[geos-commits] [SCM] GEOS branch master updated. 6fcdaeebc7ed507ef03dd6b1cc923cca4c50b70b
Fri Feb 22 11:35:48 PST 2019
the project "GEOS".
       via  6fcdaeebc7ed507ef03dd6b1cc923cca4c50b70b (commit)
       via  e77d7df343d006a86e23602813bab9f52129e95c (commit)
       via  4c38ed7bfcb79e2266441823fa460e657f1e41ed (commit)
       via  78577f4c3b0a8389c24e7dbdf098c1de679f52a6 (commit)
      from  85b2d372728d9cd82fe49fde3326fd0213f1fd14 (commit)
revisions in full, below.
commit 6fcdaeebc7ed507ef03dd6b1cc923cca4c50b70b
Merge: 85b2d37 e77d7df
Author: mdavis <mtnclimb at gmail.com>
Date:   Fri Feb 22 11:35:48 2019 -0800
    Merge branch 'InteriorPointAreaPerfTest_fixes' of rouault/geos into master
commit e77d7df343d006a86e23602813bab9f52129e95c
Author: Even Rouault <even.rouault at spatialys.com>
Date:   Fri Feb 22 14:36:24 2019 +0100
    tools/astyle/Makefile.am: fixes so that the .tar.gz generated by 'make dist' can be built with cmake
diff --git a/tools/astyle/Makefile.am b/tools/astyle/Makefile.am
index d582267..432eb11 100644
--- a/tools/astyle/Makefile.am
+++ b/tools/astyle/Makefile.am
@@ -7,9 +7,7 @@ AUTOMAKE_OPTIONS = subdir-objects
 AM_CPPFLAGS =
 EXTRA_DIST = \
-	ASLocalizer.h \
-	astyle.h \
-	astyle_main.h
+	CMakeLists.txt
 noinst_PROGRAMS = astyle
 #check_PROGRAMS =
@@ -24,4 +22,7 @@ astyle_SOURCES = \
 	astyle_main.cpp
-noinst_HEADERS =
+noinst_HEADERS = \
+	ASLocalizer.h \
+	astyle.h \
+	astyle_main.h
commit 4c38ed7bfcb79e2266441823fa460e657f1e41ed
Date:   Fri Feb 22 14:28:50 2019 +0100
    Integrate InteriorPointAreaPerfTest.cpp in autoconf builds (fixes #957)
diff --git a/configure.ac b/configure.ac
index 3852b64..8a6981a 100644
--- a/configure.ac
+++ b/configure.ac
@@ -493,6 +493,7 @@ AC_OUTPUT([
 	tests/bigtest/Makefile
 	tests/unit/Makefile
 	tests/perf/Makefile
+	tests/perf/algorithm/Makefile
 	tests/perf/operation/Makefile
 	tests/perf/operation/buffer/Makefile
 	tests/perf/operation/predicate/Makefile
diff --git a/tests/perf/Makefile.am b/tests/perf/Makefile.am
index f3a0546..82f124d 100644
--- a/tests/perf/Makefile.am
+++ b/tests/perf/Makefile.am
@@ -2,6 +2,7 @@
 # This file is part of project GEOS (http://trac.osgeo.org/geos/)
 SUBDIRS = \
+	algorithm \
 	operation \
 	capi
commit 78577f4c3b0a8389c24e7dbdf098c1de679f52a6
Date:   Fri Feb 22 14:28:22 2019 +0100
    InteriorPointAreaPerfTest.cpp: fix MSVC build (fixes #957)
diff --git a/tests/perf/algorithm/InteriorPointAreaPerfTest.cpp b/tests/perf/algorithm/InteriorPointAreaPerfTest.cpp
index 9ff3913..9d47ba1 100644
--- a/tests/perf/algorithm/InteriorPointAreaPerfTest.cpp
+++ b/tests/perf/algorithm/InteriorPointAreaPerfTest.cpp
@@ -50,7 +50,7 @@ public:
     test(int nPts)
         Coordinate origin(ORG_X, ORG_Y);
-        std::unique_ptr<Polygon> sinePoly =
+        std::unique_ptr<geos::geom::Polygon> sinePoly =
             createSineStar(origin, SIZE, nPts);
@@ -96,8 +96,6 @@ private:
     void
     test(geos::geom::Geometry& poly)
-        typedef vector<const Geometry*>::size_type size_type;
         geos::util::Profile sw("");
         sw.start();
@@ -109,7 +107,7 @@ private:
         cout << poly.getNumPoints() << " points: " << sw.getTotFormatted() << endl;
     createSineStar(const Coordinate& origin,
                    double size, int nPts)
@@ -121,7 +119,7 @@ private:
         gsf.setNumPoints(nPts);
         gsf.setArmLengthRatio( ARM_RATIO );
         gsf.setNumArms( N_ARMS );
-        std::unique_ptr<Polygon> poly = gsf.createSineStar();
+        std::unique_ptr<geos::geom::Polygon> poly = gsf.createSineStar();
         return poly;
Summary of changes:
 configure.ac                                       | 1 +
 tests/perf/Makefile.am                             | 1 +
 tests/perf/algorithm/InteriorPointAreaPerfTest.cpp | 8 +++-----
 tools/astyle/Makefile.am                           | 9 +++++----
 4 files changed, 10 insertions(+), 9 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
