[geos-commits] [SCM] GEOS branch 3.7 updated. 1c72b2e2372d4b7f2875e6841034c54aee1dc984
git at osgeo.org
git at osgeo.org
Mon Jan 28 09:53:41 PST 2019
the project "GEOS".
The branch, 3.7 has been updated
via 1c72b2e2372d4b7f2875e6841034c54aee1dc984 (commit)
from 0aa1031190752bb666f2be9af0f1c79b5f0693d0 (commit)
revisions in full, below.
commit 1c72b2e2372d4b7f2875e6841034c54aee1dc984
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Mon Jan 28 09:53:23 2019 -0800
fail with cmake -DGEOS_ENABLE_MACOSX_FRAMEWORK=NO
Closes #936
diff --git a/NEWS b/NEWS
index f5f959a..5ab05ec 100644
--- a/NEWS
+++ b/NEWS
@@ -3,6 +3,7 @@ Changes in 3.7.2
- Bug fixes / improvements
- Envelope constructor using strtod (#875 Paul Ramsey)
+ - Failure in CMake for OSX Framework (#936 Paul Ramsey)
diff --git a/capi/CMakeLists.txt b/capi/CMakeLists.txt
index a40fde1..633fff8 100644
--- a/capi/CMakeLists.txt
+++ b/capi/CMakeLists.txt
@@ -40,9 +40,10 @@ if(NOT GEOS_ENABLE_MACOSX_FRAMEWORK AND GEOS_BUILD_SHARED)
CLEAN_DIRECT_OUTPUT 1)
endif()
+ add_dependencies(geos_c geos_revision)
endif()
-add_dependencies(geos_c geos_revision)
# Installation
diff --git a/src/CMakeLists.txt b/src/CMakeLists.txt
index e477ed4..7771be2 100644
--- a/src/CMakeLists.txt
+++ b/src/CMakeLists.txt
@@ -6,7 +6,7 @@
# This is free software; you can redistribute and/or modify it under
# the terms of the GNU Lesser General Public Licence as published
-# by the Free Software Foundation.
+# by the Free Software Foundation.
# See the COPYING file for more information.
@@ -26,16 +26,15 @@ if(GEOS_ENABLE_MACOSX_FRAMEWORK)
add_library(GEOS SHARED ${geos_SOURCES} ${geos_c_SOURCES})
- math(EXPR CVERSION "${VERSION_MAJOR} + 1")
- # VERSION = current version, SOVERSION = compatibility version
+ math(EXPR CVERSION "${VERSION_MAJOR} + 1")
+ # VERSION = current version, SOVERSION = compatibility version
set_target_properties(GEOS
PROPERTIES
FRAMEWORK 1
- VERSION "${CVERSION}.${VERSION_MINOR}.${VERSION_PATCH}"
- SOVERSION ${CVERSION}
+ VERSION "${CVERSION}.${VERSION_MINOR}.${VERSION_PATCH}"
+ SOVERSION ${CVERSION}
FRAMEWORK_VERSION ${VERSION_MAJOR}
- BUILD_WITH_INSTALL_RPATH TRUE
INSTALL_NAME_DIR "${CMAKE_INSTALL_PREFIX}"
MACOSX_FRAMEWORK_INFO_PLIST "${CMAKE_CURRENT_SOURCE_DIR}/Info.plist.in"
MACOSX_FRAMEWORK_BUNDLE_VERSION "GEOS ${VERSION}"
Summary of changes:
NEWS | 1 +
capi/CMakeLists.txt | 3 ++-
src/CMakeLists.txt | 11 +++++------
3 files changed, 8 insertions(+), 7 deletions(-)
hooks/post-receive
More information about the geos-commits
