[geos-commits] [SCM] GEOS branch master updated. d352f3c7cb208a1fbed09ec4ed54496d0d3c4a04
Mon Apr 15 06:20:52 PDT 2019
the project "GEOS".
       via  d352f3c7cb208a1fbed09ec4ed54496d0d3c4a04 (commit)
       via  5f90f866dca5105cd99325378089b1ac50b95f40 (commit)
       via  3c1c9a9c1153433015ace6381a7fcf6b4b3ed847 (commit)
      from  859dc941be742e2b0c58dcf2395285dfc5e2e71f (commit)
revisions in full, below.
commit d352f3c7cb208a1fbed09ec4ed54496d0d3c4a04
Merge: 5f90f86 3c1c9a9
Author: Daniel Baston <dbaston at gmail.com>
Date:   Mon Apr 15 09:20:13 2019 -0400
    Merge branch 'bounding-circle-leaks'
commit 5f90f866dca5105cd99325378089b1ac50b95f40
Date:   Sun Apr 14 22:27:46 2019 -0400
    Fix memory leak in IndexedFacetDistance
diff --git a/src/operation/distance/FacetSequence.cpp b/src/operation/distance/FacetSequence.cpp
index 297de1f..1a9e0ac 100644
--- a/src/operation/distance/FacetSequence.cpp
+++ b/src/operation/distance/FacetSequence.cpp
@@ -19,6 +19,8 @@
 #include <geos/algorithm/Distance.h>
 #include <geos/operation/distance/FacetSequence.h>
+#include <memory>
 using namespace geos::geom;
 using namespace geos::operation::distance;
 using namespace geos::algorithm;
@@ -201,7 +203,7 @@ FacetSequence::updateNearestLocationsLineLine(int i, const Coordinate& p0, const
     LineSegment seg0(p0, p1);
     LineSegment seg1(q0, q1);
-    CoordinateSequence* closestPts = seg0.closestPoints(seg1);
+    std::unique_ptr<CoordinateSequence> closestPts(seg0.closestPoints(seg1));
     Coordinate c0, c1;
     closestPts->getAt(0, c0);
     closestPts->getAt(1, c1);
commit 3c1c9a9c1153433015ace6381a7fcf6b4b3ed847
Date:   Sun Apr 14 22:19:11 2019 -0400
    Fix memory leaks in MinimumBoundingCircle
diff --git a/src/algorithm/MinimumBoundingCircle.cpp b/src/algorithm/MinimumBoundingCircle.cpp
index 59b1084..bb3951c 100644
--- a/src/algorithm/MinimumBoundingCircle.cpp
+++ b/src/algorithm/MinimumBoundingCircle.cpp
@@ -187,9 +187,9 @@ MinimumBoundingCircle::computeCirclePoints()
     * The problem is simplified by reducing to the convex hull.
     * Computing the convex hull also has the useful effect of eliminating duplicate points
-    Geometry* convexHull = input->convexHull();
+    std::unique_ptr<Geometry> convexHull(input->convexHull());
-    CoordinateSequence* cs = convexHull->getCoordinates();
+    std::unique_ptr<CoordinateSequence> cs(convexHull->getCoordinates());
     std::vector<Coordinate> pts;
     cs->toVector(pts);
Summary of changes:
 src/algorithm/MinimumBoundingCircle.cpp  | 4 ++--
 src/operation/distance/FacetSequence.cpp | 4 +++-
 2 files changed, 5 insertions(+), 3 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
