[geos-commits] [SCM] GEOS branch svn-3.5 updated. fa3be2ec90992c0c34cc7744e99dcccd0b0c0ef0
git at osgeo.org
git at osgeo.org
Fri Jan 25 08:47:27 PST 2019
the project "GEOS".
The branch, svn-3.5 has been updated
via fa3be2ec90992c0c34cc7744e99dcccd0b0c0ef0 (commit)
from be199aa38726248cc5b52c809ce0157f75f6a2fb (commit)
revisions in full, below.
commit fa3be2ec90992c0c34cc7744e99dcccd0b0c0ef0
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Fri Jan 25 08:46:59 2019 -0800
Test -ansi w/i the context of C++
References #786
diff --git a/configure.ac b/configure.ac
index a6597af..529ce91 100644
--- a/configure.ac
+++ b/configure.ac
@@ -130,7 +130,7 @@ else
fi
dnl --------------------------------------------------------------------
-dnl - Append default C++ and C flags
+dnl - Append default C++ and C flags
dnl In order for AC_LIBTOOL_COMPILER_OPTION to use
@@ -138,18 +138,21 @@ dnl the C compiler we need the hack below.
dnl It is likely a bug in the libtool macro file to
dnl require AC_LIBTOOL_LANG_CXX_CONFIG in *addition*
dnl to AC_LANG(CXX) or AC_LANG_PUSH(CXX)/AC_LANG_POP()
-dnl
+dnl
-# Set default AM_CXXFLAGS and AM_CFLAGS
+# Set default AM_CXXFLAGS and AM_CFLAGS
# -pedantic: ISO does not support long long
# we add -Wno-long-long to avoid those messages
WARNFLAGS=""
AC_LIBTOOL_COMPILER_OPTION([if $compiler supports -pedantic], [dummy_cv_pedantic], [-pedantic], [], [WARNFLAGS="$WARNFLAGS -pedantic"], [])
AC_LIBTOOL_COMPILER_OPTION([if $compiler supports -Wall], [dummy_cv_wall], [-Wall], [], [WARNFLAGS="$WARNFLAGS -Wall"], [])
-AC_LIBTOOL_COMPILER_OPTION([if $compiler supports -ansi], [dummy_cv_ansi], [-ansi], [], [WARNFLAGS="$WARNFLAGS -ansi"], [])
AC_LIBTOOL_COMPILER_OPTION([if $compiler supports -Wno-long-long], [dummy_cv_no_long_long], [-Wno-long-long], [], [WARNFLAGS="$WARNFLAGS -Wno-long-long"], [])
+AC_LANG_PUSH([C++])
+AC_LIBTOOL_COMPILER_OPTION([if $compiler supports -ansi], [dummy_cv_ansi], [-ansi], [], [WARNFLAGS="$WARNFLAGS -ansi"], [])
+AC_LANG_POP([C++])
# To make numerical computation more stable, we use --ffloat-store
NUMERICFLAGS=""
AC_LIBTOOL_COMPILER_OPTION([if $compiler supports -ffloat-store], [dummy_cv_ffloat_store], [-ffloat-store], [], [NUMERICFLAGS="$NUMERICFLAGS -ffloat-store"], [])
@@ -278,9 +281,9 @@ if test x"$use_python" = xtrue ||
test x"$use_ruby" = xtrue; then
AC_PROG_SWIG(1.3.28)
if test x"$SWIG" != "x"; then
- SWIG_ENABLE_CXX
- AC_SUBST(SWIG)
- use_swig=true
+ SWIG_ENABLE_CXX
+ AC_SUBST(SWIG)
+ use_swig=true
else
use_python=false
use_ruby=false
@@ -294,14 +297,14 @@ dnl - check for python if enabled
if test x"$use_python" = xtrue; then
- dnl Check for Python
- AM_PATH_PYTHON
+ dnl Check for Python
+ AM_PATH_PYTHON
SWIG_PYTHON
if test x"$PYTHON" = "x"; then
use_python=false
fi
AC_SUBST(PYTHON)
AC_SUBST(SWIG_PYTHON_CPPFLAGS)
AC_SUBST(SWIG_PYTHON_OPT)
@@ -314,7 +317,7 @@ dnl - check for ruby if enabled
if test x"$use_ruby" = xtrue; then
- dnl Check for Ruby
+ dnl Check for Ruby
AC_RUBY_DEVEL
if test x"$RUBY" = x; then
@@ -329,7 +332,7 @@ dnl - check for php if enabled
if test x"$use_php" = xtrue; then
- dnl Check for PHP
+ dnl Check for PHP
AC_PATH_PROG(PHP_CONFIG, php-config)
if test x"$PHP_CONFIG" = x; then
@@ -383,7 +386,7 @@ dnl AM_CXXFLAGS="$AM_CXXFLAGS -Wnon-virtual-dtor -Woverloaded-virtual"
esac
-dnl - check for boost
+dnl - check for boost
dnl -- AX_BOOST(1.32)
@@ -414,13 +417,13 @@ AC_SUBST(CAPI_INTERFACE_AGE)
dnl output stuff ----------------------------------------------------------
AC_OUTPUT([
- Makefile
+ Makefile
capi/Makefile
capi/geos_c.h
doc/Doxyfile
doc/Makefile
macros/Makefile
- src/Makefile
+ src/Makefile
src/algorithm/Makefile
src/algorithm/locate/Makefile
src/algorithm/distance/Makefile
Summary of changes:
configure.ac | 33 ++++++++++++++++++---------------
1 file changed, 18 insertions(+), 15 deletions(-)
hooks/post-receive
More information about the geos-commits
