[geos-commits] [SCM] GEOS branch 3.7 updated. db3e7a7350e29b96255e34295f8771dd3fb80eee
git at osgeo.org
git at osgeo.org
Sun Sep 2 17:04:13 PDT 2018
the project "GEOS".
The branch, 3.7 has been updated
via db3e7a7350e29b96255e34295f8771dd3fb80eee (commit)
from 9ab043f7b851308240f603291409bea4be9e20c8 (commit)
revisions in full, below.
commit db3e7a7350e29b96255e34295f8771dd3fb80eee
Author: Regina Obe <lr at pcorp.us>
Date: Sun Sep 2 20:04:13 2018 -0400
Take out failing test on FreeBSD/macOS Clang. References #894
Will revisit in 3.8
diff --git a/tests/unit/capi/GEOSGeomFromWKBTest.cpp b/tests/unit/capi/GEOSGeomFromWKBTest.cpp
index e431648..bc5298f 100644
--- a/tests/unit/capi/GEOSGeomFromWKBTest.cpp
+++ b/tests/unit/capi/GEOSGeomFromWKBTest.cpp
@@ -81,20 +81,19 @@ namespace tut
// Test Cases
- template<>
+ /** TODO: Put this back after
+ * We figure out why it fails on some Clang platforms
+ * See https://trac.osgeo.org/geos/ticket/894 for details
+/* template<>
template<>
void object::test<1>()
// POINT(1.234 5.678)
std::string wkt("POINT (1.234 5.678)");
std::string wkb("01010000005839B4C876BEF33F83C0CAA145B61640");
- /** TODO: Put this back after
- * We figure out why it fails on some Clang platforms
- * See https://trac.osgeo.org/geos/ticket/894 for details
- //test_wkb(wkb, wkt);
+ test_wkb(wkb, wkt);
template<>
template<>
Summary of changes:
tests/unit/capi/GEOSGeomFromWKBTest.cpp | 15 +++++++--------
1 file changed, 7 insertions(+), 8 deletions(-)
hooks/post-receive
More information about the geos-commits
