[geos-commits] [SCM] GEOS branch master updated. 4e0bb742cd823cba60d299cc44f97c89593bcc76
Mon Feb 4 09:22:18 PST 2019
the project "GEOS".
       via  4e0bb742cd823cba60d299cc44f97c89593bcc76 (commit)
      from  b88d4614aaf3c5e73fd275a88253f62f34c25bb9 (commit)
revisions in full, below.
commit 4e0bb742cd823cba60d299cc44f97c89593bcc76
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Mon Feb 4 09:21:45 2019 -0800
    Astyle 3.1 added to source tree for future
    spacing compatibility purposes (per strk)
diff --git a/configure.ac b/configure.ac
index 56c26ac..3852b64 100644
--- a/configure.ac
+++ b/configure.ac
@@ -502,6 +502,7 @@ AC_OUTPUT([
 	tests/thread/Makefile
 	tools/Makefile
 	tools/geos-config
+	tools/astyle/Makefile
 dnl -- echo "---------------------------------------"
diff --git a/tools/CMakeLists.txt b/tools/CMakeLists.txt
index 32fea3d..c5356e3 100644
--- a/tools/CMakeLists.txt
+++ b/tools/CMakeLists.txt
@@ -6,7 +6,7 @@
 # This is free software; you can redistribute and/or modify it under
 # the terms of the GNU Lesser General Public Licence as published
-# by the Free Software Foundation.
+# by the Free Software Foundation.
 # See the COPYING file for more information.
@@ -26,11 +26,11 @@ if(UNIX OR MINGW)
   set(exec_prefix ${prefix}/bin)
   set(libdir ${prefix}/lib)
   if(installdest)
     configure_file(${CMAKE_CURRENT_SOURCE_DIR}/geos-config.in
                    ${CMAKE_CURRENT_BINARY_DIR}/geos-config @ONLY)
     install(FILES ${CMAKE_CURRENT_BINARY_DIR}/geos-config
       DESTINATION ${installdest}
       PERMISSIONS
@@ -38,3 +38,4 @@ if(UNIX OR MINGW)
 endif()
 endif()
+add_subdirectory(astyle)
diff --git a/tools/Makefile.am b/tools/Makefile.am
index 1de5cf4..2b63b78 100644
--- a/tools/Makefile.am
+++ b/tools/Makefile.am
@@ -3,3 +3,5 @@
 bin_SCRIPTS = geos-config
 EXTRA_DIST = CMakeLists.txt repo_revision.sh
+SUBDIRS = astyle
diff --git a/tools/astyle/ASBeautifier.cpp b/tools/astyle/ASBeautifier.cpp
new file mode 100755
index 0000000..10317dd
--- /dev/null
+++ b/tools/astyle/ASBeautifier.cpp
@@ -0,0 +1,3744 @@
+// ASBeautifier.cpp
+// Copyright (c) 2018 by Jim Pattee <jimp03 at email.com>.
+// This code is licensed under the MIT License.
+// License.md describes the conditions under which this software may be distributed.
+// headers
+#include "astyle.h"
+#include <algorithm>
+// astyle namespace
+namespace astyle {
+// this must be global
+static int g_preprocessorCppExternCBrace;
+// ASBeautifier class
+ * ASBeautifier's constructor
+ * This constructor is called only once for each source file.
+ * The cloned ASBeautifier objects are created with the copy constructor.
+ASBeautifier::ASBeautifier()
+	waitingBeautifierStack = nullptr;
+	activeBeautifierStack = nullptr;
+	waitingBeautifierStackLengthStack = nullptr;
+	activeBeautifierStackLengthStack = nullptr;
+	headerStack = nullptr;
+	tempStacks = nullptr;
+	parenDepthStack = nullptr;
+	blockStatementStack = nullptr;
+	parenStatementStack = nullptr;
+	braceBlockStateStack = nullptr;
+	continuationIndentStack = nullptr;
+	continuationIndentStackSizeStack = nullptr;
+	parenIndentStack = nullptr;
+	preprocIndentStack = nullptr;
+	sourceIterator = nullptr;
+	isModeManuallySet = false;
+	shouldForceTabIndentation = false;
+	setSpaceIndentation(4);
+	setContinuationIndentation(1);
+	setMinConditionalIndentOption(MINCOND_TWO);
+	setMaxContinuationIndentLength(40);
+	classInitializerIndents = 1;
+	tabLength = 0;
+	setClassIndent(false);
+	setModifierIndent(false);
+	setSwitchIndent(false);
+	setCaseIndent(false);
+	setBlockIndent(false);
+	setBraceIndent(false);
+	setBraceIndentVtk(false);
+	setNamespaceIndent(false);
+	setAfterParenIndent(false);
+	setLabelIndent(false);
+	setEmptyLineFill(false);
+	setCStyle();
+	setPreprocDefineIndent(false);
+	setPreprocConditionalIndent(false);
+	setAlignMethodColon(false);
+	// initialize ASBeautifier member vectors
+	beautifierFileType = 9;		// reset to an invalid type
+	headers = new vector<const string*>;
+	nonParenHeaders = new vector<const string*>;
+	assignmentOperators = new vector<const string*>;
+	nonAssignmentOperators = new vector<const string*>;
+	preBlockStatements = new vector<const string*>;
+	preCommandHeaders = new vector<const string*>;
+	indentableHeaders = new vector<const string*>;
+ * ASBeautifier's copy constructor
+ * Copy the vector objects to vectors in the new ASBeautifier
+ * object so the new object can be destroyed without deleting
+ * the vector objects in the copied vector.
+ * This is the reason a copy constructor is needed.
+ * Must explicitly call the base class copy constructor.
+ASBeautifier::ASBeautifier(const ASBeautifier& other) : ASBase(other)
+	// these don't need to copy the stack
+	// vector '=' operator performs a DEEP copy of all elements in the vector
+	headerStack = new vector<const string*>;
+	*headerStack = *other.headerStack;
+	tempStacks = copyTempStacks(other);
+	parenDepthStack = new vector<int>;
+	*parenDepthStack = *other.parenDepthStack;
+	blockStatementStack = new vector<bool>;
+	*blockStatementStack = *other.blockStatementStack;
+	parenStatementStack = new vector<bool>;
+	*parenStatementStack = *other.parenStatementStack;
+	braceBlockStateStack = new vector<bool>;
+	*braceBlockStateStack = *other.braceBlockStateStack;
+	continuationIndentStack = new vector<int>;
+	*continuationIndentStack = *other.continuationIndentStack;
+	continuationIndentStackSizeStack = new vector<int>;
+	*continuationIndentStackSizeStack = *other.continuationIndentStackSizeStack;
+	parenIndentStack = new vector<int>;
+	*parenIndentStack = *other.parenIndentStack;
+	preprocIndentStack = new vector<pair<int, int> >;
+	*preprocIndentStack = *other.preprocIndentStack;
+	// Copy the pointers to vectors.
+	// This is ok because the original ASBeautifier object
+	// is not deleted until end of job.
+	beautifierFileType = other.beautifierFileType;
+	headers = other.headers;
+	nonParenHeaders = other.nonParenHeaders;
+	assignmentOperators = other.assignmentOperators;
+	nonAssignmentOperators = other.nonAssignmentOperators;
+	preBlockStatements = other.preBlockStatements;
+	preCommandHeaders = other.preCommandHeaders;
+	indentableHeaders = other.indentableHeaders;
+	// protected variables
+	// variables set by ASFormatter
+	// must also be updated in activeBeautifierStack
+	inLineNumber = other.inLineNumber;
+	runInIndentContinuation = other.runInIndentContinuation;
+	nonInStatementBrace = other.nonInStatementBrace;
+	objCColonAlignSubsequent = other.objCColonAlignSubsequent;
+	lineCommentNoBeautify = other.lineCommentNoBeautify;
+	isElseHeaderIndent = other.isElseHeaderIndent;
+	isCaseHeaderCommentIndent = other.isCaseHeaderCommentIndent;
+	isNonInStatementArray = other.isNonInStatementArray;
+	isSharpAccessor = other.isSharpAccessor;
+	isSharpDelegate = other.isSharpDelegate;
+	isInExternC = other.isInExternC;
+	isInBeautifySQL = other.isInBeautifySQL;
+	isInIndentableStruct = other.isInIndentableStruct;
+	isInIndentablePreproc = other.isInIndentablePreproc;
+	// private variables
+	sourceIterator = other.sourceIterator;
+	currentHeader = other.currentHeader;
+	previousLastLineHeader = other.previousLastLineHeader;
+	probationHeader = other.probationHeader;
+	lastLineHeader = other.lastLineHeader;
+	indentString = other.indentString;
+	verbatimDelimiter = other.verbatimDelimiter;
+	isInQuote = other.isInQuote;
+	isInVerbatimQuote = other.isInVerbatimQuote;
+	haveLineContinuationChar = other.haveLineContinuationChar;
+	isInAsm = other.isInAsm;
+	isInAsmOneLine = other.isInAsmOneLine;
+	isInAsmBlock = other.isInAsmBlock;
+	isInComment = other.isInComment;
+	isInPreprocessorComment = other.isInPreprocessorComment;
+	isInRunInComment = other.isInRunInComment;
+	isInCase = other.isInCase;
+	isInQuestion = other.isInQuestion;
+	isContinuation = other.isContinuation;
+	isInHeader = other.isInHeader;
+	isInTemplate = other.isInTemplate;
+	isInDefine = other.isInDefine;
+	isInDefineDefinition = other.isInDefineDefinition;
+	classIndent = other.classIndent;
+	isIndentModeOff = other.isIndentModeOff;
+	isInClassHeader = other.isInClassHeader;
+	isInClassHeaderTab = other.isInClassHeaderTab;
+	isInClassInitializer = other.isInClassInitializer;
+	isInClass = other.isInClass;
+	isInObjCMethodDefinition = other.isInObjCMethodDefinition;
+	isInObjCMethodCall = other.isInObjCMethodCall;
+	isInObjCMethodCallFirst = other.isInObjCMethodCallFirst;
+	isImmediatelyPostObjCMethodDefinition = other.isImmediatelyPostObjCMethodDefinition;
+	isImmediatelyPostObjCMethodCall = other.isImmediatelyPostObjCMethodCall;
+	isInIndentablePreprocBlock = other.isInIndentablePreprocBlock;
+	isInObjCInterface = other.isInObjCInterface;
+	isInEnum = other.isInEnum;
+	isInEnumTypeID = other.isInEnumTypeID;
+	isInLet = other.isInLet;
+	isInTrailingReturnType = other.isInTrailingReturnType;
+	modifierIndent = other.modifierIndent;
+	switchIndent = other.switchIndent;
+	caseIndent = other.caseIndent;
+	namespaceIndent = other.namespaceIndent;
+	braceIndent = other.braceIndent;
+	braceIndentVtk = other.braceIndentVtk;
+	blockIndent = other.blockIndent;
+	shouldIndentAfterParen = other.shouldIndentAfterParen;
+	labelIndent = other.labelIndent;
+	isInConditional = other.isInConditional;
+	isModeManuallySet = other.isModeManuallySet;
+	shouldForceTabIndentation = other.shouldForceTabIndentation;
+	emptyLineFill = other.emptyLineFill;
+	lineOpensWithLineComment = other.lineOpensWithLineComment;
+	lineOpensWithComment = other.lineOpensWithComment;
+	lineStartsInComment = other.lineStartsInComment;
+	backslashEndsPrevLine = other.backslashEndsPrevLine;
+	blockCommentNoIndent = other.blockCommentNoIndent;
+	blockCommentNoBeautify = other.blockCommentNoBeautify;
+	previousLineProbationTab = other.previousLineProbationTab;
+	lineBeginsWithOpenBrace = other.lineBeginsWithOpenBrace;
+	lineBeginsWithCloseBrace = other.lineBeginsWithCloseBrace;
+	lineBeginsWithComma = other.lineBeginsWithComma;
+	lineIsCommentOnly = other.lineIsCommentOnly;
+	lineIsLineCommentOnly = other.lineIsLineCommentOnly;
+	shouldIndentBracedLine = other.shouldIndentBracedLine;
+	isInSwitch = other.isInSwitch;
+	foundPreCommandHeader = other.foundPreCommandHeader;
+	foundPreCommandMacro = other.foundPreCommandMacro;
+	shouldAlignMethodColon = other.shouldAlignMethodColon;
+	shouldIndentPreprocDefine = other.shouldIndentPreprocDefine;
+	shouldIndentPreprocConditional = other.shouldIndentPreprocConditional;
+	indentCount = other.indentCount;
+	spaceIndentCount = other.spaceIndentCount;
+	spaceIndentObjCMethodAlignment = other.spaceIndentObjCMethodAlignment;
+	bracePosObjCMethodAlignment = other.bracePosObjCMethodAlignment;
+	colonIndentObjCMethodAlignment = other.colonIndentObjCMethodAlignment;
+	lineOpeningBlocksNum = other.lineOpeningBlocksNum;
+	lineClosingBlocksNum = other.lineClosingBlocksNum;
+	fileType = other.fileType;
+	minConditionalOption = other.minConditionalOption;
+	minConditionalIndent = other.minConditionalIndent;
+	parenDepth = other.parenDepth;
+	indentLength = other.indentLength;
+	tabLength = other.tabLength;
+	continuationIndent = other.continuationIndent;
+	blockTabCount = other.blockTabCount;
+	maxContinuationIndent = other.maxContinuationIndent;
+	classInitializerIndents = other.classInitializerIndents;
+	templateDepth = other.templateDepth;
+	squareBracketCount = other.squareBracketCount;
+	prevFinalLineSpaceIndentCount = other.prevFinalLineSpaceIndentCount;
+	prevFinalLineIndentCount = other.prevFinalLineIndentCount;
+	defineIndentCount = other.defineIndentCount;
+	preprocBlockIndent = other.preprocBlockIndent;
+	quoteChar = other.quoteChar;
+	prevNonSpaceCh = other.prevNonSpaceCh;
+	currentNonSpaceCh = other.currentNonSpaceCh;
+	currentNonLegalCh = other.currentNonLegalCh;
+	prevNonLegalCh = other.prevNonLegalCh;
+ * ASBeautifier's destructor
+ASBeautifier::~ASBeautifier()
+	deleteBeautifierContainer(waitingBeautifierStack);
+	deleteBeautifierContainer(activeBeautifierStack);
+	deleteContainer(waitingBeautifierStackLengthStack);
+	deleteContainer(activeBeautifierStackLengthStack);
+	deleteContainer(headerStack);
+	deleteTempStacksContainer(tempStacks);
+	deleteContainer(parenDepthStack);
+	deleteContainer(blockStatementStack);
+	deleteContainer(parenStatementStack);
+	deleteContainer(braceBlockStateStack);
+	deleteContainer(continuationIndentStack);
+	deleteContainer(continuationIndentStackSizeStack);
+	deleteContainer(parenIndentStack);
+	deleteContainer(preprocIndentStack);
+ * initialize the ASBeautifier.
+ * This init() should be called every time a ABeautifier object is to start
+ * beautifying a NEW source file.
+ * It is called only when a new ASFormatter object is created.
+ * init() receives a pointer to a ASSourceIterator object that will be
+ * used to iterate through the source code.
+ * @param iter     a pointer to the ASSourceIterator or ASStreamIterator object.
+void ASBeautifier::init(ASSourceIterator* iter)
+	sourceIterator = iter;
+	initVectors();
+	ASBase::init(getFileType());
+	g_preprocessorCppExternCBrace = 0;
+	initContainer(waitingBeautifierStack, new vector<ASBeautifier*>);
+	initContainer(activeBeautifierStack, new vector<ASBeautifier*>);
+	initContainer(waitingBeautifierStackLengthStack, new vector<int>);
+	initContainer(activeBeautifierStackLengthStack, new vector<int>);
+	initContainer(headerStack, new vector<const string*>);
+	initTempStacksContainer(tempStacks, new vector<vector<const string*>*>);
+	tempStacks->emplace_back(new vector<const string*>);
+	initContainer(parenDepthStack, new vector<int>);
+	initContainer(blockStatementStack, new vector<bool>);
+	initContainer(parenStatementStack, new vector<bool>);
+	initContainer(braceBlockStateStack, new vector<bool>);
+	braceBlockStateStack->push_back(true);
+	initContainer(continuationIndentStack, new vector<int>);
+	initContainer(continuationIndentStackSizeStack, new vector<int>);
+	continuationIndentStackSizeStack->emplace_back(0);
+	initContainer(parenIndentStack, new vector<int>);
+	initContainer(preprocIndentStack, new vector<pair<int, int> >);
+	previousLastLineHeader = nullptr;
+	currentHeader = nullptr;
+	isInQuote = false;
+	isInVerbatimQuote = false;
+	haveLineContinuationChar = false;
+	isInAsm = false;
+	isInAsmOneLine = false;
+	isInAsmBlock = false;
+	isInComment = false;
+	isInPreprocessorComment = false;
+	isInRunInComment = false;
+	isContinuation = false;
+	isInCase = false;
+	isInQuestion = false;
+	isIndentModeOff = false;
+	isInClassHeader = false;
+	isInClassHeaderTab = false;
+	isInClassInitializer = false;
+	isInClass = false;
+	isInObjCMethodDefinition = false;
+	isInObjCMethodCall = false;
+	isInObjCMethodCallFirst = false;
+	isImmediatelyPostObjCMethodDefinition = false;
+	isImmediatelyPostObjCMethodCall = false;
+	isInIndentablePreprocBlock = false;
+	isInObjCInterface = false;
+	isInEnum = false;
+	isInEnumTypeID = false;
+	isInLet = false;
+	isInHeader = false;
+	isInTemplate = false;
+	isInConditional = false;
+	isInTrailingReturnType = false;
+	indentCount = 0;
+	spaceIndentCount = 0;
+	spaceIndentObjCMethodAlignment = 0;
+	bracePosObjCMethodAlignment = 0;
+	colonIndentObjCMethodAlignment = 0;
+	lineOpeningBlocksNum = 0;
+	lineClosingBlocksNum = 0;
+	templateDepth = 0;
+	squareBracketCount = 0;
+	parenDepth = 0;
+	blockTabCount = 0;
+	prevFinalLineSpaceIndentCount = 0;
+	prevFinalLineIndentCount = 0;
+	defineIndentCount = 0;
+	preprocBlockIndent = 0;
+	prevNonSpaceCh = '{';
+	currentNonSpaceCh = '{';
+	prevNonLegalCh = '{';
+	currentNonLegalCh = '{';
+	quoteChar = ' ';
+	probationHeader = nullptr;
+	lastLineHeader = nullptr;
+	backslashEndsPrevLine = false;
+	lineOpensWithLineComment = false;
+	lineOpensWithComment = false;
+	lineStartsInComment = false;
+	isInDefine = false;
+	isInDefineDefinition = false;
+	lineCommentNoBeautify = false;
+	isElseHeaderIndent = false;
+	isCaseHeaderCommentIndent = false;
+	blockCommentNoIndent = false;
+	blockCommentNoBeautify = false;
+	previousLineProbationTab = false;
+	lineBeginsWithOpenBrace = false;
+	lineBeginsWithCloseBrace = false;
+	lineBeginsWithComma = false;
+	lineIsCommentOnly = false;
+	lineIsLineCommentOnly = false;
+	shouldIndentBracedLine = true;
+	isInSwitch = false;
+	foundPreCommandHeader = false;
+	foundPreCommandMacro = false;
+	isNonInStatementArray = false;
+	isSharpAccessor = false;
+	isSharpDelegate = false;
+	isInExternC = false;
+	isInBeautifySQL = false;
+	isInIndentableStruct = false;
+	isInIndentablePreproc = false;
+	inLineNumber = 0;
+	runInIndentContinuation = 0;
+	nonInStatementBrace = 0;
+	objCColonAlignSubsequent = 0;
+ * initialize the vectors
+void ASBeautifier::initVectors()
+	if (fileType == beautifierFileType)    // don't build unless necessary
+		return;
+	beautifierFileType = fileType;
+	headers->clear();
+	nonParenHeaders->clear();
+	assignmentOperators->clear();
+	nonAssignmentOperators->clear();
+	preBlockStatements->clear();
+	preCommandHeaders->clear();
+	indentableHeaders->clear();
+	ASResource::buildHeaders(headers, fileType, true);
+	ASResource::buildNonParenHeaders(nonParenHeaders, fileType, true);
+	ASResource::buildAssignmentOperators(assignmentOperators);
+	ASResource::buildNonAssignmentOperators(nonAssignmentOperators);
+	ASResource::buildPreBlockStatements(preBlockStatements, fileType);
+	ASResource::buildPreCommandHeaders(preCommandHeaders, fileType);
+	ASResource::buildIndentableHeaders(indentableHeaders);
+ * set indentation style to C/C++.
+void ASBeautifier::setCStyle()
+	fileType = C_TYPE;
+ * set indentation style to Java.
+void ASBeautifier::setJavaStyle()
+	fileType = JAVA_TYPE;
+ * set indentation style to C#.
+void ASBeautifier::setSharpStyle()
+	fileType = SHARP_TYPE;
+ * set mode manually set flag
+void ASBeautifier::setModeManuallySet(bool state)
+	isModeManuallySet = state;
+ * set tabLength equal to indentLength.
+ * This is done when tabLength is not explicitly set by
+ * "indent=force-tab-x"
+void ASBeautifier::setDefaultTabLength()
+	tabLength = indentLength;
+ * indent using a different tab setting for indent=force-tab
+ * @param   length     number of spaces per tab.
+void ASBeautifier::setForceTabXIndentation(int length)
+	// set tabLength instead of indentLength
+	indentString = "\t";
+	tabLength = length;
+	shouldForceTabIndentation = true;
+ * indent using one tab per indentation
+void ASBeautifier::setTabIndentation(int length, bool forceTabs)
+	indentLength = length;
+	shouldForceTabIndentation = forceTabs;
+ * indent using a number of spaces per indentation.
+ * @param   length     number of spaces per indent.
+void ASBeautifier::setSpaceIndentation(int length)
+	indentString = string(length, ' ');
+* indent continuation lines using a number of indents.
+* @param   indent     number of indents per line.
+void ASBeautifier::setContinuationIndentation(int indent)
+	continuationIndent = indent;
+ * set the maximum indentation between two lines in a multi-line statement.
+ * @param   max     maximum indentation length.
+void ASBeautifier::setMaxContinuationIndentLength(int max)
+	maxContinuationIndent = max;
+// retained for compatibility with release 2.06
+// "MaxInStatementIndent" has been changed to "MaxContinuationIndent" in 3.0
+// it is referenced only by the old "MaxInStatementIndent" options
+void ASBeautifier::setMaxInStatementIndentLength(int max)
+	setMaxContinuationIndentLength(max);
+ * set the minimum conditional indentation option.
+ * @param   min     minimal indentation option.
+void ASBeautifier::setMinConditionalIndentOption(int min)
+	minConditionalOption = min;
+ * set minConditionalIndent from the minConditionalOption.
+void ASBeautifier::setMinConditionalIndentLength()
+	if (minConditionalOption == MINCOND_ZERO)
+		minConditionalIndent = 0;
+	else if (minConditionalOption == MINCOND_ONE)
+		minConditionalIndent = indentLength;
+	else if (minConditionalOption == MINCOND_ONEHALF)
+		minConditionalIndent = indentLength / 2;
+	// minConditionalOption = INDENT_TWO
+	else
+		minConditionalIndent = indentLength * 2;
+ * set the state of the brace indent option. If true, braces will
+ * be indented one additional indent.
+ * @param   state             state of option.
+void ASBeautifier::setBraceIndent(bool state)
+	braceIndent = state;
+* set the state of the brace indent VTK option. If true, braces will
+* be indented one additional indent, except for the opening brace.
+* @param   state             state of option.
+void ASBeautifier::setBraceIndentVtk(bool state)
+	// need to set both of these
+	setBraceIndent(state);
+	braceIndentVtk = state;
+ * set the state of the block indentation option. If true, entire blocks
+ * will be indented one additional indent, similar to the GNU indent style.
+void ASBeautifier::setBlockIndent(bool state)
+	blockIndent = state;
+ * set the state of the class indentation option. If true, C++ class
+ * definitions will be indented one additional indent.
+void ASBeautifier::setClassIndent(bool state)
+	classIndent = state;
+ * set the state of the modifier indentation option. If true, C++ class
+ * access modifiers will be indented one-half an indent.
+void ASBeautifier::setModifierIndent(bool state)
+	modifierIndent = state;
+ * set the state of the switch indentation option. If true, blocks of 'switch'
+ * statements will be indented one additional indent.
+void ASBeautifier::setSwitchIndent(bool state)
+	switchIndent = state;
+ * set the state of the case indentation option. If true, lines of 'case'
+void ASBeautifier::setCaseIndent(bool state)
+	caseIndent = state;
+ * set the state of the namespace indentation option.
+ * If true, blocks of 'namespace' statements will be indented one
+ * additional indent. Otherwise, NO indentation will be added.
+void ASBeautifier::setNamespaceIndent(bool state)
+	namespaceIndent = state;
+* set the state of the indent after parens option.
+void ASBeautifier::setAfterParenIndent(bool state)
+	shouldIndentAfterParen = state;
+ * set the state of the label indentation option.
+ * If true, labels will be indented one indent LESS than the
+ * current indentation level.
+ * If false, labels will be flushed to the left with NO
+ * indent at all.
+void ASBeautifier::setLabelIndent(bool state)
+	labelIndent = state;
+ * set the state of the preprocessor indentation option.
+ * If true, multi-line #define statements will be indented.
+void ASBeautifier::setPreprocDefineIndent(bool state)
+	shouldIndentPreprocDefine = state;
+void ASBeautifier::setPreprocConditionalIndent(bool state)
+	shouldIndentPreprocConditional = state;
+ * set the state of the empty line fill option.
+ * If true, empty lines will be filled with the whitespace.
+ * of their previous lines.
+ * If false, these lines will remain empty.
+void ASBeautifier::setEmptyLineFill(bool state)
+	emptyLineFill = state;
+void ASBeautifier::setAlignMethodColon(bool state)
+	shouldAlignMethodColon = state;
+ * get the file type.
+int ASBeautifier::getFileType() const
+	return fileType;
+ * get the number of spaces per indent
+ * @return   value of indentLength option.
+int ASBeautifier::getIndentLength() const
+	return indentLength;
+ * get the char used for indentation, space or tab
+ * @return   the char used for indentation.
+string ASBeautifier::getIndentString() const
+	return indentString;
+ * get mode manually set flag
+bool ASBeautifier::getModeManuallySet() const
+	return isModeManuallySet;
+ * get the state of the force tab indentation option.
+ * @return   state of force tab indentation.
+bool ASBeautifier::getForceTabIndentation() const
+	return shouldForceTabIndentation;
+* Get the state of the Objective-C align method colon option.
+* @return   state of shouldAlignMethodColon option.
+bool ASBeautifier::getAlignMethodColon() const
+	return shouldAlignMethodColon;
+ * get the state of the block indentation option.
+ * @return   state of blockIndent option.
+bool ASBeautifier::getBlockIndent() const
+	return blockIndent;
+ * get the state of the brace indentation option.
+ * @return   state of braceIndent option.
+bool ASBeautifier::getBraceIndent() const
+	return braceIndent;
+* Get the state of the namespace indentation option. If true, blocks
+* of the 'namespace' statement will be indented one additional indent.
+* @return   state of namespaceIndent option.
+bool ASBeautifier::getNamespaceIndent() const
+	return namespaceIndent;
+ * Get the state of the class indentation option. If true, blocks of
+ * the 'class' statement will be indented one additional indent.
+ * @return   state of classIndent option.
+bool ASBeautifier::getClassIndent() const
+	return classIndent;
+ * Get the state of the class access modifier indentation option.
+ * If true, the class access modifiers will be indented one-half indent.
+ * @return   state of modifierIndent option.
+bool ASBeautifier::getModifierIndent() const
+	return modifierIndent;
+ * get the state of the switch indentation option. If true, blocks of
+ * the 'switch' statement will be indented one additional indent.
+ * @return   state of switchIndent option.
+bool ASBeautifier::getSwitchIndent() const
+	return switchIndent;
+ * get the state of the case indentation option. If true, lines of 'case'
+ * @return   state of caseIndent option.
+bool ASBeautifier::getCaseIndent() const
+	return caseIndent;
+ * get the state of the empty line fill option.
+ * @return   state of emptyLineFill option.
+bool ASBeautifier::getEmptyLineFill() const
+	return emptyLineFill;
+ * get the state of the preprocessor indentation option.
+ * If true, preprocessor "define" lines will be indented.
+ * If false, preprocessor "define" lines will be unchanged.
+ * @return   state of shouldIndentPreprocDefine option.
+bool ASBeautifier::getPreprocDefineIndent() const
+	return shouldIndentPreprocDefine;
+ * get the length of the tab indentation option.
+ * @return   length of tab indent option.
+int ASBeautifier::getTabLength() const
+	return tabLength;
+ * beautify a line of source code.
+ * every line of source code in a source code file should be sent
+ * one after the other to the beautify method.
+ * @return      the indented line.
+ * @param originalLine       the original unindented line.
+string ASBeautifier::beautify(const string& originalLine)
+	string line;
+	bool isInQuoteContinuation = isInVerbatimQuote || haveLineContinuationChar;
+	blockCommentNoBeautify = blockCommentNoIndent;
+	lineStartsInComment = isInComment;
+	if (isImmediatelyPostObjCMethodDefinition)
+		clearObjCMethodDefinitionAlignment();
+	if (isImmediatelyPostObjCMethodCall)
+	// handle and remove white spaces around the line:
+	// If not in comment, first find out size of white space before line,
+	// so that possible comments starting in the line continue in
+	// relation to the preliminary white-space.
+	if (isInQuoteContinuation)
+		// trim a single space added by ASFormatter, otherwise leave it alone
+		if (!(originalLine.length() == 1 && originalLine[0] == ' '))
+			line = originalLine;
+	else if (isInComment || isInBeautifySQL)
+		// trim the end of comment and SQL lines
+		size_t trimEnd = line.find_last_not_of(" \t");
+		if (trimEnd == string::npos)
+			trimEnd = 0;
+		else
+			trimEnd++;
+		if (trimEnd < line.length())
+			line.erase(trimEnd);
+		// does a brace open the line
+		size_t firstChar = line.find_first_not_of(" \t");
+		if (firstChar != string::npos)
+			if (line[firstChar] == '{')
+				lineBeginsWithOpenBrace = true;
+			else if (line[firstChar] == '}')
+				lineBeginsWithCloseBrace = true;
+			else if (line[firstChar] == ',')
+				lineBeginsWithComma = true;
+	else
+		line = trim(originalLine);
+		if (line.length() > 0)
+			if (line[0] == '{')
+			else if (line[0] == '}')
+			else if (line[0] == ',')
+			else if (line.compare(0, 2, "//") == 0)
+				lineIsLineCommentOnly = true;
+			else if (line.compare(0, 2, "/*") == 0)
+				if (line.find("*/", 2) != string::npos)
+					lineIsCommentOnly = true;
+		size_t j = line.find_first_not_of(" \t{");
+		if (j != string::npos && line.compare(j, 2, "//") == 0)
+			lineOpensWithLineComment = true;
+		if (j != string::npos && line.compare(j, 2, "/*") == 0)
+			lineOpensWithComment = true;
+			size_t k = line.find_first_not_of(" \t");
+			if (k != string::npos && line.compare(k, 1, "{") == 0)
+				isInRunInComment = true;
+	// When indent is OFF the lines must still be processed by ASBeautifier.
+	// Otherwise the lines immediately following may not be indented correctly.
+	if ((lineIsLineCommentOnly || lineIsCommentOnly)
+	        && line.find("*INDENT-OFF*", 0) != string::npos)
+		isIndentModeOff = true;
+	if (line.length() == 0)
+		if (backslashEndsPrevLine)
+			// check if this line ends a multi-line #define
+			// if so, remove the #define's cloned beautifier from the active
+			// beautifier stack and delete it.
+			if (isInDefineDefinition && !isInDefine)
+				if (!activeBeautifierStack->empty())
+					ASBeautifier* defineBeautifier = activeBeautifierStack->back();
+					activeBeautifierStack->pop_back();
+					delete defineBeautifier;
+		if (emptyLineFill && !isInQuoteContinuation)
+			if (isInIndentablePreprocBlock)
+				return preLineWS(preprocBlockIndent, 0);
+			if (!headerStack->empty() || isInEnum)
+				return preLineWS(prevFinalLineIndentCount, prevFinalLineSpaceIndentCount);
+			// must fall thru here
+		else
+			return line;
+	// handle preprocessor commands
+	        && line.length() > 0
+	        && line[0] != '#')
+		string indentedLine;
+		if (isInClassHeaderTab || isInClassInitializer)
+			// parsing is turned off in ASFormatter by indent-off
+			// the originalLine will probably never be returned here
+			indentedLine = preLineWS(prevFinalLineIndentCount, prevFinalLineSpaceIndentCount) + line;
+			return getIndentedLineReturn(indentedLine, originalLine);
+		indentedLine = preLineWS(preprocBlockIndent, 0) + line;
+	if (!isInComment
+	        && !isInQuoteContinuation
+	        && ((line[0] == '#' && !isIndentedPreprocessor(line, 0))
+	            || backslashEndsPrevLine))
+		if (line[0] == '#' && !isInDefine)
+			string preproc = extractPreprocessorStatement(line);
+			processPreprocessor(preproc, line);
+			if (isInIndentablePreprocBlock || isInIndentablePreproc)
+				if ((preproc.length() >= 2 && preproc.substr(0, 2) == "if")) // #if, #ifdef, #ifndef
+					preprocBlockIndent += 1;
+					isInIndentablePreprocBlock = true;
+				else if (preproc == "else" || preproc == "elif")
+					indentedLine = preLineWS(preprocBlockIndent - 1, 0) + line;
+				else if (preproc == "endif")
+					preprocBlockIndent -= 1;
+					if (preprocBlockIndent == 0)
+				else
+			if (shouldIndentPreprocConditional && preproc.length() > 0)
+				if (preproc.length() >= 2 && preproc.substr(0, 2) == "if") // #if, #ifdef, #ifndef
+					pair<int, int> entry;	// indentCount, spaceIndentCount
+					if (!isInDefine && activeBeautifierStack != nullptr && !activeBeautifierStack->empty())
+						entry = activeBeautifierStack->back()->computePreprocessorIndent();
+					else
+						entry = computePreprocessorIndent();
+					preprocIndentStack->emplace_back(entry);
+					indentedLine = preLineWS(preprocIndentStack->back().first,
+					                         preprocIndentStack->back().second) + line;
+				if (preproc == "else" || preproc == "elif")
+					if (!preprocIndentStack->empty())	// if no entry don't indent
+						preprocIndentStack->pop_back();
+		// check if the last char is a backslash
+			backslashEndsPrevLine = (line[line.length() - 1] == '\\');
+		// comments within the definition line can be continued without the backslash
+		if (isInPreprocessorUnterminatedComment(line))
+			backslashEndsPrevLine = true;
+		// if so, use the #define's cloned beautifier for the line's indentation
+		// and then remove it from the active beautifier stack and delete it.
+		if (!backslashEndsPrevLine && isInDefineDefinition && !isInDefine)
+			// this could happen with invalid input
+			if (activeBeautifierStack->empty())
+				return originalLine;
+			string indentedLine = defineBeautifier->beautify(line);
+		// unless this is a multi-line #define, return this precompiler line as is.
+		if (!isInDefine && !isInDefineDefinition)
+	// if there exists any worker beautifier in the activeBeautifierStack,
+	// then use it instead of me to indent the current line.
+	// variables set by ASFormatter must be updated.
+		activeBeautifierStack->back()->inLineNumber = inLineNumber;
+		activeBeautifierStack->back()->runInIndentContinuation = runInIndentContinuation;
+		activeBeautifierStack->back()->nonInStatementBrace = nonInStatementBrace;
+		activeBeautifierStack->back()->objCColonAlignSubsequent = objCColonAlignSubsequent;
+		activeBeautifierStack->back()->lineCommentNoBeautify = lineCommentNoBeautify;
+		activeBeautifierStack->back()->isElseHeaderIndent = isElseHeaderIndent;
+		activeBeautifierStack->back()->isCaseHeaderCommentIndent = isCaseHeaderCommentIndent;
+		activeBeautifierStack->back()->isNonInStatementArray = isNonInStatementArray;
+		activeBeautifierStack->back()->isSharpAccessor = isSharpAccessor;
+		activeBeautifierStack->back()->isSharpDelegate = isSharpDelegate;
+		activeBeautifierStack->back()->isInExternC = isInExternC;
+		activeBeautifierStack->back()->isInBeautifySQL = isInBeautifySQL;
+		activeBeautifierStack->back()->isInIndentableStruct = isInIndentableStruct;
+		activeBeautifierStack->back()->isInIndentablePreproc = isInIndentablePreproc;
+		// must return originalLine not the trimmed line
+		return activeBeautifierStack->back()->beautify(originalLine);
+	// Flag an indented header in case this line is a one-line block.
+	// The header in the header stack will be deleted by a one-line block.
+	bool isInExtraHeaderIndent = false;
+	        && lineBeginsWithOpenBrace
+	        && (headerStack->back() != &AS_OPEN_BRACE
+	            || probationHeader != nullptr))
+		isInExtraHeaderIndent = true;
+	size_t iPrelim = headerStack->size();
+	// calculate preliminary indentation based on headerStack and data from past lines
+	computePreliminaryIndentation();
+	// parse characters in the current line.
+	parseCurrentLine(line);
+	// handle special cases of indentation
+	adjustParsedLineIndentation(iPrelim, isInExtraHeaderIndent);
+	if (isInObjCMethodDefinition)
+		adjustObjCMethodDefinitionIndentation(line);
+	if (isInObjCMethodCall)
+		adjustObjCMethodCallIndentation(line);
+	if (isInDefine)
+		if (line.length() > 0 && line[0] == '#')
+			// the 'define' does not have to be attached to the '#'
+			string preproc = trim(line.substr(1));
+			if (preproc.compare(0, 6, "define") == 0)
+				if (!continuationIndentStack->empty()
+				        && continuationIndentStack->back() > 0)
+					defineIndentCount = indentCount;
+				else
+					defineIndentCount = indentCount - 1;
+					--indentCount;
+		indentCount -= defineIndentCount;
+	if (indentCount < 0)
+		indentCount = 0;
+	if (lineCommentNoBeautify || blockCommentNoBeautify || isInQuoteContinuation)
+		indentCount = spaceIndentCount = 0;
+	// finally, insert indentations into beginning of line
+	string indentedLine = preLineWS(indentCount, spaceIndentCount) + line;
+	indentedLine = getIndentedLineReturn(indentedLine, originalLine);
+	prevFinalLineSpaceIndentCount = spaceIndentCount;
+	prevFinalLineIndentCount = indentCount;
+	if (lastLineHeader != nullptr)
+		previousLastLineHeader = lastLineHeader;
+	        && line.find("*INDENT-ON*", 0) != string::npos)
+	return indentedLine;
+const string& ASBeautifier::getIndentedLineReturn(const string& newLine, const string& originalLine) const
+	if (isIndentModeOff)
+	return newLine;
+string ASBeautifier::preLineWS(int lineIndentCount, int lineSpaceIndentCount) const
+	if (shouldForceTabIndentation)
+		if (tabLength != indentLength)
+			// adjust for different tab length
+			int indentCountOrig = lineIndentCount;
+			int spaceIndentCountOrig = lineSpaceIndentCount;
+			lineIndentCount = ((indentCountOrig * indentLength) + spaceIndentCountOrig) / tabLength;
+			lineSpaceIndentCount = ((indentCountOrig * indentLength) + spaceIndentCountOrig) % tabLength;
+		else
+			lineIndentCount += lineSpaceIndentCount / indentLength;
+			lineSpaceIndentCount = lineSpaceIndentCount % indentLength;
+	string ws;
+	for (int i = 0; i < lineIndentCount; i++)
+		ws += indentString;
+	while ((lineSpaceIndentCount--) > 0)
+		ws += string(" ");
+	return ws;
+ * register a continuation indent.
+void ASBeautifier::registerContinuationIndent(const string& line, int i, int spaceIndentCount_,
+                                              int tabIncrementIn, int minIndent, bool updateParenStack)
+	assert(i >= -1);
+	int remainingCharNum = line.length() - i;
+	int nextNonWSChar = getNextProgramCharDistance(line, i);
+	// if indent is around the last char in the line OR indent-after-paren is requested,
+	// indent with the continuation indent
+	if (nextNonWSChar == remainingCharNum || shouldIndentAfterParen)
+		int previousIndent = spaceIndentCount_;
+		if (!continuationIndentStack->empty())
+			previousIndent = continuationIndentStack->back();
+		int currIndent = continuationIndent * indentLength + previousIndent;
+		if (currIndent > maxContinuationIndent && line[i] != '{')
+			currIndent = indentLength * 2 + spaceIndentCount_;
+		continuationIndentStack->emplace_back(currIndent);
+		if (updateParenStack)
+			parenIndentStack->emplace_back(previousIndent);
+		return;
+		parenIndentStack->emplace_back(i + spaceIndentCount_ - runInIndentContinuation);
+		if (parenIndentStack->back() < 0)
+			parenIndentStack->back() = 0;
+	int tabIncrement = tabIncrementIn;
+	// check for following tabs
+	for (int j = i + 1; j < (i + nextNonWSChar); j++)
+		if (line[j] == '\t')
+			tabIncrement += convertTabToSpaces(j, tabIncrement);
+	int continuationIndentCount = i + nextNonWSChar + spaceIndentCount_ + tabIncrement;
+	// check for run-in statement
+	if (i > 0 && line[0] == '{')
+		continuationIndentCount -= indentLength;
+	if (continuationIndentCount < minIndent)
+		continuationIndentCount = minIndent + spaceIndentCount_;
+	// this is not done for an in-statement array
+	if (continuationIndentCount > maxContinuationIndent
+	        && !(prevNonLegalCh == '=' && currentNonLegalCh == '{'))
+		continuationIndentCount = indentLength * 2 + spaceIndentCount_;
+	        && continuationIndentCount < continuationIndentStack->back())
+		continuationIndentCount = continuationIndentStack->back();
+	// the block opener is not indented for a NonInStatementArray
+	if ((isNonInStatementArray && i >= 0 && line[i] == '{')
+	        && !isInEnum && !braceBlockStateStack->empty() && braceBlockStateStack->back())
+		continuationIndentCount = 0;
+	continuationIndentStack->emplace_back(continuationIndentCount);
+* Register a continuation indent for a class header or a class initializer colon.
+void ASBeautifier::registerContinuationIndentColon(const string& line, int i, int tabIncrementIn)
+	assert(line[i] == ':');
+	assert(isInClassInitializer || isInClassHeaderTab);
+	// register indent at first word after the colon
+	if (firstChar == (size_t) i)		// firstChar is ':'
+		size_t firstWord = line.find_first_not_of(" \t", firstChar + 1);
+		if (firstWord != string::npos)
+			int continuationIndentCount = firstWord + spaceIndentCount + tabIncrementIn;
+			isContinuation = true;
+ * Compute indentation for a preprocessor #if statement.
+ * This may be called for the activeBeautiferStack
+ * instead of the active ASBeautifier object.
+pair<int, int> ASBeautifier::computePreprocessorIndent()
+	pair<int, int> entry(indentCount, spaceIndentCount);
+	        && entry.first > 0
+	        && (headerStack->back() == &AS_IF
+	            || headerStack->back() == &AS_ELSE
+	            || headerStack->back() == &AS_FOR
+	            || headerStack->back() == &AS_WHILE))
+		--entry.first;
+	return entry;
+ * get distance to the next non-white space, non-comment character in the line.
+ * if no such character exists, return the length remaining to the end of the line.
+int ASBeautifier::getNextProgramCharDistance(const string& line, int i) const
+	bool inComment = false;
+	int  charDistance;
+	char ch;
+	for (charDistance = 1; charDistance < remainingCharNum; charDistance++)
+		ch = line[i + charDistance];
+		if (inComment)
+			if (line.compare(i + charDistance, 2, "*/") == 0)
+				charDistance++;
+				inComment = false;
+			continue;
+		else if (isWhiteSpace(ch))
+			continue;
+		else if (ch == '/')
+			if (line.compare(i + charDistance, 2, "//") == 0)
+				return remainingCharNum;
+			if (line.compare(i + charDistance, 2, "/*") == 0)
+				charDistance++;
+				inComment = true;
+		else
+			return charDistance;
+ * find the index number of a string element in a container of strings
+ * @return              the index number of element in the container. -1 if element not found.
+ * @param container     a vector of strings.
+ * @param element       the element to find .
+int ASBeautifier::indexOf(const vector<const string*>& container, const string* element) const
+	vector<const string*>::const_iterator where;
+	where = find(container.begin(), container.end(), element);
+	if (where == container.end())
+		return -1;
+	return (int) (where - container.begin());
+ * convert tabs to spaces.
+ * i is the position of the character to convert to spaces.
+ * tabIncrementIn is the increment that must be added for tab indent characters
+ *     to get the correct column for the current tab.
+int ASBeautifier::convertTabToSpaces(int i, int tabIncrementIn) const
+	int tabToSpacesAdjustment = indentLength - 1 - ((tabIncrementIn + i) % indentLength);
+	return tabToSpacesAdjustment;
+ * trim removes the white space surrounding a line.
+ * @return          the trimmed line.
+ * @param str       the line to trim.
+string ASBeautifier::trim(const string& str) const
+	int start = 0;
+	int end = str.length() - 1;
+	while (start < end && isWhiteSpace(str[start]))
+		start++;
+	while (start <= end && isWhiteSpace(str[end]))
+		end--;
+	// don't trim if it ends in a continuation
+	if (end > -1 && str[end] == '\\')
+		end = str.length() - 1;
+	string returnStr(str, start, end + 1 - start);
+	return returnStr;
+ * rtrim removes the white space from the end of a line.
+string ASBeautifier::rtrim(const string& str) const
+	size_t len = str.length();
+	size_t end = str.find_last_not_of(" \t");
+	if (end == string::npos
+	        || end == len - 1)
+		return str;
+	string returnStr(str, 0, end + 1);
+	return returnStr;
+ * Copy tempStacks for the copy constructor.
+ * The value of the vectors must also be copied.
+vector<vector<const string*>*>* ASBeautifier::copyTempStacks(const ASBeautifier& other) const
+	vector<vector<const string*>*>* tempStacksNew = new vector<vector<const string*>*>;
+	vector<vector<const string*>*>::iterator iter;
+	for (iter = other.tempStacks->begin();
+	        iter != other.tempStacks->end();
+	        ++iter)
+		vector<const string*>* newVec = new vector<const string*>;
+		*newVec = **iter;
+		tempStacksNew->emplace_back(newVec);
+	return tempStacksNew;
+ * delete a member vectors to eliminate memory leak reporting
+void ASBeautifier::deleteBeautifierVectors()
+	delete headers;
+	delete nonParenHeaders;
+	delete preBlockStatements;
+	delete preCommandHeaders;
+	delete assignmentOperators;
+	delete nonAssignmentOperators;
+	delete indentableHeaders;
+ * delete a vector object
+ * T is the type of vector
+ * used for all vectors except tempStacks
+template<typename T>
+void ASBeautifier::deleteContainer(T& container)
+	if (container != nullptr)
+		container->clear();
+		delete (container);
+		container = nullptr;
+ * Delete the ASBeautifier vector object.
+ * This is a vector of pointers to ASBeautifier objects allocated with the 'new' operator.
+ * Therefore the ASBeautifier objects have to be deleted in addition to the
+ * ASBeautifier pointer entries.
+void ASBeautifier::deleteBeautifierContainer(vector<ASBeautifier*>*& container)
+		vector<ASBeautifier*>::iterator iter = container->begin();
+		while (iter < container->end())
+			delete *iter;
+			++iter;
+ * Delete the tempStacks vector object.
+ * The tempStacks is a vector of pointers to strings allocated with the 'new' operator.
+ * Therefore the strings have to be deleted in addition to the tempStacks entries.
+void ASBeautifier::deleteTempStacksContainer(vector<vector<const string*>*>*& container)
+		vector<vector<const string*>*>::iterator iter = container->begin();
+			delete *iter;
+			++iter;
+ * initialize a vector object
+ * T is the type of vector used for all vectors
+void ASBeautifier::initContainer(T& container, T value)
+	// since the ASFormatter object is never deleted,
+	// the existing vectors must be deleted before creating new ones
+		deleteContainer(container);
+	container = value;
+ * Initialize the tempStacks vector object.
+ * Any residual entries are deleted before the vector is initialized.
+void ASBeautifier::initTempStacksContainer(vector<vector<const string*>*>*& container,
+                                           vector<vector<const string*>*>* value)
+		deleteTempStacksContainer(container);
+ * Determine if an assignment statement ends with a comma
+ *     that is not in a function argument. It ends with a
+ *     comma if a comma is the last char on the line.
+ * @return  true if line ends with a comma, otherwise false.
+bool ASBeautifier::statementEndsWithComma(const string& line, int index) const
+	assert(line[index] == '=');
+	bool isInComment_ = false;
+	bool isInQuote_ = false;
+	int parenCount = 0;
+	size_t lineLength = line.length();
+	size_t i = 0;
+	char quoteChar_ = ' ';
+	for (i = index + 1; i < lineLength; ++i)
+		char ch = line[i];
+		if (isInComment_)
+			if (line.compare(i, 2, "*/") == 0)
+				isInComment_ = false;
+				++i;
+			continue;
+		if (ch == '\\')
+			++i;
+			continue;
+		if (isInQuote_)
+			if (ch == quoteChar_)
+				isInQuote_ = false;
+			continue;
+		if (ch == '"'
+		        || (ch == '\'' && !isDigitSeparator(line, i)))
+			isInQuote_ = true;
+			quoteChar_ = ch;
+			continue;
+		if (line.compare(i, 2, "//") == 0)
+			break;
+		if (line.compare(i, 2, "/*") == 0)
+			if (isLineEndComment(line, i))
+				break;
+			else
+				isInComment_ = true;
+				++i;
+				continue;
+		if (ch == '(')
+			parenCount++;
+		if (ch == ')')
+			parenCount--;
+	if (isInComment_
+	        || isInQuote_
+	        || parenCount > 0)
+		return false;
+	size_t lastChar = line.find_last_not_of(" \t", i - 1);
+	if (lastChar == string::npos || line[lastChar] != ',')
+		return false;
+	return true;
+ * check if current comment is a line-end comment
+ * @return     is before a line-end comment.
+bool ASBeautifier::isLineEndComment(const string& line, int startPos) const
+	assert(line.compare(startPos, 2, "/*") == 0);
+	// comment must be closed on this line with nothing after it
+	size_t endNum = line.find("*/", startPos + 2);
+	if (endNum != string::npos)
+		size_t nextChar = line.find_first_not_of(" \t", endNum + 2);
+		if (nextChar == string::npos)
+			return true;
+	return false;
+ * get the previous word index for an assignment operator
+ * @return is the index to the previous word (the in statement indent).
+int ASBeautifier::getContinuationIndentAssign(const string& line, size_t currPos) const
+	assert(line[currPos] == '=');
+	if (currPos == 0)
+		return 0;
+	// get the last legal word (may be a number)
+	size_t end = line.find_last_not_of(" \t", currPos - 1);
+	if (end == string::npos || !isLegalNameChar(line[end]))
+		return 0;
+	int start;          // start of the previous word
+	for (start = end; start > -1; start--)
+		if (!isLegalNameChar(line[start]))
+			break;
+	start++;
+	return start;
+ * get the instatement indent for a comma
+ * @return is the indent to the second word on the line (the in statement indent).
+int ASBeautifier::getContinuationIndentComma(const string& line, size_t currPos) const
+	assert(line[currPos] == ',');
+	// get first word on a line
+	size_t indent = line.find_first_not_of(" \t");
+	if (indent == string::npos || !isLegalNameChar(line[indent]))
+		return 0;
+	// bypass first word
+	for (; indent < currPos; indent++)
+		if (!isLegalNameChar(line[indent]))
+			break;
+	indent++;
+	if (indent >= currPos || indent < 4)
+		return 0;
+	// point to second word or assignment operator
+	indent = line.find_first_not_of(" \t", indent);
+	if (indent == string::npos || indent >= currPos)
+		return 0;
+	return indent;
+ * get the next word on a line
+ * the argument 'currPos' must point to the current position.
+ * @return is the next word or an empty string if none found.
+string ASBeautifier::getNextWord(const string& line, size_t currPos) const
+	if (currPos == lineLength - 1)
+		return string();
+	size_t start = line.find_first_not_of(" \t", currPos + 1);
+	if (start == string::npos || !isLegalNameChar(line[start]))
+		return string();
+	size_t end;			// end of the current word
+	for (end = start + 1; end <= lineLength; end++)
+		if (!isLegalNameChar(line[end]) || line[end] == '.')
+			break;
+	return line.substr(start, end - start);
+ * Check if a preprocessor directive is always indented.
+ * C# "region" and "endregion" are always indented.
+ * C/C++ "pragma omp" is always indented.
+ * @return is true or false.
+bool ASBeautifier::isIndentedPreprocessor(const string& line, size_t currPos) const
+	assert(line[0] == '#');
+	string nextWord = getNextWord(line, currPos);
+	if (nextWord == "region" || nextWord == "endregion")
+		return true;
+	// is it #pragma omp
+	if (nextWord == "pragma")
+		// find pragma
+		size_t start = line.find("pragma");
+			return false;
+		// bypass pragma
+		for (; start < line.length(); start++)
+				break;
+		start++;
+		if (start >= line.length())
+			return false;
+		// point to start of second word
+		start = line.find_first_not_of(" \t", start);
+		if (start == string::npos)
+			return false;
+		// point to end of second word
+		size_t end;
+		for (end = start; end < line.length(); end++)
+			if (!isLegalNameChar(line[end]))
+				break;
+		// check for "pragma omp"
+		string word = line.substr(start, end - start);
+		if (word == "omp" || word == "region" || word == "endregion")
+			return true;
+	return false;
+ * Check if a preprocessor directive is checking for __cplusplus defined.
+bool ASBeautifier::isPreprocessorConditionalCplusplus(const string& line) const
+	if (preproc.compare(0, 5, "ifdef") == 0 && getNextWord(preproc, 4) == "__cplusplus")
+		return true;
+	if (preproc.compare(0, 2, "if") == 0)
+		// check for " #if defined(__cplusplus)"
+		size_t charNum = 2;
+		charNum = preproc.find_first_not_of(" \t", charNum);
+		if (charNum != string::npos && preproc.compare(charNum, 7, "defined") == 0)
+			charNum += 7;
+			if (charNum != string::npos && preproc.compare(charNum, 1, "(") == 0)
+				++charNum;
+				if (charNum != string::npos && preproc.compare(charNum, 11, "__cplusplus") == 0)
+					return true;
+	return false;
+ * Check if a preprocessor definition contains an unterminated comment.
+ * Comments within a preprocessor definition can be continued without the backslash.
+bool ASBeautifier::isInPreprocessorUnterminatedComment(const string& line)
+	if (!isInPreprocessorComment)
+		size_t startPos = line.find("/*");
+		if (startPos == string::npos)
+			return false;
+	size_t endNum = line.find("*/");
+		return false;
+	isInPreprocessorComment = true;
+	return true;
+void ASBeautifier::popLastContinuationIndent()
+	assert(!continuationIndentStackSizeStack->empty());
+	int previousIndentStackSize = continuationIndentStackSizeStack->back();
+	if (continuationIndentStackSizeStack->size() > 1)
+		continuationIndentStackSizeStack->pop_back();
+	while (previousIndentStackSize < (int) continuationIndentStack->size())
+		continuationIndentStack->pop_back();
+// for unit testing
+int ASBeautifier::getBeautifierFileType() const
+{ return beautifierFileType; }
+ * Process preprocessor statements and update the beautifier stacks.
+void ASBeautifier::processPreprocessor(const string& preproc, const string& line)
+	// When finding a multi-lined #define statement, the original beautifier
+	// 1. sets its isInDefineDefinition flag
+	// 2. clones a new beautifier that will be used for the actual indentation
+	//    of the #define. This clone is put into the activeBeautifierStack in order
+	//    to be called for the actual indentation.
+	// The original beautifier will have isInDefineDefinition = true, isInDefine = false
+	// The cloned beautifier will have   isInDefineDefinition = true, isInDefine = true
+	if (shouldIndentPreprocDefine && preproc == "define" && line[line.length() - 1] == '\\')
+		if (!isInDefineDefinition)
+			// this is the original beautifier
+			isInDefineDefinition = true;
+			// push a new beautifier into the active stack
+			// this beautifier will be used for the indentation of this define
+			ASBeautifier* defineBeautifier = new ASBeautifier(*this);
+			activeBeautifierStack->emplace_back(defineBeautifier);
+		else
+			// the is the cloned beautifier that is in charge of indenting the #define.
+			isInDefine = true;
+	else if (preproc.length() >= 2 && preproc.substr(0, 2) == "if")
+		if (isPreprocessorConditionalCplusplus(line) && !g_preprocessorCppExternCBrace)
+			g_preprocessorCppExternCBrace = 1;
+		// push a new beautifier into the stack
+		waitingBeautifierStackLengthStack->push_back(waitingBeautifierStack->size());
+		activeBeautifierStackLengthStack->push_back(activeBeautifierStack->size());
+		if (activeBeautifierStackLengthStack->back() == 0)
+			waitingBeautifierStack->emplace_back(new ASBeautifier(*this));
+		else
+			waitingBeautifierStack->emplace_back(new ASBeautifier(*activeBeautifierStack->back()));
+	else if (preproc == "else")
+		if ((waitingBeautifierStack != nullptr) && !waitingBeautifierStack->empty())
+			// MOVE current waiting beautifier to active stack.
+			activeBeautifierStack->emplace_back(waitingBeautifierStack->back());
+			waitingBeautifierStack->pop_back();
+	else if (preproc == "elif")
+			// append a COPY current waiting beautifier to active stack, WITHOUT deleting the original.
+			activeBeautifierStack->emplace_back(new ASBeautifier(*(waitingBeautifierStack->back())));
+		int stackLength = 0;
+		ASBeautifier* beautifier = nullptr;
+		if (waitingBeautifierStackLengthStack != nullptr && !waitingBeautifierStackLengthStack->empty())
+			stackLength = waitingBeautifierStackLengthStack->back();
+			waitingBeautifierStackLengthStack->pop_back();
+			while ((int) waitingBeautifierStack->size() > stackLength)
+				beautifier = waitingBeautifierStack->back();
+				delete beautifier;
+		if (!activeBeautifierStackLengthStack->empty())
+			stackLength = activeBeautifierStackLengthStack->back();
+			activeBeautifierStackLengthStack->pop_back();
+			while ((int) activeBeautifierStack->size() > stackLength)
+				beautifier = activeBeautifierStack->back();
+// Compute the preliminary indentation based on data in the headerStack
+// and data from previous lines.
+// Update the class variable indentCount.
+void ASBeautifier::computePreliminaryIndentation()
+	indentCount = 0;
+	if (isInObjCMethodDefinition && !continuationIndentStack->empty())
+		spaceIndentObjCMethodAlignment = continuationIndentStack->back();
+		spaceIndentCount = continuationIndentStack->back();
+	for (size_t i = 0; i < headerStack->size(); i++)
+		if (blockIndent)
+			// do NOT indent opening block for these headers
+			if (!((*headerStack)[i] == &AS_NAMESPACE
+			        || (*headerStack)[i] == &AS_MODULE
+			        || (*headerStack)[i] == &AS_CLASS
+			        || (*headerStack)[i] == &AS_STRUCT
+			        || (*headerStack)[i] == &AS_UNION
+			        || (*headerStack)[i] == &AS_INTERFACE
+			        || (*headerStack)[i] == &AS_THROWS
+			        || (*headerStack)[i] == &AS_STATIC))
+				++indentCount;
+		else if (!(i > 0 && (*headerStack)[i - 1] != &AS_OPEN_BRACE
+		           && (*headerStack)[i] == &AS_OPEN_BRACE))
+			++indentCount;
+		if (!isJavaStyle() && !namespaceIndent && i > 0
+		        && ((*headerStack)[i - 1] == &AS_NAMESPACE
+		            || (*headerStack)[i - 1] == &AS_MODULE)
+			--indentCount;
+		if (isCStyle() && i >= 1
+		        && (*headerStack)[i - 1] == &AS_CLASS
+			if (classIndent)
+				++indentCount;
+			isInClass = true;
+		// is the switchIndent option is on, indent switch statements an additional indent.
+		else if (switchIndent && i > 1
+		         && (*headerStack)[i - 1] == &AS_SWITCH
+			++indentCount;
+			isInSwitch = true;
+	}	// end of for loop
+	if (isInClassHeader)
+		if (!isJavaStyle())
+			isInClassHeaderTab = true;
+		if (lineOpensWithLineComment || lineStartsInComment || lineOpensWithComment)
+			if (!lineBeginsWithOpenBrace)
+				--indentCount;
+				spaceIndentCount -= continuationIndentStack->back();
+		else if (blockIndent)
+				++indentCount;
+	if (isInClassInitializer || isInEnumTypeID)
+		indentCount += classInitializerIndents;
+	if (isInEnum && lineBeginsWithComma && !continuationIndentStack->empty())
+		// unregister '=' indent from the previous line
+	// Objective-C interface continuation line
+	if (isInObjCInterface)
+		++indentCount;
+	// unindent a class closing brace...
+	if (!lineStartsInComment
+	        && isCStyle()
+	        && isInClass
+	        && classIndent
+	        && headerStack->size() >= 2
+	        && (*headerStack)[headerStack->size() - 2] == &AS_CLASS
+	        && (*headerStack)[headerStack->size() - 1] == &AS_OPEN_BRACE
+	        && lineBeginsWithCloseBrace
+	        && braceBlockStateStack->back())
+		--indentCount;
+	// unindent an indented switch closing brace...
+	else if (!lineStartsInComment
+	         && isInSwitch
+	         && switchIndent
+	         && (*headerStack)[headerStack->size() - 2] == &AS_SWITCH
+	         && lineBeginsWithCloseBrace)
+		--indentCount;
+	// handle special case of run-in comment in an indented class statement
+	if (isInClass
+	        && classIndent
+	        && isInRunInComment
+	        && !lineOpensWithComment
+	        && headerStack->size() > 1
+	        && (*headerStack)[headerStack->size() - 2] == &AS_CLASS)
+		--indentCount;
+	if (isInConditional)
+		--indentCount;
+	if (g_preprocessorCppExternCBrace >= 4)
+		--indentCount;
+void ASBeautifier::adjustParsedLineIndentation(size_t iPrelim, bool isInExtraHeaderIndent)
+	if (lineStartsInComment)
+		return;
+	// unindent a one-line statement in a header indent
+	if (!blockIndent
+	        && headerStack->size() < iPrelim
+	        && isInExtraHeaderIndent
+	        && (lineOpeningBlocksNum > 0 && lineOpeningBlocksNum <= lineClosingBlocksNum)
+	        && shouldIndentBracedLine)
+		--indentCount;
+	 * if '{' doesn't follow an immediately previous '{' in the headerStack
+	 * (but rather another header such as "for" or "if", then unindent it
+	 * by one indentation relative to its block.
+	else if (!blockIndent
+	         && !(lineOpeningBlocksNum > 0 && lineOpeningBlocksNum <= lineClosingBlocksNum)
+	         && (headerStack->size() > 1 && (*headerStack)[headerStack->size() - 2] != &AS_OPEN_BRACE)
+		--indentCount;
+	// must check one less in headerStack if more than one header on a line (allow-addins)...
+	else if (headerStack->size() > iPrelim + 1
+	         && !blockIndent
+	         && (headerStack->size() > 2 && (*headerStack)[headerStack->size() - 3] != &AS_OPEN_BRACE)
+		--indentCount;
+	// unindent a closing brace...
+	else if (lineBeginsWithCloseBrace
+		--indentCount;
+	// correctly indent one-line-blocks...
+	else if (lineOpeningBlocksNum > 0
+	         && lineOpeningBlocksNum == lineClosingBlocksNum
+	         && previousLineProbationTab)
+		--indentCount;
+		indentCount = 0;
+	// take care of extra brace indentation option...
+	        && braceIndent
+	        && (lineBeginsWithOpenBrace || lineBeginsWithCloseBrace))
+		if (!braceIndentVtk)
+			++indentCount;
+		else
+			// determine if a style VTK brace is indented
+			bool haveUnindentedBrace = false;
+				if (((*headerStack)[i] == &AS_NAMESPACE
+				        || (*headerStack)[i] == &AS_STRUCT)
+				        && i + 1 < headerStack->size()
+				        && (*headerStack)[i + 1] == &AS_OPEN_BRACE)
+					i++;
+				else if (lineBeginsWithOpenBrace)
+					// don't double count the current brace
+					if (i + 1 < headerStack->size()
+						haveUnindentedBrace = true;
+				else if ((*headerStack)[i] == &AS_OPEN_BRACE)
+			if (haveUnindentedBrace)
+				++indentCount;
+ * Compute indentCount adjustment when in a series of else-if statements
+ * and shouldBreakElseIfs is requested.
+ * It increments by one for each 'else' in the tempStack.
+int ASBeautifier::adjustIndentCountForBreakElseIfComments() const
+	assert(isElseHeaderIndent && !tempStacks->empty());
+	int indentCountIncrement = 0;
+	vector<const string*>* lastTempStack = tempStacks->back();
+	if (lastTempStack != nullptr)
+		for (size_t i = 0; i < lastTempStack->size(); i++)
+			if (*lastTempStack->at(i) == AS_ELSE)
+				indentCountIncrement++;
+	return indentCountIncrement;
+ * Extract a preprocessor statement without the #.
+ * If a error occurs an empty string is returned.
+string ASBeautifier::extractPreprocessorStatement(const string& line) const
+	string preproc;
+	size_t start = line.find_first_not_of("#/ \t");
+		return preproc;
+	size_t end = line.find_first_of("/ \t", start);
+	if (end == string::npos)
+		end = line.length();
+	preproc = line.substr(start, end - start);
+	return preproc;
+void ASBeautifier::adjustObjCMethodDefinitionIndentation(const string& line_)
+	// register indent for Objective-C continuation line
+	if (line_.length() > 0
+	        && (line_[0] == '-' || line_[0] == '+'))
+		if (shouldAlignMethodColon && objCColonAlignSubsequent != -1)
+			string convertedLine = getIndentedSpaceEquivalent(line_);
+			colonIndentObjCMethodAlignment = findObjCColonAlignment(convertedLine);
+			int objCColonAlignSubsequentIndent = objCColonAlignSubsequent + indentLength;
+			if (objCColonAlignSubsequentIndent > colonIndentObjCMethodAlignment)
+				colonIndentObjCMethodAlignment = objCColonAlignSubsequentIndent;
+		else if (continuationIndentStack->empty()
+		         || continuationIndentStack->back() == 0)
+			continuationIndentStack->emplace_back(indentLength);
+	// set indent for last definition line
+	else if (!lineBeginsWithOpenBrace)
+		if (shouldAlignMethodColon)
+			spaceIndentCount = computeObjCColonAlignment(line_, colonIndentObjCMethodAlignment);
+		else if (continuationIndentStack->empty())
+			spaceIndentCount = spaceIndentObjCMethodAlignment;
+void ASBeautifier::adjustObjCMethodCallIndentation(const string& line_)
+	static int keywordIndentObjCMethodAlignment = 0;
+		if (isInObjCMethodCallFirst)
+			bracePosObjCMethodAlignment = convertedLine.find('[');
+			keywordIndentObjCMethodAlignment =
+			    getObjCFollowingKeyword(convertedLine, bracePosObjCMethodAlignment);
+			if (colonIndentObjCMethodAlignment >= 0)
+				if (lineBeginsWithOpenBrace)
+					colonIndentObjCMethodAlignment -= indentLength;
+		else
+			if (findObjCColonAlignment(line_) != -1)
+				if (colonIndentObjCMethodAlignment < 0)
+					spaceIndentCount += computeObjCColonAlignment(line_, objCColonAlignSubsequent);
+				else if (objCColonAlignSubsequent > colonIndentObjCMethodAlignment)
+					spaceIndentCount = computeObjCColonAlignment(line_, objCColonAlignSubsequent);
+				else
+			else
+				if (spaceIndentCount < colonIndentObjCMethodAlignment)
+					spaceIndentCount += keywordIndentObjCMethodAlignment;
+	else    // align keywords instead of colons
+		else
+			if (spaceIndentCount < keywordIndentObjCMethodAlignment + bracePosObjCMethodAlignment)
+ * Clear the variables used to align the Objective-C method definitions.
+void ASBeautifier::clearObjCMethodDefinitionAlignment()
+	assert(isImmediatelyPostObjCMethodDefinition);
+ * Find the first alignment colon on a line.
+ * Ternary operators (?) are bypassed.
+int ASBeautifier::findObjCColonAlignment(const string& line) const
+	bool haveTernary = false;
+	for (size_t i = 0; i < line.length(); i++)
+		i = line.find_first_of(":?", i);
+		if (i == string::npos)
+			break;
+		if (line[i] == '?')
+			haveTernary = true;
+			continue;
+		if (haveTernary)
+			haveTernary = false;
+			continue;
+		return i;
+	return -1;
+ * Compute the spaceIndentCount necessary to align the current line colon
+ * with the colon position in the argument.
+ * If it cannot be aligned indentLength is returned and a new colon
+ * position is calculated.
+int ASBeautifier::computeObjCColonAlignment(const string& line, int colonAlignPosition) const
+	int colonPosition = findObjCColonAlignment(line);
+	if (colonPosition < 0 || colonPosition > colonAlignPosition)
+	return (colonAlignPosition - colonPosition);
+ * Compute position of the keyword following the method call object.
+ * This is oversimplified to find unusual method calls.
+ * Use for now and see what happens.
+ * Most programmers will probably use align-method-colon anyway.
+int ASBeautifier::getObjCFollowingKeyword(const string& line, int bracePos) const
+	assert(line[bracePos] == '[');
+	size_t firstText = line.find_first_not_of(" \t", bracePos + 1);
+	if (firstText == string::npos)
+		return -(indentCount * indentLength - 1);
+	size_t searchBeg = firstText;
+	size_t objectEnd = 0;	// end of object text
+	if (line[searchBeg] == '[')
+		objectEnd = line.find(']', searchBeg + 1);
+		if (objectEnd == string::npos)
+			return 0;
+	else
+		if (line[searchBeg] == '(')
+			searchBeg = line.find(')', searchBeg + 1);
+			if (searchBeg == string::npos)
+				return 0;
+		// bypass the object name
+		objectEnd = line.find_first_of(" \t", searchBeg + 1);
+			return 0;
+		--objectEnd;
+	size_t keyPos = line.find_first_not_of(" \t", objectEnd + 1);
+	if (keyPos == string::npos)
+		return 0;
+	return keyPos - firstText;
+ * Get a line using the current space indent with all tabs replaced by spaces.
+ * The indentCount is NOT included
+ * Needed to compute an accurate alignment.
+string ASBeautifier::getIndentedSpaceEquivalent(const string& line_) const
+	string spaceIndent;
+	spaceIndent.append(spaceIndentCount, ' ');
+	string convertedLine = spaceIndent + line_;
+	for (size_t i = spaceIndent.length(); i < convertedLine.length(); i++)
+		if (convertedLine[i] == '\t')
+			size_t numSpaces = indentLength - (i % indentLength);
+			convertedLine.replace(i, 1, numSpaces, ' ');
+			i += indentLength - 1;
+	return convertedLine;
+ * Determine if an item is at a top level.
+bool ASBeautifier::isTopLevel() const
+	if (headerStack->empty())
+		return true;
+	else if (headerStack->back() == &AS_OPEN_BRACE
+	         && headerStack->size() >= 2)
+		if ((*headerStack)[headerStack->size() - 2] == &AS_NAMESPACE
+		        || (*headerStack)[headerStack->size() - 2] == &AS_MODULE
+		        || (*headerStack)[headerStack->size() - 2] == &AS_CLASS
+		        || (*headerStack)[headerStack->size() - 2] == &AS_INTERFACE
+		        || (*headerStack)[headerStack->size() - 2] == &AS_STRUCT
+		        || (*headerStack)[headerStack->size() - 2] == &AS_UNION)
+			return true;
+	else if (headerStack->back() == &AS_NAMESPACE
+	         || headerStack->back() == &AS_MODULE
+	         || headerStack->back() == &AS_CLASS
+	         || headerStack->back() == &AS_INTERFACE
+	         || headerStack->back() == &AS_STRUCT
+	         || headerStack->back() == &AS_UNION)
+		return true;
+	return false;
+ * Parse the current line to update indentCount and spaceIndentCount.
+void ASBeautifier::parseCurrentLine(const string& line)
+	bool isInLineComment = false;
+	bool isInOperator = false;
+	bool isSpecialChar = false;
+	bool haveCaseIndent = false;
+	bool haveAssignmentThisLine = false;
+	bool closingBraceReached = false;
+	bool previousLineProbation = (probationHeader != nullptr);
+	char ch = ' ';
+	int tabIncrementIn = 0;
+	if (isInQuote
+	        && !haveLineContinuationChar
+	        && !isInVerbatimQuote
+	        && !isInAsm)
+		isInQuote = false;				// missing closing quote
+		ch = line[i];
+		if (isInBeautifySQL)
+			continue;
+		// handle special characters (i.e. backslash+character such as \n, \t, ...)
+		if (isInQuote && !isInVerbatimQuote)
+			if (isSpecialChar)
+				isSpecialChar = false;
+				continue;
+			if (line.compare(i, 2, "\\\\") == 0)
+				i++;
+				continue;
+			if (ch == '\\')
+				if (peekNextChar(line, i) == ' ')   // is this '\' at end of line
+					haveLineContinuationChar = true;
+				else
+					isSpecialChar = true;
+				continue;
+		else if (isInDefine && ch == '\\')
+			continue;
+		// bypass whitespace here
+		if (isWhiteSpace(ch))
+			if (ch == '\t')
+				tabIncrementIn += convertTabToSpaces(i, tabIncrementIn);
+			continue;
+		// handle quotes (such as 'x' and "Hello Dolly")
+		if (!(isInComment || isInLineComment)
+		        && (ch == '"'
+		            || (ch == '\'' && !isDigitSeparator(line, i))))
+			if (!isInQuote)
+				quoteChar = ch;
+				isInQuote = true;
+				char prevCh = i > 0 ? line[i - 1] : ' ';
+				if (isCStyle() && prevCh == 'R')
+					int parenPos = line.find('(', i);
+					if (parenPos != -1)
+						isInVerbatimQuote = true;
+						verbatimDelimiter = line.substr(i + 1, parenPos - i - 1);
+				else if (isSharpStyle() && prevCh == '@')
+				// check for "C" following "extern"
+				else if (g_preprocessorCppExternCBrace == 2 && line.compare(i, 3, "\"C\"") == 0)
+					++g_preprocessorCppExternCBrace;
+			else if (isInVerbatimQuote && ch == '"')
+				if (isCStyle())
+					string delim = ')' + verbatimDelimiter;
+					int delimStart = i - delim.length();
+					if (delimStart > 0 && line.substr(delimStart, delim.length()) == delim)
+				else if (isSharpStyle())
+					if (line.compare(i, 2, "\"\"") == 0)
+						i++;
+					else
+						continue;
+			else if (quoteChar == ch)
+				continue;
+		if (isInQuote)
+			continue;
+		// handle comments
+		if (!(isInComment || isInLineComment) && line.compare(i, 2, "//") == 0)
+			// if there is a 'case' statement after these comments unindent by 1
+			if (isCaseHeaderCommentIndent)
+				--indentCount;
+			// isElseHeaderIndent is set by ASFormatter if shouldBreakElseIfs is requested
+			// if there is an 'else' after these comments a tempStacks indent is required
+			if (isElseHeaderIndent && lineOpensWithLineComment && !tempStacks->empty())
+				indentCount += adjustIndentCountForBreakElseIfComments();
+			isInLineComment = true;
+			i++;
+			continue;
+		else if (!(isInComment || isInLineComment) && line.compare(i, 2, "/*") == 0)
+			if (isCaseHeaderCommentIndent && lineOpensWithComment)
+				--indentCount;
+			if (isElseHeaderIndent && lineOpensWithComment && !tempStacks->empty())
+			isInComment = true;
+			i++;
+			if (!lineOpensWithComment)				// does line start with comment?
+				blockCommentNoIndent = true;        // if no, cannot indent continuation lines
+			continue;
+		else if ((isInComment || isInLineComment) && line.compare(i, 2, "*/") == 0)
+			size_t firstText = line.find_first_not_of(" \t");
+			// only if the ending comment is the first entry on the line
+			if (isCaseHeaderCommentIndent && firstText == i)
+				--indentCount;
+			// if this comment close starts the line, must check for else-if indent
+			if (firstText == i)
+				if (isElseHeaderIndent && !lineOpensWithComment && !tempStacks->empty())
+			i++;
+			blockCommentNoIndent = false;           // ok to indent next comment
+			continue;
+		// treat indented preprocessor lines as a line comment
+		else if (line[0] == '#' && isIndentedPreprocessor(line, i))
+		if (isInLineComment)
+			// bypass rest of the comment up to the comment end
+			while (i + 1 < line.length())
+				i++;
+			continue;
+		if (isInComment)
+			if (!lineOpensWithComment && isCaseHeaderCommentIndent)
+				--indentCount;
+			if (!lineOpensWithComment && isElseHeaderIndent && !tempStacks->empty())
+			        && line.compare(i + 1, 2, "*/") != 0)
+				i++;
+			continue;
+		// if we have reached this far then we are NOT in a comment or string of special character...
+		if (probationHeader != nullptr)
+			if ((probationHeader == &AS_STATIC && ch == '{')
+			        || (probationHeader == &AS_SYNCHRONIZED && ch == '('))
+				// insert the probation header as a new header
+				isInHeader = true;
+				headerStack->emplace_back(probationHeader);
+				// handle the specific probation header
+				isInConditional = (probationHeader == &AS_SYNCHRONIZED);
+				// if the probation comes from the previous line, then indent by 1 tab count.
+				if (previousLineProbation
+				        && ch == '{'
+				        && !(blockIndent && probationHeader == &AS_STATIC))
+					++indentCount;
+					previousLineProbationTab = true;
+				previousLineProbation = false;
+			// dismiss the probation header
+		prevNonSpaceCh = currentNonSpaceCh;
+		currentNonSpaceCh = ch;
+		if (!isLegalNameChar(ch) && ch != ',' && ch != ';')
+			prevNonLegalCh = currentNonLegalCh;
+			currentNonLegalCh = ch;
+		if (isInHeader)
+			currentHeader = headerStack->back();
+		else
+		if (isCStyle() && isInTemplate
+		        && (ch == '<' || ch == '>')
+		        && !(line.length() > i + 1 && line.compare(i, 2, ">=") == 0))
+			if (ch == '<')
+				++templateDepth;
+				continuationIndentStackSizeStack->push_back(continuationIndentStack->size());
+				registerContinuationIndent(line, i, spaceIndentCount, tabIncrementIn, 0, true);
+			else if (ch == '>')
+				popLastContinuationIndent();
+				if (--templateDepth <= 0)
+					ch = ';';
+		// handle parentheses
+		if (ch == '(' || ch == '[' || ch == ')' || ch == ']')
+			if (ch == '(' || ch == '[')
+				isInOperator = false;
+				// if have a struct header, this is a declaration not a definition
+				if (ch == '('
+				        && !headerStack->empty()
+				        && headerStack->back() == &AS_STRUCT)
+					headerStack->pop_back();
+					if (line.find(AS_STRUCT, 0) > i)	// if not on this line
+						indentCount -= classInitializerIndents;
+						indentCount = 0;
+				if (parenDepth == 0)
+					parenStatementStack->push_back(isContinuation);
+				parenDepth++;
+				if (ch == '[')
+					++squareBracketCount;
+					if (squareBracketCount == 1 && isCStyle())
+						isInObjCMethodCall = true;
+						isInObjCMethodCallFirst = true;
+				if (currentHeader != nullptr)
+					registerContinuationIndent(line, i, spaceIndentCount, tabIncrementIn, minConditionalIndent, true);
+				else if (!isInObjCMethodDefinition)
+			else if (ch == ')' || ch == ']')
+				if (ch == ']')
+					--squareBracketCount;
+				if (squareBracketCount <= 0)
+						isImmediatelyPostObjCMethodCall = true;
+				parenDepth--;
+					if (!parenStatementStack->empty())      // in case of unmatched closing parens
+						isContinuation = parenStatementStack->back();
+						parenStatementStack->pop_back();
+					isInAsm = false;
+				if (!continuationIndentStackSizeStack->empty())
+					if (!parenIndentStack->empty())
+						int poppedIndent = parenIndentStack->back();
+						parenIndentStack->pop_back();
+						if (i == 0)
+							spaceIndentCount = poppedIndent;
+			continue;
+		if (ch == '{')
+			// first, check if '{' is a block-opener or a static-array opener
+			bool isBlockOpener = ((prevNonSpaceCh == '{' && braceBlockStateStack->back())
+			                      || prevNonSpaceCh == '}'
+			                      || prevNonSpaceCh == ')'
+			                      || prevNonSpaceCh == ';'
+			                      || peekNextChar(line, i) == '{'
+			                      || isInTrailingReturnType
+			                      || foundPreCommandHeader
+			                      || foundPreCommandMacro
+			                      || isInClassHeader
+			                      || (isInClassInitializer && !isLegalNameChar(prevNonSpaceCh))
+			                      || isNonInStatementArray
+			                      || isInObjCMethodDefinition
+			                      || isInObjCInterface
+			                      || isSharpAccessor
+			                      || isSharpDelegate
+			                      || isInExternC
+			                      || isInAsmBlock
+			                      || getNextWord(line, i) == AS_NEW
+			                      || (isInDefine
+			                          && (prevNonSpaceCh == '('
+			                              || isLegalNameChar(prevNonSpaceCh))));
+				isImmediatelyPostObjCMethodDefinition = true;
+				if (lineBeginsWithOpenBrace)		// for run-in braces
+			if (!isBlockOpener && !isContinuation && !isInClassInitializer && !isInEnum)
+				if (isTopLevel())
+					isBlockOpener = true;
+			if (!isBlockOpener && currentHeader != nullptr)
+				for (size_t n = 0; n < nonParenHeaders->size(); n++)
+					if (currentHeader == (*nonParenHeaders)[n])
+						break;
+			braceBlockStateStack->push_back(isBlockOpener);
+			if (!isBlockOpener)
+				parenDepth++;
+				if (i == 0)
+					shouldIndentBracedLine = false;
+				continue;
+			// this brace is a block opener...
+			++lineOpeningBlocksNum;
+				// decrease tab count if brace is broken
+					// decrease one more if an empty class
+					        && (*headerStack).back() == &AS_CLASS)
+						int nextChar = getNextProgramCharDistance(line, i);
+						if ((int) line.length() > nextChar && line[nextChar] == '}')
+							--indentCount;
+					--indentCount;
+			if (braceIndent && !namespaceIndent && !headerStack->empty()
+			        && ((*headerStack).back() == &AS_NAMESPACE
+			            || (*headerStack).back() == &AS_MODULE))
+				--indentCount;
+			// an indentable struct is treated like a class in the header stack
+			        && (*headerStack).back() == &AS_STRUCT
+			        && isInIndentableStruct)
+				(*headerStack).back() = &AS_CLASS;
+			// is a brace inside a paren?
+			parenDepthStack->emplace_back(parenDepth);
+			blockStatementStack->push_back(isContinuation);
+				// completely purge the continuationIndentStack
+				while (!continuationIndentStack->empty())
+				if (isInClassInitializer || isInClassHeaderTab)
+					if (lineBeginsWithOpenBrace || lineBeginsWithComma)
+				else
+			blockTabCount += (isContinuation ? 1 : 0);
+			if (g_preprocessorCppExternCBrace == 3)
+			parenDepth = 0;
+			isInClassHeader = false;
+			isInClassHeaderTab = false;
+			isInClassInitializer = false;
+			isContinuation = false;
+			isInQuestion = false;
+			isInLet = false;
+			tempStacks->emplace_back(new vector<const string*>);
+			headerStack->emplace_back(&AS_OPEN_BRACE);
+			lastLineHeader = &AS_OPEN_BRACE;
+			continue;
+		}	// end '{'
+		//check if a header has been reached
+		bool isPotentialHeader = isCharPotentialHeader(line, i);
+		if (isPotentialHeader && squareBracketCount == 0)
+			const string* newHeader = findHeader(line, i, headers);
+			// java can have a 'default' not in a switch
+			if (newHeader == &AS_DEFAULT
+			        && peekNextChar(line, (i + (*newHeader).length() - 1)) != ':')
+				newHeader = nullptr;
+			// Qt headers may be variables in C++
+			if (isCStyle()
+			        && (newHeader == &AS_FOREVER || newHeader == &AS_FOREACH))
+				if (line.find_first_of("=;", i) != string::npos)
+			         && (newHeader == &AS_GET || newHeader == &AS_SET))
+				if (getNextWord(line, i + (*newHeader).length()) == "is")
+			else if (newHeader == &AS_USING
+			         && peekNextChar(line, i + (*newHeader).length() - 1) != '(')
+			if (newHeader != nullptr)
+				// if we reached here, then this is a header...
+				bool isIndentableHeader = true;
+				vector<const string*>* lastTempStack = nullptr;;
+				if (!tempStacks->empty())
+					lastTempStack = tempStacks->back();
+				// if a new block is opened, push a new stack into tempStacks to hold the
+				// future list of headers in the new block.
+				// take care of the special case: 'else if (...)'
+				if (newHeader == &AS_IF && lastLineHeader == &AS_ELSE)
+					if (!headerStack->empty())
+				// take care of 'else'
+				else if (newHeader == &AS_ELSE)
+						int indexOfIf = indexOf(*lastTempStack, &AS_IF);
+						if (indexOfIf != -1)
+							// recreate the header list in headerStack up to the previous 'if'
+							// from the temporary snapshot stored in lastTempStack.
+							int restackSize = lastTempStack->size() - indexOfIf - 1;
+							for (int r = 0; r < restackSize; r++)
+								headerStack->emplace_back(lastTempStack->back());
+								lastTempStack->pop_back();
+							if (!closingBraceReached)
+								indentCount += restackSize;
+						 * If the above if is not true, i.e. no 'if' before the 'else',
+						 * then nothing beautiful will come out of this...
+						 * I should think about inserting an Exception here to notify the caller of this...
+				// check if 'while' closes a previous 'do'
+				else if (newHeader == &AS_WHILE)
+						int indexOfDo = indexOf(*lastTempStack, &AS_DO);
+						if (indexOfDo != -1)
+							// recreate the header list in headerStack up to the previous 'do'
+							int restackSize = lastTempStack->size() - indexOfDo - 1;
+				// check if 'catch' closes a previous 'try' or 'catch'
+				else if (newHeader == &AS_CATCH || newHeader == &AS_FINALLY)
+						int indexOfTry = indexOf(*lastTempStack, &AS_TRY);
+						if (indexOfTry == -1)
+							indexOfTry = indexOf(*lastTempStack, &AS_CATCH);
+						if (indexOfTry != -1)
+							// recreate the header list in headerStack up to the previous 'try'
+							int restackSize = lastTempStack->size() - indexOfTry - 1;
+				else if (newHeader == &AS_CASE)
+					isInCase = true;
+					if (!haveCaseIndent)
+						haveCaseIndent = true;
+							--indentCount;
+				else if (newHeader == &AS_DEFAULT)
+					isInCase = true;
+					--indentCount;
+				else if (newHeader == &AS_STATIC
+				         || newHeader == &AS_SYNCHRONIZED)
+					        && (headerStack->back() == &AS_STATIC
+					            || headerStack->back() == &AS_SYNCHRONIZED))
+						isIndentableHeader = false;
+					else
+						probationHeader = newHeader;
+				else if (newHeader == &AS_TEMPLATE)
+					isInTemplate = true;
+				if (isIndentableHeader)
+					headerStack->emplace_back(newHeader);
+					if (indexOf(*nonParenHeaders, newHeader) == -1)
+						isInConditional = true;
+					lastLineHeader = newHeader;
+				else
+					isInHeader = false;
+				i += newHeader->length() - 1;
+				continue;
+			}  // newHeader != nullptr
+			if (findHeader(line, i, preCommandHeaders) != nullptr)
+				// must be after function arguments
+				if (prevNonSpaceCh == ')')
+					foundPreCommandHeader = true;
+			// Objective-C NSException macros are preCommandHeaders
+			if (isCStyle() && findKeyword(line, i, AS_NS_DURING))
+				foundPreCommandMacro = true;
+			if (isCStyle() && findKeyword(line, i, AS_NS_HANDLER))
+			if (parenDepth == 0 && findKeyword(line, i, AS_ENUM))
+				isInEnum = true;
+			if (isSharpStyle() && findKeyword(line, i, AS_LET))
+				isInLet = true;
+		}   // isPotentialHeader
+		if (ch == '?')
+			isInQuestion = true;
+		// special handling of colons
+		if (ch == ':')
+			if (line.length() > i + 1 && line[i + 1] == ':') // look for ::
+				++i;
+				continue;
+			else if (isInQuestion)
+				// do nothing special
+			else if (parenDepth > 0)
+				// found a 'for' loop or an objective-C statement
+				// so do nothing special
+			else if (isInEnum)
+				// found an enum with a base-type
+				isInEnumTypeID = true;
+				if (i == 0)
+			else if ((isCStyle() || isSharpStyle())
+			         && !isInCase
+			         && (prevNonSpaceCh == ')' || foundPreCommandHeader))
+				// found a 'class' c'tor initializer
+				isInClassInitializer = true;
+				registerContinuationIndentColon(line, i, tabIncrementIn);
+				if (i == 0)
+			else if (isInClassHeader || isInObjCInterface)
+				// is in a 'class A : public B' definition
+			else if (isInAsm || isInAsmOneLine || isInAsmBlock)
+			else if (isDigit(peekNextChar(line, i)))
+				// found a bit field - do nothing special
+			else if (isCStyle() && isInClass && prevNonSpaceCh != ')')
+				// found a 'private:' or 'public:' inside a class definition
+				--indentCount;
+				if (modifierIndent)
+					spaceIndentCount += (indentLength / 2);
+			else if (isCStyle() && !isInClass
+			         && (*headerStack)[headerStack->size() - 1] == &AS_OPEN_BRACE)
+				// and on the same line as the class opening brace
+				// do nothing
+			else if (isJavaStyle() && lastLineHeader == &AS_FOR)
+				// found a java for-each statement
+			else
+				currentNonSpaceCh = ';'; // so that braces after the ':' will appear as block-openers
+				char peekedChar = peekNextChar(line, i);
+				if (isInCase)
+					isInCase = false;
+					ch = ';'; // from here on, treat char as ';'
+				else if (isCStyle() || (isSharpStyle() && peekedChar == ';'))
+					// is in a label (e.g. 'label1:')
+					if (labelIndent)
+						--indentCount; // unindent label by one indent
+						indentCount = 0; // completely flush indent to left
+		if ((ch == ';' || (parenDepth > 0 && ch == ',')) && !continuationIndentStackSizeStack->empty())
+			while ((int) continuationIndentStackSizeStack->back() + (parenDepth > 0 ? 1 : 0)
+			        < (int) continuationIndentStack->size())
+		else if (ch == ',' && isInEnum && isNonInStatementArray && !continuationIndentStack->empty())
+		// handle commas
+		// previous "isInStatement" will be from an assignment operator or class initializer
+		if (ch == ',' && parenDepth == 0 && !isContinuation && !isNonInStatementArray)
+			// is comma at end of line
+			size_t nextChar = line.find_first_not_of(" \t", i + 1);
+			if (nextChar != string::npos)
+				if (line.compare(nextChar, 2, "//") == 0
+				        || line.compare(nextChar, 2, "/*") == 0)
+					nextChar = string::npos;
+				// register indent at previous word
+				if (isJavaStyle() && isInClassHeader)
+					// do nothing for now
+				// register indent at second word on the line
+				else if (!isInTemplate && !isInClassHeaderTab && !isInClassInitializer)
+					int prevWord = getContinuationIndentComma(line, i);
+					int continuationIndentCount = prevWord + spaceIndentCount + tabIncrementIn;
+		// handle comma first initializers
+		if (ch == ',' && parenDepth == 0 && lineBeginsWithComma
+		        && (isInClassInitializer || isInClassHeaderTab))
+			spaceIndentCount = 0;
+		// handle ends of statements
+		if ((ch == ';' && parenDepth == 0) || ch == '}')
+			if (ch == '}')
+				// first check if this '}' closes a previous block, or a static array...
+				if (braceBlockStateStack->size() > 1)
+					bool braceBlockState = braceBlockStateStack->back();
+					braceBlockStateStack->pop_back();
+					if (!braceBlockState)
+							// this brace is a static array
+							parenDepth--;
+							if (i == 0)
+								if (i == 0)
+						continue;
+				// this brace is block closer...
+				++lineClosingBlocksNum;
+				if (!parenDepthStack->empty())
+					parenDepth = parenDepthStack->back();
+					parenDepthStack->pop_back();
+					isContinuation = blockStatementStack->back();
+					blockStatementStack->pop_back();
+					if (isContinuation)
+						blockTabCount--;
+				closingBraceReached = true;
+				if (i == 0)
+				isInAsmBlock = false;
+				isInAsm = isInAsmOneLine = isInQuote = false;	// close these just in case
+				int headerPlace = indexOf(*headerStack, &AS_OPEN_BRACE);
+				if (headerPlace != -1)
+					const string* popped = headerStack->back();
+					while (popped != &AS_OPEN_BRACE)
+						popped = headerStack->back();
+						g_preprocessorCppExternCBrace = 0;
+					// do not indent namespace brace unless namespaces are indented
+					if (!namespaceIndent && !headerStack->empty()
+					        && i == 0)		// must be the first brace on the line
+						vector<const string*>* temp = tempStacks->back();
+						tempStacks->pop_back();
+						delete temp;
+				ch = ' '; // needed due to cases such as '}else{', so that headers ('else' in this case) will be identified...
+			}	// ch == '}'
+			 * Create a temporary snapshot of the current block's header-list in the
+			 * uppermost inner stack in tempStacks, and clear the headerStack up to
+			 * the beginning of the block.
+			 * Thus, the next future statement will think it comes one indent past
+			 * the block's '{' unless it specifically checks for a companion-header
+			 * (such as a previous 'if' for an 'else' header) within the tempStacks,
+			 * and recreates the temporary snapshot by manipulating the tempStacks.
+			if (!tempStacks->back()->empty())
+				while (!tempStacks->back()->empty())
+					tempStacks->back()->pop_back();
+			while (!headerStack->empty() && headerStack->back() != &AS_OPEN_BRACE)
+				tempStacks->back()->emplace_back(headerStack->back());
+			if (parenDepth == 0 && ch == ';')
+				objCColonAlignSubsequent = 0;
+			previousLastLineHeader = nullptr;
+			isInClassHeader = false;		// for 'friend' class
+			isInEnum = false;
+			isInEnumTypeID = false;
+			isInTemplate = false;
+			isInObjCInterface = false;
+			foundPreCommandHeader = false;
+			foundPreCommandMacro = false;
+			squareBracketCount = 0;
+			continue;
+		if (isPotentialHeader)
+			// check for preBlockStatements in C/C++ ONLY if not within parentheses
+			// (otherwise 'struct XXX' statements would be wrongly interpreted...)
+			if (!isInTemplate && !(isCStyle() && parenDepth > 0))
+				const string* newHeader = findHeader(line, i, preBlockStatements);
+				// CORBA IDL module
+				if (newHeader == &AS_MODULE)
+					char nextChar = peekNextChar(line, i + newHeader->length() - 1);
+					if (prevNonSpaceCh == ')' || !isalpha(nextChar))
+				        && !(isCStyle() && newHeader == &AS_CLASS && isInEnum)	// is not 'enum class'
+				        && !(isCStyle() && newHeader == &AS_INTERFACE			// CORBA IDL interface
+				             && (headerStack->empty()
+				                 || headerStack->back() != &AS_OPEN_BRACE)))
+					if (!isSharpStyle())
+					// do not need 'where' in the headerStack
+					// do not need second 'class' statement in a row
+					else if (!(newHeader == &AS_WHERE
+					           || ((newHeader == &AS_CLASS || newHeader == &AS_STRUCT)
+					               && (headerStack->back() == &AS_CLASS
+					                   || headerStack->back() == &AS_STRUCT))))
+						if ((*headerStack).back() == &AS_CLASS
+						        || (*headerStack).back() == &AS_STRUCT
+						        || (*headerStack).back() == &AS_INTERFACE)
+							isInClassHeader = true;
+						else if ((*headerStack).back() == &AS_NAMESPACE
+							// remove continuationIndent from namespace
+					continue;
+			const string* foundIndentableHeader = findHeader(line, i, indentableHeaders);
+			if (foundIndentableHeader != nullptr)
+				// must bypass the header before registering the in statement
+				i += foundIndentableHeader->length() - 1;
+				if (!isInOperator && !isInTemplate && !isNonInStatementArray)
+					registerContinuationIndent(line, i, spaceIndentCount, tabIncrementIn, 0, false);
+				continue;
+			if (isCStyle() && findKeyword(line, i, AS_OPERATOR))
+				isInOperator = true;
+			if (g_preprocessorCppExternCBrace == 1 && findKeyword(line, i, AS_EXTERN))
+			if (g_preprocessorCppExternCBrace == 3)	// extern "C" is not followed by a '{'
+			// "new" operator is a pointer, not a calculation
+			if (findKeyword(line, i, AS_NEW))
+				if (isContinuation && !continuationIndentStack->empty() && prevNonSpaceCh == '=')
+					continuationIndentStack->back() = 0;
+			if (isCStyle() && findKeyword(line, i, AS_AUTO) && isTopLevel())
+				isInTrailingReturnType = true;
+			if (isCStyle())
+				if (findKeyword(line, i, AS_ASM)
+				        || findKeyword(line, i, AS__ASM__))
+					isInAsm = true;
+				else if (findKeyword(line, i, AS_MS_ASM)		// microsoft specific
+				         || findKeyword(line, i, AS_MS__ASM))
+					int index = 4;
+					if (peekNextChar(line, i) == '_')		// check for __asm
+						index = 5;
+					char peekedChar = peekNextChar(line, i + index);
+					if (peekedChar == '{' || peekedChar == ' ')
+						isInAsmBlock = true;
+					else
+						isInAsmOneLine = true;
+			// bypass the entire name for all others
+			string name = getCurrentWord(line, i);
+			i += name.length() - 1;
+			continue;
+		// Handle Objective-C statements
+		if (ch == '@'
+		        && line.length() > i + 1
+		        && !isWhiteSpace(line[i + 1])
+		        && isCharPotentialHeader(line, i + 1))
+			string curWord = getCurrentWord(line, i + 1);
+			if (curWord == AS_INTERFACE)
+				isInObjCInterface = true;
+				string name = '@' + curWord;
+				continue;
+			else if (isInObjCInterface)
+				--indentCount;
+			if (curWord == AS_PUBLIC
+			        || curWord == AS_PRIVATE
+			        || curWord == AS_PROTECTED)
+				--indentCount;
+				continue;
+			else if (curWord == AS_END)
+				isInObjCMethodDefinition = false;
+				continue;
+		else if ((ch == '-' || ch == '+')
+		         && (prevNonSpaceCh == ';' || prevNonSpaceCh == '{'
+		             || headerStack->empty() || isInObjCInterface)
+		         && ASBase::peekNextChar(line, i) != '-'
+		         && ASBase::peekNextChar(line, i) != '+'
+		         && line.find_first_not_of(" \t") == i)
+				--indentCount;
+			isInObjCMethodDefinition = true;
+			continue;
+		// Handle operators
+		bool isPotentialOperator = isCharPotentialOperator(ch);
+		if (isPotentialOperator)
+			// Check if an operator has been reached.
+			const string* foundAssignmentOp = findOperator(line, i, assignmentOperators);
+			const string* foundNonAssignmentOp = findOperator(line, i, nonAssignmentOperators);
+			if (foundNonAssignmentOp != nullptr)
+				if (foundNonAssignmentOp == &AS_LAMBDA)
+				if (isInTemplate && foundNonAssignmentOp == &AS_GR_GR)
+					foundNonAssignmentOp = nullptr;
+			// Since findHeader's boundary checking was not used above, it is possible
+			// that both an assignment op and a non-assignment op where found,
+			// e.g. '>>' and '>>='. If this is the case, treat the LONGER one as the
+			// found operator.
+			if (foundAssignmentOp != nullptr && foundNonAssignmentOp != nullptr)
+				if (foundAssignmentOp->length() < foundNonAssignmentOp->length())
+					foundAssignmentOp = nullptr;
+				else
+				if (foundNonAssignmentOp->length() > 1)
+					i += foundNonAssignmentOp->length() - 1;
+				// For C++ input/output, operator<< and >> should be
+				// aligned, if we are not in a statement already and
+				// also not in the "operator<<(...)" header line
+				if (!isInOperator
+				        && continuationIndentStack->empty()
+				        && isCStyle()
+				        && (foundNonAssignmentOp == &AS_GR_GR
+				            || foundNonAssignmentOp == &AS_LS_LS))
+					// this will be true if the line begins with the operator
+					if (i < foundNonAssignmentOp->length() && spaceIndentCount == 0)
+						spaceIndentCount += 2 * indentLength;
+					// align to the beginning column of the operator
+					registerContinuationIndent(line, i - foundNonAssignmentOp->length(), spaceIndentCount, tabIncrementIn, 0, false);
+			else if (foundAssignmentOp != nullptr)
+				foundPreCommandHeader = false;		// clears this for array assignments
+				if (foundAssignmentOp->length() > 1)
+					i += foundAssignmentOp->length() - 1;
+				if (!isInOperator && !isInTemplate && (!isNonInStatementArray || isInEnum))
+					// if multiple assignments, align on the previous word
+					if (foundAssignmentOp == &AS_ASSIGN
+					        && prevNonSpaceCh != ']'		// an array
+					        && statementEndsWithComma(line, i))
+						if (!haveAssignmentThisLine)		// only one assignment indent per line
+							haveAssignmentThisLine = true;
+							int prevWordIndex = getContinuationIndentAssign(line, i);
+							int continuationIndentCount = prevWordIndex + spaceIndentCount + tabIncrementIn;
+					// don't indent an assignment if 'let'
+					else if (isInLet)
+						isInLet = false;
+					else if (!lineBeginsWithComma)
+						if (i == 0 && spaceIndentCount == 0)
+							spaceIndentCount += indentLength;
+	}	// end of for loop * end of for loop * end of for loop * end of for loop * end of for loop *
+}   // end namespace astyle
diff --git a/tools/astyle/ASEnhancer.cpp b/tools/astyle/ASEnhancer.cpp
new file mode 100755
index 0000000..cb197a9
--- /dev/null
+++ b/tools/astyle/ASEnhancer.cpp
@@ -0,0 +1,796 @@
+// ASEnhancer.cpp
+// Copyright (c) 2018 by Jim Pattee <jimp03 at email.com>.
+// This code is licensed under the MIT License.
+// License.md describes the conditions under which this software may be distributed.
+// headers
+#include "astyle.h"
+// astyle namespace
+namespace astyle {
+// ASEnhancer class
+ * ASEnhancer constructor
+ASEnhancer::ASEnhancer()
+ * Destructor of ASEnhancer
+ASEnhancer::~ASEnhancer()
+ * initialize the ASEnhancer.
+ * init() is called each time an ASFormatter object is initialized.
+void ASEnhancer::init(int  _fileType,
+                      int  _indentLength,
+                      int  _tabLength,
+                      bool _useTabs,
+                      bool _forceTab,
+                      bool _namespaceIndent,
+                      bool _caseIndent,
+                      bool _preprocBlockIndent,
+                      bool _preprocDefineIndent,
+                      bool _emptyLineFill,
+                      vector<const pair<const string, const string>* >* _indentableMacros)
+	// formatting variables from ASFormatter and ASBeautifier
+	ASBase::init(_fileType);
+	indentLength = _indentLength;
+	tabLength = _tabLength;
+	useTabs = _useTabs;
+	forceTab = _forceTab;
+	namespaceIndent = _namespaceIndent;
+	caseIndent = _caseIndent;
+	preprocBlockIndent = _preprocBlockIndent;
+	preprocDefineIndent = _preprocDefineIndent;
+	emptyLineFill = _emptyLineFill;
+	indentableMacros = _indentableMacros;
+	quoteChar = '\'';
+	// unindent variables
+	lineNumber = 0;
+	braceCount = 0;
+	isInComment = false;
+	switchDepth = 0;
+	eventPreprocDepth = 0;
+	lookingForCaseBrace = false;
+	unindentNextLine = false;
+	shouldUnindentLine = false;
+	shouldUnindentComment = false;
+	// switch struct and vector
+	sw.switchBraceCount = 0;
+	sw.unindentDepth = 0;
+	sw.unindentCase = false;
+	switchStack.clear();
+	// other variables
+	nextLineIsEventIndent = false;
+	isInEventTable = false;
+	nextLineIsDeclareIndent = false;
+	isInDeclareSection = false;
+ * additional formatting for line of source code.
+ * every line of source code in a source code file should be sent
+ *     one after the other to this function.
+ * indents event tables
+ * unindents the case blocks
+ * @param line       the original formatted line will be updated if necessary.
+void ASEnhancer::enhance(string& line, bool isInNamespace, bool isInPreprocessor, bool isInSQL)
+	shouldUnindentLine = true;
+	lineNumber++;
+	// check for beginning of event table
+	if (nextLineIsEventIndent)
+		isInEventTable = true;
+	// check for beginning of SQL declare section
+	if (nextLineIsDeclareIndent)
+		isInDeclareSection = true;
+	if (line.length() == 0
+	        && !isInEventTable
+	        && !isInDeclareSection
+	        && !emptyLineFill)
+		return;
+	// test for unindent on attached braces
+	if (unindentNextLine)
+		sw.unindentDepth++;
+		sw.unindentCase = true;
+	// parse characters in the current line
+	parseCurrentLine(line, isInPreprocessor, isInSQL);
+	// check for SQL indentable lines
+	if (isInDeclareSection)
+		if (firstText == string::npos || line[firstText] != '#')
+			indentLine(line, 1);
+	// check for event table indentable lines
+	if (isInEventTable
+	        && (eventPreprocDepth == 0
+	            || (namespaceIndent && isInNamespace)))
+	if (shouldUnindentComment && sw.unindentDepth > 0)
+		unindentLine(line, sw.unindentDepth - 1);
+	else if (shouldUnindentLine && sw.unindentDepth > 0)
+		unindentLine(line, sw.unindentDepth);
+ * convert a force-tab indent to spaces
+ * @param line          a reference to the line that will be converted.
+void ASEnhancer::convertForceTabIndentToSpaces(string& line) const
+	// replace tab indents with spaces
+		if (!isWhiteSpace(line[i]))
+			break;
+		if (line[i] == '\t')
+			line.erase(i, 1);
+			line.insert(i, tabLength, ' ');
+			i += tabLength - 1;
+ * convert a space indent to force-tab
+void ASEnhancer::convertSpaceIndentToForceTab(string& line) const
+	assert(tabLength > 0);
+	// replace leading spaces with tab indents
+	size_t newSpaceIndentLength = line.find_first_not_of(" \t");
+	size_t tabCount = newSpaceIndentLength / tabLength;		// truncate extra spaces
+	line.replace(0U, tabCount * tabLength, tabCount, '\t');
+ * find the colon following a 'case' statement
+ * @param line          a reference to the line.
+ * @param caseIndex     the line index of the case statement.
+ * @return              the line index of the colon.
+size_t ASEnhancer::findCaseColon(const string& line, size_t caseIndex) const
+	size_t i = caseIndex;
+	for (; i < line.length(); i++)
+		if (isInQuote_)
+			if (line[i] == '\\')
+				i++;
+				continue;
+			else if (line[i] == quoteChar_)          // check ending quote
+				quoteChar_ = ' ';
+				continue;
+			else
+				continue;                           // must close quote before continuing
+		if (line[i] == '"' 		// check opening quote
+		        || (line[i] == '\'' && !isDigitSeparator(line, i)))
+			quoteChar_ = line[i];
+			continue;
+		if (line[i] == ':')
+			if ((i + 1 < line.length()) && (line[i + 1] == ':'))
+				i++;                                // bypass scope resolution operator
+			else
+				break;                              // found it
+	return i;
+* indent a line by a given number of tabsets
+ *    by inserting leading whitespace to the line argument.
+ * @param line          a reference to the line to indent.
+ * @param indent        the number of tabsets to insert.
+ * @return              the number of characters inserted.
+int ASEnhancer::indentLine(string& line, int indent) const
+		return 0;
+	size_t charsToInsert = 0;
+	if (forceTab && indentLength != tabLength)
+		convertForceTabIndentToSpaces(line);
+		// insert the space indents
+		charsToInsert = indent * indentLength;
+		line.insert(line.begin(), charsToInsert, ' ');
+		convertSpaceIndentToForceTab(line);
+	else if (useTabs)
+		charsToInsert = indent;
+		line.insert(line.begin(), charsToInsert, '\t');
+	else // spaces
+	return charsToInsert;
+ * check for SQL "BEGIN DECLARE SECTION".
+ * must compare case insensitive and allow any spacing between words.
+ * @param index         the current line index.
+ * @return              true if a hit.
+bool ASEnhancer::isBeginDeclareSectionSQL(const string& line, size_t index) const
+	string word;
+	size_t hits = 0;
+	size_t i;
+	for (i = index; i < line.length(); i++)
+		i = line.find_first_not_of(" \t", i);
+			return false;
+		if (line[i] == ';')
+			break;
+		if (!isCharPotentialHeader(line, i))
+			continue;
+		word = getCurrentWord(line, i);
+		for (size_t j = 0; j < word.length(); j++)
+			word[j] = (char) toupper(word[j]);
+		if (word == "EXEC" || word == "SQL")
+			i += word.length() - 1;
+			continue;
+		if (word == "DECLARE" || word == "SECTION")
+			hits++;
+			continue;
+		if (word == "BEGIN")
+			hits++;
+			continue;
+		return false;
+	if (hits == 3)
+		return true;
+	return false;
+ * check for SQL "END DECLARE SECTION".
+bool ASEnhancer::isEndDeclareSectionSQL(const string& line, size_t index) const
+	string word;
+	size_t hits = 0;
+	size_t i;
+			return false;
+			break;
+			continue;
+			continue;
+			hits++;
+			continue;
+		if (word == "END")
+			hits++;
+			continue;
+		return false;
+	if (hits == 3)
+		return true;
+	return false;
+ * check if a one-line brace has been reached,
+ * i.e. if the currently reached '{' character is closed
+ * with a complimentary '}' elsewhere on the current line,
+ * @return     false = one-line brace has not been reached.
+ *             true  = one-line brace has been reached.
+bool ASEnhancer::isOneLineBlockReached(const string& line, int startChar) const
+	assert(line[startChar] == '{');
+	int _braceCount = 1;
+	int lineLength = line.length();
+	char ch = ' ';
+	for (int i = startChar + 1; i < lineLength; ++i)
+		ch = line[i];
+		if (isInComment_)
+				++i;
+			continue;
+		if (ch == '\\')
+			++i;
+			continue;
+		if (isInQuote_)
+			continue;
+		if (ch == '"'
+			quoteChar_ = ch;
+			continue;
+			break;
+			++i;
+			continue;
+		if (ch == '{')
+			++_braceCount;
+		else if (ch == '}')
+			--_braceCount;
+		if (_braceCount == 0)
+			return true;
+	return false;
+ * parse characters in the current line to determine if an indent
+ * or unindent is needed.
+void ASEnhancer::parseCurrentLine(string& line, bool isInPreprocessor, bool isInSQL)
+	bool isSpecialChar = false;			// is a backslash escape character
+			continue;
+			continue;
+		if (!(isInComment) && line.compare(i, 2, "\\\\") == 0)
+			i++;
+			continue;
+		if (!(isInComment) && ch == '\\')
+			continue;
+		if (!isInComment
+		        && (ch == '"'
+			if (!isInQuote)
+				quoteChar = ch;
+				isInQuote = true;
+				continue;
+		if (isInQuote)
+			continue;
+		if (!(isInComment) && line.compare(i, 2, "//") == 0)
+			// check for windows line markers
+			if (line.compare(i + 2, 1, "\xf0") > 0)
+				lineNumber--;
+			// unindent if not in case braces
+			if (line.find_first_not_of(" \t") == i
+			        && sw.switchBraceCount == 1
+			        && sw.unindentCase)
+				shouldUnindentComment = true;
+			break;                 // finished with the line
+		else if (!(isInComment) && line.compare(i, 2, "/*") == 0)
+			if (sw.switchBraceCount == 1 && sw.unindentCase)
+			size_t commentEnd = line.find("*/", i);
+			if (commentEnd == string::npos)
+				i = line.length() - 1;
+			else
+				i = commentEnd - 1;
+			continue;
+		else if ((isInComment) && line.compare(i, 2, "*/") == 0)
+			i++;
+			continue;
+		if (isInComment)
+			else
+			continue;
+		// if we have reached this far then we are NOT in a comment or string of special characters
+		if (line[i] == '{')
+			braceCount++;
+		if (line[i] == '}')
+			braceCount--;
+		// check for preprocessor within an event table
+		if (isInEventTable && line[i] == '#' && preprocBlockIndent)
+			string preproc;
+			preproc = line.substr(i + 1);
+			if (preproc.substr(0, 2) == "if") // #if, #ifdef, #ifndef)
+				eventPreprocDepth += 1;
+			if (preproc.substr(0, 5) == "endif" && eventPreprocDepth > 0)
+				eventPreprocDepth -= 1;
+		bool isPotentialKeyword = isCharPotentialHeader(line, i);
+		// ----------------  wxWidgets and MFC macros  ----------------------------------
+		if (isPotentialKeyword)
+			for (size_t j = 0; j < indentableMacros->size(); j++)
+				// 'first' is the beginning macro
+				if (findKeyword(line, i, indentableMacros->at(j)->first))
+					nextLineIsEventIndent = true;
+					break;
+				// 'second' is the ending macro
+				if (findKeyword(line, i, indentableMacros->at(j)->second))
+					break;
+		// ----------------  process SQL  -----------------------------------------------
+		if (isInSQL)
+			if (isBeginDeclareSectionSQL(line, i))
+				nextLineIsDeclareIndent = true;
+			if (isEndDeclareSectionSQL(line, i))
+			break;
+		// ----------------  process switch statements  ---------------------------------
+		if (isPotentialKeyword && findKeyword(line, i, ASResource::AS_SWITCH))
+			switchDepth++;
+			switchStack.emplace_back(sw);                      // save current variables
+			sw.unindentCase = false;                        // don't clear case until end of switch
+			i += 5;                                         // bypass switch statement
+			continue;
+		// just want unindented case statements from this point
+		if (caseIndent
+		        || switchDepth == 0
+		        || (isInPreprocessor && !preprocDefineIndent))
+			// bypass the entire word
+			continue;
+		i = processSwitchBlock(line, i);
+ * process the character at the current index in a switch block.
+ * @return              the new line index.
+size_t ASEnhancer::processSwitchBlock(string& line, size_t index)
+	size_t i = index;
+		sw.switchBraceCount++;
+		if (lookingForCaseBrace)                      // if 1st after case statement
+			sw.unindentCase = true;                     // unindenting this case
+			lookingForCaseBrace = false;              // not looking now
+		return i;
+	lookingForCaseBrace = false;                      // no opening brace, don't indent
+		sw.switchBraceCount--;
+		if (sw.switchBraceCount == 0)                 // if end of switch statement
+			int lineUnindent = sw.unindentDepth;
+			        && !switchStack.empty())
+				lineUnindent = switchStack[switchStack.size() - 1].unindentDepth;
+			if (shouldUnindentLine)
+				if (lineUnindent > 0)
+					i -= unindentLine(line, lineUnindent);
+			switchDepth--;
+			sw = switchStack.back();
+			switchStack.pop_back();
+		return i;
+	        && (findKeyword(line, i, ASResource::AS_CASE)
+	            || findKeyword(line, i, ASResource::AS_DEFAULT)))
+		if (sw.unindentCase)					// if unindented last case
+			sw.unindentCase = false;			// stop unindenting previous case
+			sw.unindentDepth--;
+		i = findCaseColon(line, i);
+		i++;
+		for (; i < line.length(); i++)			// bypass whitespace
+				break;
+		if (i < line.length())
+				braceCount++;
+				if (!isOneLineBlockReached(line, i))
+					unindentNextLine = true;
+				return i;
+		lookingForCaseBrace = true;
+		i--;									// need to process this char
+		return i;
+		string name = getCurrentWord(line, i);          // bypass the entire name
+	return i;
+ * unindent a line by a given number of tabsets
+ *    by erasing the leading whitespace from the line argument.
+ * @param line          a reference to the line to unindent.
+ * @param unindent      the number of tabsets to erase.
+ * @return              the number of characters erased.
+int ASEnhancer::unindentLine(string& line, int unindent) const
+	size_t whitespace = line.find_first_not_of(" \t");
+	if (whitespace == string::npos)         // if line is blank
+		whitespace = line.length();         // must remove padding, if any
+	if (whitespace == 0)
+		return 0;
+	size_t charsToErase = 0;
+		// remove the space indents
+		size_t spaceIndentLength = line.find_first_not_of(" \t");
+		charsToErase = unindent * indentLength;
+		if (charsToErase <= spaceIndentLength)
+			line.erase(0, charsToErase);
+		else
+			charsToErase = 0;
+	else if (useTabs)
+		charsToErase = unindent;
+		if (charsToErase <= whitespace)
+		else
+			charsToErase = 0;
+	else // spaces
+		else
+			charsToErase = 0;
+	return charsToErase;
diff --git a/tools/astyle/ASFormatter.cpp b/tools/astyle/ASFormatter.cpp
index 0000000..bd1a004
--- /dev/null
+++ b/tools/astyle/ASFormatter.cpp
@@ -0,0 +1,8245 @@
+// ASFormatter.cpp
+// headers
+#include <algorithm>
+#include <fstream>
+namespace astyle {
+// ASFormatter class
+ * Constructor of ASFormatter
+ASFormatter::ASFormatter()
+	sourceIterator = nullptr;
+	enhancer = new ASEnhancer;
+	preBraceHeaderStack = nullptr;
+	braceTypeStack = nullptr;
+	parenStack = nullptr;
+	structStack = nullptr;
+	questionMarkStack = nullptr;
+	lineCommentNoIndent = false;
+	formattingStyle = STYLE_NONE;
+	braceFormatMode = NONE_MODE;
+	pointerAlignment = PTR_ALIGN_NONE;
+	referenceAlignment = REF_SAME_AS_PTR;
+	objCColonPadMode = COLON_PAD_NO_CHANGE;
+	lineEnd = LINEEND_DEFAULT;
+	maxCodeLength = string::npos;
+	shouldPadCommas = false;
+	shouldPadOperators = false;
+	shouldPadParensOutside = false;
+	shouldPadFirstParen = false;
+	shouldPadParensInside = false;
+	shouldPadHeader = false;
+	shouldStripCommentPrefix = false;
+	shouldUnPadParens = false;
+	attachClosingBraceMode = false;
+	shouldBreakOneLineBlocks = true;
+	shouldBreakOneLineHeaders = false;
+	shouldBreakOneLineStatements = true;
+	shouldConvertTabs = false;
+	shouldIndentCol1Comments = false;
+	shouldIndentPreprocBlock = false;
+	shouldCloseTemplates = false;
+	shouldAttachExternC = false;
+	shouldAttachNamespace = false;
+	shouldAttachClass = false;
+	shouldAttachClosingWhile = false;
+	shouldAttachInline = false;
+	shouldBreakBlocks = false;
+	shouldBreakClosingHeaderBlocks = false;
+	shouldBreakClosingHeaderBraces = false;
+	shouldDeleteEmptyLines = false;
+	shouldBreakReturnType = false;
+	shouldBreakReturnTypeDecl = false;
+	shouldAttachReturnType = false;
+	shouldAttachReturnTypeDecl = false;
+	shouldBreakElseIfs = false;
+	shouldBreakLineAfterLogical = false;
+	shouldAddBraces = false;
+	shouldAddOneLineBraces = false;
+	shouldRemoveBraces = false;
+	shouldPadMethodColon = false;
+	shouldPadMethodPrefix = false;
+	shouldUnPadMethodPrefix = false;
+	shouldPadReturnType = false;
+	shouldUnPadReturnType = false;
+	shouldPadParamType = false;
+	shouldUnPadParamType = false;
+	// initialize ASFormatter member vectors
+	formatterFileType = 9;		// reset to an invalid type
+	headers = new vector<const string*>;
+	nonParenHeaders = new vector<const string*>;
+	preDefinitionHeaders = new vector<const string*>;
+	preCommandHeaders = new vector<const string*>;
+	operators = new vector<const string*>;
+	assignmentOperators = new vector<const string*>;
+	castOperators = new vector<const string*>;
+	// initialize ASEnhancer member vectors
+	indentableMacros = new vector<const pair<const string, const string>* >;
+ * Destructor of ASFormatter
+ASFormatter::~ASFormatter()
+	// delete ASFormatter stack vectors
+	deleteContainer(preBraceHeaderStack);
+	deleteContainer(braceTypeStack);
+	deleteContainer(parenStack);
+	deleteContainer(structStack);
+	deleteContainer(questionMarkStack);
+	// delete ASFormatter member vectors
+	delete headers;
+	delete nonParenHeaders;
+	delete preDefinitionHeaders;
+	delete preCommandHeaders;
+	delete operators;
+	delete assignmentOperators;
+	delete castOperators;
+	// delete ASEnhancer member vectors
+	delete indentableMacros;
+	// must be done when the ASFormatter object is deleted (not ASBeautifier)
+	// delete ASBeautifier member vectors
+	ASBeautifier::deleteBeautifierVectors();
+	delete enhancer;
+ * initialize the ASFormatter.
+ * init() should be called every time a ASFormatter object is to start
+ * formatting a NEW source file.
+ * init() receives a pointer to a ASSourceIterator object that will be
+ * used to iterate through the source code.
+ * @param si        a pointer to the ASSourceIterator or ASStreamIterator object.
+void ASFormatter::init(ASSourceIterator* si)
+	buildLanguageVectors();
+	fixOptionVariableConflicts();
+	ASBeautifier::init(si);
+	sourceIterator = si;
+	enhancer->init(getFileType(),
+	               getIndentLength(),
+	               getTabLength(),
+	               getIndentString() == "\t",
+	               getForceTabIndentation(),
+	               getNamespaceIndent(),
+	               getCaseIndent(),
+	               shouldIndentPreprocBlock,
+	               getPreprocDefineIndent(),
+	               getEmptyLineFill(),
+	               indentableMacros);
+	initContainer(preBraceHeaderStack, new vector<const string*>);
+	initContainer(parenStack, new vector<int>);
+	initContainer(structStack, new vector<bool>);
+	initContainer(questionMarkStack, new vector<bool>);
+	parenStack->emplace_back(0);               // parenStack must contain this default entry
+	initContainer(braceTypeStack, new vector<BraceType>);
+	braceTypeStack->emplace_back(NULL_TYPE);   // braceTypeStack must contain this default entry
+	clearFormattedLineSplitPoints();
+	currentHeader = nullptr;
+	currentLine = "";
+	readyFormattedLine = "";
+	formattedLine = "";
+	verbatimDelimiter = "";
+	currentChar = ' ';
+	previousChar = ' ';
+	previousCommandChar = ' ';
+	previousNonWSChar = ',';	// not a potential name or operator
+	quoteChar = '"';
+	preprocBlockEnd = 0;
+	charNum = 0;
+	checksumIn = 0;
+	checksumOut = 0;
+	currentLineFirstBraceNum = string::npos;
+	formattedLineCommentNum = 0;
+	leadingSpaces = 0;
+	previousReadyFormattedLineLength = string::npos;
+	preprocBraceTypeStackSize = 0;
+	spacePadNum = 0;
+	methodAttachCharNum = string::npos;
+	methodAttachLineNum = 0;
+	methodBreakCharNum = string::npos;
+	methodBreakLineNum = 0;
+	nextLineSpacePadNum = 0;
+	objCColonAlign = 0;
+	templateDepth = 0;
+	runInIndentChars = 0;
+	tabIncrementIn = 0;
+	previousBraceType = NULL_TYPE;
+	isVirgin = true;
+	isInVirginLine = true;
+	isInLineComment = false;
+	isInCommentStartLine = false;
+	noTrimCommentContinuation = false;
+	isInPreprocessor = false;
+	isInPreprocessorBeautify = false;
+	doesLineStartComment = false;
+	lineEndsInCommentOnly = false;
+	lineIsCommentOnly = false;
+	lineIsLineCommentOnly = false;
+	lineIsEmpty = false;
+	isImmediatelyPostCommentOnly = false;
+	isImmediatelyPostEmptyLine = false;
+	isInVerbatimQuote = false;
+	haveLineContinuationChar = false;
+	isInQuoteContinuation = false;
+	isHeaderInMultiStatementLine = false;
+	isNonParenHeader = false;
+	foundNamespaceHeader = false;
+	foundClassHeader = false;
+	foundStructHeader = false;
+	foundInterfaceHeader = false;
+	foundPreDefinitionHeader = false;
+	foundTrailingReturnType = false;
+	foundCastOperator = false;
+	foundQuestionMark = false;
+	isInLineBreak = false;
+	endOfAsmReached = false;
+	endOfCodeReached = false;
+	isFormattingModeOff = false;
+	isInEnum = false;
+	isInExecSQL = false;
+	isInAsm = false;
+	isInAsmOneLine = false;
+	isLineReady = false;
+	elseHeaderFollowsComments = false;
+	caseHeaderFollowsComments = false;
+	isPreviousBraceBlockRelated = false;
+	isInPotentialCalculation = false;
+	needHeaderOpeningBrace = false;
+	shouldBreakLineAtNextChar = false;
+	shouldKeepLineUnbroken = false;
+	shouldReparseCurrentChar = false;
+	passedSemicolon = false;
+	passedColon = false;
+	isImmediatelyPostNonInStmt = false;
+	isCharImmediatelyPostNonInStmt = false;
+	isImmediatelyPostComment = false;
+	isImmediatelyPostLineComment = false;
+	isImmediatelyPostEmptyBlock = false;
+	isImmediatelyPostObjCMethodPrefix = false;
+	isImmediatelyPostPreprocessor = false;
+	isImmediatelyPostReturn = false;
+	isImmediatelyPostThrow = false;
+	isImmediatelyPostNewDelete = false;
+	isImmediatelyPostOperator = false;
+	isImmediatelyPostTemplate = false;
+	isImmediatelyPostPointerOrReference = false;
+	isCharImmediatelyPostReturn = false;
+	isCharImmediatelyPostThrow = false;
+	isCharImmediatelyPostNewDelete = false;
+	isCharImmediatelyPostOperator = false;
+	isCharImmediatelyPostComment = false;
+	isPreviousCharPostComment = false;
+	isCharImmediatelyPostLineComment = false;
+	isCharImmediatelyPostOpenBlock = false;
+	isCharImmediatelyPostCloseBlock = false;
+	isCharImmediatelyPostTemplate = false;
+	isCharImmediatelyPostPointerOrReference = false;
+	isInObjCReturnType = false;
+	isInObjCParam = false;
+	isInObjCSelector = false;
+	breakCurrentOneLineBlock = false;
+	shouldRemoveNextClosingBrace = false;
+	isInBraceRunIn = false;
+	returnTypeChecked = false;
+	currentLineBeginsWithBrace = false;
+	isPrependPostBlockEmptyLineRequested = false;
+	isAppendPostBlockEmptyLineRequested = false;
+	isIndentableProprocessor = false;
+	isIndentableProprocessorBlock = false;
+	prependEmptyLine = false;
+	appendOpeningBrace = false;
+	foundClosingHeader = false;
+	isImmediatelyPostHeader = false;
+	isInCase = false;
+	isFirstPreprocConditional = false;
+	processedFirstConditional = false;
+	isJavaStaticConstructor = false;
+ * build vectors for each programing language
+ * depending on the file extension.
+void ASFormatter::buildLanguageVectors()
+	if (getFileType() == formatterFileType)  // don't build unless necessary
+		return;
+	formatterFileType = getFileType();
+	headers->clear();
+	nonParenHeaders->clear();
+	preDefinitionHeaders->clear();
+	preCommandHeaders->clear();
+	operators->clear();
+	assignmentOperators->clear();
+	castOperators->clear();
+	indentableMacros->clear();	// ASEnhancer
+	ASResource::buildHeaders(headers, getFileType());
+	ASResource::buildNonParenHeaders(nonParenHeaders, getFileType());
+	ASResource::buildPreDefinitionHeaders(preDefinitionHeaders, getFileType());
+	ASResource::buildPreCommandHeaders(preCommandHeaders, getFileType());
+	ASResource::buildOperators(operators, getFileType());
+	ASResource::buildAssignmentOperators(assignmentOperators);
+	ASResource::buildCastOperators(castOperators);
+	ASResource::buildIndentableMacros(indentableMacros);	//ASEnhancer
+ * set the variables for each predefined style.
+ * this will override any previous settings.
+void ASFormatter::fixOptionVariableConflicts()
+	if (formattingStyle == STYLE_ALLMAN)
+		setBraceFormatMode(BREAK_MODE);
+	else if (formattingStyle == STYLE_JAVA)
+		setBraceFormatMode(ATTACH_MODE);
+	else if (formattingStyle == STYLE_KR)
+		setBraceFormatMode(LINUX_MODE);
+	else if (formattingStyle == STYLE_STROUSTRUP)
+		setBreakClosingHeaderBracesMode(true);
+	else if (formattingStyle == STYLE_WHITESMITH)
+		setBraceIndent(true);
+		setClassIndent(true);			// avoid hanging indent with access modifiers
+		setSwitchIndent(true);			// avoid hanging indent with case statements
+	else if (formattingStyle == STYLE_VTK)
+		// the unindented class brace does NOT cause a hanging indent like Whitesmith
+		setBraceIndentVtk(true);		// sets both braceIndent and braceIndentVtk
+	else if (formattingStyle == STYLE_RATLIFF)
+		// attached braces can have hanging indents with the closing brace
+	else if (formattingStyle == STYLE_GNU)
+		setBlockIndent(true);
+	else if (formattingStyle == STYLE_LINUX)
+		// always for Linux style
+		setMinConditionalIndentOption(MINCOND_ONEHALF);
+	else if (formattingStyle == STYLE_HORSTMANN)
+		setBraceFormatMode(RUN_IN_MODE);
+	else if (formattingStyle == STYLE_1TBS)
+		setAddBracesMode(true);
+		setRemoveBracesMode(false);
+	else if (formattingStyle == STYLE_GOOGLE)
+		setModifierIndent(true);
+		setClassIndent(false);
+	else if (formattingStyle == STYLE_MOZILLA)
+	else if (formattingStyle == STYLE_PICO)
+		setAttachClosingBraceMode(true);
+		setBreakOneLineBlocksMode(false);
+		setBreakOneLineStatementsMode(false);
+		// add-braces won't work for pico, but it could be fixed if necessary
+		// both options should be set to true
+		if (shouldAddBraces)
+			shouldAddOneLineBraces = true;
+	else if (formattingStyle == STYLE_LISP)
+		// add-one-line-braces won't work for lisp
+		// only shouldAddBraces should be set to true
+		if (shouldAddOneLineBraces)
+			shouldAddBraces = true;
+	setMinConditionalIndentLength();
+	// if not set by indent=force-tab-x set equal to indentLength
+	if (getTabLength() == 0)
+		setDefaultTabLength();
+	// add-one-line-braces implies keep-one-line-blocks
+	// don't allow add-braces and remove-braces
+	if (shouldAddBraces || shouldAddOneLineBraces)
+	// don't allow break-return-type and attach-return-type
+	if (shouldBreakReturnType)
+	if (shouldBreakReturnTypeDecl)
+	// don't allow indent-classes and indent-modifiers
+	if (getClassIndent())
+		setModifierIndent(false);
+ * get the next formatted line.
+ * @return    formatted line.
+string ASFormatter::nextLine()
+	const string* newHeader = nullptr;
+	isInVirginLine = isVirgin;
+	while (!isLineReady)
+		if (shouldReparseCurrentChar)
+		else if (!getNextChar())
+			breakLine();
+			continue;
+		else // stuff to do when reading a new character...
+			// make sure that a virgin '{' at the beginning of the file will be treated as a block...
+			if (isInVirginLine && currentChar == '{'
+			        && currentLineBeginsWithBrace
+			        && previousCommandChar == ' ')
+				previousCommandChar = '{';
+			        && isBraceType(braceTypeStack->back(), COMMAND_TYPE))
+			if (isInBraceRunIn)
+			if (!isWhiteSpace(currentChar))
+			isPreviousCharPostComment = isCharImmediatelyPostComment;
+		if ((lineIsLineCommentOnly || lineIsCommentOnly)
+		        && currentLine.find("*INDENT-ON*", charNum) != string::npos
+		        && isFormattingModeOff)
+			breakLine();
+			formattedLine = currentLine;
+			charNum = (int) currentLine.length() - 1;
+			continue;
+		if (isFormattingModeOff)
+			breakLine();
+			continue;
+		        && currentLine.find("*INDENT-OFF*", charNum) != string::npos)
+			isFormattingModeOff = true;
+			if (isInLineBreak)			// is true if not the first line
+				breakLine();
+			continue;
+		if (shouldBreakLineAtNextChar)
+			if (isWhiteSpace(currentChar) && !lineIsEmpty)
+				continue;
+			isInLineBreak = true;
+		if (isInExecSQL && !passedSemicolon)
+			if (currentChar == ';')
+				passedSemicolon = true;
+			appendCurrentChar();
+			continue;
+			formatLineCommentBody();
+			continue;
+		else if (isInComment)
+			formatCommentBody();
+			continue;
+		else if (isInQuote)
+			formatQuoteBody();
+			continue;
+		// not in quote or comment or line comment
+		if (isSequenceReached("//"))
+			formatLineCommentOpener();
+			testForTimeToSplitFormattedLine();
+			continue;
+		else if (isSequenceReached("/*"))
+			formatCommentOpener();
+			continue;
+		else if (currentChar == '"'
+		         || (currentChar == '\'' && !isDigitSeparator(currentLine, charNum)))
+			formatQuoteOpener();
+			continue;
+		// treat these preprocessor statements as a line comment
+		else if (currentChar == '#'
+		         && currentLine.find_first_not_of(" \t") == (size_t) charNum)
+			string preproc = trim(currentLine.c_str() + charNum + 1);
+			if (preproc.length() > 0
+			        && isCharPotentialHeader(preproc, 0)
+			        && (findKeyword(preproc, 0, "region")
+			            || findKeyword(preproc, 0, "endregion")
+			            || findKeyword(preproc, 0, "error")
+			            || findKeyword(preproc, 0, "warning")
+			            || findKeyword(preproc, 0, "line")))
+				currentLine = rtrim(currentLine);	// trim the end only
+				// check for run-in
+				if (formattedLine.length() > 0 && formattedLine[0] == '{')
+				if (previousCommandChar == '}')
+				continue;
+		if (isInPreprocessor)
+			continue;
+		if (isInTemplate && shouldCloseTemplates)
+			if (previousNonWSChar == '>' && isWhiteSpace(currentChar) && peekNextChar() == '>')
+				continue;
+		if (shouldRemoveNextClosingBrace && currentChar == '}')
+			currentLine[charNum] = currentChar = ' ';
+			assert(adjustChecksumIn(-'}'));
+			if (isEmptyLine(currentLine))
+				continue;
+		// handle white space - needed to simplify the rest.
+		if (isWhiteSpace(currentChar))
+			continue;
+		/* not in MIDDLE of quote or comment or SQL or white-space of any type ... */
+		// check if in preprocessor
+		// ** isInPreprocessor will be automatically reset at the beginning
+		//    of a new line in getnextChar()
+		if (currentChar == '#'
+		        && !isBraceType(braceTypeStack->back(), SINGLE_LINE_TYPE))
+			isInPreprocessor = true;
+			processPreprocessor();
+			// if top level it is potentially indentable
+			if (shouldIndentPreprocBlock
+			        && (isBraceType(braceTypeStack->back(), NULL_TYPE)
+			            || isBraceType(braceTypeStack->back(), NAMESPACE_TYPE))
+			        && !foundClassHeader
+			        && !isInClassInitializer
+			        && sourceIterator->tellg() > preprocBlockEnd)
+				// indent the #if preprocessor blocks
+				string preproc = ASBeautifier::extractPreprocessorStatement(currentLine);
+				if (preproc.length() >= 2 && preproc.substr(0, 2) == "if") // #if, #ifdef, #ifndef
+					if (isImmediatelyPostPreprocessor)
+						breakLine();
+					isIndentableProprocessorBlock = isIndentablePreprocessorBlock(currentLine, charNum);
+					isIndentableProprocessor = isIndentableProprocessorBlock;
+			if (isIndentableProprocessorBlock
+			        && charNum < (int) currentLine.length() - 1
+			        && isWhiteSpace(currentLine[charNum + 1]))
+				size_t nextText = currentLine.find_first_not_of(" \t", charNum + 1);
+				if (nextText != string::npos)
+					currentLine.erase(charNum + 1, nextText - charNum - 1);
+			        && sourceIterator->tellg() >= preprocBlockEnd)
+			//  need to fall thru here to reset the variables
+		/* not in preprocessor ... */
+		if (isImmediatelyPostComment)
+			isCharImmediatelyPostComment = true;
+		if (isImmediatelyPostLineComment)
+			isCharImmediatelyPostLineComment = true;
+		if (isImmediatelyPostReturn)
+			isCharImmediatelyPostReturn = true;
+		if (isImmediatelyPostThrow)
+			isCharImmediatelyPostThrow = true;
+		if (isImmediatelyPostNewDelete)
+			isCharImmediatelyPostNewDelete = true;
+		if (isImmediatelyPostOperator)
+			isCharImmediatelyPostOperator = true;
+		if (isImmediatelyPostTemplate)
+			isCharImmediatelyPostTemplate = true;
+		if (isImmediatelyPostPointerOrReference)
+			isCharImmediatelyPostPointerOrReference = true;
+		// reset isImmediatelyPostHeader information
+		if (isImmediatelyPostHeader)
+			// should braces be added
+			if (currentChar != '{'
+			        && shouldAddBraces
+			        && currentChar != '#'	// don't add to preprocessor
+			        && (shouldBreakOneLineStatements || !isHeaderInMultiStatementLine)
+			        && isOkToBreakBlock(braceTypeStack->back()))
+				bool bracesAdded = addBracesToStatement();
+				if (bracesAdded && !shouldAddOneLineBraces)
+					size_t firstText = currentLine.find_first_not_of(" \t");
+					assert(firstText != string::npos);
+					if ((int) firstText == charNum || shouldBreakOneLineHeaders)
+						breakCurrentOneLineBlock = true;
+			// should braces be removed
+			else if (currentChar == '{' && shouldRemoveBraces)
+				bool bracesRemoved = removeBracesFromStatement();
+				if (bracesRemoved)
+					shouldRemoveNextClosingBrace = true;
+					if (isBeforeAnyLineEndComment(charNum))
+						spacePadNum--;
+					else if (shouldBreakOneLineBlocks
+					         || (currentLineBeginsWithBrace
+					             && currentLine.find_first_not_of(" \t") != string::npos))
+						shouldBreakLineAtNextChar = true;
+					continue;
+			// break 'else-if' if shouldBreakElseIfs is requested
+			if (shouldBreakElseIfs
+			        && currentHeader == &AS_ELSE
+			        && !isBeforeAnyComment()
+			        && (shouldBreakOneLineStatements || !isHeaderInMultiStatementLine))
+				string nextText = peekNextText(currentLine.substr(charNum));
+				if (nextText.length() > 0
+				        && isCharPotentialHeader(nextText, 0)
+				        && ASBase::findHeader(nextText, 0, headers) == &AS_IF)
+			// break a header (e.g. if, while, else) from the following statement
+			if (shouldBreakOneLineHeaders
+			        && peekNextChar() != ' '
+			            || (!isHeaderInMultiStatementLine
+			                && !isMultiStatementLine()))
+			        && !isBeforeAnyComment())
+				if (currentChar == '{')
+					if (!currentLineBeginsWithBrace)
+						if (isOneLineBlockReached(currentLine, charNum) == 3)
+						else
+				else if (currentHeader == &AS_ELSE)
+					string nextText = peekNextText(currentLine.substr(charNum), true);
+					        && ((isCharPotentialHeader(nextText, 0)
+					             && ASBase::findHeader(nextText, 0, headers) != &AS_IF)
+					            || nextText[0] == '{'))
+				else
+		if (passedSemicolon)    // need to break the formattedLine
+			if (parenStack->back() == 0 && !isCharImmediatelyPostComment && currentChar != ';') // allow ;;
+				// does a one-line block have ending comments?
+				if (isBraceType(braceTypeStack->back(), SINGLE_LINE_TYPE))
+					size_t blockEnd = currentLine.rfind(AS_CLOSE_BRACE);
+					assert(blockEnd != string::npos);
+					// move ending comments to this formattedLine
+					if (isBeforeAnyLineEndComment(blockEnd))
+						size_t commentStart = currentLine.find_first_not_of(" \t", blockEnd + 1);
+						assert(commentStart != string::npos);
+						assert((currentLine.compare(commentStart, 2, "//") == 0)
+						       || (currentLine.compare(commentStart, 2, "/*") == 0));
+						formattedLine.append(getIndentLength() - 1, ' ');
+						// append comment
+						int charNumSave = charNum;
+						charNum = commentStart;
+						while (charNum < (int) currentLine.length())
+							currentChar = currentLine[charNum];
+							if (currentChar == '\t' && shouldConvertTabs)
+								convertTabToSpaces();
+							formattedLine.append(1, currentChar);
+							++charNum;
+						size_t commentLength = currentLine.length() - commentStart;
+						currentLine.erase(commentStart, commentLength);
+						charNum = charNumSave;
+				shouldReparseCurrentChar = true;
+				if (formattedLine.find_first_not_of(" \t") != string::npos)
+				if (needHeaderOpeningBrace)
+					isCharImmediatelyPostCloseBlock = true;
+				continue;
+		if (passedColon)
+			        && (formattedLine.find_first_not_of(" \t") != string::npos))
+				continue;
+		// Check if in template declaration, e.g. foo<bar> or foo<bar,fig>
+		if (!isInTemplate && currentChar == '<')
+			checkIfTemplateOpener();
+		// Check for break return type
+		if ((size_t) charNum >= methodBreakCharNum && methodBreakLineNum == 0)
+			if ((size_t) charNum == methodBreakCharNum)
+		// Check for attach return type
+		if ((size_t) charNum >= methodAttachCharNum && methodAttachLineNum == 0)
+			if ((size_t) charNum == methodAttachCharNum)
+				int pa = pointerAlignment;
+				int ra = referenceAlignment;
+				int itemAlignment = (previousNonWSChar == '*' || previousNonWSChar == '^')
+				                    ? pa : ((ra == REF_SAME_AS_PTR) ? pa : ra);
+				if (previousNonWSChar == '*' || previousNonWSChar == '&' || previousNonWSChar == '^')
+					if (itemAlignment == REF_ALIGN_TYPE)
+						        && !isWhiteSpace(formattedLine[formattedLine.length() - 1]))
+							formattedLine.append(1, ' ');
+					else if (itemAlignment == REF_ALIGN_MIDDLE)
+					else if (itemAlignment == REF_ALIGN_NAME)
+						        && isWhiteSpace(formattedLine[formattedLine.length() - 1]))
+							formattedLine.erase(formattedLine.length() - 1);
+					else
+						if (formattedLine.length() > 1
+						        && !isWhiteSpace(formattedLine[formattedLine.length() - 2]))
+				else
+		// handle parens
+		if (currentChar == '(' || currentChar == '[' || (isInTemplate && currentChar == '<'))
+			questionMarkStack->push_back(foundQuestionMark);
+			parenStack->back()++;
+			if (currentChar == '[')
+				if (getAlignMethodColon() && squareBracketCount == 1 && isCStyle())
+					objCColonAlign = findObjCColonAlignment();
+		else if (currentChar == ')' || currentChar == ']' || (isInTemplate && currentChar == '>'))
+			parenStack->back()--;
+			// this can happen in preprocessor directives
+			if (parenStack->back() < 0)
+				parenStack->back() = 0;
+			if (!questionMarkStack->empty())
+				foundQuestionMark = questionMarkStack->back();
+				questionMarkStack->pop_back();
+			if (isInTemplate && currentChar == '>')
+				templateDepth--;
+				if (templateDepth == 0)
+					isImmediatelyPostTemplate = true;
+			// check if this parenthesis closes a header, e.g. if (...), while (...)
+			if (isInHeader && parenStack->back() == 0)
+				isImmediatelyPostHeader = true;
+			if (currentChar == ']')
+			if (currentChar == ')')
+				if (parenStack->back() == 0)
+					endOfAsmReached = true;
+		// handle braces
+		if (currentChar == '{' || currentChar == '}')
+			// if appendOpeningBrace this was already done for the original brace
+			if (currentChar == '{' && !appendOpeningBrace)
+				BraceType newBraceType = getBraceType();
+				isInEnum = false;
+				//assert(methodBreakCharNum == string::npos);	// comment out
+				//assert(methodBreakLineNum == 0);				// comment out
+				isPreviousBraceBlockRelated = !isBraceType(newBraceType, ARRAY_TYPE);
+				braceTypeStack->emplace_back(newBraceType);
+				preBraceHeaderStack->emplace_back(currentHeader);
+				structStack->push_back(isInIndentableStruct);
+				if (isBraceType(newBraceType, STRUCT_TYPE) && isCStyle())
+					isInIndentableStruct = isStructAccessModified(currentLine, charNum);
+				else
+					isInIndentableStruct = false;
+			// this must be done before the braceTypeStack is popped
+			BraceType braceType = braceTypeStack->back();
+			bool isOpeningArrayBrace = (isBraceType(braceType, ARRAY_TYPE)
+			                            && braceTypeStack->size() >= 2
+			                            && !isBraceType((*braceTypeStack)[braceTypeStack->size() - 2], ARRAY_TYPE)
+			if (currentChar == '}')
+				// if a request has been made to append a post block empty line,
+				// but the block exists immediately before a closing brace,
+				// then there is no need for the post block empty line.
+				if (isInAsm)
+				isInAsmOneLine = isInQuote = false;
+				if (braceTypeStack->size() > 1)
+					previousBraceType = braceTypeStack->back();
+					braceTypeStack->pop_back();
+					isPreviousBraceBlockRelated = !isBraceType(braceType, ARRAY_TYPE);
+				else
+				if (!preBraceHeaderStack->empty())
+					currentHeader = preBraceHeaderStack->back();
+					preBraceHeaderStack->pop_back();
+				else
+				if (!structStack->empty())
+					isInIndentableStruct = structStack->back();
+					structStack->pop_back();
+				else
+				if (isNonInStatementArray
+				        && (!isBraceType(braceTypeStack->back(), ARRAY_TYPE)	// check previous brace
+				            || peekNextChar() == ';'))							// check for "};" added V2.01
+					isImmediatelyPostNonInStmt = true;
+				if (!shouldBreakOneLineStatements
+				        && ASBeautifier::getNextWord(currentLine, charNum) == AS_ELSE)
+					// handle special case of "else" at the end of line
+					if (ASBeautifier::peekNextChar(currentLine, nextText + 3) == ' ')
+			// format braces
+			if (isBraceType(braceType, ARRAY_TYPE))
+				formatArrayBraces(braceType, isOpeningArrayBrace);
+			else
+					formatOpeningBrace(braceType);
+				else
+					formatClosingBrace(braceType);
+			continue;
+		if ((((previousCommandChar == '{' && isPreviousBraceBlockRelated)
+		        || ((previousCommandChar == '}'
+		             && !isImmediatelyPostEmptyBlock
+		             && isPreviousBraceBlockRelated
+		             && !isPreviousCharPostComment       // Fixes wrongly appended newlines after '}' immediately after comments
+		             && !isBraceType(previousBraceType, DEFINITION_TYPE))
+		            && !isBraceType(braceTypeStack->back(), DEFINITION_TYPE)))
+		        // check for array
+		        || (previousCommandChar == '{'			// added 9/30/2010
+		            && isBraceType(braceTypeStack->back(), ARRAY_TYPE)
+		            && isNonInStatementArray)
+		        // check for pico one line braces
+		        || (formattingStyle == STYLE_PICO
+		            && (previousCommandChar == '{' && isPreviousBraceBlockRelated)
+		            && isBraceType(braceTypeStack->back(), SINGLE_LINE_TYPE)
+		            && braceFormatMode == RUN_IN_MODE)
+			isCharImmediatelyPostOpenBlock = (previousCommandChar == '{');
+			isCharImmediatelyPostCloseBlock = (previousCommandChar == '}');
+			if (isCharImmediatelyPostOpenBlock
+			        && !isCharImmediatelyPostComment
+			        && !isCharImmediatelyPostLineComment)
+				if (braceFormatMode == NONE_MODE)
+					        && (isBraceType(braceTypeStack->back(), BREAK_BLOCK_TYPE)
+					            || shouldBreakOneLineBlocks))
+					else if (currentLineBeginsWithBrace)
+						formatRunIn();
+					else
+						breakLine();
+				else if (braceFormatMode == RUN_IN_MODE
+				         && currentChar != '#')
+					formatRunIn();
+				else
+			else if (isCharImmediatelyPostCloseBlock
+			         && shouldBreakOneLineStatements
+			         && ((isLegalNameChar(currentChar) && currentChar != '.')
+			             || currentChar == '+'
+			             || currentChar == '-'
+			             || currentChar == '*'
+			             || currentChar == '&'
+			             || currentChar == '('))
+		// reset block handling flags
+		// Objective-C method prefix with no return type
+		if (isImmediatelyPostObjCMethodPrefix && currentChar != '(')
+			if (shouldPadMethodPrefix || shouldUnPadMethodPrefix)
+				padObjCMethodPrefix();
+		// look for headers
+		bool isPotentialHeader = isCharPotentialHeader(currentLine, charNum);
+		if (isPotentialHeader && !isInTemplate && squareBracketCount == 0)
+			newHeader = findHeader(headers);
+			        && ASBeautifier::peekNextChar(
+			            currentLine, charNum + (*newHeader).length() - 1) != ':')
+			if (isCStyle()
+				if (currentLine.find_first_of("=;", charNum) != string::npos)
+			if (isJavaStyle()
+			        && (newHeader == &AS_SYNCHRONIZED))
+				// want synchronized statements not synchronized methods
+				if (!isBraceType(braceTypeStack->back(), COMMAND_TYPE))
+			             currentLine, charNum + (*newHeader).length() - 1) != '(')
+				foundClosingHeader = isClosingHeader(newHeader);
+				if (!foundClosingHeader)
+					// these are closing headers
+					if ((newHeader == &AS_WHILE && currentHeader == &AS_DO)
+					        || (newHeader == &_AS_FINALLY && currentHeader == &_AS_TRY)
+					        || (newHeader == &_AS_EXCEPT && currentHeader == &_AS_TRY))
+						foundClosingHeader = true;
+					// don't append empty block for these related headers
+					else if (isSharpStyle()
+					         && previousNonWSChar == '}'
+					         && ((newHeader == &AS_SET && currentHeader == &AS_GET)
+					             || (newHeader == &AS_REMOVE && currentHeader == &AS_ADD))
+				// TODO: this can be removed in a future release
+				// version 3.0 - break erroneous attached header from previous versions
+				        && currentLine[currentLine.find_first_not_of(" \t")] == '}')
+				// END TODO
+				const string* previousHeader = currentHeader;
+				currentHeader = newHeader;
+				needHeaderOpeningBrace = true;
+				// is the previous statement on the same line?
+				if ((previousNonWSChar == ';' || previousNonWSChar == ':')
+				        && !isInLineBreak
+					// if breaking lines, break the line at the header
+					// except for multiple 'case' statements on a line
+					if (maxCodeLength != string::npos
+					        && previousHeader != &AS_CASE)
+					else
+						isHeaderInMultiStatementLine = true;
+				if (foundClosingHeader && previousNonWSChar == '}')
+					if (isOkToBreakBlock(braceTypeStack->back()))
+						isLineBreakBeforeClosingHeader();
+					// get the adjustment for a comment following the closing header
+						nextLineSpacePadNum = getNextLineCommentAdjustment();
+					else
+						spacePadNum = getCurrentLineCommentAdjustment();
+				// check if the found header is non-paren header
+				isNonParenHeader = findHeader(nonParenHeaders) != nullptr;
+				if (isNonParenHeader
+				        && (currentHeader == &AS_CATCH
+				            || currentHeader == &AS_CASE))
+					int startChar = charNum + currentHeader->length() - 1;
+					if (ASBeautifier::peekNextChar(currentLine, startChar) == '(')
+				// join 'else if' statements
+				if (currentHeader == &AS_IF
+				        && previousHeader == &AS_ELSE
+				        && isInLineBreak
+				        && !shouldBreakElseIfs
+				        && !isImmediatelyPostPreprocessor)
+					// 'else' must be last thing on the line
+					size_t start = formattedLine.length() >= 6 ? formattedLine.length() - 6 : 0;
+					if (formattedLine.find(AS_ELSE, start) != string::npos)
+						appendSpacePad();
+				appendSequence(*currentHeader);
+				goForward(currentHeader->length() - 1);
+				// if a paren-header is found add a space after it, if needed
+				// this checks currentLine, appendSpacePad() checks formattedLine
+				// in 'case' and C# 'catch' can be either a paren or non-paren header
+				if (shouldPadHeader
+				        && !isNonParenHeader
+				        && charNum < (int) currentLine.length() - 1 && !isWhiteSpace(currentLine[charNum + 1]))
+					appendSpacePad();
+				// Signal that a header has been reached
+				// *** But treat a closing while() (as in do...while)
+				//     as if it were NOT a header since a closing while()
+				//     should never have a block after it!
+				if (currentHeader != &AS_CASE && currentHeader != &AS_DEFAULT
+				        && !(foundClosingHeader && currentHeader == &AS_WHILE))
+					isInHeader = true;
+					// in C# 'catch' and 'delegate' can be a paren or non-paren header
+					if (isNonParenHeader && !isSharpStyleWithParen(currentHeader))
+				if (shouldBreakBlocks
+				        && !isHeaderInMultiStatementLine)
+					if (previousHeader == nullptr
+					        && !foundClosingHeader
+					        && !isCharImmediatelyPostOpenBlock
+					        && !isImmediatelyPostCommentOnly)
+						isPrependPostBlockEmptyLineRequested = true;
+					if (isClosingHeader(currentHeader)
+					        || foundClosingHeader)
+					if (shouldBreakClosingHeaderBlocks
+					        && isCharImmediatelyPostCloseBlock
+					        && !(currentHeader == &AS_WHILE			// do-while
+					             && foundClosingHeader))
+				if (currentHeader == &AS_CASE
+				        || currentHeader == &AS_DEFAULT)
+					isInCase = true;
+				continue;
+			else if ((newHeader = findHeader(preDefinitionHeaders)) != nullptr
+			         && parenStack->back() == 0
+			         && !isInEnum)		// not C++11 enum class
+				if (newHeader == &AS_NAMESPACE || newHeader == &AS_MODULE)
+					foundNamespaceHeader = true;
+				if (newHeader == &AS_CLASS)
+					foundClassHeader = true;
+				if (newHeader == &AS_STRUCT)
+					foundStructHeader = true;
+				if (newHeader == &AS_INTERFACE && !foundNamespaceHeader && !foundClassHeader)
+					foundInterfaceHeader = true;
+				foundPreDefinitionHeader = true;
+				appendSequence(*newHeader);
+				goForward(newHeader->length() - 1);
+				continue;
+			else if ((newHeader = findHeader(preCommandHeaders)) != nullptr)
+				if (previousNonWSChar == ')')
+			else if ((newHeader = findHeader(castOperators)) != nullptr)
+				foundCastOperator = true;
+				continue;
+		}   // (isPotentialHeader && !isInTemplate)
+		if (isInLineBreak)          // OK to break line here
+			breakLine();
+			if (isInVirginLine)		// adjust for the first line
+				lineCommentNoBeautify = lineCommentNoIndent;
+					isInIndentablePreproc = isIndentableProprocessor;
+		if (previousNonWSChar == '}' || currentChar == ';')
+				if (((shouldBreakOneLineStatements
+				        || isBraceType(braceTypeStack->back(), SINGLE_LINE_TYPE))
+				        && !(attachClosingBraceMode && peekNextChar() == '}'))
+				else if (!shouldBreakOneLineStatements
+				        && currentHeader != nullptr
+				        && currentHeader != &AS_CASE
+				        && currentHeader != &AS_DEFAULT
+				        && parenStack->back() == 0)
+					isAppendPostBlockEmptyLineRequested = true;
+			if (currentChar != ';'
+			        || (needHeaderOpeningBrace && parenStack->back() == 0))
+			resetEndOfStatement();
+		if (currentChar == ':'
+		        && previousChar != ':'         // not part of '::'
+		        && peekNextChar() != ':')      // not part of '::'
+			if (isInCase)
+				isInCase = false;
+				if (shouldBreakOneLineStatements)
+					passedColon = true;
+			else if (isCStyle()                     // for C/C++ only
+			         && !foundQuestionMark          // not in a ?: sequence
+			         && !foundPreDefinitionHeader   // not in a definition block
+			         && previousCommandChar != ')'  // not after closing paren of a method header
+			         && !foundPreCommandHeader      // not after a 'noexcept'
+			         && squareBracketCount == 0     // not in objC method call
+			         && !isInObjCMethodDefinition   // not objC '-' or '+' method
+			         && !isInObjCInterface          // not objC @interface
+			         && !isInObjCSelector           // not objC @selector
+			         && !isDigit(peekNextChar())    // not a bit field
+			         && !isInEnum                   // not an enum with a base type
+			         && !isInAsm                    // not in extended assembler
+			         && !isInAsmOneLine             // not in extended assembler
+			         && !isInAsmBlock)              // not in extended assembler
+			if (isCStyle()
+			        && (squareBracketCount > 0 || isInObjCMethodDefinition || isInObjCSelector)
+			        && !foundQuestionMark)			// not in a ?: sequence
+				isInObjCParam = true;
+				if (shouldPadMethodColon)
+					padObjCMethodColon();
+			if (isInObjCInterface)
+				appendSpacePad();
+				if ((int) currentLine.length() > charNum + 1
+				        && !isWhiteSpace(currentLine[charNum + 1]))
+					currentLine.insert(charNum + 1, " ");
+			if (isClassInitializer())
+		if (currentChar == '?')
+			foundQuestionMark = true;
+		if (isPotentialHeader && !isInTemplate)
+			if (findKeyword(currentLine, charNum, AS_NEW)
+			        || findKeyword(currentLine, charNum, AS_DELETE))
+				isImmediatelyPostNewDelete = true;
+			if (findKeyword(currentLine, charNum, AS_RETURN))
+				isInPotentialCalculation = true;
+				isImmediatelyPostReturn = true;		// return is the same as an = sign
+			if (findKeyword(currentLine, charNum, AS_OPERATOR))
+				isImmediatelyPostOperator = true;
+			if (findKeyword(currentLine, charNum, AS_ENUM))
+				size_t firstNum = currentLine.find_first_of("(){},/");
+				if (firstNum == string::npos
+				        || currentLine[firstNum] == '{'
+				        || currentLine[firstNum] == '/')
+					isInEnum = true;
+			if (isCStyle()
+			        && findKeyword(currentLine, charNum, AS_THROW)
+			        && !foundPreCommandHeader)      // 'const' throw()
+				isImmediatelyPostThrow = true;
+			if (isCStyle() && findKeyword(currentLine, charNum, AS_EXTERN) && isExternC())
+				isInExternC = true;
+			if (isCStyle() && findKeyword(currentLine, charNum, AS_AUTO)
+			            || isBraceType(braceTypeStack->back(), DEFINITION_TYPE)))
+				foundTrailingReturnType = true;
+			// check for break/attach return type
+			if (shouldBreakReturnType || shouldBreakReturnTypeDecl
+			        || shouldAttachReturnType || shouldAttachReturnTypeDecl)
+				if ((isBraceType(braceTypeStack->back(), NULL_TYPE)
+				        && !returnTypeChecked
+				        && !foundNamespaceHeader
+				        // bypass objective-C and java @ character
+				        && charNum == (int) currentLine.find_first_not_of(" \t")
+				        && !(isCStyle() && isCharPotentialHeader(currentLine, charNum)
+				             && (findKeyword(currentLine, charNum, AS_PUBLIC)
+				                 || findKeyword(currentLine, charNum, AS_PRIVATE)
+				                 || findKeyword(currentLine, charNum, AS_PROTECTED))))
+					findReturnTypeSplitPoint(currentLine);
+					returnTypeChecked = true;
+			// Objective-C NSException macros are preCommandHeaders
+			if (isCStyle() && findKeyword(currentLine, charNum, AS_NS_DURING))
+				foundPreCommandMacro = true;
+			if (isCStyle() && findKeyword(currentLine, charNum, AS_NS_HANDLER))
+			if (isCStyle() && isExecSQL(currentLine, charNum))
+				isInExecSQL = true;
+			if (isCStyle())
+				if (findKeyword(currentLine, charNum, AS_ASM)
+				        || findKeyword(currentLine, charNum, AS__ASM__))
+					isInAsm = true;
+				else if (findKeyword(currentLine, charNum, AS_MS_ASM)		// microsoft specific
+				         || findKeyword(currentLine, charNum, AS_MS__ASM))
+					int index = 4;
+					if (peekNextChar() == '_')	// check for __asm
+						index = 5;
+					char peekedChar = ASBase::peekNextChar(currentLine, charNum + index);
+					else
+			if (isJavaStyle()
+			        && (findKeyword(currentLine, charNum, AS_STATIC)
+			            && isNextCharOpeningBrace(charNum + 6)))
+				isJavaStaticConstructor = true;
+			if (isSharpStyle()
+			        && (findKeyword(currentLine, charNum, AS_DELEGATE)
+			            || findKeyword(currentLine, charNum, AS_UNCHECKED)))
+				isSharpDelegate = true;
+			// append the entire name
+			string name = getCurrentWord(currentLine, charNum);
+			// must pad the 'and' and 'or' operators if required
+			if (name == "and" || name == "or")
+				if (shouldPadOperators && previousNonWSChar != ':')
+					appendSpacePad();
+					appendOperator(name);
+					goForward(name.length() - 1);
+					if (!isBeforeAnyComment()
+					        && !(currentLine.compare(charNum + 1, 1, AS_SEMICOLON) == 0)
+					        && !(currentLine.compare(charNum + 1, 2, AS_SCOPE_RESOLUTION) == 0))
+						appendSpaceAfter();
+				else
+			else
+				appendSequence(name);
+			continue;
+		// determine if this is an Objective-C statement
+		if (currentChar == '@'
+		        && isCStyle()
+		        && (int) currentLine.length() > charNum + 1
+		        && isCharPotentialHeader(currentLine, charNum + 1)
+		        && findKeyword(currentLine, charNum + 1, AS_INTERFACE)
+		        && isBraceType(braceTypeStack->back(), NULL_TYPE))
+			string name = '@' + AS_INTERFACE;
+			continue;
+		else if (currentChar == '@'
+		         && isCStyle()
+		         && findKeyword(currentLine, charNum + 1, AS_SELECTOR))
+			isInObjCSelector = true;
+			string name = '@' + AS_SELECTOR;
+			continue;
+		else if ((currentChar == '-' || currentChar == '+')
+		         && isCStyle()
+		         && (int) currentLine.find_first_not_of(" \t") == charNum
+		         && !isInPotentialCalculation
+		             || (isBraceType(braceTypeStack->back(), EXTERN_TYPE))))
+			isImmediatelyPostObjCMethodPrefix = true;
+			if (getAlignMethodColon())
+			continue;
+		// determine if this is a potential calculation
+		bool isPotentialOperator = isCharPotentialOperator(currentChar);
+		newHeader = nullptr;
+			newHeader = findOperator(operators);
+			// check for Java ? wildcard
+			if (newHeader != nullptr
+			        && newHeader == &AS_GCC_MIN_ASSIGN
+			        && isJavaStyle()
+			        && isInTemplate)
+			if (newHeader != nullptr)
+				if (newHeader == &AS_LAMBDA)
+					foundPreCommandHeader = true;
+				// correct mistake of two >> closing a template
+				if (isInTemplate && (newHeader == &AS_GR_GR || newHeader == &AS_GR_GR_GR))
+					newHeader = &AS_GR;
+				if (!isInPotentialCalculation)
+					// must determine if newHeader is an assignment operator
+					// do NOT use findOperator - the length must be exact!!!
+					if (find(begin(*assignmentOperators), end(*assignmentOperators), newHeader)
+					        != end(*assignmentOperators))
+						char peekedChar = peekNextChar();
+						isInPotentialCalculation = !(newHeader == &AS_EQUAL && peekedChar == '*')
+						                           && !(newHeader == &AS_EQUAL && peekedChar == '&')
+						                           && !isCharImmediatelyPostOperator;
+		// process pointers and references
+		// check newHeader to eliminate things like '&&' sequence
+		if (newHeader != nullptr && !isJavaStyle()
+		        && (newHeader == &AS_MULT
+		            || newHeader == &AS_BIT_AND
+		            || newHeader == &AS_BIT_XOR
+		            || newHeader == &AS_AND)
+		        && isPointerOrReference())
+			if (!isDereferenceOrAddressOf() && !isOperatorPaddingDisabled())
+				formatPointerOrReference();
+			else
+				appendOperator(*newHeader);
+			isImmediatelyPostPointerOrReference = true;
+			continue;
+		if (shouldPadOperators && newHeader != nullptr && !isOperatorPaddingDisabled())
+			padOperators(newHeader);
+			continue;
+		// remove spaces before commas
+		if (currentChar == ',')
+			const size_t len = formattedLine.length();
+			size_t lastText = formattedLine.find_last_not_of(' ');
+			if (lastText != string::npos && lastText < len - 1)
+				formattedLine.resize(lastText + 1);
+				int size_diff = len - (lastText + 1);
+				spacePadNum -= size_diff;
+		// pad commas and semi-colons
+		        || (currentChar == ',' && (shouldPadOperators || shouldPadCommas)))
+			char nextChar = ' ';
+			if (charNum + 1 < (int) currentLine.length())
+				nextChar = currentLine[charNum + 1];
+			if (!isWhiteSpace(nextChar)
+			        && nextChar != '}'
+			        && nextChar != ')'
+			        && nextChar != ']'
+			        && nextChar != '>'
+			        && nextChar != ';'
+			        /* && !(isBraceType(braceTypeStack->back(), ARRAY_TYPE)) */
+				continue;
+		// pad parens
+		if (currentChar == '(' || currentChar == ')')
+			if (currentChar == '(')
+				        && (isCharImmediatelyPostReturn
+				            || isCharImmediatelyPostThrow
+				            || isCharImmediatelyPostNewDelete))
+					appendSpacePad();
+			if (shouldPadParensOutside || shouldPadParensInside || shouldUnPadParens || shouldPadFirstParen)
+				padParens();
+			else
+			if (isInObjCMethodDefinition)
+				if (currentChar == '(' && isImmediatelyPostObjCMethodPrefix)
+					isInObjCReturnType = true;
+				else if (currentChar == ')' && isInObjCReturnType)
+					if (shouldPadReturnType || shouldUnPadReturnType)
+						padObjCReturnType();
+				else if (isInObjCParam
+				         && (shouldPadParamType || shouldUnPadParamType))
+					padObjCParamType();
+			continue;
+		// bypass the entire operator
+			continue;
+	}   // end of while loop  *  end of while loop  *  end of while loop  *  end of while loop
+	// return a beautified (i.e. correctly indented) line.
+	string beautifiedLine;
+	size_t readyFormattedLineLength = trim(readyFormattedLine).length();
+	bool isInNamespace = isBraceType(braceTypeStack->back(), NAMESPACE_TYPE);
+	if (prependEmptyLine		// prepend a blank line before this formatted line
+	        && readyFormattedLineLength > 0
+	        && previousReadyFormattedLineLength > 0)
+		isLineReady = true;		// signal a waiting readyFormattedLine
+		beautifiedLine = beautify("");
+		previousReadyFormattedLineLength = 0;
+		// call the enhancer for new empty lines
+		enhancer->enhance(beautifiedLine, isInNamespace, isInPreprocessorBeautify, isInBeautifySQL);
+	else		// format the current formatted line
+		runInIndentContinuation = runInIndentChars;
+		beautifiedLine = beautify(readyFormattedLine);
+		previousReadyFormattedLineLength = readyFormattedLineLength;
+		// the enhancer is not called for no-indent line comments
+		if (!lineCommentNoBeautify && !isFormattingModeOff)
+		isElseHeaderIndent = elseHeaderFollowsComments;
+		isCaseHeaderCommentIndent = caseHeaderFollowsComments;
+		objCColonAlignSubsequent = objCColonAlign;
+		if (isCharImmediatelyPostNonInStmt)
+			isNonInStatementArray = false;
+		isInPreprocessorBeautify = isInPreprocessor;	// used by ASEnhancer
+		isInBeautifySQL = isInExecSQL;					// used by ASEnhancer
+	assert(computeChecksumOut(beautifiedLine));
+	return beautifiedLine;
+ * check if there are any indented lines ready to be read by nextLine()
+ * @return    are there any indented lines ready?
+bool ASFormatter::hasMoreLines() const
+	return !endOfCodeReached;
+ * comparison function for BraceType enum
+bool ASFormatter::isBraceType(BraceType a, BraceType b) const
+	if (a == NULL_TYPE || b == NULL_TYPE)
+		return (a == b);
+	return ((a & b) == b);
+ * set the formatting style.
+ * @param style         the formatting style.
+void ASFormatter::setFormattingStyle(FormatStyle style)
+	formattingStyle = style;
+ * set the add braces mode.
+ * options:
+ *    true     braces added to headers for single line statements.
+ *    false    braces NOT added to headers for single line statements.
+ * @param state         the add braces state.
+void ASFormatter::setAddBracesMode(bool state)
+	shouldAddBraces = state;
+ * set the add one line braces mode.
+ * options:
+ *    true     one line braces added to headers for single line statements.
+ *    false    one line braces NOT added to headers for single line statements.
+ * @param state         the add one line braces state.
+void ASFormatter::setAddOneLineBracesMode(bool state)
+	shouldAddOneLineBraces = state;
+ * set the remove braces mode.
+ * options:
+ *    true     braces removed from headers for single line statements.
+ *    false    braces NOT removed from headers for single line statements.
+ * @param state         the remove braces state.
+void ASFormatter::setRemoveBracesMode(bool state)
+	shouldRemoveBraces = state;
+// retained for compatibility with release 2.06
+// "Brackets" have been changed to "Braces" in 3.0
+// it is referenced only by the old "bracket" options
+void ASFormatter::setAddBracketsMode(bool state)
+	setAddBracesMode(state);
+void ASFormatter::setAddOneLineBracketsMode(bool state)
+	setAddOneLineBracesMode(state);
+void ASFormatter::setRemoveBracketsMode(bool state)
+	setRemoveBracesMode(state);
+void ASFormatter::setBreakClosingHeaderBracketsMode(bool state)
+	setBreakClosingHeaderBracesMode(state);
+ * set the brace formatting mode.
+ * options:
+ * @param mode         the brace formatting mode.
+void ASFormatter::setBraceFormatMode(BraceMode mode)
+	braceFormatMode = mode;
+ * set 'break after' mode for maximum code length
+ * @param state         the 'break after' mode.
+void ASFormatter::setBreakAfterMode(bool state)
+	shouldBreakLineAfterLogical = state;
+ * set closing header brace breaking mode
+ * options:
+ *    true     braces just before closing headers (e.g. 'else', 'catch')
+ *             will be broken, even if standard braces are attached.
+ *    false    closing header braces will be treated as standard braces.
+ * @param state         the closing header brace breaking mode.
+void ASFormatter::setBreakClosingHeaderBracesMode(bool state)
+	shouldBreakClosingHeaderBraces = state;
+ * set 'else if()' breaking mode
+ * options:
+ *    true     'else' headers will be broken from their succeeding 'if' headers.
+ *    false    'else' headers will be attached to their succeeding 'if' headers.
+ * @param state         the 'else if()' breaking mode.
+void ASFormatter::setBreakElseIfsMode(bool state)
+	shouldBreakElseIfs = state;
+* set comma padding mode.
+* options:
+*    true     statement commas and semicolons will be padded with spaces around them.
+*    false    statement commas and semicolons will not be padded.
+* @param state         the padding mode.
+void ASFormatter::setCommaPaddingMode(bool state)
+	shouldPadCommas = state;
+ * set maximum code length
+ * @param max         the maximum code length.
+void ASFormatter::setMaxCodeLength(int max)
+	maxCodeLength = max;
+ * set operator padding mode.
+ * options:
+ *    true     statement operators will be padded with spaces around them.
+ *    false    statement operators will not be padded.
+ * @param state         the padding mode.
+void ASFormatter::setOperatorPaddingMode(bool state)
+	shouldPadOperators = state;
+ * set parenthesis outside padding mode.
+ * options:
+ *    true     statement parentheses will be padded with spaces around them.
+ *    false    statement parentheses will not be padded.
+void ASFormatter::setParensOutsidePaddingMode(bool state)
+	shouldPadParensOutside = state;
+ * set parenthesis inside padding mode.
+ * options:
+ *    true     statement parenthesis will be padded with spaces around them.
+ *    false    statement parenthesis will not be padded.
+void ASFormatter::setParensInsidePaddingMode(bool state)
+	shouldPadParensInside = state;
+ * set padding mode before one or more open parentheses.
+ * options:
+ *    true     first open parenthesis will be padded with a space before.
+ *    false    first open parenthesis will not be padded.
+void ASFormatter::setParensFirstPaddingMode(bool state)
+	shouldPadFirstParen = state;
+ * set header padding mode.
+ * options:
+ *    true     headers will be padded with spaces around them.
+ *    false    headers will not be padded.
+void ASFormatter::setParensHeaderPaddingMode(bool state)
+	shouldPadHeader = state;
+ * set parenthesis unpadding mode.
+ * options:
+ *    true     statement parenthesis will be unpadded with spaces removed around them.
+ *    false    statement parenthesis will not be unpadded.
+void ASFormatter::setParensUnPaddingMode(bool state)
+	shouldUnPadParens = state;
+* set the state of the preprocessor indentation option.
+* If true, #ifdef blocks at level 0 will be indented.
+* @param   state             state of option.
+void ASFormatter::setPreprocBlockIndent(bool state)
+	shouldIndentPreprocBlock = state;
+ * Set strip comment prefix mode.
+ * options:
+ *    true     strip leading '*' in a comment.
+ *    false    leading '*' in a comment will be left unchanged.
+ * @param state         the strip comment prefix mode.
+void ASFormatter::setStripCommentPrefix(bool state)
+	shouldStripCommentPrefix = state;
+ * set objective-c '-' or '+' class prefix padding mode.
+ * options:
+ *    true     class prefix will be padded a spaces after them.
+ *    false    class prefix will be left unchanged.
+void ASFormatter::setMethodPrefixPaddingMode(bool state)
+	shouldPadMethodPrefix = state;
+ * set objective-c '-' or '+' class prefix unpadding mode.
+ * options:
+ *    true     class prefix will be unpadded with spaces after them removed.
+ *    false    class prefix will left unchanged.
+ * @param state         the unpadding mode.
+void ASFormatter::setMethodPrefixUnPaddingMode(bool state)
+	shouldUnPadMethodPrefix = state;
+// set objective-c '-' or '+' return type padding mode.
+void ASFormatter::setReturnTypePaddingMode(bool state)
+	shouldPadReturnType = state;
+// set objective-c '-' or '+' return type unpadding mode.
+void ASFormatter::setReturnTypeUnPaddingMode(bool state)
+	shouldUnPadReturnType = state;
+// set objective-c method parameter type padding mode.
+void ASFormatter::setParamTypePaddingMode(bool state)
+	shouldPadParamType = state;
+// set objective-c method parameter type unpadding mode.
+void ASFormatter::setParamTypeUnPaddingMode(bool state)
+	shouldUnPadParamType = state;
+ * set objective-c method colon padding mode.
+ * @param mode         objective-c colon padding mode.
+void ASFormatter::setObjCColonPaddingMode(ObjCColonPad mode)
+	shouldPadMethodColon = true;
+	objCColonPadMode = mode;
+ * set option to attach closing braces
+ * @param state        true = attach, false = don't attach.
+void ASFormatter::setAttachClosingBraceMode(bool state)
+	attachClosingBraceMode = state;
+ * set option to attach class braces
+ * @param state        true = attach, false = use style default.
+void ASFormatter::setAttachClass(bool state)
+	shouldAttachClass = state;
+ * set option to attach extern "C" braces
+void ASFormatter::setAttachExternC(bool state)
+	shouldAttachExternC = state;
+ * set option to attach namespace braces
+void ASFormatter::setAttachNamespace(bool state)
+	shouldAttachNamespace = state;
+ * set option to attach inline braces
+void ASFormatter::setAttachInline(bool state)
+	shouldAttachInline = state;
+void ASFormatter::setAttachClosingWhile(bool state)
+	shouldAttachClosingWhile = state;
+ * set option to break/not break one-line blocks
+ * @param state        true = break, false = don't break.
+void ASFormatter::setBreakOneLineBlocksMode(bool state)
+	shouldBreakOneLineBlocks = state;
+* set one line headers breaking mode
+void ASFormatter::setBreakOneLineHeadersMode(bool state)
+	shouldBreakOneLineHeaders = state;
+* set option to break/not break lines consisting of multiple statements.
+* @param state        true = break, false = don't break.
+void ASFormatter::setBreakOneLineStatementsMode(bool state)
+	shouldBreakOneLineStatements = state;
+void ASFormatter::setCloseTemplatesMode(bool state)
+	shouldCloseTemplates = state;
+ * set option to convert tabs to spaces.
+ * @param state        true = convert, false = don't convert.
+void ASFormatter::setTabSpaceConversionMode(bool state)
+	shouldConvertTabs = state;
+ * set option to indent comments in column 1.
+ * @param state        true = indent, false = don't indent.
+void ASFormatter::setIndentCol1CommentsMode(bool state)
+	shouldIndentCol1Comments = state;
+ * set option to force all line ends to a particular style.
+ * @param fmt           format enum value
+void ASFormatter::setLineEndFormat(LineEndFormat fmt)
+	lineEnd = fmt;
+ * set option to break unrelated blocks of code with empty lines.
+void ASFormatter::setBreakBlocksMode(bool state)
+	shouldBreakBlocks = state;
+ * set option to break closing header blocks of code (such as 'else', 'catch', ...) with empty lines.
+void ASFormatter::setBreakClosingHeaderBlocksMode(bool state)
+	shouldBreakClosingHeaderBlocks = state;
+ * set option to delete empty lines.
+ * @param state        true = delete, false = don't delete.
+void ASFormatter::setDeleteEmptyLinesMode(bool state)
+	shouldDeleteEmptyLines = state;
+void ASFormatter::setBreakReturnType(bool state)
+	shouldBreakReturnType = state;
+void ASFormatter::setBreakReturnTypeDecl(bool state)
+	shouldBreakReturnTypeDecl = state;
+void ASFormatter::setAttachReturnType(bool state)
+	shouldAttachReturnType = state;
+void ASFormatter::setAttachReturnTypeDecl(bool state)
+	shouldAttachReturnTypeDecl = state;
+ * set the pointer alignment.
+ * @param alignment    the pointer alignment.
+void ASFormatter::setPointerAlignment(PointerAlign alignment)
+	pointerAlignment = alignment;
+void ASFormatter::setReferenceAlignment(ReferenceAlign alignment)
+	referenceAlignment = alignment;
+ * jump over several characters.
+ * @param i       the number of characters to jump over.
+void ASFormatter::goForward(int i)
+	while (--i >= 0)
+		getNextChar();
+ * peek at the next unread character.
+ * @return     the next unread character.
+char ASFormatter::peekNextChar() const
+	char ch = ' ';
+	size_t peekNum = currentLine.find_first_not_of(" \t", charNum + 1);
+	if (peekNum == string::npos)
+		return ch;
+	ch = currentLine[peekNum];
+	return ch;
+ * check if current placement is before a comment
+ * @return     is before a comment.
+bool ASFormatter::isBeforeComment() const
+	bool foundComment = false;
+		return foundComment;
+	foundComment = (currentLine.compare(peekNum, 2, "/*") == 0);
+ * check if current placement is before a comment or line-comment
+ * @return     is before a comment or line-comment.
+bool ASFormatter::isBeforeAnyComment() const
+	                || currentLine.compare(peekNum, 2, "//") == 0);
+ * if a block comment it must be at the end of the line
+bool ASFormatter::isBeforeAnyLineEndComment(int startPos) const
+	bool foundLineEndComment = false;
+	size_t peekNum = currentLine.find_first_not_of(" \t", startPos + 1);
+	if (peekNum != string::npos)
+		if (currentLine.compare(peekNum, 2, "//") == 0)
+			foundLineEndComment = true;
+		else if (currentLine.compare(peekNum, 2, "/*") == 0)
+			// comment must be closed on this line with nothing after it
+			size_t endNum = currentLine.find("*/", peekNum + 2);
+			if (endNum != string::npos)
+				size_t nextChar = currentLine.find_first_not_of(" \t", endNum + 2);
+				if (nextChar == string::npos)
+	return foundLineEndComment;
+ * check if current placement is before a comment followed by a line-comment
+ * @return     is before a multiple line-end comment.
+bool ASFormatter::isBeforeMultipleLineEndComments(int startPos) const
+	bool foundMultipleLineEndComment = false;
+		if (currentLine.compare(peekNum, 2, "/*") == 0)
+				if (nextChar != string::npos
+				        && currentLine.compare(nextChar, 2, "//") == 0)
+					foundMultipleLineEndComment = true;
+	return foundMultipleLineEndComment;
+ * get the next character, increasing the current placement in the process.
+ * the new character is inserted into the variable currentChar.
+ * @return   whether succeeded to receive the new character.
+bool ASFormatter::getNextChar()
+	previousChar = currentChar;
+		previousNonWSChar = currentChar;
+		if (!isInComment && !isInLineComment && !isInQuote
+		        && !isImmediatelyPostLineComment
+		        && !isInPreprocessor
+		        && !isSequenceReached("/*")
+		        && !isSequenceReached("//"))
+			previousCommandChar = currentChar;
+	        && (!isWhiteSpace(peekNextChar()) || isInComment || isInLineComment))
+		currentChar = currentLine[++charNum];
+		return true;
+	// end of line has been reached
+	return getNextLine();
+ * get the next line of input, increasing the current placement in the process.
+ * @param emptyLineWasDeleted         an empty line was deleted.
+ * @return   whether succeeded in reading the next line.
+bool ASFormatter::getNextLine(bool emptyLineWasDeleted /*false*/)
+	if (!sourceIterator->hasMoreLines())
+		endOfCodeReached = true;
+		return false;
+	if (appendOpeningBrace)
+		currentLine = "{";		// append brace that was removed from the previous line
+	else
+		currentLine = sourceIterator->nextLine(emptyLineWasDeleted);
+		assert(computeChecksumIn(currentLine));
+	// reset variables for new line
+	inLineNumber++;
+	if (endOfAsmReached)
+		endOfAsmReached = isInAsmBlock = isInAsm = false;
+	isInCase = false;
+	isInQuoteContinuation = isInVerbatimQuote || haveLineContinuationChar;
+	isImmediatelyPostEmptyLine = lineIsEmpty;
+	if (currentLine.length() == 0)
+		currentLine = string(" ");        // a null is inserted if this is not done
+	if (methodBreakLineNum > 0)
+		--methodBreakLineNum;
+	if (methodAttachLineNum > 0)
+		--methodAttachLineNum;
+	// unless reading in the first line of the file, break a new line.
+	if (!isVirgin)
+	else
+		isVirgin = false;
+	if (isImmediatelyPostNonInStmt)
+		isCharImmediatelyPostNonInStmt = true;
+	// check if is in preprocessor before line trimming
+	// a blank line after a \ will remove the flag
+	isImmediatelyPostPreprocessor = isInPreprocessor;
+	if (!isInComment
+	        && (previousNonWSChar != '\\'
+	            || isEmptyLine(currentLine)))
+	initNewLine();
+	if (isInBraceRunIn && previousNonWSChar == '{' && !isInComment)
+	// check for an empty line inside a command brace.
+	// if yes then read the next line (calls getNextLine recursively).
+	// must be after initNewLine.
+	if (shouldDeleteEmptyLines
+	        && lineIsEmpty
+	        && isBraceType((*braceTypeStack)[braceTypeStack->size() - 1], COMMAND_TYPE))
+		if (!shouldBreakBlocks || previousNonWSChar == '{' || !commentAndHeaderFollows())
+			isInPreprocessor = isImmediatelyPostPreprocessor;		// restore
+			return getNextLine(true);
+	return true;
+ * jump over the leading white space in the current line,
+ * IF the line does not begin a comment or is in a preprocessor definition.
+void ASFormatter::initNewLine()
+	size_t len = currentLine.length();
+	size_t tabSize = getTabLength();
+	charNum = 0;
+	// don't trim these
+	if (isInQuoteContinuation
+	        || (isInPreprocessor && !getPreprocDefineIndent()))
+		return;
+	// SQL continuation lines must be adjusted so the leading spaces
+	// is equivalent to the opening EXEC SQL
+	if (isInExecSQL)
+		// replace leading tabs with spaces
+		// so that continuation indent will be spaces
+		size_t tabCount_ = 0;
+		size_t i;
+		for (i = 0; i < currentLine.length(); i++)
+			if (!isWhiteSpace(currentLine[i]))		// stop at first text
+				break;
+			if (currentLine[i] == '\t')
+				size_t numSpaces = tabSize - ((tabCount_ + i) % tabSize);
+				currentLine.replace(i, 1, numSpaces, ' ');
+				tabCount_++;
+				i += tabSize - 1;
+		// this will correct the format if EXEC SQL is not a hanging indent
+		trimContinuationLine();
+		return;
+	// comment continuation lines must be adjusted so the leading spaces
+	// is equivalent to the opening comment
+	if (isInComment)
+		if (noTrimCommentContinuation)
+			leadingSpaces = tabIncrementIn = 0;
+		return;
+	// compute leading spaces
+	isImmediatelyPostCommentOnly = lineIsLineCommentOnly || lineEndsInCommentOnly;
+	// bypass whitespace at the start of a line
+	// preprocessor tabs are replaced later in the program
+	for (charNum = 0; isWhiteSpace(currentLine[charNum]) && charNum + 1 < (int) len; charNum++)
+		if (currentLine[charNum] == '\t' && !isInPreprocessor)
+			tabIncrementIn += tabSize - 1 - ((tabIncrementIn + charNum) % tabSize);
+	leadingSpaces = charNum + tabIncrementIn;
+	if (isSequenceReached("/*"))
+		doesLineStartComment = true;
+		if ((int) currentLine.length() > charNum + 2
+		        && currentLine.find("*/", charNum + 2) != string::npos)
+			lineIsCommentOnly = true;
+	else if (isSequenceReached("//"))
+		lineIsLineCommentOnly = true;
+	else if (isSequenceReached("{"))
+		currentLineBeginsWithBrace = true;
+		currentLineFirstBraceNum = charNum;
+		size_t firstText = currentLine.find_first_not_of(" \t", charNum + 1);
+		if (firstText != string::npos)
+			if (currentLine.compare(firstText, 2, "//") == 0)
+			else if (currentLine.compare(firstText, 2, "/*") == 0
+			         || isExecSQL(currentLine, firstText))
+				// get the extra adjustment
+				size_t j;
+				for (j = charNum + 1; j < firstText && isWhiteSpace(currentLine[j]); j++)
+					if (currentLine[j] == '\t')
+						tabIncrementIn += tabSize - 1 - ((tabIncrementIn + j) % tabSize);
+				leadingSpaces = j + tabIncrementIn;
+				if (currentLine.compare(firstText, 2, "/*") == 0)
+	else if (isWhiteSpace(currentLine[charNum]) && !(charNum + 1 < (int) currentLine.length()))
+		lineIsEmpty = true;
+	// do not trim indented preprocessor define (except for comment continuation lines)
+		if (!doesLineStartComment)
+		charNum = 0;
+ * Append a character to the current formatted line.
+ * The formattedLine split points are updated.
+ * @param ch               the character to append.
+ * @param canBreakLine     if true, a registered line-break
+void ASFormatter::appendChar(char ch, bool canBreakLine)
+	if (canBreakLine && isInLineBreak)
+		breakLine();
+	formattedLine.append(1, ch);
+	if (maxCodeLength != string::npos)
+		// These compares reduce the frequency of function calls.
+		if (isOkToSplitFormattedLine())
+			updateFormattedLineSplitPoints(ch);
+		if (formattedLine.length() > maxCodeLength)
+ * Append a string sequence to the current formatted line.
+ * The formattedLine split points are NOT updated.
+ * But the formattedLine is checked for time to split.
+ * @param sequence         the sequence to append.
+void ASFormatter::appendSequence(const string& sequence, bool canBreakLine)
+		breakLine();
+	formattedLine.append(sequence);
+ * Append an operator sequence to the current formatted line.
+void ASFormatter::appendOperator(const string& sequence, bool canBreakLine)
+		breakLine();
+			updateFormattedLineSplitPointsOperator(sequence);
+ * append a space to the current formattedline, UNLESS the
+ * last character is already a white-space character.
+void ASFormatter::appendSpacePad()
+	int len = formattedLine.length();
+	if (len > 0 && !isWhiteSpace(formattedLine[len - 1]))
+		spacePadNum++;
+				updateFormattedLineSplitPoints(' ');
+ * next character is already a white-space character.
+void ASFormatter::appendSpaceAfter()
+	int len = currentLine.length();
+	if (charNum + 1 < len && !isWhiteSpace(currentLine[charNum + 1]))
+		spacePadNum++;
+ * register a line break for the formatted line.
+void ASFormatter::breakLine(bool isSplitLine /*false*/)
+	spacePadNum = nextLineSpacePadNum;
+	readyFormattedLine = formattedLine;
+	formattedLine.erase();
+	// queue an empty line prepend request if one exists
+	prependEmptyLine = isPrependPostBlockEmptyLineRequested;
+	if (!isSplitLine)
+		formattedLineCommentNum = string::npos;
+		if (isAppendPostBlockEmptyLineRequested)
+		else
+ * check if the currently reached open-brace (i.e. '{')
+ * opens a:
+ * - a definition type block (such as a class or namespace),
+ * - a command block (such as a method block)
+ * - a static array
+ * this method takes for granted that the current character
+ * is an opening brace.
+ * @return    the type of the opened block.
+BraceType ASFormatter::getBraceType()
+	assert(currentChar == '{');
+	BraceType returnVal = NULL_TYPE;
+	if ((previousNonWSChar == '='
+	        || isBraceType(braceTypeStack->back(), ARRAY_TYPE))
+	        && !isNonParenHeader)
+		returnVal = ARRAY_TYPE;
+	else if (foundPreDefinitionHeader && previousCommandChar != ')')
+		returnVal = DEFINITION_TYPE;
+		if (foundNamespaceHeader)
+			returnVal = (BraceType)(returnVal | NAMESPACE_TYPE);
+		else if (foundClassHeader)
+			returnVal = (BraceType)(returnVal | CLASS_TYPE);
+		else if (foundStructHeader)
+			returnVal = (BraceType)(returnVal | STRUCT_TYPE);
+		else if (foundInterfaceHeader)
+			returnVal = (BraceType)(returnVal | INTERFACE_TYPE);
+	else if (isInEnum)
+		returnVal = (BraceType)(ARRAY_TYPE | ENUM_TYPE);
+	else
+		bool isCommandType = (foundPreCommandHeader
+		                      || foundPreCommandMacro
+		                      || (currentHeader != nullptr && isNonParenHeader)
+		                      || (previousCommandChar == ')')
+		                      || (previousCommandChar == ':' && !foundQuestionMark)
+		                      || (previousCommandChar == ';')
+		                      || ((previousCommandChar == '{' || previousCommandChar == '}')
+		                          && isPreviousBraceBlockRelated)
+		                      || (isInClassInitializer
+		                          && ((!isLegalNameChar(previousNonWSChar) && previousNonWSChar != '(')
+		                              || foundPreCommandHeader))
+		                      || foundTrailingReturnType
+		                      || isInObjCMethodDefinition
+		                      || isInObjCInterface
+		                      || isJavaStaticConstructor
+		                      || isSharpDelegate);
+		// C# methods containing 'get', 'set', 'add', and 'remove' do NOT end with parens
+		if (!isCommandType && isSharpStyle() && isNextWordSharpNonParenHeader(charNum + 1))
+			isCommandType = true;
+			isSharpAccessor = true;
+		if (isInExternC)
+			returnVal = (isCommandType ? COMMAND_TYPE : EXTERN_TYPE);
+		else
+			returnVal = (isCommandType ? COMMAND_TYPE : ARRAY_TYPE);
+	int foundOneLineBlock = isOneLineBlockReached(currentLine, charNum);
+	if (foundOneLineBlock == 2 && returnVal == COMMAND_TYPE)
+	if (foundOneLineBlock > 0)
+		returnVal = (BraceType) (returnVal | SINGLE_LINE_TYPE);
+		if (breakCurrentOneLineBlock)
+			returnVal = (BraceType) (returnVal | BREAK_BLOCK_TYPE);
+		if (foundOneLineBlock == 3)
+			returnVal = (BraceType)(returnVal | EMPTY_BLOCK_TYPE);
+	if (isBraceType(returnVal, ARRAY_TYPE))
+		if (isNonInStatementArrayBrace())
+			returnVal = (BraceType)(returnVal | ARRAY_NIS_TYPE);
+			isNonInStatementArray = true;
+			isImmediatelyPostNonInStmt = false;		// in case of "},{"
+			nonInStatementBrace = formattedLine.length() - 1;
+		if (isUniformInitializerBrace())
+			returnVal = (BraceType)(returnVal | INIT_TYPE);
+	return returnVal;
+bool ASFormatter::isNumericVariable(string word) const
+	if (word == "bool"
+	        || word == "int"
+	        || word == "void"
+	        || word == "char"
+	        || word == "long"
+	        || word == "short"
+	        || word == "double"
+	        || word == "float"
+	        || (word.length() >= 4     // check end of word for _t
+	            && word.compare(word.length() - 2, 2, "_t") == 0)
+// removed release 3.1
+//	        || word == "Int32"
+//	        || word == "UInt32"
+//	        || word == "Int64"
+//	        || word == "UInt64"
+	        || word == "BOOL"
+	        || word == "DWORD"
+	        || word == "HWND"
+	        || word == "INT"
+	        || word == "LPSTR"
+	        || word == "VOID"
+	        || word == "LPVOID"
+	        || word == "wxFontEncoding"
+		return true;
+	return false;
+* check if a colon is a class initializer separator
+* @return        whether it is a class initializer separator
+bool ASFormatter::isClassInitializer() const
+	assert(currentChar == ':');
+	assert(previousChar != ':' && peekNextChar() != ':');	// not part of '::'
+	// this should be similar to ASBeautifier::parseCurrentLine()
+	bool foundClassInitializer = false;
+	if (foundQuestionMark)
+		// do nothing special
+	else if (parenStack->back() > 0)
+		// found a 'for' loop or an objective-C statement
+		// so do nothing special
+		// found an enum with a base-type
+	         && !isInCase
+	         && (previousCommandChar == ')' || foundPreCommandHeader))
+		// found a 'class' c'tor initializer
+		foundClassInitializer = true;
+	return foundClassInitializer;
+ * check if a line is empty
+ * @return        whether line is empty
+bool ASFormatter::isEmptyLine(const string& line) const
+	return line.find_first_not_of(" \t") == string::npos;
+ * Check if the following text is "C" as in extern "C".
+ * @return        whether the statement is extern "C"
+bool ASFormatter::isExternC() const
+	// charNum should be at 'extern'
+	assert(!isWhiteSpace(currentLine[charNum]));
+	size_t startQuote = currentLine.find_first_of(" \t\"", charNum);
+	if (startQuote == string::npos)
+		return false;
+	startQuote = currentLine.find_first_not_of(" \t", startQuote);
+		return false;
+	if (currentLine.compare(startQuote, 3, "\"C\"") != 0)
+		return false;
+	return true;
+ * Check if the currently reached '*', '&' or '^' character is
+ * a pointer-or-reference symbol, or another operator.
+ * A pointer dereference (*) or an "address of" character (&)
+ * counts as a pointer or reference because it is not an
+ * arithmetic operator.
+ * @return        whether current character is a reference-or-pointer
+bool ASFormatter::isPointerOrReference() const
+	assert(currentChar == '*' || currentChar == '&' || currentChar == '^');
+	if (isJavaStyle())
+		return false;
+	if (isCharImmediatelyPostOperator)
+		return false;
+	// get the last legal word (may be a number)
+	string lastWord = getPreviousWord(currentLine, charNum);
+	if (lastWord.empty())
+		lastWord = " ";
+	// check for preceding or following numeric values
+	string nextText = peekNextText(currentLine.substr(charNum + 1));
+	if (nextText.length() == 0)
+		nextText = " ";
+	if (isDigit(lastWord[0])
+	        || isDigit(nextText[0])
+	        || nextText[0] == '!'
+	        || nextText[0] == '~')
+		return false;
+	// check for multiply then a dereference (a * *b)
+	char nextChar = peekNextChar();
+	if (currentChar == '*'
+	        && nextChar == '*'
+	        && !isPointerToPointer(currentLine, charNum))
+		return false;
+	if ((foundCastOperator && nextChar == '>')
+	        || isPointerOrReferenceVariable(lastWord))
+		return true;
+	if (isInClassInitializer
+	        && previousNonWSChar != '('
+	        && previousNonWSChar != '{'
+	        && previousCommandChar != ','
+	        && nextChar != '}')
+		return false;
+	//check for rvalue reference
+	if (currentChar == '&' && nextChar == '&')
+		if (lastWord == AS_AUTO)
+			return true;
+		if (previousNonWSChar == '>')
+			return true;
+		string followingText;
+		if ((int) currentLine.length() > charNum + 2)
+			followingText = peekNextText(currentLine.substr(charNum + 2));
+		if (followingText.length() > 0 && followingText[0] == ')')
+			return true;
+		if (currentHeader != nullptr || isInPotentialCalculation)
+			return false;
+		if (parenStack->back() > 0 && isBraceType(braceTypeStack->back(), COMMAND_TYPE))
+			return false;
+		return true;
+	if (nextChar == '*'
+	        || previousNonWSChar == '='
+	        || previousNonWSChar == '('
+	        || previousNonWSChar == '['
+	        || isCharImmediatelyPostReturn
+	        || isInTemplate
+	        || isCharImmediatelyPostTemplate
+	        || currentHeader == &AS_CATCH
+	        || currentHeader == &AS_FOREACH
+	        || currentHeader == &AS_QFOREACH)
+		return true;
+	if (isBraceType(braceTypeStack->back(), ARRAY_TYPE)
+	        && isLegalNameChar(lastWord[0])
+	        && isLegalNameChar(nextChar)
+	        && previousNonWSChar != ')')
+		if (isArrayOperator())
+			return false;
+	// checks on operators in parens
+	        && isLegalNameChar(nextChar))
+		// if followed by an assignment it is a pointer or reference
+		// if followed by semicolon it is a pointer or reference in range-based for
+		const string* followingOperator = getFollowingOperator();
+		if (followingOperator != nullptr
+		        && followingOperator != &AS_MULT
+		        && followingOperator != &AS_BIT_AND)
+			if (followingOperator == &AS_ASSIGN || followingOperator == &AS_COLON)
+				return true;
+			return false;
+		if (isBraceType(braceTypeStack->back(), COMMAND_TYPE)
+		        || squareBracketCount > 0)
+			return false;
+		return true;
+	// checks on operators in parens with following '('
+	        && nextChar == '('
+	        && previousNonWSChar != ','
+	        && previousNonWSChar != '!'
+	        && previousNonWSChar != '&'
+	        && previousNonWSChar != '*'
+	        && previousNonWSChar != '|')
+		return false;
+	if (nextChar == '-'
+	        || nextChar == '+')
+		size_t nextNum = currentLine.find_first_not_of(" \t", charNum + 1);
+		if (nextNum != string::npos)
+			if (currentLine.compare(nextNum, 2, "++") != 0
+			        && currentLine.compare(nextNum, 2, "--") != 0)
+				return false;
+	bool isPR = (!isInPotentialCalculation
+	             || (!isLegalNameChar(previousNonWSChar)
+	                 && !(previousNonWSChar == ')' && nextChar == '(')
+	                 && !(previousNonWSChar == ')' && currentChar == '*' && !isImmediatelyPostCast())
+	                 && previousNonWSChar != ']')
+	             || (!isWhiteSpace(nextChar)
+	                 && nextChar != '-'
+	                 && nextChar != '('
+	                 && nextChar != '['
+	                 && !isLegalNameChar(nextChar))
+	return isPR;
+ * Check if the currently reached  '*' or '&' character is
+ * a dereferenced pointer or "address of" symbol.
+ * NOTE: this MUST be a pointer or reference as determined by
+ * the function isPointerOrReference().
+ * @return        whether current character is a dereference or address of
+bool ASFormatter::isDereferenceOrAddressOf() const
+	if (isCharImmediatelyPostTemplate)
+		return false;
+	if (previousNonWSChar == '='
+	        || previousNonWSChar == ','
+	        || previousNonWSChar == '.'
+	        || previousNonWSChar == '{'
+	        || previousNonWSChar == '>'
+	        || previousNonWSChar == '<'
+	        || previousNonWSChar == '?'
+	        || isCharImmediatelyPostLineComment
+	        || isCharImmediatelyPostComment
+	        || isCharImmediatelyPostReturn)
+		return true;
+	if (currentChar == '*' && nextChar == '*')
+		if (previousNonWSChar == '(')
+			return true;
+		if ((int) currentLine.length() < charNum + 2)
+			return true;
+		return false;
+		if (previousNonWSChar == '(' || isInTemplate)
+			return true;
+			return true;
+		return false;
+	// check first char on the line
+	if (charNum == (int) currentLine.find_first_not_of(" \t")
+	        && (isBraceType(braceTypeStack->back(), COMMAND_TYPE)
+	            || parenStack->back() != 0))
+		return true;
+	if (nextText.length() > 0)
+		if (nextText[0] == ')' || nextText[0] == '>'
+		        || nextText[0] == ',' || nextText[0] == '=')
+			return false;
+		if (nextText[0] == ';')
+			return true;
+	// check for reference to a pointer *&
+	if ((currentChar == '*' && nextChar == '&')
+	        || (previousNonWSChar == '*' && currentChar == '&'))
+		return false;
+		return false;
+	if (lastWord == "else" || lastWord == "delete")
+		return true;
+	if (isPointerOrReferenceVariable(lastWord))
+		return false;
+	bool isDA = (!(isLegalNameChar(previousNonWSChar) || previousNonWSChar == '>')
+	             || (nextText.length() > 0 && !isLegalNameChar(nextText[0]) && nextText[0] != '/')
+	             || (ispunct((unsigned char)previousNonWSChar) && previousNonWSChar != '.')
+	             || isCharImmediatelyPostReturn);
+	return isDA;
+ * centered with one space on each side.
+ * Only spaces are checked, not tabs.
+ * If true then a space will be deleted on the output.
+ * @return        whether current character is centered.
+bool ASFormatter::isPointerOrReferenceCentered() const
+	int prNum = charNum;
+	int lineLength = (int) currentLine.length();
+	// check for end of line
+	if (peekNextChar() == ' ')
+		return false;
+	// check space before
+	if (prNum < 1
+	        || currentLine[prNum - 1] != ' ')
+		return false;
+	// check no space before that
+	if (prNum < 2
+	        || currentLine[prNum - 2] == ' ')
+		return false;
+	// check for ** or &&
+	if (prNum + 1 < lineLength
+	        && (currentLine[prNum + 1] == '*' || currentLine[prNum + 1] == '&'))
+		prNum++;
+	// check space after
+	if (prNum + 1 <= lineLength
+	        && currentLine[prNum + 1] != ' ')
+		return false;
+	// check no space after that
+	if (prNum + 2 < lineLength
+	        && currentLine[prNum + 2] == ' ')
+		return false;
+	return true;
+ * Check if a word is a pointer or reference variable type.
+ * @return        whether word is a pointer or reference variable.
+bool ASFormatter::isPointerOrReferenceVariable(const string& word) const
+	return (word == "char"
+	        || word == "int"
+	        || word == "void"
+	        || (word.length() >= 6     // check end of word for _t
+	        || word == "INT"
+	        || word == "VOID");
+ * Check if * * is a pointer to a pointer or a multiply then a dereference.
+ * @return        true if a pointer *.
+bool ASFormatter::isPointerToPointer(const string& line, int currPos) const
+	assert(line[currPos] == '*' && peekNextChar() == '*');
+	if ((int) line.length() > currPos + 1 && line[currPos + 1] == '*')
+		return true;
+	size_t nextText = line.find_first_not_of(" \t", currPos + 1);
+	if (nextText == string::npos || line[nextText] != '*')
+		return false;
+	size_t nextText2 = line.find_first_not_of(" \t", nextText + 1);
+	if (nextText == string::npos)
+		return false;
+	if (line[nextText2] == ')' || line[nextText2] == '*')
+		return true;
+	return false;
+ * check if the currently reached '+' or '-' character is a unary operator
+ * is a '+' or '-'.
+ * @return        whether the current '+' or '-' is a unary operator.
+bool ASFormatter::isUnaryOperator() const
+	assert(currentChar == '+' || currentChar == '-');
+	// does a digit follow a c-style cast
+	if (previousCommandChar == ')')
+		if (!isdigit(peekNextChar()))
+			return false;
+		size_t end = currentLine.rfind(')', charNum);
+		if (end == string::npos)
+			return false;
+		size_t lastChar = currentLine.find_last_not_of(" \t", end - 1);
+		if (lastChar == string::npos)
+			return false;
+		if (currentLine[lastChar] == '*')
+			end = lastChar;
+		string prevWord = getPreviousWord(currentLine, end);
+		if (prevWord.empty())
+			return false;
+		if (!isNumericVariable(prevWord))
+			return false;
+		return true;
+	return ((isCharImmediatelyPostReturn || !isLegalNameChar(previousCommandChar))
+	        && previousCommandChar != '.'
+	        && previousCommandChar != '\"'
+	        && previousCommandChar != '\''
+	        && previousCommandChar != ']');
+ * check if the currently reached comment is in a 'switch' statement
+ * @return        whether the current '+' or '-' is in an exponent.
+bool ASFormatter::isInSwitchStatement() const
+	assert(isInLineComment || isInComment);
+		for (size_t i = 1; i < preBraceHeaderStack->size(); i++)
+			if (preBraceHeaderStack->at(i) == &AS_SWITCH)
+				return true;
+	return false;
+ * part of an exponent, i.e. 0.2E-5.
+bool ASFormatter::isInExponent() const
+	if (charNum >= 2)
+		char prevPrevFormattedChar = currentLine[charNum - 2];
+		char prevFormattedChar = currentLine[charNum - 1];
+		return ((prevFormattedChar == 'e' || prevFormattedChar == 'E')
+		        && (prevPrevFormattedChar == '.' || isDigit(prevPrevFormattedChar)));
+	return false;
+ * check if an array brace should NOT have an in-statement indent
+ * @return        the array is non in-statement
+bool ASFormatter::isNonInStatementArrayBrace() const
+	bool returnVal = false;
+	// if this opening brace begins the line there will be no inStatement indent
+	if (currentLineBeginsWithBrace
+	        && (size_t) charNum == currentLineFirstBraceNum
+		returnVal = true;
+	// if an opening brace ends the line there will be no inStatement indent
+	if (isWhiteSpace(nextChar)
+	        || isBeforeAnyLineEndComment(charNum)
+	        || nextChar == '{')
+		returnVal = true;
+	// Java "new Type [] {...}" IS an inStatement indent
+	if (isJavaStyle() && previousNonWSChar == ']')
+		returnVal = false;
+	return returnVal;
+ * check if a one-line block has been reached,
+ * i.e. if the currently reached '{' character is closed
+ * with a complimentary '}' elsewhere on the current line,
+ * @return     0 = one-line block has not been reached.
+ *             1 = one-line block has been reached.
+ *             2 = one-line block has been reached and is followed by a comma.
+ *             3 = one-line block has been reached and is an empty block.
+int ASFormatter::isOneLineBlockReached(const string& line, int startChar) const
+	assert(line[startChar] == '{');
+	bool isInComment_ = false;
+	bool isInQuote_ = false;
+	bool hasText = false;
+	int braceCount = 0;
+	int lineLength = line.length();
+	char quoteChar_ = ' ';
+	char ch = ' ';
+	char prevCh = ' ';
+	for (int i = startChar; i < lineLength; ++i)
+		ch = line[i];
+		if (isInComment_)
+			if (line.compare(i, 2, "*/") == 0)
+				isInComment_ = false;
+				++i;
+			continue;
+		if (isInQuote_)
+			if (ch == '\\')
+				++i;
+			else if (ch == quoteChar_)
+				isInQuote_ = false;
+			continue;
+		if (ch == '"'
+		        || (ch == '\'' && !isDigitSeparator(line, i)))
+			isInQuote_ = true;
+			quoteChar_ = ch;
+			continue;
+		if (line.compare(i, 2, "//") == 0)
+			break;
+		if (line.compare(i, 2, "/*") == 0)
+			isInComment_ = true;
+			++i;
+			continue;
+		if (ch == '{')
+			++braceCount;
+			continue;
+		if (ch == '}')
+			--braceCount;
+			if (braceCount == 0)
+				// is this an array?
+				if (parenStack->back() == 0 && prevCh != '}')
+					size_t peekNum = line.find_first_not_of(" \t", i + 1);
+					if (peekNum != string::npos && line[peekNum] == ',')
+						return 2;
+				if (!hasText)
+					return 3;	// is an empty block
+				return 1;
+		if (ch == ';')
+			continue;
+		if (!isWhiteSpace(ch))
+			hasText = true;
+			prevCh = ch;
+	return 0;
+ * peek at the next word to determine if it is a C# non-paren header.
+ * will look ahead in the input file if necessary.
+ * @param  startChar      position on currentLine to start the search
+ * @return                true if the next word is get or set.
+bool ASFormatter::isNextWordSharpNonParenHeader(int startChar) const
+	// look ahead to find the next non-comment text
+	string nextText = peekNextText(currentLine.substr(startChar));
+		return false;
+	if (nextText[0] == '[')
+		return true;
+	if (!isCharPotentialHeader(nextText, 0))
+		return false;
+	if (findKeyword(nextText, 0, AS_GET) || findKeyword(nextText, 0, AS_SET)
+	        || findKeyword(nextText, 0, AS_ADD) || findKeyword(nextText, 0, AS_REMOVE))
+		return true;
+	return false;
+ * peek at the next char to determine if it is an opening brace.
+ * this determines a java static constructor.
+ * @return              true if the next word is an opening brace.
+bool ASFormatter::isNextCharOpeningBrace(int startChar) const
+	bool retVal = false;
+	        && nextText.compare(0, 1, "{") == 0)
+		retVal = true;
+	return retVal;
+* Check if operator and, pointer, and reference padding is disabled.
+* Disabling is done thru a NOPAD tag in an ending comment.
+* @return              true if the formatting on this line is disabled.
+bool ASFormatter::isOperatorPaddingDisabled() const
+	size_t commentStart = currentLine.find("//", charNum);
+	if (commentStart == string::npos)
+		commentStart = currentLine.find("/*", charNum);
+		// comment must end on this line
+		if (commentStart != string::npos)
+			size_t commentEnd = currentLine.find("*/", commentStart + 2);
+			if (commentEnd == string::npos)
+				commentStart = string::npos;
+		return false;
+	size_t noPadStart = currentLine.find("*NOPAD*", commentStart);
+	if (noPadStart == string::npos)
+		return false;
+	return true;
+* Determine if an opening array-type brace should have a leading space pad.
+* This is to identify C++11 uniform initializers.
+bool ASFormatter::isUniformInitializerBrace() const
+	if (isCStyle() && !isInEnum && !isImmediatelyPostPreprocessor)
+		        || isLegalNameChar(previousNonWSChar)
+		        || previousNonWSChar == '(')
+			return true;
+	return false;
+* Determine if there is a following statement on the current line.
+bool ASFormatter::isMultiStatementLine() const
+	assert((isImmediatelyPostHeader || foundClosingHeader));
+	int  semiCount_ = 0;
+	int  parenCount_ = 0;
+	int  braceCount_ = 0;
+	for (size_t i = 0; i < currentLine.length(); i++)
+		if (isInComment_)
+			if (currentLine.compare(i, 2, "*/") == 0)
+				continue;
+		if (currentLine.compare(i, 2, "/*") == 0)
+			continue;
+		if (currentLine.compare(i, 2, "//") == 0)
+			return false;
+		if (isInQuote_)
+			if (currentLine[i] == '"' || currentLine[i] == '\'')
+			continue;
+			continue;
+		if (currentLine[i] == '(')
+			++parenCount_;
+			continue;
+		if (currentLine[i] == ')')
+			--parenCount_;
+			continue;
+		if (parenCount_ > 0)
+			continue;
+		if (currentLine[i] == '{')
+			++braceCount_;
+		if (currentLine[i] == '}')
+			--braceCount_;
+		if (braceCount_ > 0)
+			continue;
+		if (currentLine[i] == ';')
+			++semiCount_;
+			if (semiCount_ > 1)
+				return true;
+			continue;
+	return false;
+ * get the next non-whitespace substring on following lines, bypassing all comments.
+ * @param   firstLine   the first line to check
+ * @return  the next non-whitespace substring.
+string ASFormatter::peekNextText(const string& firstLine,
+                                 bool endOnEmptyLine /*false*/,
+                                 shared_ptr<ASPeekStream> streamArg /*nullptr*/) const
+	assert(sourceIterator->getPeekStart() == 0 || streamArg != nullptr);	// Borland may need != 0
+	bool isFirstLine = true;
+	string nextLine_ = firstLine;
+	size_t firstChar = string::npos;
+	shared_ptr<ASPeekStream> stream = streamArg;
+	if (stream == nullptr)					// Borland may need == 0
+		stream = make_shared<ASPeekStream>(sourceIterator);
+	// find the first non-blank text, bypassing all comments.
+	while (stream->hasMoreLines() || isFirstLine)
+		if (isFirstLine)
+			isFirstLine = false;
+		else
+			nextLine_ = stream->peekNextLine();
+		firstChar = nextLine_.find_first_not_of(" \t");
+		if (firstChar == string::npos)
+			if (endOnEmptyLine && !isInComment_)
+				break;
+			continue;
+		if (nextLine_.compare(firstChar, 2, "/*") == 0)
+			firstChar += 2;
+		if (isInComment_)
+			firstChar = nextLine_.find("*/", firstChar);
+				continue;
+			firstChar += 2;
+			firstChar = nextLine_.find_first_not_of(" \t", firstChar);
+				continue;
+		if (nextLine_.compare(firstChar, 2, "//") == 0)
+			continue;
+		// found the next text
+		break;
+		nextLine_ = "";
+	else
+		nextLine_ = nextLine_.substr(firstChar);
+	return nextLine_;
+ * adjust comment position because of adding or deleting spaces
+ * the spaces are added or deleted to formattedLine
+ * spacePadNum contains the adjustment
+void ASFormatter::adjustComments()
+	assert(spacePadNum != 0);
+	assert(isSequenceReached("//") || isSequenceReached("/*"));
+	// block comment must be closed on this line with nothing after it
+		size_t endNum = currentLine.find("*/", charNum + 2);
+		if (endNum == string::npos)
+			return;
+		// following line comments may be a tag from AStyleWx //[[)>
+		size_t nextNum = currentLine.find_first_not_of(" \t", endNum + 2);
+		        && currentLine.compare(nextNum, 2, "//") != 0)
+			return;
+	size_t len = formattedLine.length();
+	// don't adjust a tab
+	if (formattedLine[len - 1] == '\t')
+		return;
+	// if spaces were removed, need to add spaces before the comment
+	if (spacePadNum < 0)
+		int adjust = -spacePadNum;          // make the number positive
+		formattedLine.append(adjust, ' ');
+	// if spaces were added, need to delete extra spaces before the comment
+	// if cannot be done put the comment one space after the last text
+	else if (spacePadNum > 0)
+		int adjust = spacePadNum;
+		        && lastText < len - adjust - 1)
+			formattedLine.resize(len - adjust);
+		else if (len > lastText + 2)
+			formattedLine.resize(lastText + 2);
+		else if (len < lastText + 2)
+			formattedLine.append(len - lastText, ' ');
+ * append the current brace inside the end of line comments
+ * currentChar contains the brace, it will be appended to formattedLine
+ * formattedLineCommentNum is the comment location on formattedLine
+void ASFormatter::appendCharInsideComments()
+	if (formattedLineCommentNum == string::npos     // does the comment start on the previous line?
+	        || formattedLineCommentNum == 0)
+		appendCurrentChar();                        // don't attach
+		return;
+	assert(formattedLine.compare(formattedLineCommentNum, 2, "//") == 0
+	       || formattedLine.compare(formattedLineCommentNum, 2, "/*") == 0);
+	// find the previous non space char
+	size_t end = formattedLineCommentNum;
+	size_t beg = formattedLine.find_last_not_of(" \t", end - 1);
+	if (beg == string::npos)
+		return;
+	beg++;
+	// insert the brace
+	if (end - beg < 3)                      // is there room to insert?
+		formattedLine.insert(beg, 3 - end + beg, ' ');
+	if (formattedLine[beg] == '\t')         // don't pad with a tab
+		formattedLine.insert(beg, 1, ' ');
+	formattedLine[beg + 1] = currentChar;
+	testForTimeToSplitFormattedLine();
+	if (isBeforeComment())
+		breakLine();
+	else if (isCharImmediatelyPostLineComment)
+		shouldBreakLineAtNextChar = true;
+ * add or remove space padding to operators
+ * the operators and necessary padding will be appended to formattedLine
+ * the calling function should have a continue statement after calling this method
+ * @param newOperator     the operator to be padded
+void ASFormatter::padOperators(const string* newOperator)
+	assert(shouldPadOperators);
+	assert(newOperator != nullptr);
+	char nextNonWSChar = ASBase::peekNextChar(currentLine, charNum);
+	bool shouldPad = (newOperator != &AS_SCOPE_RESOLUTION
+	                  && newOperator != &AS_PLUS_PLUS
+	                  && newOperator != &AS_MINUS_MINUS
+	                  && newOperator != &AS_NOT
+	                  && newOperator != &AS_BIT_NOT
+	                  && newOperator != &AS_ARROW
+	                  && !(newOperator == &AS_COLON && !foundQuestionMark			// objC methods
+	                       && (isInObjCMethodDefinition || isInObjCInterface
+	                           || isInObjCSelector || squareBracketCount != 0))
+	                  && !(newOperator == &AS_MINUS && isInExponent())
+	                  && !(newOperator == &AS_PLUS && isInExponent())
+	                  && !((newOperator == &AS_PLUS || newOperator == &AS_MINUS)	// check for unary plus or minus
+	                       && (previousNonWSChar == '('
+	                           || previousNonWSChar == ':'
+	                           || previousNonWSChar == '{'))
+//?                   // commented out in release 2.05.1 - doesn't seem to do anything???
+//x                   && !((newOperator == &AS_MULT || newOperator == &AS_BIT_AND || newOperator == &AS_AND)
+//x                        && isPointerOrReference())
+	                  && !(newOperator == &AS_MULT
+	                       && (previousNonWSChar == '.'
+	                           || previousNonWSChar == '>'))    // check for ->
+	                  && !(newOperator == &AS_MULT && peekNextChar() == '>')
+	                  && !((isInTemplate || isImmediatelyPostTemplate)
+	                       && (newOperator == &AS_LS || newOperator == &AS_GR))
+	                  && !(newOperator == &AS_GCC_MIN_ASSIGN
+	                       && ASBase::peekNextChar(currentLine, charNum + 1) == '>')
+	                  && !(newOperator == &AS_GR && previousNonWSChar == '?')
+	                  && !(newOperator == &AS_QUESTION			// check for Java wildcard
+	                       && isJavaStyle()
+	                       && (previousNonWSChar == '<'
+	                           || nextNonWSChar == '>'
+	                           || nextNonWSChar == '.'))
+	                  && !(newOperator == &AS_QUESTION			// check for C# null conditional operator
+	                       && isSharpStyle()
+	                       && (nextNonWSChar == '.'
+	                           || nextNonWSChar == '['))
+	                  && !isInCase
+	                  && !isInAsm
+	                  && !isInAsmBlock
+	// pad before operator
+	if (shouldPad
+	             && (!foundQuestionMark && !isInEnum) && currentHeader != &AS_FOR)
+	        && !(newOperator == &AS_QUESTION && isSharpStyle() // check for C# nullable type (e.g. int?)
+	             && currentLine.find(':', charNum + 1) == string::npos)
+		appendSpacePad();
+	appendOperator(*newOperator);
+	goForward(newOperator->length() - 1);
+	currentChar = (*newOperator)[newOperator->length() - 1];
+	// pad after operator
+	// but do not pad after a '-' that is a unary-minus.
+	if (shouldPad
+	        && !isBeforeAnyComment()
+	        && !(newOperator == &AS_PLUS && isUnaryOperator())
+	        && !(newOperator == &AS_MINUS && isUnaryOperator())
+	        && !(peekNextChar() == ',')
+	             && peekNextChar() == '[')
+ * format pointer or reference
+ * currentChar contains the pointer or reference
+ * the symbol and necessary padding will be appended to formattedLine
+ * NOTE: Do NOT use appendCurrentChar() in this method. The line should not be
+ *       broken once the calculation starts.
+void ASFormatter::formatPointerOrReference()
+	assert(!isJavaStyle());
+	int pa = pointerAlignment;
+	int ra = referenceAlignment;
+	int itemAlignment = (currentChar == '*' || currentChar == '^')
+	                    ? pa : ((ra == REF_SAME_AS_PTR) ? pa : ra);
+	// check for ** and &&
+	int ptrLength = 1;
+	if ((currentChar == '*' && peekedChar == '*')
+	        || (currentChar == '&' && peekedChar == '&'))
+		ptrLength = 2;
+		size_t nextChar = currentLine.find_first_not_of(" \t", charNum + 2);
+			peekedChar = ' ';
+		else
+			peekedChar = currentLine[nextChar];
+	// check for cast
+	if (peekedChar == ')' || peekedChar == '>' || peekedChar == ',')
+		formatPointerOrReferenceCast();
+		return;
+	// check for a padded space and remove it
+	if (charNum > 0
+	        && !isWhiteSpace(currentLine[charNum - 1])
+	        && formattedLine.length() > 0
+	        && isWhiteSpace(formattedLine[formattedLine.length() - 1]))
+		formattedLine.erase(formattedLine.length() - 1);
+		spacePadNum--;
+	if (itemAlignment == PTR_ALIGN_TYPE)
+		formatPointerOrReferenceToType();
+	else if (itemAlignment == PTR_ALIGN_MIDDLE)
+		formatPointerOrReferenceToMiddle();
+	else if (itemAlignment == PTR_ALIGN_NAME)
+		formatPointerOrReferenceToName();
+	else	// pointerAlignment == PTR_ALIGN_NONE
+		formattedLine.append(currentLine.substr(charNum, ptrLength));
+		if (ptrLength > 1)
+			goForward(ptrLength - 1);
+ * format pointer or reference with align to type
+void ASFormatter::formatPointerOrReferenceToType()
+	// do this before bumping charNum
+	bool isOldPRCentered = isPointerOrReferenceCentered();
+	string sequenceToInsert(1, currentChar);
+	// get the sequence
+	if (currentChar == peekNextChar())
+		for (size_t i = charNum + 1; currentLine.length() > i; i++)
+			if (currentLine[i] == sequenceToInsert[0])
+				sequenceToInsert.append(1, currentLine[i]);
+				goForward(1);
+				continue;
+			break;
+	// append the seqence
+	string charSave;
+	size_t prevCh = formattedLine.find_last_not_of(" \t");
+	if (prevCh < formattedLine.length())
+		charSave = formattedLine.substr(prevCh + 1);
+		formattedLine.resize(prevCh + 1);
+	formattedLine.append(sequenceToInsert);
+	if (peekNextChar() != ')')
+		formattedLine.append(charSave);
+	else
+		spacePadNum -= charSave.length();
+	// if no space after then add one
+	if (charNum < (int) currentLine.length() - 1
+	        && currentLine[charNum + 1] != ')')
+		appendSpacePad();
+	// if old pointer or reference is centered, remove a space
+	if (isOldPRCentered
+		formattedLine.erase(formattedLine.length() - 1, 1);
+		spacePadNum--;
+	// update the formattedLine split point
+	if (maxCodeLength != string::npos && formattedLine.length() > 0)
+		size_t index = formattedLine.length() - 1;
+		if (isWhiteSpace(formattedLine[index]))
+			updateFormattedLineSplitPointsPointerOrReference(index);
+ * format pointer or reference with align in the middle
+void ASFormatter::formatPointerOrReferenceToMiddle()
+	// compute current whitespace before
+	size_t wsBefore = currentLine.find_last_not_of(" \t", charNum - 1);
+	if (wsBefore == string::npos)
+		wsBefore = 0;
+	else
+		wsBefore = charNum - wsBefore - 1;
+				goForward(1);
+				continue;
+			break;
+	// if reference to a pointer check for conflicting alignment
+	else if (currentChar == '*' && peekNextChar() == '&'
+	         && (referenceAlignment == REF_ALIGN_TYPE
+	             || referenceAlignment == REF_ALIGN_MIDDLE
+	             || referenceAlignment == REF_SAME_AS_PTR))
+		sequenceToInsert = "*&";
+		goForward(1);
+		for (size_t i = charNum; i < currentLine.length() - 1 && isWhiteSpace(currentLine[i]); i++)
+			goForward(1);
+	// if a comment follows don't align, just space pad
+	if (isBeforeAnyComment())
+		appendSpacePad();
+		return;
+	// do this before goForward()
+	bool isAfterScopeResolution = previousNonWSChar == ':';
+	size_t charNumSave = charNum;
+	// if this is the last thing on the line
+	if (currentLine.find_first_not_of(" \t", charNum + 1) == string::npos)
+		if (wsBefore == 0 && !isAfterScopeResolution)
+			formattedLine.append(1, ' ');
+		return;
+	// goForward() to convert tabs to spaces, if necessary,
+	// and move following characters to preceding characters
+	// this may not work every time with tab characters
+	for (size_t i = charNum + 1; i < currentLine.length() && isWhiteSpace(currentLine[i]); i++)
+		goForward(1);
+		if (formattedLine.length() > 0)
+			formattedLine.append(1, currentLine[i]);
+		else
+			spacePadNum--;
+	// find space padding after
+	size_t wsAfter = currentLine.find_first_not_of(" \t", charNumSave + 1);
+	if (wsAfter == string::npos || isBeforeAnyComment())
+		wsAfter = 0;
+	else
+		wsAfter = wsAfter - charNumSave - 1;
+	// don't pad before scope resolution operator, but pad after
+	if (isAfterScopeResolution)
+		size_t lastText = formattedLine.find_last_not_of(" \t");
+		formattedLine.insert(lastText + 1, sequenceToInsert);
+		appendSpacePad();
+	else if (formattedLine.length() > 0)
+		// whitespace should be at least 2 chars to center
+		if (wsBefore + wsAfter < 2)
+			size_t charsToAppend = (2 - (wsBefore + wsAfter));
+			formattedLine.append(charsToAppend, ' ');
+			spacePadNum += charsToAppend;
+			if (wsBefore == 0)
+				wsBefore++;
+			if (wsAfter == 0)
+				wsAfter++;
+		// insert the pointer or reference char
+		size_t padAfter = (wsBefore + wsAfter) / 2;
+		size_t index = formattedLine.length() - padAfter;
+		if (index < formattedLine.length())
+			formattedLine.insert(index, sequenceToInsert);
+		else
+	else	// formattedLine.length() == 0
+		if (wsAfter == 0)
+			wsAfter++;
+		formattedLine.append(wsAfter, ' ');
+		spacePadNum += wsAfter;
+	// update the formattedLine split point after the pointer
+		size_t index = formattedLine.find_last_not_of(" \t");
+		if (index != string::npos && (index < formattedLine.length() - 1))
+			index++;
+ * format pointer or reference with align to name
+void ASFormatter::formatPointerOrReferenceToName()
+	size_t startNum = formattedLine.find_last_not_of(" \t");
+	if (startNum == string::npos)
+		startNum = 0;
+				goForward(1);
+				continue;
+			break;
+	// if reference to a pointer align both to name
+	else if (currentChar == '*' && peekNextChar() == '&')
+		goForward(1);
+			goForward(1);
+	bool isAfterScopeResolution = previousNonWSChar == ':';		// check for ::
+	// if this is not the last thing on the line
+	if ((isLegalNameChar(peekedChar) || peekedChar == '(' || peekedChar == '[' || peekedChar == '=')
+	        && (int) currentLine.find_first_not_of(" \t", charNum + 1) > charNum)
+			// if a padded paren follows don't move
+			if (shouldPadParensOutside && peekedChar == '(' && !isOldPRCentered)
+				// empty parens don't count
+				size_t start = currentLine.find_first_not_of("( \t", i);
+				if (start != string::npos && currentLine[start] != ')')
+					break;
+			goForward(1);
+				formattedLine.append(1, currentLine[charNum]);
+			else
+				spacePadNum--;
+		if (lastText != string::npos && lastText + 1 < formattedLine.length())
+			formattedLine.erase(lastText + 1);
+	// if no space before * then add one
+	         && (formattedLine.length() <= startNum + 1
+	             || !isWhiteSpace(formattedLine[startNum + 1])))
+		formattedLine.insert(startNum + 1, 1, ' ');
+		spacePadNum++;
+	appendSequence(sequenceToInsert, false);
+	        && formattedLine.length() > startNum + 1
+	        && isWhiteSpace(formattedLine[startNum + 1])
+	        && peekedChar != '*'		// check for '* *'
+	        && !isBeforeAnyComment())
+		formattedLine.erase(startNum + 1, 1);
+		spacePadNum--;
+	// don't convert to *= or &=
+	if (peekedChar == '=')
+		// if more than one space before, delete one
+		if (formattedLine.length() > startNum
+		        && isWhiteSpace(formattedLine[startNum + 2]))
+			spacePadNum--;
+		size_t index = formattedLine.find_last_of(" \t");
+		        && index < formattedLine.length() - 1
+		        && (formattedLine[index + 1] == '*'
+		            || formattedLine[index + 1] == '&'
+		            || formattedLine[index + 1] == '^'))
+ * format pointer or reference cast
+ * NOTE: the pointers and references in function definitions
+ *       are processed as a cast (e.g. void foo(void*, void*))
+ *       is processed here.
+void ASFormatter::formatPointerOrReferenceCast()
+	if (isSequenceReached("**") || isSequenceReached("&&"))
+		goForward(1);
+		sequenceToInsert.append(1, currentLine[charNum]);
+	if (itemAlignment == PTR_ALIGN_NONE)
+		return;
+	// remove preceding whitespace
+	size_t prevNum = formattedLine.find_last_not_of(" \t");
+	if (prevNum != string::npos)
+		prevCh = formattedLine[prevNum];
+		if (itemAlignment == PTR_ALIGN_TYPE && currentChar == '*' && prevCh == '*')
+			// '* *' may be a multiply followed by a dereference
+			if (prevNum + 2 < formattedLine.length()
+			        && isWhiteSpace(formattedLine[prevNum + 2]))
+				spacePadNum -= (formattedLine.length() - 2 - prevNum);
+				formattedLine.erase(prevNum + 2);
+		else if (prevNum + 1 < formattedLine.length()
+		         && isWhiteSpace(formattedLine[prevNum + 1])
+		         && prevCh != '(')
+			spacePadNum -= (formattedLine.length() - 1 - prevNum);
+			formattedLine.erase(prevNum + 1);
+	if ((itemAlignment == PTR_ALIGN_MIDDLE || itemAlignment == PTR_ALIGN_NAME)
+	        && !isAfterScopeResolution && prevCh != '(')
+		appendSpacePad();
+		// in this case appendSpacePad may or may not update the split point
+			updateFormattedLineSplitPointsPointerOrReference(formattedLine.length() - 1);
+	else
+ * add or remove space padding to parens
+ * currentChar contains the paren
+ * the parens and necessary padding will be appended to formattedLine
+void ASFormatter::padParens()
+	assert(currentChar == '(' || currentChar == ')');
+	assert(shouldPadParensOutside || shouldPadParensInside || shouldUnPadParens || shouldPadFirstParen);
+	int spacesOutsideToDelete = 0;
+	int spacesInsideToDelete = 0;
+		spacesOutsideToDelete = formattedLine.length() - 1;
+		spacesInsideToDelete = 0;
+		// compute spaces outside the opening paren to delete
+		if (shouldUnPadParens)
+			char lastChar = ' ';
+			bool prevIsParenHeader = false;
+			size_t i = formattedLine.find_last_not_of(" \t");
+			if (i != string::npos)
+				// if last char is a brace the previous whitespace is an indent
+				if (formattedLine[i] == '{')
+					spacesOutsideToDelete = 0;
+				else if (isCharImmediatelyPostPointerOrReference)
+				else
+					spacesOutsideToDelete -= i;
+					lastChar = formattedLine[i];
+					// if previous word is a header, it will be a paren header
+					string prevWord = getPreviousWord(formattedLine, formattedLine.length());
+					const string* prevWordH = nullptr;
+					if (shouldPadHeader
+					        && prevWord.length() > 0
+					        && isCharPotentialHeader(prevWord, 0))
+						prevWordH = ASBase::findHeader(prevWord, 0, headers);
+					if (prevWordH != nullptr)
+						prevIsParenHeader = true;    // don't unpad
+					else if (prevWord == AS_RETURN)
+					else if ((prevWord == AS_NEW || prevWord == AS_DELETE)
+					         && shouldPadHeader)
+					else if (isCStyle() && prevWord == AS_THROW && shouldPadHeader)
+					else if (prevWord == "and" || prevWord == "or" || prevWord == "in")
+					// don't unpad variables
+					else if (isNumericVariable(prevWord))
+			// do not unpad operators, but leave them if already padded
+			if (shouldPadParensOutside || prevIsParenHeader)
+				spacesOutsideToDelete--;
+			else if (lastChar == '|'          // check for ||
+			         || lastChar == '&'       // check for &&
+			         || lastChar == ','
+			         || (lastChar == '(' && shouldPadParensInside)
+			         || (lastChar == '>' && !foundCastOperator)
+			         || lastChar == '<'
+			         || lastChar == '?'
+			         || lastChar == ':'
+			         || lastChar == ';'
+			         || lastChar == '='
+			         || lastChar == '+'
+			         || lastChar == '-'
+			         || lastChar == '*'
+			         || lastChar == '/'
+			         || lastChar == '%'
+			         || lastChar == '^'
+			if (spacesOutsideToDelete > 0)
+				formattedLine.erase(i + 1, spacesOutsideToDelete);
+				spacePadNum -= spacesOutsideToDelete;
+		// pad open paren outside
+		char peekedCharOutside = peekNextChar();
+		if (shouldPadFirstParen && previousChar != '(' && peekedCharOutside != ')')
+			appendSpacePad();
+		else if (shouldPadParensOutside)
+			if (!(currentChar == '(' && peekedCharOutside == ')'))
+				appendSpacePad();
+		// unpad open paren inside
+			size_t j = currentLine.find_first_not_of(" \t", charNum + 1);
+			if (j != string::npos)
+				spacesInsideToDelete = j - charNum - 1;
+			if (shouldPadParensInside)
+				spacesInsideToDelete--;
+			if (spacesInsideToDelete > 0)
+				currentLine.erase(charNum + 1, spacesInsideToDelete);
+				spacePadNum -= spacesInsideToDelete;
+			// convert tab to space if requested
+			if (shouldConvertTabs
+			        && (int) currentLine.length() > charNum + 1
+			        && currentLine[charNum + 1] == '\t')
+				currentLine[charNum + 1] = ' ';
+		// pad open paren inside
+		char peekedCharInside = peekNextChar();
+			if (!(currentChar == '(' && peekedCharInside == ')'))
+				appendSpaceAfter();
+	else if (currentChar == ')')
+		// unpad close paren inside
+			spacesInsideToDelete = formattedLine.length();
+				spacesInsideToDelete = formattedLine.length() - 1 - i;
+				formattedLine.erase(i + 1, spacesInsideToDelete);
+		// pad close paren inside
+			if (!(previousChar == '(' && currentChar == ')'))
+				appendSpacePad();
+		// unpad close paren outside
+		// close parens outside are left unchanged
+			//spacesOutsideToDelete = 0;
+			//size_t j = currentLine.find_first_not_of(" \t", charNum + 1);
+			//if (j != string::npos)
+			//	spacesOutsideToDelete = j - charNum - 1;
+			//if (shouldPadParensOutside)
+			//	spacesOutsideToDelete--;
+			//if (spacesOutsideToDelete > 0)
+			//	currentLine.erase(charNum + 1, spacesOutsideToDelete);
+			//	spacePadNum -= spacesOutsideToDelete;
+		// pad close paren outside
+		if (shouldPadParensOutside)
+			if (peekedCharOutside != ';'
+			        && peekedCharOutside != ','
+			        && peekedCharOutside != '.'
+			        && peekedCharOutside != '+'    // check for ++
+			        && peekedCharOutside != '-'    // check for --
+			        && peekedCharOutside != ']')
+* add or remove space padding to objective-c method prefix (- or +)
+* if this is a '(' it begins a return type
+* these options have precedence over the padParens methods
+* the padParens method has already been called, this method adjusts
+void ASFormatter::padObjCMethodPrefix()
+	assert(isInObjCMethodDefinition && isImmediatelyPostObjCMethodPrefix);
+	assert(shouldPadMethodPrefix || shouldUnPadMethodPrefix);
+	size_t prefix = formattedLine.find_first_of("+-");
+	if (prefix == string::npos)
+		return;
+	size_t firstChar = formattedLine.find_first_not_of(" \t", prefix + 1);
+		firstChar = formattedLine.length();
+	int spaces = firstChar - prefix - 1;
+	if (shouldPadMethodPrefix)
+		if (spaces == 0)
+			formattedLine.insert(prefix + 1, 1, ' ');
+			spacePadNum += 1;
+		else if (spaces > 1)
+			formattedLine.erase(prefix + 1, spaces - 1);
+			formattedLine[prefix + 1] = ' ';  // convert any tab to space
+			spacePadNum -= spaces - 1;
+	// this option will be ignored if used with pad-method-prefix
+	else if (shouldUnPadMethodPrefix)
+		if (spaces > 0)
+			formattedLine.erase(prefix + 1, spaces);
+			spacePadNum -= spaces;
+* add or remove space padding to objective-c parens
+void ASFormatter::padObjCReturnType()
+	assert(currentChar == ')' && isInObjCReturnType);
+	assert(shouldPadReturnType || shouldUnPadReturnType);
+	size_t nextText = currentLine.find_first_not_of(" \t", charNum + 1);
+		return;
+	int spaces = nextText - charNum - 1;
+	if (shouldPadReturnType)
+		if (spaces == 0)
+			// this will already be padded if pad-paren is used
+			if (formattedLine[formattedLine.length() - 1] != ' ')
+				formattedLine.append(" ");
+				spacePadNum += 1;
+			// do not use goForward here
+			currentLine.erase(charNum + 1, spaces - 1);
+			currentLine[charNum + 1] = ' ';  // convert any tab to space
+	// this option will be ignored if used with pad-return-type
+	else if (shouldUnPadReturnType)
+		if (formattedLine[formattedLine.length() - 1] == ' ')
+			int lastText = formattedLine.find_last_not_of(" \t");
+			spacePadNum -= formattedLine.length() - lastText - 1;
+			formattedLine.resize(lastText + 1);
+		currentLine.erase(charNum + 1, spaces);
+void ASFormatter::padObjCParamType()
+	assert((currentChar == '(' || currentChar == ')') && isInObjCMethodDefinition);
+	assert(!isImmediatelyPostObjCMethodPrefix && !isInObjCReturnType);
+	assert(shouldPadParamType || shouldUnPadParamType);
+	if (currentChar == '(')
+		// open paren has already been attached to formattedLine by padParen
+		size_t paramOpen = formattedLine.rfind('(');
+		assert(paramOpen != string::npos);
+		size_t prevText = formattedLine.find_last_not_of(" \t", paramOpen - 1);
+		if (prevText == string::npos)
+			return;
+		int spaces = paramOpen - prevText - 1;
+		if (shouldPadParamType
+		        || objCColonPadMode == COLON_PAD_ALL
+		        || objCColonPadMode == COLON_PAD_AFTER)
+			if (spaces == 0)
+				formattedLine.insert(paramOpen, 1, ' ');
+				spacePadNum += 1;
+			if (spaces > 1)
+				formattedLine.erase(prevText + 1, spaces - 1);
+				formattedLine[prevText + 1] = ' ';  // convert any tab to space
+		// this option will be ignored if used with pad-param-type
+		else if (shouldUnPadParamType
+		         || objCColonPadMode == COLON_PAD_NONE
+		         || objCColonPadMode == COLON_PAD_BEFORE)
+			if (spaces > 0)
+				formattedLine.erase(prevText + 1, spaces);
+			return;
+		if (shouldPadParamType)
+			if (spaces == 0)
+					spacePadNum += 1;
+		else if (shouldUnPadParamType)
+				spacePadNum -= 1;
+			if (spaces > 0)
+ * format opening brace as attached or broken
+ * the braces will be appended to the current formattedLine or a new formattedLine as necessary
+ * @param braceType    the type of brace to be formatted.
+void ASFormatter::formatOpeningBrace(BraceType braceType)
+	assert(!isBraceType(braceType, ARRAY_TYPE));
+	parenStack->emplace_back(0);
+	bool breakBrace = isCurrentBraceBroken();
+	if (breakBrace)
+		if (isBeforeAnyComment() && isOkToBreakBlock(braceType) && sourceIterator->hasMoreLines())
+			// if comment is at line end leave the comment on this line
+			if (isBeforeAnyLineEndComment(charNum) && !currentLineBeginsWithBrace)
+				currentChar = ' ';              // remove brace from current line
+				if (parenStack->size() > 1)
+					parenStack->pop_back();
+				currentLine[charNum] = currentChar;
+				appendOpeningBrace = true;      // append brace to following line
+			// else put comment after the brace
+			else if (!isBeforeMultipleLineEndComments(charNum))
+				breakLine();
+		else if (!isBraceType(braceType, SINGLE_LINE_TYPE))
+			formattedLine = rtrim(formattedLine);
+			breakLine();
+		else if ((shouldBreakOneLineBlocks || isBraceType(braceType, BREAK_BLOCK_TYPE))
+		         && !isBraceType(braceType, EMPTY_BLOCK_TYPE))
+			breakLine();
+		else if (!isInLineBreak)
+			appendSpacePad();
+		// should a following comment break from the brace?
+		// must break the line AFTER the brace
+		        && formattedLine[0] == '{'
+		        && isOkToBreakBlock(braceType)
+		        && (braceFormatMode == BREAK_MODE
+		            || braceFormatMode == LINUX_MODE))
+	else    // attach brace
+		// are there comments before the brace?
+		if (isCharImmediatelyPostComment || isCharImmediatelyPostLineComment)
+			if (isOkToBreakBlock(braceType)
+			        && !(isCharImmediatelyPostComment && isCharImmediatelyPostLineComment)	// don't attach if two comments on the line
+			        && !isImmediatelyPostPreprocessor
+//			        && peekNextChar() != '}'		// don't attach { }		// removed release 2.03
+			        && previousCommandChar != '{'	// don't attach { {
+			        && previousCommandChar != '}'	// don't attach } {
+			        && previousCommandChar != ';')	// don't attach ; {
+				appendCharInsideComments();
+			else
+		else if (previousCommandChar == '{'
+		         || (previousCommandChar == '}' && !isInClassInitializer)
+		         || previousCommandChar == ';')		// '}' , ';' chars added for proper handling of '{' immediately after a '}' or ';'
+		else
+			// if a blank line precedes this don't attach
+			if (isEmptyLine(formattedLine))
+			else if (isOkToBreakBlock(braceType)
+			         && !(isImmediatelyPostPreprocessor
+			              && currentLineBeginsWithBrace))
+				if (!isBraceType(braceType, EMPTY_BLOCK_TYPE))
+					appendSpacePad();
+					appendCurrentChar(false);				// OK to attach
+					testForTimeToSplitFormattedLine();		// line length will have changed
+					// should a following comment attach with the brace?
+					// insert spaces to reposition the comment
+					        && !isBeforeMultipleLineEndComments(charNum)
+					        && (!isBeforeAnyLineEndComment(charNum)	|| currentLineBeginsWithBrace))
+						currentLine.insert(charNum + 1, charNum + 1, ' ');
+					else if (!isBeforeAnyComment())		// added in release 2.03
+				else
+					if (currentLineBeginsWithBrace && (size_t) charNum == currentLineFirstBraceNum)
+						appendSpacePad();
+						appendCurrentChar(false);		// attach
+					else
+						appendSpacePad();
+			else
+				if (!isInLineBreak)
+					appendSpacePad();
+ * format closing brace
+ * @param braceType    the type of the opening brace for this closing brace.
+void ASFormatter::formatClosingBrace(BraceType braceType)
+	assert(currentChar == '}');
+	// parenStack must contain one entry
+	// mark state of immediately after empty block
+	// this state will be used for locating braces that appear immediately AFTER an empty block (e.g. '{} \n}').
+	if (previousCommandChar == '{')
+		isImmediatelyPostEmptyBlock = true;
+	if (attachClosingBraceMode)
+		// for now, namespaces and classes will be attached. Uncomment the lines below to break.
+		if ((isEmptyLine(formattedLine)			// if a blank line precedes this
+		        || (isImmediatelyPostPreprocessor && (int) currentLine.find_first_not_of(" \t") == charNum)
+//		        || (isBraceType(braceType, CLASS_TYPE) && isOkToBreakBlock(braceType) && previousNonWSChar != '{')
+//		        || (isBraceType(braceType, NAMESPACE_TYPE) && isOkToBreakBlock(braceType) && previousNonWSChar != '{')
+		        && (!isBraceType(braceType, SINGLE_LINE_TYPE) || isOkToBreakBlock(braceType)))
+			breakLine();
+		else
+			if (previousNonWSChar != '{'
+			            || isOkToBreakBlock(braceType)))
+				appendSpacePad();
+	else if (!isBraceType(braceType, EMPTY_BLOCK_TYPE)
+	         && (isBraceType(braceType, BREAK_BLOCK_TYPE)
+		breakLine();
+	else
+	// if a declaration follows a definition, space pad
+	if (isLegalNameChar(peekNextChar()))
+	if (shouldBreakBlocks
+	        && currentHeader != nullptr
+	        && !isHeaderInMultiStatementLine
+	        && parenStack->back() == 0)
+		if (currentHeader == &AS_CASE || currentHeader == &AS_DEFAULT)
+			// do not yet insert a line if "break" statement is outside the braces
+			        && nextText.substr(0, 5) != "break")
+				isAppendPostBlockEmptyLineRequested = true;
+		else
+ * format array braces as attached or broken
+ * determine if the braces can have an inStatement indent
+ * @param braceType            the type of brace to be formatted, must be an ARRAY_TYPE.
+ * @param isOpeningArrayBrace  indicates if this is the opening brace for the array block.
+void ASFormatter::formatArrayBraces(BraceType braceType, bool isOpeningArrayBrace)
+	assert(isBraceType(braceType, ARRAY_TYPE));
+	assert(currentChar == '{' || currentChar == '}');
+	if (currentChar == '{')
+		// is this the first opening brace in the array?
+		if (isOpeningArrayBrace)
+			if (braceFormatMode == ATTACH_MODE
+				// break an enum if mozilla
+				if (isBraceType(braceType, ENUM_TYPE)
+				        && formattingStyle == STYLE_MOZILLA)
+					isInLineBreak = true;
+				// don't attach to a preprocessor directive or '\' line
+				else if ((isImmediatelyPostPreprocessor
+				          || (formattedLine.length() > 0
+				              && formattedLine[formattedLine.length() - 1] == '\\'))
+				else if (isCharImmediatelyPostComment)
+					// TODO: attach brace to line-end comment
+				else if (isCharImmediatelyPostLineComment && !isBraceType(braceType, SINGLE_LINE_TYPE))
+				else
+					else
+						// if brace is broken or not an assignment
+						        && !isBraceType(braceType, SINGLE_LINE_TYPE))
+							appendSpacePad();
+							// TODO: debug the following line
+							        && currentLineFirstBraceNum == (size_t) charNum)
+						else
+							if (previousNonWSChar != '(')
+								// don't space pad C++11 uniform initialization
+								if (!isBraceType(braceType, INIT_TYPE))
+									appendSpacePad();
+			else if (braceFormatMode == BREAK_MODE)
+				if (isWhiteSpace(peekNextChar()) && !isInVirginLine)
+					breakLine();
+				else if (isBeforeAnyComment() && sourceIterator->hasMoreLines())
+					// do not break unless comment is at line end
+				if (!isInLineBreak && previousNonWSChar != '(')
+						appendSpacePad();
+			else if (braceFormatMode == RUN_IN_MODE)
+					breakLine();
+						appendSpacePad();
+			else if (braceFormatMode == NONE_MODE)
+				        && (size_t) charNum == currentLineFirstBraceNum)
+				else
+							appendSpacePad();
+		else	     // not the first opening brace
+			if (braceFormatMode == RUN_IN_MODE)
+				if (previousNonWSChar == '{'
+				        && braceTypeStack->size() > 2
+				        && !isBraceType((*braceTypeStack)[braceTypeStack->size() - 2],
+				                        SINGLE_LINE_TYPE))
+					formatArrayRunIn();
+			         && !isWhiteSpace(peekNextChar())
+			         && previousNonWSChar == '{'
+	else if (currentChar == '}')
+			if (isEmptyLine(formattedLine)			// if a blank line precedes this
+			        || isImmediatelyPostPreprocessor
+			        || isCharImmediatelyPostComment)
+			else
+				appendSpacePad();
+		else
+			// does this close the first opening brace in the array?
+			// must check if the block is still a single line because of anonymous statements
+			            || formattedLine.find('{') == string::npos))
+				breakLine();
+		// if a declaration follows an enum definition, space pad
+		char peekedChar = peekNextChar();
+		if ((isLegalNameChar(peekedChar) && peekedChar != '.')
+		        || peekedChar == '[')
+ * determine if a run-in can be attached.
+ * if it can insert the indents in formattedLine and reset the current line break.
+void ASFormatter::formatRunIn()
+	assert(braceFormatMode == RUN_IN_MODE || braceFormatMode == NONE_MODE);
+	// keep one line blocks returns true without indenting the run-in
+	if (formattingStyle != STYLE_PICO
+	        && !isOkToBreakBlock(braceTypeStack->back()))
+		return; // true;
+	// make sure the line begins with a brace
+	if (lastText == string::npos || formattedLine[lastText] != '{')
+		return; // false;
+	// make sure the brace is broken
+	if (formattedLine.find_first_not_of(" \t{") != string::npos)
+		return; // false;
+	if (isBraceType(braceTypeStack->back(), NAMESPACE_TYPE))
+		return; // false;
+	bool extraIndent = false;
+	bool extraHalfIndent = false;
+	// cannot attach a class modifier without indent-classes
+	if (isCStyle()
+	        && isCharPotentialHeader(currentLine, charNum)
+	        && (isBraceType(braceTypeStack->back(), CLASS_TYPE)
+	            || (isBraceType(braceTypeStack->back(), STRUCT_TYPE)
+	                && isInIndentableStruct)))
+		if (findKeyword(currentLine, charNum, AS_PUBLIC)
+		        || findKeyword(currentLine, charNum, AS_PRIVATE)
+		        || findKeyword(currentLine, charNum, AS_PROTECTED))
+			if (getModifierIndent())
+				extraHalfIndent = true;
+			else if (!getClassIndent())
+				return; // false;
+		else if (getClassIndent())
+			extraIndent = true;
+	// cannot attach a 'case' statement without indent-switches
+	if (!getSwitchIndent()
+	        && (findKeyword(currentLine, charNum, AS_CASE)
+	            || findKeyword(currentLine, charNum, AS_DEFAULT)))
+		return; // false;
+	// extra indent for switch statements
+	if (getSwitchIndent()
+	        && !preBraceHeaderStack->empty()
+	        && preBraceHeaderStack->back() == &AS_SWITCH
+	        && ((isLegalNameChar(currentChar)
+	             && !findKeyword(currentLine, charNum, AS_CASE))))
+	isInLineBreak = false;
+	// remove for extra whitespace
+	if (formattedLine.length() > lastText + 1
+	        && formattedLine.find_first_not_of(" \t", lastText + 1) == string::npos)
+	if (extraHalfIndent)
+		int indentLength_ = getIndentLength();
+		runInIndentChars = indentLength_ / 2;
+		formattedLine.append(runInIndentChars - 1, ' ');
+	else if (getForceTabIndentation() && getIndentLength() != getTabLength())
+		// insert the space indents
+		string indent;
+		int tabLength_ = getTabLength();
+		indent.append(indentLength_, ' ');
+		if (extraIndent)
+		// replace spaces indents with tab indents
+		size_t tabCount = indent.length() / tabLength_;		// truncate extra spaces
+		indent.replace(0U, tabCount * tabLength_, tabCount, '\t');
+		runInIndentChars = indentLength_;
+		if (indent[0] == ' ')			// allow for brace
+			indent.erase(0, 1);
+		formattedLine.append(indent);
+	else if (getIndentString() == "\t")
+		appendChar('\t', false);
+		runInIndentChars = 2;	// one for { and one for tab
+		if (extraIndent)
+			runInIndentChars++;
+	else // spaces
+		formattedLine.append(indentLength_ - 1, ' ');
+		if (extraIndent)
+			formattedLine.append(indentLength_, ' ');
+			runInIndentChars += indentLength_;
+	isInBraceRunIn = true;
+ * remove whitespace and add indentation for an array run-in.
+void ASFormatter::formatArrayRunIn()
+	assert(isBraceType(braceTypeStack->back(), ARRAY_TYPE));
+		return;
+		return;
+	// check for extra whitespace
+	if (getIndentString() == "\t")
+	else
+		int indent = getIndentLength();
+		formattedLine.append(indent - 1, ' ');
+		runInIndentChars = indent;
+ * delete a braceTypeStack vector object
+ * BraceTypeStack did not work with the DeleteContainer template
+void ASFormatter::deleteContainer(vector<BraceType>*& container)
+	if (container != nullptr)
+		container->clear();
+		delete (container);
+		container = nullptr;
+ * delete a vector object
+ * T is the type of vector
+ * used for all vectors except braceTypeStack
+template<typename T>
+void ASFormatter::deleteContainer(T& container)
+ * initialize a braceType vector object
+ * braceType did not work with the DeleteContainer template
+void ASFormatter::initContainer(vector<BraceType>*& container, vector<BraceType>* value)
+		deleteContainer(container);
+	container = value;
+ * initialize a vector object
+void ASFormatter::initContainer(T& container, T value)
+	// since the ASFormatter object is never deleted,
+	// the existing vectors must be deleted before creating new ones
+ * convert a tab to spaces.
+ * charNum points to the current character to convert to spaces.
+ * tabIncrementIn is the increment that must be added for tab indent characters
+ *     to get the correct column for the current tab.
+ * replaces the tab in currentLine with the required number of spaces.
+ * replaces the value of currentChar.
+void ASFormatter::convertTabToSpaces()
+	assert(currentChar == '\t');
+	// do NOT replace if in quotes
+	if (isInQuote || isInQuoteContinuation)
+		return;
+	size_t tabSize = getTabLength();
+	size_t numSpaces = tabSize - ((tabIncrementIn + charNum) % tabSize);
+	currentLine.replace(charNum, 1, numSpaces, ' ');
+	currentChar = currentLine[charNum];
+* is it ok to break this block?
+bool ASFormatter::isOkToBreakBlock(BraceType braceType) const
+	// Actually, there should not be an ARRAY_TYPE brace here.
+	// But this will avoid breaking a one line block when there is.
+	// Otherwise they will be formatted differently on consecutive runs.
+	if (isBraceType(braceType, ARRAY_TYPE)
+	        && isBraceType(braceType, SINGLE_LINE_TYPE))
+		return false;
+	if (isBraceType(braceType, COMMAND_TYPE)
+	        && isBraceType(braceType, EMPTY_BLOCK_TYPE))
+		return false;
+	if (!isBraceType(braceType, SINGLE_LINE_TYPE)
+	        || isBraceType(braceType, BREAK_BLOCK_TYPE)
+	        || shouldBreakOneLineBlocks)
+		return true;
+	return false;
+* check if a sharp header is a paren or non-paren header
+bool ASFormatter::isSharpStyleWithParen(const string* header) const
+	return (isSharpStyle() && peekNextChar() == '('
+	        && (header == &AS_CATCH
+	            || header == &AS_DELEGATE));
+ * Check for a following header when a comment is reached.
+ * firstLine must contain the start of the comment.
+ * return value is a pointer to the header or nullptr.
+const string* ASFormatter::checkForHeaderFollowingComment(const string& firstLine) const
+	assert(isInComment || isInLineComment);
+	assert(shouldBreakElseIfs || shouldBreakBlocks || isInSwitchStatement());
+	bool endOnEmptyLine = (currentHeader == nullptr);
+	if (isInSwitchStatement())
+		endOnEmptyLine = false;
+	string nextText = peekNextText(firstLine, endOnEmptyLine);
+	if (nextText.length() == 0 || !isCharPotentialHeader(nextText, 0))
+		return nullptr;
+	return ASBase::findHeader(nextText, 0, headers);
+ * process preprocessor statements.
+ * charNum should be the index of the #.
+ * delete braceTypeStack entries added by #if if a #else is found.
+ * prevents double entries in the braceTypeStack.
+void ASFormatter::processPreprocessor()
+	assert(currentChar == '#');
+	const size_t preproc = currentLine.find_first_not_of(" \t", charNum + 1);
+	if (preproc == string::npos)
+		return;
+	if (currentLine.compare(preproc, 2, "if") == 0)
+		preprocBraceTypeStackSize = braceTypeStack->size();
+	else if (currentLine.compare(preproc, 4, "else") == 0)
+		// delete stack entries added in #if
+		// should be replaced by #else
+		if (preprocBraceTypeStackSize > 0)
+			int addedPreproc = braceTypeStack->size() - preprocBraceTypeStackSize;
+			for (int i = 0; i < addedPreproc; i++)
+				braceTypeStack->pop_back();
+ * determine if the next line starts a comment
+ * and a header follows the comment or comments.
+bool ASFormatter::commentAndHeaderFollows()
+	// called ONLY IF shouldDeleteEmptyLines and shouldBreakBlocks are TRUE.
+	assert(shouldDeleteEmptyLines && shouldBreakBlocks);
+	// is the next line a comment
+	auto stream = make_shared<ASPeekStream>(sourceIterator);
+	if (!stream->hasMoreLines())
+		return false;
+	string nextLine_ = stream->peekNextLine();
+	size_t firstChar = nextLine_.find_first_not_of(" \t");
+	        || !(nextLine_.compare(firstChar, 2, "//") == 0
+	             || nextLine_.compare(firstChar, 2, "/*") == 0))
+		return false;
+	// find the next non-comment text, and reset
+	string nextText = peekNextText(nextLine_, false, stream);
+		return false;
+	const string* newHeader = ASBase::findHeader(nextText, 0, headers);
+	if (newHeader == nullptr)
+		return false;
+	// if a closing header, reset break unless break is requested
+	if (isClosingHeader(newHeader) && !shouldBreakClosingHeaderBlocks)
+		isAppendPostBlockEmptyLineRequested = false;
+		return false;
+	return true;
+ * determine if a brace should be attached or broken
+ * uses braces in the braceTypeStack
+ * the last brace in the braceTypeStack is the one being formatted
+ * returns true if the brace should be broken
+bool ASFormatter::isCurrentBraceBroken() const
+	assert(braceTypeStack->size() > 1);
+	bool breakBrace = false;
+	size_t stackEnd = braceTypeStack->size() - 1;
+	// check brace modifiers
+	if (shouldAttachExternC
+	        && isBraceType((*braceTypeStack)[stackEnd], EXTERN_TYPE))
+		return false;
+	if (shouldAttachNamespace
+	        && isBraceType((*braceTypeStack)[stackEnd], NAMESPACE_TYPE))
+		return false;
+	if (shouldAttachClass
+	        && (isBraceType((*braceTypeStack)[stackEnd], CLASS_TYPE)
+	            || isBraceType((*braceTypeStack)[stackEnd], INTERFACE_TYPE)))
+		return false;
+	if (shouldAttachInline
+	        && isCStyle()			// for C++ only
+	        && braceFormatMode != RUN_IN_MODE
+	        && !(currentLineBeginsWithBrace && peekNextChar() == '/')
+	        && isBraceType((*braceTypeStack)[stackEnd], COMMAND_TYPE))
+		size_t i;
+		for (i = 1; i < braceTypeStack->size(); i++)
+			if (isBraceType((*braceTypeStack)[i], CLASS_TYPE)
+			        || isBraceType((*braceTypeStack)[i], STRUCT_TYPE))
+				return false;
+	// check braces
+	if (isBraceType((*braceTypeStack)[stackEnd], EXTERN_TYPE))
+		        || braceFormatMode == RUN_IN_MODE)
+			breakBrace = true;
+	else if (braceFormatMode == BREAK_MODE || braceFormatMode == RUN_IN_MODE)
+	else if (braceFormatMode == LINUX_MODE)
+		// break a namespace if NOT stroustrup or mozilla
+		if (isBraceType((*braceTypeStack)[stackEnd], NAMESPACE_TYPE))
+			if (formattingStyle != STYLE_STROUSTRUP
+			        && formattingStyle != STYLE_MOZILLA)
+		// break a class or interface if NOT stroustrup
+		else if (isBraceType((*braceTypeStack)[stackEnd], CLASS_TYPE)
+			if (formattingStyle != STYLE_STROUSTRUP)
+		// break a struct if mozilla - an enum is processed as an array brace
+		else if (isBraceType((*braceTypeStack)[stackEnd], STRUCT_TYPE))
+			if (formattingStyle == STYLE_MOZILLA)
+		// break the first brace if a function
+		else if (isBraceType((*braceTypeStack)[stackEnd], COMMAND_TYPE))
+			if (stackEnd == 1)
+			else if (stackEnd > 1)
+				// break the first brace after these if a function
+				if (isBraceType((*braceTypeStack)[stackEnd - 1], NAMESPACE_TYPE)
+				        || isBraceType((*braceTypeStack)[stackEnd - 1], CLASS_TYPE)
+				        || isBraceType((*braceTypeStack)[stackEnd - 1], ARRAY_TYPE)
+				        || isBraceType((*braceTypeStack)[stackEnd - 1], STRUCT_TYPE)
+				        || isBraceType((*braceTypeStack)[stackEnd - 1], EXTERN_TYPE))
+	return breakBrace;
+ * format comment body
+void ASFormatter::formatCommentBody()
+	assert(isInComment);
+	// append the comment
+	while (charNum < (int) currentLine.length())
+		if (isSequenceReached("*/"))
+			formatCommentCloser();
+			break;
+		if (currentChar == '\t' && shouldConvertTabs)
+			convertTabToSpaces();
+		++charNum;
+	if (shouldStripCommentPrefix)
+		stripCommentPrefix();
+ * format a comment opener
+ * the comment opener will be appended to the current formattedLine or a new formattedLine as necessary
+void ASFormatter::formatCommentOpener()
+	assert(isSequenceReached("/*"));
+	isInComment = isInCommentStartLine = true;
+	isImmediatelyPostLineComment = false;
+	if (previousNonWSChar == '}')
+		resetEndOfStatement();
+	// Check for a following header.
+	// For speed do not check multiple comment lines more than once.
+	// For speed do not check shouldBreakBlocks if previous line is empty, a comment, or a '{'.
+	const string* followingHeader = nullptr;
+	if ((doesLineStartComment
+	        && !isImmediatelyPostCommentOnly
+	        && isBraceType(braceTypeStack->back(), COMMAND_TYPE))
+	        && (shouldBreakElseIfs
+	            || isInSwitchStatement()
+	            || (shouldBreakBlocks
+	                && !isImmediatelyPostEmptyLine
+	                && previousCommandChar != '{')))
+		followingHeader = checkForHeaderFollowingComment(currentLine.substr(charNum));
+	if (spacePadNum != 0 && !isInLineBreak)
+		adjustComments();
+	formattedLineCommentNum = formattedLine.length();
+	// must be done BEFORE appendSequence
+	        && !isImmediatelyPostLineComment)
+			// namespace run-in is always broken.
+			// should a run-in statement be attached?
+			if (currentLineBeginsWithBrace)
+				formatRunIn();
+		else if (braceFormatMode == ATTACH_MODE)
+			// if the brace was not attached?
+			if (formattedLine.length() > 0 && formattedLine[0] == '{'
+			        && !isBraceType(braceTypeStack->back(), SINGLE_LINE_TYPE))
+			if (formattedLine.length() > 0 && formattedLine[0] == '{')
+				formatRunIn();
+	else if (!doesLineStartComment)
+		noTrimCommentContinuation = true;
+	// ASBeautifier needs to know the following statements
+	if (shouldBreakElseIfs && followingHeader == &AS_ELSE)
+		elseHeaderFollowsComments = true;
+	if (followingHeader == &AS_CASE || followingHeader == &AS_DEFAULT)
+		caseHeaderFollowsComments = true;
+	// appendSequence will write the previous line
+	appendSequence(AS_OPEN_COMMENT);
+	goForward(1);
+	// must be done AFTER appendSequence
+	// Break before the comment if a header follows the line comment.
+	// But not break if previous line is empty, a comment, or a '{'.
+	        && followingHeader != nullptr
+		if (isClosingHeader(followingHeader))
+			if (!shouldBreakClosingHeaderBlocks)
+				isPrependPostBlockEmptyLineRequested = false;
+		// if an opening header, break before the comment
+		else
+			isPrependPostBlockEmptyLineRequested = true;
+	if (previousCommandChar == '}')
+		currentHeader = nullptr;
+ * format a comment closer
+ * the comment closer will be appended to the current formattedLine
+void ASFormatter::formatCommentCloser()
+	assert(isSequenceReached("*/"));
+	isInComment = false;
+	noTrimCommentContinuation = false;
+	isImmediatelyPostComment = true;
+	appendSequence(AS_CLOSE_COMMENT);
+	goForward(1);
+	if (doesLineStartComment
+	        && (currentLine.find_first_not_of(" \t", charNum + 1) == string::npos))
+		lineEndsInCommentOnly = true;
+	if (peekNextChar() == '}'
+	        && !isBraceType(braceTypeStack->back(), ARRAY_TYPE)
+	        && !isInPreprocessor
+	        && isOkToBreakBlock(braceTypeStack->back()))
+ * format a line comment body
+void ASFormatter::formatLineCommentBody()
+	assert(isInLineComment);
+//	        && !isLineReady	// commented out in release 2.04, unnecessary
+		++charNum;
+	// explicitly break a line when a line comment's end is found.
+	if (charNum == (int) currentLine.length())
+		isInLineComment = false;
+		isImmediatelyPostLineComment = true;
+		currentChar = 0;  //make sure it is a neutral char.
+ * format a line comment opener
+ * the line comment opener will be appended to the current formattedLine or a new formattedLine as necessary
+void ASFormatter::formatLineCommentOpener()
+	assert(isSequenceReached("//"));
+	if ((int) currentLine.length() > charNum + 2
+	        && currentLine[charNum + 2] == '\xf2')     // check for windows line marker
+	isInLineComment = true;
+	isCharImmediatelyPostComment = false;
+	if ((lineIsLineCommentOnly
+	// do not indent if in column 1 or 2
+	// or in a namespace before the opening brace
+	if ((!shouldIndentCol1Comments && !lineCommentNoIndent)
+	        || foundNamespaceHeader)
+		if (charNum == 0)
+			lineCommentNoIndent = true;
+		else if (charNum == 1 && currentLine[0] == ' ')
+	// move comment if spaces were added or deleted
+	if (!lineCommentNoIndent && spacePadNum != 0 && !isInLineBreak)
+		adjustComments();
+	// check for run-in statement
+		if (braceFormatMode == NONE_MODE)
+				formatRunIn();
+			if (!lineCommentNoIndent)
+				formatRunIn();
+			else
+		else
+	appendSequence(AS_OPEN_LINE_COMMENT);
+	goForward(1);
+	// But do not break if previous line is empty, a comment, or a '{'.
+		else
+	// if tabbed input don't convert the immediately following tabs to spaces
+	if (getIndentString() == "\t" && lineCommentNoIndent)
+		while (charNum + 1 < (int) currentLine.length()
+			currentChar = currentLine[++charNum];
+	if (charNum + 1 == (int) currentLine.length())
+ * format quote body
+void ASFormatter::formatQuoteBody()
+	assert(isInQuote);
+	if (isSpecialChar)
+		isSpecialChar = false;
+	else if (currentChar == '\\' && !isInVerbatimQuote)
+		if (peekNextChar() == ' ')              // is this '\' at end of line
+			haveLineContinuationChar = true;
+		else
+			isSpecialChar = true;
+	else if (isInVerbatimQuote && currentChar == '"')
+		if (isCStyle())
+			string delim = ')' + verbatimDelimiter;
+			int delimStart = charNum - delim.length();
+			if (delimStart > 0 && currentLine.substr(delimStart, delim.length()) == delim)
+				isInQuote = false;
+				isInVerbatimQuote = false;
+		else if (isSharpStyle())
+			if ((int) currentLine.length() > charNum + 1
+			        && currentLine[charNum + 1] == '"')			// check consecutive quotes
+				appendSequence("\"\"");
+				goForward(1);
+				return;
+	else if (quoteChar == currentChar)
+	// append the text to the ending quoteChar or an escape sequence
+	// tabs in quotes are NOT changed by convert-tabs
+	if (isInQuote && currentChar != '\\')
+		        && currentLine[charNum + 1] != quoteChar
+		        && currentLine[charNum + 1] != '\\')
+	if (charNum + 1 >= (int) currentLine.length()
+	        && currentChar != '\\'
+	        && !isInVerbatimQuote)
+		isInQuote = false;				// missing closing quote
+ * format a quote opener
+ * the quote opener will be appended to the current formattedLine or a new formattedLine as necessary
+void ASFormatter::formatQuoteOpener()
+	assert(currentChar == '"'
+	       || (currentChar == '\'' && !isDigitSeparator(currentLine, charNum)));
+	isInQuote = true;
+	quoteChar = currentChar;
+	if (isCStyle() && previousChar == 'R')
+		int parenPos = currentLine.find('(', charNum);
+		if (parenPos != -1)
+			isInVerbatimQuote = true;
+			verbatimDelimiter = currentLine.substr(charNum + 1, parenPos - charNum - 1);
+	else if (isSharpStyle() && previousChar == '@')
+	// a quote following a brace is an array
+	        && isNonInStatementArray
+	        && !isWhiteSpace(peekNextChar()))
+				formatRunIn();
+			formatRunIn();
+		else
+	previousCommandChar = ' ';
+ * get the next line comment adjustment that results from breaking a closing brace.
+ * the brace must be on the same line as the closing header.
+ * i.e "} else" changed to "} <NL> else".
+int ASFormatter::getNextLineCommentAdjustment()
+	assert(foundClosingHeader && previousNonWSChar == '}');
+	if (charNum < 1)			// "else" is in column 1
+		return 0;
+	size_t lastBrace = currentLine.rfind('}', charNum - 1);
+	if (lastBrace != string::npos)
+		return (lastBrace - charNum);	// return a negative number
+	return 0;
+// for console build only
+LineEndFormat ASFormatter::getLineEndFormat() const
+	return lineEnd;
+ * get the current line comment adjustment that results from attaching
+ * a closing header to a closing brace.
+ * the brace must be on the line previous to the closing header.
+ * the adjustment is 2 chars, one for the brace and one for the space.
+ * i.e "} <NL> else" changed to "} else".
+int ASFormatter::getCurrentLineCommentAdjustment()
+	if (charNum < 1)
+		return 2;
+	if (lastBrace == string::npos)
+		return 2;
+	return 0;
+ * get the previous word on a line
+ * the argument 'currPos' must point to the current position.
+ * @return is the previous word or an empty string if none found.
+string ASFormatter::getPreviousWord(const string& line, int currPos) const
+	// get the last legal word (may be a number)
+	if (currPos == 0)
+		return string();
+	size_t end = line.find_last_not_of(" \t", currPos - 1);
+	if (end == string::npos || !isLegalNameChar(line[end]))
+		return string();
+	int start;          // start of the previous word
+	for (start = end; start > -1; start--)
+		if (!isLegalNameChar(line[start]) || line[start] == '.')
+			break;
+	start++;
+	return (line.substr(start, end - start + 1));
+ * check if a line break is needed when a closing brace
+ * is followed by a closing header.
+ * the break depends on the braceFormatMode and other factors.
+void ASFormatter::isLineBreakBeforeClosingHeader()
+	if (currentHeader == &AS_WHILE && shouldAttachClosingWhile)
+		appendClosingHeader();
+		return;
+	if (braceFormatMode == BREAK_MODE
+	        || attachClosingBraceMode)
+		if (shouldBreakClosingHeaderBraces
+		        || getBraceIndent() || getBlockIndent())
+		else
+			appendSpacePad();
+			// is closing brace broken?
+			size_t i = currentLine.find_first_not_of(" \t");
+			if (i != string::npos && currentLine[i] == '}')
+			if (shouldBreakBlocks)
+	// braceFormatMode == ATTACH_MODE, LINUX_MODE
+	else
+		else
+ * Append a closing header to the previous closing brace, if possible
+void ASFormatter::appendClosingHeader()
+	// if a blank line does not precede this
+	// or last line is not a one line block, attach header
+	bool previousLineIsEmpty = isEmptyLine(formattedLine);
+	int previousLineIsOneLineBlock = 0;
+	size_t firstBrace = findNextChar(formattedLine, '{');
+	if (firstBrace != string::npos)
+		previousLineIsOneLineBlock = isOneLineBlockReached(formattedLine, firstBrace);
+	if (!previousLineIsEmpty
+	        && previousLineIsOneLineBlock == 0)
+		appendSpacePad();
+		spacePadNum = 0;	// don't count as comment padding
+ * Add braces to a single line statement following a header.
+ * braces are not added if the proper conditions are not met.
+ * braces are added to the currentLine.
+bool ASFormatter::addBracesToStatement()
+	assert(isImmediatelyPostHeader);
+	if (currentHeader != &AS_IF
+	        && currentHeader != &AS_ELSE
+	        && currentHeader != &AS_FOR
+	        && currentHeader != &AS_WHILE
+	        && currentHeader != &AS_DO
+	        && currentHeader != &AS_FOREACH
+	        && currentHeader != &AS_QFOREACH
+	        && currentHeader != &AS_QFOREVER
+	        && currentHeader != &AS_FOREVER)
+		return false;
+	if (currentHeader == &AS_WHILE && foundClosingHeader)	// do-while
+		return false;
+	// do not brace an empty statement
+	if (currentChar == ';')
+		return false;
+	// do not add if a header follows
+	if (isCharPotentialHeader(currentLine, charNum))
+		if (findHeader(headers) != nullptr)
+			return false;
+	// find the next semi-colon
+	size_t nextSemiColon = charNum;
+	if (currentChar != ';')
+		nextSemiColon = findNextChar(currentLine, ';', charNum + 1);
+	if (nextSemiColon == string::npos)
+		return false;
+	// add closing brace before changing the line length
+	if (nextSemiColon == currentLine.length() - 1)
+		currentLine.append(" }");
+	else
+		currentLine.insert(nextSemiColon + 1, " }");
+	// add opening brace
+	currentLine.insert(charNum, "{ ");
+	assert(computeChecksumIn("{}"));
+	currentChar = '{';
+	if ((int) currentLine.find_first_not_of(" \t") == charNum)
+		currentLineBeginsWithBrace = true;
+	// remove extra spaces
+	if (!shouldAddOneLineBraces)
+		if ((formattedLine.length() - 1) - lastText > 1)
+	return true;
+ * Remove braces from a single line statement following a header.
+ * braces are not removed if the proper conditions are not met.
+ * The first brace is replaced by a space.
+bool ASFormatter::removeBracesFromStatement()
+	assert(currentChar == '{');
+	        && currentHeader != &AS_FOREACH)
+		return false;
+		return false;
+	string nextLine_;
+	// leave nextLine_ empty if end of line comment follows
+	if (!isBeforeAnyLineEndComment(charNum) || currentLineBeginsWithBrace)
+		nextLine_ = currentLine.substr(charNum + 1);
+	size_t nextChar = 0;
+	ASPeekStream stream(sourceIterator);
+	while (stream.hasMoreLines() || isFirstLine)
+		if (isFirstLine)
+		else
+			nextLine_ = stream.peekNextLine();
+			nextChar = 0;
+		nextChar = nextLine_.find_first_not_of(" \t", nextChar);
+		if (nextChar != string::npos)
+			break;
+	if (!stream.hasMoreLines())
+		return false;
+	// don't remove if comments or a header follow the brace
+	if ((nextLine_.compare(nextChar, 2, "/*") == 0)
+	        || (nextLine_.compare(nextChar, 2, "//") == 0)
+	        || (isCharPotentialHeader(nextLine_, nextChar)
+	            && ASBase::findHeader(nextLine_, nextChar, headers) != nullptr))
+		return false;
+	size_t nextSemiColon = nextChar;
+	if (nextLine_[nextChar] != ';')
+		nextSemiColon = findNextChar(nextLine_, ';', nextChar + 1);
+		return false;
+	// find the closing brace
+	isFirstLine = true;
+	nextChar = nextSemiColon + 1;
+		if (isFirstLine)
+		else
+			nextChar = 0;
+			break;
+	if (nextLine_.length() == 0 || nextLine_[nextChar] != '}')
+		return false;
+	// remove opening brace
+	currentLine[charNum] = currentChar = ' ';
+	assert(adjustChecksumIn(-'{'));
+	return true;
+ * Find the next character that is not in quotes or a comment.
+ * @param line         the line to be searched.
+ * @param searchChar   the char to find.
+ * @param searchStart  the start position on the line (default is 0).
+ * @return the position on the line or string::npos if not found.
+size_t ASFormatter::findNextChar(const string& line, char searchChar, int searchStart /*0*/) const
+	// find the next searchChar
+	size_t i;
+	for (i = searchStart; i < line.length(); i++)
+		if (line.compare(i, 2, "//") == 0)
+			return string::npos;
+		if (line.compare(i, 2, "/*") == 0)
+			size_t endComment = line.find("*/", i + 2);
+			if (endComment == string::npos)
+			i = endComment + 2;
+			if (i >= line.length())
+		if (line[i] == '"'
+		        || (line[i] == '\'' && !isDigitSeparator(line, i)))
+			char quote = line[i];
+			while (i < line.length())
+				size_t endQuote = line.find(quote, i + 1);
+				if (endQuote == string::npos)
+				i = endQuote;
+				if (line[endQuote - 1] != '\\')	// check for '\"'
+					break;
+				if (line[endQuote - 2] == '\\')	// check for '\\'
+					break;
+		if (line[i] == searchChar)
+			break;
+		// for now don't process C# 'delegate' braces
+		// do this last in case the search char is a '{'
+		if (line[i] == '{')
+	if (i >= line.length())	// didn't find searchChar
+	return i;
+ * Find split point for break/attach return type.
+void ASFormatter::findReturnTypeSplitPoint(const string& firstLine)
+	assert((isBraceType(braceTypeStack->back(), NULL_TYPE)
+	        || isBraceType(braceTypeStack->back(), DEFINITION_TYPE)));
+	assert(shouldBreakReturnType || shouldBreakReturnTypeDecl
+	       || shouldAttachReturnType || shouldAttachReturnTypeDecl);
+	bool isInComment_    = false;
+	bool isInQuote_      = false;
+	bool foundSplitPoint = false;
+	bool isAlreadyBroken = false;
+	char quoteChar_      = ' ';
+	char currNonWSChar   = ' ';
+	char prevNonWSChar   = ' ';
+	size_t parenCount    = 0;
+	size_t squareCount   = 0;
+	size_t angleCount    = 0;
+	size_t breakLineNum  = 0;
+	size_t breakCharNum  = string::npos;
+	string line          = firstLine;
+	// Process the lines until a ';' or '{'.
+		if (isFirstLine)
+		else
+			if (isInQuote_)
+				return;
+			line = stream.peekNextLine();
+			if (!foundSplitPoint)
+				++breakLineNum;
+		size_t firstCharNum = line.find_first_not_of(" \t");
+		if (firstCharNum == string::npos)
+			continue;
+		if (line[firstCharNum] == '#')
+			if (shouldAttachReturnType || shouldAttachReturnTypeDecl)
+				return;
+			else
+				continue;
+		// parse the line
+		for (size_t i = 0; i < line.length(); i++)
+			if (!isWhiteSpace(line[i]))
+				prevNonWSChar = currNonWSChar;
+				currNonWSChar = line[i];
+			else if (line[i] == '\t' && shouldConvertTabs)
+				size_t numSpaces = tabSize - ((tabIncrementIn + i) % tabSize);
+				line.replace(i, 1, numSpaces, ' ');
+				currentChar = line[i];
+				isInComment_ = true;
+			if (isInComment_)
+				if (line.compare(i, 2, "*/") == 0)
+					isInComment_ = false;
+					++i;
+				continue;
+			if (line[i] == '\\')
+				++i;
+				continue;
+			if (isInQuote_)
+				if (line[i] == quoteChar_)
+					isInQuote_ = false;
+				continue;
+				isInQuote_ = true;
+				quoteChar_ = line[i];
+				continue;
+				i = line.length();
+				continue;
+			// not in quote or comment
+				if (line[i] == '<')
+					++angleCount;
+					continue;
+				if (line[i] == '>')
+					if (angleCount)
+						--angleCount;
+					if (!angleCount)
+						size_t nextCharNum = line.find_first_not_of(" \t*&", i + 1);
+						if (nextCharNum == string::npos)
+							breakCharNum  = string::npos;
+							continue;
+						if (line[nextCharNum] != ':')		// scope operator
+							breakCharNum  = nextCharNum;
+					continue;
+				if (angleCount)
+					continue;
+				if (line[i] == '[')
+					++squareCount;
+					continue;
+				if (line[i] == ']')
+					if (squareCount)
+						--squareCount;
+					continue;
+				// an assignment before the parens is not a function
+				if (line[i] == '=')
+					return;
+				if (isWhiteSpace(line[i]) || line[i] == '*' || line[i] == '&')
+					size_t nextNum = line.find_first_not_of(" \t", i + 1);
+					if (nextNum == string::npos)
+					else
+						if (line.length() > nextNum + 1
+						        && line[nextNum] == ':' && line[nextNum + 1] == ':')
+							i = --nextNum;
+						else if (line[nextNum] != '(')
+					continue;
+				if ((isLegalNameChar(line[i]) || line[i] == '~')
+				        && breakCharNum == string::npos)
+					breakCharNum = i;
+					if (isLegalNameChar(line[i])
+					        && findKeyword(line, i, AS_OPERATOR))
+						if (breakCharNum == firstCharNum)
+							isAlreadyBroken = true;
+						foundSplitPoint = true;
+						// find the operator, may be parens
+						size_t parenNum =
+						    line.find_first_not_of(" \t", i + AS_OPERATOR.length());
+						if (parenNum == string::npos)
+							return;
+						// find paren after the operator
+						parenNum = line.find('(', parenNum + 1);
+							return;
+						i = --parenNum;
+					continue;
+				if (line[i] == ':'
+				        && line.length() > i + 1
+				        && line[i + 1] == ':')
+					size_t nextCharNum = line.find_first_not_of(" \t:", i + 1);
+						return;
+					if (isLegalNameChar(line[nextCharNum])
+					        && findKeyword(line, nextCharNum, AS_OPERATOR))
+						i = nextCharNum;
+						size_t parenNum =
+							return;
+							return;
+						i = --parenNum;
+					else
+						i = --nextCharNum;
+					continue;
+				if (line[i] == '(' && !squareCount)
+					// is line is already broken?
+					if (breakCharNum == firstCharNum && breakLineNum > 0)
+					++parenCount;
+					continue;
+			// end !foundSplitPoint
+			if (line[i] == '(')
+				// consecutive ')(' parens is probably a function pointer
+				if (prevNonWSChar == ')' && !parenCount)
+					return;
+				++parenCount;
+				continue;
+			if (line[i] == ')')
+				if (parenCount)
+					--parenCount;
+				continue;
+				if (shouldBreakReturnType && foundSplitPoint && !isAlreadyBroken)
+					methodBreakCharNum = breakCharNum;
+					methodBreakLineNum = breakLineNum;
+				if (shouldAttachReturnType && foundSplitPoint && isAlreadyBroken)
+					methodAttachCharNum = breakCharNum;
+					methodAttachLineNum = breakLineNum;
+				return;
+			if (line[i] == ';')
+				if (shouldBreakReturnTypeDecl && foundSplitPoint && !isAlreadyBroken)
+				if ((shouldAttachReturnTypeDecl && foundSplitPoint && isAlreadyBroken))
+				return;
+			if (line[i] == '}')
+				return;
+		}   // end of for loop
+	}   // end of while loop
+ * Look ahead in the file to see if a struct has access modifiers.
+ * @param firstLine     a reference to the line to indent.
+ * @param index         the current line index.
+ * @return              true if the struct has access modifiers.
+bool ASFormatter::isStructAccessModified(const string& firstLine, size_t index) const
+	assert(firstLine[index] == '{');
+	assert(isCStyle());
+	bool isFirstLine = true;
+	size_t braceCount = 1;
+	string nextLine_ = firstLine.substr(index + 1);
+	// find the first non-blank text, bypassing all comments and quotes.
+		if (isFirstLine)
+			isFirstLine = false;
+		else
+		// parse the line
+		for (size_t i = 0; i < nextLine_.length(); i++)
+			if (isWhiteSpace(nextLine_[i]))
+				continue;
+			if (nextLine_.compare(i, 2, "/*") == 0)
+			if (isInComment_)
+				if (nextLine_.compare(i, 2, "*/") == 0)
+					++i;
+				continue;
+			if (nextLine_[i] == '\\')
+				++i;
+				continue;
+			if (isInQuote_)
+				if (nextLine_[i] == quoteChar_)
+				continue;
+			if (nextLine_[i] == '"'
+			        || (nextLine_[i] == '\'' && !isDigitSeparator(nextLine_, i)))
+				quoteChar_ = nextLine_[i];
+				continue;
+			if (nextLine_.compare(i, 2, "//") == 0)
+				i = nextLine_.length();
+				continue;
+			// handle braces
+			if (nextLine_[i] == '{')
+				++braceCount;
+			if (nextLine_[i] == '}')
+				--braceCount;
+			if (braceCount == 0)
+				return false;
+			// check for access modifiers
+			if (isCharPotentialHeader(nextLine_, i))
+				if (findKeyword(nextLine_, i, AS_PUBLIC)
+				        || findKeyword(nextLine_, i, AS_PRIVATE)
+				        || findKeyword(nextLine_, i, AS_PROTECTED))
+					return true;
+				string name = getCurrentWord(nextLine_, i);
+				i += name.length() - 1;
+	return false;
+* Look ahead in the file to see if a preprocessor block is indentable.
+* @param firstLine     a reference to the line to indent.
+* @param index         the current line index.
+* @return              true if the block is indentable.
+bool ASFormatter::isIndentablePreprocessorBlock(const string& firstLine, size_t index)
+	assert(firstLine[index] == '#');
+	bool isInIndentableBlock = false;
+	bool blockContainsBraces = false;
+	bool blockContainsDefineContinuation = false;
+	bool isInClassConstructor = false;
+	bool isPotentialHeaderGuard = false;	// ifndef is first preproc statement
+	bool isPotentialHeaderGuard2 = false;	// define is within the first proproc
+	int  numBlockIndents = 0;
+	int  lineParenCount = 0;
+	string nextLine_ = firstLine.substr(index);
+	// find end of the block, bypassing all comments and quotes.
+	while (stream->hasMoreLines() || isFirstLine)
+		if (isFirstLine)
+		else
+			nextLine_ = stream->peekNextLine();
+		// parse the line
+				continue;
+			if (isInComment_)
+					++i;
+				continue;
+				++i;
+				continue;
+			if (isInQuote_)
+				continue;
+				continue;
+				continue;
+			// handle preprocessor statement
+			if (nextLine_[i] == '#')
+				string preproc = ASBeautifier::extractPreprocessorStatement(nextLine_);
+				if (preproc.length() >= 2 && preproc.substr(0, 2) == "if") // #if, #ifdef, #ifndef
+					numBlockIndents += 1;
+					isInIndentableBlock = true;
+					// flag first preprocessor conditional for header include guard check
+					if (!processedFirstConditional)
+						processedFirstConditional = true;
+						isFirstPreprocConditional = true;
+						if (isNDefPreprocStatement(nextLine_, preproc))
+							isPotentialHeaderGuard = true;
+				else if (preproc == "endif")
+					if (numBlockIndents > 0)
+						numBlockIndents -= 1;
+					// must exit BOTH loops
+					if (numBlockIndents == 0)
+						goto EndOfWhileLoop;
+				else if (preproc == "define")
+					if (nextLine_[nextLine_.length() - 1] == '\\')
+						blockContainsDefineContinuation = true;
+					// check for potential header include guards
+					else if (isPotentialHeaderGuard && numBlockIndents == 1)
+						isPotentialHeaderGuard2 = true;
+				continue;
+			// handle exceptions
+			if (nextLine_[i] == '{' || nextLine_[i] == '}')
+				blockContainsBraces = true;
+			else if (nextLine_[i] == '(')
+				++lineParenCount;
+			else if (nextLine_[i] == ')')
+				--lineParenCount;
+			else if (nextLine_[i] == ':')
+				// check for '::'
+				if (nextLine_.length() > i + 1 && nextLine_[i + 1] == ':')
+					++i;
+				else
+					isInClassConstructor = true;
+			// bypass unnecessary parsing - must exit BOTH loops
+			if (blockContainsBraces || isInClassConstructor || blockContainsDefineContinuation)
+		}	// end of for loop, end of line
+		if (lineParenCount != 0)
+			break;
+EndOfWhileLoop:
+	preprocBlockEnd = sourceIterator->tellg();
+	if (preprocBlockEnd < 0)
+		preprocBlockEnd = sourceIterator->getStreamLength();
+	        || isInClassConstructor
+	        || blockContainsDefineContinuation
+	        || lineParenCount != 0
+	        || numBlockIndents != 0)
+		isInIndentableBlock = false;
+	// find next executable instruction
+	// this WILL RESET the get pointer
+	string nextText = peekNextText("", false, stream);
+	// bypass header include guards
+	if (isFirstPreprocConditional)
+		isFirstPreprocConditional = false;
+		if (nextText.empty() && isPotentialHeaderGuard2)
+			preprocBlockEnd = 0;
+	// this allows preprocessor blocks within this block to be indented
+	if (!isInIndentableBlock)
+	// peekReset() is done by previous peekNextText()
+	return isInIndentableBlock;
+bool ASFormatter::isNDefPreprocStatement(const string& nextLine_, const string& preproc) const
+	if (preproc == "ifndef")
+		return true;
+	// check for '!defined'
+	if (preproc == "if")
+		size_t i = nextLine_.find('!');
+		if (i == string::npos)
+			return false;
+		i = nextLine_.find_first_not_of(" \t", ++i);
+		if (i != string::npos && nextLine_.compare(i, 7, "defined") == 0)
+			return true;
+	return false;
+ * Check to see if this is an EXEC SQL statement.
+ * @param line          a reference to the line to indent.
+ * @return              true if the statement is EXEC SQL.
+bool ASFormatter::isExecSQL(const string& line, size_t index) const
+	if (line[index] != 'e' && line[index] != 'E')	// quick check to reject most
+		return false;
+	string word;
+	if (isCharPotentialHeader(line, index))
+		word = getCurrentWord(line, index);
+	for (size_t i = 0; i < word.length(); i++)
+		word[i] = (char) toupper(word[i]);
+	if (word != "EXEC")
+		return false;
+	size_t index2 = index + word.length();
+	index2 = line.find_first_not_of(" \t", index2);
+	if (index2 == string::npos)
+		return false;
+	word.erase();
+	if (isCharPotentialHeader(line, index2))
+		word = getCurrentWord(line, index2);
+	if (word != "SQL")
+		return false;
+	return true;
+ * The continuation lines must be adjusted so the leading spaces
+ *     is equivalent to the text on the opening line.
+ * Updates currentLine and charNum.
+void ASFormatter::trimContinuationLine()
+	size_t len = currentLine.length();
+	charNum = 0;
+	if (leadingSpaces > 0 && len > 0)
+		size_t i;
+		size_t continuationIncrementIn = 0;
+		for (i = 0; (i < len) && (i + continuationIncrementIn < leadingSpaces); i++)
+			if (!isWhiteSpace(currentLine[i]))		// don't delete any text
+				if (i < continuationIncrementIn)
+					leadingSpaces = i + tabIncrementIn;
+				continuationIncrementIn = tabIncrementIn;
+				break;
+			if (currentLine[i] == '\t')
+				continuationIncrementIn += tabSize - 1 - ((continuationIncrementIn + i) % tabSize);
+		if ((int) continuationIncrementIn == tabIncrementIn)
+			charNum = i;
+		else
+			// build a new line with the equivalent leading chars
+			string newLine;
+			int leadingChars = 0;
+			if ((int) leadingSpaces > tabIncrementIn)
+				leadingChars = leadingSpaces - tabIncrementIn;
+			newLine.append(leadingChars, ' ');
+			newLine.append(currentLine, i, len - i);
+			currentLine = newLine;
+			charNum = leadingChars;
+			if (currentLine.length() == 0)
+				currentLine = string(" ");        // a null is inserted if this is not done
+		if (i >= len)
+			charNum = 0;
+ * Determine if a header is a closing header
+ * @return      true if the header is a closing header.
+bool ASFormatter::isClosingHeader(const string* header) const
+	return (header == &AS_ELSE
+	        || header == &AS_CATCH
+	        || header == &AS_FINALLY);
+ * Determine if a * following a closing paren is immediately.
+ * after a cast. If so it is a deference and not a multiply.
+ * e.g. "(int*) *ptr" is a deference.
+bool ASFormatter::isImmediatelyPostCast() const
+	assert(previousNonWSChar == ')' && currentChar == '*');
+	// find preceding closing paren on currentLine or readyFormattedLine
+	string line;		// currentLine or readyFormattedLine
+	size_t paren = currentLine.rfind(')', charNum);
+	if (paren != string::npos)
+		line = currentLine;
+	// if not on currentLine it must be on the previous line
+	else
+		line = readyFormattedLine;
+		paren = line.rfind(')');
+		if (paren == string::npos)
+			return false;
+	if (paren == 0)
+		return false;
+	// find character preceding the closing paren
+	size_t lastChar = line.find_last_not_of(" \t", paren - 1);
+	if (lastChar == string::npos)
+		return false;
+	// check for pointer cast
+	if (line[lastChar] == '*')
+		return true;
+	return false;
+ * Determine if a < is a template definition or instantiation.
+ * Sets the class variables isInTemplate and templateDepth.
+void ASFormatter::checkIfTemplateOpener()
+	assert(!isInTemplate && currentChar == '<');
+	// find first char after the '<' operators
+	size_t firstChar = currentLine.find_first_not_of("< \t", charNum);
+	if (firstChar == string::npos
+	        || currentLine[firstChar] == '=')
+		// this is not a template -> leave...
+		isInTemplate = false;
+		return;
+	int parenDepth_ = 0;
+	int maxTemplateDepth = 0;
+	templateDepth = 0;
+	string nextLine_ = currentLine.substr(charNum);
+	// find the angle braces, bypassing all comments and quotes.
+		if (isFirstLine)
+		else
+		// parse the line
+			char currentChar_ = nextLine_[i];
+			if (isWhiteSpace(currentChar_))
+				continue;
+			if (isInComment_)
+					++i;
+				continue;
+			if (currentChar_ == '\\')
+				++i;
+				continue;
+			if (isInQuote_)
+				if (currentChar_ == quoteChar_)
+				continue;
+			if (currentChar_ == '"'
+			        || (currentChar_ == '\'' && !isDigitSeparator(nextLine_, i)))
+				quoteChar_ = currentChar_;
+				continue;
+				continue;
+			// not in a comment or quote
+			if (currentChar_ == '<')
+				++templateDepth;
+				++maxTemplateDepth;
+				continue;
+			else if (currentChar_ == '>')
+				--templateDepth;
+				if (templateDepth == 0)
+					if (parenDepth_ == 0)
+						// this is a template!
+						isInTemplate = true;
+						templateDepth = maxTemplateDepth;
+					return;
+				continue;
+			else if (currentChar_ == '(' || currentChar_ == ')')
+				if (currentChar_ == '(')
+					++parenDepth_;
+				else
+					--parenDepth_;
+				if (parenDepth_ >= 0)
+					continue;
+				return;
+			else if (nextLine_.compare(i, 2, AS_AND) == 0
+			         || nextLine_.compare(i, 2, AS_OR) == 0)
+				return;
+			else if (currentChar_ == ','  // comma,     e.g. A<int, char>
+			         || currentChar_ == '&'    // reference, e.g. A<int&>
+			         || currentChar_ == '*'    // pointer,   e.g. A<int*>
+			         || currentChar_ == '^'    // C++/CLI managed pointer, e.g. A<int^>
+			         || currentChar_ == ':'    // ::,        e.g. std::string
+			         || currentChar_ == '='    // assign     e.g. default parameter
+			         || currentChar_ == '['    // []         e.g. string[]
+			         || currentChar_ == ']'    // []         e.g. string[]
+			         || currentChar_ == '('    // (...)      e.g. function definition
+			         || currentChar_ == ')'    // (...)      e.g. function definition
+			         || (isJavaStyle() && currentChar_ == '?')   // Java wildcard
+				continue;
+			else if (!isLegalNameChar(currentChar_))
+				return;
+		}	// end for loop
+	}	// end while loop
+void ASFormatter::updateFormattedLineSplitPoints(char appendedChar)
+	assert(maxCodeLength != string::npos);
+	assert(formattedLine.length() > 0);
+	if (!isOkToSplitFormattedLine())
+		return;
+	char nextChar = peekNextChar();
+	// don't split before an end of line comment
+	if (nextChar == '/')
+		return;
+	// don't split before or after a brace
+	if (appendedChar == '{' || appendedChar == '}'
+	        || previousNonWSChar == '{' || previousNonWSChar == '}'
+	        || nextChar == '{' || nextChar == '}'
+	        || currentChar == '{' || currentChar == '}')	// currentChar tests for an appended brace
+		return;
+	// don't split before or after a block paren
+	if (appendedChar == '[' || appendedChar == ']'
+	        || previousNonWSChar == '['
+	        || nextChar == '[' || nextChar == ']')
+		return;
+	if (isWhiteSpace(appendedChar))
+		if (nextChar != ')'						// space before a closing paren
+		        && nextChar != '('				// space before an opening paren
+		        && nextChar != '/'				// space before a comment
+		        && nextChar != ':'				// space before a colon
+		        && currentChar != ')'			// appended space before and after a closing paren
+		        && currentChar != '('			// appended space before and after a opening paren
+		        && previousNonWSChar != '('		// decided at the '('
+		        // don't break before a pointer or reference aligned to type
+		        && !(nextChar == '*'
+		             && !isCharPotentialOperator(previousNonWSChar)
+		             && pointerAlignment == PTR_ALIGN_TYPE)
+		        && !(nextChar == '&'
+		             && (referenceAlignment == REF_ALIGN_TYPE
+		                 || (referenceAlignment == REF_SAME_AS_PTR && pointerAlignment == PTR_ALIGN_TYPE)))
+			if (formattedLine.length() - 1 <= maxCodeLength)
+				maxWhiteSpace = formattedLine.length() - 1;
+			else
+				maxWhiteSpacePending = formattedLine.length() - 1;
+	// unpadded closing parens may split after the paren (counts as whitespace)
+	else if (appendedChar == ')')
+		        && nextChar != ' '
+		        && nextChar != ';'
+		        && nextChar != ','
+		        && nextChar != '.'
+		        && !(nextChar == '-' && pointerSymbolFollows()))	// check for ->
+			if (formattedLine.length() <= maxCodeLength)
+				maxWhiteSpace = formattedLine.length();
+			else
+				maxWhiteSpacePending = formattedLine.length();
+	// unpadded commas may split after the comma
+	else if (appendedChar == ',')
+			maxComma = formattedLine.length();
+		else
+			maxCommaPending = formattedLine.length();
+	else if (appendedChar == '(')
+		if (nextChar != ')' && nextChar != '(' && nextChar != '"' && nextChar != '\'')
+			// if follows an operator break before
+			size_t parenNum;
+			if (previousNonWSChar != ' ' && isCharPotentialOperator(previousNonWSChar))
+				parenNum = formattedLine.length() - 1;
+			else
+				parenNum = formattedLine.length();
+				maxParen = parenNum;
+			else
+				maxParenPending = parenNum;
+	else if (appendedChar == ';')
+		if (nextChar != ' '  && nextChar != '}' && nextChar != '/')	// check for following comment
+				maxSemi = formattedLine.length();
+			else
+				maxSemiPending = formattedLine.length();
+void ASFormatter::updateFormattedLineSplitPointsOperator(const string& sequence)
+		return;
+		return;
+	// check for logical conditional
+	if (sequence == "||" || sequence == "&&" || sequence == "or" || sequence == "and")
+		if (shouldBreakLineAfterLogical)
+				maxAndOr = formattedLine.length();
+			else
+				maxAndOrPending = formattedLine.length();
+		else
+			// adjust for leading space in the sequence
+			size_t sequenceLength = sequence.length();
+			if (formattedLine.length() > sequenceLength
+			        && isWhiteSpace(formattedLine[formattedLine.length() - sequenceLength - 1]))
+				sequenceLength++;
+			if (formattedLine.length() - sequenceLength <= maxCodeLength)
+				maxAndOr = formattedLine.length() - sequenceLength;
+			else
+				maxAndOrPending = formattedLine.length() - sequenceLength;
+	// comparison operators will split after the operator (counts as whitespace)
+	else if (sequence == "==" || sequence == "!=" || sequence == ">=" || sequence == "<=")
+		else
+	// unpadded operators that will split BEFORE the operator (counts as whitespace)
+	else if (sequence == "+" || sequence == "-" || sequence == "?")
+		if (charNum > 0
+		        && !(sequence == "+" && isInExponent())
+		        && !(sequence == "-"  && isInExponent())
+		        && (isLegalNameChar(currentLine[charNum - 1])
+		            || currentLine[charNum - 1] == ')'
+		            || currentLine[charNum - 1] == ']'
+		            || currentLine[charNum - 1] == '\"'))
+			else
+	// unpadded operators that will USUALLY split AFTER the operator (counts as whitespace)
+	else if (sequence == "=" || sequence == ":")
+		// split BEFORE if the line is too long
+		// do NOT use <= here, must allow for a brace attached to an array
+		size_t splitPoint = 0;
+		if (formattedLine.length() < maxCodeLength)
+			splitPoint = formattedLine.length();
+		else
+			splitPoint = formattedLine.length() - 1;
+		// padded or unpadded arrays
+		if (previousNonWSChar == ']')
+				maxWhiteSpace = splitPoint;
+			else
+				maxWhiteSpacePending = splitPoint;
+		else if (charNum > 0
+		             || currentLine[charNum - 1] == ']'))
+			else
+ * Update the split point when a pointer or reference is formatted.
+ * The argument is the maximum index of the last whitespace character.
+void ASFormatter::updateFormattedLineSplitPointsPointerOrReference(size_t index)
+	assert(index < formattedLine.length());
+		return;
+	if (index < maxWhiteSpace)		// just in case
+		return;
+	if (index <= maxCodeLength)
+		maxWhiteSpace = index;
+	else
+		maxWhiteSpacePending = index;
+bool ASFormatter::isOkToSplitFormattedLine()
+	// Is it OK to split the line?
+	if (shouldKeepLineUnbroken
+	        || isInLineComment
+	        || isInComment
+	        || isInQuote
+	        || isInCase
+	        || isInPreprocessor
+	        || isInExecSQL
+	        || isInAsm || isInAsmOneLine || isInAsmBlock
+	        || isInTemplate)
+		return false;
+	if (!isOkToBreakBlock(braceTypeStack->back()) && currentChar != '{')
+		shouldKeepLineUnbroken = true;
+		clearFormattedLineSplitPoints();
+		return false;
+	if (isBraceType(braceTypeStack->back(), ARRAY_TYPE))
+		if (!isBraceType(braceTypeStack->back(), ARRAY_NIS_TYPE))
+		return false;
+	return true;
+/* This is called if the option maxCodeLength is set.
+void ASFormatter::testForTimeToSplitFormattedLine()
+	//	DO NOT ASSERT maxCodeLength HERE
+	// should the line be split
+	if (formattedLine.length() > maxCodeLength && !isLineReady)
+		size_t splitPoint = findFormattedLineSplitPoint();
+		if (splitPoint > 0 && splitPoint < formattedLine.length())
+			string splitLine = formattedLine.substr(splitPoint);
+			formattedLine = formattedLine.substr(0, splitPoint);
+			breakLine(true);
+			formattedLine = splitLine;
+			// if break-blocks is requested and this is a one-line statement
+			string nextWord = ASBeautifier::getNextWord(currentLine, charNum - 1);
+			if (isAppendPostBlockEmptyLineRequested
+			        && (nextWord == "break" || nextWord == "continue"))
+			else
+			// adjust max split points
+			maxAndOr = (maxAndOr > splitPoint) ? (maxAndOr - splitPoint) : 0;
+			maxSemi = (maxSemi > splitPoint) ? (maxSemi - splitPoint) : 0;
+			maxComma = (maxComma > splitPoint) ? (maxComma - splitPoint) : 0;
+			maxParen = (maxParen > splitPoint) ? (maxParen - splitPoint) : 0;
+			maxWhiteSpace = (maxWhiteSpace > splitPoint) ? (maxWhiteSpace - splitPoint) : 0;
+			if (maxSemiPending > 0)
+				maxSemi = (maxSemiPending > splitPoint) ? (maxSemiPending - splitPoint) : 0;
+				maxSemiPending = 0;
+			if (maxAndOrPending > 0)
+				maxAndOr = (maxAndOrPending > splitPoint) ? (maxAndOrPending - splitPoint) : 0;
+				maxAndOrPending = 0;
+			if (maxCommaPending > 0)
+				maxComma = (maxCommaPending > splitPoint) ? (maxCommaPending - splitPoint) : 0;
+				maxCommaPending = 0;
+			if (maxParenPending > 0)
+				maxParen = (maxParenPending > splitPoint) ? (maxParenPending - splitPoint) : 0;
+				maxParenPending = 0;
+			if (maxWhiteSpacePending > 0)
+				maxWhiteSpace = (maxWhiteSpacePending > splitPoint) ? (maxWhiteSpacePending - splitPoint) : 0;
+				maxWhiteSpacePending = 0;
+			// don't allow an empty formatted line
+			size_t firstText = formattedLine.find_first_not_of(" \t");
+			if (firstText == string::npos && formattedLine.length() > 0)
+				formattedLine.erase();
+				if (isWhiteSpace(currentChar))
+					for (size_t i = charNum + 1; i < currentLine.length() && isWhiteSpace(currentLine[i]); i++)
+						goForward(1);
+			else if (firstText > 0)
+				formattedLine.erase(0, firstText);
+				maxSemi = (maxSemi > firstText) ? (maxSemi - firstText) : 0;
+				maxAndOr = (maxAndOr > firstText) ? (maxAndOr - firstText) : 0;
+				maxComma = (maxComma > firstText) ? (maxComma - firstText) : 0;
+				maxParen = (maxParen > firstText) ? (maxParen - firstText) : 0;
+				maxWhiteSpace = (maxWhiteSpace > firstText) ? (maxWhiteSpace - firstText) : 0;
+			// reset formattedLineCommentNum
+			if (formattedLineCommentNum != string::npos)
+				formattedLineCommentNum = formattedLine.find("//");
+				if (formattedLineCommentNum == string::npos)
+					formattedLineCommentNum = formattedLine.find("/*");
+size_t ASFormatter::findFormattedLineSplitPoint() const
+	// determine where to split
+	size_t minCodeLength = 10;
+	splitPoint = maxSemi;
+	if (maxAndOr >= minCodeLength)
+		splitPoint = maxAndOr;
+	if (splitPoint < minCodeLength)
+		splitPoint = maxWhiteSpace;
+		// use maxParen instead if it is long enough
+		if (maxParen > splitPoint
+		        || maxParen >= maxCodeLength * .7)
+			splitPoint = maxParen;
+		// use maxComma instead if it is long enough
+		// increasing the multiplier causes more splits at whitespace
+		if (maxComma > splitPoint
+		        || maxComma >= maxCodeLength * .3)
+			splitPoint = maxComma;
+	// replace split point with first available break point
+		splitPoint = string::npos;
+		if (maxSemiPending > 0 && maxSemiPending < splitPoint)
+			splitPoint = maxSemiPending;
+		if (maxAndOrPending > 0 && maxAndOrPending < splitPoint)
+			splitPoint = maxAndOrPending;
+		if (maxCommaPending > 0 && maxCommaPending < splitPoint)
+			splitPoint = maxCommaPending;
+		if (maxParenPending > 0 && maxParenPending < splitPoint)
+			splitPoint = maxParenPending;
+		if (maxWhiteSpacePending > 0 && maxWhiteSpacePending < splitPoint)
+			splitPoint = maxWhiteSpacePending;
+		if (splitPoint == string::npos)
+			splitPoint = 0;
+	// if remaining line after split is too long
+	else if (formattedLine.length() - splitPoint > maxCodeLength)
+		// if end of the currentLine, find a new split point
+		size_t newCharNum;
+		if (!isWhiteSpace(currentChar) && isCharPotentialHeader(currentLine, charNum))
+			newCharNum = getCurrentWord(currentLine, charNum).length() + charNum;
+		else
+			newCharNum = charNum + 2;
+		if (newCharNum + 1 > currentLine.length())
+			// don't move splitPoint from before a conditional to after
+			if (maxWhiteSpace > splitPoint + 3)
+			if (maxParen > splitPoint)
+	return splitPoint;
+void ASFormatter::clearFormattedLineSplitPoints()
+	maxSemi = 0;
+	maxAndOr = 0;
+	maxComma = 0;
+	maxParen = 0;
+	maxWhiteSpace = 0;
+ * Check if a pointer symbol (->) follows on the currentLine.
+bool ASFormatter::pointerSymbolFollows() const
+	size_t peekNum = currentLine.find_first_not_of(" \t", charNum + 1);
+	if (peekNum == string::npos || currentLine.compare(peekNum, 2, "->") != 0)
+		return false;
+	return true;
+ * Compute the input checksum.
+ * This is called as an assert so it for is debug config only
+bool ASFormatter::computeChecksumIn(const string& currentLine_)
+	for (size_t i = 0; i < currentLine_.length(); i++)
+		if (!isWhiteSpace(currentLine_[i]))
+			checksumIn += currentLine_[i];
+	return true;
+ * Adjust the input checksum for deleted chars.
+bool ASFormatter::adjustChecksumIn(int adjustment)
+	checksumIn += adjustment;
+	return true;
+ * get the value of checksumIn for unit testing
+ * @return   checksumIn.
+size_t ASFormatter::getChecksumIn() const
+	return checksumIn;
+ * Compute the output checksum.
+ * This is called as an assert so it is for debug config only
+bool ASFormatter::computeChecksumOut(const string& beautifiedLine)
+	for (size_t i = 0; i < beautifiedLine.length(); i++)
+		if (!isWhiteSpace(beautifiedLine[i]))
+			checksumOut += beautifiedLine[i];
+	return true;
+ * Return isLineReady for the final check at end of file.
+bool ASFormatter::getIsLineReady() const
+	return isLineReady;
+ * get the value of checksumOut for unit testing
+ * @return   checksumOut.
+size_t ASFormatter::getChecksumOut() const
+	return checksumOut;
+ * Return the difference in checksums.
+ * If zero all is okay.
+int ASFormatter::getChecksumDiff() const
+	return checksumOut - checksumIn;
+// for unit testing
+int ASFormatter::getFormatterFileType() const
+	return formatterFileType;
+// Check if an operator follows the next word.
+// The next word must be a legal name.
+const string* ASFormatter::getFollowingOperator() const
+	// find next word
+	size_t nextNum = currentLine.find_first_not_of(" \t", charNum + 1);
+		return nullptr;
+	if (!isLegalNameChar(currentLine[nextNum]))
+		return nullptr;
+	// bypass next word and following spaces
+	while (nextNum < currentLine.length())
+		        && !isWhiteSpace(currentLine[nextNum]))
+			break;
+		nextNum++;
+	if (nextNum >= currentLine.length()
+	        || !isCharPotentialOperator(currentLine[nextNum])
+	        || currentLine[nextNum] == '/')		// comment
+		return nullptr;
+	const string* newOperator = ASBase::findOperator(currentLine, nextNum, operators);
+	return newOperator;
+// Check following data to determine if the current character is an array operator.
+bool ASFormatter::isArrayOperator() const
+	assert(currentChar == '*' || currentChar == '&' || currentChar == '^');
+	// find next word
+		return false;
+		return false;
+			break;
+		nextNum++;
+	// check for characters that indicate an operator
+	if (currentLine[nextNum] == ','
+	        || currentLine[nextNum] == '}'
+	        || currentLine[nextNum] == ')'
+	        || currentLine[nextNum] == '(')
+		return true;
+	return false;
+// Reset the flags that indicate various statement information.
+void ASFormatter::resetEndOfStatement()
+	foundQuestionMark = false;
+	foundNamespaceHeader = false;
+	foundClassHeader = false;
+	foundStructHeader = false;
+	foundInterfaceHeader = false;
+	foundPreDefinitionHeader = false;
+	foundPreCommandHeader = false;
+	foundPreCommandMacro = false;
+	foundTrailingReturnType = false;
+	foundCastOperator = false;
+	isInPotentialCalculation = false;
+	isSharpAccessor = false;
+	isSharpDelegate = false;
+	isInObjCMethodDefinition = false;
+	isImmediatelyPostObjCMethodPrefix = false;
+	isInObjCReturnType = false;
+	isInObjCParam = false;
+	isInObjCInterface = false;
+	isInObjCSelector = false;
+	isInEnum = false;
+	isInExternC = false;
+	elseHeaderFollowsComments = false;
+	returnTypeChecked = false;
+	nonInStatementBrace = 0;
+	while (!questionMarkStack->empty())
+		questionMarkStack->pop_back();
+// Find the colon alignment for Objective-C method definitions and method calls.
+int ASFormatter::findObjCColonAlignment() const
+	assert(currentChar == '+' || currentChar == '-' || currentChar == '[');
+	assert(getAlignMethodColon());
+	bool haveFirstColon = false;
+	bool foundMethodColon = false;
+	bool haveTernary = false;
+	int  sqBracketCount = 0;
+	int  colonAdjust = 0;
+	int  colonAlign = 0;
+	string nextLine_ = currentLine;
+	// peek next line
+	while (sourceIterator->hasMoreLines() || isFirstLine)
+		if (!isFirstLine)
+		// parse the line
+		haveFirstColon = false;
+		nextLine_ = ASBeautifier::trim(nextLine_);
+				continue;
+			if (isInComment_)
+					++i;
+				continue;
+				++i;
+				continue;
+			if (isInQuote_)
+				continue;
+				continue;
+				continue;
+			// process the current char
+			if ((nextLine_[i] == '{' && (currentChar == '-' || currentChar == '+'))
+			        || nextLine_[i] == ';')
+				goto EndOfWhileLoop;       // end of method definition
+			if (nextLine_[i] == ']')
+				--sqBracketCount;
+				if (sqBracketCount == 0)
+					goto EndOfWhileLoop;   // end of method call
+			if (nextLine_[i] == '[')
+				++sqBracketCount;
+			if (isFirstLine)	 // colon align does not include the first line
+				continue;
+			if (sqBracketCount > 1)
+				continue;
+			if (haveFirstColon)  // multiple colons per line
+				continue;
+			if (nextLine_[i] == '?')
+				haveTernary = true;
+				continue;
+			// compute colon adjustment
+			if (nextLine_[i] == ':')
+				if (haveTernary)
+					haveTernary = false;
+					continue;
+				haveFirstColon = true;
+				foundMethodColon = true;
+				if (shouldPadMethodColon)
+					int spacesStart;
+					for (spacesStart = i; spacesStart > 0; spacesStart--)
+						if (!isWhiteSpace(nextLine_[spacesStart - 1]))
+							break;
+					int spaces = i - spacesStart;
+					if (objCColonPadMode == COLON_PAD_ALL || objCColonPadMode == COLON_PAD_BEFORE)
+						colonAdjust = 1 - spaces;
+					else if (objCColonPadMode == COLON_PAD_NONE || objCColonPadMode == COLON_PAD_AFTER)
+						colonAdjust = 0 - spaces;
+				// compute alignment
+				int colonPosition = i + colonAdjust;
+				if (colonPosition > colonAlign)
+					colonAlign = colonPosition;
+EndOfWhileLoop:
+	if (!foundMethodColon)
+		colonAlign = -1;
+	return colonAlign;
+// pad an Objective-C method colon
+void ASFormatter::padObjCMethodColon()
+	assert(currentChar == ':');
+	int commentAdjust = 0;
+	if (objCColonPadMode == COLON_PAD_NONE
+	        || objCColonPadMode == COLON_PAD_AFTER
+	        || nextChar == ')')
+		// remove spaces before
+		for (int i = formattedLine.length() - 1; (i > -1) && isWhiteSpace(formattedLine[i]); i--)
+			formattedLine.erase(i);
+			--commentAdjust;
+	else
+		// pad space before
+		for (int i = formattedLine.length() - 1; (i > 0) && isWhiteSpace(formattedLine[i]); i--)
+			if (isWhiteSpace(formattedLine[i - 1]))
+				--commentAdjust;
+		if (formattedLine.length() > 0)
+			appendSpacePad();
+			formattedLine.back() = ' ';  // convert any tab to space
+	        || objCColonPadMode == COLON_PAD_BEFORE
+		// remove spaces after
+		size_t nextText = currentLine.find_first_not_of(" \t", charNum + 1);
+		if (nextText == string::npos)
+			nextText = currentLine.length();
+		int spaces = nextText - charNum - 1;
+		if (spaces > 0)
+			// do not use goForward here
+			currentLine.erase(charNum + 1, spaces);
+			spacePadNum -= spaces;
+	else
+		// pad space after
+		if (spaces == 0)
+			currentLine.insert(charNum + 1, 1, ' ');
+			spacePadNum += 1;
+		else if (spaces > 1)
+			currentLine.erase(charNum + 1, spaces - 1);
+			currentLine[charNum + 1] = ' ';  // convert any tab to space
+			spacePadNum -= spaces - 1;
+	spacePadNum += commentAdjust;
+// Remove the leading '*' from a comment line and indent to the next tab.
+void ASFormatter::stripCommentPrefix()
+	int firstChar = formattedLine.find_first_not_of(" \t");
+	if (firstChar < 0)
+		return;
+	if (isInCommentStartLine)
+		// comment opener must begin the line
+		if (formattedLine.compare(firstChar, 2, "/*") != 0)
+			return;
+		int commentOpener = firstChar;
+		// ignore single line comments
+		int commentEnd = formattedLine.find("*/", firstChar + 2);
+		if (commentEnd != -1)
+			return;
+		// first char after the comment opener must be at least one indent
+		int followingText = formattedLine.find_first_not_of(" \t", commentOpener + 2);
+		if (followingText < 0)
+			return;
+		if (formattedLine[followingText] == '*' || formattedLine[followingText] == '!')
+			followingText = formattedLine.find_first_not_of(" \t", followingText + 1);
+			return;
+		if (formattedLine[followingText] == '*')
+			return;
+		int indentLen = getIndentLength();
+		int followingTextIndent = followingText - commentOpener;
+		if (followingTextIndent < indentLen)
+			string stringToInsert(indentLen - followingTextIndent, ' ');
+			formattedLine.insert(followingText, stringToInsert);
+		return;
+	// comment body including the closer
+	if (formattedLine[firstChar] == '*')
+		if (formattedLine.compare(firstChar, 2, "*/") == 0)
+			// line starts with an end comment
+			formattedLine = "*/";
+		else
+			// build a new line with one indent
+			int secondChar = formattedLine.find_first_not_of(" \t", firstChar + 1);
+			if (secondChar < 0)
+				adjustChecksumIn(-'*');
+				return;
+			if (formattedLine[secondChar] == '*')
+				return;
+			// replace the leading '*'
+			// second char must be at least one indent
+			if (formattedLine.substr(0, secondChar).find('\t') != string::npos)
+				formattedLine.erase(firstChar, 1);
+			else
+				int spacesToInsert = 0;
+				if (secondChar >= indentLen)
+					spacesToInsert = secondChar;
+				else
+					spacesToInsert = indentLen;
+				formattedLine = string(spacesToInsert, ' ') + formattedLine.substr(secondChar);
+			// remove a trailing '*'
+			int lastChar = formattedLine.find_last_not_of(" \t");
+			if (lastChar > -1 && formattedLine[lastChar] == '*')
+				formattedLine[lastChar] = ' ';
+	else
+		// first char not a '*'
+		// first char must be at least one indent
+		if (formattedLine.substr(0, firstChar).find('\t') == string::npos)
+			if (firstChar < indentLen)
+				string stringToInsert(indentLen, ' ');
+				formattedLine = stringToInsert + formattedLine.substr(firstChar);
+}   // end namespace astyle
diff --git a/tools/astyle/ASLocalizer.cpp b/tools/astyle/ASLocalizer.cpp
new file mode 100755
index 0000000..caece11
--- /dev/null
+++ b/tools/astyle/ASLocalizer.cpp
@@ -0,0 +1,1166 @@
+// ASLocalizer.cpp
+// Copyright (c) 2018 by Jim Pattee <jimp03 at email.com>.
+// This code is licensed under the MIT License.
+// License.md describes the conditions under which this software may be distributed.
+// File encoding for this file is UTF-8 WITHOUT a byte order mark (BOM).
+//    русский     中文(简体)    日本語     한국의
+// Windows:
+// Add the required "Language" to the system.
+// The settings do NOT need to be changed to the added language.
+// Change the "Region" settings.
+// Change both the "Format" and the "Current Language..." settings.
+// A restart is required if the codepage has changed.
+//		Windows problems:
+//		Hindi    - no available locale, language pack removed
+//		Japanese - language pack install error
+//		Ukranian - displays a ? instead of i
+// Linux:
+// Change the LANG environment variable: LANG=fr_FR.UTF-8.
+// setlocale() will use the LANG environment variable on Linux.
+ *   To add a new language to this source module:
+ *   Add a new translation class to ASLocalizer.h.
+ *   Update the WinLangCode array in ASLocalizer.cpp.
+ *   Add the language code to setTranslationClass() in ASLocalizer.cpp.
+ *   Add the English-Translation pair to the constructor in ASLocalizer.cpp.
+// headers
+#include "ASLocalizer.h"
+#ifdef _WIN32
+	#include <windows.h>
+#endif
+#ifdef __VMS
+	#define __USE_STD_IOSTREAM 1
+	#include <assert>
+#else
+	#include <cassert>
+#endif
+#include <cstdio>
+#include <iostream>
+#include <clocale>		// needed by some compilers
+#include <cstdlib>
+#include <typeinfo>
+#ifdef _MSC_VER
+	#pragma warning(disable: 4996)  // secure version deprecation warnings
+#endif
+#ifdef __BORLANDC__
+	#pragma warn -8104	    // Local Static with constructor dangerous for multi-threaded apps
+#endif
+#ifdef __INTEL_COMPILER
+	#pragma warning(disable:  383)  // value copied to temporary, reference to temporary used
+	#pragma warning(disable:  981)  // operands are evaluated in unspecified order
+#endif
+#ifdef __clang__
+	#pragma clang diagnostic ignored "-Wdeprecated-declarations"  // wcstombs
+#endif
+namespace astyle {
+#ifndef ASTYLE_LIB
+// ASLocalizer class methods.
+ASLocalizer::ASLocalizer()
+// Set the locale information.
+	// set language default values to english (ascii)
+	// this will be used if a locale or a language cannot be found
+	m_localeName = "UNKNOWN";
+	m_langID = "en";
+	m_lcid = 0;
+	m_subLangID.clear();
+	m_translation = nullptr;
+	// Not all compilers support the C++ function locale::global(locale(""));
+	char* localeName = setlocale(LC_ALL, "");
+	if (localeName == nullptr)		// use the english (ascii) defaults
+		fprintf(stderr, "\n%s\n\n", "Cannot set native locale, reverting to English");
+		setTranslationClass();
+		return;
+	// set the class variables
+#ifdef _WIN32
+	size_t lcid = GetUserDefaultLCID();
+	setLanguageFromLCID(lcid);
+#else
+	setLanguageFromName(localeName);
+#endif
+ASLocalizer::~ASLocalizer()
+// Delete dynamically allocated memory.
+	delete m_translation;
+#ifdef _WIN32
+struct WinLangCode
+	size_t winLang;
+	char canonicalLang[3];
+static WinLangCode wlc[] =
+// primary language identifier http://msdn.microsoft.com/en-us/library/aa912554.aspx
+// sublanguage identifier http://msdn.microsoft.com/en-us/library/aa913256.aspx
+// language ID http://msdn.microsoft.com/en-us/library/ee797784%28v=cs.20%29.aspx
+	{ LANG_BULGARIAN,  "bg" },		//	bg-BG	1251
+	{ LANG_CHINESE,    "zh" },		//	zh-CHS, zh-CHT
+	{ LANG_DUTCH,      "nl" },		//	nl-NL	1252
+	{ LANG_ENGLISH,    "en" },		//	en-US	1252
+	{ LANG_ESTONIAN,   "et" },		//	et-EE
+	{ LANG_FINNISH,    "fi" },		//	fi-FI	1252
+	{ LANG_FRENCH,     "fr" },		//	fr-FR	1252
+	{ LANG_GERMAN,     "de" },		//	de-DE	1252
+	{ LANG_GREEK,      "el" },		//	el-GR	1253
+	{ LANG_HINDI,      "hi" },		//	hi-IN
+	{ LANG_HUNGARIAN,  "hu" },		//	hu-HU	1250
+	{ LANG_ITALIAN,    "it" },		//	it-IT	1252
+	{ LANG_JAPANESE,   "ja" },		//	ja-JP
+	{ LANG_KOREAN,     "ko" },		//	ko-KR
+	{ LANG_NORWEGIAN,  "nn" },		//	nn-NO	1252
+	{ LANG_POLISH,     "pl" },		//	pl-PL	1250
+	{ LANG_PORTUGUESE, "pt" },		//	pt-PT	1252
+	{ LANG_ROMANIAN,   "ro" },		//	ro-RO	1250
+	{ LANG_RUSSIAN,    "ru" },		//	ru-RU	1251
+	{ LANG_SPANISH,    "es" },		//	es-ES	1252
+	{ LANG_SWEDISH,    "sv" },		//	sv-SE	1252
+	{ LANG_UKRAINIAN,  "uk" },		//	uk-UA	1251
+void ASLocalizer::setLanguageFromLCID(size_t lcid)
+// Windows get the language to use from the user locale.
+// NOTE: GetUserDefaultLocaleName() gets nearly the same name as Linux.
+//       But it needs Windows Vista or higher.
+//       Same with LCIDToLocaleName().
+	m_lcid = lcid;
+	m_langID = "en";	// default to english
+	size_t lang = PRIMARYLANGID(LANGIDFROMLCID(m_lcid));
+	size_t sublang = SUBLANGID(LANGIDFROMLCID(m_lcid));
+	// find language in the wlc table
+	size_t count = sizeof(wlc) / sizeof(wlc[0]);
+	for (size_t i = 0; i < count; i++)
+		if (wlc[i].winLang == lang)
+			m_langID = wlc[i].canonicalLang;
+			break;
+	if (m_langID == "zh")
+		if (sublang == SUBLANG_CHINESE_SIMPLIFIED || sublang == SUBLANG_CHINESE_SINGAPORE)
+			m_subLangID = "CHS";
+		else
+			m_subLangID = "CHT";	// default
+#endif	// _WIN32
+string ASLocalizer::getLanguageID() const
+// Returns the language ID in m_langID.
+	return m_langID;
+const Translation* ASLocalizer::getTranslationClass() const
+// Returns the name of the translation class in m_translation.  Used for testing.
+	assert(m_translation);
+	return m_translation;
+void ASLocalizer::setLanguageFromName(const char* langID)
+// Linux set the language to use from the langID.
+// the language string has the following form
+//      lang[_LANG][.encoding][@modifier]
+// (see environ(5) in the Open Unix specification)
+// where lang is the primary language, LANG is a sublang/territory,
+// encoding is the charset to use and modifier "allows the user to select
+// a specific instance of localization data within a single category"
+// for example, the following strings are valid:
+//      fr
+//      fr_FR
+//      de_DE.iso88591
+//      de_DE at euro
+//      de_DE.iso88591 at euro
+	// the constants describing the format of lang_LANG locale string
+	m_lcid = 0;
+	string langStr = langID;
+	m_langID = langStr.substr(0, 2);
+	// need the sublang for chinese
+	if (m_langID == "zh" && langStr[2] == '_')
+		string subLang = langStr.substr(3, 2);
+		if (subLang == "CN" || subLang == "SG")
+		else
+const char* ASLocalizer::settext(const char* textIn) const
+// Call the settext class and return the value.
+	const string stringIn = textIn;
+	return m_translation->translate(stringIn).c_str();
+void ASLocalizer::setTranslationClass()
+// Return the required translation class.
+// Sets the class variable m_translation from the value of m_langID.
+// Get the language ID at http://msdn.microsoft.com/en-us/library/ee797784%28v=cs.20%29.aspx
+	assert(m_langID.length());
+	// delete previously set (--ascii option)
+	if (m_translation != nullptr)
+	if (m_langID == "bg")
+		m_translation = new Bulgarian;
+	else if (m_langID == "zh" && m_subLangID == "CHS")
+		m_translation = new ChineseSimplified;
+	else if (m_langID == "zh" && m_subLangID == "CHT")
+		m_translation = new ChineseTraditional;
+	else if (m_langID == "nl")
+		m_translation = new Dutch;
+	else if (m_langID == "en")
+		m_translation = new English;
+	else if (m_langID == "et")
+		m_translation = new Estonian;
+	else if (m_langID == "fi")
+		m_translation = new Finnish;
+	else if (m_langID == "fr")
+		m_translation = new French;
+	else if (m_langID == "de")
+		m_translation = new German;
+	else if (m_langID == "el")
+		m_translation = new Greek;
+	else if (m_langID == "hi")
+		m_translation = new Hindi;
+	else if (m_langID == "hu")
+		m_translation = new Hungarian;
+	else if (m_langID == "it")
+		m_translation = new Italian;
+	else if (m_langID == "ja")
+		m_translation = new Japanese;
+	else if (m_langID == "ko")
+		m_translation = new Korean;
+	else if (m_langID == "nn")
+		m_translation = new Norwegian;
+	else if (m_langID == "pl")
+		m_translation = new Polish;
+	else if (m_langID == "pt")
+		m_translation = new Portuguese;
+	else if (m_langID == "ro")
+		m_translation = new Romanian;
+	else if (m_langID == "ru")
+		m_translation = new Russian;
+	else if (m_langID == "es")
+		m_translation = new Spanish;
+	else if (m_langID == "sv")
+		m_translation = new Swedish;
+	else if (m_langID == "uk")
+		m_translation = new Ukrainian;
+	else	// default
+// Translation base class methods.
+void Translation::addPair(const string& english, const wstring& translated)
+// Add a string pair to the translation vector.
+	pair<string, wstring> entry(english, translated);
+	m_translation.emplace_back(entry);
+string Translation::convertToMultiByte(const wstring& wideStr) const
+// Convert wchar_t to a multibyte string using the currently assigned locale.
+// Return an empty string if an error occurs.
+	static bool msgDisplayed = false;
+	// get length of the output excluding the nullptr and validate the parameters
+	size_t mbLen = wcstombs(nullptr, wideStr.c_str(), 0);
+	if (mbLen == string::npos)
+		if (!msgDisplayed)
+			fprintf(stderr, "\n%s\n\n", "Cannot convert to multi-byte string, reverting to English");
+			msgDisplayed = true;
+		return "";
+	// convert the characters
+	char* mbStr = new (nothrow) char[mbLen + 1];
+	if (mbStr == nullptr)
+			fprintf(stderr, "\n%s\n\n", "Bad memory alloc for multi-byte string, reverting to English");
+		return "";
+	wcstombs(mbStr, wideStr.c_str(), mbLen + 1);
+	// return the string
+	string mbTranslation = mbStr;
+	delete[] mbStr;
+	return mbTranslation;
+string Translation::getTranslationString(size_t i) const
+// Return the translation ascii value. Used for testing.
+	if (i >= m_translation.size())
+		return string();
+	return m_translation[i].first;
+size_t Translation::getTranslationVectorSize() const
+// Return the translation vector size.  Used for testing.
+	return m_translation.size();
+bool Translation::getWideTranslation(const string& stringIn, wstring& wideOut) const
+// Get the wide translation string. Used for testing.
+	for (size_t i = 0; i < m_translation.size(); i++)
+		if (m_translation[i].first == stringIn)
+			wideOut = m_translation[i].second;
+			return true;
+	// not found
+	wideOut = L"";
+	return false;
+string& Translation::translate(const string& stringIn) const
+// Translate a string.
+// Return a mutable string so the method can have a "const" designation.
+// This allows "settext" to be called from a "const" method.
+	m_mbTranslation.clear();
+			m_mbTranslation = convertToMultiByte(m_translation[i].second);
+			break;
+	// not found, return english
+	if (m_mbTranslation.empty())
+		m_mbTranslation = stringIn;
+	return m_mbTranslation;
+// Translation class methods.
+// These classes have only a constructor which builds the language vector.
+Bulgarian::Bulgarian()	// български
+// build the translation vector in the Translation base class
+	addPair("Formatted  %s\n", L"Форматиран  %s\n");		// should align with unchanged
+	addPair("Unchanged  %s\n", L"Непроменен  %s\n");		// should align with formatted
+	addPair("Directory  %s\n", L"директория  %s\n");
+	addPair("Default option file  %s\n", L"Файл с опции по подразбиране  %s\n");
+	addPair("Project option file  %s\n", L"Файл с опции за проекта  %s\n");
+	addPair("Exclude  %s\n", L"Изключвам  %s\n");
+	addPair("Exclude (unmatched)  %s\n", L"Изключване (несравнимо)  %s\n");
+	addPair(" %s formatted   %s unchanged   ", L" %s форматиран   %s hепроменен   ");
+	addPair(" seconds   ", L" секунди   ");
+	addPair("%d min %d sec   ", L"%d мин %d сек   ");
+	addPair("%s lines\n", L"%s линии\n");
+	addPair("Opening HTML documentation %s\n", L"Откриване HTML документация %s\n");
+	addPair("Invalid default options:", L"Невалидни опции по подразбиране:");
+	addPair("Invalid project options:", L"Невалидни опции за проекти:");
+	addPair("Invalid command line options:", L"Невалидни опции за командния ред:");
+	addPair("For help on options type 'astyle -h'", L"За помощ относно възможностите тип 'astyle -h'");
+	addPair("Cannot open default option file", L"Не може да се отвори файлът с опции по подразбиране");
+	addPair("Cannot open project option file", L"Не може да се отвори файла с опции за проекта");
+	addPair("Cannot open directory", L"Не може да се отвори директория");
+	addPair("Cannot open HTML file %s\n", L"Не може да се отвори HTML файл %s\n");
+	addPair("Command execute failure", L"Command изпълни недостатъчност");
+	addPair("Command is not installed", L"Command не е инсталиран");
+	addPair("Missing filename in %s\n", L"Липсва името на файла в %s\n");
+	addPair("Recursive option with no wildcard", L"Рекурсивно опция, без маска");
+	addPair("Did you intend quote the filename", L"Знаете ли намерение да цитирам името на файла");
+	addPair("No file to process %s\n", L"Не файл за обработка %s\n");
+	addPair("Did you intend to use --recursive", L"Знаете ли възнамерявате да използвате --recursive");
+	addPair("Cannot process UTF-32 encoding", L"Не може да са UTF-32 кодиране");
+	addPair("Artistic Style has terminated\n", L"Artistic Style е прекратено\n");
+ChineseSimplified::ChineseSimplified()	// 中文(简体)
+	addPair("Formatted  %s\n", L"格式化  %s\n");		// should align with unchanged
+	addPair("Unchanged  %s\n", L"未改变  %s\n");		// should align with formatted
+	addPair("Directory  %s\n", L"目录  %s\n");
+	addPair("Default option file  %s\n", L"默认选项文件  %s\n");
+	addPair("Project option file  %s\n", L"项目选项文件  %s\n");
+	addPair("Exclude  %s\n", L"排除  %s\n");
+	addPair("Exclude (unmatched)  %s\n", L"排除(无匹配项)  %s\n");
+	addPair(" %s formatted   %s unchanged   ", L" %s 格式化   %s 未改变   ");
+	addPair(" seconds   ", L" 秒   ");
+	addPair("%d min %d sec   ", L"%d 分 %d 秒   ");
+	addPair("%s lines\n", L"%s 行\n");
+	addPair("Opening HTML documentation %s\n", L"打开HTML文档 %s\n");
+	addPair("Invalid default options:", L"默认选项无效:");
+	addPair("Invalid project options:", L"项目选项无效:");
+	addPair("Invalid command line options:", L"无效的命令行选项:");
+	addPair("For help on options type 'astyle -h'", L"输入 'astyle -h' 以获得有关命令行的帮助");
+	addPair("Cannot open default option file", L"无法打开默认选项文件");
+	addPair("Cannot open project option file", L"无法打开项目选项文件");
+	addPair("Cannot open directory", L"无法打开目录");
+	addPair("Cannot open HTML file %s\n", L"无法打开HTML文件 %s\n");
+	addPair("Command execute failure", L"执行命令失败");
+	addPair("Command is not installed", L"未安装命令");
+	addPair("Missing filename in %s\n", L"在%s缺少文件名\n");
+	addPair("Recursive option with no wildcard", L"递归选项没有通配符");
+	addPair("Did you intend quote the filename", L"你打算引用文件名");
+	addPair("No file to process %s\n", L"没有文件可处理 %s\n");
+	addPair("Did you intend to use --recursive", L"你打算使用 --recursive");
+	addPair("Cannot process UTF-32 encoding", L"不能处理UTF-32编码");
+	addPair("Artistic Style has terminated\n", L"Artistic Style 已经终止运行\n");
+ChineseTraditional::ChineseTraditional()	// 中文(繁體)
+	addPair("Unchanged  %s\n", L"未改變  %s\n");		// should align with formatted
+	addPair("Directory  %s\n", L"目錄  %s\n");
+	addPair("Default option file  %s\n", L"默認選項文件  %s\n");
+	addPair("Project option file  %s\n", L"項目選項文件  %s\n");
+	addPair("Exclude (unmatched)  %s\n", L"排除(無匹配項)  %s\n");
+	addPair(" %s formatted   %s unchanged   ", L" %s 格式化   %s 未改變   ");
+	addPair("Opening HTML documentation %s\n", L"打開HTML文檔 %s\n");
+	addPair("Invalid default options:", L"默認選項無效:");
+	addPair("Invalid project options:", L"項目選項無效:");
+	addPair("Invalid command line options:", L"無效的命令行選項:");
+	addPair("For help on options type 'astyle -h'", L"輸入'astyle -h'以獲得有關命令行的幫助:");
+	addPair("Cannot open default option file", L"無法打開默認選項文件");
+	addPair("Cannot open project option file", L"無法打開項目選項文件");
+	addPair("Cannot open directory", L"無法打開目錄");
+	addPair("Cannot open HTML file %s\n", L"無法打開HTML文件 %s\n");
+	addPair("Command execute failure", L"執行命令失敗");
+	addPair("Command is not installed", L"未安裝命令");
+	addPair("Recursive option with no wildcard", L"遞歸選項沒有通配符");
+	addPair("No file to process %s\n", L"沒有文件可處理 %s\n");
+	addPair("Cannot process UTF-32 encoding", L"不能處理UTF-32編碼");
+	addPair("Artistic Style has terminated\n", L"Artistic Style 已經終止運行\n");
+Dutch::Dutch()	// Nederlandse
+	addPair("Formatted  %s\n", L"Geformatteerd  %s\n");	// should align with unchanged
+	addPair("Unchanged  %s\n", L"Onveranderd    %s\n");	// should align with formatted
+	addPair("Directory  %s\n", L"Directory  %s\n");
+	addPair("Default option file  %s\n", L"Standaard optie bestand  %s\n");
+	addPair("Project option file  %s\n", L"Project optie bestand  %s\n");
+	addPair("Exclude  %s\n", L"Uitsluiten  %s\n");
+	addPair("Exclude (unmatched)  %s\n", L"Uitgesloten (ongeëvenaarde)  %s\n");
+	addPair(" %s formatted   %s unchanged   ", L" %s geformatteerd   %s onveranderd   ");
+	addPair(" seconds   ", L" seconden   ");
+	addPair("%d min %d sec   ", L"%d min %d sec   ");
+	addPair("%s lines\n", L"%s lijnen\n");
+	addPair("Opening HTML documentation %s\n", L"Het openen van HTML-documentatie %s\n");
+	addPair("Invalid default options:", L"Ongeldige standaardopties:");
+	addPair("Invalid project options:", L"Ongeldige projectopties:");
+	addPair("Invalid command line options:", L"Ongeldige command line opties:");
+	addPair("For help on options type 'astyle -h'", L"Voor hulp bij 'astyle-h' opties het type");
+	addPair("Cannot open default option file", L"Kan het standaardoptiesbestand niet openen");
+	addPair("Cannot open project option file", L"Kan het project optie bestand niet openen");
+	addPair("Cannot open directory", L"Kan niet open directory");
+	addPair("Cannot open HTML file %s\n", L"Kan HTML-bestand niet openen %s\n");
+	addPair("Command execute failure", L"Voeren commando falen");
+	addPair("Command is not installed", L"Command is niet geïnstalleerd");
+	addPair("Missing filename in %s\n", L"Ontbrekende bestandsnaam in %s\n");
+	addPair("Recursive option with no wildcard", L"Recursieve optie met geen wildcard");
+	addPair("Did you intend quote the filename", L"Heeft u van plan citaat van de bestandsnaam");
+	addPair("No file to process %s\n", L"Geen bestand te verwerken %s\n");
+	addPair("Did you intend to use --recursive", L"Hebt u van plan bent te gebruiken --recursive");
+	addPair("Cannot process UTF-32 encoding", L"Kan niet verwerken UTF-32 codering");
+	addPair("Artistic Style has terminated\n", L"Artistic Style heeft beëindigd\n");
+English::English()
+// this class is NOT translated
+Estonian::Estonian()	// Eesti
+	addPair("Formatted  %s\n", L"Formaadis  %s\n");		// should align with unchanged
+	addPair("Unchanged  %s\n", L"Muutumatu  %s\n");		// should align with formatted
+	addPair("Directory  %s\n", L"Kataloog  %s\n");
+	addPair("Default option file  %s\n", L"Vaikefunktsioonifail  %s\n");
+	addPair("Project option file  %s\n", L"Projekti valiku fail  %s\n");
+	addPair("Exclude  %s\n", L"Välista  %s\n");
+	addPair("Exclude (unmatched)  %s\n", L"Välista (tasakaalustamata)  %s\n");
+	addPair(" %s formatted   %s unchanged   ", L" %s formaadis   %s muutumatu   ");
+	addPair(" seconds   ", L" sekundit   ");
+	addPair("%d min %d sec   ", L"%d min %d sek   ");
+	addPair("%s lines\n", L"%s read\n");
+	addPair("Opening HTML documentation %s\n", L"Avamine HTML dokumentatsioon %s\n");
+	addPair("Invalid default options:", L"Vaikevalikud on sobimatud:");
+	addPair("Invalid project options:", L"Projekti valikud on sobimatud:");
+	addPair("Invalid command line options:", L"Vale käsureavõtmetega:");
+	addPair("For help on options type 'astyle -h'", L"Abiks võimaluste tüüp 'astyle -h'");
+	addPair("Cannot open default option file", L"Vaikimisi valitud faili ei saa avada");
+	addPair("Cannot open project option file", L"Projektivaliku faili ei saa avada");
+	addPair("Cannot open directory", L"Ei saa avada kataloogi");
+	addPair("Cannot open HTML file %s\n", L"Ei saa avada HTML-faili %s\n");
+	addPair("Command execute failure", L"Käsk täita rike");
+	addPair("Command is not installed", L"Käsk ei ole paigaldatud");
+	addPair("Missing filename in %s\n", L"Kadunud failinimi %s\n");
+	addPair("Recursive option with no wildcard", L"Rekursiivne võimalus ilma metamärgi");
+	addPair("Did you intend quote the filename", L"Kas te kavatsete tsiteerida failinimi");
+	addPair("No file to process %s\n", L"No faili töötlema %s\n");
+	addPair("Did you intend to use --recursive", L"Kas te kavatsete kasutada --recursive");
+	addPair("Cannot process UTF-32 encoding", L"Ei saa töödelda UTF-32 kodeeringus");
+	addPair("Artistic Style has terminated\n", L"Artistic Style on lõpetatud\n");
+Finnish::Finnish()	// Suomeksi
+	addPair("Formatted  %s\n", L"Muotoiltu  %s\n");	// should align with unchanged
+	addPair("Unchanged  %s\n", L"Ennallaan  %s\n");	// should align with formatted
+	addPair("Default option file  %s\n", L"Oletusasetustiedosto  %s\n");
+	addPair("Project option file  %s\n", L"Projektin valintatiedosto  %s\n");
+	addPair("Exclude  %s\n", L"Sulkea  %s\n");
+	addPair("Exclude (unmatched)  %s\n", L"Sulkea (verraton)  %s\n");
+	addPair(" %s formatted   %s unchanged   ", L" %s muotoiltu   %s ennallaan   ");
+	addPair(" seconds   ", L" sekuntia   ");
+	addPair("%s lines\n", L"%s linjat\n");
+	addPair("Opening HTML documentation %s\n", L"Avaaminen HTML asiakirjat %s\n");
+	addPair("Invalid default options:", L"Virheelliset oletusasetukset:");
+	addPair("Invalid project options:", L"Virheelliset hankevalinnat:");
+	addPair("Invalid command line options:", L"Virheellinen komentorivin:");
+	addPair("For help on options type 'astyle -h'", L"Apua vaihtoehdoista tyyppi 'astyle -h'");
+	addPair("Cannot open default option file", L"Et voi avata oletusasetustiedostoa");
+	addPair("Cannot open project option file", L"Projektin asetustiedostoa ei voi avata");
+	addPair("Cannot open directory", L"Ei Open Directory");
+	addPair("Cannot open HTML file %s\n", L"Ei voi avata HTML-tiedoston %s\n");
+	addPair("Command execute failure", L"Suorita komento vika");
+	addPair("Command is not installed", L"Komento ei ole asennettu");
+	addPair("Missing filename in %s\n", L"Puuttuvat tiedostonimi %s\n");
+	addPair("Recursive option with no wildcard", L"Rekursiivinen vaihtoehto ilman wildcard");
+	addPair("Did you intend quote the filename", L"Oletko aio lainata tiedostonimi");
+	addPair("No file to process %s\n", L"Ei tiedostoa käsitellä %s\n");
+	addPair("Did you intend to use --recursive", L"Oliko aiot käyttää --recursive");
+	addPair("Cannot process UTF-32 encoding", L"Ei voi käsitellä UTF-32 koodausta");
+	addPair("Artistic Style has terminated\n", L"Artistic Style on päättynyt\n");
+French::French()	// Française
+	addPair("Formatted  %s\n", L"Formaté    %s\n");	// should align with unchanged
+	addPair("Unchanged  %s\n", L"Inchangée  %s\n");	// should align with formatted
+	addPair("Directory  %s\n", L"Répertoire  %s\n");
+	addPair("Default option file  %s\n", L"Fichier d'option par défaut  %s\n");
+	addPair("Project option file  %s\n", L"Fichier d'option de projet  %s\n");
+	addPair("Exclude  %s\n", L"Exclure  %s\n");
+	addPair("Exclude (unmatched)  %s\n", L"Exclure (non appariés)  %s\n");
+	addPair(" %s formatted   %s unchanged   ", L" %s formaté   %s inchangée   ");
+	addPair(" seconds   ", L" seconde   ");
+	addPair("%s lines\n", L"%s lignes\n");
+	addPair("Opening HTML documentation %s\n", L"Ouverture documentation HTML %s\n");
+	addPair("Invalid default options:", L"Options par défaut invalides:");
+	addPair("Invalid project options:", L"Options de projet non valides:");
+	addPair("Invalid command line options:", L"Blancs options ligne de commande:");
+	addPair("For help on options type 'astyle -h'", L"Pour de l'aide sur les options tapez 'astyle -h'");
+	addPair("Cannot open default option file", L"Impossible d'ouvrir le fichier d'option par défaut");
+	addPair("Cannot open project option file", L"Impossible d'ouvrir le fichier d'option de projet");
+	addPair("Cannot open directory", L"Impossible d'ouvrir le répertoire");
+	addPair("Cannot open HTML file %s\n", L"Impossible d'ouvrir le fichier HTML %s\n");
+	addPair("Command execute failure", L"Exécuter échec de la commande");
+	addPair("Command is not installed", L"Commande n'est pas installé");
+	addPair("Missing filename in %s\n", L"Nom de fichier manquant dans %s\n");
+	addPair("Recursive option with no wildcard", L"Option récursive sans joker");
+	addPair("Did you intend quote the filename", L"Avez-vous l'intention de citer le nom de fichier");
+	addPair("No file to process %s\n", L"Aucun fichier à traiter %s\n");
+	addPair("Did you intend to use --recursive", L"Avez-vous l'intention d'utiliser --recursive");
+	addPair("Cannot process UTF-32 encoding", L"Impossible de traiter codage UTF-32");
+	addPair("Artistic Style has terminated\n", L"Artistic Style a mis fin\n");
+German::German()	// Deutsch
+	addPair("Formatted  %s\n", L"Formatiert   %s\n");	// should align with unchanged
+	addPair("Unchanged  %s\n", L"Unverändert  %s\n");	// should align with formatted
+	addPair("Directory  %s\n", L"Verzeichnis  %s\n");
+	addPair("Default option file  %s\n", L"Standard-Optionsdatei  %s\n");
+	addPair("Project option file  %s\n", L"Projektoptionsdatei  %s\n");
+	addPair("Exclude  %s\n", L"Ausschließen  %s\n");
+	addPair("Exclude (unmatched)  %s\n", L"Ausschließen (unerreichte)  %s\n");
+	addPair(" %s formatted   %s unchanged   ", L" %s formatiert   %s unverändert   ");
+	addPair(" seconds   ", L" sekunden   ");
+	addPair("%s lines\n", L"%s linien\n");
+	addPair("Opening HTML documentation %s\n", L"Öffnen HTML-Dokumentation %s\n");
+	addPair("Invalid default options:", L"Ungültige Standardoptionen:");
+	addPair("Invalid project options:", L"Ungültige Projektoptionen:");
+	addPair("Invalid command line options:", L"Ungültige Kommandozeilen-Optionen:");
+	addPair("For help on options type 'astyle -h'", L"Für Hilfe zu den Optionen geben Sie 'astyle -h'");
+	addPair("Cannot open default option file", L"Die Standardoptionsdatei kann nicht geöffnet werden");
+	addPair("Cannot open project option file", L"Die Projektoptionsdatei kann nicht geöffnet werden");
+	addPair("Cannot open directory", L"Kann nicht geöffnet werden Verzeichnis");
+	addPair("Cannot open HTML file %s\n", L"Kann nicht öffnen HTML-Datei %s\n");
+	addPair("Command execute failure", L"Execute Befehl Scheitern");
+	addPair("Command is not installed", L"Befehl ist nicht installiert");
+	addPair("Missing filename in %s\n", L"Missing in %s Dateiname\n");
+	addPair("Recursive option with no wildcard", L"Rekursive Option ohne Wildcard");
+	addPair("Did you intend quote the filename", L"Haben Sie die Absicht Inhalte der Dateiname");
+	addPair("No file to process %s\n", L"Keine Datei zu verarbeiten %s\n");
+	addPair("Did you intend to use --recursive", L"Haben Sie verwenden möchten --recursive");
+	addPair("Cannot process UTF-32 encoding", L"Nicht verarbeiten kann UTF-32 Codierung");
+	addPair("Artistic Style has terminated\n", L"Artistic Style ist beendet\n");
+Greek::Greek()	// ελληνικά
+	addPair("Formatted  %s\n", L"Διαμορφωμένη  %s\n");	// should align with unchanged
+	addPair("Unchanged  %s\n", L"Αμετάβλητος   %s\n");	// should align with formatted
+	addPair("Directory  %s\n", L"Κατάλογος  %s\n");
+	addPair("Default option file  %s\n", L"Προεπιλεγμένο αρχείο επιλογών  %s\n");
+	addPair("Project option file  %s\n", L"Αρχείο επιλογής έργου  %s\n");
+	addPair("Exclude  %s\n", L"Αποκλείω  %s\n");
+	addPair(" %s formatted   %s unchanged   ", L" %s σχηματοποιημένη   %s αμετάβλητες   ");
+	addPair(" seconds   ", L" δευτερόλεπτα   ");
+	addPair("%d min %d sec   ", L"%d λεπ %d δευ   ");
+	addPair("%s lines\n", L"%s γραμμές\n");
+	addPair("Opening HTML documentation %s\n", L"Εγκαίνια έγγραφα HTML %s\n");
+	addPair("Invalid default options:", L"Μη έγκυρες επιλογές προεπιλογής:");
+	addPair("Invalid project options:", L"Μη έγκυρες επιλογές έργου:");
+	addPair("Invalid command line options:", L"Μη έγκυρη επιλογές γραμμής εντολών:");
+	addPair("For help on options type 'astyle -h'", L"Για βοήθεια σχετικά με το είδος επιλογές 'astyle -h'");
+	addPair("Cannot open default option file", L"Δεν είναι δυνατό να ανοίξει το προεπιλεγμένο αρχείο επιλογών");
+	addPair("Cannot open project option file", L"Δεν είναι δυνατό να ανοίξει το αρχείο επιλογής έργου");
+	addPair("Cannot open directory", L"Δεν μπορείτε να ανοίξετε τον κατάλογο");
+	addPair("Cannot open HTML file %s\n", L"Δεν μπορείτε να ανοίξετε το αρχείο HTML %s\n");
+	addPair("Command execute failure", L"Εντολή να εκτελέσει την αποτυχία");
+	addPair("Command is not installed", L"Η εντολή δεν έχει εγκατασταθεί");
+	addPair("Missing filename in %s\n", L"Λείπει το όνομα αρχείου σε %s\n");
+	addPair("Recursive option with no wildcard", L"Αναδρομικές επιλογή χωρίς μπαλαντέρ");
+	addPair("Did you intend quote the filename", L"Μήπως σκοπεύετε να αναφέρετε το όνομα του αρχείου");
+	addPair("No file to process %s\n", L"Δεν υπάρχει αρχείο για την επεξεργασία %s\n");
+	addPair("Did you intend to use --recursive", L"Μήπως σκοπεύετε να χρησιμοποιήσετε --recursive");
+	addPair("Cannot process UTF-32 encoding", L"δεν μπορεί να επεξεργαστεί UTF-32 κωδικοποίηση");
+	addPair("Artistic Style has terminated\n", L"Artistic Style έχει λήξει\n");
+Hindi::Hindi()	// हिन्दी
+	// NOTE: Scintilla based editors (CodeBlocks) cannot always edit Hindi.
+	//       Use Visual Studio instead.
+	addPair("Formatted  %s\n", L"स्वरूपित किया  %s\n");	// should align with unchanged
+	addPair("Unchanged  %s\n", L"अपरिवर्तित     %s\n");	// should align with formatted
+	addPair("Directory  %s\n", L"निर्देशिका  %s\n");
+	addPair("Default option file  %s\n", L"डिफ़ॉल्ट विकल्प फ़ाइल  %s\n");
+	addPair("Project option file  %s\n", L"प्रोजेक्ट विकल्प फ़ाइल  %s\n");
+	addPair("Exclude  %s\n", L"निकालना  %s\n");
+	addPair("Exclude (unmatched)  %s\n", L"अपवर्जित (बेजोड़)  %s\n");
+	addPair(" %s formatted   %s unchanged   ", L" %s स्वरूपित किया   %s अपरिवर्तित   ");
+	addPair(" seconds   ", L" सेकंड   ");
+	addPair("%d min %d sec   ", L"%d मिनट %d सेकंड   ");
+	addPair("%s lines\n", L"%s लाइनों\n");
+	addPair("Opening HTML documentation %s\n", L"एचटीएमएल प्रलेखन खोलना %s\n");
+	addPair("Invalid default options:", L"अमान्य डिफ़ॉल्ट विकल्प:");
+	addPair("Invalid project options:", L"अमान्य प्रोजेक्ट विकल्प:");
+	addPair("Invalid command line options:", L"कमांड लाइन विकल्प अवैध:");
+	addPair("For help on options type 'astyle -h'", L"विकल्पों पर मदद के लिए प्रकार 'astyle -h'");
+	addPair("Cannot open default option file", L"डिफ़ॉल्ट विकल्प फ़ाइल नहीं खोल सकता");
+	addPair("Cannot open project option file", L"परियोजना विकल्प फ़ाइल नहीं खोल सकता");
+	addPair("Cannot open directory", L"निर्देशिका नहीं खोल सकता");
+	addPair("Cannot open HTML file %s\n", L"HTML फ़ाइल नहीं खोल सकता %s\n");
+	addPair("Command execute failure", L"आदेश विफलता निष्पादित");
+	addPair("Command is not installed", L"कमान स्थापित नहीं है");
+	addPair("Missing filename in %s\n", L"लापता में फ़ाइलनाम %s\n");
+	addPair("Recursive option with no wildcard", L"कोई वाइल्डकार्ड साथ पुनरावर्ती विकल्प");
+	addPair("Did you intend quote the filename", L"क्या आप बोली फ़ाइलनाम का इरादा");
+	addPair("No file to process %s\n", L"कोई फ़ाइल %s प्रक्रिया के लिए\n");
+	addPair("Did you intend to use --recursive", L"क्या आप उपयोग करना चाहते हैं --recursive");
+	addPair("Cannot process UTF-32 encoding", L"UTF-32 कूटबन्धन प्रक्रिया नहीं कर सकते");
+	addPair("Artistic Style has terminated\n", L"Artistic Style समाप्त किया है\n");
+Hungarian::Hungarian()	// Magyar
+	addPair("Formatted  %s\n", L"Formázott    %s\n");	// should align with unchanged
+	addPair("Unchanged  %s\n", L"Változatlan  %s\n");	// should align with formatted
+	addPair("Directory  %s\n", L"Címjegyzék  %s\n");
+	addPair("Default option file  %s\n", L"Alapértelmezett beállítási fájl  %s\n");
+	addPair("Project option file  %s\n", L"Projekt opciófájl  %s\n");
+	addPair("Exclude  %s\n", L"Kizár  %s\n");
+	addPair("Exclude (unmatched)  %s\n", L"Escludere (senza pari)  %s\n");
+	addPair(" %s formatted   %s unchanged   ", L" %s formázott   %s változatlan   ");
+	addPair(" seconds   ", L" másodperc   ");
+	addPair("%d min %d sec   ", L"%d jeg %d más   ");
+	addPair("%s lines\n", L"%s vonalak\n");
+	addPair("Opening HTML documentation %s\n", L"Nyitó HTML dokumentáció %s\n");
+	addPair("Invalid default options:", L"Érvénytelen alapértelmezett beállítások:");
+	addPair("Invalid project options:", L"Érvénytelen projektbeállítások:");
+	addPair("Invalid command line options:", L"Érvénytelen parancssori opciók:");
+	addPair("For help on options type 'astyle -h'", L"Ha segítségre van lehetőség típus 'astyle-h'");
+	addPair("Cannot open default option file", L"Nem lehet megnyitni az alapértelmezett beállítási fájlt");
+	addPair("Cannot open project option file", L"Nem lehet megnyitni a projekt opció fájlt");
+	addPair("Cannot open directory", L"Nem lehet megnyitni könyvtár");
+	addPair("Cannot open HTML file %s\n", L"Nem lehet megnyitni a HTML fájlt %s\n");
+	addPair("Command execute failure", L"Command végre hiba");
+	addPair("Command is not installed", L"Parancs nincs telepítve");
+	addPair("Missing filename in %s\n", L"Hiányzó fájlnév %s\n");
+	addPair("Recursive option with no wildcard", L"Rekurzív kapcsolót nem wildcard");
+	addPair("Did you intend quote the filename", L"Esetleg kívánja idézni a fájlnév");
+	addPair("No file to process %s\n", L"Nincs fájl feldolgozása %s\n");
+	addPair("Did you intend to use --recursive", L"Esetleg a használni kívánt --recursive");
+	addPair("Cannot process UTF-32 encoding", L"Nem tudja feldolgozni UTF-32 kódolással");
+	addPair("Artistic Style has terminated\n", L"Artistic Style megszűnt\n");
+Italian::Italian()	// Italiano
+	addPair("Formatted  %s\n", L"Formattata  %s\n");	// should align with unchanged
+	addPair("Unchanged  %s\n", L"Immutato    %s\n");	// should align with formatted
+	addPair("Directory  %s\n", L"Elenco  %s\n");
+	addPair("Default option file  %s\n", L"File di opzione predefinito  %s\n");
+	addPair("Project option file  %s\n", L"File di opzione del progetto  %s\n");
+	addPair("Exclude  %s\n", L"Escludere  %s\n");
+	addPair(" %s formatted   %s unchanged   ", L" %s ormattata   %s immutato   ");
+	addPair(" seconds   ", L" secondo   ");
+	addPair("%d min %d sec   ", L"%d min %d seg   ");
+	addPair("%s lines\n", L"%s linee\n");
+	addPair("Opening HTML documentation %s\n", L"Apertura di documenti HTML %s\n");
+	addPair("Invalid default options:", L"Opzioni di default non valide:");
+	addPair("Invalid project options:", L"Opzioni di progetto non valide:");
+	addPair("Invalid command line options:", L"Opzioni della riga di comando non valido:");
+	addPair("For help on options type 'astyle -h'", L"Per informazioni sulle opzioni di tipo 'astyle-h'");
+	addPair("Cannot open default option file", L"Impossibile aprire il file di opzione predefinito");
+	addPair("Cannot open project option file", L"Impossibile aprire il file di opzione del progetto");
+	addPair("Cannot open directory", L"Impossibile aprire la directory");
+	addPair("Cannot open HTML file %s\n", L"Impossibile aprire il file HTML %s\n");
+	addPair("Command execute failure", L"Esegui fallimento comando");
+	addPair("Command is not installed", L"Il comando non è installato");
+	addPair("Missing filename in %s\n", L"Nome del file mancante in %s\n");
+	addPair("Recursive option with no wildcard", L"Opzione ricorsiva senza jolly");
+	addPair("Did you intend quote the filename", L"Avete intenzione citare il nome del file");
+	addPair("No file to process %s\n", L"Nessun file al processo %s\n");
+	addPair("Did you intend to use --recursive", L"Hai intenzione di utilizzare --recursive");
+	addPair("Cannot process UTF-32 encoding", L"Non è possibile processo di codifica UTF-32");
+	addPair("Artistic Style has terminated\n", L"Artistic Style ha terminato\n");
+Japanese::Japanese()	// 日本語
+	addPair("Formatted  %s\n", L"フォーマット済みの  %s\n");		// should align with unchanged
+	addPair("Unchanged  %s\n", L"変わりません        %s\n");		// should align with formatted
+	addPair("Directory  %s\n", L"ディレクトリ  %s\n");
+	addPair("Default option file  %s\n", L"デフォルトオプションファイル  %s\n");
+	addPair("Project option file  %s\n", L"プロジェクトオプションファイル  %s\n");
+	addPair("Exclude  %s\n", L"除外する  %s\n");
+	addPair("Exclude (unmatched)  %s\n", L"除外する(一致しません)  %s\n");
+	addPair(" %s formatted   %s unchanged   ", L" %s フフォーマット済みの   %s 変わりません   ");
+	addPair("%s lines\n", L"%s ライン\n");
+	addPair("Opening HTML documentation %s\n", L"オープニングHTMLドキュメント %s\n");
+	addPair("Invalid default options:", L"無効なデフォルトオプション:");
+	addPair("Invalid project options:", L"無効なプロジェクトオプション:");
+	addPair("Invalid command line options:", L"無効なコマンドラインオプション:");
+	addPair("For help on options type 'astyle -h'", L"コオプションの種類のヘルプについて'astyle- h'を入力してください");
+	addPair("Cannot open default option file", L"デフォルトのオプションファイルを開くことができません");
+	addPair("Cannot open project option file", L"プロジェクトオプションファイルを開くことができません");
+	addPair("Cannot open directory", L"ディレクトリを開くことができません。");
+	addPair("Cannot open HTML file %s\n", L"HTMLファイルを開くことができません %s\n");
+	addPair("Command execute failure", L"コマンドが失敗を実行します");
+	addPair("Command is not installed", L"コマンドがインストールされていません");
+	addPair("Missing filename in %s\n", L"%s で、ファイル名がありません\n");
+	addPair("Recursive option with no wildcard", L"無ワイルドカードを使用して再帰的なオプション");
+	addPair("Did you intend quote the filename", L"あなたはファイル名を引用するつもりでした");
+	addPair("No file to process %s\n", L"いいえファイルは処理しないように %s\n");
+	addPair("Did you intend to use --recursive", L"あなたは--recursive使用するつもりでした");
+	addPair("Cannot process UTF-32 encoding", L"UTF - 32エンコーディングを処理できません");
+	addPair("Artistic Style has terminated\n", L"Artistic Style 終了しました\n");
+Korean::Korean()	// 한국의
+	addPair("Formatted  %s\n", L"수정됨    %s\n");		// should align with unchanged
+	addPair("Unchanged  %s\n", L"변경없음  %s\n");		// should align with formatted
+	addPair("Directory  %s\n", L"디렉토리  %s\n");
+	addPair("Default option file  %s\n", L"기본 옵션 파일  %s\n");
+	addPair("Project option file  %s\n", L"프로젝트 옵션 파일  %s\n");
+	addPair("Exclude  %s\n", L"제외됨  %s\n");
+	addPair("Exclude (unmatched)  %s\n", L"제외 (NO 일치)  %s\n");
+	addPair(" %s formatted   %s unchanged   ", L" %s 수정됨   %s 변경없음   ");
+	addPair(" seconds   ", L" 초   ");
+	addPair("%d min %d sec   ", L"%d 분 %d 초   ");
+	addPair("%s lines\n", L"%s 라인\n");
+	addPair("Opening HTML documentation %s\n", L"HTML 문서를 열기 %s\n");
+	addPair("Invalid default options:", L"잘못된 기본 옵션:");
+	addPair("Invalid project options:", L"잘못된 프로젝트 옵션:");
+	addPair("Invalid command line options:", L"잘못된 명령줄 옵션 :");
+	addPair("For help on options type 'astyle -h'", L"도움말을 보려면 옵션 유형 'astyle - H'를 사용합니다");
+	addPair("Cannot open default option file", L"기본 옵션 파일을 열 수 없습니다.");
+	addPair("Cannot open project option file", L"프로젝트 옵션 파일을 열 수 없습니다.");
+	addPair("Cannot open directory", L"디렉토리를 열지 못했습니다");
+	addPair("Cannot open HTML file %s\n", L"HTML 파일을 열 수 없습니다 %s\n");
+	addPair("Command execute failure", L"명령 실패를 실행");
+	addPair("Command is not installed", L"명령이 설치되어 있지 않습니다");
+	addPair("Missing filename in %s\n", L"%s 에서 누락된 파일 이름\n");
+	addPair("Recursive option with no wildcard", L"와일드 카드없이 재귀 옵션");
+	addPair("Did you intend quote the filename", L"당신은 파일 이름을 인용하고자하나요");
+	addPair("No file to process %s\n", L"처리할 파일이 없습니다 %s\n");
+	addPair("Did you intend to use --recursive", L"--recursive 를 사용하고자 하십니까");
+	addPair("Cannot process UTF-32 encoding", L"UTF-32 인코딩을 처리할 수 없습니다");
+	addPair("Artistic Style has terminated\n", L"Artistic Style를 종료합니다\n");
+Norwegian::Norwegian()	// Norsk
+	addPair("Formatted  %s\n", L"Formatert  %s\n");		// should align with unchanged
+	addPair("Unchanged  %s\n", L"Uendret    %s\n");		// should align with formatted
+	addPair("Directory  %s\n", L"Katalog  %s\n");
+	addPair("Default option file  %s\n", L"Standard alternativfil  %s\n");
+	addPair("Project option file  %s\n", L"Prosjekt opsjonsfil  %s\n");
+	addPair("Exclude  %s\n", L"Ekskluder  %s\n");
+	addPair("Exclude (unmatched)  %s\n", L"Ekskluder (uovertruffen)  %s\n");
+	addPair(" %s formatted   %s unchanged   ", L" %s formatert   %s uendret   ");
+	addPair(" seconds   ", L" sekunder   ");
+	addPair("%d min %d sec   ", L"%d min %d sek?   ");
+	addPair("%s lines\n", L"%s linjer\n");
+	addPair("Opening HTML documentation %s\n", L"Åpning HTML dokumentasjon %s\n");
+	addPair("Invalid default options:", L"Ugyldige standardalternativer:");
+	addPair("Invalid project options:", L"Ugyldige prosjektalternativer:");
+	addPair("Invalid command line options:", L"Kommandolinjevalg Ugyldige:");
+	addPair("For help on options type 'astyle -h'", L"For hjelp til alternativer type 'astyle -h'");
+	addPair("Cannot open default option file", L"Kan ikke åpne standardvalgsfilen");
+	addPair("Cannot open project option file", L"Kan ikke åpne prosjektvalgsfilen");
+	addPair("Cannot open directory", L"Kan ikke åpne katalog");
+	addPair("Cannot open HTML file %s\n", L"Kan ikke åpne HTML-fil %s\n");
+	addPair("Command execute failure", L"Command utføre svikt");
+	addPair("Command is not installed", L"Command er ikke installert");
+	addPair("Missing filename in %s\n", L"Mangler filnavn i %s\n");
+	addPair("Recursive option with no wildcard", L"Rekursiv alternativ uten wildcard");
+	addPair("Did you intend quote the filename", L"Har du tenkt sitere filnavnet");
+	addPair("No file to process %s\n", L"Ingen fil å behandle %s\n");
+	addPair("Did you intend to use --recursive", L"Har du tenkt å bruke --recursive");
+	addPair("Cannot process UTF-32 encoding", L"Kan ikke behandle UTF-32 koding");
+	addPair("Artistic Style has terminated\n", L"Artistic Style har avsluttet\n");
+Polish::Polish()	// Polski
+	addPair("Formatted  %s\n", L"Sformatowany  %s\n");	// should align with unchanged
+	addPair("Unchanged  %s\n", L"Niezmienione  %s\n");	// should align with formatted
+	addPair("Default option file  %s\n", L"Domyślny plik opcji  %s\n");
+	addPair("Project option file  %s\n", L"Plik opcji projektu  %s\n");
+	addPair("Exclude  %s\n", L"Wykluczać  %s\n");
+	addPair("Exclude (unmatched)  %s\n", L"Wyklucz (niezrównany)  %s\n");
+	addPair(" %s formatted   %s unchanged   ", L" %s sformatowany   %s niezmienione   ");
+	addPair(" seconds   ", L" sekund   ");
+	addPair("%s lines\n", L"%s linii\n");
+	addPair("Opening HTML documentation %s\n", L"Otwarcie dokumentacji HTML %s\n");
+	addPair("Invalid default options:", L"Nieprawidłowe opcje domyślne:");
+	addPair("Invalid project options:", L"Nieprawidłowe opcje projektu:");
+	addPair("Invalid command line options:", L"Nieprawidłowe opcje wiersza polecenia:");
+	addPair("For help on options type 'astyle -h'", L"Aby uzyskać pomoc od rodzaju opcji 'astyle -h'");
+	addPair("Cannot open default option file", L"Nie można otworzyć pliku opcji domyślnych");
+	addPair("Cannot open project option file", L"Nie można otworzyć pliku opcji projektu");
+	addPair("Cannot open directory", L"Nie można otworzyć katalogu");
+	addPair("Cannot open HTML file %s\n", L"Nie można otworzyć pliku HTML %s\n");
+	addPair("Command execute failure", L"Wykonaj polecenia niepowodzenia");
+	addPair("Command is not installed", L"Polecenie nie jest zainstalowany");
+	addPair("Missing filename in %s\n", L"Brakuje pliku w %s\n");
+	addPair("Recursive option with no wildcard", L"Rekurencyjne opcja bez symboli");
+	addPair("Did you intend quote the filename", L"Czy zamierza Pan podać nazwę pliku");
+	addPair("No file to process %s\n", L"Brak pliku do procesu %s\n");
+	addPair("Did you intend to use --recursive", L"Czy masz zamiar używać --recursive");
+	addPair("Cannot process UTF-32 encoding", L"Nie można procesu kodowania UTF-32");
+	addPair("Artistic Style has terminated\n", L"Artistic Style został zakończony\n");
+Portuguese::Portuguese()	// Português
+	addPair("Formatted  %s\n", L"Formatado   %s\n");	// should align with unchanged
+	addPair("Unchanged  %s\n", L"Inalterado  %s\n");	// should align with formatted
+	addPair("Directory  %s\n", L"Diretório  %s\n");
+	addPair("Default option file  %s\n", L"Arquivo de opção padrão  %s\n");
+	addPair("Project option file  %s\n", L"Arquivo de opção de projeto  %s\n");
+	addPair("Exclude  %s\n", L"Excluir  %s\n");
+	addPair("Exclude (unmatched)  %s\n", L"Excluir (incomparável)  %s\n");
+	addPair(" %s formatted   %s unchanged   ", L" %s formatado   %s inalterado   ");
+	addPair(" seconds   ", L" segundo   ");
+	addPair("%s lines\n", L"%s linhas\n");
+	addPair("Opening HTML documentation %s\n", L"Abrindo a documentação HTML %s\n");
+	addPair("Invalid default options:", L"Opções padrão inválidas:");
+	addPair("Invalid project options:", L"Opções de projeto inválidas:");
+	addPair("Invalid command line options:", L"Opções de linha de comando inválida:");
+	addPair("For help on options type 'astyle -h'", L"Para obter ajuda sobre as opções de tipo 'astyle -h'");
+	addPair("Cannot open default option file", L"Não é possível abrir o arquivo de opção padrão");
+	addPair("Cannot open project option file", L"Não é possível abrir o arquivo de opção do projeto");
+	addPair("Cannot open directory", L"Não é possível abrir diretório");
+	addPair("Cannot open HTML file %s\n", L"Não é possível abrir arquivo HTML %s\n");
+	addPair("Command execute failure", L"Executar falha de comando");
+	addPair("Command is not installed", L"Comando não está instalado");
+	addPair("Missing filename in %s\n", L"Filename faltando em %s\n");
+	addPair("Recursive option with no wildcard", L"Opção recursiva sem curinga");
+	addPair("Did you intend quote the filename", L"Será que você pretende citar o nome do arquivo");
+	addPair("No file to process %s\n", L"Nenhum arquivo para processar %s\n");
+	addPair("Did you intend to use --recursive", L"Será que você pretende usar --recursive");
+	addPair("Cannot process UTF-32 encoding", L"Não pode processar a codificação UTF-32");
+	addPair("Artistic Style has terminated\n", L"Artistic Style terminou\n");
+Romanian::Romanian()	// Română
+	addPair("Formatted  %s\n", L"Formatat    %s\n");	// should align with unchanged
+	addPair("Unchanged  %s\n", L"Neschimbat  %s\n");	// should align with formatted
+	addPair("Directory  %s\n", L"Director  %s\n");
+	addPair("Default option file  %s\n", L"Fișier opțional implicit  %s\n");
+	addPair("Project option file  %s\n", L"Fișier opțiune proiect  %s\n");
+	addPair("Exclude  %s\n", L"Excludeți  %s\n");
+	addPair("Exclude (unmatched)  %s\n", L"Excludeți (necompensată)  %s\n");
+	addPair(" %s formatted   %s unchanged   ", L" %s formatat   %s neschimbat   ");
+	addPair(" seconds   ", L" secunde   ");
+	addPair("Opening HTML documentation %s\n", L"Documentație HTML deschidere %s\n");
+	addPair("Invalid default options:", L"Opțiuni implicite nevalide:");
+	addPair("Invalid project options:", L"Opțiunile de proiect nevalide:");
+	addPair("Invalid command line options:", L"Opțiuni de linie de comandă nevalide:");
+	addPair("For help on options type 'astyle -h'", L"Pentru ajutor cu privire la tipul de opțiuni 'astyle -h'");
+	addPair("Cannot open default option file", L"Nu se poate deschide fișierul cu opțiuni implicite");
+	addPair("Cannot open project option file", L"Nu se poate deschide fișierul cu opțiuni de proiect");
+	addPair("Cannot open directory", L"Nu se poate deschide directorul");
+	addPair("Cannot open HTML file %s\n", L"Nu se poate deschide fișierul HTML %s\n");
+	addPair("Command execute failure", L"Comandă executa eșec");
+	addPair("Command is not installed", L"Comanda nu este instalat");
+	addPair("Missing filename in %s\n", L"Lipsă nume de fișier %s\n");
+	addPair("Recursive option with no wildcard", L"Opțiunea recursiv cu nici un wildcard");
+	addPair("Did you intend quote the filename", L"V-intentionati cita numele de fișier");
+	addPair("No file to process %s\n", L"Nu există un fișier pentru a procesa %s\n");
+	addPair("Did you intend to use --recursive", L"V-ați intenționați să utilizați --recursive");
+	addPair("Cannot process UTF-32 encoding", L"Nu se poate procesa codificarea UTF-32");
+	addPair("Artistic Style has terminated\n", L"Artistic Style a terminat\n");
+Russian::Russian()	// русский
+	addPair("Formatted  %s\n", L"Форматированный  %s\n");	// should align with unchanged
+	addPair("Unchanged  %s\n", L"без изменений    %s\n");	// should align with formatted
+	addPair("Directory  %s\n", L"каталог  %s\n");
+	addPair("Default option file  %s\n", L"Файл с опцией по умолчанию  %s\n");
+	addPair("Project option file  %s\n", L"Файл опций проекта  %s\n");
+	addPair("Exclude  %s\n", L"исключать  %s\n");
+	addPair("Exclude (unmatched)  %s\n", L"Исключить (непревзойденный)  %s\n");
+	addPair(" %s formatted   %s unchanged   ", L" %s Форматированный   %s без изменений   ");
+	addPair(" seconds   ", L" секунды   ");
+	addPair("%s lines\n", L"%s линий\n");
+	addPair("Opening HTML documentation %s\n", L"Открытие HTML документации %s\n");
+	addPair("Invalid default options:", L"Недействительные параметры по умолчанию:");
+	addPair("Invalid project options:", L"Недопустимые параметры проекта:");
+	addPair("Invalid command line options:", L"Недопустимые параметры командной строки:");
+	addPair("For help on options type 'astyle -h'", L"Для получения справки по 'astyle -h' опций типа");
+	addPair("Cannot open default option file", L"Не удается открыть файл параметров по умолчанию");
+	addPair("Cannot open project option file", L"Не удается открыть файл опций проекта");
+	addPair("Cannot open directory", L"Не могу открыть каталог");
+	addPair("Cannot open HTML file %s\n", L"Не удается открыть файл HTML %s\n");
+	addPair("Command execute failure", L"Выполнить команду недостаточности");
+	addPair("Command is not installed", L"Не установлен Команда");
+	addPair("Missing filename in %s\n", L"Отсутствует имя файла в %s\n");
+	addPair("Recursive option with no wildcard", L"Рекурсивный вариант без каких-либо шаблона");
+	addPair("Did you intend quote the filename", L"Вы намерены цитатой файла");
+	addPair("No file to process %s\n", L"Нет файлов для обработки %s\n");
+	addPair("Did you intend to use --recursive", L"Неужели вы собираетесь использовать --recursive");
+	addPair("Cannot process UTF-32 encoding", L"Не удается обработать UTF-32 кодировке");
+	addPair("Artistic Style has terminated\n", L"Artistic Style прекратил\n");
+Spanish::Spanish()	// Español
+	addPair("Formatted  %s\n", L"Formato     %s\n");	// should align with unchanged
+	addPair("Directory  %s\n", L"Directorio  %s\n");
+	addPair("Default option file  %s\n", L"Archivo de opciones predeterminado  %s\n");
+	addPair("Project option file  %s\n", L"Archivo de opciones del proyecto  %s\n");
+	addPair("Exclude (unmatched)  %s\n", L"Excluir (incomparable)  %s\n");
+	addPair(" %s formatted   %s unchanged   ", L" %s formato   %s inalterado   ");
+	addPair("%s lines\n", L"%s líneas\n");
+	addPair("Opening HTML documentation %s\n", L"Apertura de documentación HTML %s\n");
+	addPair("Invalid default options:", L"Opciones predeterminadas no válidas:");
+	addPair("Invalid project options:", L"Opciones de proyecto no válidas:");
+	addPair("Invalid command line options:", L"No válido opciones de línea de comando:");
+	addPair("For help on options type 'astyle -h'", L"Para obtener ayuda sobre las opciones tipo 'astyle -h'");
+	addPair("Cannot open default option file", L"No se puede abrir el archivo de opciones predeterminado");
+	addPair("Cannot open project option file", L"No se puede abrir el archivo de opciones del proyecto");
+	addPair("Cannot open directory", L"No se puede abrir el directorio");
+	addPair("Cannot open HTML file %s\n", L"No se puede abrir el archivo HTML %s\n");
+	addPair("Command execute failure", L"Ejecutar el fracaso de comandos");
+	addPair("Command is not installed", L"El comando no está instalado");
+	addPair("Missing filename in %s\n", L"Falta nombre del archivo en %s\n");
+	addPair("Recursive option with no wildcard", L"Recursiva opción sin comodín");
+	addPair("Did you intend quote the filename", L"Se tiene la intención de citar el nombre de archivo");
+	addPair("No file to process %s\n", L"No existe el fichero a procesar %s\n");
+	addPair("Did you intend to use --recursive", L"Se va a utilizar --recursive");
+	addPair("Cannot process UTF-32 encoding", L"No se puede procesar la codificación UTF-32");
+	addPair("Artistic Style has terminated\n", L"Artistic Style ha terminado\n");
+Swedish::Swedish()	// Svenska
+	addPair("Formatted  %s\n", L"Formaterade  %s\n");	// should align with unchanged
+	addPair("Unchanged  %s\n", L"Oförändrade  %s\n");	// should align with formatted
+	addPair("Default option file  %s\n", L"Standardalternativsfil  %s\n");
+	addPair("Project option file  %s\n", L"Projektalternativ fil  %s\n");
+	addPair("Exclude  %s\n", L"Uteslut  %s\n");
+	addPair("Exclude (unmatched)  %s\n", L"Uteslut (oöverträffad)  %s\n");
+	addPair(" %s formatted   %s unchanged   ", L" %s formaterade   %s oförändrade   ");
+	addPair("Opening HTML documentation %s\n", L"Öppna HTML-dokumentation %s\n");
+	addPair("Invalid default options:", L"Ogiltiga standardalternativ:");
+	addPair("Invalid project options:", L"Ogiltiga projektalternativ:");
+	addPair("Invalid command line options:", L"Ogiltig kommandoraden alternativ:");
+	addPair("For help on options type 'astyle -h'", L"För hjälp om alternativ typ 'astyle -h'");
+	addPair("Cannot open default option file", L"Kan inte öppna standardalternativsfilen");
+	addPair("Cannot open project option file", L"Kan inte öppna projektalternativsfilen");
+	addPair("Cannot open directory", L"Kan inte öppna katalog");
+	addPair("Cannot open HTML file %s\n", L"Kan inte öppna HTML-filen %s\n");
+	addPair("Command execute failure", L"Utför kommando misslyckande");
+	addPair("Command is not installed", L"Kommandot är inte installerat");
+	addPair("Missing filename in %s\n", L"Saknade filnamn i %s\n");
+	addPair("Recursive option with no wildcard", L"Rekursiva alternativ utan jokertecken");
+	addPair("Did you intend quote the filename", L"Visste du tänker citera filnamnet");
+	addPair("No file to process %s\n", L"Ingen fil att bearbeta %s\n");
+	addPair("Did you intend to use --recursive", L"Har du för avsikt att använda --recursive");
+	addPair("Cannot process UTF-32 encoding", L"Kan inte hantera UTF-32 kodning");
+	addPair("Artistic Style has terminated\n", L"Artistic Style har upphört\n");
+Ukrainian::Ukrainian()	// Український
+	addPair("Formatted  %s\n", L"форматований  %s\n");	// should align with unchanged
+	addPair("Unchanged  %s\n", L"без змін      %s\n");	// should align with formatted
+	addPair("Directory  %s\n", L"Каталог  %s\n");
+	addPair("Default option file  %s\n", L"Файл параметра за замовчуванням  %s\n");
+	addPair("Project option file  %s\n", L"Файл варіанту проекту  %s\n");
+	addPair("Exclude  %s\n", L"Виключити  %s\n");
+	addPair("Exclude (unmatched)  %s\n", L"Виключити (неперевершений)  %s\n");
+	addPair(" %s formatted   %s unchanged   ", L" %s відформатований   %s без змін   ");
+	addPair("%d min %d sec   ", L"%d хви %d cek   ");
+	addPair("%s lines\n", L"%s ліній\n");
+	addPair("Opening HTML documentation %s\n", L"Відкриття HTML документації %s\n");
+	addPair("Invalid default options:", L"Недійсні параметри за умовчанням:");
+	addPair("Invalid project options:", L"Недійсні параметри проекту:");
+	addPair("Invalid command line options:", L"Неприпустима параметри командного рядка:");
+	addPair("For help on options type 'astyle -h'", L"Для отримання довідки по 'astyle -h' опцій типу");
+	addPair("Cannot open default option file", L"Неможливо відкрити файл параметрів за замовчуванням");
+	addPair("Cannot open project option file", L"Неможливо відкрити файл параметрів проекту");
+	addPair("Cannot open directory", L"Не можу відкрити каталог");
+	addPair("Cannot open HTML file %s\n", L"Не вдається відкрити файл HTML %s\n");
+	addPair("Command execute failure", L"Виконати команду недостатності");
+	addPair("Command is not installed", L"Не встановлений Команда");
+	addPair("Missing filename in %s\n", L"Відсутня назва файлу в %s\n");
+	addPair("Recursive option with no wildcard", L"Рекурсивний варіант без будь-яких шаблону");
+	addPair("Did you intend quote the filename", L"Ви маєте намір цитатою файлу");
+	addPair("No file to process %s\n", L"Немає файлів для обробки %s\n");
+	addPair("Did you intend to use --recursive", L"Невже ви збираєтеся використовувати --recursive");
+	addPair("Cannot process UTF-32 encoding", L"Не вдається обробити UTF-32 кодуванні");
+	addPair("Artistic Style has terminated\n", L"Artistic Style припинив\n");
+#endif	// ASTYLE_LIB
+}   // end of namespace astyle
diff --git a/tools/astyle/ASLocalizer.h b/tools/astyle/ASLocalizer.h
index 0000000..703092b
--- /dev/null
+++ b/tools/astyle/ASLocalizer.h
@@ -0,0 +1,167 @@
+// ASLocalizer.h
+#ifndef ASLOCALIZER_H
+#define ASLOCALIZER_H
+#include <string>
+#include <vector>
+// library builds do not need ASLocalizer
+#ifdef ASTYLE_JNI
+	#ifndef ASTYLE_LIB    // ASTYLE_LIB must be defined for ASTYLE_JNI
+		#define ASTYLE_LIB
+	#endif
+#endif  //  ASTYLE_JNI
+namespace astyle {
+using namespace std;
+#ifndef ASTYLE_LIB
+// ASLocalizer class for console build.
+// This class encapsulates all language-dependent settings and is a
+// generalization of the C locale concept.
+class Translation;
+class ASLocalizer
+public:		// functions
+	ASLocalizer();
+	virtual ~ASLocalizer();
+	string getLanguageID() const;
+	const Translation* getTranslationClass() const;
+#ifdef _WIN32
+	void setLanguageFromLCID(size_t lcid);
+#endif
+	void setLanguageFromName(const char* langID);
+	const char* settext(const char* textIn) const;
+private:	// functions
+	void setTranslationClass();
+private:	// variables
+	Translation* m_translation;		// pointer to a polymorphic Translation class
+	string m_langID;				// language identifier from the locale
+	string m_subLangID;				// sub language identifier, if needed
+	string m_localeName;			// name of the current locale (Linux only)
+	size_t m_lcid;					// LCID of the user locale (Windows only)
+// Translation base class.
+class Translation
+// This base class is inherited by the language translation classes.
+// Polymorphism is used to call the correct language translator.
+// This class contains the translation vector and settext translation method.
+// The language vector is built by the language sub classes.
+// NOTE: This class must have virtual methods for typeid() to work.
+//       typeid() is used by AStyleTestI18n_Localizer.cpp.
+public:
+	Translation() {}
+	virtual ~Translation() {}
+	string convertToMultiByte(const wstring& wideStr) const;
+	string getTranslationString(size_t i) const;
+	size_t getTranslationVectorSize() const;
+	bool getWideTranslation(const string& stringIn, wstring& wideOut) const;
+	string& translate(const string& stringIn) const;
+protected:
+	void addPair(const string& english, const wstring& translated);
+	// variables
+	vector<pair<string, wstring> > m_translation;		// translation vector
+private:
+	mutable string m_mbTranslation;
+// Translation classes
+// One class for each language.
+class Bulgarian : public Translation
+{ public: Bulgarian(); };
+class ChineseSimplified : public Translation
+{ public: ChineseSimplified(); };
+class ChineseTraditional : public Translation
+{ public: ChineseTraditional(); };
+class Dutch : public Translation
+{ public: Dutch(); };
+class English : public Translation
+{ public: English(); };
+class Estonian : public Translation
+{ public: Estonian(); };
+class Finnish : public Translation
+{ public: Finnish(); };
+class French : public Translation
+{ public: French(); };
+class German : public Translation
+{ public: German(); };
+class Greek : public Translation
+{ public: Greek(); };
+class Hindi : public Translation
+{ public: Hindi(); };
+class Hungarian : public Translation
+{ public: Hungarian(); };
+class Italian : public Translation
+{ public: Italian(); };
+class Japanese : public Translation
+{ public: Japanese(); };
+class Korean : public Translation
+{ public: Korean(); };
+class Norwegian : public Translation
+{ public: Norwegian(); };
+class Polish : public Translation
+{ public: Polish(); };
+class Portuguese : public Translation
+{ public: Portuguese(); };
+class Romanian : public Translation
+{ public: Romanian(); };
+class Russian : public Translation
+{ public: Russian(); };
+class Spanish : public Translation
+{ public: Spanish(); };
+class Swedish : public Translation
+{ public: Swedish(); };
+class Ukrainian : public Translation
+{ public: Ukrainian(); };
+}	// namespace astyle
+#endif	//  ASLOCALIZER_H
diff --git a/tools/astyle/ASResource.cpp b/tools/astyle/ASResource.cpp
index 0000000..e2fc772
--- /dev/null
+++ b/tools/astyle/ASResource.cpp
@@ -0,0 +1,837 @@
+// ASResource.cpp
+// headers
+#include "astyle.h"
+#include <algorithm>
+// astyle namespace
+namespace astyle {
+const string ASResource::_AS_EXCEPT = string("__except");
+const string ASResource::_AS_FINALLY = string("__finally");
+const string ASResource::_AS_TRY = string("__try");
+const string ASResource::AS_ADD = string("add");
+const string ASResource::AS_AUTO = string("auto");
+const string ASResource::AS_AUTORELEASEPOOL = string("autoreleasepool");
+const string ASResource::AS_CASE = string("case");
+const string ASResource::AS_CATCH = string("catch");
+const string ASResource::AS_CLASS = string("class");
+const string ASResource::AS_CONST = string("const");
+const string ASResource::AS_CONST_CAST = string("const_cast");
+const string ASResource::AS_DEFAULT = string("default");
+const string ASResource::AS_DELEGATE = string("delegate");
+const string ASResource::AS_DELETE = string("delete");
+const string ASResource::AS_DO = string("do");
+const string ASResource::AS_DYNAMIC_CAST = string("dynamic_cast");
+const string ASResource::AS_ELSE = string("else");
+const string ASResource::AS_END = string("end");
+const string ASResource::AS_ENUM = string("enum");
+const string ASResource::AS_EXTERN = string("extern");
+const string ASResource::AS_FINAL = string("final");
+const string ASResource::AS_FINALLY = string("finally");
+const string ASResource::AS_FIXED = string("fixed");
+const string ASResource::AS_FOR = string("for");
+const string ASResource::AS_FOREACH = string("foreach");
+const string ASResource::AS_FOREVER = string("forever");
+const string ASResource::AS_GET = string("get");
+const string ASResource::AS_IF = string("if");
+const string ASResource::AS_INTERFACE = string("interface");
+const string ASResource::AS_INTERRUPT = string("interrupt");
+const string ASResource::AS_LET = string("let");
+const string ASResource::AS_LOCK = string("lock");
+const string ASResource::AS_MODULE = string("module");	// CORBA IDL module definition
+const string ASResource::AS_NAMESPACE = string("namespace");
+const string ASResource::AS_NEW = string("new");
+const string ASResource::AS_NOEXCEPT = string("noexcept");
+const string ASResource::AS_NS_DURING = string("NS_DURING");
+const string ASResource::AS_NS_HANDLER = string("NS_HANDLER");
+const string ASResource::AS_OPERATOR = string("operator");
+const string ASResource::AS_OVERRIDE = string("override");
+const string ASResource::AS_PRIVATE = string("private");
+const string ASResource::AS_PROTECTED = string("protected");
+const string ASResource::AS_PUBLIC = string("public");
+const string ASResource::AS_QFOREACH = string("Q_FOREACH");
+const string ASResource::AS_QFOREVER = string("Q_FOREVER");
+const string ASResource::AS_REINTERPRET_CAST = string("reinterpret_cast");
+const string ASResource::AS_REMOVE = string("remove");
+const string ASResource::AS_SEALED = string("sealed");
+const string ASResource::AS_SELECTOR = string("selector");
+const string ASResource::AS_SET = string("set");
+const string ASResource::AS_STATIC = string("static");
+const string ASResource::AS_STATIC_CAST = string("static_cast");
+const string ASResource::AS_STRUCT = string("struct");
+const string ASResource::AS_SWITCH = string("switch");
+const string ASResource::AS_SYNCHRONIZED = string("synchronized");
+const string ASResource::AS_TEMPLATE = string("template");
+const string ASResource::AS_THROW = string("throw");
+const string ASResource::AS_THROWS = string("throws");
+const string ASResource::AS_TRY = string("try");
+const string ASResource::AS_UNCHECKED = string("unchecked");
+const string ASResource::AS_UNION = string("union");
+const string ASResource::AS_UNSAFE = string("unsafe");
+const string ASResource::AS_USING = string("using");
+const string ASResource::AS_VOLATILE = string("volatile");
+const string ASResource::AS_WHERE = string("where");
+const string ASResource::AS_WHILE = string("while");
+const string ASResource::AS_ASM = string("asm");
+const string ASResource::AS__ASM__ = string("__asm__");
+const string ASResource::AS_MS_ASM = string("_asm");
+const string ASResource::AS_MS__ASM = string("__asm");
+const string ASResource::AS_BAR_DEFINE = string("#define");
+const string ASResource::AS_BAR_INCLUDE = string("#include");
+const string ASResource::AS_BAR_IF = string("#if");
+const string ASResource::AS_BAR_EL = string("#el");
+const string ASResource::AS_BAR_ENDIF = string("#endif");
+const string ASResource::AS_OPEN_BRACE = string("{");
+const string ASResource::AS_CLOSE_BRACE = string("}");
+const string ASResource::AS_OPEN_LINE_COMMENT = string("//");
+const string ASResource::AS_OPEN_COMMENT = string("/*");
+const string ASResource::AS_CLOSE_COMMENT = string("*/");
+const string ASResource::AS_ASSIGN = string("=");
+const string ASResource::AS_PLUS_ASSIGN = string("+=");
+const string ASResource::AS_MINUS_ASSIGN = string("-=");
+const string ASResource::AS_MULT_ASSIGN = string("*=");
+const string ASResource::AS_DIV_ASSIGN = string("/=");
+const string ASResource::AS_MOD_ASSIGN = string("%=");
+const string ASResource::AS_OR_ASSIGN = string("|=");
+const string ASResource::AS_AND_ASSIGN = string("&=");
+const string ASResource::AS_XOR_ASSIGN = string("^=");
+const string ASResource::AS_GR_GR_ASSIGN = string(">>=");
+const string ASResource::AS_LS_LS_ASSIGN = string("<<=");
+const string ASResource::AS_GR_GR_GR_ASSIGN = string(">>>=");
+const string ASResource::AS_LS_LS_LS_ASSIGN = string("<<<=");
+const string ASResource::AS_GCC_MIN_ASSIGN = string("<?");
+const string ASResource::AS_GCC_MAX_ASSIGN = string(">?");
+const string ASResource::AS_RETURN = string("return");
+const string ASResource::AS_CIN = string("cin");
+const string ASResource::AS_COUT = string("cout");
+const string ASResource::AS_CERR = string("cerr");
+const string ASResource::AS_EQUAL = string("==");
+const string ASResource::AS_PLUS_PLUS = string("++");
+const string ASResource::AS_MINUS_MINUS = string("--");
+const string ASResource::AS_NOT_EQUAL = string("!=");
+const string ASResource::AS_GR_EQUAL = string(">=");
+const string ASResource::AS_GR_GR = string(">>");
+const string ASResource::AS_GR_GR_GR = string(">>>");
+const string ASResource::AS_LS_EQUAL = string("<=");
+const string ASResource::AS_LS_LS = string("<<");
+const string ASResource::AS_LS_LS_LS = string("<<<");
+const string ASResource::AS_QUESTION_QUESTION = string("??");
+const string ASResource::AS_LAMBDA = string("=>");            // C# lambda expression arrow
+const string ASResource::AS_ARROW = string("->");
+const string ASResource::AS_AND = string("&&");
+const string ASResource::AS_OR = string("||");
+const string ASResource::AS_SCOPE_RESOLUTION = string("::");
+const string ASResource::AS_PLUS = string("+");
+const string ASResource::AS_MINUS = string("-");
+const string ASResource::AS_MULT = string("*");
+const string ASResource::AS_DIV = string("/");
+const string ASResource::AS_MOD = string("%");
+const string ASResource::AS_GR = string(">");
+const string ASResource::AS_LS = string("<");
+const string ASResource::AS_NOT = string("!");
+const string ASResource::AS_BIT_OR = string("|");
+const string ASResource::AS_BIT_AND = string("&");
+const string ASResource::AS_BIT_NOT = string("~");
+const string ASResource::AS_BIT_XOR = string("^");
+const string ASResource::AS_QUESTION = string("?");
+const string ASResource::AS_COLON = string(":");
+const string ASResource::AS_COMMA = string(",");
+const string ASResource::AS_SEMICOLON = string(";");
+ * Sort comparison function.
+ * Compares the length of the value of pointers in the vectors.
+ * The LONGEST strings will be first in the vector.
+ * @param a and b, the string pointers to be compared.
+bool sortOnLength(const string* a, const string* b)
+	return (*a).length() > (*b).length();
+ * Compares the value of pointers in the vectors.
+bool sortOnName(const string* a, const string* b)
+	return *a < *b;
+ * Build the vector of assignment operators.
+ * Used by BOTH ASFormatter.cpp and ASBeautifier.cpp
+ * @param assignmentOperators   a reference to the vector to be built.
+void ASResource::buildAssignmentOperators(vector<const string*>* assignmentOperators)
+	const size_t elements = 15;
+	static bool reserved = false;
+	if (!reserved)
+		assignmentOperators->reserve(elements);
+		reserved = true;
+	assignmentOperators->emplace_back(&AS_ASSIGN);
+	assignmentOperators->emplace_back(&AS_PLUS_ASSIGN);
+	assignmentOperators->emplace_back(&AS_MINUS_ASSIGN);
+	assignmentOperators->emplace_back(&AS_MULT_ASSIGN);
+	assignmentOperators->emplace_back(&AS_DIV_ASSIGN);
+	assignmentOperators->emplace_back(&AS_MOD_ASSIGN);
+	assignmentOperators->emplace_back(&AS_OR_ASSIGN);
+	assignmentOperators->emplace_back(&AS_AND_ASSIGN);
+	assignmentOperators->emplace_back(&AS_XOR_ASSIGN);
+	// Java
+	assignmentOperators->emplace_back(&AS_GR_GR_GR_ASSIGN);
+	assignmentOperators->emplace_back(&AS_GR_GR_ASSIGN);
+	assignmentOperators->emplace_back(&AS_LS_LS_ASSIGN);
+	// Unknown
+	assignmentOperators->emplace_back(&AS_LS_LS_LS_ASSIGN);
+	assert(assignmentOperators->size() < elements);
+	sort(assignmentOperators->begin(), assignmentOperators->end(), sortOnLength);
+ * Build the vector of C++ cast operators.
+ * Used by ONLY ASFormatter.cpp
+ * @param castOperators     a reference to the vector to be built.
+void ASResource::buildCastOperators(vector<const string*>* castOperators)
+	const size_t elements = 5;
+	if (!reserved)
+		castOperators->reserve(elements);
+		reserved = true;
+	castOperators->emplace_back(&AS_CONST_CAST);
+	castOperators->emplace_back(&AS_DYNAMIC_CAST);
+	castOperators->emplace_back(&AS_REINTERPRET_CAST);
+	castOperators->emplace_back(&AS_STATIC_CAST);
+	assert(castOperators->size() < elements);
+	sort(castOperators->begin(), castOperators->end(), sortOnName);
+ * Build the vector of header words.
+ * @param headers       a reference to the vector to be built.
+void ASResource::buildHeaders(vector<const string*>* headers, int fileType, bool beautifier)
+	const size_t elements = 25;
+	if (!reserved)
+		headers->reserve(elements);
+		reserved = true;
+	headers->emplace_back(&AS_IF);
+	headers->emplace_back(&AS_ELSE);
+	headers->emplace_back(&AS_FOR);
+	headers->emplace_back(&AS_WHILE);
+	headers->emplace_back(&AS_DO);
+	headers->emplace_back(&AS_SWITCH);
+	headers->emplace_back(&AS_CASE);
+	headers->emplace_back(&AS_DEFAULT);
+	headers->emplace_back(&AS_TRY);
+	headers->emplace_back(&AS_CATCH);
+	headers->emplace_back(&AS_QFOREACH);		// QT
+	headers->emplace_back(&AS_QFOREVER);		// QT
+	headers->emplace_back(&AS_FOREACH);		// QT & C#
+	headers->emplace_back(&AS_FOREVER);		// Qt & Boost
+	if (fileType == C_TYPE)
+		headers->emplace_back(&_AS_TRY);		// __try
+		headers->emplace_back(&_AS_FINALLY);	// __finally
+		headers->emplace_back(&_AS_EXCEPT);	// __except
+	if (fileType == JAVA_TYPE)
+		headers->emplace_back(&AS_FINALLY);
+		headers->emplace_back(&AS_SYNCHRONIZED);
+	if (fileType == SHARP_TYPE)
+		headers->emplace_back(&AS_LOCK);
+		headers->emplace_back(&AS_FIXED);
+		headers->emplace_back(&AS_GET);
+		headers->emplace_back(&AS_SET);
+		headers->emplace_back(&AS_ADD);
+		headers->emplace_back(&AS_REMOVE);
+		headers->emplace_back(&AS_USING);
+	if (beautifier)
+			headers->emplace_back(&AS_TEMPLATE);
+			headers->emplace_back(&AS_STATIC);         // for static constructor
+	assert(headers->size() < elements);
+	sort(headers->begin(), headers->end(), sortOnName);
+ * Build the vector of indentable headers.
+ * Used by ONLY ASBeautifier.cpp
+ * @param indentableHeaders     a reference to the vector to be built.
+void ASResource::buildIndentableHeaders(vector<const string*>* indentableHeaders)
+	indentableHeaders->emplace_back(&AS_RETURN);
+//	sort(indentableHeaders->begin(), indentableHeaders->end(), sortOnName);
+* Build the vector of indentable macros pairs.
+* Initialized by ASFormatter, used by ONLY ASEnhancer.cpp
+* @param indentableMacros       a reference to the vector to be built.
+void ASResource::buildIndentableMacros(vector<const pair<const string, const string>* >* indentableMacros)
+	const size_t elements = 10;
+	if (!reserved)
+		indentableMacros->reserve(elements);
+		reserved = true;
+	// the pairs must be retained in memory because of pair pointers
+	typedef pair<const string, const string> macro_pair;
+	static const macro_pair macros[] =
+		// wxWidgets
+		macro_pair("BEGIN_EVENT_TABLE",   "END_EVENT_TABLE"),
+		macro_pair("wxBEGIN_EVENT_TABLE", "wxEND_EVENT_TABLE"),
+		// MFC
+		macro_pair("BEGIN_DISPATCH_MAP",  "END_DISPATCH_MAP"),
+		macro_pair("BEGIN_EVENT_MAP",     "END_EVENT_MAP"),
+		macro_pair("BEGIN_MESSAGE_MAP",   "END_MESSAGE_MAP"),
+		macro_pair("BEGIN_PROPPAGEIDS",   "END_PROPPAGEIDS"),
+	size_t entries = sizeof(macros) / sizeof(macros[0]);
+	for (size_t i = 0; i < entries; i++)
+		indentableMacros->emplace_back(&macros[i]);
+	assert(indentableMacros->size() < elements);
+ * Build the vector of non-assignment operators.
+ * @param nonAssignmentOperators       a reference to the vector to be built.
+void ASResource::buildNonAssignmentOperators(vector<const string*>* nonAssignmentOperators)
+	if (!reserved)
+		nonAssignmentOperators->reserve(elements);
+		reserved = true;
+	nonAssignmentOperators->emplace_back(&AS_EQUAL);
+	nonAssignmentOperators->emplace_back(&AS_PLUS_PLUS);
+	nonAssignmentOperators->emplace_back(&AS_MINUS_MINUS);
+	nonAssignmentOperators->emplace_back(&AS_NOT_EQUAL);
+	nonAssignmentOperators->emplace_back(&AS_GR_EQUAL);
+	nonAssignmentOperators->emplace_back(&AS_GR_GR_GR);
+	nonAssignmentOperators->emplace_back(&AS_GR_GR);
+	nonAssignmentOperators->emplace_back(&AS_LS_EQUAL);
+	nonAssignmentOperators->emplace_back(&AS_LS_LS_LS);
+	nonAssignmentOperators->emplace_back(&AS_LS_LS);
+	nonAssignmentOperators->emplace_back(&AS_ARROW);
+	nonAssignmentOperators->emplace_back(&AS_AND);
+	nonAssignmentOperators->emplace_back(&AS_OR);
+	nonAssignmentOperators->emplace_back(&AS_LAMBDA);
+	assert(nonAssignmentOperators->size() < elements);
+	sort(nonAssignmentOperators->begin(), nonAssignmentOperators->end(), sortOnLength);
+ * Build the vector of header non-paren headers.
+ * Used by BOTH ASFormatter.cpp and ASBeautifier.cpp.
+ * NOTE: Non-paren headers should also be included in the headers vector.
+ * @param nonParenHeaders       a reference to the vector to be built.
+void ASResource::buildNonParenHeaders(vector<const string*>* nonParenHeaders, int fileType, bool beautifier)
+	const size_t elements = 20;
+	if (!reserved)
+		nonParenHeaders->reserve(elements);
+		reserved = true;
+	nonParenHeaders->emplace_back(&AS_ELSE);
+	nonParenHeaders->emplace_back(&AS_DO);
+	nonParenHeaders->emplace_back(&AS_TRY);
+	nonParenHeaders->emplace_back(&AS_CATCH);		// can be paren or non-paren
+	nonParenHeaders->emplace_back(&AS_CASE);		// can be paren or non-paren
+	nonParenHeaders->emplace_back(&AS_DEFAULT);
+	nonParenHeaders->emplace_back(&AS_QFOREVER);	// QT
+	nonParenHeaders->emplace_back(&AS_FOREVER);	// Boost
+		nonParenHeaders->emplace_back(&_AS_TRY);		// __try
+		nonParenHeaders->emplace_back(&_AS_FINALLY);	// __finally
+		nonParenHeaders->emplace_back(&AS_FINALLY);
+		nonParenHeaders->emplace_back(&AS_GET);
+		nonParenHeaders->emplace_back(&AS_SET);
+		nonParenHeaders->emplace_back(&AS_ADD);
+		nonParenHeaders->emplace_back(&AS_REMOVE);
+	if (beautifier)
+			nonParenHeaders->emplace_back(&AS_TEMPLATE);
+			nonParenHeaders->emplace_back(&AS_STATIC);
+	assert(nonParenHeaders->size() < elements);
+	sort(nonParenHeaders->begin(), nonParenHeaders->end(), sortOnName);
+ * Build the vector of operators.
+ * @param operators             a reference to the vector to be built.
+void ASResource::buildOperators(vector<const string*>* operators, int fileType)
+	const size_t elements = 50;
+	if (!reserved)
+		operators->reserve(elements);
+		reserved = true;
+	operators->emplace_back(&AS_PLUS_ASSIGN);
+	operators->emplace_back(&AS_MINUS_ASSIGN);
+	operators->emplace_back(&AS_MULT_ASSIGN);
+	operators->emplace_back(&AS_DIV_ASSIGN);
+	operators->emplace_back(&AS_MOD_ASSIGN);
+	operators->emplace_back(&AS_OR_ASSIGN);
+	operators->emplace_back(&AS_AND_ASSIGN);
+	operators->emplace_back(&AS_XOR_ASSIGN);
+	operators->emplace_back(&AS_EQUAL);
+	operators->emplace_back(&AS_PLUS_PLUS);
+	operators->emplace_back(&AS_MINUS_MINUS);
+	operators->emplace_back(&AS_NOT_EQUAL);
+	operators->emplace_back(&AS_GR_EQUAL);
+	operators->emplace_back(&AS_GR_GR_GR_ASSIGN);
+	operators->emplace_back(&AS_GR_GR_ASSIGN);
+	operators->emplace_back(&AS_GR_GR_GR);
+	operators->emplace_back(&AS_GR_GR);
+	operators->emplace_back(&AS_LS_EQUAL);
+	operators->emplace_back(&AS_LS_LS_LS_ASSIGN);
+	operators->emplace_back(&AS_LS_LS_ASSIGN);
+	operators->emplace_back(&AS_LS_LS_LS);
+	operators->emplace_back(&AS_LS_LS);
+	operators->emplace_back(&AS_QUESTION_QUESTION);
+	operators->emplace_back(&AS_LAMBDA);
+	operators->emplace_back(&AS_ARROW);
+	operators->emplace_back(&AS_AND);
+	operators->emplace_back(&AS_OR);
+	operators->emplace_back(&AS_SCOPE_RESOLUTION);
+	operators->emplace_back(&AS_PLUS);
+	operators->emplace_back(&AS_MINUS);
+	operators->emplace_back(&AS_MULT);
+	operators->emplace_back(&AS_DIV);
+	operators->emplace_back(&AS_MOD);
+	operators->emplace_back(&AS_QUESTION);
+	operators->emplace_back(&AS_COLON);
+	operators->emplace_back(&AS_ASSIGN);
+	operators->emplace_back(&AS_LS);
+	operators->emplace_back(&AS_GR);
+	operators->emplace_back(&AS_NOT);
+	operators->emplace_back(&AS_BIT_OR);
+	operators->emplace_back(&AS_BIT_AND);
+	operators->emplace_back(&AS_BIT_NOT);
+	operators->emplace_back(&AS_BIT_XOR);
+		operators->emplace_back(&AS_GCC_MIN_ASSIGN);
+		operators->emplace_back(&AS_GCC_MAX_ASSIGN);
+	assert(operators->size() < elements);
+	sort(operators->begin(), operators->end(), sortOnLength);
+ * Build the vector of pre-block statements.
+ * NOTE: Cannot be both a header and a preBlockStatement.
+ * @param preBlockStatements        a reference to the vector to be built.
+void ASResource::buildPreBlockStatements(vector<const string*>* preBlockStatements, int fileType)
+	if (!reserved)
+		preBlockStatements->reserve(elements);
+		reserved = true;
+	preBlockStatements->emplace_back(&AS_CLASS);
+		preBlockStatements->emplace_back(&AS_STRUCT);
+		preBlockStatements->emplace_back(&AS_UNION);
+		preBlockStatements->emplace_back(&AS_NAMESPACE);
+		preBlockStatements->emplace_back(&AS_MODULE);     // for CORBA IDL
+		preBlockStatements->emplace_back(&AS_INTERFACE);  // for CORBA IDL
+		preBlockStatements->emplace_back(&AS_THROWS);
+		preBlockStatements->emplace_back(&AS_WHERE);
+	assert(preBlockStatements->size() < elements);
+	sort(preBlockStatements->begin(), preBlockStatements->end(), sortOnName);
+ * Build the vector of pre-command headers.
+ * NOTE: Cannot be both a header and a preCommandHeader.
+ * A preCommandHeader is in a function definition between
+ * the closing paren and the opening brace.
+ * e.g. in "void foo() const {}", "const" is a preCommandHeader.
+void ASResource::buildPreCommandHeaders(vector<const string*>* preCommandHeaders, int fileType)
+	if (!reserved)
+		preCommandHeaders->reserve(elements);
+		reserved = true;
+		preCommandHeaders->emplace_back(&AS_CONST);
+		preCommandHeaders->emplace_back(&AS_FINAL);
+		preCommandHeaders->emplace_back(&AS_INTERRUPT);
+		preCommandHeaders->emplace_back(&AS_NOEXCEPT);
+		preCommandHeaders->emplace_back(&AS_OVERRIDE);
+		preCommandHeaders->emplace_back(&AS_VOLATILE);
+		preCommandHeaders->emplace_back(&AS_SEALED);			// Visual C only
+		preCommandHeaders->emplace_back(&AS_AUTORELEASEPOOL);	// Obj-C only
+		preCommandHeaders->emplace_back(&AS_THROWS);
+		preCommandHeaders->emplace_back(&AS_WHERE);
+	assert(preCommandHeaders->size() < elements);
+	sort(preCommandHeaders->begin(), preCommandHeaders->end(), sortOnName);
+ * Build the vector of pre-definition headers.
+ * NOTE: Do NOT add 'enum' here. It is an array type brace.
+ * NOTE: Do NOT add 'extern' here. Do not want an extra indent.
+ * @param preDefinitionHeaders      a reference to the vector to be built.
+void ASResource::buildPreDefinitionHeaders(vector<const string*>* preDefinitionHeaders, int fileType)
+	if (!reserved)
+		preDefinitionHeaders->reserve(elements);
+		reserved = true;
+	preDefinitionHeaders->emplace_back(&AS_CLASS);
+		preDefinitionHeaders->emplace_back(&AS_STRUCT);
+		preDefinitionHeaders->emplace_back(&AS_UNION);
+		preDefinitionHeaders->emplace_back(&AS_NAMESPACE);
+		preDefinitionHeaders->emplace_back(&AS_MODULE);     // for CORBA IDL
+		preDefinitionHeaders->emplace_back(&AS_INTERFACE);  // for CORBA IDL
+	assert(preDefinitionHeaders->size() < elements);
+	sort(preDefinitionHeaders->begin(), preDefinitionHeaders->end(), sortOnName);
+ *                             ASBase Functions
+// check if a specific line position contains a header.
+const string* ASBase::findHeader(const string& line, int i,
+                                 const vector<const string*>* possibleHeaders) const
+	assert(isCharPotentialHeader(line, i));
+	// check the word
+	size_t maxHeaders = possibleHeaders->size();
+	for (size_t p = 0; p < maxHeaders; p++)
+		const string* header = (*possibleHeaders)[p];
+		const size_t wordEnd = i + header->length();
+		if (wordEnd > line.length())
+			continue;
+		int result = (line.compare(i, header->length(), *header));
+		if (result > 0)
+			continue;
+		if (result < 0)
+			break;
+		// check that this is not part of a longer word
+		if (wordEnd == line.length())
+			return header;
+		if (isLegalNameChar(line[wordEnd]))
+			continue;
+		const char peekChar = peekNextChar(line, wordEnd - 1);
+		// is not a header if part of a definition
+		if (peekChar == ',' || peekChar == ')')
+			break;
+		// the following accessor definitions are NOT headers
+		// goto default; is NOT a header
+		// default(int) keyword in C# is NOT a header
+		else if ((header == &AS_GET
+		          || header == &AS_SET
+		          || header == &AS_DEFAULT)
+		         && (peekChar == ';' || peekChar == '(' || peekChar == '='))
+			break;
+		return header;
+	return nullptr;
+// check if a specific line position contains a keyword.
+bool ASBase::findKeyword(const string& line, int i, const string& keyword) const
+	// check the word
+	const size_t keywordLength = keyword.length();
+	const size_t wordEnd = i + keywordLength;
+		return false;
+	if (line.compare(i, keywordLength, keyword) != 0)
+		return false;
+		return true;
+		return false;
+	// is not a keyword if part of a definition
+	const char peekChar = peekNextChar(line, (int) wordEnd - 1);
+		return false;
+	return true;
+// check if a specific line position contains an operator.
+const string* ASBase::findOperator(const string& line, int i,
+                                   const vector<const string*>* possibleOperators) const
+	assert(isCharPotentialOperator(line[i]));
+	// find the operator in the vector
+	// the vector contains the LONGEST operators first
+	// must loop thru the entire vector
+	size_t maxOperators = possibleOperators->size();
+	for (size_t p = 0; p < maxOperators; p++)
+		const size_t wordEnd = i + (*(*possibleOperators)[p]).length();
+			continue;
+		if (line.compare(i, (*(*possibleOperators)[p]).length(), *(*possibleOperators)[p]) == 0)
+			return (*possibleOperators)[p];
+	return nullptr;
+// get the current word on a line
+// index must point to the beginning of the word
+string ASBase::getCurrentWord(const string& line, size_t index) const
+	assert(isCharPotentialHeader(line, index));
+	size_t lineLength = line.length();
+	size_t i;
+	for (i = index; i < lineLength; i++)
+		if (!isLegalNameChar(line[i]))
+			break;
+	return line.substr(index, i - index);
+// check if a specific character can be used in a legal variable/method/class name
+bool ASBase::isLegalNameChar(char ch) const
+	if (isWhiteSpace(ch))
+		return false;
+	if ((unsigned char) ch > 127)
+		return false;
+	return (isalnum((unsigned char) ch)
+	        || ch == '.' || ch == '_'
+	        || (isJavaStyle() && ch == '$')
+	        || (isSharpStyle() && ch == '@'));  // may be used as a prefix
+// check if a specific character can be part of a header
+bool ASBase::isCharPotentialHeader(const string& line, size_t i) const
+	assert(!isWhiteSpace(line[i]));
+	char prevCh = ' ';
+	if (i > 0)
+		prevCh = line[i - 1];
+	if (i > 1 && line[i - 2] == '\\')
+		prevCh = ' ';
+	if (!isLegalNameChar(prevCh) && isLegalNameChar(line[i]))
+		return true;
+	return false;
+// check if a specific character can be part of an operator
+bool ASBase::isCharPotentialOperator(char ch) const
+	assert(!isWhiteSpace(ch));
+	if ((unsigned) ch > 127)
+		return false;
+	return (ispunct((unsigned char) ch)
+	        && ch != '{' && ch != '}'
+	        && ch != '(' && ch != ')'
+	        && ch != '[' && ch != ']'
+	        && ch != ';' && ch != ','
+	        && ch != '#' && ch != '\\'
+	        && ch != '\'' && ch != '\"');
+// check if a specific character is a digit
+// NOTE: Visual C isdigit() gives assert error if char > 256
+bool ASBase::isDigit(char ch) const
+	return (ch >= '0' && ch <= '9');
+// check if a specific character is a digit separator
+bool ASBase::isDigitSeparator(const string& line, int i) const
+	assert(line[i] == '\'');
+	// casting to (unsigned char) eliminates negative characters
+	// will get a "Debug Assertion Failed" if not cast
+	bool foundDigitSeparator = i > 0
+	                           && isxdigit((unsigned char) line[i - 1])
+	                           && i < (int) line.length() - 1
+	                           && isxdigit((unsigned char) line[i + 1]);
+	return foundDigitSeparator;
+// peek at the next unread character.
+char ASBase::peekNextChar(const string& line, int i) const
+	char ch = ' ';
+	size_t peekNum = line.find_first_not_of(" \t", i + 1);
+	if (peekNum == string::npos)
+		return ch;
+	ch = line[peekNum];
+	return ch;
+}   // end namespace astyle
diff --git a/tools/astyle/CMakeLists.txt b/tools/astyle/CMakeLists.txt
new file mode 100644
index 0000000..e6ea8dc
--- /dev/null
+++ b/tools/astyle/CMakeLists.txt
@@ -0,0 +1,20 @@
+# Copyright (C) 2019 Paul Ramsey <pramsey at cleverelephant.ca>
+# This is free software; you can redistribute and/or modify it under
+# the terms of the GNU Lesser General Public Licence as published
+# by the Free Software Foundation.
+# See the COPYING file for more information.
+include_directories(${CMAKE_CURRENT_SOURCE_DIR})
+file(GLOB_RECURSE astyle_SOURCES ${CMAKE_CURRENT_SOURCE_DIR}/*.cpp)
+add_executable(astyle ${astyle_SOURCES})
+# message(STATUS "Enable AStyle")
+# Group source files for IDE source explorers (e.g. Visual Studio)
+GenerateSourceGroups(tools/astyle)
diff --git a/tools/astyle/Makefile.am b/tools/astyle/Makefile.am
index 0000000..7bf90d8
--- /dev/null
+++ b/tools/astyle/Makefile.am
@@ -0,0 +1,31 @@
+# This file is part of project GEOS (http://trac.osgeo.org/geos/)
+AUTOMAKE_OPTIONS = subdir-objects
+AM_CPPFLAGS =
+EXTRA_DIST = \
+	ASLocalizer.h \
+	astyle.h \
+	astyle_main.h
+noinst_PROGRAMS = astyle
+#check_PROGRAMS =
+#bin_PROGRAMS = astyle
+geos_unit_LDADD = \
+	$(NULL)
+astyle_SOURCES = \
+	ASBeautifier.cpp \
+	ASEnhancer.cpp \
+	ASFormatter.cpp \
+	ASLocalizer.cpp \
+	ASResource.cpp \
+	astyle_main.cpp
+noinst_HEADERS =
diff --git a/tools/astyle/astyle.h b/tools/astyle/astyle.h
new file mode 100755
index 0000000..d886aa6
--- /dev/null
+++ b/tools/astyle/astyle.h
@@ -0,0 +1,1083 @@
+// astyle.h
+// Copyright (c) 2018 by Jim Pattee <jimp03 at email.com>.
+// This code is licensed under the MIT License.
+// License.md describes the conditions under which this software may be distributed.
+#ifndef ASTYLE_H
+#define ASTYLE_H
+// headers
+#ifdef __VMS
+	#define __USE_STD_IOSTREAM 1
+	#include <assert>
+#else
+	#include <cassert>
+#endif
+#include <cctype>
+#include <iostream>		// for cout
+#include <memory>
+#include <string>
+#include <vector>
+#ifdef __GNUC__
+	#include <cstring>              // need both string and cstring for GCC
+#endif
+// declarations
+#ifdef _MSC_VER
+	#pragma warning(disable: 4267)  // conversion from size_t to int
+#endif
+#ifdef __BORLANDC__
+	#pragma warn -8004	            // variable is assigned a value that is never used
+#endif
+#ifdef __GNUC__
+	#pragma GCC diagnostic ignored "-Wconversion"
+#endif
+#ifdef __INTEL_COMPILER
+	#pragma warning(disable:  383)  // value copied to temporary, reference to temporary used
+	#pragma warning(disable:  981)  // operands are evaluated in unspecified order
+#endif
+#ifdef __clang__
+	#pragma clang diagnostic ignored "-Wshorten-64-to-32"
+#endif
+namespace astyle {
+// definitions
+enum FileType { C_TYPE = 0, JAVA_TYPE = 1, SHARP_TYPE = 2 };
+/* The enums below are not recognized by 'vectors' in Microsoft Visual C++
+   V5 when they are part of a namespace!!!  Use Visual C++ V6 or higher.
+enum FormatStyle
+	STYLE_NONE,
+	STYLE_ALLMAN,
+	STYLE_JAVA,
+	STYLE_KR,
+	STYLE_STROUSTRUP,
+	STYLE_WHITESMITH,
+	STYLE_VTK,
+	STYLE_RATLIFF,
+	STYLE_GNU,
+	STYLE_LINUX,
+	STYLE_HORSTMANN,
+	STYLE_1TBS,
+	STYLE_GOOGLE,
+	STYLE_MOZILLA,
+	STYLE_PICO,
+	STYLE_LISP
+enum BraceMode
+	NONE_MODE,
+	ATTACH_MODE,
+	BREAK_MODE,
+	LINUX_MODE,
+	RUN_IN_MODE		// broken braces
+// maximum value for int is 16,384 (total value of 32,767)
+enum BraceType
+	NULL_TYPE        = 0,
+	NAMESPACE_TYPE   = 1,		// also a DEFINITION_TYPE
+	CLASS_TYPE       = 2,		// also a DEFINITION_TYPE
+	STRUCT_TYPE      = 4,		// also a DEFINITION_TYPE
+	INTERFACE_TYPE   = 8,		// also a DEFINITION_TYPE
+	DEFINITION_TYPE  = 16,
+	COMMAND_TYPE     = 32,
+	ARRAY_NIS_TYPE   = 64,		// also an ARRAY_TYPE
+	ENUM_TYPE        = 128,		// also an ARRAY_TYPE
+	INIT_TYPE        = 256,		// also an ARRAY_TYPE
+	ARRAY_TYPE       = 512,
+	EXTERN_TYPE      = 1024,	// extern "C", not a command type extern
+	EMPTY_BLOCK_TYPE = 2048,	// also a SINGLE_LINE_TYPE
+	BREAK_BLOCK_TYPE = 4096,	// also a SINGLE_LINE_TYPE
+	SINGLE_LINE_TYPE = 8192
+enum MinConditional
+	MINCOND_ZERO,
+	MINCOND_ONE,
+	MINCOND_TWO,
+	MINCOND_ONEHALF,
+	MINCOND_END
+enum ObjCColonPad
+	COLON_PAD_NO_CHANGE,
+	COLON_PAD_NONE,
+	COLON_PAD_ALL,
+	COLON_PAD_AFTER,
+	COLON_PAD_BEFORE
+enum PointerAlign
+	PTR_ALIGN_NONE,
+	PTR_ALIGN_TYPE,
+	PTR_ALIGN_MIDDLE,
+	PTR_ALIGN_NAME
+enum ReferenceAlign
+	REF_ALIGN_NONE   = PTR_ALIGN_NONE,
+	REF_ALIGN_TYPE   = PTR_ALIGN_TYPE,
+	REF_ALIGN_MIDDLE = PTR_ALIGN_MIDDLE,
+	REF_ALIGN_NAME   = PTR_ALIGN_NAME,
+	REF_SAME_AS_PTR
+enum FileEncoding
+	ENCODING_8BIT,  // includes UTF-8 without BOM
+	UTF_8BOM,       // UTF-8 with BOM
+	UTF_16BE,
+	UTF_16LE,       // Windows default
+	UTF_32BE,
+	UTF_32LE
+enum LineEndFormat
+	LINEEND_DEFAULT,	// Use line break that matches most of the file
+	LINEEND_WINDOWS,
+	LINEEND_LINUX,
+	LINEEND_MACOLD,
+	LINEEND_CRLF = LINEEND_WINDOWS,
+	LINEEND_LF   = LINEEND_LINUX,
+	LINEEND_CR   = LINEEND_MACOLD
+// Class ASSourceIterator
+// A pure virtual class is used by ASFormatter and ASBeautifier instead of
+// ASStreamIterator. This allows programs using AStyle as a plug-in to define
+// their own ASStreamIterator. The ASStreamIterator class must inherit
+// this class.
+class ASSourceIterator
+public:
+	ASSourceIterator() {}
+	virtual ~ASSourceIterator() {}
+	virtual streamoff getPeekStart() const = 0;
+	virtual int getStreamLength() const = 0;
+	virtual bool hasMoreLines() const = 0;
+	virtual string nextLine(bool emptyLineWasDeleted = false) = 0;
+	virtual string peekNextLine() = 0;
+	virtual void peekReset() = 0;
+	virtual streamoff tellg() = 0;
+// Class ASPeekStream
+// A small class using RAII to peek ahead in the ASSourceIterator stream
+// and to reset the ASSourceIterator pointer in the destructor.
+// It enables a return from anywhere in the method.
+class ASPeekStream
+private:
+	ASSourceIterator* sourceIterator;
+	bool needReset;		// reset sourceIterator to the original position
+public:
+	explicit ASPeekStream(ASSourceIterator* sourceIterator_)
+	{ sourceIterator = sourceIterator_; needReset = false; }
+	~ASPeekStream()
+	{ if (needReset) sourceIterator->peekReset(); }
+	bool hasMoreLines() const
+	{ return sourceIterator->hasMoreLines(); }
+	string peekNextLine()
+	{ needReset = true; return sourceIterator->peekNextLine(); }
+// Class ASResource
+class ASResource
+public:
+	void buildAssignmentOperators(vector<const string*>* assignmentOperators);
+	void buildCastOperators(vector<const string*>* castOperators);
+	void buildHeaders(vector<const string*>* headers, int fileType, bool beautifier = false);
+	void buildIndentableMacros(vector<const pair<const string, const string>* >* indentableMacros);
+	void buildIndentableHeaders(vector<const string*>* indentableHeaders);
+	void buildNonAssignmentOperators(vector<const string*>* nonAssignmentOperators);
+	void buildNonParenHeaders(vector<const string*>* nonParenHeaders, int fileType, bool beautifier = false);
+	void buildOperators(vector<const string*>* operators, int fileType);
+	void buildPreBlockStatements(vector<const string*>* preBlockStatements, int fileType);
+	void buildPreCommandHeaders(vector<const string*>* preCommandHeaders, int fileType);
+	void buildPreDefinitionHeaders(vector<const string*>* preDefinitionHeaders, int fileType);
+public:
+	static const string AS_IF, AS_ELSE;
+	static const string AS_DO, AS_WHILE;
+	static const string AS_FOR;
+	static const string AS_SWITCH, AS_CASE, AS_DEFAULT;
+	static const string AS_TRY, AS_CATCH, AS_THROW, AS_THROWS, AS_FINALLY, AS_USING;
+	static const string _AS_TRY, _AS_FINALLY, _AS_EXCEPT;
+	static const string AS_PUBLIC, AS_PROTECTED, AS_PRIVATE;
+	static const string AS_CLASS, AS_STRUCT, AS_UNION, AS_INTERFACE, AS_NAMESPACE;
+	static const string AS_MODULE;
+	static const string AS_END;
+	static const string AS_SELECTOR;
+	static const string AS_EXTERN, AS_ENUM;
+	static const string AS_FINAL, AS_OVERRIDE;
+	static const string AS_STATIC, AS_CONST, AS_SEALED, AS_VOLATILE, AS_NEW, AS_DELETE;
+	static const string AS_NOEXCEPT, AS_INTERRUPT, AS_AUTORELEASEPOOL;
+	static const string AS_WHERE, AS_LET, AS_SYNCHRONIZED;
+	static const string AS_OPERATOR, AS_TEMPLATE;
+	static const string AS_OPEN_BRACE, AS_CLOSE_BRACE;
+	static const string AS_OPEN_LINE_COMMENT, AS_OPEN_COMMENT, AS_CLOSE_COMMENT;
+	static const string AS_BAR_DEFINE, AS_BAR_INCLUDE, AS_BAR_IF, AS_BAR_EL, AS_BAR_ENDIF;
+	static const string AS_AUTO, AS_RETURN;
+	static const string AS_CIN, AS_COUT, AS_CERR;
+	static const string AS_ASSIGN, AS_PLUS_ASSIGN, AS_MINUS_ASSIGN, AS_MULT_ASSIGN;
+	static const string AS_DIV_ASSIGN, AS_MOD_ASSIGN, AS_XOR_ASSIGN, AS_OR_ASSIGN, AS_AND_ASSIGN;
+	static const string AS_GR_GR_ASSIGN, AS_LS_LS_ASSIGN, AS_GR_GR_GR_ASSIGN, AS_LS_LS_LS_ASSIGN;
+	static const string AS_GCC_MIN_ASSIGN, AS_GCC_MAX_ASSIGN;
+	static const string AS_EQUAL, AS_PLUS_PLUS, AS_MINUS_MINUS, AS_NOT_EQUAL, AS_GR_EQUAL;
+	static const string AS_LS_EQUAL, AS_LS_LS_LS, AS_LS_LS, AS_GR_GR_GR, AS_GR_GR;
+	static const string AS_QUESTION_QUESTION, AS_LAMBDA;
+	static const string AS_ARROW, AS_AND, AS_OR;
+	static const string AS_SCOPE_RESOLUTION;
+	static const string AS_PLUS, AS_MINUS, AS_MULT, AS_DIV, AS_MOD, AS_GR, AS_LS;
+	static const string AS_NOT, AS_BIT_XOR, AS_BIT_OR, AS_BIT_AND, AS_BIT_NOT;
+	static const string AS_QUESTION, AS_COLON, AS_SEMICOLON, AS_COMMA;
+	static const string AS_ASM, AS__ASM__, AS_MS_ASM, AS_MS__ASM;
+	static const string AS_QFOREACH, AS_QFOREVER, AS_FOREVER;
+	static const string AS_FOREACH, AS_LOCK, AS_UNSAFE, AS_FIXED;
+	static const string AS_GET, AS_SET, AS_ADD, AS_REMOVE;
+	static const string AS_DELEGATE, AS_UNCHECKED;
+	static const string AS_CONST_CAST, AS_DYNAMIC_CAST, AS_REINTERPRET_CAST, AS_STATIC_CAST;
+	static const string AS_NS_DURING, AS_NS_HANDLER;
+};  // Class ASResource
+// Class ASBase
+// Functions definitions are at the end of ASResource.cpp.
+class ASBase : protected ASResource
+private:
+	// all variables should be set by the "init" function
+	int baseFileType;      // a value from enum FileType
+protected:
+	ASBase() : baseFileType(C_TYPE) { }
+protected:  // inline functions
+	void init(int fileTypeArg) { baseFileType = fileTypeArg; }
+	bool isCStyle() const { return (baseFileType == C_TYPE); }
+	bool isJavaStyle() const { return (baseFileType == JAVA_TYPE); }
+	bool isSharpStyle() const { return (baseFileType == SHARP_TYPE); }
+	bool isWhiteSpace(char ch) const { return (ch == ' ' || ch == '\t'); }
+protected:  // functions definitions are at the end of ASResource.cpp
+	const string* findHeader(const string& line, int i,
+	                         const vector<const string*>* possibleHeaders) const;
+	bool findKeyword(const string& line, int i, const string& keyword) const;
+	const string* findOperator(const string& line, int i,
+	                           const vector<const string*>* possibleOperators) const;
+	string getCurrentWord(const string& line, size_t index) const;
+	bool isDigit(char ch) const;
+	bool isLegalNameChar(char ch) const;
+	bool isCharPotentialHeader(const string& line, size_t i) const;
+	bool isCharPotentialOperator(char ch) const;
+	bool isDigitSeparator(const string& line, int i) const;
+	char peekNextChar(const string& line, int i) const;
+};  // Class ASBase
+// Class ASBeautifier
+class ASBeautifier : protected ASBase
+public:
+	ASBeautifier();
+	virtual ~ASBeautifier();
+	virtual void init(ASSourceIterator* iter);
+	virtual string beautify(const string& originalLine);
+	void setCaseIndent(bool state);
+	void setClassIndent(bool state);
+	void setContinuationIndentation(int indent = 1);
+	void setCStyle();
+	void setDefaultTabLength();
+	void setEmptyLineFill(bool state);
+	void setForceTabXIndentation(int length);
+	void setAfterParenIndent(bool state);
+	void setJavaStyle();
+	void setLabelIndent(bool state);
+	void setMaxContinuationIndentLength(int max);
+	void setMaxInStatementIndentLength(int max);
+	void setMinConditionalIndentOption(int min);
+	void setMinConditionalIndentLength();
+	void setModeManuallySet(bool state);
+	void setModifierIndent(bool state);
+	void setNamespaceIndent(bool state);
+	void setAlignMethodColon(bool state);
+	void setSharpStyle();
+	void setSpaceIndentation(int length = 4);
+	void setSwitchIndent(bool state);
+	void setTabIndentation(int length = 4, bool forceTabs = false);
+	void setPreprocDefineIndent(bool state);
+	void setPreprocConditionalIndent(bool state);
+	int  getBeautifierFileType() const;
+	int  getFileType() const;
+	int  getIndentLength() const;
+	int  getTabLength() const;
+	string getIndentString() const;
+	string getNextWord(const string& line, size_t currPos) const;
+	bool getAlignMethodColon() const;
+	bool getBraceIndent() const;
+	bool getBlockIndent() const;
+	bool getCaseIndent() const;
+	bool getClassIndent() const;
+	bool getEmptyLineFill() const;
+	bool getForceTabIndentation() const;
+	bool getModeManuallySet() const;
+	bool getModifierIndent() const;
+	bool getNamespaceIndent() const;
+	bool getPreprocDefineIndent() const;
+	bool getSwitchIndent() const;
+protected:
+	void deleteBeautifierVectors();
+	int  getNextProgramCharDistance(const string& line, int i) const;
+	int  indexOf(const vector<const string*>& container, const string* element) const;
+	void setBlockIndent(bool state);
+	void setBraceIndent(bool state);
+	void setBraceIndentVtk(bool state);
+	string extractPreprocessorStatement(const string& line) const;
+	string trim(const string& str) const;
+	string rtrim(const string& str) const;
+	// variables set by ASFormatter - must be updated in activeBeautifierStack
+	int  inLineNumber;
+	int  runInIndentContinuation;
+	int  nonInStatementBrace;
+	int  objCColonAlignSubsequent;		// for subsequent lines not counting indent
+	bool lineCommentNoBeautify;
+	bool isElseHeaderIndent;
+	bool isCaseHeaderCommentIndent;
+	bool isNonInStatementArray;
+	bool isSharpAccessor;
+	bool isSharpDelegate;
+	bool isInExternC;
+	bool isInBeautifySQL;
+	bool isInIndentableStruct;
+	bool isInIndentablePreproc;
+	ASBeautifier(const ASBeautifier& other);     // inline functions
+	ASBeautifier& operator=(ASBeautifier&);      // not to be implemented
+	void adjustObjCMethodDefinitionIndentation(const string& line_);
+	void adjustObjCMethodCallIndentation(const string& line_);
+	void adjustParsedLineIndentation(size_t iPrelim, bool isInExtraHeaderIndent);
+	void computePreliminaryIndentation();
+	void parseCurrentLine(const string& line);
+	void popLastContinuationIndent();
+	void processPreprocessor(const string& preproc, const string& line);
+	void registerContinuationIndent(const string& line, int i, int spaceIndentCount_,
+	                                int tabIncrementIn, int minIndent, bool updateParenStack);
+	void registerContinuationIndentColon(const string& line, int i, int tabIncrementIn);
+	void initVectors();
+	void initTempStacksContainer(vector<vector<const string*>*>*& container,
+	                             vector<vector<const string*>*>* value);
+	void clearObjCMethodDefinitionAlignment();
+	void deleteBeautifierContainer(vector<ASBeautifier*>*& container);
+	void deleteTempStacksContainer(vector<vector<const string*>*>*& container);
+	int  adjustIndentCountForBreakElseIfComments() const;
+	int  computeObjCColonAlignment(const string& line, int colonAlignPosition) const;
+	int  convertTabToSpaces(int i, int tabIncrementIn) const;
+	int  findObjCColonAlignment(const string& line) const;
+	int  getContinuationIndentAssign(const string& line, size_t currPos) const;
+	int  getContinuationIndentComma(const string& line, size_t currPos) const;
+	int  getObjCFollowingKeyword(const string& line, int bracePos) const;
+	bool isIndentedPreprocessor(const string& line, size_t currPos) const;
+	bool isLineEndComment(const string& line, int startPos) const;
+	bool isPreprocessorConditionalCplusplus(const string& line) const;
+	bool isInPreprocessorUnterminatedComment(const string& line);
+	bool isTopLevel() const;
+	bool statementEndsWithComma(const string& line, int index) const;
+	const string& getIndentedLineReturn(const string& newLine, const string& originalLine) const;
+	string getIndentedSpaceEquivalent(const string& line_) const;
+	string preLineWS(int lineIndentCount, int lineSpaceIndentCount) const;
+	template<typename T> void deleteContainer(T& container);
+	template<typename T> void initContainer(T& container, T value);
+	vector<vector<const string*>*>* copyTempStacks(const ASBeautifier& other) const;
+	pair<int, int> computePreprocessorIndent();
+	int beautifierFileType;
+	vector<const string*>* headers;
+	vector<const string*>* nonParenHeaders;
+	vector<const string*>* preBlockStatements;
+	vector<const string*>* preCommandHeaders;
+	vector<const string*>* assignmentOperators;
+	vector<const string*>* nonAssignmentOperators;
+	vector<const string*>* indentableHeaders;
+	vector<ASBeautifier*>* waitingBeautifierStack;
+	vector<ASBeautifier*>* activeBeautifierStack;
+	vector<int>* waitingBeautifierStackLengthStack;
+	vector<int>* activeBeautifierStackLengthStack;
+	vector<const string*>* headerStack;
+	vector<vector<const string*>* >* tempStacks;
+	vector<int>* parenDepthStack;
+	vector<bool>* blockStatementStack;
+	vector<bool>* parenStatementStack;
+	vector<bool>* braceBlockStateStack;
+	vector<int>* continuationIndentStack;
+	vector<int>* continuationIndentStackSizeStack;
+	vector<int>* parenIndentStack;
+	vector<pair<int, int> >* preprocIndentStack;
+	const string* currentHeader;
+	const string* previousLastLineHeader;
+	const string* probationHeader;
+	const string* lastLineHeader;
+	string indentString;
+	string verbatimDelimiter;
+	bool isInQuote;
+	bool isInVerbatimQuote;
+	bool haveLineContinuationChar;
+	bool isInAsm;
+	bool isInAsmOneLine;
+	bool isInAsmBlock;
+	bool isInComment;
+	bool isInPreprocessorComment;
+	bool isInRunInComment;
+	bool isInCase;
+	bool isInQuestion;
+	bool isContinuation;
+	bool isInHeader;
+	bool isInTemplate;
+	bool isInDefine;
+	bool isInDefineDefinition;
+	bool classIndent;
+	bool isIndentModeOff;
+	bool isInClassHeader;			// is in a class before the opening brace
+	bool isInClassHeaderTab;		// is in an indentable class header line
+	bool isInClassInitializer;		// is in a class after the ':' initializer
+	bool isInClass;					// is in a class after the opening brace
+	bool isInObjCMethodDefinition;
+	bool isInObjCMethodCall;
+	bool isInObjCMethodCallFirst;
+	bool isImmediatelyPostObjCMethodDefinition;
+	bool isImmediatelyPostObjCMethodCall;
+	bool isInIndentablePreprocBlock;
+	bool isInObjCInterface;
+	bool isInEnum;
+	bool isInEnumTypeID;
+	bool isInLet;
+	bool isInTrailingReturnType;
+	bool modifierIndent;
+	bool switchIndent;
+	bool caseIndent;
+	bool namespaceIndent;
+	bool blockIndent;
+	bool braceIndent;
+	bool braceIndentVtk;
+	bool shouldIndentAfterParen;
+	bool labelIndent;
+	bool shouldIndentPreprocDefine;
+	bool isInConditional;
+	bool isModeManuallySet;
+	bool shouldForceTabIndentation;
+	bool emptyLineFill;
+	bool backslashEndsPrevLine;
+	bool lineOpensWithLineComment;
+	bool lineOpensWithComment;
+	bool lineStartsInComment;
+	bool blockCommentNoIndent;
+	bool blockCommentNoBeautify;
+	bool previousLineProbationTab;
+	bool lineBeginsWithOpenBrace;
+	bool lineBeginsWithCloseBrace;
+	bool lineBeginsWithComma;
+	bool lineIsCommentOnly;
+	bool lineIsLineCommentOnly;
+	bool shouldIndentBracedLine;
+	bool isInSwitch;
+	bool foundPreCommandHeader;
+	bool foundPreCommandMacro;
+	bool shouldAlignMethodColon;
+	bool shouldIndentPreprocConditional;
+	int  indentCount;
+	int  spaceIndentCount;
+	int  spaceIndentObjCMethodAlignment;
+	int  bracePosObjCMethodAlignment;
+	int  colonIndentObjCMethodAlignment;
+	int  lineOpeningBlocksNum;
+	int  lineClosingBlocksNum;
+	int  fileType;
+	int  minConditionalOption;
+	int  minConditionalIndent;
+	int  parenDepth;
+	int  indentLength;
+	int  tabLength;
+	int  continuationIndent;
+	int  blockTabCount;
+	int  maxContinuationIndent;
+	int  classInitializerIndents;
+	int  templateDepth;
+	int  squareBracketCount;
+	int  prevFinalLineSpaceIndentCount;
+	int  prevFinalLineIndentCount;
+	int  defineIndentCount;
+	int  preprocBlockIndent;
+	char quoteChar;
+	char prevNonSpaceCh;
+	char currentNonSpaceCh;
+	char currentNonLegalCh;
+	char prevNonLegalCh;
+};  // Class ASBeautifier
+// Class ASEnhancer
+class ASEnhancer : protected ASBase
+	ASEnhancer();
+	virtual ~ASEnhancer();
+	void init(int, int, int, bool, bool, bool, bool, bool, bool, bool,
+	          vector<const pair<const string, const string>* >*);
+	void enhance(string& line, bool isInNamespace, bool isInPreprocessor, bool isInSQL);
+	void   convertForceTabIndentToSpaces(string&  line) const;
+	void   convertSpaceIndentToForceTab(string& line) const;
+	size_t findCaseColon(const string&  line, size_t caseIndex) const;
+	int    indentLine(string&  line, int indent) const;
+	bool   isBeginDeclareSectionSQL(const string&  line, size_t index) const;
+	bool   isEndDeclareSectionSQL(const string&  line, size_t index) const;
+	bool   isOneLineBlockReached(const string& line, int startChar) const;
+	void   parseCurrentLine(string& line, bool isInPreprocessor, bool isInSQL);
+	size_t processSwitchBlock(string&  line, size_t index);
+	int    unindentLine(string&  line, int unindent) const;
+private:
+	// options from command line or options file
+	int  indentLength;
+	int  tabLength;
+	bool useTabs;
+	bool forceTab;
+	bool caseIndent;
+	bool preprocBlockIndent;
+	bool preprocDefineIndent;
+	// parsing variables
+	int  lineNumber;
+	bool isInQuote;
+	bool isInComment;
+	char quoteChar;
+	// unindent variables
+	int  braceCount;
+	int  switchDepth;
+	int  eventPreprocDepth;
+	bool lookingForCaseBrace;
+	bool unindentNextLine;
+	bool shouldUnindentLine;
+	bool shouldUnindentComment;
+	// struct used by ParseFormattedLine function
+	// contains variables used to unindent the case blocks
+	struct SwitchVariables
+		int  switchBraceCount;
+		int  unindentDepth;
+		bool unindentCase;
+	SwitchVariables sw;                      // switch variables struct
+	vector<SwitchVariables> switchStack;     // stack vector of switch variables
+	// event table variables
+	bool nextLineIsEventIndent;             // begin event table indent is reached
+	bool isInEventTable;                    // need to indent an event table
+	vector<const pair<const string, const string>* >* indentableMacros;
+	// SQL variables
+	bool nextLineIsDeclareIndent;           // begin declare section indent is reached
+	bool isInDeclareSection;                // need to indent a declare section
+};  // Class ASEnhancer
+// Class ASFormatter
+class ASFormatter : public ASBeautifier
+	ASFormatter();
+	virtual ~ASFormatter();
+	virtual void init(ASSourceIterator* si);
+	virtual bool hasMoreLines() const;
+	virtual string nextLine();
+	LineEndFormat getLineEndFormat() const;
+	bool getIsLineReady() const;
+	void setFormattingStyle(FormatStyle style);
+	void setAddBracesMode(bool state);
+	void setAddOneLineBracesMode(bool state);
+	void setRemoveBracesMode(bool state);
+	void setAttachClass(bool state);
+	void setAttachClosingWhile(bool state);
+	void setAttachExternC(bool state);
+	void setAttachNamespace(bool state);
+	void setAttachInline(bool state);
+	void setBraceFormatMode(BraceMode mode);
+	void setBreakAfterMode(bool state);
+	void setBreakClosingHeaderBracesMode(bool state);
+	void setBreakBlocksMode(bool state);
+	void setBreakClosingHeaderBlocksMode(bool state);
+	void setBreakElseIfsMode(bool state);
+	void setBreakOneLineBlocksMode(bool state);
+	void setBreakOneLineHeadersMode(bool state);
+	void setBreakOneLineStatementsMode(bool state);
+	void setMethodPrefixPaddingMode(bool state);
+	void setMethodPrefixUnPaddingMode(bool state);
+	void setReturnTypePaddingMode(bool state);
+	void setReturnTypeUnPaddingMode(bool state);
+	void setParamTypePaddingMode(bool state);
+	void setParamTypeUnPaddingMode(bool state);
+	void setCloseTemplatesMode(bool state);
+	void setCommaPaddingMode(bool state);
+	void setDeleteEmptyLinesMode(bool state);
+	void setBreakReturnType(bool state);
+	void setBreakReturnTypeDecl(bool state);
+	void setAttachReturnType(bool state);
+	void setAttachReturnTypeDecl(bool state);
+	void setIndentCol1CommentsMode(bool state);
+	void setLineEndFormat(LineEndFormat fmt);
+	void setMaxCodeLength(int max);
+	void setObjCColonPaddingMode(ObjCColonPad mode);
+	void setOperatorPaddingMode(bool state);
+	void setParensOutsidePaddingMode(bool state);
+	void setParensFirstPaddingMode(bool state);
+	void setParensInsidePaddingMode(bool state);
+	void setParensHeaderPaddingMode(bool state);
+	void setParensUnPaddingMode(bool state);
+	void setPointerAlignment(PointerAlign alignment);
+	void setPreprocBlockIndent(bool state);
+	void setReferenceAlignment(ReferenceAlign alignment);
+	void setStripCommentPrefix(bool state);
+	void setTabSpaceConversionMode(bool state);
+	size_t getChecksumIn() const;
+	size_t getChecksumOut() const;
+	int  getChecksumDiff() const;
+	int  getFormatterFileType() const;
+	// retained for compatibility with release 2.06
+	// "Brackets" have been changed to "Braces" in 3.0
+	// they are referenced only by the old "bracket" options
+	void setAddBracketsMode(bool state);
+	void setAddOneLineBracketsMode(bool state);
+	void setRemoveBracketsMode(bool state);
+	void setBreakClosingHeaderBracketsMode(bool state);
+	ASFormatter(const ASFormatter& copy);       // not to be implemented
+	ASFormatter& operator=(ASFormatter&);       // not to be implemented
+	char peekNextChar() const;
+	BraceType getBraceType();
+	bool adjustChecksumIn(int adjustment);
+	bool computeChecksumIn(const string& currentLine_);
+	bool computeChecksumOut(const string& beautifiedLine);
+	bool addBracesToStatement();
+	bool removeBracesFromStatement();
+	bool commentAndHeaderFollows();
+	bool getNextChar();
+	bool getNextLine(bool emptyLineWasDeleted = false);
+	bool isArrayOperator() const;
+	bool isBeforeComment() const;
+	bool isBeforeAnyComment() const;
+	bool isBeforeAnyLineEndComment(int startPos) const;
+	bool isBeforeMultipleLineEndComments(int startPos) const;
+	bool isBraceType(BraceType a, BraceType b) const;
+	bool isClassInitializer() const;
+	bool isClosingHeader(const string* header) const;
+	bool isCurrentBraceBroken() const;
+	bool isDereferenceOrAddressOf() const;
+	bool isExecSQL(const string& line, size_t index) const;
+	bool isEmptyLine(const string& line) const;
+	bool isExternC() const;
+	bool isMultiStatementLine() const;
+	bool isNextWordSharpNonParenHeader(int startChar) const;
+	bool isNonInStatementArrayBrace() const;
+	bool isNumericVariable(string word) const;
+	bool isOkToSplitFormattedLine();
+	bool isPointerOrReference() const;
+	bool isPointerOrReferenceCentered() const;
+	bool isPointerOrReferenceVariable(const string& word) const;
+	bool isPointerToPointer(const string& line, int currPos) const;
+	bool isSharpStyleWithParen(const string* header) const;
+	bool isStructAccessModified(const string& firstLine, size_t index) const;
+	bool isIndentablePreprocessorBlock(const string& firstLine, size_t index);
+	bool isNDefPreprocStatement(const string& nextLine_, const string& preproc) const;
+	bool isUnaryOperator() const;
+	bool isUniformInitializerBrace() const;
+	bool isImmediatelyPostCast() const;
+	bool isInExponent() const;
+	bool isInSwitchStatement() const;
+	bool isNextCharOpeningBrace(int startChar) const;
+	bool isOkToBreakBlock(BraceType braceType) const;
+	bool isOperatorPaddingDisabled() const;
+	bool pointerSymbolFollows() const;
+	int  findObjCColonAlignment() const;
+	int  getCurrentLineCommentAdjustment();
+	int  getNextLineCommentAdjustment();
+	int  isOneLineBlockReached(const string& line, int startChar) const;
+	void adjustComments();
+	void appendChar(char ch, bool canBreakLine);
+	void appendCharInsideComments();
+	void appendClosingHeader();
+	void appendOperator(const string& sequence, bool canBreakLine = true);
+	void appendSequence(const string& sequence, bool canBreakLine = true);
+	void appendSpacePad();
+	void appendSpaceAfter();
+	void breakLine(bool isSplitLine = false);
+	void buildLanguageVectors();
+	void updateFormattedLineSplitPoints(char appendedChar);
+	void updateFormattedLineSplitPointsOperator(const string& sequence);
+	void checkIfTemplateOpener();
+	void clearFormattedLineSplitPoints();
+	void convertTabToSpaces();
+	void deleteContainer(vector<BraceType>*& container);
+	void findReturnTypeSplitPoint(const string& firstLine);
+	void formatArrayRunIn();
+	void formatRunIn();
+	void formatArrayBraces(BraceType braceType, bool isOpeningArrayBrace);
+	void formatClosingBrace(BraceType braceType);
+	void formatCommentBody();
+	void formatCommentOpener();
+	void formatCommentCloser();
+	void formatLineCommentBody();
+	void formatLineCommentOpener();
+	void formatOpeningBrace(BraceType braceType);
+	void formatQuoteBody();
+	void formatQuoteOpener();
+	void formatPointerOrReference();
+	void formatPointerOrReferenceCast();
+	void formatPointerOrReferenceToMiddle();
+	void formatPointerOrReferenceToName();
+	void formatPointerOrReferenceToType();
+	void fixOptionVariableConflicts();
+	void goForward(int i);
+	void isLineBreakBeforeClosingHeader();
+	void initContainer(vector<BraceType>*& container, vector<BraceType>* value);
+	void initNewLine();
+	void padObjCMethodColon();
+	void padObjCMethodPrefix();
+	void padObjCParamType();
+	void padObjCReturnType();
+	void padOperators(const string* newOperator);
+	void padParens();
+	void processPreprocessor();
+	void resetEndOfStatement();
+	void setAttachClosingBraceMode(bool state);
+	void stripCommentPrefix();
+	void testForTimeToSplitFormattedLine();
+	void trimContinuationLine();
+	void updateFormattedLineSplitPointsPointerOrReference(size_t index);
+	size_t findFormattedLineSplitPoint() const;
+	size_t findNextChar(const string& line, char searchChar, int searchStart = 0) const;
+	const string* checkForHeaderFollowingComment(const string& firstLine) const;
+	const string* getFollowingOperator() const;
+	string getPreviousWord(const string& line, int currPos) const;
+	string peekNextText(const string& firstLine,
+	                    bool endOnEmptyLine = false,
+	                    shared_ptr<ASPeekStream> streamArg = nullptr) const;
+	int formatterFileType;
+	vector<const string*>* preDefinitionHeaders;
+	vector<const string*>* operators;
+	vector<const string*>* castOperators;
+	vector<const pair<const string, const string>* >* indentableMacros;	// for ASEnhancer
+	ASEnhancer* enhancer;
+	vector<const string*>* preBraceHeaderStack;
+	vector<BraceType>* braceTypeStack;
+	vector<int>* parenStack;
+	vector<bool>* structStack;
+	vector<bool>* questionMarkStack;
+	string currentLine;
+	string formattedLine;
+	string readyFormattedLine;
+	char currentChar;
+	char previousChar;
+	char previousNonWSChar;
+	char previousCommandChar;
+	char quoteChar;
+	streamoff preprocBlockEnd;
+	int  charNum;
+	int  runInIndentChars;
+	int  nextLineSpacePadNum;
+	int  objCColonAlign;
+	int  preprocBraceTypeStackSize;
+	int  spacePadNum;
+	int  tabIncrementIn;
+	size_t checksumIn;
+	size_t checksumOut;
+	size_t currentLineFirstBraceNum;	// first brace location on currentLine
+	size_t formattedLineCommentNum;     // comment location on formattedLine
+	size_t leadingSpaces;
+	size_t maxCodeLength;
+	size_t methodAttachCharNum;
+	size_t methodAttachLineNum;
+	size_t methodBreakCharNum;
+	size_t methodBreakLineNum;
+	// possible split points
+	size_t maxSemi;			// probably a 'for' statement
+	size_t maxAndOr;		// probably an 'if' statement
+	size_t maxComma;
+	size_t maxParen;
+	size_t maxWhiteSpace;
+	size_t maxSemiPending;
+	size_t maxAndOrPending;
+	size_t maxCommaPending;
+	size_t maxParenPending;
+	size_t maxWhiteSpacePending;
+	size_t previousReadyFormattedLineLength;
+	FormatStyle formattingStyle;
+	BraceMode braceFormatMode;
+	BraceType previousBraceType;
+	PointerAlign pointerAlignment;
+	ReferenceAlign referenceAlignment;
+	ObjCColonPad objCColonPadMode;
+	LineEndFormat lineEnd;
+	bool isVirgin;
+	bool isInVirginLine;
+	bool shouldPadCommas;
+	bool shouldPadOperators;
+	bool shouldPadParensOutside;
+	bool shouldPadFirstParen;
+	bool shouldPadParensInside;
+	bool shouldPadHeader;
+	bool shouldStripCommentPrefix;
+	bool shouldUnPadParens;
+	bool shouldConvertTabs;
+	bool shouldIndentCol1Comments;
+	bool shouldIndentPreprocBlock;
+	bool shouldCloseTemplates;
+	bool shouldAttachExternC;
+	bool shouldAttachNamespace;
+	bool shouldAttachClass;
+	bool shouldAttachClosingWhile;
+	bool shouldAttachInline;
+	bool isInLineComment;
+	bool isInComment;
+	bool isInCommentStartLine;
+	bool noTrimCommentContinuation;
+	bool isInPreprocessor;
+	bool isInPreprocessorBeautify;
+	bool doesLineStartComment;
+	bool lineEndsInCommentOnly;
+	bool lineIsEmpty;
+	bool isImmediatelyPostCommentOnly;
+	bool isImmediatelyPostEmptyLine;
+	bool isInQuote;
+	bool isInQuoteContinuation;
+	bool isHeaderInMultiStatementLine;
+	bool isSpecialChar;
+	bool isNonParenHeader;
+	bool foundQuestionMark;
+	bool foundPreDefinitionHeader;
+	bool foundNamespaceHeader;
+	bool foundClassHeader;
+	bool foundStructHeader;
+	bool foundInterfaceHeader;
+	bool foundTrailingReturnType;
+	bool foundCastOperator;
+	bool isInLineBreak;
+	bool endOfAsmReached;
+	bool endOfCodeReached;
+	bool lineCommentNoIndent;
+	bool isFormattingModeOff;
+	bool isInEnum;
+	bool isInExecSQL;
+	bool isInAsm;
+	bool isLineReady;
+	bool elseHeaderFollowsComments;
+	bool caseHeaderFollowsComments;
+	bool isPreviousBraceBlockRelated;
+	bool isInPotentialCalculation;
+	bool isCharImmediatelyPostComment;
+	bool isPreviousCharPostComment;
+	bool isCharImmediatelyPostLineComment;
+	bool isCharImmediatelyPostOpenBlock;
+	bool isCharImmediatelyPostCloseBlock;
+	bool isCharImmediatelyPostTemplate;
+	bool isCharImmediatelyPostReturn;
+	bool isCharImmediatelyPostThrow;
+	bool isCharImmediatelyPostNewDelete;
+	bool isCharImmediatelyPostOperator;
+	bool isCharImmediatelyPostPointerOrReference;
+	bool isInObjCReturnType;
+	bool isInObjCParam;
+	bool isInObjCSelector;
+	bool breakCurrentOneLineBlock;
+	bool shouldRemoveNextClosingBrace;
+	bool isInBraceRunIn;
+	bool returnTypeChecked;
+	bool currentLineBeginsWithBrace;
+	bool attachClosingBraceMode;
+	bool shouldBreakOneLineBlocks;
+	bool shouldBreakOneLineHeaders;
+	bool shouldBreakOneLineStatements;
+	bool shouldBreakClosingHeaderBraces;
+	bool shouldBreakElseIfs;
+	bool shouldBreakLineAfterLogical;
+	bool shouldAddBraces;
+	bool shouldAddOneLineBraces;
+	bool shouldRemoveBraces;
+	bool shouldPadMethodColon;
+	bool shouldPadMethodPrefix;
+	bool shouldReparseCurrentChar;
+	bool shouldUnPadMethodPrefix;
+	bool shouldPadReturnType;
+	bool shouldUnPadReturnType;
+	bool shouldPadParamType;
+	bool shouldUnPadParamType;
+	bool shouldDeleteEmptyLines;
+	bool shouldBreakReturnType;
+	bool shouldBreakReturnTypeDecl;
+	bool shouldAttachReturnType;
+	bool shouldAttachReturnTypeDecl;
+	bool needHeaderOpeningBrace;
+	bool shouldBreakLineAtNextChar;
+	bool shouldKeepLineUnbroken;
+	bool passedSemicolon;
+	bool passedColon;
+	bool isImmediatelyPostNonInStmt;
+	bool isCharImmediatelyPostNonInStmt;
+	bool isImmediatelyPostComment;
+	bool isImmediatelyPostLineComment;
+	bool isImmediatelyPostEmptyBlock;
+	bool isImmediatelyPostObjCMethodPrefix;
+	bool isImmediatelyPostPreprocessor;
+	bool isImmediatelyPostReturn;
+	bool isImmediatelyPostThrow;
+	bool isImmediatelyPostNewDelete;
+	bool isImmediatelyPostOperator;
+	bool isImmediatelyPostTemplate;
+	bool isImmediatelyPostPointerOrReference;
+	bool shouldBreakBlocks;
+	bool shouldBreakClosingHeaderBlocks;
+	bool isPrependPostBlockEmptyLineRequested;
+	bool isAppendPostBlockEmptyLineRequested;
+	bool isIndentableProprocessor;
+	bool isIndentableProprocessorBlock;
+	bool prependEmptyLine;
+	bool appendOpeningBrace;
+	bool foundClosingHeader;
+	bool isInHeader;
+	bool isImmediatelyPostHeader;
+	bool isInCase;
+	bool isFirstPreprocConditional;
+	bool processedFirstConditional;
+	bool isJavaStaticConstructor;
+private:  // inline functions
+	// append the CURRENT character (curentChar) to the current formatted line.
+	void appendCurrentChar(bool canBreakLine = true)
+	{ appendChar(currentChar, canBreakLine); }
+	// check if a specific sequence exists in the current placement of the current line
+	bool isSequenceReached(const char* sequence) const
+	{ return currentLine.compare(charNum, strlen(sequence), sequence) == 0; }
+	// call ASBase::findHeader for the current character
+	const string* findHeader(const vector<const string*>* headers_)
+	{ return ASBase::findHeader(currentLine, charNum, headers_); }
+	// call ASBase::findOperator for the current character
+	const string* findOperator(const vector<const string*>* operators_)
+	{ return ASBase::findOperator(currentLine, charNum, operators_); }
+};  // Class ASFormatter
+// astyle namespace global declarations
+// sort comparison functions for ASResource
+bool sortOnLength(const string* a, const string* b);
+bool sortOnName(const string* a, const string* b);
+}   // namespace astyle
+// end of astyle namespace  --------------------------------------------------
+#endif // closes ASTYLE_H
diff --git a/tools/astyle/astyle_main.cpp b/tools/astyle/astyle_main.cpp
index 0000000..96ae075
--- /dev/null
+++ b/tools/astyle/astyle_main.cpp
@@ -0,0 +1,4312 @@
+// astyle_main.cpp
+ *   AStyle_main source file map.
+ *   This source file contains several classes.
+ *   They are arranged as follows.
+ *   namespace astyle {
+ *   ASStreamIterator methods
+ *   ASConsole methods
+ *      // Windows specific
+ *      // Linux specific
+ *   ASLibrary methods
+ *   ASOptions methods
+ *   ASEncoding methods
+ *   }  // end of astyle namespace
+ *   Global Area ---------------------------
+ *      Java Native Interface functions
+ *      AStyleMainUtf16 entry point
+ *      AStyleMain entry point
+ *      AStyleGetVersion entry point
+ *      main entry point
+// headers
+#include "astyle_main.h"
+#include <algorithm>
+#include <cerrno>
+#include <clocale>		// needed by some compilers
+#include <cstdlib>
+#include <fstream>
+#include <sstream>
+// includes for recursive getFileNames() function
+#ifdef _WIN32
+	#undef UNICODE		// use ASCII windows functions
+	#include <windows.h>
+#else
+	#include <dirent.h>
+	#include <unistd.h>
+	#include <sys/stat.h>
+	#ifdef __VMS
+		#include <unixlib.h>
+		#include <rms.h>
+		#include <ssdef.h>
+		#include <stsdef.h>
+		#include <lib$routines.h>
+		#include <starlet.h>
+	#endif /* __VMS */
+#endif
+// declarations
+// turn off MinGW automatic file globbing
+// this CANNOT be in the astyle namespace
+#ifndef ASTYLE_LIB
+	int _CRT_glob = 0;
+#endif
+namespace astyle {
+// console build variables
+#ifndef ASTYLE_LIB
+	#ifdef _WIN32
+		char g_fileSeparator = '\\';     // Windows file separator
+		bool g_isCaseSensitive = false;  // Windows IS NOT case sensitive
+	#else
+		char g_fileSeparator = '/';      // Linux file separator
+		bool g_isCaseSensitive = true;   // Linux IS case sensitive
+	#endif	// _WIN32
+#endif	// ASTYLE_LIB
+// java library build variables
+#ifdef ASTYLE_JNI
+	JNIEnv*   g_env;
+	jobject   g_obj;
+	jmethodID g_mid;
+#endif
+const char* g_version = "3.1";
+// ASStreamIterator class
+// typename will be stringstream for AStyle
+// it could be istream or wxChar for plug-ins
+template<typename T>
+ASStreamIterator<T>::ASStreamIterator(T* in)
+	inStream = in;
+	buffer.reserve(200);
+	eolWindows = 0;
+	eolLinux = 0;
+	eolMacOld = 0;
+	peekStart = 0;
+	prevLineDeleted = false;
+	checkForEmptyLine = false;
+	// get length of stream
+	inStream->seekg(0, inStream->end);
+	streamLength = inStream->tellg();
+	inStream->seekg(0, inStream->beg);
+ASStreamIterator<T>::~ASStreamIterator()
+* get the length of the input stream.
+* streamLength variable is set by the constructor.
+* @return     length of the input file stream, converted to an int.
+int ASStreamIterator<T>::getStreamLength() const
+	return static_cast<int>(streamLength);
+ * read the input stream, delete any end of line characters,
+ *     and build a string that contains the input line.
+ * @return        string containing the next input line minus any end of line characters
+string ASStreamIterator<T>::nextLine(bool emptyLineWasDeleted)
+	// verify that the current position is correct
+	assert(peekStart == 0);
+	// a deleted line may be replaced if break-blocks is requested
+	// this sets up the compare to check for a replaced empty line
+	if (prevLineDeleted)
+		checkForEmptyLine = true;
+	if (!emptyLineWasDeleted)
+		prevBuffer = buffer;
+	else
+		prevLineDeleted = true;
+	// read the next record
+	buffer.clear();
+	char ch;
+	inStream->get(ch);
+	while (!inStream->eof() && ch != '\n' && ch != '\r')
+		buffer.append(1, ch);
+	if (inStream->eof())
+		return buffer;
+	int peekCh = inStream->peek();
+	// find input end-of-line characters
+	if (!inStream->eof())
+		if (ch == '\r')         // CR+LF is windows otherwise Mac OS 9
+			if (peekCh == '\n')
+				inStream->get();
+				eolWindows++;
+			else
+				eolMacOld++;
+		else                    // LF is Linux, allow for improbable LF/CR
+			if (peekCh == '\r')
+				inStream->get();
+				eolWindows++;
+			else
+				eolLinux++;
+	else
+		inStream->clear();
+	// has not detected an input end of line
+	if (!eolWindows && !eolLinux && !eolMacOld)
+#ifdef _WIN32
+		eolWindows++;
+#else
+		eolLinux++;
+#endif
+	// set output end of line characters
+	if (eolWindows >= eolLinux)
+		if (eolWindows >= eolMacOld)
+			outputEOL = "\r\n";     // Windows (CR+LF)
+		else
+			outputEOL = "\r";       // MacOld (CR)
+	else if (eolLinux >= eolMacOld)
+		outputEOL = "\n";           // Linux (LF)
+	else
+	return buffer;
+// save the current position and get the next line
+// this can be called for multiple reads
+// when finished peeking you MUST call peekReset()
+// call this function from ASFormatter ONLY
+string ASStreamIterator<T>::peekNextLine()
+	assert(hasMoreLines());
+	string nextLine_;
+	char ch;
+	if (peekStart == 0)
+		peekStart = inStream->tellg();
+		nextLine_.append(1, ch);
+		return nextLine_;
+	// remove end-of-line characters
+		if ((peekCh == '\n' || peekCh == '\r') && peekCh != ch)
+			inStream->get();
+	return nextLine_;
+// reset current position and EOF for peekNextLine()
+void ASStreamIterator<T>::peekReset()
+	assert(peekStart != 0);
+	inStream->seekg(peekStart);
+	peekStart = 0;
+// save the last input line after input has reached EOF
+void ASStreamIterator<T>::saveLastInputLine()
+	assert(inStream->eof());
+// return position of the get pointer
+streamoff ASStreamIterator<T>::tellg()
+	return inStream->tellg();
+// check for a change in line ends
+bool ASStreamIterator<T>::getLineEndChange(int lineEndFormat) const
+	assert(lineEndFormat == LINEEND_DEFAULT
+	       || lineEndFormat == LINEEND_WINDOWS
+	       || lineEndFormat == LINEEND_LINUX
+	       || lineEndFormat == LINEEND_MACOLD);
+	bool lineEndChange = false;
+	if (lineEndFormat == LINEEND_WINDOWS)
+		lineEndChange = (eolLinux + eolMacOld != 0);
+	else if (lineEndFormat == LINEEND_LINUX)
+		lineEndChange = (eolWindows + eolMacOld != 0);
+	else if (lineEndFormat == LINEEND_MACOLD)
+		lineEndChange = (eolWindows + eolLinux != 0);
+	else
+		if (eolWindows > 0)
+		else if (eolLinux > 0)
+		else if (eolMacOld > 0)
+	return lineEndChange;
+// ASConsole class
+// main function will be included only in the console build
+#ifndef ASTYLE_LIB
+ASConsole::ASConsole(ASFormatter& formatterArg) : formatter(formatterArg)
+	errorStream = &cerr;
+	// command line options
+	isRecursive = false;
+	isDryRun = false;
+	noBackup = false;
+	preserveDate = false;
+	isVerbose = false;
+	isQuiet = false;
+	isFormattedOnly = false;
+	ignoreExcludeErrors = false;
+	ignoreExcludeErrorsDisplay = false;
+	useAscii = false;
+	// other variables
+	bypassBrowserOpen = false;
+	hasWildcard = false;
+	filesAreIdentical = true;
+	lineEndsMixed = false;
+	origSuffix = ".orig";
+	mainDirectoryLength = 0;
+	filesFormatted = 0;
+	filesUnchanged = 0;
+	linesOut = 0;
+ASConsole::~ASConsole()
+// rewrite a stringstream converting the line ends
+void ASConsole::convertLineEnds(ostringstream& out, int lineEnd)
+	assert(lineEnd == LINEEND_WINDOWS || lineEnd == LINEEND_LINUX || lineEnd == LINEEND_MACOLD);
+	const string& inStr = out.str();	// avoids strange looking syntax
+	string outStr;						// the converted output
+	int inLength = (int) inStr.length();
+	for (int pos = 0; pos < inLength; pos++)
+		if (inStr[pos] == '\r')
+			if (inStr[pos + 1] == '\n')
+				// CRLF
+				if (lineEnd == LINEEND_CR)
+					outStr += inStr[pos];		// Delete the LF
+					pos++;
+					continue;
+				else if (lineEnd == LINEEND_LF)
+					outStr += inStr[pos + 1];		// Delete the CR
+					pos++;
+					continue;
+				else
+					outStr += inStr[pos];		// Do not change
+					pos++;
+					continue;
+			else
+				// CR
+				if (lineEnd == LINEEND_CRLF)
+					outStr += inStr[pos];		// Insert the CR
+					outStr += '\n';				// Insert the LF
+					continue;
+					continue;
+				else
+					continue;
+		else if (inStr[pos] == '\n')
+			// LF
+				outStr += '\r';				// Insert the CR
+				outStr += inStr[pos];		// Insert the LF
+				continue;
+			else if (lineEnd == LINEEND_CR)
+				continue;
+			else
+				continue;
+		else
+			outStr += inStr[pos];		// Write the current char
+	// replace the stream
+	out.str(outStr);
+void ASConsole::correctMixedLineEnds(ostringstream& out)
+	LineEndFormat lineEndFormat = LINEEND_DEFAULT;
+	if (outputEOL == "\r\n")
+		lineEndFormat = LINEEND_WINDOWS;
+	if (outputEOL == "\n")
+		lineEndFormat = LINEEND_LINUX;
+	if (outputEOL == "\r")
+		lineEndFormat = LINEEND_MACOLD;
+	convertLineEnds(out, lineEndFormat);
+// check files for 16 or 32 bit encoding
+// the file must have a Byte Order Mark (BOM)
+// NOTE: some string functions don't work with NULLs (e.g. length())
+FileEncoding ASConsole::detectEncoding(const char* data, size_t dataSize) const
+	FileEncoding encoding = ENCODING_8BIT;
+	if (dataSize >= 3 && memcmp(data, "\xEF\xBB\xBF", 3) == 0)
+		encoding = UTF_8BOM;
+	else if (dataSize >= 4 && memcmp(data, "\x00\x00\xFE\xFF", 4) == 0)
+		encoding = UTF_32BE;
+	else if (dataSize >= 4 && memcmp(data, "\xFF\xFE\x00\x00", 4) == 0)
+		encoding = UTF_32LE;
+	else if (dataSize >= 2 && memcmp(data, "\xFE\xFF", 2) == 0)
+		encoding = UTF_16BE;
+	else if (dataSize >= 2 && memcmp(data, "\xFF\xFE", 2) == 0)
+		encoding = UTF_16LE;
+	return encoding;
+// error exit without a message
+void ASConsole::error() const
+	(*errorStream) << _("Artistic Style has terminated\n") << endl;
+	exit(EXIT_FAILURE);
+// error exit with a message
+void ASConsole::error(const char* why, const char* what) const
+	(*errorStream) << why << ' ' << what << endl;
+	error();
+ * If no files have been given, use cin for input and cout for output.
+ * This is used to format text for text editors.
+ * Do NOT display any console messages when this function is used.
+void ASConsole::formatCinToCout()
+	// check for files from --stdin= and --stdout=
+	if (!stdPathIn.empty())
+		if (!freopen(stdPathIn.c_str(), "r", stdin))
+			error("Cannot open input file", stdPathIn.c_str());
+	if (!stdPathOut.empty())
+		if (!freopen(stdPathOut.c_str(), "w", stdout))
+			error("Cannot open output file", stdPathOut.c_str());
+	// Using cin.tellg() causes problems with both Windows and Linux.
+	// The Windows problem occurs when the input is not Windows line-ends.
+	// The tellg() will be out of sequence with the get() statements.
+	// The Linux cin.tellg() will return -1 (invalid).
+	// Copying the input sequentially to a stringstream before
+	// formatting solves the problem for both.
+	istream* inStream = &cin;
+	stringstream outStream;
+	char ch;
+	while (!inStream->eof() && !inStream->fail())
+		outStream.put(ch);
+	ASStreamIterator<stringstream> streamIterator(&outStream);
+	// Windows pipe or redirection always outputs Windows line-ends.
+	// Linux pipe or redirection will output any line end.
+#ifdef _WIN32
+#else
+	LineEndFormat lineEndFormat = formatter.getLineEndFormat();
+#endif // _WIN32
+	initializeOutputEOL(lineEndFormat);
+	formatter.init(&streamIterator);
+	while (formatter.hasMoreLines())
+		cout << formatter.nextLine();
+		if (formatter.hasMoreLines())
+			setOutputEOL(lineEndFormat, streamIterator.getOutputEOL());
+			cout << outputEOL;
+		else
+			// this can happen if the file if missing a closing brace and break-blocks is requested
+			if (formatter.getIsLineReady())
+	cout.flush();
+ * Open input file, format it, and close the output.
+ * @param fileName_     The path and name of the file to be processed.
+void ASConsole::formatFile(const string& fileName_)
+	stringstream in;
+	ostringstream out;
+	FileEncoding encoding = readFile(fileName_, in);
+	// Unless a specific language mode has been set, set the language mode
+	// according to the file's suffix.
+	if (!formatter.getModeManuallySet())
+		if (stringEndsWith(fileName_, string(".java")))
+			formatter.setJavaStyle();
+		else if (stringEndsWith(fileName_, string(".cs")))
+			formatter.setSharpStyle();
+		else
+			formatter.setCStyle();
+	// set line end format
+	string nextLine;				// next output line
+	filesAreIdentical = true;		// input and output files are identical
+	// do this AFTER setting the file mode
+	ASStreamIterator<stringstream> streamIterator(&in);
+	// format the file
+		nextLine = formatter.nextLine();
+		out << nextLine;
+		linesOut++;
+			out << outputEOL;
+		else
+			streamIterator.saveLastInputLine();     // to compare the last input line
+				out << outputEOL;
+				out << nextLine;
+				linesOut++;
+		if (filesAreIdentical)
+			if (streamIterator.checkForEmptyLine)
+				if (nextLine.find_first_not_of(" \t") != string::npos)
+					filesAreIdentical = false;
+			else if (!streamIterator.compareToInputBuffer(nextLine))
+			streamIterator.checkForEmptyLine = false;
+	// correct for mixed line ends
+	if (lineEndsMixed)
+		correctMixedLineEnds(out);
+	// remove targetDirectory from filename if required by print
+	string displayName;
+	if (hasWildcard)
+		displayName = fileName_.substr(targetDirectory.length() + 1);
+	else
+		displayName = fileName_;
+	// if file has changed, write the new file
+	if (!filesAreIdentical || streamIterator.getLineEndChange(lineEndFormat))
+		if (!isDryRun)
+			writeFile(fileName_, encoding, out);
+		printMsg(_("Formatted  %s\n"), displayName);
+		filesFormatted++;
+	else
+		if (!isFormattedOnly)
+			printMsg(_("Unchanged  %s\n"), displayName);
+		filesUnchanged++;
+	assert(formatter.getChecksumDiff() == 0);
+ * Searches for a file named fileName_ in the current directory. If it is not
+ * found, recursively searches for fileName_ in the current directory's parent
+ * directories, returning the location of the first instance of fileName_
+ * found. If fileName_ is not found, an empty string is returned.
+ * @param fileName_     The filename the function should attempt to locate.
+ * @return              The full path to fileName_ in the current directory or
+ *                      nearest parent directory if found, otherwise an empty
+ *                      string.
+string ASConsole::findProjectOptionFilePath(const string& fileName_) const
+	string parent;
+	if (!fileNameVector.empty())
+		parent = getFullPathName(fileNameVector.front());
+	else if (!stdPathIn.empty())
+		parent = getFullPathName(stdPathIn);
+	else
+		parent = getFullPathName(getCurrentDirectory(fileName_));
+	// remove filename from path
+	size_t endPath = parent.find_last_of(g_fileSeparator);
+	if (endPath != string::npos)
+		parent = parent.substr(0, endPath + 1);
+	while (!parent.empty())
+		string filepath = parent + fileName_;
+		if (fileExists(filepath.c_str()))
+			return filepath;
+		else if (fileName_ == ".astylerc")
+			filepath = parent + "_astylerc";
+				return filepath;
+		parent = getParentDirectory(parent);
+	return string();
+// for unit testing
+vector<bool> ASConsole::getExcludeHitsVector() const
+{ return excludeHitsVector; }
+vector<string> ASConsole::getExcludeVector() const
+{ return excludeVector; }
+vector<string> ASConsole::getFileName() const
+{ return fileName; }
+vector<string> ASConsole::getFileNameVector() const
+{ return fileNameVector; }
+vector<string> ASConsole::getFileOptionsVector() const
+{ return fileOptionsVector; }
+bool ASConsole::getFilesAreIdentical() const
+{ return filesAreIdentical; }
+int ASConsole::getFilesFormatted() const
+{ return filesFormatted; }
+bool ASConsole::getIgnoreExcludeErrors() const
+{ return ignoreExcludeErrors; }
+bool ASConsole::getIgnoreExcludeErrorsDisplay() const
+{ return ignoreExcludeErrorsDisplay; }
+bool ASConsole::getIsDryRun() const
+{ return isDryRun; }
+bool ASConsole::getIsFormattedOnly() const
+{ return isFormattedOnly; }
+string ASConsole::getLanguageID() const
+{ return localizer.getLanguageID(); }
+bool ASConsole::getIsQuiet() const
+{ return isQuiet; }
+bool ASConsole::getIsRecursive() const
+{ return isRecursive; }
+bool ASConsole::getIsVerbose() const
+{ return isVerbose; }
+bool ASConsole::getLineEndsMixed() const
+{ return lineEndsMixed; }
+bool ASConsole::getNoBackup() const
+{ return noBackup; }
+string ASConsole::getOptionFileName() const
+{ return optionFileName; }
+vector<string> ASConsole::getOptionsVector() const
+{ return optionsVector; }
+string ASConsole::getOrigSuffix() const
+{ return origSuffix; }
+bool ASConsole::getPreserveDate() const
+{ return preserveDate; }
+string ASConsole::getProjectOptionFileName() const
+	assert(projectOptionFileName.length() > 0);
+	// remove the directory path
+	size_t start = projectOptionFileName.find_last_of(g_fileSeparator);
+	if (start == string::npos)
+		start = 0;
+	return projectOptionFileName.substr(start + 1);
+vector<string> ASConsole::getProjectOptionsVector() const
+{ return projectOptionsVector; }
+string ASConsole::getStdPathIn() const
+{ return stdPathIn; }
+string ASConsole::getStdPathOut() const
+{ return stdPathOut; }
+void ASConsole::setBypassBrowserOpen(bool state)
+{ bypassBrowserOpen = state; }
+ostream* ASConsole::getErrorStream() const
+	return errorStream;
+void ASConsole::setErrorStream(ostream* errStreamPtr)
+	errorStream = errStreamPtr;
+// build a vector of argv options
+// the program path argv[0] is excluded
+vector<string> ASConsole::getArgvOptions(int argc, char** argv) const
+	vector<string> argvOptions;
+	for (int i = 1; i < argc; i++)
+		argvOptions.emplace_back(string(argv[i]));
+	return argvOptions;
+string ASConsole::getParam(const string& arg, const char* op)
+	return arg.substr(strlen(op));
+void ASConsole::getTargetFilenames(string& targetFilename_,
+                                   vector<string>& targetFilenameVector) const
+	size_t beg = 0;
+	size_t sep = 0;
+	while (beg < targetFilename_.length())
+		// find next target
+		sep = targetFilename_.find_first_of(",;", beg);
+		if (sep == string::npos)
+			sep = targetFilename_.length();
+		string fileExtension = targetFilename_.substr(beg, sep - beg);
+		beg = sep + 1;
+		// remove whitespace
+		while (fileExtension.length() > 0
+		        && (fileExtension[0] == ' ' || fileExtension[0] == '\t'))
+			fileExtension = fileExtension.erase(0, 1);
+		        && (fileExtension[fileExtension.length() - 1] == ' '
+		            || fileExtension[fileExtension.length() - 1] == '\t'))
+			fileExtension = fileExtension.erase(fileExtension.length() - 1, 1);
+		if (fileExtension.length() > 0)
+			targetFilenameVector.emplace_back(fileExtension);
+	if (targetFilenameVector.size() == 0)
+		fprintf(stderr, _("Missing filename in %s\n"), targetFilename_.c_str());
+		error();
+// initialize output end of line
+void ASConsole::initializeOutputEOL(LineEndFormat lineEndFormat)
+	outputEOL.clear();			// current line end
+	prevEOL.clear();			// previous line end
+	lineEndsMixed = false;		// output has mixed line ends, LINEEND_DEFAULT only
+		outputEOL = "\n";
+		outputEOL = "\r";
+	else
+// read a file into the stringstream 'in'
+FileEncoding ASConsole::readFile(const string& fileName_, stringstream& in) const
+	const int blockSize = 65536;	// 64 KB
+	ifstream fin(fileName_.c_str(), ios::binary);
+	if (!fin)
+		error("Cannot open file", fileName_.c_str());
+	char* data = new (nothrow) char[blockSize];
+	if (data == nullptr)
+		error("Cannot allocate memory to open file", fileName_.c_str());
+	fin.read(data, blockSize);
+	if (fin.bad())
+		error("Cannot read file", fileName_.c_str());
+	size_t dataSize = static_cast<size_t>(fin.gcount());
+	FileEncoding encoding = detectEncoding(data, dataSize);
+	if (encoding == UTF_32BE || encoding == UTF_32LE)
+		error(_("Cannot process UTF-32 encoding"), fileName_.c_str());
+	bool firstBlock = true;
+	bool isBigEndian = (encoding == UTF_16BE);
+	while (dataSize != 0)
+		if (encoding == UTF_16LE || encoding == UTF_16BE)
+			// convert utf-16 to utf-8
+			size_t utf8Size = encode.utf8LengthFromUtf16(data, dataSize, isBigEndian);
+			char* utf8Out = new (nothrow) char[utf8Size];
+			if (utf8Out == nullptr)
+				error("Cannot allocate memory for utf-8 conversion", fileName_.c_str());
+			size_t utf8Len = encode.utf16ToUtf8(data, dataSize, isBigEndian, firstBlock, utf8Out);
+			assert(utf8Len <= utf8Size);
+			in << string(utf8Out, utf8Len);
+			delete[] utf8Out;
+		else
+			in << string(data, dataSize);
+		if (fin.bad())
+		dataSize = static_cast<size_t>(fin.gcount());
+		firstBlock = false;
+	fin.close();
+	delete[] data;
+	return encoding;
+void ASConsole::setIgnoreExcludeErrors(bool state)
+{ ignoreExcludeErrors = state; }
+void ASConsole::setIgnoreExcludeErrorsAndDisplay(bool state)
+{ ignoreExcludeErrors = state; ignoreExcludeErrorsDisplay = state; }
+void ASConsole::setIsFormattedOnly(bool state)
+{ isFormattedOnly = state; }
+void ASConsole::setIsQuiet(bool state)
+{ isQuiet = state; }
+void ASConsole::setIsRecursive(bool state)
+{ isRecursive = state; }
+void ASConsole::setIsDryRun(bool state)
+{ isDryRun = state; }
+void ASConsole::setIsVerbose(bool state)
+{ isVerbose = state; }
+void ASConsole::setNoBackup(bool state)
+{ noBackup = state; }
+void ASConsole::setOptionFileName(const string& name)
+{ optionFileName = name; }
+void ASConsole::setOrigSuffix(const string& suffix)
+{ origSuffix = suffix; }
+void ASConsole::setPreserveDate(bool state)
+{ preserveDate = state; }
+void ASConsole::setProjectOptionFileName(const string& optfilepath)
+{ projectOptionFileName = optfilepath; }
+void ASConsole::setStdPathIn(const string& path)
+{ stdPathIn = path; }
+void ASConsole::setStdPathOut(const string& path)
+{ stdPathOut = path; }
+// set outputEOL variable
+void ASConsole::setOutputEOL(LineEndFormat lineEndFormat, const string& currentEOL)
+	if (lineEndFormat == LINEEND_DEFAULT)
+		outputEOL = currentEOL;
+		if (prevEOL.empty())
+			prevEOL = outputEOL;
+		if (prevEOL != outputEOL)
+			lineEndsMixed = true;
+	else
+		prevEOL = currentEOL;
+#ifdef _WIN32  // Windows specific
+ * WINDOWS function to display the last system error.
+void ASConsole::displayLastError()
+	LPSTR msgBuf;
+	DWORD lastError = GetLastError();
+	FormatMessage(FORMAT_MESSAGE_ALLOCATE_BUFFER | FORMAT_MESSAGE_FROM_SYSTEM,
+	              nullptr,
+	              lastError,
+	              MAKELANGID(LANG_NEUTRAL, SUBLANG_DEFAULT),  // Default language
+	              (LPSTR) &msgBuf,
+	              0,
+	              nullptr
+	// Display the string.
+	(*errorStream) << "Error (" << lastError << ") " << msgBuf << endl;
+	// Free the buffer.
+	LocalFree(msgBuf);
+ * WINDOWS function to get the current directory.
+ * NOTE: getenv("CD") does not work for Windows Vista.
+ *        The Windows function GetCurrentDirectory is used instead.
+ * @return              The path of the current directory
+string ASConsole::getCurrentDirectory(const string& fileName_) const
+	char currdir[MAX_PATH];
+	currdir[0] = '\0';
+	if (!GetCurrentDirectory(sizeof(currdir), currdir))
+		error("Cannot find file", fileName_.c_str());
+	return string(currdir);
+ * WINDOWS function to resolve wildcards and recurse into sub directories.
+ * The fileName vector is filled with the path and names of files to process.
+ * @param directory     The path of the directory to be processed.
+ * @param wildcards     A vector of wildcards to be processed (e.g. *.cpp).
+void ASConsole::getFileNames(const string& directory, const vector<string>& wildcards)
+	vector<string> subDirectory;    // sub directories of directory
+	WIN32_FIND_DATA findFileData;   // for FindFirstFile and FindNextFile
+	// Find the first file in the directory
+	// Find will get at least "." and "..".
+	string firstFile = directory + "\\*";
+	HANDLE hFind = FindFirstFile(firstFile.c_str(), &findFileData);
+	if (hFind == INVALID_HANDLE_VALUE)
+		// Error (3) The system cannot find the path specified.
+		// Error (123) The filename, directory name, or volume label syntax is incorrect.
+		// ::FindClose(hFind); before exiting
+		displayLastError();
+		error(_("Cannot open directory"), directory.c_str());
+	// save files and sub directories
+	do
+		// skip hidden or read only
+		if (findFileData.cFileName[0] == '.'
+		        || (findFileData.dwFileAttributes & FILE_ATTRIBUTE_HIDDEN)
+		        || (findFileData.dwFileAttributes & FILE_ATTRIBUTE_READONLY))
+			continue;
+		// is this a sub directory
+		if (findFileData.dwFileAttributes & FILE_ATTRIBUTE_DIRECTORY)
+			if (!isRecursive)
+				continue;
+			// if a sub directory and recursive, save sub directory
+			string subDirectoryPath = directory + g_fileSeparator + findFileData.cFileName;
+			if (isPathExclued(subDirectoryPath))
+				printMsg(_("Exclude  %s\n"), subDirectoryPath.substr(mainDirectoryLength));
+			else
+				subDirectory.emplace_back(subDirectoryPath);
+			continue;
+		string filePathName = directory + g_fileSeparator + findFileData.cFileName;
+		// check exclude before wildcmp to avoid "unmatched exclude" error
+		bool isExcluded = isPathExclued(filePathName);
+		// save file name if wildcard match
+		for (size_t i = 0; i < wildcards.size(); i++)
+			if (wildcmp(wildcards[i].c_str(), findFileData.cFileName))
+				if (isExcluded)
+					printMsg(_("Exclude  %s\n"), filePathName.substr(mainDirectoryLength));
+				else
+					fileName.emplace_back(filePathName);
+				break;
+	while (FindNextFile(hFind, &findFileData) != 0);
+	// check for processing error
+	::FindClose(hFind);
+	DWORD dwError = GetLastError();
+	if (dwError != ERROR_NO_MORE_FILES)
+		error("Error processing directory", directory.c_str());
+	// recurse into sub directories
+	// if not doing recursive subDirectory is empty
+	for (unsigned i = 0; i < subDirectory.size(); i++)
+		getFileNames(subDirectory[i], wildcards);
+	return;
+// WINDOWS function to get the full path name from the relative path name
+// Return the full path name or an empty string if failed.
+string ASConsole::getFullPathName(const string& relativePath) const
+	char fullPath[MAX_PATH];
+	GetFullPathName(relativePath.c_str(), MAX_PATH, fullPath, NULL);
+	return fullPath;
+ * WINDOWS function to format a number according to the current locale.
+ * This formats positive integers only, no float.
+ * @param num		The number to be formatted.
+ * @param lcid		The LCID of the locale to be used for testing.
+ * @return			The formatted number.
+string ASConsole::getNumberFormat(int num, size_t lcid) const
+#if defined(_MSC_VER) || defined(__MINGW32__) || defined(__BORLANDC__) || defined(__GNUC__)
+	// Compilers that don't support C++ locales should still support this assert.
+	// The C locale should be set but not the C++.
+	// This function is not necessary if the C++ locale is set.
+	// The locale().name() return value is not portable to all compilers.
+	assert(locale().name() == "C");
+#endif
+	// convert num to a string
+	stringstream alphaNum;
+	alphaNum << num;
+	string number = alphaNum.str();
+	if (useAscii)
+		return number;
+	// format the number using the Windows API
+	if (lcid == 0)
+		lcid = LOCALE_USER_DEFAULT;
+	int outSize = ::GetNumberFormat(lcid, 0, number.c_str(), nullptr, nullptr, 0);
+	char* outBuf = new (nothrow) char[outSize];
+	if (outBuf == nullptr)
+		return number;
+	::GetNumberFormat(lcid, 0, number.c_str(), nullptr, outBuf, outSize);
+	string formattedNum(outBuf);
+	delete[] outBuf;
+	// remove the decimal
+	int decSize = ::GetLocaleInfo(lcid, LOCALE_SDECIMAL, nullptr, 0);
+	char* decBuf = new (nothrow) char[decSize];
+	if (decBuf == nullptr)
+		return number;
+	::GetLocaleInfo(lcid, LOCALE_SDECIMAL, decBuf, decSize);
+	size_t i = formattedNum.rfind(decBuf);
+	delete[] decBuf;
+	if (i != string::npos)
+		formattedNum.erase(i);
+	if (!formattedNum.length())
+		formattedNum = "0";
+	return formattedNum;
+ * WINDOWS function to check for a HOME directory
+ * @param absPath       The path to be evaluated.
+ * @returns             true if absPath is HOME or is an invalid absolute
+ *                      path, false otherwise.
+bool ASConsole::isHomeOrInvalidAbsPath(const string& absPath) const
+	char* env = getenv("USERPROFILE");
+	if (env == nullptr)
+		return true;
+	if (absPath.c_str() == env)
+		return true;
+	if (absPath.compare(0, strlen(env), env) != 0)
+		return true;
+	return false;
+ * WINDOWS function to open a HTML file in the default browser.
+void ASConsole::launchDefaultBrowser(const char* filePathIn /*nullptr*/) const
+	struct stat statbuf;
+	const char* envPaths[] = { "PROGRAMFILES(X86)", "PROGRAMFILES" };
+	size_t pathsLen = sizeof(envPaths) / sizeof(envPaths[0]);
+	string htmlDefaultPath;
+	for (size_t i = 0; i < pathsLen; i++)
+		const char* envPath = getenv(envPaths[i]);
+		if (envPath == nullptr)
+			continue;
+		htmlDefaultPath = envPath;
+		if (htmlDefaultPath.length() > 0
+		        && htmlDefaultPath[htmlDefaultPath.length() - 1] == g_fileSeparator)
+			htmlDefaultPath.erase(htmlDefaultPath.length() - 1);
+		htmlDefaultPath.append("\\AStyle\\doc");
+		if (stat(htmlDefaultPath.c_str(), &statbuf) == 0 && statbuf.st_mode & S_IFDIR)
+			break;
+	htmlDefaultPath.append("\\");
+	// build file path
+	string htmlFilePath;
+	if (filePathIn == nullptr)
+		htmlFilePath = htmlDefaultPath + "astyle.html";
+	else
+		if (strpbrk(filePathIn, "\\/") == nullptr)
+			htmlFilePath = htmlDefaultPath + filePathIn;
+		else
+			htmlFilePath = filePathIn;
+	standardizePath(htmlFilePath);
+	if (stat(htmlFilePath.c_str(), &statbuf) != 0 || !(statbuf.st_mode & S_IFREG))
+		printf(_("Cannot open HTML file %s\n"), htmlFilePath.c_str());
+		return;
+	SHELLEXECUTEINFO sei = { sizeof(sei), 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 };
+	sei.fMask = SEE_MASK_FLAG_NO_UI;
+	sei.lpVerb = "open";
+	sei.lpFile = htmlFilePath.c_str();
+	sei.nShow = SW_SHOWNORMAL;
+	// browser open will be bypassed in test programs
+	printf(_("Opening HTML documentation %s\n"), htmlFilePath.c_str());
+	if (!bypassBrowserOpen)
+		int ret = ShellExecuteEx(&sei);
+		if (!ret)
+			error(_("Command execute failure"), htmlFilePath.c_str());
+#else  // Linux specific
+ * LINUX function to get the current directory.
+ * This is done if the fileName does not contain a path.
+ * It is probably from an editor sending a single file.
+ * @param fileName_     The filename is used only for  the error message.
+	char* currdir = getenv("PWD");
+	if (currdir == nullptr)
+ * LINUX function to resolve wildcards and recurse into sub directories.
+	struct dirent* entry;           // entry from readdir()
+	struct stat statbuf;            // entry from stat()
+	vector<string> subDirectory;    // sub directories of this directory
+	// errno is defined in <errno.h> and is set for errors in opendir, readdir, or stat
+	errno = 0;
+	DIR* dp = opendir(directory.c_str());
+	if (dp == nullptr)
+	// save the first fileName entry for this recursion
+	const unsigned firstEntry = fileName.size();
+	while ((entry = readdir(dp)) != nullptr)
+		// get file status
+		string entryFilepath = directory + g_fileSeparator + entry->d_name;
+		if (stat(entryFilepath.c_str(), &statbuf) != 0)
+			if (errno == EOVERFLOW)         // file over 2 GB is OK
+				errno = 0;
+				continue;
+			perror("errno message");
+			error("Error getting file status in directory", directory.c_str());
+		if (entry->d_name[0] == '.' || !(statbuf.st_mode & S_IWUSR))
+			continue;
+		if (S_ISDIR(statbuf.st_mode) && isRecursive)
+			if (isPathExclued(entryFilepath))
+				printMsg(_("Exclude  %s\n"), entryFilepath.substr(mainDirectoryLength));
+			else
+				subDirectory.emplace_back(entryFilepath);
+			continue;
+		// if a file, save file name
+		if (S_ISREG(statbuf.st_mode))
+			bool isExcluded = isPathExclued(entryFilepath);
+			for (string wildcard : wildcards)
+				if (wildcmp(wildcard.c_str(), entry->d_name) != 0)
+					if (isExcluded)
+					else
+						fileName.emplace_back(entryFilepath);
+					break;
+	if (closedir(dp) != 0)
+		error("Error reading directory", directory.c_str());
+	// sort the current entries for fileName
+	if (firstEntry < fileName.size())
+		sort(&fileName[firstEntry], &fileName[fileName.size()]);
+	// if not doing recursive, subDirectory is empty
+	if (subDirectory.size() > 1)
+		sort(subDirectory.begin(), subDirectory.end());
+// LINUX function to get the full path name from the relative path name
+	// ignore realPath attribute warning
+#pragma GCC diagnostic push
+#pragma GCC diagnostic ignored "-Wunused-result"
+	char fullPath[PATH_MAX];
+	realpath(relativePath.c_str(), fullPath);
+	return fullPath;
+#pragma GCC diagnostic pop
+ * LINUX function to get locale information and call getNumberFormat.
+ *                  size_t is for compatibility with the Windows function.
+string ASConsole::getNumberFormat(int num, size_t /*lcid*/) const
+#endif
+	// get the locale info
+	struct lconv* lc;
+	lc = localeconv();
+	return getNumberFormat(num, lc->grouping, lc->thousands_sep);
+ * LINUX function to format a number according to the current locale.
+ * @param groupingArg   The grouping string from the locale.
+ * @param  separator	The thousands group separator from the locale.
+string ASConsole::getNumberFormat(int num, const char* groupingArg, const char* separator) const
+	alphaNum << num;
+	// format the number from right to left
+	string formattedNum;
+	size_t ig = 0;	// grouping index
+	int grouping = groupingArg[ig];
+	int i = number.length();
+	// check for no grouping
+	if (grouping == 0)
+		grouping = number.length();
+	while (i > 0)
+		// extract a group of numbers
+		string group;
+		if (i < grouping)
+			group = number;
+		else
+			group = number.substr(i - grouping);
+		// update formatted number
+		formattedNum.insert(0, group);
+		i -= grouping;
+		if (i < 0)
+			i = 0;
+		if (i > 0)
+			formattedNum.insert(0, separator);
+		number.erase(i);
+		// update grouping
+		if (groupingArg[ig] != '\0'
+		        && groupingArg[ig + 1] != '\0')
+			grouping = groupingArg[++ig];
+ * LINUX function to check for a HOME directory
+	char* env = getenv("HOME");
+		return true;
+		return true;
+		return true;
+	return false;
+ * LINUX function to open a HTML file in the default browser.
+ * Use xdg-open from freedesktop.org cross-desktop compatibility suite xdg-utils.
+ * see http://portland.freedesktop.org/wiki/
+ * This is installed on most modern distributions.
+	string htmlDefaultPath = "/usr/share/doc/astyle/html/";
+	string htmlDefaultFile = "astyle.html";
+		htmlFilePath = htmlDefaultPath + htmlDefaultFile;
+	else
+		else
+		return;
+	// get search paths
+	const char* envPaths = getenv("PATH");
+	if (envPaths == nullptr)
+		envPaths = "?";
+	size_t envlen = strlen(envPaths);
+	char* paths = new char[envlen + 1];
+	strcpy(paths, envPaths);
+	// find xdg-open (usually in /usr/bin)
+	// Mac uses open instead
+#ifdef __APPLE__
+	const char* fileOpen = "open";
+#else
+	const char* fileOpen = "xdg-open";
+#endif
+	string searchPath;
+	char* searchDir = strtok(paths, ":");
+	while (searchDir != nullptr)
+		searchPath = searchDir;
+		if (searchPath.length() > 0
+		        && searchPath[searchPath.length() - 1] != g_fileSeparator)
+			searchPath.append(string(1, g_fileSeparator));
+		searchPath.append(fileOpen);
+		if (stat(searchPath.c_str(), &statbuf) == 0 && (statbuf.st_mode & S_IFREG))
+			break;
+		searchDir = strtok(nullptr, ":");
+	delete[] paths;
+	if (searchDir == nullptr)
+		error(_("Command is not installed"), fileOpen);
+		execlp(fileOpen, fileOpen, htmlFilePath.c_str(), nullptr);
+		// execlp will NOT return if successful
+		error(_("Command execute failure"), fileOpen);
+#endif  // _WIN32
+ * Returns the parent directory of absPath. If absPath is not a valid absolute
+ * path or if it does not have a parent, an empty string is returned.
+ * @param absPath       The initial directory.
+ * @return              The parent directory of absPath, or an empty string if
+ *                      one cannot be found.
+string ASConsole::getParentDirectory(const string& absPath) const
+	if (isHomeOrInvalidAbsPath(absPath))
+		return string();
+	size_t offset = absPath.size() - 1;
+	if (absPath[absPath.size() - 1] == g_fileSeparator)
+		offset -= 1;
+	size_t idx = absPath.rfind(g_fileSeparator, offset);
+	if (idx == string::npos)
+		return string();
+	string str = absPath.substr(0, idx + 1);
+	return str;
+// get individual file names from the command-line file path
+void ASConsole::getFilePaths(const string& filePath)
+	fileName.clear();
+	targetDirectory = string();
+	targetFilename = string();
+	vector<string> targetFilenameVector;
+	// separate directory and file name
+	size_t separator = filePath.find_last_of(g_fileSeparator);
+	if (separator == string::npos)
+		// if no directory is present, use the currently active directory
+		targetDirectory = getCurrentDirectory(filePath);
+		targetFilename  = filePath;
+		mainDirectoryLength = targetDirectory.length() + 1;    // +1 includes trailing separator
+	else
+		targetDirectory = filePath.substr(0, separator);
+		targetFilename  = filePath.substr(separator + 1);
+	if (targetFilename.length() == 0)
+		fprintf(stderr, _("Missing filename in %s\n"), filePath.c_str());
+		error();
+	// check filename for wildcards
+	if (targetFilename.find_first_of("*?") != string::npos)
+		hasWildcard = true;
+	// If the filename is not quoted on Linux, bash will replace the
+	// wildcard instead of passing it to the program.
+	if (isRecursive && !hasWildcard)
+		fprintf(stderr, "%s\n", _("Recursive option with no wildcard"));
+#ifndef _WIN32
+		fprintf(stderr, "%s\n", _("Did you intend quote the filename"));
+#endif
+		error();
+	bool hasMultipleTargets = false;
+	if (targetFilename.find_first_of(",;") != string::npos)
+		hasMultipleTargets = true;
+	// display directory name for wildcard processing
+	if (hasWildcard)
+		printSeparatingLine();
+		printMsg(_("Directory  %s\n"), targetDirectory + g_fileSeparator + targetFilename);
+	// clear exclude hits vector
+	size_t excludeHitsVectorSize = excludeHitsVector.size();
+	for (size_t ix = 0; ix < excludeHitsVectorSize; ix++)
+		excludeHitsVector[ix] = false;
+	// create a vector of paths and file names to process
+	if (hasWildcard || isRecursive || hasMultipleTargets)
+		getTargetFilenames(targetFilename, targetFilenameVector);
+		getFileNames(targetDirectory, targetFilenameVector);
+	else
+		// verify a single file is not a directory (needed on Linux)
+		string entryFilepath = targetDirectory + g_fileSeparator + targetFilename;
+		if (stat(entryFilepath.c_str(), &statbuf) == 0 && (statbuf.st_mode & S_IFREG))
+	// check for unprocessed excludes
+	bool excludeErr = false;
+	for (size_t ix = 0; ix < excludeHitsVector.size(); ix++)
+		if (!excludeHitsVector[ix])
+			excludeErr = true;
+			if (!ignoreExcludeErrorsDisplay)
+				if (ignoreExcludeErrors)
+					printMsg(_("Exclude (unmatched)  %s\n"), excludeVector[ix]);
+				else
+					fprintf(stderr, _("Exclude (unmatched)  %s\n"), excludeVector[ix].c_str());
+			else
+				if (!ignoreExcludeErrors)
+	if (excludeErr && !ignoreExcludeErrors)
+		if (hasWildcard && !isRecursive)
+			fprintf(stderr, "%s\n", _("Did you intend to use --recursive"));
+		error();
+	// check if files were found (probably an input error if not)
+	if (fileName.empty())
+		fprintf(stderr, _("No file to process %s\n"), filePath.c_str());
+		error();
+	if (hasWildcard)
+// Check if a file exists
+bool ASConsole::fileExists(const char* file) const
+	struct stat buf;
+	return (stat(file, &buf) == 0);
+bool ASConsole::fileNameVectorIsEmpty() const
+	return fileNameVector.empty();
+bool ASConsole::isOption(const string& arg, const char* op)
+	return arg.compare(op) == 0;
+bool ASConsole::isOption(const string& arg, const char* a, const char* b)
+	return (isOption(arg, a) || isOption(arg, b));
+bool ASConsole::isParamOption(const string& arg, const char* option)
+	bool retVal = arg.compare(0, strlen(option), option) == 0;
+	// if comparing for short option, 2nd char of arg must be numeric
+	if (retVal && strlen(option) == 1 && arg.length() > 1)
+		if (!isdigit((unsigned char) arg[1]))
+			retVal = false;
+	return retVal;
+// compare a path to the exclude vector
+// used for both directories and filenames
+// updates the g_excludeHitsVector
+// return true if a match
+bool ASConsole::isPathExclued(const string& subPath)
+	bool retVal = false;
+	// read the exclude vector checking for a match
+	for (size_t i = 0; i < excludeVector.size(); i++)
+		string exclude = excludeVector[i];
+		if (subPath.length() < exclude.length())
+			continue;
+		size_t compareStart = subPath.length() - exclude.length();
+		// subPath compare must start with a directory name
+		if (compareStart > 0)
+			char lastPathChar = subPath[compareStart - 1];
+			if (lastPathChar != g_fileSeparator)
+				continue;
+		string compare = subPath.substr(compareStart);
+		if (!g_isCaseSensitive)
+			// make it case insensitive for Windows
+			for (size_t j = 0; j < compare.length(); j++)
+				compare[j] = (char) tolower(compare[j]);
+			for (size_t j = 0; j < exclude.length(); j++)
+				exclude[j] = (char) tolower(exclude[j]);
+		// compare sub directory to exclude data - must check them all
+		if (compare == exclude)
+			excludeHitsVector[i] = true;
+			retVal = true;
+			break;
+	return retVal;
+void ASConsole::printHelp() const
+	cout << endl;
+	cout << "                     Artistic Style " << g_version << endl;
+	cout << "                     Maintained by: Jim Pattee\n";
+	cout << "                     Original Author: Tal Davidson\n";
+	cout << endl;
+	cout << "Usage:\n";
+	cout << "------\n";
+	cout << "            astyle [OPTIONS] File1 File2 File3 [...]\n";
+	cout << endl;
+	cout << "            astyle [OPTIONS] < Original > Beautified\n";
+	cout << endl;
+	cout << "    When indenting a specific file, the resulting indented file RETAINS\n";
+	cout << "    the original file-name. The original pre-indented file is renamed,\n";
+	cout << "    with a suffix of \'.orig\' added to the original filename.\n";
+	cout << endl;
+	cout << "    Wildcards (* and ?) may be used in the filename.\n";
+	cout << "    A \'recursive\' option can process directories recursively.\n";
+	cout << "    Multiple file extensions may be separated by a comma.\n";
+	cout << endl;
+	cout << "    By default, astyle is set up to indent with four spaces per indent,\n";
+	cout << "    a maximal indentation of 40 spaces inside continuous statements,\n";
+	cout << "    a minimum indentation of eight spaces inside conditional statements,\n";
+	cout << "    and NO formatting options.\n";
+	cout << endl;
+	cout << "Options:\n";
+	cout << "--------\n";
+	cout << "    This  program  follows  the  usual  GNU  command line syntax.\n";
+	cout << "    Long options (starting with '--') must be written one at a time.\n";
+	cout << "    Short options (starting with '-') may be appended together.\n";
+	cout << "    Thus, -bps4 is the same as -b -p -s4.\n";
+	cout << endl;
+	cout << "Option Files:\n";
+	cout << "-------------\n";
+	cout << "    Artistic Style looks for a default option file and/or a project\n";
+	cout << "    option file in the following order:\n";
+	cout << "    1. The command line options have precedence.\n";
+	cout << "    2. The project option file has precedence over the default file\n";
+	cout << "       o the file name indicated by the --project= command line option.\n";
+	cout << "       o the file named .astylerc or _ astylerc.\n";
+	cout << "       o the file name identified by ARTISTIC_STYLE_PROJECT_OPTIONS.\n";
+	cout << "       o the file is disabled by --project=none on the command line.\n";
+	cout << "    3. The default option file that can be used for all projects.\n";
+	cout << "       o the file path indicated by the --options= command line option.\n";
+	cout << "       o the file path indicated by ARTISTIC_STYLE_OPTIONS.\n";
+	cout << "       o the file named .astylerc in the HOME directory (for Linux).\n";
+	cout << "       o the file name astylerc in the APPDATA directory (for Windows).\n";
+	cout << "    Long options within the option files may be written without '--'.\n";
+	cout << "    Line-end comments begin with a '#'.\n";
+	cout << endl;
+	cout << "Disable Formatting:\n";
+	cout << "-------------------\n";
+	cout << "    Disable Block\n";
+	cout << "    Blocks of code can be disabled with the comment tags *INDENT-OFF*\n";
+	cout << "    and *INDENT-ON*. It must be contained in a one-line comment.\n";
+	cout << endl;
+	cout << "    Disable Line\n";
+	cout << "    Padding of operators can be disabled on a single line using the\n";
+	cout << "    comment tag *NOPAD*. It must be contained in a line-end comment.\n";
+	cout << endl;
+	cout << "Brace Style Options:\n";
+	cout << "--------------------\n";
+	cout << "    default brace style\n";
+	cout << "    If no brace style is requested, the opening braces will not be\n";
+	cout << "    changed and closing braces will be broken from the preceding line.\n";
+	cout << endl;
+	cout << "    --style=allman  OR  --style=bsd  OR  --style=break  OR  -A1\n";
+	cout << "    Allman style formatting/indenting.\n";
+	cout << "    Broken braces.\n";
+	cout << endl;
+	cout << "    --style=java  OR  --style=attach  OR  -A2\n";
+	cout << "    Java style formatting/indenting.\n";
+	cout << "    Attached braces.\n";
+	cout << endl;
+	cout << "    --style=kr  OR  --style=k&r  OR  --style=k/r  OR  -A3\n";
+	cout << "    Kernighan & Ritchie style formatting/indenting.\n";
+	cout << "    Linux braces.\n";
+	cout << endl;
+	cout << "    --style=stroustrup  OR  -A4\n";
+	cout << "    Stroustrup style formatting/indenting.\n";
+	cout << endl;
+	cout << "    --style=whitesmith  OR  -A5\n";
+	cout << "    Whitesmith style formatting/indenting.\n";
+	cout << "    Broken, indented braces.\n";
+	cout << "    Indented class blocks and switch blocks.\n";
+	cout << endl;
+	cout << "    --style=vtk  OR  -A15\n";
+	cout << "    VTK style formatting/indenting.\n";
+	cout << "    Broken, indented braces except for the opening braces.\n";
+	cout << endl;
+	cout << "    --style=ratliff  OR  --style=banner  OR  -A6\n";
+	cout << "    Ratliff style formatting/indenting.\n";
+	cout << "    Attached, indented braces.\n";
+	cout << endl;
+	cout << "    --style=gnu  OR  -A7\n";
+	cout << "    GNU style formatting/indenting.\n";
+	cout << "    Broken braces, indented blocks.\n";
+	cout << endl;
+	cout << "    --style=linux  OR  --style=knf  OR  -A8\n";
+	cout << "    Linux style formatting/indenting.\n";
+	cout << "    Linux braces, minimum conditional indent is one-half indent.\n";
+	cout << endl;
+	cout << "    --style=horstmann  OR  --style=run-in  OR  -A9\n";
+	cout << "    Horstmann style formatting/indenting.\n";
+	cout << "    Run-in braces, indented switches.\n";
+	cout << endl;
+	cout << "    --style=1tbs  OR  --style=otbs  OR  -A10\n";
+	cout << "    One True Brace Style formatting/indenting.\n";
+	cout << "    Linux braces, add braces to all conditionals.\n";
+	cout << endl;
+	cout << "    --style=google  OR  -A14\n";
+	cout << "    Google style formatting/indenting.\n";
+	cout << "    Attached braces, indented class modifiers.\n";
+	cout << endl;
+	cout << "    --style=mozilla  OR  -A16\n";
+	cout << "    Mozilla style formatting/indenting.\n";
+	cout << "    Linux braces, with broken braces for structs and enums,\n";
+	cout << "    and attached braces for namespaces.\n";
+	cout << endl;
+	cout << "    --style=pico  OR  -A11\n";
+	cout << "    Pico style formatting/indenting.\n";
+	cout << "    Run-in opening braces and attached closing braces.\n";
+	cout << "    Uses keep one line blocks and keep one line statements.\n";
+	cout << endl;
+	cout << "    --style=lisp  OR  -A12\n";
+	cout << "    Lisp style formatting/indenting.\n";
+	cout << "    Attached opening braces and attached closing braces.\n";
+	cout << "    Uses keep one line statements.\n";
+	cout << endl;
+	cout << "Tab Options:\n";
+	cout << "------------\n";
+	cout << "    default indent option\n";
+	cout << "    If no indentation option is set, the default\n";
+	cout << "    option of 4 spaces per indent will be used.\n";
+	cout << endl;
+	cout << "    --indent=spaces=#  OR  -s#\n";
+	cout << "    Indent using # spaces per indent. Not specifying #\n";
+	cout << "    will result in a default of 4 spaces per indent.\n";
+	cout << endl;
+	cout << "    --indent=tab  OR  --indent=tab=#  OR  -t  OR  -t#\n";
+	cout << "    Indent using tab characters, assuming that each\n";
+	cout << "    indent is # spaces long. Not specifying # will result\n";
+	cout << "    in a default assumption of 4 spaces per indent.\n";
+	cout << endl;
+	cout << "    --indent=force-tab=#  OR  -T#\n";
+	cout << "    indent is # spaces long. Force tabs to be used in areas\n";
+	cout << "    AStyle would prefer to use spaces.\n";
+	cout << endl;
+	cout << "    --indent=force-tab-x=#  OR  -xT#\n";
+	cout << "    Allows the tab length to be set to a length that is different\n";
+	cout << "    from the indent length. This may cause the indentation to be\n";
+	cout << "    a mix of both spaces and tabs. This option sets the tab length.\n";
+	cout << endl;
+	cout << "Brace Modify Options:\n";
+	cout << "---------------------\n";
+	cout << "    --attach-namespaces  OR  -xn\n";
+	cout << "    Attach braces to a namespace statement.\n";
+	cout << endl;
+	cout << "    --attach-classes  OR  -xc\n";
+	cout << "    Attach braces to a class statement.\n";
+	cout << endl;
+	cout << "    --attach-inlines  OR  -xl\n";
+	cout << "    Attach braces to class inline function definitions.\n";
+	cout << endl;
+	cout << "    --attach-extern-c  OR  -xk\n";
+	cout << "    Attach braces to an extern \"C\" statement.\n";
+	cout << endl;
+	cout << "    --attach-closing-while  OR  -xV\n";
+	cout << "    Attach closing while of do-while to the closing brace.\n";
+	cout << endl;
+	cout << "Indentation Options:\n";
+	cout << "    --indent-classes  OR  -C\n";
+	cout << "    Indent 'class' blocks so that the entire block is indented.\n";
+	cout << endl;
+	cout << "    --indent-modifiers  OR  -xG\n";
+	cout << "    Indent 'class' access modifiers, 'public:', 'protected:' or\n";
+	cout << "    'private:', one half indent. The rest of the class is not\n";
+	cout << "    indented. \n";
+	cout << endl;
+	cout << "    --indent-switches  OR  -S\n";
+	cout << "    Indent 'switch' blocks, so that the inner 'case XXX:'\n";
+	cout << "    headers are indented in relation to the switch block.\n";
+	cout << endl;
+	cout << "    --indent-cases  OR  -K\n";
+	cout << "    Indent case blocks from the 'case XXX:' headers.\n";
+	cout << "    Case statements not enclosed in blocks are NOT indented.\n";
+	cout << endl;
+	cout << "    --indent-namespaces  OR  -N\n";
+	cout << "    Indent the contents of namespace blocks.\n";
+	cout << endl;
+	cout << "    --indent-after-parens  OR  -xU\n";
+	cout << "    Indent, instead of align, continuation lines following lines\n";
+	cout << "    that contain an opening paren '(' or an assignment '='. \n";
+	cout << endl;
+	cout << "    --indent-continuation=#  OR  -xt#\n";
+	cout << "    Indent continuation lines an additional # indents.\n";
+	cout << "    The valid values are 0 thru 4 indents.\n";
+	cout << "    The default value is 1 indent.\n";
+	cout << endl;
+	cout << "    --indent-labels  OR  -L\n";
+	cout << "    Indent labels so that they appear one indent less than\n";
+	cout << "    the current indentation level, rather than being\n";
+	cout << "    flushed completely to the left (which is the default).\n";
+	cout << endl;
+	cout << "    --indent-preproc-block  OR  -xW\n";
+	cout << "    Indent preprocessor blocks at brace level 0.\n";
+	cout << "    Without this option the preprocessor block is not indented.\n";
+	cout << endl;
+	cout << "    --indent-preproc-cond  OR  -xw\n";
+	cout << "    Indent preprocessor conditional statements #if/#else/#endif\n";
+	cout << "    to the same level as the source code.\n";
+	cout << endl;
+	cout << "    --indent-preproc-define  OR  -w\n";
+	cout << "    Indent multi-line preprocessor #define statements.\n";
+	cout << endl;
+	cout << "    --indent-col1-comments  OR  -Y\n";
+	cout << "    Indent line comments that start in column one.\n";
+	cout << endl;
+	cout << "    --min-conditional-indent=#  OR  -m#\n";
+	cout << "    Indent a minimal # spaces in a continuous conditional\n";
+	cout << "    belonging to a conditional header.\n";
+	cout << "    The valid values are:\n";
+	cout << "    0 - no minimal indent.\n";
+	cout << "    1 - indent at least one additional indent.\n";
+	cout << "    2 - indent at least two additional indents.\n";
+	cout << "    3 - indent at least one-half an additional indent.\n";
+	cout << "    The default value is 2, two additional indents.\n";
+	cout << endl;
+	cout << "    --max-continuation-indent=#  OR  -M#\n";
+	cout << "    Indent a maximal # spaces in a continuation line,\n";
+	cout << "    relative to the previous line.\n";
+	cout << "    The valid values are 40 thru 120.\n";
+	cout << "    The default value is 40.\n";
+	cout << endl;
+	cout << "Padding Options:\n";
+	cout << "----------------\n";
+	cout << "    --break-blocks  OR  -f\n";
+	cout << "    Insert empty lines around unrelated blocks, labels, classes, ...\n";
+	cout << endl;
+	cout << "    --break-blocks=all  OR  -F\n";
+	cout << "    Like --break-blocks, except also insert empty lines \n";
+	cout << "    around closing headers (e.g. 'else', 'catch', ...).\n";
+	cout << endl;
+	cout << "    --pad-oper  OR  -p\n";
+	cout << "    Insert space padding around operators.\n";
+	cout << endl;
+	cout << "    --pad-comma  OR  -xg\n";
+	cout << "    Insert space padding after commas.\n";
+	cout << endl;
+	cout << "    --pad-paren  OR  -P\n";
+	cout << "    Insert space padding around parenthesis on both the outside\n";
+	cout << "    and the inside.\n";
+	cout << endl;
+	cout << "    --pad-paren-out  OR  -d\n";
+	cout << "    Insert space padding around parenthesis on the outside only.\n";
+	cout << endl;
+	cout << "    --pad-first-paren-out  OR  -xd\n";
+	cout << "    Insert space padding around first parenthesis in a series on\n";
+	cout << "    the outside only.\n";
+	cout << endl;
+	cout << "    --pad-paren-in  OR  -D\n";
+	cout << "    Insert space padding around parenthesis on the inside only.\n";
+	cout << endl;
+	cout << "    --pad-header  OR  -H\n";
+	cout << "    Insert space padding after paren headers (e.g. 'if', 'for'...).\n";
+	cout << endl;
+	cout << "    --unpad-paren  OR  -U\n";
+	cout << "    Remove unnecessary space padding around parenthesis. This\n";
+	cout << "    can be used in combination with the 'pad' options above.\n";
+	cout << endl;
+	cout << "    --delete-empty-lines  OR  -xd\n";
+	cout << "    Delete empty lines within a function or method.\n";
+	cout << "    It will NOT delete lines added by the break-blocks options.\n";
+	cout << endl;
+	cout << "    --fill-empty-lines  OR  -E\n";
+	cout << "    Fill empty lines with the white space of their\n";
+	cout << "    previous lines.\n";
+	cout << endl;
+	cout << "    --align-pointer=type    OR  -k1\n";
+	cout << "    --align-pointer=middle  OR  -k2\n";
+	cout << "    --align-pointer=name    OR  -k3\n";
+	cout << "    Attach a pointer or reference operator (*, &, or ^) to either\n";
+	cout << "    the operator type (left), middle, or operator name (right).\n";
+	cout << "    To align the reference separately use --align-reference.\n";
+	cout << endl;
+	cout << "    --align-reference=none    OR  -W0\n";
+	cout << "    --align-reference=type    OR  -W1\n";
+	cout << "    --align-reference=middle  OR  -W2\n";
+	cout << "    --align-reference=name    OR  -W3\n";
+	cout << "    Attach a reference operator (&) to either\n";
+	cout << "    If not set, follow pointer alignment.\n";
+	cout << endl;
+	cout << "Formatting Options:\n";
+	cout << "    --break-closing-braces  OR  -y\n";
+	cout << "    Break braces before closing headers (e.g. 'else', 'catch', ...).\n";
+	cout << "    Use with --style=java, --style=kr, --style=stroustrup,\n";
+	cout << "    --style=linux, or --style=1tbs.\n";
+	cout << endl;
+	cout << "    --break-elseifs  OR  -e\n";
+	cout << "    Break 'else if()' statements into two different lines.\n";
+	cout << endl;
+	cout << "    --break-one-line-headers  OR  -xb\n";
+	cout << "    Break one line headers (e.g. 'if', 'while', 'else', ...) from a\n";
+	cout << "    statement residing on the same line.\n";
+	cout << endl;
+	cout << "    --add-braces  OR  -j\n";
+	cout << "    Add braces to unbraced one line conditional statements.\n";
+	cout << endl;
+	cout << "    --add-one-line-braces  OR  -J\n";
+	cout << "    Add one line braces to unbraced one line conditional\n";
+	cout << "    statements.\n";
+	cout << endl;
+	cout << "    --remove-braces  OR  -xj\n";
+	cout << "    Remove braces from a braced one line conditional statements.\n";
+	cout << endl;
+	cout << "    --break-return-type       OR  -xB\n";
+	cout << "    --break-return-type-decl  OR  -xD\n";
+	cout << "    Break the return type from the function name. Options are\n";
+	cout << "    for the function definitions and the function declarations.\n";
+	cout << endl;
+	cout << "    --attach-return-type       OR  -xf\n";
+	cout << "    --attach-return-type-decl  OR  -xh\n";
+	cout << "    Attach the return type to the function name. Options are\n";
+	cout << endl;
+	cout << "    --keep-one-line-blocks  OR  -O\n";
+	cout << "    Don't break blocks residing completely on one line.\n";
+	cout << endl;
+	cout << "    --keep-one-line-statements  OR  -o\n";
+	cout << "    Don't break lines containing multiple statements into\n";
+	cout << "    multiple single-statement lines.\n";
+	cout << endl;
+	cout << "    --convert-tabs  OR  -c\n";
+	cout << "    Convert tabs to the appropriate number of spaces.\n";
+	cout << endl;
+	cout << "    --close-templates  OR  -xy\n";
+	cout << "    Close ending angle brackets on template definitions.\n";
+	cout << endl;
+	cout << "    --remove-comment-prefix  OR  -xp\n";
+	cout << "    Remove the leading '*' prefix on multi-line comments and\n";
+	cout << "    indent the comment text one indent.\n";
+	cout << endl;
+	cout << "    --max-code-length=#    OR  -xC#\n";
+	cout << "    --break-after-logical  OR  -xL\n";
+	cout << "    max-code-length=# will break the line if it exceeds more than\n";
+	cout << "    # characters. The valid values are 50 thru 200.\n";
+	cout << "    If the line contains logical conditionals they will be placed\n";
+	cout << "    first on the new line. The option break-after-logical will\n";
+	cout << "    cause the logical conditional to be placed last on the\n";
+	cout << "    previous line.\n";
+	cout << endl;
+	cout << "    --mode=c\n";
+	cout << "    Indent a C or C++ source file (this is the default).\n";
+	cout << endl;
+	cout << "    --mode=java\n";
+	cout << "    Indent a Java source file.\n";
+	cout << endl;
+	cout << "    --mode=cs\n";
+	cout << "    Indent a C# source file.\n";
+	cout << endl;
+	cout << "Objective-C Options:\n";
+	cout << "    --pad-method-prefix  OR  -xQ\n";
+	cout << "    Insert space padding after the '-' or '+' Objective-C\n";
+	cout << "    method prefix.\n";
+	cout << endl;
+	cout << "    --unpad-method-prefix  OR  -xR\n";
+	cout << "    Remove all space padding after the '-' or '+' Objective-C\n";
+	cout << endl;
+	cout << "    --pad-return-type  OR  -xq\n";
+	cout << "    Insert space padding after the Objective-C return type.\n";
+	cout << endl;
+	cout << "    --unpad-return-type  OR  -xr\n";
+	cout << "    Remove all space padding after the Objective-C return type.\n";
+	cout << endl;
+	cout << "    --pad-param-type  OR  -xS\n";
+	cout << endl;
+	cout << "    --unpad-param-type  OR  -xs\n";
+	cout << endl;
+	cout << "    --align-method-colon  OR  -xM\n";
+	cout << "    Align the colons in an Objective-C method definition.\n";
+	cout << endl;
+	cout << "    --pad-method-colon=none    OR  -xP\n";
+	cout << "    --pad-method-colon=all     OR  -xP1\n";
+	cout << "    --pad-method-colon=after   OR  -xP2\n";
+	cout << "    --pad-method-colon=before  OR  -xP3\n";
+	cout << "    Add or remove space padding before or after the colons in an\n";
+	cout << "    Objective-C method call.\n";
+	cout << endl;
+	cout << "Other Options:\n";
+	cout << "--------------\n";
+	cout << "    --suffix=####\n";
+	cout << "    Append the suffix #### instead of '.orig' to original filename.\n";
+	cout << endl;
+	cout << "    --suffix=none  OR  -n\n";
+	cout << "    Do not retain a backup of the original file.\n";
+	cout << endl;
+	cout << "    --recursive  OR  -r  OR  -R\n";
+	cout << "    Process subdirectories recursively.\n";
+	cout << endl;
+	cout << "    --dry-run\n";
+	cout << "    Perform a trial run with no changes made to check for formatting.\n";
+	cout << endl;
+	cout << "    --exclude=####\n";
+	cout << "    Specify a file or directory #### to be excluded from processing.\n";
+	cout << endl;
+	cout << "    --ignore-exclude-errors  OR  -i\n";
+	cout << "    Allow processing to continue if there are errors in the exclude=####\n";
+	cout << "    options. It will display the unmatched excludes.\n";
+	cout << endl;
+	cout << "    --ignore-exclude-errors-x  OR  -xi\n";
+	cout << "    options. It will NOT display the unmatched excludes.\n";
+	cout << endl;
+	cout << "    --errors-to-stdout  OR  -X\n";
+	cout << "    Print errors and help information to standard-output rather than\n";
+	cout << "    to standard-error.\n";
+	cout << endl;
+	cout << "    --preserve-date  OR  -Z\n";
+	cout << "    Preserve the original file's date and time modified. The time\n";
+	cout << "     modified will be changed a few micro seconds to force a compile.\n";
+	cout << endl;
+	cout << "    --verbose  OR  -v\n";
+	cout << "    Verbose mode. Extra informational messages will be displayed.\n";
+	cout << endl;
+	cout << "    --formatted  OR  -Q\n";
+	cout << "    Formatted display mode. Display only the files that have been\n";
+	cout << "    formatted.\n";
+	cout << endl;
+	cout << "    --quiet  OR  -q\n";
+	cout << "    Quiet mode. Suppress all output except error messages.\n";
+	cout << endl;
+	cout << "    --lineend=windows  OR  -z1\n";
+	cout << "    --lineend=linux    OR  -z2\n";
+	cout << "    --lineend=macold   OR  -z3\n";
+	cout << "    Force use of the specified line end style. Valid options\n";
+	cout << "    are windows (CRLF), linux (LF), and macold (CR).\n";
+	cout << endl;
+	cout << "Command Line Only:\n";
+	cout << "------------------\n";
+	cout << "    --options=####\n";
+	cout << "    --options=none\n";
+	cout << "    Specify a default option file #### to read and use.\n";
+	cout << "    It must contain a file path and a file name.\n";
+	cout << "    'none' disables the default option file.\n";
+	cout << endl;
+	cout << "    --project\n";
+	cout << "    --project=####\n";
+	cout << "    --project=none\n";
+	cout << "    Specify a project option file #### to read and use.\n";
+	cout << "    It must contain a file name only, without a directory path.\n";
+	cout << "    The file should be included in the project top-level directory.\n";
+	cout << "    The default file name is .astylerc or _astylerc.\n";
+	cout << "    'none' disables the project or environment variable file.\n";
+	cout << endl;
+	cout << "    --ascii  OR  -I\n";
+	cout << "    The displayed output will be ascii characters only.\n";
+	cout << endl;
+	cout << "    --version  OR  -V\n";
+	cout << "    Print version number.\n";
+	cout << endl;
+	cout << "    --help  OR  -h  OR  -?\n";
+	cout << "    Print this help message.\n";
+	cout << endl;
+	cout << "    --html  OR  -!\n";
+	cout << "    Open the HTML help file \"astyle.html\" in the default browser.\n";
+	cout << "    The documentation must be installed in the standard install path.\n";
+	cout << endl;
+	cout << "    --html=####\n";
+	cout << "    Open a HTML help file in the default browser using the file path\n";
+	cout << "    ####. The path may include a directory path and a file name, or a\n";
+	cout << "    file name only. Paths containing spaces must be enclosed in quotes.\n";
+	cout << endl;
+	cout << "    --stdin=####\n";
+	cout << "    Use the file path #### as input to single file formatting.\n";
+	cout << "    This is a replacement for redirection.\n";
+	cout << endl;
+	cout << "    --stdout=####\n";
+	cout << "    Use the file path #### as output from single file formatting.\n";
+	cout << endl;
+	cout << endl;
+ * Process files in the fileNameVector.
+void ASConsole::processFiles()
+	if (isVerbose)
+		printVerboseHeader();
+	clock_t startTime = clock();     // start time of file formatting
+	// loop thru input fileNameVector and process the files
+	for (size_t i = 0; i < fileNameVector.size(); i++)
+		getFilePaths(fileNameVector[i]);
+		// loop thru fileName vector formatting the files
+		for (size_t j = 0; j < fileName.size(); j++)
+			formatFile(fileName[j]);
+	// files are processed, display stats
+	if (isVerbose)
+		printVerboseStats(startTime);
+// process options from the command line and option files
+// build the vectors fileNameVector, excludeVector, optionsVector,
+// projectOptionsVector and fileOptionsVector
+void ASConsole::processOptions(const vector<string>& argvOptions)
+	string arg;
+	bool ok = true;
+	bool optionFileRequired = false;
+	bool shouldParseOptionFile = true;
+	bool projectOptionFileRequired = false;
+	bool shouldParseProjectOptionFile = true;
+	string projectOptionArg;		// save for display
+	// get command line options
+	for (size_t i = 0; i < argvOptions.size(); i++)
+		arg = argvOptions[i];
+		if (isOption(arg, "-I")
+		        || isOption(arg, "--ascii"))
+			useAscii = true;
+			setlocale(LC_ALL, "C");		// use English decimal indicator
+			localizer.setLanguageFromName("en");
+		else if (isOption(arg, "--options=none"))
+			optionFileRequired = false;
+			shouldParseOptionFile = false;
+			optionFileName = "";
+		else if (isParamOption(arg, "--options="))
+			optionFileName = getParam(arg, "--options=");
+			standardizePath(optionFileName);
+			optionFileName = getFullPathName(optionFileName);
+			optionFileRequired = true;
+		else if (isOption(arg, "--project=none"))
+			projectOptionFileRequired = false;
+			shouldParseProjectOptionFile = false;
+			setProjectOptionFileName("");
+		else if (isParamOption(arg, "--project="))
+			projectOptionFileName = getParam(arg, "--project=");
+			standardizePath(projectOptionFileName);
+			projectOptionFileRequired = true;
+			projectOptionArg = projectOptionFileName;
+		else if (isOption(arg, "--project"))
+			projectOptionFileName = ".astylerc";
+		else if (isOption(arg, "-h")
+		         || isOption(arg, "--help")
+		         || isOption(arg, "-?"))
+			printHelp();
+			exit(EXIT_SUCCESS);
+		else if (isOption(arg, "-!")
+		         || isOption(arg, "--html"))
+			launchDefaultBrowser();
+		else if (isParamOption(arg, "--html="))
+			string htmlFilePath = getParam(arg, "--html=");
+			launchDefaultBrowser(htmlFilePath.c_str());
+		else if (isOption(arg, "-V")
+		         || isOption(arg, "--version"))
+			printf("Artistic Style Version %s\n", g_version);
+		else if (isParamOption(arg, "--stdin="))
+			string path = getParam(arg, "--stdin=");
+			standardizePath(path);
+			setStdPathIn(path);
+		else if (isParamOption(arg, "--stdout="))
+			string path = getParam(arg, "--stdout=");
+			setStdPathOut(path);
+		else if (arg[0] == '-')
+			optionsVector.emplace_back(arg);
+		else // file-name
+			standardizePath(arg);
+			fileNameVector.emplace_back(arg);
+	// get option file path and name
+	if (shouldParseOptionFile)
+		if (optionFileName.empty())
+			char* env = getenv("ARTISTIC_STYLE_OPTIONS");
+			if (env != nullptr)
+				setOptionFileName(env);
+		// for Linux
+				string name = string(env) + "/.astylerc";
+				if (fileExists(name.c_str()))
+					setOptionFileName(name);
+		// for Windows
+			char* env = getenv("APPDATA");
+				string name = string(env) + "\\astylerc";
+		// for Windows
+		// NOTE: depreciated with release 3.1, remove when appropriate
+		// there is NO test data for this option
+	// find project option file
+	if (projectOptionFileRequired)
+		string optfilepath = findProjectOptionFilePath(projectOptionFileName);
+		if (optfilepath.empty() || projectOptionArg.empty())
+			error(_("Cannot open project option file"), projectOptionArg.c_str());
+		standardizePath(optfilepath);
+		setProjectOptionFileName(optfilepath);
+	if (shouldParseProjectOptionFile)
+		char* env = getenv("ARTISTIC_STYLE_PROJECT_OPTIONS");
+			string optfilepath = findProjectOptionFilePath(env);
+	ASOptions options(formatter, *this);
+	if (!optionFileName.empty())
+		stringstream optionsIn;
+		if (!fileExists(optionFileName.c_str()))
+			error(_("Cannot open default option file"), optionFileName.c_str());
+		FileEncoding encoding = readFile(optionFileName, optionsIn);
+		// bypass a BOM, all BOMs have been converted to utf-8
+		if (encoding == UTF_8BOM || encoding == UTF_16LE || encoding == UTF_16BE)
+			char buf[4];
+			optionsIn.get(buf, 4);
+			assert(strcmp(buf, "\xEF\xBB\xBF") == 0);
+		options.importOptions(optionsIn, fileOptionsVector);
+		ok = options.parseOptions(fileOptionsVector,
+		                          string(_("Invalid default options:")));
+	else if (optionFileRequired)
+	if (!ok)
+		(*errorStream) << options.getOptionErrors();
+		(*errorStream) << _("For help on options type 'astyle -h'") << endl;
+		error();
+	if (!projectOptionFileName.empty())
+		stringstream projectOptionsIn;
+		if (!fileExists(projectOptionFileName.c_str()))
+			error(_("Cannot open project option file"), projectOptionFileName.c_str());
+		FileEncoding encoding = readFile(projectOptionFileName, projectOptionsIn);
+			char buf[4];
+			projectOptionsIn.get(buf, 4);
+		options.importOptions(projectOptionsIn, projectOptionsVector);
+		ok = options.parseOptions(projectOptionsVector,
+		                          string(_("Invalid project options:")));
+	if (!ok)
+		error();
+	// parse the command line options vector for errors
+	ok = options.parseOptions(optionsVector,
+	                          string(_("Invalid command line options:")));
+	if (!ok)
+		error();
+// remove a file and check for an error
+void ASConsole::removeFile(const char* fileName_, const char* errMsg) const
+	if (remove(fileName_) != 0)
+		if (errno == ENOENT)        // no file is OK
+			errno = 0;
+		if (errno)
+			error(errMsg, fileName_);
+// rename a file and check for an error
+void ASConsole::renameFile(const char* oldFileName, const char* newFileName, const char* errMsg) const
+	int result = rename(oldFileName, newFileName);
+	if (result != 0)
+		// if file still exists the remove needs more time - retry
+		if (errno == EEXIST)
+			errno = 0;
+			waitForRemove(newFileName);
+			result = rename(oldFileName, newFileName);
+		if (result != 0)
+			error(errMsg, oldFileName);
+// make sure file separators are correct type (Windows or Linux)
+// remove ending file separator
+// remove beginning file separator if requested and NOT a complete file path
+void ASConsole::standardizePath(string& path, bool removeBeginningSeparator /*false*/) const
+#ifdef __VMS
+	struct FAB fab;
+	struct NAML naml;
+	char less[NAML$C_MAXRSS];
+	char sess[NAM$C_MAXRSS];
+	int r0_status;
+	// If we are on a VMS system, translate VMS style filenames to unix
+	// style.
+	fab = cc$rms_fab;
+	fab.fab$l_fna = (char*) -1;
+	fab.fab$b_fns = 0;
+	fab.fab$l_naml = &naml;
+	naml = cc$rms_naml;
+	strcpy(sess, path.c_str());
+	naml.naml$l_long_filename = (char*) sess;
+	naml.naml$l_long_filename_size = path.length();
+	naml.naml$l_long_expand = less;
+	naml.naml$l_long_expand_alloc = sizeof(less);
+	naml.naml$l_esa = sess;
+	naml.naml$b_ess = sizeof(sess);
+	naml.naml$v_no_short_upcase = 1;
+	r0_status = sys$parse(&fab);
+	if (r0_status == RMS$_SYN)
+		error("File syntax error", path.c_str());
+	else
+		if (!$VMS_STATUS_SUCCESS(r0_status))
+			(void) lib$signal(r0_status);
+	less[naml.naml$l_long_expand_size - naml.naml$b_ver] = '\0';
+	sess[naml.naml$b_esl - naml.naml$b_ver] = '\0';
+	if (naml.naml$l_long_expand_size > naml.naml$b_esl)
+		path = decc$translate_vms(less);
+	else
+		path = decc$translate_vms(sess);
+#endif /* __VMS */
+	// make sure separators are correct type (Windows or Linux)
+	for (size_t i = 0; i < path.length(); i++)
+		i = path.find_first_of("/\\", i);
+		if (i == string::npos)
+			break;
+		path[i] = g_fileSeparator;
+	// remove beginning separator if requested
+	if (removeBeginningSeparator && (path[0] == g_fileSeparator))
+		path.erase(0, 1);
+void ASConsole::printMsg(const char* msg, const string& data) const
+	if (isQuiet)
+		return;
+	printf(msg, data.c_str());
+void ASConsole::printSeparatingLine() const
+	string line;
+	for (size_t i = 0; i < 60; i++)
+		line.append("-");
+	printMsg("%s\n", line);
+void ASConsole::printVerboseHeader() const
+	assert(isVerbose);
+	if (isQuiet)
+		return;
+	// get the date
+	time_t lt;
+	char str[20];
+	lt = time(nullptr);
+	struct tm* ptr = localtime(&lt);
+	strftime(str, 20, "%x", ptr);
+	// print the header
+	// 60 is the length of the separator in printSeparatingLine()
+	string header = "Artistic Style " + string(g_version);
+	size_t numSpaces = 60 - header.length() - strlen(str);
+	header.append(numSpaces, ' ');
+	header.append(str);
+	header.append("\n");
+	printf("%s", header.c_str());
+	// print option files
+		printf(_("Default option file  %s\n"), optionFileName.c_str());
+		if (env != nullptr && optionFileName == string(env) + "\\astylerc")
+			printf("The above option file has been DEPRECIATED\n");
+	// end depreciated
+		printf(_("Project option file  %s\n"), projectOptionFileName.c_str());
+void ASConsole::printVerboseStats(clock_t startTime) const
+	if (isQuiet)
+		return;
+	if (hasWildcard)
+	string formatted = getNumberFormat(filesFormatted);
+	string unchanged = getNumberFormat(filesUnchanged);
+	printf(_(" %s formatted   %s unchanged   "), formatted.c_str(), unchanged.c_str());
+	// show processing time
+	clock_t stopTime = clock();
+	double secs = (stopTime - startTime) / double(CLOCKS_PER_SEC);
+	if (secs < 60)
+		if (secs < 2.0)
+			printf("%.2f", secs);
+		else if (secs < 20.0)
+			printf("%.1f", secs);
+		else
+			printf("%.0f", secs);
+		printf("%s", _(" seconds   "));
+	else
+		// show minutes and seconds if time is greater than one minute
+		int min = (int) secs / 60;
+		secs -= min * 60;
+		int minsec = int(secs + .5);
+		printf(_("%d min %d sec   "), min, minsec);
+	string lines = getNumberFormat(linesOut);
+	printf(_("%s lines\n"), lines.c_str());
+	printf("\n");
+void ASConsole::sleep(int seconds) const
+	clock_t endwait;
+	endwait = clock_t(clock() + seconds * CLOCKS_PER_SEC);
+	while (clock() < endwait) {}
+bool ASConsole::stringEndsWith(const string& str, const string& suffix) const
+	int strIndex = (int) str.length() - 1;
+	int suffixIndex = (int) suffix.length() - 1;
+	while (strIndex >= 0 && suffixIndex >= 0)
+		if (tolower(str[strIndex]) != tolower(suffix[suffixIndex]))
+			return false;
+		--strIndex;
+		--suffixIndex;
+	// suffix longer than string
+	if (strIndex < 0 && suffixIndex >= 0)
+		return false;
+	return true;
+void ASConsole::updateExcludeVector(const string& suffixParam)
+	excludeVector.emplace_back(suffixParam);
+	standardizePath(excludeVector.back(), true);
+	excludeHitsVector.push_back(false);
+int ASConsole::waitForRemove(const char* newFileName) const
+	struct stat stBuf;
+	int seconds;
+	// sleep a max of 20 seconds for the remove
+	for (seconds = 1; seconds <= 20; seconds++)
+		sleep(1);
+		if (stat(newFileName, &stBuf) != 0)
+			break;
+	errno = 0;
+	return seconds;
+// From The Code Project http://www.codeproject.com/string/wildcmp.asp
+// Written by Jack Handy - jakkhandy at hotmail.com
+// Modified to compare case insensitive for Windows
+int ASConsole::wildcmp(const char* wild, const char* data) const
+	const char* cp = nullptr, *mp = nullptr;
+	bool cmpval;
+	while ((*data) && (*wild != '*'))
+			cmpval = (tolower(*wild) != tolower(*data)) && (*wild != '?');
+		else
+			cmpval = (*wild != *data) && (*wild != '?');
+		if (cmpval)
+			return 0;
+		wild++;
+		data++;
+	while (*data)
+		if (*wild == '*')
+			if (!*++wild)
+				return 1;
+			mp = wild;
+			cp = data + 1;
+		else
+				cmpval = (tolower(*wild) == tolower(*data) || (*wild == '?'));
+			else
+				cmpval = (*wild == *data) || (*wild == '?');
+			if (cmpval)
+				wild++;
+				data++;
+			else
+				wild = mp;
+				data = cp++;
+	while (*wild == '*')
+		wild++;
+	return !*wild;
+void ASConsole::writeFile(const string& fileName_, FileEncoding encoding, ostringstream& out) const
+	// save date accessed and date modified of original file
+	bool statErr = false;
+	if (stat(fileName_.c_str(), &stBuf) == -1)
+		statErr = true;
+	// create a backup
+	if (!noBackup)
+		string origFileName = fileName_ + origSuffix;
+		removeFile(origFileName.c_str(), "Cannot remove pre-existing backup file");
+		renameFile(fileName_.c_str(), origFileName.c_str(), "Cannot create backup file");
+	// write the output file
+	ofstream fout(fileName_.c_str(), ios::binary | ios::trunc);
+	if (!fout)
+		error("Cannot open output file", fileName_.c_str());
+		// convert utf-8 to utf-16
+		size_t utf16Size = encode.utf16LengthFromUtf8(out.str().c_str(), out.str().length());
+		char* utf16Out = new char[utf16Size];
+		size_t utf16Len = encode.utf8ToUtf16(const_cast<char*>(out.str().c_str()),
+		                                     out.str().length(), isBigEndian, utf16Out);
+		assert(utf16Len <= utf16Size);
+		fout << string(utf16Out, utf16Len);
+		delete[] utf16Out;
+	else
+		fout << out.str();
+	fout.close();
+	// change date modified to original file date
+	// Embarcadero must be linked with cw32mt not cw32
+	if (preserveDate)
+		if (!statErr)
+			struct utimbuf outBuf;
+			outBuf.actime = stBuf.st_atime;
+			// add ticks so 'make' will recognize a change
+			// Visual Studio 2008 needs more than 1
+			outBuf.modtime = stBuf.st_mtime + 10;
+			if (utime(fileName_.c_str(), &outBuf) == -1)
+				statErr = true;
+		if (statErr)
+			(*errorStream) << "*********  Cannot preserve file date" << endl;
+#else	// ASTYLE_LIB
+// ASLibrary class
+// used by shared object (DLL) calls
+char16_t* ASLibrary::formatUtf16(const char16_t* pSourceIn,		// the source to be formatted
+                                 const char16_t* pOptions,		// AStyle options
+                                 fpError fpErrorHandler,		// error handler function
+                                 fpAlloc fpMemoryAlloc) const	// memory allocation function)
+	const char* utf8In = convertUtf16ToUtf8(pSourceIn);
+	if (utf8In == nullptr)
+		fpErrorHandler(121, "Cannot convert input utf-16 to utf-8.");
+		return nullptr;
+	const char* utf8Options = convertUtf16ToUtf8(pOptions);
+	if (utf8Options == nullptr)
+		delete[] utf8In;
+		fpErrorHandler(122, "Cannot convert options utf-16 to utf-8.");
+		return nullptr;
+	// call the Artistic Style formatting function
+	// cannot use the callers memory allocation here
+	char* utf8Out = AStyleMain(utf8In,
+	                           utf8Options,
+	                           fpErrorHandler,
+	                           ASLibrary::tempMemoryAllocation);
+	// finished with these
+	delete[] utf8In;
+	delete[] utf8Options;
+	utf8In = nullptr;
+	utf8Options = nullptr;
+	// AStyle error has already been sent
+		return nullptr;
+	// convert text to wide char and return it
+	char16_t* utf16Out = convertUtf8ToUtf16(utf8Out, fpMemoryAlloc);
+	delete[] utf8Out;
+	utf8Out = nullptr;
+	if (utf16Out == nullptr)
+		fpErrorHandler(123, "Cannot convert output utf-8 to utf-16.");
+		return nullptr;
+	return utf16Out;
+// STATIC method to allocate temporary memory for AStyle formatting.
+// The data will be converted before being returned to the calling program.
+char* STDCALL ASLibrary::tempMemoryAllocation(unsigned long memoryNeeded)
+	char* buffer = new (nothrow) char[memoryNeeded];
+	return buffer;
+ * Convert utf-8 strings to utf16 strings.
+ * Memory is allocated by the calling program memory allocation function.
+ * The calling function must check for errors.
+char16_t* ASLibrary::convertUtf8ToUtf16(const char* utf8In, fpAlloc fpMemoryAlloc) const
+		return nullptr;
+	char* data = const_cast<char*>(utf8In);
+	size_t dataSize = strlen(utf8In);
+	bool isBigEndian = encode.getBigEndian();
+	// return size is in number of CHARs, not char16_t
+	size_t utf16Size = (encode.utf16LengthFromUtf8(data, dataSize) + sizeof(char16_t));
+	char* utf16Out = fpMemoryAlloc((long) utf16Size);
+		return nullptr;
+#ifdef NDEBUG
+	encode.utf8ToUtf16(data, dataSize + 1, isBigEndian, utf16Out);
+#else
+	size_t utf16Len = encode.utf8ToUtf16(data, dataSize + 1, isBigEndian, utf16Out);
+	assert(utf16Len == utf16Size);
+#endif
+	assert(utf16Size == (encode.utf16len(reinterpret_cast<char16_t*>(utf16Out)) + 1) * sizeof(char16_t));
+	return reinterpret_cast<char16_t*>(utf16Out);
+ * Convert utf16 strings to utf-8.
+ * The calling function must check for errors and delete the
+ * allocated memory.
+char* ASLibrary::convertUtf16ToUtf8(const char16_t* utf16In) const
+	if (utf16In == nullptr)
+		return nullptr;
+	char* data = reinterpret_cast<char*>(const_cast<char16_t*>(utf16In));
+	// size must be in chars
+	size_t dataSize = encode.utf16len(utf16In) * sizeof(char16_t);
+	size_t utf8Size = encode.utf8LengthFromUtf16(data, dataSize, isBigEndian) + 1;
+		return nullptr;
+#ifdef NDEBUG
+	encode.utf16ToUtf8(data, dataSize + 1, isBigEndian, true, utf8Out);
+#else
+	size_t utf8Len = encode.utf16ToUtf8(data, dataSize + 1, isBigEndian, true, utf8Out);
+	assert(utf8Len == utf8Size);
+#endif
+	assert(utf8Size == strlen(utf8Out) + 1);
+	return utf8Out;
+#endif	// ASTYLE_LIB
+// ASOptions class
+// used by both console and library builds
+#ifdef ASTYLE_LIB
+ASOptions::ASOptions(ASFormatter& formatterArg)
+	: formatter(formatterArg)
+#else
+ASOptions::ASOptions(ASFormatter& formatterArg, ASConsole& consoleArg)
+	: formatter(formatterArg), console(consoleArg)
+#endif
+ * parse the options vector
+ * optionsVector can be either a fileOptionsVector (option file),
+ * a projectOptionsVector (project option file),
+ * or an optionsVector (command line)
+ * @return        true if no errors, false if errors
+bool ASOptions::parseOptions(vector<string>& optionsVector, const string& errorInfo)
+	vector<string>::iterator option;
+	string arg, subArg;
+	optionErrors.clear();
+	for (option = optionsVector.begin(); option != optionsVector.end(); ++option)
+		arg = *option;
+		if (arg.compare(0, 2, "--") == 0)
+			parseOption(arg.substr(2), errorInfo);
+			size_t i;
+			for (i = 1; i < arg.length(); ++i)
+				if (i > 1
+				        && isalpha((unsigned char) arg[i])
+				        && arg[i - 1] != 'x')
+					// parse the previous option in subArg
+					parseOption(subArg, errorInfo);
+					subArg = "";
+				// append the current option to subArg
+				subArg.append(1, arg[i]);
+			// parse the last option
+			subArg = "";
+		else
+			parseOption(arg, errorInfo);
+			subArg = "";
+	if (optionErrors.str().length() > 0)
+		return false;
+	return true;
+void ASOptions::parseOption(const string& arg, const string& errorInfo)
+	if (isOption(arg, "A1", "style=allman") || isOption(arg, "style=bsd") || isOption(arg, "style=break"))
+		formatter.setFormattingStyle(STYLE_ALLMAN);
+	else if (isOption(arg, "A2", "style=java") || isOption(arg, "style=attach"))
+		formatter.setFormattingStyle(STYLE_JAVA);
+	else if (isOption(arg, "A3", "style=k&r") || isOption(arg, "style=kr") || isOption(arg, "style=k/r"))
+		formatter.setFormattingStyle(STYLE_KR);
+	else if (isOption(arg, "A4", "style=stroustrup"))
+		formatter.setFormattingStyle(STYLE_STROUSTRUP);
+	else if (isOption(arg, "A5", "style=whitesmith"))
+		formatter.setFormattingStyle(STYLE_WHITESMITH);
+	else if (isOption(arg, "A15", "style=vtk"))
+		formatter.setFormattingStyle(STYLE_VTK);
+	else if (isOption(arg, "A6", "style=ratliff") || isOption(arg, "style=banner"))
+		formatter.setFormattingStyle(STYLE_RATLIFF);
+	else if (isOption(arg, "A7", "style=gnu"))
+		formatter.setFormattingStyle(STYLE_GNU);
+	else if (isOption(arg, "A8", "style=linux") || isOption(arg, "style=knf"))
+		formatter.setFormattingStyle(STYLE_LINUX);
+	else if (isOption(arg, "A9", "style=horstmann") || isOption(arg, "style=run-in"))
+		formatter.setFormattingStyle(STYLE_HORSTMANN);
+	else if (isOption(arg, "A10", "style=1tbs") || isOption(arg, "style=otbs"))
+		formatter.setFormattingStyle(STYLE_1TBS);
+	else if (isOption(arg, "A14", "style=google"))
+		formatter.setFormattingStyle(STYLE_GOOGLE);
+	else if (isOption(arg, "A16", "style=mozilla"))
+		formatter.setFormattingStyle(STYLE_MOZILLA);
+	else if (isOption(arg, "A11", "style=pico"))
+		formatter.setFormattingStyle(STYLE_PICO);
+	else if (isOption(arg, "A12", "style=lisp") || isOption(arg, "style=python"))
+		formatter.setFormattingStyle(STYLE_LISP);
+	// must check for mode=cs before mode=c !!!
+	else if (isOption(arg, "mode=cs"))
+		formatter.setSharpStyle();
+		formatter.setModeManuallySet(true);
+	else if (isOption(arg, "mode=c"))
+		formatter.setCStyle();
+	else if (isOption(arg, "mode=java"))
+		formatter.setJavaStyle();
+	else if (isParamOption(arg, "t", "indent=tab="))
+		int spaceNum = 4;
+		string spaceNumParam = getParam(arg, "t", "indent=tab=");
+		if (spaceNumParam.length() > 0)
+			spaceNum = atoi(spaceNumParam.c_str());
+		if (spaceNum < 2 || spaceNum > 20)
+			isOptionError(arg, errorInfo);
+		else
+			formatter.setTabIndentation(spaceNum, false);
+	else if (isOption(arg, "indent=tab"))
+		formatter.setTabIndentation(4);
+	else if (isParamOption(arg, "T", "indent=force-tab="))
+		int spaceNum = 4;
+		string spaceNumParam = getParam(arg, "T", "indent=force-tab=");
+		else
+			formatter.setTabIndentation(spaceNum, true);
+	else if (isOption(arg, "indent=force-tab"))
+		formatter.setTabIndentation(4, true);
+	else if (isParamOption(arg, "xT", "indent=force-tab-x="))
+		int tabNum = 8;
+		string tabNumParam = getParam(arg, "xT", "indent=force-tab-x=");
+		if (tabNumParam.length() > 0)
+			tabNum = atoi(tabNumParam.c_str());
+		if (tabNum < 2 || tabNum > 20)
+		else
+			formatter.setForceTabXIndentation(tabNum);
+	else if (isOption(arg, "indent=force-tab-x"))
+		formatter.setForceTabXIndentation(8);
+	else if (isParamOption(arg, "s", "indent=spaces="))
+		int spaceNum = 4;
+		string spaceNumParam = getParam(arg, "s", "indent=spaces=");
+		else
+			formatter.setSpaceIndentation(spaceNum);
+	else if (isOption(arg, "indent=spaces"))
+		formatter.setSpaceIndentation(4);
+	else if (isParamOption(arg, "xt", "indent-continuation="))
+		int contIndent = 1;
+		string contIndentParam = getParam(arg, "xt", "indent-continuation=");
+		if (contIndentParam.length() > 0)
+			contIndent = atoi(contIndentParam.c_str());
+		if (contIndent < 0)
+		else if (contIndent > 4)
+		else
+			formatter.setContinuationIndentation(contIndent);
+	else if (isParamOption(arg, "m", "min-conditional-indent="))
+		int minIndent = MINCOND_TWO;
+		string minIndentParam = getParam(arg, "m", "min-conditional-indent=");
+		if (minIndentParam.length() > 0)
+			minIndent = atoi(minIndentParam.c_str());
+		if (minIndent >= MINCOND_END)
+		else
+			formatter.setMinConditionalIndentOption(minIndent);
+	else if (isParamOption(arg, "M", "max-continuation-indent="))
+		int maxIndent = 40;
+		string maxIndentParam = getParam(arg, "M", "max-continuation-indent=");
+		if (maxIndentParam.length() > 0)
+			maxIndent = atoi(maxIndentParam.c_str());
+		if (maxIndent < 40)
+		else if (maxIndent > 120)
+		else
+			formatter.setMaxContinuationIndentLength(maxIndent);
+	else if (isOption(arg, "N", "indent-namespaces"))
+		formatter.setNamespaceIndent(true);
+	else if (isOption(arg, "C", "indent-classes"))
+		formatter.setClassIndent(true);
+	else if (isOption(arg, "xG", "indent-modifiers"))
+		formatter.setModifierIndent(true);
+	else if (isOption(arg, "S", "indent-switches"))
+		formatter.setSwitchIndent(true);
+	else if (isOption(arg, "K", "indent-cases"))
+		formatter.setCaseIndent(true);
+	else if (isOption(arg, "xU", "indent-after-parens"))
+		formatter.setAfterParenIndent(true);
+	else if (isOption(arg, "L", "indent-labels"))
+		formatter.setLabelIndent(true);
+	else if (isOption(arg, "xW", "indent-preproc-block"))
+		formatter.setPreprocBlockIndent(true);
+	else if (isOption(arg, "w", "indent-preproc-define"))
+		formatter.setPreprocDefineIndent(true);
+	else if (isOption(arg, "xw", "indent-preproc-cond"))
+		formatter.setPreprocConditionalIndent(true);
+	else if (isOption(arg, "y", "break-closing-braces"))
+		formatter.setBreakClosingHeaderBracesMode(true);
+	else if (isOption(arg, "O", "keep-one-line-blocks"))
+		formatter.setBreakOneLineBlocksMode(false);
+	else if (isOption(arg, "o", "keep-one-line-statements"))
+		formatter.setBreakOneLineStatementsMode(false);
+	else if (isOption(arg, "P", "pad-paren"))
+		formatter.setParensOutsidePaddingMode(true);
+		formatter.setParensInsidePaddingMode(true);
+	else if (isOption(arg, "d", "pad-paren-out"))
+	else if (isOption(arg, "xd", "pad-first-paren-out"))
+		formatter.setParensFirstPaddingMode(true);
+	else if (isOption(arg, "D", "pad-paren-in"))
+	else if (isOption(arg, "H", "pad-header"))
+		formatter.setParensHeaderPaddingMode(true);
+	else if (isOption(arg, "U", "unpad-paren"))
+		formatter.setParensUnPaddingMode(true);
+	else if (isOption(arg, "p", "pad-oper"))
+		formatter.setOperatorPaddingMode(true);
+	else if (isOption(arg, "xg", "pad-comma"))
+		formatter.setCommaPaddingMode(true);
+	else if (isOption(arg, "xe", "delete-empty-lines"))
+		formatter.setDeleteEmptyLinesMode(true);
+	else if (isOption(arg, "E", "fill-empty-lines"))
+		formatter.setEmptyLineFill(true);
+	else if (isOption(arg, "c", "convert-tabs"))
+		formatter.setTabSpaceConversionMode(true);
+	else if (isOption(arg, "xy", "close-templates"))
+		formatter.setCloseTemplatesMode(true);
+	else if (isOption(arg, "F", "break-blocks=all"))
+		formatter.setBreakBlocksMode(true);
+		formatter.setBreakClosingHeaderBlocksMode(true);
+	else if (isOption(arg, "f", "break-blocks"))
+	else if (isOption(arg, "e", "break-elseifs"))
+		formatter.setBreakElseIfsMode(true);
+	else if (isOption(arg, "xb", "break-one-line-headers"))
+		formatter.setBreakOneLineHeadersMode(true);
+	else if (isOption(arg, "j", "add-braces"))
+		formatter.setAddBracesMode(true);
+	else if (isOption(arg, "J", "add-one-line-braces"))
+		formatter.setAddOneLineBracesMode(true);
+	else if (isOption(arg, "xj", "remove-braces"))
+		formatter.setRemoveBracesMode(true);
+	else if (isOption(arg, "Y", "indent-col1-comments"))
+		formatter.setIndentCol1CommentsMode(true);
+	else if (isOption(arg, "align-pointer=type"))
+		formatter.setPointerAlignment(PTR_ALIGN_TYPE);
+	else if (isOption(arg, "align-pointer=middle"))
+		formatter.setPointerAlignment(PTR_ALIGN_MIDDLE);
+	else if (isOption(arg, "align-pointer=name"))
+		formatter.setPointerAlignment(PTR_ALIGN_NAME);
+	else if (isParamOption(arg, "k"))
+		int align = 0;
+		string styleParam = getParam(arg, "k");
+		if (styleParam.length() > 0)
+			align = atoi(styleParam.c_str());
+		if (align < 1 || align > 3)
+		else if (align == 1)
+		else if (align == 2)
+		else if (align == 3)
+	else if (isOption(arg, "align-reference=none"))
+		formatter.setReferenceAlignment(REF_ALIGN_NONE);
+	else if (isOption(arg, "align-reference=type"))
+		formatter.setReferenceAlignment(REF_ALIGN_TYPE);
+	else if (isOption(arg, "align-reference=middle"))
+		formatter.setReferenceAlignment(REF_ALIGN_MIDDLE);
+	else if (isOption(arg, "align-reference=name"))
+		formatter.setReferenceAlignment(REF_ALIGN_NAME);
+	else if (isParamOption(arg, "W"))
+		int align = 0;
+		string styleParam = getParam(arg, "W");
+		if (align < 0 || align > 3)
+		else if (align == 0)
+	else if (isParamOption(arg, "max-code-length="))
+		int maxLength = 50;
+		string maxLengthParam = getParam(arg, "max-code-length=");
+		if (maxLengthParam.length() > 0)
+			maxLength = atoi(maxLengthParam.c_str());
+		if (maxLength < 50)
+		else if (maxLength > 200)
+		else
+			formatter.setMaxCodeLength(maxLength);
+	else if (isParamOption(arg, "xC"))
+		string maxLengthParam = getParam(arg, "xC");
+		if (maxLength > 200)
+		else
+	else if (isOption(arg, "xL", "break-after-logical"))
+		formatter.setBreakAfterMode(true);
+	else if (isOption(arg, "xc", "attach-classes"))
+		formatter.setAttachClass(true);
+	else if (isOption(arg, "xV", "attach-closing-while"))
+		formatter.setAttachClosingWhile(true);
+	else if (isOption(arg, "xk", "attach-extern-c"))
+		formatter.setAttachExternC(true);
+	else if (isOption(arg, "xn", "attach-namespaces"))
+		formatter.setAttachNamespace(true);
+	else if (isOption(arg, "xl", "attach-inlines"))
+		formatter.setAttachInline(true);
+	else if (isOption(arg, "xp", "remove-comment-prefix"))
+		formatter.setStripCommentPrefix(true);
+	else if (isOption(arg, "xB", "break-return-type"))
+		formatter.setBreakReturnType(true);
+	else if (isOption(arg, "xD", "break-return-type-decl"))
+		formatter.setBreakReturnTypeDecl(true);
+	else if (isOption(arg, "xf", "attach-return-type"))
+		formatter.setAttachReturnType(true);
+	else if (isOption(arg, "xh", "attach-return-type-decl"))
+		formatter.setAttachReturnTypeDecl(true);
+	// Objective-C options
+	else if (isOption(arg, "xQ", "pad-method-prefix"))
+		formatter.setMethodPrefixPaddingMode(true);
+	else if (isOption(arg, "xR", "unpad-method-prefix"))
+		formatter.setMethodPrefixUnPaddingMode(true);
+	else if (isOption(arg, "xq", "pad-return-type"))
+		formatter.setReturnTypePaddingMode(true);
+	else if (isOption(arg, "xr", "unpad-return-type"))
+		formatter.setReturnTypeUnPaddingMode(true);
+	else if (isOption(arg, "xS", "pad-param-type"))
+		formatter.setParamTypePaddingMode(true);
+	else if (isOption(arg, "xs", "unpad-param-type"))
+		formatter.setParamTypeUnPaddingMode(true);
+	else if (isOption(arg, "xM", "align-method-colon"))
+		formatter.setAlignMethodColon(true);
+	else if (isOption(arg, "xP0", "pad-method-colon=none"))
+		formatter.setObjCColonPaddingMode(COLON_PAD_NONE);
+	else if (isOption(arg, "xP1", "pad-method-colon=all"))
+		formatter.setObjCColonPaddingMode(COLON_PAD_ALL);
+	else if (isOption(arg, "xP2", "pad-method-colon=after"))
+		formatter.setObjCColonPaddingMode(COLON_PAD_AFTER);
+	else if (isOption(arg, "xP3", "pad-method-colon=before"))
+		formatter.setObjCColonPaddingMode(COLON_PAD_BEFORE);
+	// NOTE: depreciated options - remove when appropriate
+	// depreciated options ////////////////////////////////////////////////////////////////////////
+	else if (isOption(arg, "indent-preprocessor"))		// depreciated release 2.04
+	else if (isOption(arg, "style=ansi"))					// depreciated release 2.05
+	// depreciated in release 3.0 /////////////////////////////////////////////////////////////////
+	else if (isOption(arg, "break-closing-brackets"))		// depreciated release 3.0
+		formatter.setBreakClosingHeaderBracketsMode(true);
+	else if (isOption(arg, "add-brackets"))				// depreciated release 3.0
+		formatter.setAddBracketsMode(true);
+	else if (isOption(arg, "add-one-line-brackets"))		// depreciated release 3.0
+		formatter.setAddOneLineBracketsMode(true);
+	else if (isOption(arg, "remove-brackets"))			// depreciated release 3.0
+		formatter.setRemoveBracketsMode(true);
+	else if (isParamOption(arg, "max-instatement-indent="))	// depreciated release 3.0
+		string maxIndentParam = getParam(arg, "max-instatement-indent=");
+		else
+			formatter.setMaxInStatementIndentLength(maxIndent);
+	// end depreciated options ////////////////////////////////////////////////////////////////////
+#ifdef ASTYLE_LIB
+	// End of options used by GUI /////////////////////////////////////////////////////////////////
+	else
+#else
+	// Options used by only console ///////////////////////////////////////////////////////////////
+	else if (isOption(arg, "n", "suffix=none"))
+		console.setNoBackup(true);
+	else if (isParamOption(arg, "suffix="))
+		string suffixParam = getParam(arg, "suffix=");
+		if (suffixParam.length() > 0)
+			console.setOrigSuffix(suffixParam);
+	else if (isParamOption(arg, "exclude="))
+		string suffixParam = getParam(arg, "exclude=");
+			console.updateExcludeVector(suffixParam);
+	else if (isOption(arg, "r", "R") || isOption(arg, "recursive"))
+		console.setIsRecursive(true);
+	else if (isOption(arg, "dry-run"))
+		console.setIsDryRun(true);
+	else if (isOption(arg, "Z", "preserve-date"))
+		console.setPreserveDate(true);
+	else if (isOption(arg, "v", "verbose"))
+		console.setIsVerbose(true);
+	else if (isOption(arg, "Q", "formatted"))
+		console.setIsFormattedOnly(true);
+	else if (isOption(arg, "q", "quiet"))
+		console.setIsQuiet(true);
+	else if (isOption(arg, "i", "ignore-exclude-errors"))
+		console.setIgnoreExcludeErrors(true);
+	else if (isOption(arg, "xi", "ignore-exclude-errors-x"))
+		console.setIgnoreExcludeErrorsAndDisplay(true);
+	else if (isOption(arg, "X", "errors-to-stdout"))
+		console.setErrorStream(&cout);
+	else if (isOption(arg, "lineend=windows"))
+		formatter.setLineEndFormat(LINEEND_WINDOWS);
+	else if (isOption(arg, "lineend=linux"))
+		formatter.setLineEndFormat(LINEEND_LINUX);
+	else if (isOption(arg, "lineend=macold"))
+		formatter.setLineEndFormat(LINEEND_MACOLD);
+	else if (isParamOption(arg, "z"))
+		int lineendType = 0;
+		string lineendParam = getParam(arg, "z");
+		if (lineendParam.length() > 0)
+			lineendType = atoi(lineendParam.c_str());
+		if (lineendType < 1 || lineendType > 3)
+		else if (lineendType == 1)
+		else if (lineendType == 2)
+		else if (lineendType == 3)
+	else
+#endif
+}	// End of parseOption function
+// Parse options from the option file.
+void ASOptions::importOptions(stringstream& in, vector<string>& optionsVector)
+	char ch;
+	bool isInQuote = false;
+	char quoteChar = ' ';
+	string currentToken;
+	while (in)
+		currentToken = "";
+		do
+			in.get(ch);
+			if (in.eof())
+				break;
+			// treat '#' as line comments
+			if (ch == '#')
+				while (in)
+					in.get(ch);
+					if (ch == '\n' || ch == '\r')
+						break;
+			// break options on new-lines, tabs, commas, or spaces
+			// remove quotes from output
+			if (in.eof() || ch == '\n' || ch == '\r' || ch == '\t' || ch == ',')
+				break;
+			if (ch == ' ' && !isInQuote)
+				break;
+			if (ch == quoteChar && isInQuote)
+				break;
+			if (ch == '"' || ch == '\'')
+				isInQuote = true;
+				quoteChar = ch;
+				continue;
+			currentToken.append(1, ch);
+		while (in);
+		if (currentToken.length() != 0)
+			optionsVector.emplace_back(currentToken);
+		isInQuote = false;
+string ASOptions::getOptionErrors() const
+	return optionErrors.str();
+string ASOptions::getParam(const string& arg, const char* op)
+	return arg.substr(strlen(op));
+string ASOptions::getParam(const string& arg, const char* op1, const char* op2)
+	return isParamOption(arg, op1) ? getParam(arg, op1) : getParam(arg, op2);
+bool ASOptions::isOption(const string& arg, const char* op)
+bool ASOptions::isOption(const string& arg, const char* op1, const char* op2)
+	return (isOption(arg, op1) || isOption(arg, op2));
+void ASOptions::isOptionError(const string& arg, const string& errorInfo)
+	if (optionErrors.str().length() == 0)
+		optionErrors << errorInfo << endl;   // need main error message
+	optionErrors << "\t" << arg << endl;
+bool ASOptions::isParamOption(const string& arg, const char* option)
+			retVal = false;
+	return retVal;
+bool ASOptions::isParamOption(const string& arg, const char* option1, const char* option2)
+	return isParamOption(arg, option1) || isParamOption(arg, option2);
+// ASEncoding class
+// Return true if an int is big endian.
+bool ASEncoding::getBigEndian() const
+	char16_t word = 0x0001;
+	char* byte = (char*) &word;
+	return (byte[0] ? false : true);
+// Swap the two low order bytes of a 16 bit integer value.
+int ASEncoding::swap16bit(int value) const
+	return (((value & 0xff) << 8) | ((value & 0xff00) >> 8));
+// Return the length of a utf-16 C string.
+// The length is in number of char16_t.
+size_t ASEncoding::utf16len(const utf16* utf16In) const
+	size_t length = 0;
+	while (*utf16In++ != '\0')
+		length++;
+	return length;
+// Adapted from SciTE UniConversion.cxx.
+// Copyright 1998-2001 by Neil Hodgson <neilh at scintilla.org>
+// Modified for Artistic Style by Jim Pattee.
+// Compute the length of an output utf-8 file given a utf-16 file.
+// Input inLen is the size in BYTES (not wchar_t).
+size_t ASEncoding::utf8LengthFromUtf16(const char* utf16In, size_t inLen, bool isBigEndian) const
+	size_t len = 0;
+	size_t wcharLen = (inLen / 2) + (inLen % 2);
+	const char16_t* uptr = reinterpret_cast<const char16_t*>(utf16In);
+	for (size_t i = 0; i < wcharLen;)
+		size_t uch = isBigEndian ? swap16bit(uptr[i]) : uptr[i];
+		if (uch < 0x80)
+			len++;
+		else if (uch < 0x800)
+			len += 2;
+		else if ((uch >= SURROGATE_LEAD_FIRST) && (uch <= SURROGATE_LEAD_LAST))
+			len += 4;
+			i++;
+		else
+			len += 3;
+		i++;
+	return len;
+// Adapted from SciTE Utf8_16.cxx.
+// Copyright (C) 2002 Scott Kirkwood.
+// Convert a utf-8 file to utf-16.
+size_t ASEncoding::utf8ToUtf16(char* utf8In, size_t inLen, bool isBigEndian, char* utf16Out) const
+	int nCur = 0;
+	ubyte* pRead = reinterpret_cast<ubyte*>(utf8In);
+	utf16* pCur = reinterpret_cast<utf16*>(utf16Out);
+	const ubyte* pEnd = pRead + inLen;
+	const utf16* pCurStart = pCur;
+	eState state = eStart;
+	// the BOM will automatically be converted to utf-16
+	while (pRead < pEnd)
+		switch (state)
+			case eStart:
+				if ((0xF0 & *pRead) == 0xF0)
+					nCur = (0x7 & *pRead) << 18;
+					state = eSecondOf4Bytes;
+				else if ((0xE0 & *pRead) == 0xE0)
+					nCur = (~0xE0 & *pRead) << 12;
+					state = ePenultimate;
+				else if ((0xC0 & *pRead) == 0xC0)
+					nCur = (~0xC0 & *pRead) << 6;
+					state = eFinal;
+				else
+					nCur = *pRead;
+					state = eStart;
+				break;
+			case eSecondOf4Bytes:
+				nCur |= (0x3F & *pRead) << 12;
+				break;
+			case ePenultimate:
+				nCur |= (0x3F & *pRead) << 6;
+				state = eFinal;
+				break;
+			case eFinal:
+				nCur |= (0x3F & *pRead);
+				state = eStart;
+				break;
+				// no default case is needed
+		++pRead;
+		if (state == eStart)
+			int codePoint = nCur;
+			if (codePoint >= SURROGATE_FIRST_VALUE)
+				codePoint -= SURROGATE_FIRST_VALUE;
+				int lead = (codePoint >> 10) + SURROGATE_LEAD_FIRST;
+				*pCur++ = static_cast<utf16>(isBigEndian ? swap16bit(lead) : lead);
+				int trail = (codePoint & 0x3ff) + SURROGATE_TRAIL_FIRST;
+				*pCur++ = static_cast<utf16>(isBigEndian ? swap16bit(trail) : trail);
+			else
+				*pCur++ = static_cast<utf16>(isBigEndian ? swap16bit(codePoint) : codePoint);
+	// return value is the output length in BYTES (not wchar_t)
+	return (pCur - pCurStart) * 2;
+// Compute the length of an output utf-16 file given a utf-8 file.
+// Return value is the size in BYTES (not wchar_t).
+size_t ASEncoding::utf16LengthFromUtf8(const char* utf8In, size_t len) const
+	size_t ulen = 0;
+	size_t charLen;
+	for (size_t i = 0; i < len;)
+		unsigned char ch = static_cast<unsigned char>(utf8In[i]);
+		if (ch < 0x80)
+			charLen = 1;
+		else if (ch < 0x80 + 0x40 + 0x20)
+			charLen = 2;
+		else if (ch < 0x80 + 0x40 + 0x20 + 0x10)
+			charLen = 3;
+		else
+			charLen = 4;
+			ulen++;
+		i += charLen;
+		ulen++;
+	// return value is the length in bytes (not wchar_t)
+	return ulen * 2;
+// Convert a utf-16 file to utf-8.
+size_t ASEncoding::utf16ToUtf8(char* utf16In, size_t inLen, bool isBigEndian,
+                               bool firstBlock, char* utf8Out) const
+	int nCur16 = 0;
+	int nCur = 0;
+	ubyte* pRead = reinterpret_cast<ubyte*>(utf16In);
+	ubyte* pCur = reinterpret_cast<ubyte*>(utf8Out);
+	const ubyte* pCurStart = pCur;
+	static eState state = eStart;	// state is retained for subsequent blocks
+	if (firstBlock)
+		state = eStart;
+	// the BOM will automatically be converted to utf-8
+		switch (state)
+			case eStart:
+				if (pRead >= pEnd)
+					++pRead;
+					break;
+				if (isBigEndian)
+					nCur16 = static_cast<utf16>(*pRead++ << 8);
+					nCur16 |= static_cast<utf16>(*pRead);
+				else
+					nCur16 = *pRead++;
+					nCur16 |= static_cast<utf16>(*pRead << 8);
+				if (nCur16 >= SURROGATE_LEAD_FIRST && nCur16 <= SURROGATE_LEAD_LAST)
+					++pRead;
+					int trail;
+					if (isBigEndian)
+						trail = static_cast<utf16>(*pRead++ << 8);
+						trail |= static_cast<utf16>(*pRead);
+					else
+						trail = *pRead++;
+						trail |= static_cast<utf16>(*pRead << 8);
+					nCur16 = (((nCur16 & 0x3ff) << 10) | (trail & 0x3ff)) + SURROGATE_FIRST_VALUE;
+				++pRead;
+				if (nCur16 < 0x80)
+					nCur = static_cast<ubyte>(nCur16 & 0xFF);
+					state = eStart;
+				else if (nCur16 < 0x800)
+					nCur = static_cast<ubyte>(0xC0 | (nCur16 >> 6));
+					state = eFinal;
+				else if (nCur16 < SURROGATE_FIRST_VALUE)
+					nCur = static_cast<ubyte>(0xE0 | (nCur16 >> 12));
+				else
+					nCur = static_cast<ubyte>(0xF0 | (nCur16 >> 18));
+				break;
+				nCur = static_cast<ubyte>(0x80 | ((nCur16 >> 12) & 0x3F));
+				break;
+				nCur = static_cast<ubyte>(0x80 | ((nCur16 >> 6) & 0x3F));
+				state = eFinal;
+				break;
+			case eFinal:
+				nCur = static_cast<ubyte>(0x80 | (nCur16 & 0x3F));
+				state = eStart;
+				break;
+		*pCur++ = static_cast<ubyte>(nCur);
+	return pCur - pCurStart;
+}   // namespace astyle
+using namespace astyle;
+// ASTYLE_JNI functions for Java library builds
+#ifdef ASTYLE_JNI
+// called by a java program to get the version number
+// the function name is constructed from method names in the calling java program
+extern "C"  EXPORT
+jstring STDCALL Java_AStyleInterface_AStyleGetVersion(JNIEnv* env, jclass)
+	return env->NewStringUTF(g_version);
+// called by a java program to format the source code
+extern "C"  EXPORT
+jstring STDCALL Java_AStyleInterface_AStyleMain(JNIEnv* env,
+                                                jobject obj,
+                                                jstring textInJava,
+                                                jstring optionsJava)
+	g_env = env;                                // make object available globally
+	g_obj = obj;                                // make object available globally
+	jstring textErr = env->NewStringUTF("");    // zero length text returned if an error occurs
+	// get the method ID
+	jclass cls = env->GetObjectClass(obj);
+	g_mid = env->GetMethodID(cls, "ErrorHandler", "(ILjava/lang/String;)V");
+	if (g_mid == nullptr)
+		cout << "Cannot find java method ErrorHandler" << endl;
+		return textErr;
+	// convert jstring to char*
+	const char* textIn = env->GetStringUTFChars(textInJava, nullptr);
+	const char* options = env->GetStringUTFChars(optionsJava, nullptr);
+	// call the C++ formatting function
+	char* textOut = AStyleMain(textIn, options, javaErrorHandler, javaMemoryAlloc);
+	// if an error message occurred it was displayed by errorHandler
+	if (textOut == nullptr)
+		return textErr;
+	// release memory
+	jstring textOutJava = env->NewStringUTF(textOut);
+	delete[] textOut;
+	env->ReleaseStringUTFChars(textInJava, textIn);
+	env->ReleaseStringUTFChars(optionsJava, options);
+	return textOutJava;
+// Call the Java error handler
+void STDCALL javaErrorHandler(int errorNumber, const char* errorMessage)
+	jstring errorMessageJava = g_env->NewStringUTF(errorMessage);
+	g_env->CallVoidMethod(g_obj, g_mid, errorNumber, errorMessageJava);
+// Allocate memory for the formatted text
+char* STDCALL javaMemoryAlloc(unsigned long memoryNeeded)
+	// error condition is checked after return from AStyleMain
+	return buffer;
+#endif	// ASTYLE_JNI
+// ASTYLE_LIB functions for library builds
+#ifdef ASTYLE_LIB
+// ASTYLE_LIB entry point for AStyleMainUtf16 library builds
+* IMPORTANT Visual C DLL linker for WIN32 must have the additional options:
+*           /EXPORT:AStyleMain=_AStyleMain at 16
+*           /EXPORT:AStyleMainUtf16=_AStyleMainUtf16 at 16
+*           /EXPORT:AStyleGetVersion=_AStyleGetVersion at 0
+* No /EXPORT is required for x64
+extern "C" EXPORT char16_t* STDCALL AStyleMainUtf16(const char16_t* pSourceIn,	// the source to be formatted
+                                                    fpAlloc fpMemoryAlloc)		// memory allocation function
+	if (fpErrorHandler == nullptr)         // cannot display a message if no error handler
+		return nullptr;
+	if (pSourceIn == nullptr)
+		fpErrorHandler(101, "No pointer to source input.");
+		return nullptr;
+	if (pOptions == nullptr)
+		fpErrorHandler(102, "No pointer to AStyle options.");
+		return nullptr;
+	if (fpMemoryAlloc == nullptr)
+		fpErrorHandler(103, "No pointer to memory allocation function.");
+		return nullptr;
+#ifndef _WIN32
+	// check size of char16_t on Linux
+	int sizeCheck = 2;
+	if (sizeof(char16_t) != sizeCheck)
+		fpErrorHandler(104, "char16_t is not the correct size.");
+		return nullptr;
+#endif
+	ASLibrary library;
+	char16_t* utf16Out = library.formatUtf16(pSourceIn, pOptions, fpErrorHandler, fpMemoryAlloc);
+	return utf16Out;
+// ASTYLE_LIB entry point for library builds
+ * IMPORTANT Visual C DLL linker for WIN32 must have the additional options:
+ *           /EXPORT:AStyleMain=_AStyleMain at 16
+ *           /EXPORT:AStyleMainUtf16=_AStyleMainUtf16 at 16
+ *           /EXPORT:AStyleGetVersion=_AStyleGetVersion at 0
+ * No /EXPORT is required for x64
+extern "C" EXPORT char* STDCALL AStyleMain(const char* pSourceIn,		// the source to be formatted
+                                           const char* pOptions,		// AStyle options
+		return nullptr;
+		return nullptr;
+		return nullptr;
+		return nullptr;
+	ASFormatter formatter;
+	ASOptions options(formatter);
+	vector<string> optionsVector;
+	stringstream opt(pOptions);
+	options.importOptions(opt, optionsVector);
+	bool ok = options.parseOptions(optionsVector, "Invalid Artistic Style options:");
+	if (!ok)
+		fpErrorHandler(130, options.getOptionErrors().c_str());
+	stringstream in(pSourceIn);
+	ASStreamIterator<stringstream> streamIterator(&in);
+	ostringstream out;
+	formatter.init(&streamIterator);
+	while (formatter.hasMoreLines())
+		out << formatter.nextLine();
+		if (formatter.hasMoreLines())
+			out << streamIterator.getOutputEOL();
+		else
+			// this can happen if the file if missing a closing brace and break-blocks is requested
+			if (formatter.getIsLineReady())
+	size_t textSizeOut = out.str().length();
+	char* pTextOut = fpMemoryAlloc((long) textSizeOut + 1);     // call memory allocation function
+	if (pTextOut == nullptr)
+		fpErrorHandler(120, "Allocation failure on output.");
+		return nullptr;
+	strcpy(pTextOut, out.str().c_str());
+#ifndef NDEBUG
+	// The checksum is an assert in the console build and ASFormatter.
+	// This error returns the incorrectly formatted file to the editor.
+	// This is done to allow the file to be saved for debugging purposes.
+	if (formatter.getChecksumDiff() != 0)
+		fpErrorHandler(220,
+		               "Checksum error.\n"
+		               "The incorrectly formatted file will be returned for debugging.");
+#endif
+	return pTextOut;
+extern "C" EXPORT const char* STDCALL AStyleGetVersion(void)
+	return g_version;
+// ASTYLECON_LIB is defined to exclude "main" from the test programs
+#elif !defined(ASTYLECON_LIB)
+// main function for ASConsole build
+int main(int argc, char** argv)
+	// create objects
+	unique_ptr<ASConsole> console(new ASConsole(formatter));
+	// process command line and option files
+	// build the vectors fileNameVector, optionsVector, and fileOptionsVector
+	vector<string> argvOptions;
+	argvOptions = console->getArgvOptions(argc, argv);
+	console->processOptions(argvOptions);
+	// if no files have been given, use cin for input and cout for output
+	if (!console->fileNameVectorIsEmpty())
+		console->processFiles();
+	else
+		console->formatCinToCout();
+	return EXIT_SUCCESS;
diff --git a/tools/astyle/astyle_main.h b/tools/astyle/astyle_main.h
new file mode 100755
index 0000000..32b2be1
--- /dev/null
+++ b/tools/astyle/astyle_main.h
@@ -0,0 +1,452 @@
+// astyle_main.h
+// Copyright (c) 2018 by Jim Pattee <jimp03 at email.com>.
+// This code is licensed under the MIT License.
+// License.md describes the conditions under which this software may be distributed.
+#ifndef ASTYLE_MAIN_H
+#define ASTYLE_MAIN_H
+// headers
+#include "astyle.h"
+#include <sstream>
+#include <ctime>
+#if defined(__BORLANDC__) && __BORLANDC__ < 0x0650
+	// Embarcadero needs this for the following utime.h
+	// otherwise "struct utimbuf" gets an error on time_t
+	// 0x0650 for C++Builder XE3
+	using std::time_t;
+#endif
+#if defined(_MSC_VER)
+	#include <sys/utime.h>
+	#include <sys/stat.h>
+#else
+	#include <utime.h>
+#endif                         // end compiler checks
+#ifdef ASTYLE_JNI
+	#include <jni.h>
+	#ifndef ASTYLE_LIB    // ASTYLE_LIB must be defined for ASTYLE_JNI
+		#define ASTYLE_LIB
+	#endif
+#ifndef ASTYLE_LIB
+	// for console build only
+	#include "ASLocalizer.h"
+	#define _(a) localizer.settext(a)
+// declarations
+// for G++ implementation of string.compare:
+#if defined(__GNUC__) && __GNUC__ < 3
+	#error - Use GNU C compiler release 3 or higher
+#endif
+// for getenv and localtime
+	#pragma warning(disable: 4996)  // secure version deprecation warnings
+#endif
+// for Visual Studio supported C++11 standard
+#if defined(_MSC_VER) && _MSC_VER < 1600
+	#error Use Microsoft Visual Studio 2010 or higher
+#endif
+#ifdef __clang__
+	#pragma clang diagnostic ignored "-Wdeprecated-declarations"  // getenv, localtime
+	#pragma clang diagnostic ignored "-Wmissing-braces"
+#endif
+// for mingw BOM, UTF-16, and Unicode functions
+#if defined(__MINGW32__) && !defined(__MINGW64_VERSION_MAJOR)
+	#if (__MINGW32_MAJOR_VERSION > 3) || \
+		((__MINGW32_MAJOR_VERSION == 3) && (__MINGW32_MINOR_VERSION < 16))
+		#error - Use MinGW compiler version 4 or higher
+	#endif
+#endif
+#ifdef ASTYLE_LIB
+	// define STDCALL and EXPORT for Windows
+	// MINGW defines STDCALL in Windows.h (actually windef.h)
+	// EXPORT has no value if ASTYLE_NO_EXPORT is defined
+	#ifdef _WIN32
+		#ifndef STDCALL
+			#define STDCALL __stdcall
+		#endif
+		// define this to prevent compiler warning and error messages
+		#ifdef ASTYLE_NO_EXPORT
+			#define EXPORT
+		#else
+			#define EXPORT __declspec(dllexport)
+		#endif
+		// define STDCALL and EXPORT for non-Windows
+		// visibility attribute allows "-fvisibility=hidden" compiler option
+	#else
+		#define STDCALL
+		#if __GNUC__ >= 4
+			#define EXPORT __attribute__ ((visibility ("default")))
+		#else
+			#define EXPORT
+		#endif
+	#endif	// #ifdef _WIN32
+	// define pointers to callback error handler and memory allocation
+	typedef void (STDCALL* fpError)(int errorNumber, const char* errorMessage);
+	typedef char* (STDCALL* fpAlloc)(unsigned long memoryNeeded);
+#endif  // #ifdef ASTYLE_LIB
+// astyle namespace
+namespace astyle {
+// ASStreamIterator class
+// typename will be stringstream for AStyle
+// it could be istream or wxChar for plug-ins
+// ASSourceIterator is an inherited abstract class defined in astyle.h
+template<typename T>
+class ASStreamIterator : public ASSourceIterator
+public:
+	bool checkForEmptyLine;
+	// function declarations
+	explicit ASStreamIterator(T* in);
+	virtual ~ASStreamIterator();
+	bool getLineEndChange(int lineEndFormat) const;
+	int  getStreamLength() const;
+	string nextLine(bool emptyLineWasDeleted);
+	string peekNextLine();
+	void peekReset();
+	void saveLastInputLine();
+	streamoff tellg();
+private:
+	ASStreamIterator(const ASStreamIterator& copy);       // copy constructor not to be implemented
+	ASStreamIterator& operator=(ASStreamIterator&);       // assignment operator not to be implemented
+	T* inStream;            // pointer to the input stream
+	string buffer;          // current input line
+	string prevBuffer;      // previous input line
+	string outputEOL;       // next output end of line char
+	int eolWindows;         // number of Windows line endings, CRLF
+	int eolLinux;           // number of Linux line endings, LF
+	int eolMacOld;          // number of old Mac line endings. CR
+	streamoff streamLength; // length of the input file stream
+	streamoff peekStart;    // starting position for peekNextLine
+	bool prevLineDeleted;   // the previous input line was deleted
+public:	// inline functions
+	bool compareToInputBuffer(const string& nextLine_) const
+	{ return (nextLine_ == prevBuffer); }
+	const string& getOutputEOL() const { return outputEOL; }
+	streamoff getPeekStart() const { return peekStart; }
+	bool hasMoreLines() const { return !inStream->eof(); }
+// ASEncoding class for utf8/16 conversions
+class ASEncoding
+private:
+	typedef char16_t utf16;       // 16 bits unsigned
+	typedef unsigned char utf8;   // 8 bits
+	typedef unsigned char ubyte;  // 8 bits
+	enum { SURROGATE_LEAD_FIRST = 0xD800 };
+	enum { SURROGATE_LEAD_LAST = 0xDBFF };
+	enum { SURROGATE_TRAIL_FIRST = 0xDC00 };
+	enum { SURROGATE_TRAIL_LAST = 0xDFFF };
+	enum { SURROGATE_FIRST_VALUE = 0x10000 };
+	enum eState { eStart, eSecondOf4Bytes, ePenultimate, eFinal };
+public:
+	bool   getBigEndian() const;
+	int    swap16bit(int value) const;
+	size_t utf16len(const utf16* utf16In) const;
+	size_t utf8LengthFromUtf16(const char* utf16In, size_t inLen, bool isBigEndian) const;
+	size_t utf8ToUtf16(char* utf8In, size_t inLen, bool isBigEndian, char* utf16Out) const;
+	size_t utf16LengthFromUtf8(const char* utf8In, size_t len) const;
+	size_t utf16ToUtf8(char* utf16In, size_t inLen, bool isBigEndian,
+	                   bool firstBlock, char* utf8Out) const;
+// ASOptions class for options processing
+class ASConsole;
+class ASOptions
+public:
+#ifdef ASTYLE_LIB
+	ASOptions(ASFormatter& formatterArg);
+#else
+	ASOptions(ASFormatter& formatterArg, ASConsole& consoleArg);
+#endif
+	string getOptionErrors() const;
+	void importOptions(stringstream& in, vector<string>& optionsVector);
+	bool parseOptions(vector<string>& optionsVector, const string& errorInfo);
+private:
+	// variables
+	ASFormatter& formatter;
+	stringstream optionErrors;		// option error messages
+#ifndef ASTYLE_LIB
+	ASConsole&   console;			// DO NOT USE for ASTYLE_LIB
+#endif
+	// functions
+	ASOptions(const ASOptions&);           // copy constructor not to be implemented
+	ASOptions& operator=(ASOptions&);      // assignment operator not to be implemented
+	string getParam(const string& arg, const char* op);
+	string getParam(const string& arg, const char* op1, const char* op2);
+	bool isOption(const string& arg, const char* op);
+	bool isOption(const string& arg, const char* op1, const char* op2);
+	void isOptionError(const string& arg, const string& errorInfo);
+	bool isParamOption(const string& arg, const char* option);
+	bool isParamOption(const string& arg, const char* option1, const char* option2);
+	void parseOption(const string& arg, const string& errorInfo);
+#ifndef	ASTYLE_LIB
+// ASConsole class for console build
+class ASConsole
+private:    // variables
+	ASFormatter& formatter;             // reference to the ASFormatter object
+	ASEncoding encode;                  // file encoding conversion
+	ASLocalizer localizer;              // language translation
+	ostream* errorStream;               // direct error messages to cerr or cout
+	// command line options
+	bool isRecursive;                   // recursive option
+	bool isDryRun;                      // dry-run option
+	bool noBackup;                      // suffix=none option
+	bool preserveDate;                  // preserve-date option
+	bool isVerbose;                     // verbose option
+	bool isQuiet;                       // quiet option
+	bool isFormattedOnly;               // formatted lines only option
+	bool ignoreExcludeErrors;           // don't abort on unmatched excludes
+	bool ignoreExcludeErrorsDisplay;    // don't display unmatched excludes
+	bool useAscii;                      // ascii option
+	// other variables
+	bool bypassBrowserOpen;             // don't open the browser on html options
+	bool hasWildcard;                   // file name includes a wildcard
+	size_t mainDirectoryLength;         // directory length to be excluded in displays
+	bool filesAreIdentical;             // input and output files are identical
+	int  filesFormatted;                // number of files formatted
+	int  filesUnchanged;                // number of files unchanged
+	bool lineEndsMixed;                 // output has mixed line ends
+	int  linesOut;                      // number of output lines
+	string outputEOL;                   // current line end
+	string prevEOL;                     // previous line end
+	string optionFileName;              // file path and name of the options file
+	string origSuffix;                  // suffix= option
+	string projectOptionFileName;       // file path and name of the project options file
+	string stdPathIn;                   // path to input from stdin=
+	string stdPathOut;                  // path to output from stdout=
+	string targetDirectory;             // path to the directory being processed
+	string targetFilename;              // file name being processed
+	vector<string> excludeVector;       // exclude from wildcard hits
+	vector<bool>   excludeHitsVector;   // exclude flags for error reporting
+	vector<string> fileNameVector;      // file paths and names from the command line
+	vector<string> optionsVector;       // options from the command line
+	vector<string> projectOptionsVector;// project options from the project options file
+	vector<string> fileOptionsVector;   // options from the options file
+	vector<string> fileName;            // files to be processed including path
+public:     // functions
+	explicit ASConsole(ASFormatter& formatterArg);
+	~ASConsole();
+	void convertLineEnds(ostringstream& out, int lineEnd);
+	FileEncoding detectEncoding(const char* data, size_t dataSize) const;
+	void error() const;
+	void error(const char* why, const char* what) const;
+	void formatCinToCout();
+	vector<string> getArgvOptions(int argc, char** argv) const;
+	bool fileExists(const char* file) const;
+	bool fileNameVectorIsEmpty() const;
+	ostream* getErrorStream() const;
+	bool getFilesAreIdentical() const;
+	int  getFilesFormatted() const;
+	bool getIgnoreExcludeErrors() const;
+	bool getIgnoreExcludeErrorsDisplay() const;
+	bool getIsDryRun() const;
+	bool getIsFormattedOnly() const;
+	bool getIsQuiet() const;
+	bool getIsRecursive() const;
+	bool getIsVerbose() const;
+	bool getLineEndsMixed() const;
+	bool getNoBackup() const;
+	bool getPreserveDate() const;
+	string getLanguageID() const;
+	string getNumberFormat(int num, size_t lcid = 0) const;
+	string getNumberFormat(int num, const char* groupingArg, const char* separator) const;
+	string getOptionFileName() const;
+	string getOrigSuffix() const;
+	string getProjectOptionFileName() const;
+	string getStdPathIn() const;
+	string getStdPathOut() const;
+	void getTargetFilenames(string& targetFilename_, vector<string>& targetFilenameVector) const;
+	void processFiles();
+	void processOptions(const vector<string>& argvOptions);
+	void setBypassBrowserOpen(bool state);
+	void setErrorStream(ostream* errStreamPtr);
+	void setIgnoreExcludeErrors(bool state);
+	void setIgnoreExcludeErrorsAndDisplay(bool state);
+	void setIsDryRun(bool state);
+	void setIsFormattedOnly(bool state);
+	void setIsQuiet(bool state);
+	void setIsRecursive(bool state);
+	void setIsVerbose(bool state);
+	void setNoBackup(bool state);
+	void setOptionFileName(const string& name);
+	void setOrigSuffix(const string& suffix);
+	void setPreserveDate(bool state);
+	void setProjectOptionFileName(const string& optfilepath);
+	void setStdPathIn(const string& path);
+	void setStdPathOut(const string& path);
+	void standardizePath(string& path, bool removeBeginningSeparator = false) const;
+	bool stringEndsWith(const string& str, const string& suffix) const;
+	void updateExcludeVector(const string& suffixParam);
+	vector<string> getExcludeVector() const;
+	vector<bool>   getExcludeHitsVector() const;
+	vector<string> getFileNameVector() const;
+	vector<string> getOptionsVector() const;
+	vector<string> getProjectOptionsVector() const;
+	vector<string> getFileOptionsVector() const;
+	vector<string> getFileName() const;
+private:	// functions
+	ASConsole(const ASConsole&);           // copy constructor not to be implemented
+	ASConsole& operator=(ASConsole&);      // assignment operator not to be implemented
+	void correctMixedLineEnds(ostringstream& out);
+	void formatFile(const string& fileName_);
+	string getParentDirectory(const string& absPath) const;
+	string findProjectOptionFilePath(const string& fileName_) const;
+	string getCurrentDirectory(const string& fileName_) const;
+	void getFileNames(const string& directory, const vector<string>& wildcards);
+	void getFilePaths(const string& filePath);
+	string getFullPathName(const string& relativePath) const;
+	bool isHomeOrInvalidAbsPath(const string& absPath) const;
+	void initializeOutputEOL(LineEndFormat lineEndFormat);
+	bool isOption(const string& arg, const char* a, const char* b);
+	bool isPathExclued(const string& subPath);
+	void launchDefaultBrowser(const char* filePathIn = nullptr) const;
+	void printHelp() const;
+	void printMsg(const char* msg, const string& data) const;
+	void printSeparatingLine() const;
+	void printVerboseHeader() const;
+	void printVerboseStats(clock_t startTime) const;
+	FileEncoding readFile(const string& fileName_, stringstream& in) const;
+	void removeFile(const char* fileName_, const char* errMsg) const;
+	void renameFile(const char* oldFileName, const char* newFileName, const char* errMsg) const;
+	void setOutputEOL(LineEndFormat lineEndFormat, const string& currentEOL);
+	void sleep(int seconds) const;
+	int  waitForRemove(const char* newFileName) const;
+	int  wildcmp(const char* wild, const char* data) const;
+	void writeFile(const string& fileName_, FileEncoding encoding, ostringstream& out) const;
+#ifdef _WIN32
+	void displayLastError();
+#endif
+// ASLibrary class for library build
+class ASLibrary
+public:
+	ASLibrary() {}
+	virtual ~ASLibrary() {}
+	// virtual functions are mocked in testing
+	char16_t* formatUtf16(const char16_t*, const char16_t*, fpError, fpAlloc) const;
+	virtual char16_t* convertUtf8ToUtf16(const char* utf8In, fpAlloc fpMemoryAlloc) const;
+	virtual char* convertUtf16ToUtf8(const char16_t* utf16In) const;
+private:
+	static char* STDCALL tempMemoryAllocation(unsigned long memoryNeeded);
+private:
+}   // end of namespace astyle
+// declarations for java native interface (JNI) build
+// they are called externally and are NOT part of the namespace
+#ifdef ASTYLE_JNI
+void  STDCALL javaErrorHandler(int errorNumber, const char* errorMessage);
+char* STDCALL javaMemoryAlloc(unsigned long memoryNeeded);
+// the following function names are constructed from method names in the calling java program
+extern "C" EXPORT
+jstring STDCALL Java_AStyleInterface_AStyleGetVersion(JNIEnv* env, jclass);
+extern "C" EXPORT
+                                                jobject obj,
+                                                jstring optionsJava);
+// declarations for UTF-16 interface
+#ifdef ASTYLE_LIB
+extern "C" EXPORT
+char16_t* STDCALL AStyleMainUtf16(const char16_t* pSourceIn,
+                                  fpAlloc fpMemoryAlloc);
+// declarations for standard DLL interface
+#ifdef ASTYLE_LIB
+extern "C" EXPORT const char* STDCALL AStyleGetVersion(void);
+#endif // closes ASTYLE_MAIN_H
Summary of changes:
 configure.ac                  |    1 +
 tools/CMakeLists.txt          |    7 +-
 tools/Makefile.am             |    2 +
 tools/astyle/ASBeautifier.cpp | 3744 +++++++++++++++++++
 tools/astyle/ASEnhancer.cpp   |  796 ++++
 tools/astyle/ASFormatter.cpp  | 8245 +++++++++++++++++++++++++++++++++++++++++
 tools/astyle/ASLocalizer.cpp  | 1166 ++++++
 tools/astyle/ASLocalizer.h    |  167 +
 tools/astyle/ASResource.cpp   |  837 +++++
 tools/astyle/CMakeLists.txt   |   20 +
 tools/astyle/Makefile.am      |   31 +
 tools/astyle/astyle.h         | 1083 ++++++
 tools/astyle/astyle_main.cpp  | 4312 +++++++++++++++++++++
 tools/astyle/astyle_main.h    |  452 +++
 14 files changed, 20860 insertions(+), 3 deletions(-)
 create mode 100755 tools/astyle/ASBeautifier.cpp
 create mode 100755 tools/astyle/ASEnhancer.cpp
 create mode 100755 tools/astyle/ASFormatter.cpp
 create mode 100755 tools/astyle/ASLocalizer.cpp
 create mode 100755 tools/astyle/ASLocalizer.h
 create mode 100755 tools/astyle/ASResource.cpp
 create mode 100644 tools/astyle/CMakeLists.txt
 create mode 100644 tools/astyle/Makefile.am
 create mode 100755 tools/astyle/astyle.h
 create mode 100755 tools/astyle/astyle_main.cpp
 create mode 100755 tools/astyle/astyle_main.h
hooks/post-receive
More information about the geos-commits mailing list
