[geos-commits] [SCM] GEOS branch master updated. b2347421b7b7faa6d77ecc615ec26d3cdb5d901c
git at osgeo.org
git at osgeo.org
Mon Feb 18 15:49:32 PST 2019
the project "GEOS".
via b2347421b7b7faa6d77ecc615ec26d3cdb5d901c (commit)
from 5aae71f51ab85df4594985f1e1abedd1ce085bbc (commit)
revisions in full, below.
commit b2347421b7b7faa6d77ecc615ec26d3cdb5d901c
Author: mdavis <mtnclimb at gmail.com>
Date: Mon Feb 18 15:49:31 2019 -0800
Fix more spaces in InteriorPointAreaPerfTest (#67)
diff --git a/tests/perf/algorithm/InteriorPointAreaPerfTest.cpp b/tests/perf/algorithm/InteriorPointAreaPerfTest.cpp
index 7cc0afa..c118439 100644
--- a/tests/perf/algorithm/InteriorPointAreaPerfTest.cpp
+++ b/tests/perf/algorithm/InteriorPointAreaPerfTest.cpp
@@ -50,7 +50,7 @@ public:
test(int nPts)
Coordinate origin(ORG_X, ORG_Y);
- std::unique_ptr<Polygon> sinePoly =
+ std::unique_ptr<Polygon> sinePoly =
createSineStar(origin, SIZE, nPts);
@@ -80,7 +80,7 @@ private:
PrecisionModel pm;
GeometryFactory::Ptr fact;
- void
+ void
showHeader() {
cout << "Interior Point Area perf test" << endl;
cout << "# Iterations: " << N_ITER << endl;
@@ -88,7 +88,7 @@ private:
<< ORG_X << ", " << ORG_Y
<< ") size: " << SIZE
<< " # arms: " << N_ARMS
- << " arm ratio: " << ARM_RATIO
+ << " arm ratio: " << ARM_RATIO
<< endl;
Summary of changes:
tests/perf/algorithm/InteriorPointAreaPerfTest.cpp | 6 +++---
1 file changed, 3 insertions(+), 3 deletions(-)
hooks/post-receive
More information about the geos-commits
