[geos-commits] [SCM] GEOS branch master updated. 70cd8d043d196626f5ef10781f18ac7b2ef1bc27
Wed Apr 24 14:10:54 PDT 2019
the project "GEOS".
       via  70cd8d043d196626f5ef10781f18ac7b2ef1bc27 (commit)
      from  d97b0e5cdb075bd61b73096e75915880d3b000de (commit)
revisions in full, below.
commit 70cd8d043d196626f5ef10781f18ac7b2ef1bc27
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Wed Apr 24 14:10:26 2019 -0700
    Fill in the exception error point when a eHoleOutsideShell occurs.
    Closes #963
diff --git a/src/operation/valid/IsValidOp.cpp b/src/operation/valid/IsValidOp.cpp
index a91e90e..387218a 100644
--- a/src/operation/valid/IsValidOp.cpp
+++ b/src/operation/valid/IsValidOp.cpp
@@ -460,7 +460,7 @@ IsValidOp::checkHolesInShell(const Polygon* p, GeometryGraph* graph)
         bool outside = isShellEmpty || (Location::EXTERIOR == ipial.locate(holePt));
         if (outside) {
             validErr = new TopologyValidationError(
-                TopologyValidationError::eHoleOutsideShell);
+                TopologyValidationError::eHoleOutsideShell, *holePt);
             return;
diff --git a/tests/unit/operation/valid/IsValidTest.cpp b/tests/unit/operation/valid/IsValidTest.cpp
index e366eea..1dd5982 100644
--- a/tests/unit/operation/valid/IsValidTest.cpp
+++ b/tests/unit/operation/valid/IsValidTest.cpp
@@ -4,7 +4,7 @@
 #include <tut/tut.hpp>
 // geos
-#include <geos/constants.h>
+#include <geos/constants.h> // for std::isnan
 #include <geos/operation/valid/IsValidOp.h>
 #include <geos/geom/Coordinate.h>
 #include <geos/geom/CoordinateArraySequence.h>
@@ -13,15 +13,14 @@
 #include <geos/geom/LineString.h>
 #include <geos/geom/GeometryFactory.h>
 #include <geos/geom/PrecisionModel.h>
+#include <geos/io/WKTReader.h>
 #include <geos/operation/valid/TopologyValidationError.h>
-#include <geos/constants.h> // for std::isnan
 // std
 #include <cmath>
 #include <string>
 #include <memory>
 using namespace geos::geom;
-//using namespace geos::operation;
 using namespace geos::operation::valid;
 namespace tut {
@@ -30,6 +29,7 @@ namespace tut {
 struct test_isvalidop_data {
+    geos::io::WKTReader wktreader;
     typedef std::unique_ptr<Geometry> GeomPtr;
     typedef geos::geom::GeometryFactory GeometryFactory;
@@ -76,5 +76,28 @@ void object::test<1>
     ensure_equals(valid, false);
+template<>
+template<>
+void object::test<2>
+    std::string wkt0("POLYGON((25495445.625 6671632.625,25495445.625 6671711.375,25495555.375 6671711.375,25495555.375 6671632.625,25495445.625 6671632.625),(25495368.0441 6671726.9312,25495368.3959388 6671726.93601515,25495368.7478 6671726.9333,25495368.0441 6671726.9312))");
+    GeomPtr g0(wktreader.read(wkt0));
+    IsValidOp isValidOp(g0.get());
+    bool valid = isValidOp.isValid();
+    TopologyValidationError* err = isValidOp.getValidationError();
+    ensure(nullptr != err);
+    const Coordinate& errCoord = err->getCoordinate();
+    ensure_equals(err->getErrorType(),
+                  TopologyValidationError::eHoleOutsideShell);
+    ensure(fabs(errCoord.y - 6671726.9) < 1.0);
+    ensure(fabs(errCoord.x - 25495368.0) < 1.0);
+    ensure_equals(valid, false);
 } // namespace tut
Summary of changes:
 src/operation/valid/IsValidOp.cpp          |  2 +-
 tests/unit/operation/valid/IsValidTest.cpp | 29 ++++++++++++++++++++++++++---
 2 files changed, 27 insertions(+), 4 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
