[geos-commits] [SCM] GEOS branch master updated. 253367029a7e04db52b6828836676dd28cdbfe72
git at osgeo.org
git at osgeo.org
Wed Jan 23 10:30:08 PST 2019
the project "GEOS".
via 253367029a7e04db52b6828836676dd28cdbfe72 (commit)
from 669d86fa16a1a3ec33be73723e14640182504cd7 (commit)
revisions in full, below.
commit 253367029a7e04db52b6828836676dd28cdbfe72
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Wed Jan 23 10:29:55 2019 -0800
Confirm Polygon.normalize
JTS 3500a912c40cee7fd7ad706a8ae3b412fa3e4452
diff --git a/include/geos/algorithm/Orientation.h b/include/geos/algorithm/Orientation.h
index d051da2..1dea230 100644
--- a/include/geos/algorithm/Orientation.h
+++ b/include/geos/algorithm/Orientation.h
@@ -64,8 +64,8 @@ public:
* ( {@link #Orientation::COUNTERCLOCKWISE},
* {@link #Orientation::CLOCKWISE}, or {@link #Orientation::STRAIGHT} )
- static int index(const geom::Coordinate &p1,
- const geom::Coordinate &p2, const geom::Coordinate &q);
+ static int index(const geom::Coordinate &p1, const geom::Coordinate &p2,
+ const geom::Coordinate &q);
* Computes whether a ring defined by an array of {@link Coordinate}s is
@@ -86,8 +86,6 @@ public:
static bool isCCW(const geom::CoordinateSequence* ring);
diff --git a/src/algorithm/Orientation.cpp b/src/algorithm/Orientation.cpp
index 13a7215..de1d7bd 100644
--- a/src/algorithm/Orientation.cpp
+++ b/src/algorithm/Orientation.cpp
@@ -31,8 +31,8 @@ namespace algorithm { // geos.algorithm
/* public static */
int
-Orientation::index(const geom::Coordinate &p1,
+Orientation::index(const geom::Coordinate &p1, const geom::Coordinate &p2,
return CGAlgorithmsDD::orientationIndex(p1, p2, q);
@@ -42,20 +42,18 @@ bool
Orientation::isCCW(const geom::CoordinateSequence *ring)
// sanity check
- if (ring->getSize() < 4)
- throw util::IllegalArgumentException("Ring has fewer than 3 points, so orientation cannot be determined");
+ if (ring->getSize() < 4) {
+ throw util::IllegalArgumentException("Ring has fewer than 4 points, so orientation cannot be determined");
// # of points without closing endpoint
- const std::size_t nPts=ring->getSize()-1;
+ const std::size_t nPts = ring->getSize()-1;
// find highest point
- const geom::Coordinate *hiPt=&ring->getAt(0);
+ const geom::Coordinate *hiPt = &ring->getAt(0);
size_t hiIndex = 0;
- for (std::size_t i = 1; i <= nPts; ++i)
- const geom::Coordinate *p=&ring->getAt(i);
+ for (std::size_t i = 1; i <= nPts; ++i) {
+ const geom::Coordinate *p = &ring->getAt(i);
if (p->y > hiPt->y) {
hiPt = p;
hiIndex = i;
@@ -68,13 +66,15 @@ Orientation::isCCW(const geom::CoordinateSequence *ring)
if (iPrev == 0)
iPrev = nPts;
iPrev = iPrev - 1;
- } while (ring->getAt(iPrev) == *hiPt && iPrev != hiIndex);
+ while (ring->getAt(iPrev) == *hiPt && iPrev != hiIndex);
// find distinct point after highest point
auto iNext = hiIndex;
do {
iNext = (iNext + 1) % nPts;
- } while (ring->getAt(iNext)==*hiPt && iNext != hiIndex);
+ while (ring->getAt(iNext)==*hiPt && iNext != hiIndex);
const geom::Coordinate *prev=&ring->getAt(iPrev);
const geom::Coordinate *next=&ring->getAt(iNext);
@@ -86,19 +86,15 @@ Orientation::isCCW(const geom::CoordinateSequence *ring)
* (including the case where the input array has fewer than 4 elements),
* or it contains coincident line segments.
- if ( prev->equals2D(*hiPt) || next->equals2D(*hiPt) ||
- prev->equals2D(*next) )
+ if (prev->equals2D(*hiPt) || next->equals2D(*hiPt) ||
+ prev->equals2D(*next)) {
return false;
// MD - don't bother throwing exception,
// since this isn't a complete check for ring validity
//throw IllegalArgumentException("degenerate ring (does not contain 3 distinct points)");
- // New DD high precision implementation
int disc = Orientation::index(*prev, *hiPt, *next);
- // Old double implementation
- // int disc = CGAlgorithms::computeOrientation(*prev, *hiPt, *next);
* If disc is exactly 0, lines are collinear.
@@ -110,12 +106,13 @@ Orientation::isCCW(const geom::CoordinateSequence *ring)
* (2) should never happen, so we're going to ignore it!
* (Might want to assert this)
- bool isCCW=false;
+ bool isCCW = false;
if (disc == 0) {
// poly is CCW if prev x is right of next x
isCCW = (prev->x > next->x);
- } else {
+ else {
// if area is positive, points are ordered CCW
isCCW = (disc > 0);
diff --git a/src/geom/Polygon.cpp b/src/geom/Polygon.cpp
index 7d5dfbf..8211b91 100644
--- a/src/geom/Polygon.cpp
+++ b/src/geom/Polygon.cpp
@@ -341,12 +341,12 @@ Polygon::normalize(LinearRing *ring, bool clockwise)
if (ring->isEmpty()) {
return;
- CoordinateSequence* uniqueCoordinates=ring->getCoordinates();
+ CoordinateSequence* uniqueCoordinates = ring->getCoordinates();
uniqueCoordinates->deleteAt(uniqueCoordinates->getSize()-1);
- const Coordinate* minCoordinate=CoordinateSequence::minCoordinate(uniqueCoordinates);
+ const Coordinate* minCoordinate = CoordinateSequence::minCoordinate(uniqueCoordinates);
CoordinateSequence::scroll(uniqueCoordinates, minCoordinate);
uniqueCoordinates->add(uniqueCoordinates->getAt(0));
- if (algorithm::Orientation::isCCW(uniqueCoordinates)==clockwise) {
+ if (algorithm::Orientation::isCCW(uniqueCoordinates) == clockwise) {
CoordinateSequence::reverse(uniqueCoordinates);
ring->setPoints(uniqueCoordinates);
Summary of changes:
include/geos/algorithm/Orientation.h | 6 ++----
src/algorithm/Orientation.cpp | 37 +++++++++++++++++-------------------
src/geom/Polygon.cpp | 6 +++---
3 files changed, 22 insertions(+), 27 deletions(-)
hooks/post-receive
More information about the geos-commits
