[geos-commits] [SCM] GEOS branch master updated. 50f558821f63ef7f8dd41b4ef3bdb581763936d6
git at osgeo.org
git at osgeo.org
Mon Aug 26 11:46:09 PDT 2019
the project "GEOS".
via 50f558821f63ef7f8dd41b4ef3bdb581763936d6 (commit)
via 0bf5167794c90984a056d7b5b6a7f5cb4ecaedc9 (commit)
via c487768ede97ea3d4ab78e16f67bb37f9dd3c09d (commit)
from 2cd5f5be1685ee46f444308fa63b41becf967b16 (commit)
revisions in full, below.
commit 50f558821f63ef7f8dd41b4ef3bdb581763936d6
Merge: 2cd5f5b 0bf5167
Author: Daniel Baston <dbaston at gmail.com>
Date: Mon Aug 26 14:45:35 2019 -0400
Merge remote-tracking branch 'dbaston/trac-858'
commit 0bf5167794c90984a056d7b5b6a7f5cb4ecaedc9
Date: Sun Aug 25 11:51:14 2019 -0400
Fix invalid read on exception in IsValidOp
Fixes #858
diff --git a/include/geos/geomgraph/GeometryGraph.h b/include/geos/geomgraph/GeometryGraph.h
index a33b4d5..00bd4df 100644
--- a/include/geos/geomgraph/GeometryGraph.h
+++ b/include/geos/geomgraph/GeometryGraph.h
@@ -30,6 +30,7 @@
#include <geos/geom/Coordinate.h>
#include <geos/geom/CoordinateSequence.h> // for unique_ptr<CoordinateSequence>
#include <geos/geomgraph/PlanarGraph.h>
+#include <geos/geomgraph/index/SegmentIntersector.h>
#include <geos/geom/LineString.h> // for LineStringLT
#include <geos/inline.h>
@@ -58,7 +59,6 @@ namespace geomgraph {
class Edge;
class Node;
namespace index {
-class SegmentIntersector;
class EdgeSetIntersector;
@@ -209,7 +209,7 @@ public:
* @return the SegmentIntersector used, containing information about
* the intersections found
- index::SegmentIntersector*
+ std::unique_ptr<index::SegmentIntersector>
computeSelfNodes(
algorithm::LineIntersector* li,
bool computeRingSelfNodes,
@@ -218,7 +218,7 @@ public:
return computeSelfNodes(*li, computeRingSelfNodes, env);
computeSelfNodes(
@@ -230,15 +230,15 @@ public:
// Quick inline calling the function above, the above should probably
// be deprecated.
- index::SegmentIntersector* computeSelfNodes(
+ std::unique_ptr<index::SegmentIntersector> computeSelfNodes(
algorithm::LineIntersector& li,
bool computeRingSelfNodes, const geom::Envelope* env = nullptr);
bool computeRingSelfNodes, bool isDoneIfProperInt, const geom::Envelope* env = nullptr);
- index::SegmentIntersector* computeEdgeIntersections(GeometryGraph* g,
+ std::unique_ptr<index::SegmentIntersector> computeEdgeIntersections(GeometryGraph* g,
algorithm::LineIntersector* li, bool includeProper,
diff --git a/include/geos/geomgraph/index/SimpleMCSweepLineIntersector.h b/include/geos/geomgraph/index/SimpleMCSweepLineIntersector.h
index 4b3dcee..b92be69 100644
--- a/include/geos/geomgraph/index/SimpleMCSweepLineIntersector.h
+++ b/include/geos/geomgraph/index/SimpleMCSweepLineIntersector.h
@@ -17,10 +17,12 @@
#define GEOS_GEOMGRAPH_INDEX_SIMPLEMCSWEEPLINEINTERSECTOR_H
#include <geos/export.h>
+#include <memory>
#include <vector>
#include <geos/geomgraph/index/EdgeSetIntersector.h> // for inheritance
+#include <geos/geomgraph/index/MonotoneChain.h>
#ifdef _MSC_VER
#pragma warning(push)
@@ -68,7 +70,8 @@ public:
protected:
- std::vector<SweepLineEvent*> events;
+ std::vector<std::unique_ptr<SweepLineEvent>> events;
+ std::vector<std::unique_ptr<MonotoneChain>> chains;
// statistics information
int nOverlaps;
diff --git a/include/geos/geomgraph/index/SweepLineEvent.h b/include/geos/geomgraph/index/SweepLineEvent.h
index 3f5c6ba..f23b85c 100644
--- a/include/geos/geomgraph/index/SweepLineEvent.h
+++ b/include/geos/geomgraph/index/SweepLineEvent.h
@@ -110,8 +110,9 @@ private:
class GEOS_DLL SweepLineEventLessThen {
public:
+ template<typename T>
bool
- operator()(const SweepLineEvent* f, const SweepLineEvent* s) const
+ operator()(const T& f, const T& s) const
if(f->xValue < s->xValue) {
return true;
diff --git a/src/geomgraph/GeometryGraph.cpp b/src/geomgraph/GeometryGraph.cpp
index c5b14c3..9630379 100644
--- a/src/geomgraph/GeometryGraph.cpp
+++ b/src/geomgraph/GeometryGraph.cpp
@@ -22,6 +22,7 @@
#include <geos/algorithm/BoundaryNodeRule.h>
#include <geos/util/UnsupportedOperationException.h>
+#include <geos/util.h>
#include <geos/geomgraph/GeometryGraph.h>
#include <geos/geomgraph/Node.h>
@@ -351,18 +352,18 @@ collect_intersecting_edges(const Envelope* env, T start, T end, C& to)
/*public*/
-SegmentIntersector*
+std::unique_ptr<SegmentIntersector>
GeometryGraph::computeSelfNodes(LineIntersector& li,
bool computeRingSelfNodes, const Envelope* env)
return computeSelfNodes(li, computeRingSelfNodes, false, env);
bool computeRingSelfNodes, bool isDoneIfProperInt, const Envelope* env)
- SegmentIntersector* si = new SegmentIntersector(&li, true, false);
+ auto si = detail::make_unique<SegmentIntersector>(&li, true, false);
si->setIsDoneIfProperInt(isDoneIfProperInt);
unique_ptr<EdgeSetIntersector> esi(createEdgeSetIntersector());
@@ -382,7 +383,7 @@ GeometryGraph::computeSelfNodes(LineIntersector& li,
bool computeAllSegments = computeRingSelfNodes || ! isRings;
- esi->computeIntersections(se, si, computeAllSegments);
+ esi->computeIntersections(se, si.get(), computeAllSegments);
#if GEOS_DEBUG
cerr << "SegmentIntersector # tests = " << si->numTests << endl;
@@ -392,7 +393,7 @@ GeometryGraph::computeSelfNodes(LineIntersector& li,
return si;
GeometryGraph::computeEdgeIntersections(GeometryGraph* g,
LineIntersector* li, bool includeProper, const Envelope* env)
@@ -425,7 +426,7 @@ GeometryGraph::computeEdgeIntersections(GeometryGraph* g,
#if GEOS_DEBUG
cerr << "GeometryGraph::computeEdgeIntersections returns" << endl;
#endif
- return si.release();
+ return si;
void
diff --git a/src/geomgraph/index/SimpleMCSweepLineIntersector.cpp b/src/geomgraph/index/SimpleMCSweepLineIntersector.cpp
index f97938a..6e93ead 100644
--- a/src/geomgraph/index/SimpleMCSweepLineIntersector.cpp
+++ b/src/geomgraph/index/SimpleMCSweepLineIntersector.cpp
@@ -33,15 +33,7 @@ SimpleMCSweepLineIntersector::SimpleMCSweepLineIntersector()
-SimpleMCSweepLineIntersector::~SimpleMCSweepLineIntersector()
- for(size_t i = 0; i < events.size(); ++i) {
- SweepLineEvent* sle = events[i];
- if(sle->isDelete()) {
- delete sle;
+SimpleMCSweepLineIntersector::~SimpleMCSweepLineIntersector() = default;
void
SimpleMCSweepLineIntersector::computeIntersections(vector<Edge*>* edges,
@@ -91,12 +83,14 @@ SimpleMCSweepLineIntersector::add(Edge* edge, void* edgeSet)
auto& startIndex = mce->getStartIndexes();
size_t n = startIndex.size() - 1;
events.reserve(events.size() + (n * 2));
+ chains.reserve(chains.size() + n);
for(size_t i = 0; i < n; ++i) {
GEOS_CHECK_FOR_INTERRUPTS();
MonotoneChain* mc = new MonotoneChain(mce, i);
+ chains.emplace_back(mc);
SweepLineEvent* insertEvent = new SweepLineEvent(edgeSet, mce->getMinX(i), nullptr, mc);
- events.push_back(insertEvent);
- events.push_back(new SweepLineEvent(edgeSet, mce->getMaxX(i), insertEvent, mc));
+ events.emplace_back(insertEvent);
+ events.emplace_back(new SweepLineEvent(edgeSet, mce->getMaxX(i), insertEvent, mc));
@@ -111,7 +105,7 @@ SimpleMCSweepLineIntersector::prepareEvents()
sort(events.begin(), events.end(), SweepLineEventLessThen());
- SweepLineEvent* ev = events[i];
+ auto& ev = events[i];
if(ev->isDelete()) {
ev->getInsertEvent()->setDeleteEventIndex(i);
@@ -125,9 +119,9 @@ SimpleMCSweepLineIntersector::computeIntersections(SegmentIntersector* si)
prepareEvents();
if(ev->isInsert()) {
- processOverlaps(i, ev->getDeleteEventIndex(), ev, si);
+ processOverlaps(i, ev->getDeleteEventIndex(), ev.get(), si);
if(si->getIsDone()) {
break;
@@ -147,7 +141,7 @@ SimpleMCSweepLineIntersector::processOverlaps(size_t start, size_t end,
* Last index can be skipped, because it must be a Delete event.
for(auto i = start; i < end; ++i) {
- SweepLineEvent* ev1 = events[i];
+ auto& ev1 = events[i];
if(ev1->isInsert()) {
MonotoneChain* mc1 = (MonotoneChain*) ev1->getObject();
// don't compare edges in same group
diff --git a/src/geomgraph/index/SweepLineEvent.cpp b/src/geomgraph/index/SweepLineEvent.cpp
index 81001cb..a8aacf5 100644
--- a/src/geomgraph/index/SweepLineEvent.cpp
+++ b/src/geomgraph/index/SweepLineEvent.cpp
@@ -40,13 +40,7 @@ SweepLineEvent::SweepLineEvent(void* newEdgeSet, double x,
-SweepLineEvent::~SweepLineEvent()
- if(eventType == DELETE_EVENT) {
- delete insertEvent;
- delete obj;
+SweepLineEvent::~SweepLineEvent() = default;
* ProjectionEvents are ordered first by their x-value, and then by their
diff --git a/src/operation/overlay/OverlayOp.cpp b/src/operation/overlay/OverlayOp.cpp
index a708b23..b623f03 100644
--- a/src/operation/overlay/OverlayOp.cpp
+++ b/src/operation/overlay/OverlayOp.cpp
@@ -758,9 +758,9 @@ OverlayOp::computeOverlay(OverlayOp::OpCode opCode)
// node the input Geometries
- delete arg[0]->computeSelfNodes(li, false, env);
+ arg[0]->computeSelfNodes(li, false, env);
- delete arg[1]->computeSelfNodes(li, false, env);
+ arg[1]->computeSelfNodes(li, false, env);
#if GEOS_DEBUG
cerr << "OverlayOp::computeOverlay: computed SelfNodes" << endl;
@@ -769,7 +769,7 @@ OverlayOp::computeOverlay(OverlayOp::OpCode opCode)
// compute intersections between edges of the two input geometries
- delete arg[0]->computeEdgeIntersections(arg[1], &li, true, env);
+ arg[0]->computeEdgeIntersections(arg[1], &li, true, env);
#if GEOS_DEBUG
cerr << "OverlayOp::computeOverlay: computed EdgeIntersections" << endl;
diff --git a/src/operation/valid/IsValidOp.cpp b/src/operation/valid/IsValidOp.cpp
index c3c1489..c6b705f 100644
--- a/src/operation/valid/IsValidOp.cpp
+++ b/src/operation/valid/IsValidOp.cpp
@@ -215,7 +215,7 @@ IsValidOp::checkValid(const LinearRing* g)
LineIntersector li;
- delete graph.computeSelfNodes(&li, true, true);
+ graph.computeSelfNodes(&li, true, true);
checkNoSelfIntersectingRings(&graph);
diff --git a/tests/unit/operation/IsSimpleOpTest.cpp b/tests/unit/operation/IsSimpleOpTest.cpp
index a925714..d4a8d59 100644
--- a/tests/unit/operation/IsSimpleOpTest.cpp
+++ b/tests/unit/operation/IsSimpleOpTest.cpp
@@ -132,7 +132,11 @@ void object::test<4>
auto g = reader.readHEX(s);
- g->isSimple();
+ try {
+ g->isSimple();
+ } catch (geos::util::GEOSException & e) {
+ // no memory leaks or invalid reads on exception
} // namespace tut
commit c487768ede97ea3d4ab78e16f67bb37f9dd3c09d
Date: Sun Aug 25 11:15:27 2019 -0400
Add failing test for #858
index 284ccf1..a925714 100644
@@ -11,8 +11,10 @@
#include <geos/geom/GeometryFactory.h>
#include <geos/geom/PrecisionModel.h>
#include <geos/io/WKTReader.h>
+#include <geos/io/WKBReader.h>
// std
#include <string>
+#include <sstream>
#include <memory>
using namespace geos::geom;
@@ -102,4 +104,35 @@ void object::test<3>
ensure(true == simple);
+template<>
+template<>
+void object::test<4>
+ // Adapted from https://trac.osgeo.org/geos/ticket/858
+ constexpr char kData[] =
+ "00000000020000000e0000000000000000"
+ "0000000000000000240424242424242424"
+ "24242424280000000000ffffffffffff3b"
+ "ffffffffffffffffffffffff4000010800"
+ "0000030000003b01980000000000000000"
+ "0000000000000000000000000000002900"
+ "000000000100000000490001f34e537437"
+ "6c6f63616c653500000000000000000000"
+ "2800000000000000000000000000000000"
+ "fb0000000000010700000000003a000000"
+ "f100000000000000000000f60000000000"
+ "0000000000000000000000000000000000"
+ "0000000000000000200000000000000000"
+ "0000000000000000000000000000000000";
+ geos::io::WKBReader reader;
+ std::istringstream s(kData);
+ auto g = reader.readHEX(s);
+ g->isSimple();
} // namespace tut
Summary of changes:
include/geos/geomgraph/GeometryGraph.h | 12 +++----
.../geomgraph/index/SimpleMCSweepLineIntersector.h | 5 ++-
include/geos/geomgraph/index/SweepLineEvent.h | 3 +-
src/geomgraph/GeometryGraph.cpp | 13 ++++----
.../index/SimpleMCSweepLineIntersector.cpp | 24 ++++++--------
src/geomgraph/index/SweepLineEvent.cpp | 8 +----
src/operation/overlay/OverlayOp.cpp | 6 ++--
src/operation/valid/IsValidOp.cpp | 2 +-
tests/unit/operation/IsSimpleOpTest.cpp | 37 ++++++++++++++++++++++
9 files changed, 70 insertions(+), 40 deletions(-)
hooks/post-receive
More information about the geos-commits
