compile_flag.m4
@@ -58,7 +58,7 @@
#serial 4
AC_DEFUN([AX_CHECK_COMPILE_FLAG],
-[AC_PREREQ(2.64)dnl for _AC_LANG_PREFIX and AS_VAR_IF
+[AC_PREREQ(2.63)dnl for _AC_LANG_PREFIX and AS_VAR_IF
AS_VAR_PUSHDEF([CACHEVAR],[ax_cv_check_[]_AC_LANG_ABBREV[]flags_$4_$1])dnl
AC_CACHE_CHECK([whether _AC_LANG compiler accepts $1], CACHEVAR, [
ax_check_save_flags=$[]_AC_LANG_PREFIX[]FLAGS
Summary of changes:
configure.ac | 2 +-
macros/ax_check_compile_flag.m4 | 2 +-
2 files changed, 2 insertions(+), 2 deletions(-)
hooks/post-receive
More information about the geos-commits
