[geos-commits] [SCM] GEOS branch master updated. a276208d4e887895ce841f76d5a71131d7f49cc1
git at osgeo.org
git at osgeo.org
Fri Apr 12 10:33:49 PDT 2019
the project "GEOS".
via a276208d4e887895ce841f76d5a71131d7f49cc1 (commit)
from 93d81de9132ad7dd39534532a2f6158d8cf54ae2 (commit)
revisions in full, below.
commit a276208d4e887895ce841f76d5a71131d7f49cc1
Author: Martin Davis <mtnclimb at gmail.co>
Date: Fri Apr 12 10:33:28 2019 -0700
Add tests README
diff --git a/tests/README.md b/tests/README.md
new file mode 100644
index 0000000..9e80659
--- /dev/null
+++ b/tests/README.md
@@ -0,0 +1,45 @@
+GEOS Testing
+## Build locations
+Paths are given relative to GEOS root.
+Note some executables have different names.
+### Autotools
+* Executables are in-tree
+ * `tests/unit/geos_unit`
+ * `tests/xmltests/XMLtester`
+### CMake
+* Executables are in build directory (usually `../build`)
+ * `../build/bin/test_geos_unit`
+ * `../build/bin/test_xmltester`
+## Unit tests
+ geos_unit [class] [test number]
+Run all unit tests
+ geos_unit
+Run single unit test class
+ geos_unit capi::GEOSNode
+Run test witin unit test class
+ geos_unit capi::GEOSNode 1
+## XML Tests
+ xmltester [options] test-file ...
+CMake - Run test file
+ bin/test_xmltester ../geos/tests/xmltester/tests/general/TestBoundary.xml
Summary of changes:
tests/README.md | 45 +++++++++++++++++++++++++++++++++++++++++++++
1 file changed, 45 insertions(+)
create mode 100644 tests/README.md
hooks/post-receive
More information about the geos-commits
