[geos-commits] [SCM] GEOS branch master updated. 94331c78858ec962e53d9bb7c0741d59cb38c05d
git at osgeo.org
git at osgeo.org
Thu Feb 14 11:59:49 PST 2019
the project "GEOS".
via 94331c78858ec962e53d9bb7c0741d59cb38c05d (commit)
via 1b74b4cd7a1431a89713458dc1260f295ff3737b (commit)
from 0d54f3453533d719f8b7bfd818cad80dc7a36b97 (commit)
revisions in full, below.
commit 94331c78858ec962e53d9bb7c0741d59cb38c05d
Merge: 0d54f34 1b74b4c
Author: mdavis <mtnclimb at gmail.com>
Date: Thu Feb 14 11:59:49 2019 -0800
Merge branch 'disable-perf-test2' of mdavis/geos into master
commit 1b74b4cd7a1431a89713458dc1260f295ff3737b
Author: Martin Davis <mtnclimb at gmail.com>
Date: Thu Feb 14 11:57:10 2019 -0800
Build perf tests but don't run them by default
diff --git a/tests/CMakeLists.txt b/tests/CMakeLists.txt
index 788fa2f..9138fe3 100644
--- a/tests/CMakeLists.txt
+++ b/tests/CMakeLists.txt
@@ -15,5 +15,5 @@ add_subdirectory(unit)
add_subdirectory(xmltester)
add_subdirectory(bigtest)
-# don't run perf tests by default
-#add_subdirectory(perf)
+# perf tests are built but not run by default
+add_subdirectory(perf)
diff --git a/tests/perf/CMakeLists.txt b/tests/perf/CMakeLists.txt
index 034c6eb..4354dee 100644
--- a/tests/perf/CMakeLists.txt
+++ b/tests/perf/CMakeLists.txt
@@ -22,8 +22,7 @@ if(GEOS_ENABLE_TESTS)
target_link_libraries(perf_class_sizes geos)
- add_test(perf_class_sizes
- ${CMAKE_RUNTIME_OUTPUT_DIRECTORY}/perf_class_sizes)
+# add_test(perf_class_sizes ${CMAKE_RUNTIME_OUTPUT_DIRECTORY}/perf_class_sizes)
add_subdirectory(operation)
add_subdirectory(capi)
diff --git a/tests/perf/capi/CMakeLists.txt b/tests/perf/capi/CMakeLists.txt
index 15e5c78..f6d8315 100644
--- a/tests/perf/capi/CMakeLists.txt
+++ b/tests/perf/capi/CMakeLists.txt
@@ -15,4 +15,4 @@ add_executable(perf_memleak_mp_prep memleak_mp_prep.c)
target_link_libraries(perf_memleak_mp_prep geos_c)
-add_test(perf_memleak_mp_prep ${CMAKE_RUNTIME_OUTPUT_DIRECTORY}/perf_memleak_mp_prep)
+#add_test(perf_memleak_mp_prep ${CMAKE_RUNTIME_OUTPUT_DIRECTORY}/perf_memleak_mp_prep)
diff --git a/tests/perf/operation/buffer/CMakeLists.txt b/tests/perf/operation/buffer/CMakeLists.txt
index b6fc3e4..da2840a 100644
--- a/tests/perf/operation/buffer/CMakeLists.txt
+++ b/tests/perf/operation/buffer/CMakeLists.txt
@@ -17,5 +17,4 @@ add_executable(perf_iterated_buffer IteratedBufferStressTest.cpp)
target_link_libraries(perf_iterated_buffer geos)
-add_test(perf_iterated_buffer
- ${CMAKE_RUNTIME_OUTPUT_DIRECTORY}/perf_iterated_buffer)
+#add_test(perf_iterated_buffer ${CMAKE_RUNTIME_OUTPUT_DIRECTORY}/perf_iterated_buffer)
diff --git a/tests/perf/operation/predicate/CMakeLists.txt b/tests/perf/operation/predicate/CMakeLists.txt
index da25f8f..71e9f51 100644
--- a/tests/perf/operation/predicate/CMakeLists.txt
+++ b/tests/perf/operation/predicate/CMakeLists.txt
@@ -17,5 +17,4 @@ add_executable(perf_rectangle_intersects RectangleIntersectsPerfTest.cpp)
target_link_libraries(perf_rectangle_intersects geos)
-add_test(perf_rectangle_intersects
- ${CMAKE_RUNTIME_OUTPUT_DIRECTORY}/perf_rectangle_intersects)
+#add_test(perf_rectangle_intersects ${CMAKE_RUNTIME_OUTPUT_DIRECTORY}/perf_rectangle_intersects)
Summary of changes:
tests/CMakeLists.txt | 4 ++--
tests/perf/CMakeLists.txt | 3 +--
tests/perf/capi/CMakeLists.txt | 2 +-
tests/perf/operation/buffer/CMakeLists.txt | 3 +--
tests/perf/operation/predicate/CMakeLists.txt | 3 +--
5 files changed, 6 insertions(+), 9 deletions(-)
hooks/post-receive
More information about the geos-commits
