[geos-commits] [SCM] GEOS branch master updated. c4bfa4585e74bd63f1df1000a115ff3aa2ddd327
Tue Aug 27 09:19:53 PDT 2019
the project "GEOS".
       via  c4bfa4585e74bd63f1df1000a115ff3aa2ddd327 (commit)
      from  fa0ff9bb09549a4aa3975b371975edf46855fb4a (commit)
revisions in full, below.
commit c4bfa4585e74bd63f1df1000a115ff3aa2ddd327
Author: Daniel Baston <dbaston at gmail.com>
Date:   Tue Aug 27 12:19:35 2019 -0400
    Use empty() instead of size() where possible
    Fixes #860
diff --git a/src/algorithm/Distance.cpp b/src/algorithm/Distance.cpp
index 8a88a82..a8c6e6c 100644
--- a/src/algorithm/Distance.cpp
+++ b/src/algorithm/Distance.cpp
@@ -180,7 +180,7 @@ double
 Distance::pointToSegmentString(const geom::Coordinate& p,
                                const geom::CoordinateSequence* seq)
-    if(seq->size() == 0) {
+    if(seq->isEmpty()) {
         throw util::IllegalArgumentException(
             "Line array must contain at least one vertex");
diff --git a/src/index/intervalrtree/SortedPackedIntervalRTree.cpp b/src/index/intervalrtree/SortedPackedIntervalRTree.cpp
index a01ab37..83b4829 100644
--- a/src/index/intervalrtree/SortedPackedIntervalRTree.cpp
+++ b/src/index/intervalrtree/SortedPackedIntervalRTree.cpp
@@ -42,7 +42,7 @@ SortedPackedIntervalRTree::init()
     * if leaves is empty then nothing has been inserted.
     * In this case it is safe to leave the tree in an open state
-    if (leaves.size() == 0) return;
+    if (leaves.empty()) return;
     root = buildTree();
diff --git a/src/operation/buffer/BufferBuilder.cpp b/src/operation/buffer/BufferBuilder.cpp
index 0bc6d7e..e7f2b3c 100644
--- a/src/operation/buffer/BufferBuilder.cpp
+++ b/src/operation/buffer/BufferBuilder.cpp
@@ -408,7 +408,7 @@ BufferBuilder::buffer(const Geometry* g, double distance)
                   << " curves" << std::endl;
 #endif
         // short-circuit test
-        if(bufferSegStrList.size() <= 0) {
+        if(bufferSegStrList.empty()) {
             return createEmptyResultGeometry();
diff --git a/src/simplify/DouglasPeuckerLineSimplifier.cpp b/src/simplify/DouglasPeuckerLineSimplifier.cpp
index bcd0418..634ad55 100644
--- a/src/simplify/DouglasPeuckerLineSimplifier.cpp
+++ b/src/simplify/DouglasPeuckerLineSimplifier.cpp
@@ -62,7 +62,7 @@ DouglasPeuckerLineSimplifier::simplify()
     CoordsVectAutoPtr coordList(new CoordsVect());
     // empty coordlist is the simplest, won't simplify further
-    if(! pts.size()) {
+    if(pts.empty()) {
         return coordList;
diff --git a/src/simplify/TaggedLineString.cpp b/src/simplify/TaggedLineString.cpp
index b2be0c8..680aa4b 100644
--- a/src/simplify/TaggedLineString.cpp
+++ b/src/simplify/TaggedLineString.cpp
@@ -81,7 +81,7 @@ TaggedLineString::init()
          << endl;
 #endif
-    if(pts->size()) {
+    if(!pts->isEmpty()) {
         segs.reserve(pts->size() - 1);
diff --git a/src/simplify/TaggedLineStringSimplifier.cpp b/src/simplify/TaggedLineStringSimplifier.cpp
index b97d9b1..64ebed3 100644
--- a/src/simplify/TaggedLineStringSimplifier.cpp
+++ b/src/simplify/TaggedLineStringSimplifier.cpp
@@ -76,7 +76,7 @@ TaggedLineStringSimplifier::simplify(TaggedLineString* nLine)
               << std::endl;
 #endif
-    if(! linePts->size()) {
+    if(linePts->isEmpty()) {
         return;
     simplifySection(0, linePts->size() - 1, 0);
Summary of changes:
 src/algorithm/Distance.cpp                            | 2 +-
 src/index/intervalrtree/SortedPackedIntervalRTree.cpp | 2 +-
 src/operation/buffer/BufferBuilder.cpp                | 2 +-
 src/simplify/DouglasPeuckerLineSimplifier.cpp         | 2 +-
 src/simplify/TaggedLineString.cpp                     | 2 +-
 src/simplify/TaggedLineStringSimplifier.cpp           | 2 +-
 6 files changed, 6 insertions(+), 6 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
