[geos-commits] [SCM] GEOS branch master updated. 212ae25d09ae69894440f18c26ee8a3ca2d1052a
git at osgeo.org
git at osgeo.org
Wed Apr 10 13:58:29 PDT 2019
the project "GEOS".
via 212ae25d09ae69894440f18c26ee8a3ca2d1052a (commit)
from 63f2794d7798da8db62ec41bf2bd07502b7d0894 (commit)
revisions in full, below.
commit 212ae25d09ae69894440f18c26ee8a3ca2d1052a
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Wed Apr 10 13:57:54 2019 -0700
Reformat files after port
JTS a4f3848da812691ab9881a9b3ec857e941bc9deb
diff --git a/README.md b/README.md
index 7043a38..8f6d012 100644
--- a/README.md
+++ b/README.md
@@ -135,8 +135,11 @@ To build Doxygen documentation:
To format your code into the desired style, use astyle 3.1:
astyle --style=stroustrup \
+ --unpad-paren \
+ --pad-header \
--pad-comma \
--indent=spaces=4 \
+ --align-pointer=type \
--max-code-length=120 \
--lineend=linux \
yourfile.cpp
diff --git a/src/algorithm/InteriorPointArea.cpp b/src/algorithm/InteriorPointArea.cpp
index 24fef47..95f73bf 100644
--- a/src/algorithm/InteriorPointArea.cpp
+++ b/src/algorithm/InteriorPointArea.cpp
@@ -86,7 +86,7 @@ public:
getScanLineY()
process(*poly.getExteriorRing());
- for(size_t i = 0; i < poly.getNumInteriorRing(); i++) {
+ for (size_t i = 0; i < poly.getNumInteriorRing(); i++) {
process(*poly.getInteriorRingN(i));
double bisectY = avg(hiY, loY);
@@ -104,7 +104,7 @@ private:
process(const LineString& line)
const CoordinateSequence* seq = line.getCoordinatesRO();
- for(std::size_t i = 0, s = seq->size(); i < s; i++) {
+ for (std::size_t i = 0, s = seq->size(); i < s; i++) {
double y = seq->getY(i);
updateInterval(y);
@@ -113,13 +113,13 @@ private:
void
updateInterval(double y)
- if(y <= centreY) {
- if(y > loY) {
+ if (y <= centreY) {
+ if (y > loY) {
loY = y;
- else if(y > centreY) {
- if(y < hiY) {
+ else if (y > centreY) {
+ if (y < hiY) {
hiY = y;
@@ -161,10 +161,10 @@ public:
interiorPoint = *polygon.getCoordinate();
const LinearRing* shell = dynamic_cast<const LinearRing*>(polygon.getExteriorRing());
- scanRing( *shell, crossings );
+ scanRing(*shell, crossings);
for (size_t i = 0; i < polygon.getNumInteriorRing(); i++) {
const LinearRing* hole = dynamic_cast<const LinearRing*>(polygon.getInteriorRingN(i));
- scanRing( *hole, crossings );
+ scanRing(*hole, crossings);
findBestMidpoint(crossings);
@@ -178,7 +178,7 @@ private:
void scanRing(const LinearRing& ring, vector<double>& crossings)
// skip rings which don't cross scan line
- if ( ! intersectsHorizontalLine( ring.getEnvelopeInternal(), interiorPointY) )
+ if (! intersectsHorizontalLine(ring.getEnvelopeInternal(), interiorPointY))
return;
const CoordinateSequence* seq = ring.getCoordinatesRO();
@@ -189,17 +189,18 @@ private:
- void addEdgeCrossing(Coordinate& p0, Coordinate& p1, double scanY, vector<double>& crossings) {
- // skip non-crossing segments
- if ( !intersectsHorizontalLine(p0, p1, scanY) )
- return;
- if (! isEdgeCrossingCounted(p0, p1, scanY) )
- return;
+ void addEdgeCrossing(Coordinate& p0, Coordinate& p1, double scanY, vector<double>& crossings)
+ // skip non-crossing segments
+ if (!intersectsHorizontalLine(p0, p1, scanY))
+ return;
+ if (! isEdgeCrossingCounted(p0, p1, scanY))
+ return;
- // edge intersects scan line, so add a crossing
- double xInt = intersection(p0, p1, scanY);
- crossings.push_back(xInt);
- //checkIntersectionDD(p0, p1, scanY, xInt);
+ // edge intersects scan line, so add a crossing
+ double xInt = intersection(p0, p1, scanY);
+ crossings.push_back(xInt);
+ //checkIntersectionDD(p0, p1, scanY, xInt);
void findBestMidpoint(vector<double>& crossings)
@@ -220,7 +221,7 @@ private:
double x2 = crossings[i + 1];
double width = x2 - x1;
- if ( width > interiorSectionWidth ) {
+ if (width > interiorSectionWidth) {
interiorSectionWidth = width;
double interiorPointX = avg(x1, x2);
interiorPoint = Coordinate(interiorPointX, interiorPointY);
@@ -229,18 +230,19 @@ private:
static bool
- isEdgeCrossingCounted(Coordinate& p0, Coordinate& p1, double scanY) {
- // skip horizontal lines
- if ( p0.y == p1.y )
- return false;
- // handle cases where vertices lie on scan-line
- // downward segment does not include start point
- if ( p0.y == scanY && p1.y < scanY )
- return false;
- // upward segment does not include endpoint
- if ( p1.y == scanY && p0.y < scanY )
- return false;
- return true;
+ isEdgeCrossingCounted(Coordinate& p0, Coordinate& p1, double scanY)
+ // skip horizontal lines
+ if (p0.y == p1.y)
+ return false;
+ // handle cases where vertices lie on scan-line
+ // downward segment does not include start point
+ if (p0.y == scanY && p1.y < scanY)
+ return false;
+ // upward segment does not include endpoint
+ if (p1.y == scanY && p0.y < scanY)
+ return false;
+ return true;
static double
@@ -249,8 +251,8 @@ private:
double x0 = p0.x;
double x1 = p1.x;
- if ( x0 == x1 )
- return x0;
+ if (x0 == x1)
+ return x0;
// Assert: segDX is non-zero, due to previous equality test
double segDX = x1 - x0;
@@ -263,23 +265,24 @@ private:
static bool
intersectsHorizontalLine(const Envelope* env, double y)
- if ( y < env->getMinY() )
+ if (y < env->getMinY())
return false;
- if ( y > env->getMaxY() )
+ if (y > env->getMaxY())
return false;
return true;
static bool
- intersectsHorizontalLine(const Coordinate& p0, const Coordinate& p1, double y) {
- // both ends above?
- if ( p0.y > y && p1.y > y )
- return false;
- // both ends below?
- if ( p0.y < y && p1.y < y )
- return false;
- // segment must intersect line
- return true;
+ intersectsHorizontalLine(const Coordinate& p0, const Coordinate& p1, double y)
+ // both ends above?
+ if (p0.y > y && p1.y > y)
+ return false;
+ // both ends below?
+ if (p0.y < y && p1.y < y)
+ return false;
+ // segment must intersect line
+ return true;
@@ -314,14 +317,14 @@ InteriorPointArea::process(const Geometry* geom)
return;
const Polygon* poly = dynamic_cast<const Polygon*>(geom);
- if(poly) {
+ if (poly) {
processPolygon(poly);
return;
const GeometryCollection* gc = dynamic_cast<const GeometryCollection*>(geom);
- if(gc) {
- for(std::size_t i = 0, n = gc->getNumGeometries(); i < n; i++) {
+ if (gc) {
+ for (std::size_t i = 0, n = gc->getNumGeometries(); i < n; i++) {
process(gc->getGeometryN(i));
GEOS_CHECK_FOR_INTERRUPTS();
@@ -335,9 +338,9 @@ InteriorPointArea::processPolygon(const Polygon* polygon)
InteriorPointPolygon intPtPoly(*polygon);
intPtPoly.process();
double width = intPtPoly.getWidth();
- if ( width > maxWidth ) {
- maxWidth = width;
- intPtPoly.getInteriorPoint(interiorPoint);
+ if (width > maxWidth) {
+ maxWidth = width;
+ intPtPoly.getInteriorPoint(interiorPoint);
diff --git a/src/algorithm/InteriorPointLine.cpp b/src/algorithm/InteriorPointLine.cpp
index 4de12ad..a36818b 100644
--- a/src/algorithm/InteriorPointLine.cpp
+++ b/src/algorithm/InteriorPointLine.cpp
@@ -42,13 +42,13 @@ InteriorPointLine::InteriorPointLine(const Geometry* g)
minDistance = DoubleMax;
hasInterior = false;
- if(g->getCentroid(centroid)) {
+ if (g->getCentroid(centroid)) {
#if GEOS_DEBUG
std::cerr << "Centroid: " << centroid << std::endl;
#endif
addInterior(g);
- if(!hasInterior) {
+ if (!hasInterior) {
addEndpoints(g);
@@ -68,14 +68,14 @@ void
InteriorPointLine::addInterior(const Geometry* geom)
const LineString* ls = dynamic_cast<const LineString*>(geom);
- if(ls) {
+ if (ls) {
addInterior(ls->getCoordinatesRO());
return;
- if(gc) {
+ if (gc) {
addInterior(gc->getGeometryN(i));
@@ -85,7 +85,7 @@ void
InteriorPointLine::addInterior(const CoordinateSequence* pts)
const std::size_t n = pts->getSize() - 1;
- for(std::size_t i = 1; i < n; ++i) {
+ for (std::size_t i = 1; i < n; ++i) {
add(pts->getAt(i));
@@ -101,14 +101,14 @@ void
InteriorPointLine::addEndpoints(const Geometry* geom)
- if(ls) {
+ if (ls) {
addEndpoints(ls->getCoordinatesRO());
return;
- if(gc) {
+ if (gc) {
addEndpoints(gc->getGeometryN(i));
@@ -118,9 +118,9 @@ void
InteriorPointLine::addEndpoints(const CoordinateSequence* pts)
size_t npts = pts->size();
- if(npts) {
+ if (npts) {
add(pts->getAt(0));
- if(npts > 1) {
+ if (npts > 1) {
add(pts->getAt(npts - 1));
@@ -135,7 +135,7 @@ InteriorPointLine::add(const Coordinate& point)
#if GEOS_DEBUG
std::cerr << "point " << point << " dist " << dist << ", minDistance " << minDistance << std::endl;
#endif
- if(!hasInterior || dist < minDistance) {
+ if (!hasInterior || dist < minDistance) {
interiorPoint = point;
#if GEOS_DEBUG
std::cerr << " is new InteriorPoint" << std::endl;
@@ -148,7 +148,7 @@ InteriorPointLine::add(const Coordinate& point)
bool
InteriorPointLine::getInteriorPoint(Coordinate& ret) const
- if(! hasInterior) {
+ if (! hasInterior) {
return false;
ret = interiorPoint;
diff --git a/src/algorithm/InteriorPointPoint.cpp b/src/algorithm/InteriorPointPoint.cpp
index 7f953ae..5d23333 100644
--- a/src/algorithm/InteriorPointPoint.cpp
+++ b/src/algorithm/InteriorPointPoint.cpp
@@ -34,7 +34,7 @@ namespace algorithm { // geos.algorithm
InteriorPointPoint::InteriorPointPoint(const Geometry* g)
- if(! g->getCentroid(centroid)) {
+ if (! g->getCentroid(centroid)) {
else {
@@ -48,14 +48,14 @@ void
InteriorPointPoint::add(const Geometry* geom)
const Point* po = dynamic_cast<const Point*>(geom);
- if(po) {
+ if (po) {
add(po->getCoordinate());
return;
- if(gc) {
+ if (gc) {
add(gc->getGeometryN(i));
@@ -67,7 +67,7 @@ InteriorPointPoint::add(const Coordinate* point)
assert(point); // we wouldn't been called if this was an empty geom
double dist = point->distance(centroid);
- if(dist < minDistance) {
+ if (dist < minDistance) {
interiorPoint = *point;
minDistance = dist;
@@ -77,7 +77,7 @@ InteriorPointPoint::add(const Coordinate* point)
bool
InteriorPointPoint::getInteriorPoint(Coordinate& ret) const
return false;
Summary of changes:
README.md | 3 +
src/algorithm/InteriorPointArea.cpp | 105 ++++++++++++++++++-----------------
src/algorithm/InteriorPointLine.cpp | 26 ++++-----
src/algorithm/InteriorPointPoint.cpp | 12 ++--
4 files changed, 76 insertions(+), 70 deletions(-)
hooks/post-receive
More information about the geos-commits
