[geos-commits] [SCM] GEOS branch 3.7 updated. 3614db6a35822a42da0aaff66c2b01dc94ab552c
Sun Sep 2 23:21:54 PDT 2018
the project "GEOS".
The branch, 3.7 has been updated
       via  3614db6a35822a42da0aaff66c2b01dc94ab552c (commit)
      from  763f137df8507fefba707800786deeb68118a2c0 (commit)
revisions in full, below.
commit 3614db6a35822a42da0aaff66c2b01dc94ab552c
Author: Regina Obe <lr at pcorp.us>
Date:   Mon Sep 3 02:21:55 2018 -0400
    Remove accidentally committed file and add to gitignore
diff --git a/include/geos/platform.h.disabled b/include/geos/platform.h.disabled
deleted file mode 100644
index cabc489..0000000
--- a/include/geos/platform.h.disabled
+++ /dev/null
@@ -1,117 +0,0 @@
-/* include/geos/platform.h.  Generated from platform.h.in by configure.  */
-#ifndef GEOS_PLATFORM_H
-#define GEOS_PLATFORM_H
-/* Set to 1 if you have `int64_t' type */
-/* #undef HAVE_INT64_T_64 */
-/* Set to 1 if `long int' is 64 bits */
-/* #undef HAVE_LONG_INT_64 */
-/* Set to 1 if `long long int' is 64 bits */
-#define HAVE_LONG_LONG_INT_64 1
-/* Set to 1 if you have ieeefp.h */
-#define HAVE_IEEEFP_H 1
-/* Has finite */
-#define HAVE_FINITE 1
-/* Has isfinite */
-#define HAVE_ISFINITE 1
-/* Has isnan */
-#define HAVE_ISNAN 1
-#ifdef HAVE_IEEEFP_H
-extern "C"
-#include <ieeefp.h>
-#endif
-#ifdef HAVE_INT64_T_64
-extern "C"
-#include <inttypes.h>
-#endif
-#if defined(__GNUC__) && defined(_WIN32)
-/* For MingW the appropriate definitions are included in
- math.h and float.h but the definitions in
- math.h are only included if __STRICT_ANSI__
- is not defined.  Since GEOS is compiled with -ansi that
- means those definitions are not available. */
-#include <float.h>
-#endif
-#include <limits> // for std::numeric_limits
-//Defines NaN for intel platforms
-#define DoubleNotANumber std::numeric_limits<double>::quiet_NaN()
-//Don't forget to define infinities
-#define DoubleInfinity std::numeric_limits<double>::infinity()
-#define DoubleNegInfinity -std::numeric_limits<double>::infinity()
-#define DoubleMax std::numeric_limits<double>::max()
-  typedef int64_t int64;
-#else
-# ifdef HAVE_LONG_LONG_INT_64
-   typedef long long int int64;
-# else
-   typedef long int int64;
-#  ifndef HAVE_LONG_INT_64
-#   define INT64_IS_REALLY32 1
-#   warning "Could not find 64bit integer definition!"
-#  endif
-# endif
-#endif
-#if defined(HAVE_FINITE) && !defined(HAVE_ISFINITE)
-# define FINITE(x) (finite(x))
-#else
-# if defined(_MSC_VER)
-#  define FINITE(x) _finite(static_cast<double>(x))
-# elif defined(__hpux__) && defined(__ia64__)
-#  define FINITE(x) (_Isfinite(x))
-# else
-#  define FINITE(x) (isfinite(x))
-# endif
-#endif
-#if defined(HAVE_ISNAN)
-# define ISNAN(x) (std::isnan(x))
-#else
-#  define ISNAN(x) _isnan(x)
-# elif defined(__MINGW32__) || defined(__CYGWIN__)
-// sandro furieri: sanitizing MinGW32
-# elif defined(__OSX__) || defined(__APPLE__) || \
-       defined(__NetBSD__) || defined(__DragonFly__) || defined (__OpenBSD__) || \
-       (defined(__sun) && defined(__GNUC__))
-   // Hack for OS/X <cmath> incorrectly re-defining isnan() into oblivion.
-   // It does leave a version in std.
-# elif (defined(__sun) || defined(__sun__)) && defined(__SUNPRO_CC)
-#  include <math.h>
-#  define ISNAN(x) (::isnan(x))
-# endif
-#endif
-#ifndef FINITE
-#error "Can not compile without finite or isfinite function or macro"
-#endif
-#ifndef ISNAN
-#error "Can not compile without isnan function or macro"
-#endif
-#endif
Summary of changes:
 include/geos/platform.h.disabled | 117 ---------------------------------------
 1 file changed, 117 deletions(-)
 delete mode 100644 include/geos/platform.h.disabled
hooks/post-receive
More information about the geos-commits mailing list
