[geos-commits] [SCM] GEOS branch master updated. cb2d5a03c38fcb928397f68c9078b19cd97cece1
git at osgeo.org
git at osgeo.org
Tue Jan 29 09:04:38 PST 2019
the project "GEOS".
via cb2d5a03c38fcb928397f68c9078b19cd97cece1 (commit)
via a582d479fed26f3c17e0e0e49112cb74e039e62c (commit)
from 525e0b6305f111802b4dbcc2a5b64ee5a238f8d3 (commit)
revisions in full, below.
commit cb2d5a03c38fcb928397f68c9078b19cd97cece1
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Tue Jan 29 09:03:32 2019 -0800
convert remaining NAN/INF macros to std::
diff --git a/src/algorithm/CGAlgorithmsDD.cpp b/src/algorithm/CGAlgorithmsDD.cpp
index 30f1c49..8bcf3e9 100644
--- a/src/algorithm/CGAlgorithmsDD.cpp
+++ b/src/algorithm/CGAlgorithmsDD.cpp
@@ -58,7 +58,7 @@ int CGAlgorithmsDD::orientationIndex(const Coordinate& p1,
const Coordinate& p2,
const Coordinate& q)
- if (ISNAN(q.x) || ISNAN(q.y) || !FINITE(q.x) || !FINITE(q.y)) {
+ if (std::isnan(q.x) || std::isnan(q.y) || !std::isfinite(q.x) || !std::isfinite(q.y)) {
throw util::IllegalArgumentException("CGAlgorithmsDD::orientationIndex encountered NaN/Inf numbers");
@@ -91,8 +91,8 @@ int CGAlgorithmsDD::signOfDet2x2(DD &x1, DD &y1, DD &x2, DD &y2)
int CGAlgorithmsDD::signOfDet2x2(double dx1, double dy1, double dx2, double dy2)
- if (ISNAN(dx1) || ISNAN(dy1) || ISNAN(dx2) || ISNAN(dy2) ||
- !FINITE(dx1) || !FINITE(dy1) || !FINITE(dx2) || !FINITE(dy2)) {
+ if (std::isnan(dx1) || std::isnan(dy1) || std::isnan(dx2) || std::isnan(dy2) ||
+ !std::isfinite(dx1) || !std::isfinite(dy1) || !std::isfinite(dx2) || !std::isfinite(dy2)) {
throw util::IllegalArgumentException("CGAlgorithmsDD::signOfDet2x2 encountered NaN/Inf numbers");
DD x1(dx1);
diff --git a/src/operation/valid/IsValidOp.cpp b/src/operation/valid/IsValidOp.cpp
index dbcf4eb..73f768e 100644
--- a/src/operation/valid/IsValidOp.cpp
+++ b/src/operation/valid/IsValidOp.cpp
@@ -19,6 +19,8 @@
+#include "IndexedNestedRingTester.h"
#include <geos/export.h>
#include <geos/constants.h>
#include <geos/algorithm/CGAlgorithms.h>
@@ -40,7 +42,6 @@
#include <geos/index/chain/MonotoneChainSelectAction.h>
#include <geos/operation/valid/ConnectedInteriorTester.h>
#include <geos/operation/valid/ConsistentAreaTester.h>
-#include <geos/operation/valid/IndexedNestedRingTester.h>
#include <geos/operation/valid/IsValidOp.h>
#include <geos/util/UnsupportedOperationException.h>
@@ -96,15 +97,9 @@ IsValidOp::isValid()
bool
IsValidOp::isValid(const Coordinate &coord)
-<<<<<<< HEAD
- if (! FINITE(coord.x) ) return false;
- if (! FINITE(coord.y) ) return false;
+ if (! std::isfinite(coord.x) ) return false;
+ if (! std::isfinite(coord.y) ) return false;
return true;
- if (! std::isfinite(coord.x) ) return false;
- if (! std::isfinite(coord.y) ) return false;
- return true;
->>>>>>> Using constants.h and stop using platform.h (closes #925)
/* static public */
commit a582d479fed26f3c17e0e0e49112cb74e039e62c
Author: cvvergara <vicky at georepublic.de>
Date: Tue Sep 11 11:14:16 2018 -0500
diff --git a/CMakeLists.txt b/CMakeLists.txt
index 189959a..421862b 100644
--- a/CMakeLists.txt
+++ b/CMakeLists.txt
@@ -208,7 +208,7 @@ endif()
# Setup C/C++ library features
+if (false)
# check header files
include(CheckIncludeFiles)
@@ -228,6 +228,7 @@ else()
check_type_size("long long int" HAVE_LONG_LONG_INT_64)
endif()
endif()
+endif()
# Setup build directories
@@ -251,7 +252,7 @@ include_directories(${PROJECT_SOURCE_DIR}/include)
# for including build-specific GEOS C API headers
include_directories(${PROJECT_BINARY_DIR}/capi)
-# for including build-specific version.h, platform.h and geos_c.h
+# for including build-specific version.h and geos_c.h
include_directories(${PROJECT_BINARY_DIR}/include)
# for geos_ts.cpp which does #include "../geos_revision.h" whereas
@@ -284,26 +285,6 @@ add_custom_target(geos_revision
-D DST=${PROJECT_BINARY_DIR}/geos_revision.h
-P ${PROJECT_BINARY_DIR}/geos_revision.cmake)
-if(EXISTS ${PROJECT_SOURCE_DIR}/include/geos/platform.h)
- message(STATUS "Disabling existing ${PROJECT_SOURCE_DIR}/include/geos/platform.h")
- if(${CMAKE_MAJOR_VERSION} EQUAL 2 AND ${CMAKE_MINOR_VERSION} EQUAL 6)
- file(REMOVE ${PROJECT_SOURCE_DIR}/include/geos/platform.h)
- set(PH_RESULT "removed")
- else()
- file(RENAME
- ${PROJECT_SOURCE_DIR}/include/geos/platform.h
- ${PROJECT_SOURCE_DIR}/include/geos/platform.h.disabled)
- set(PH_RESULT "renamed")
- endif()
- message(STATUS "Disabling existing ${PROJECT_SOURCE_DIR}/include/geos/platform.h - ${PH_RESULT}")
-endif()
-message(STATUS "Generating GEOS ${PROJECT_BINARY_DIR}/include/geos/platform.h")
-configure_file(${PROJECT_SOURCE_DIR}/include/geos/platform.h.cmake
- ${PROJECT_BINARY_DIR}/include/geos/platform.h)
message(STATUS "Generating GEOS ${PROJECT_BINARY_DIR}/include/geos/version.h")
configure_file(${PROJECT_SOURCE_DIR}/include/geos/version.h.in
${PROJECT_BINARY_DIR}/include/geos/version.h @ONLY)
diff --git a/capi/geos_ts_c.cpp b/capi/geos_ts_c.cpp
index a478639..7b69c46 100644
--- a/capi/geos_ts_c.cpp
+++ b/capi/geos_ts_c.cpp
@@ -16,7 +16,6 @@
-#include <geos/platform.h> // for FINITE
#include <geos/geom/Coordinate.h>
#include <geos/geom/Geometry.h>
#include <geos/geom/prep/PreparedGeometry.h>
@@ -3914,7 +3913,7 @@ GEOSHasZ_r(GEOSContextHandle_t extHandle, const Geometry *g)
double az = g->getCoordinate()->z;
//handle->ERROR_MESSAGE("ZCoord: %g", az);
- return static_cast<char>(FINITE(az));
+ return static_cast<char>(std::isfinite(az));
int
diff --git a/configure.ac b/configure.ac
index 6ded2e3..56c26ac 100644
--- a/configure.ac
+++ b/configure.ac
@@ -43,7 +43,7 @@ AC_MSG_RESULT(["$CAPI_VERSION"])
AM_INIT_AUTOMAKE([geos], [$VERSION], [no-define])
AM_MAINTAINER_MODE
-AC_CONFIG_HEADERS([include/config.h] [include/geos/platform.h])
+AC_CONFIG_HEADERS([include/config.h])
AC_PROG_CC
dnl -- JTS_PORT: the version of JTS this release is bound to
diff --git a/doc/example.cpp b/doc/example.cpp
index 32129a0..799ac4a 100644
--- a/doc/example.cpp
+++ b/doc/example.cpp
@@ -48,15 +48,12 @@
#include <geos/util/IllegalArgumentException.h>
#include <geos/opLinemerge.h>
#include <geos/opPolygonize.h>
+#include <geos/constants.h>
#include <vector>
#include <sstream>
#include <iomanip>
#include <cstdlib> // exit()
-#ifndef M_PI
-#define M_PI 3.14159265358979323846
-#endif
// Set to 0 to skip section
#define GEOMETRIC_SHAPES 1
#define RELATIONAL_OPERATORS 1
diff --git a/include/CMakeLists.txt b/include/CMakeLists.txt
index 159ea4c..293e5dc 100644
--- a/include/CMakeLists.txt
+++ b/include/CMakeLists.txt
@@ -6,7 +6,7 @@
# This is free software; you can redistribute and/or modify it under
# the terms of the GNU Lesser General Public Licence as published
-# by the Free Software Foundation.
+# by the Free Software Foundation.
# See the COPYING file for more information.
@@ -28,9 +28,6 @@ endif()
install(FILES geos.h
DESTINATION ${installdest})
-install(FILES ${CMAKE_CURRENT_BINARY_DIR}/geos/platform.h
- DESTINATION ${installdest})
install(FILES ${CMAKE_CURRENT_BINARY_DIR}/geos/version.h
@@ -44,10 +41,10 @@ install(DIRECTORY geos/
# Some post-processing for the framework
# luckily GEOS uses header subdir already, just need to change case
if(APPLE AND GEOS_ENABLE_MACOSX_FRAMEWORK)
- install(CODE
- "execute_process(COMMAND find \"$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/${installdest}\" -name *.* -print0
+ install(CODE
+ "execute_process(COMMAND find \"$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/${installdest}\" -name *.* -print0
COMMAND xargs -0 sed -E -i \"\" \"s,# *include[[:space:]]+<geos/,#include <GEOS/,g\")")
- install(CODE
+ install(CODE
"execute_process(COMMAND ln -sfh Versions/Current/Headers \"$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/GEOS.framework/Headers\")")
endif()
diff --git a/include/geos/Makefile.am b/include/geos/Makefile.am
index 3a01905..f9fe788 100644
--- a/include/geos/Makefile.am
+++ b/include/geos/Makefile.am
@@ -1,5 +1,5 @@
-# This file is part of project GEOS (http://trac.osgeo.org/geos/)
+# This file is part of project GEOS (http://trac.osgeo.org/geos/)
SUBDIRS = \
algorithm \
@@ -16,11 +16,12 @@ SUBDIRS = \
triangulate \
util
-EXTRA_DIST = version.h.vc platform.h.vc platform.h.cmake
+EXTRA_DIST = version.h.vc
geosdir = $(includedir)/geos
geos_HEADERS = \
+ constants.h \
export.h \
geomgraph.h \
geomgraphindex.h \
@@ -54,5 +55,4 @@ geos_HEADERS = \
util.h
nodist_geos_HEADERS = \
- version.h \
- platform.h
+ version.h
diff --git a/include/geos/algorithm/distance/PointPairDistance.h b/include/geos/algorithm/distance/PointPairDistance.h
index e266faa..6c4bc62 100644
--- a/include/geos/algorithm/distance/PointPairDistance.h
+++ b/include/geos/algorithm/distance/PointPairDistance.h
@@ -19,7 +19,7 @@
#ifndef GEOS_ALGORITHM_DISTANCE_POINTPAIRDISTANCE_H
#define GEOS_ALGORITHM_DISTANCE_POINTPAIRDISTANCE_H
-#include <geos/platform.h> // for DoubleNotANumber
+#include <geos/constants.h> // for DoubleNotANumber
#include <geos/geom/Coordinate.h> // for inlines
#include <vector> // for composition
diff --git a/include/geos/platform.h.cmake b/include/geos/constants.h
similarity index 69%
rename from include/geos/platform.h.cmake
rename to include/geos/constants.h
index c6330bf..8a07b28 100644
--- a/include/geos/platform.h.cmake
+++ b/include/geos/constants.h
@@ -1,6 +1,6 @@
- * platform.h - generated by CMake from platform.h.cmake
+ * constants.h
* GEOS - Geometry Engine Open Source
* http://geos.osgeo.org
@@ -17,38 +17,31 @@
-#ifndef GEOS_PLATFORM_H_INCLUDED
-#define GEOS_PLATFORM_H_INCLUDED
+#ifndef INCLUDE_GEOS_CONSTANTS_H_
+#define INCLUDE_GEOS_CONSTANTS_H_
#ifdef _MSC_VER
#ifndef NOMINMAX
#define NOMINMAX 1
+typedef __int64 int64;
#endif
#endif
-/* Disable inclusion of platform.h not generated by CMake */
-#define GEOS_PLATFORM_H 1
-/* Set to 1 if you have ieeefp.h */
-#cmakedefine HAVE_IEEEFP_H 1
-#ifdef _MSC_VER
-# define _USE_MATH_DEFINES
-#endif
#include <cmath>
#include <limits>
#include <cinttypes>
-#ifndef M_PI
+#ifdef M_PI
+#undef M_PI
#endif
typedef int64_t int64;
-#define ISNAN(x) std::isnan(x)
-#define FINITE(x) std::isfinite(x)
+namespace geos {
+constexpr double M_PI = 3.14159265358979323846;
// Some handy constants
constexpr double DoubleNotANumber = std::numeric_limits<double>::quiet_NaN();
@@ -56,6 +49,7 @@ constexpr double DoubleMax = (std::numeric_limits<double>::max)();
constexpr double DoubleInfinity = (std::numeric_limits<double>::infinity)();
constexpr double DoubleNegInfinity = (-(std::numeric_limits<double>::infinity)());
+} // namespace geos
-#endif // GEOS_PLATFORM_H_INCLUDED
+#endif // INCLUDE_GEOS_CONSTANTS_H_
diff --git a/include/geos/geom/Coordinate.h b/include/geos/geom/Coordinate.h
index eb0f9db..945ab7b 100644
--- a/include/geos/geom/Coordinate.h
+++ b/include/geos/geom/Coordinate.h
@@ -16,7 +16,7 @@
#define GEOS_GEOM_COORDINATE_H
#include <geos/inline.h>
#include <set>
#include <stack>
diff --git a/include/geos/geom/Coordinate.inl b/include/geos/geom/Coordinate.inl
index 7920140..46ea94d 100644
--- a/include/geos/geom/Coordinate.inl
+++ b/include/geos/geom/Coordinate.inl
@@ -7,7 +7,7 @@
* This is free software; you can redistribute and/or modify it under
* the terms of the GNU Lesser General Public Licence as published
- * by the Free Software Foundation.
+ * by the Free Software Foundation.
* See the COPYING file for more information.
@@ -16,7 +16,7 @@
#define GEOS_GEOM_COORDINATE_INL
#include <cassert>
#include <cmath>
@@ -35,7 +35,7 @@ Coordinate::setNull()
INLINE bool
Coordinate::isNull() const
- return (ISNAN(x) && ISNAN(y) && ISNAN(z));
+ return (std::isnan(x) && std::isnan(y) && std::isnan(z));
INLINE
@@ -73,8 +73,8 @@ Coordinate::compareTo(const Coordinate& other) const
INLINE bool
Coordinate::equals3D(const Coordinate& other) const
- return (x == other.x) && ( y == other.y) &&
- ((z == other.z)||(ISNAN(z) && ISNAN(other.z)));
+ return (x == other.x) && ( y == other.y) &&
+ ((z == other.z)||(std::isnan(z) && std::isnan(other.z)));
INLINE double
diff --git a/include/geos/geom/CoordinateSequence.h b/include/geos/geom/CoordinateSequence.h
index c6e3e30..30e5491 100644
--- a/include/geos/geom/CoordinateSequence.h
+++ b/include/geos/geom/CoordinateSequence.h
@@ -16,7 +16,6 @@
#define GEOS_GEOM_COORDINATESEQUENCE_H
#include <geos/geom/Coordinate.h> // for applyCoordinateFilter
diff --git a/include/geos/geom/Geometry.h b/include/geos/geom/Geometry.h
index d9cf497..4e01b46 100644
--- a/include/geos/geom/Geometry.h
+++ b/include/geos/geom/Geometry.h
@@ -32,7 +32,6 @@
#endif
#include <geos/geom/Envelope.h>
#include <geos/geom/Dimension.h> // for Dimension::DimensionType
diff --git a/include/geos/geom/GeometryCollection.h b/include/geos/geom/GeometryCollection.h
index 16310a0..b108837 100644
--- a/include/geos/geom/GeometryCollection.h
+++ b/include/geos/geom/GeometryCollection.h
@@ -22,7 +22,6 @@
#include <geos/geom/Geometry.h> // for inheritance
-//#include <geos/platform.h>
#include <geos/geom/Envelope.h> // for proper use of unique_ptr<>
diff --git a/include/geos/geom/GeometryFilter.h b/include/geos/geom/GeometryFilter.h
index 164cdb2..9bbaa5f 100644
--- a/include/geos/geom/GeometryFilter.h
+++ b/include/geos/geom/GeometryFilter.h
@@ -16,7 +16,6 @@
#ifndef GEOS_GEOM_GEOMETRYFILTER_H
#define GEOS_GEOM_GEOMETRYFILTER_H
diff --git a/include/geos/geom/LineString.h b/include/geos/geom/LineString.h
index 00aff7c..25bc13d 100644
--- a/include/geos/geom/LineString.h
+++ b/include/geos/geom/LineString.h
@@ -22,7 +22,6 @@
#define GEOS_GEOS_LINESTRING_H
-#include <geos/platform.h> // do we need this ?
#include <geos/geom/Lineal.h> // for inheritance
#include <geos/geom/CoordinateSequence.h> // for proper use of unique_ptr<>
diff --git a/include/geos/geom/LinearRing.h b/include/geos/geom/LinearRing.h
index 9303f42..71ef6f2 100644
--- a/include/geos/geom/LinearRing.h
+++ b/include/geos/geom/LinearRing.h
@@ -23,7 +23,6 @@
#include <string>
#include <vector>
#include <geos/geom/LineString.h>
diff --git a/include/geos/geom/MultiPoint.h b/include/geos/geom/MultiPoint.h
index 8e35394..bc4fbf0 100644
--- a/include/geos/geom/MultiPoint.h
+++ b/include/geos/geom/MultiPoint.h
@@ -22,7 +22,6 @@
#define GEOS_GEOS_MULTIPOINT_H
#include <geos/geom/GeometryCollection.h> // for inheritance
#include <geos/geom/Puntal.h> // for inheritance
diff --git a/include/geos/geom/MultiPolygon.h b/include/geos/geom/MultiPolygon.h
index b270947..77771ee 100644
--- a/include/geos/geom/MultiPolygon.h
+++ b/include/geos/geom/MultiPolygon.h
@@ -24,7 +24,6 @@
#include <string>
#include <vector>
#include <geos/geom/Polygonal.h> // for inheritance
diff --git a/include/geos/geom/Point.h b/include/geos/geom/Point.h
index 754f1b0..e93990c 100644
--- a/include/geos/geom/Point.h
+++ b/include/geos/geom/Point.h
@@ -22,7 +22,6 @@
#define GEOS_GEOS_POINT_H
diff --git a/include/geos/geom/Polygon.h b/include/geos/geom/Polygon.h
index 8874db2..1c46dc4 100644
--- a/include/geos/geom/Polygon.h
+++ b/include/geos/geom/Polygon.h
@@ -24,7 +24,6 @@
#include <string>
#include <vector>
diff --git a/include/geos/geom/util/ComponentCoordinateExtracter.h b/include/geos/geom/util/ComponentCoordinateExtracter.h
index 5224dfe..dc86bd4 100644
--- a/include/geos/geom/util/ComponentCoordinateExtracter.h
+++ b/include/geos/geom/util/ComponentCoordinateExtracter.h
@@ -23,7 +23,6 @@
#include <geos/geom/Coordinate.h> // to be removed when we have the .inl
#include <geos/geom/LineString.h> // to be removed when we have the .inl
#include <geos/geom/Point.h> // to be removed when we have the .inl
namespace geos {
namespace geom { // geos::geom
diff --git a/include/geos/geom/util/GeometryExtracter.h b/include/geos/geom/util/GeometryExtracter.h
index 1cd33c9..89073c6 100644
--- a/include/geos/geom/util/GeometryExtracter.h
+++ b/include/geos/geom/util/GeometryExtracter.h
@@ -24,7 +24,6 @@
#include <geos/geom/GeometryFilter.h>
#include <vector>
namespace geos {
diff --git a/include/geos/geom/util/LinearComponentExtracter.h b/include/geos/geom/util/LinearComponentExtracter.h
index 66a4e52..1c0756f 100644
--- a/include/geos/geom/util/LinearComponentExtracter.h
+++ b/include/geos/geom/util/LinearComponentExtracter.h
@@ -23,7 +23,6 @@
#include <geos/geom/GeometryComponentFilter.h>
#include <geos/geom/Geometry.h> // to be removed when we have the .inl
namespace geos {
namespace geom { // geos.geom
diff --git a/include/geos/geom/util/PointExtracter.h b/include/geos/geom/util/PointExtracter.h
index 9b7ba08..df4c3d6 100644
--- a/include/geos/geom/util/PointExtracter.h
+++ b/include/geos/geom/util/PointExtracter.h
@@ -19,7 +19,6 @@
#include <vector>
namespace geos {
diff --git a/include/geos/geom/util/PolygonExtracter.h b/include/geos/geom/util/PolygonExtracter.h
index 049a40d..176aa2c 100644
--- a/include/geos/geom/util/PolygonExtracter.h
+++ b/include/geos/geom/util/PolygonExtracter.h
@@ -19,7 +19,6 @@
#include <geos/geom/Polygon.h>
#include <vector>
namespace geos {
diff --git a/include/geos/index/intervalrtree/IntervalRTreeNode.h b/include/geos/index/intervalrtree/IntervalRTreeNode.h
index 3f49615..1dfa07b 100644
--- a/include/geos/index/intervalrtree/IntervalRTreeNode.h
+++ b/include/geos/index/intervalrtree/IntervalRTreeNode.h
@@ -16,7 +16,7 @@
#ifndef GEOS_INDEX_INTERVALRTREE_INTERVALRTREENODE_H
#define GEOS_INDEX_INTERVALRTREE_INTERVALRTREENODE_H
#include <vector>
#include <limits>
diff --git a/include/geos/index/quadtree/DoubleBits.h b/include/geos/index/quadtree/DoubleBits.h
index b46e10f..6972a98 100644
--- a/include/geos/index/quadtree/DoubleBits.h
+++ b/include/geos/index/quadtree/DoubleBits.h
@@ -20,7 +20,7 @@
#define GEOS_IDX_QUADTREE_DOUBLEBITS_H
-#include <geos/platform.h> // for int64
+#include <geos/constants.h> // for int64
#include <string>
diff --git a/include/geos/io/ByteOrderDataInStream.h b/include/geos/io/ByteOrderDataInStream.h
index 9cac179..8596b56 100644
--- a/include/geos/io/ByteOrderDataInStream.h
+++ b/include/geos/io/ByteOrderDataInStream.h
@@ -22,7 +22,6 @@
//#include <geos/io/ParseException.h>
//#include <geos/io/ByteOrderValues.h>
diff --git a/include/geos/io/ByteOrderValues.h b/include/geos/io/ByteOrderValues.h
index 2777b6c..c7394ed 100644
--- a/include/geos/io/ByteOrderValues.h
+++ b/include/geos/io/ByteOrderValues.h
@@ -21,7 +21,7 @@
#define GEOS_IO_BYTEORDERVALUES_H
namespace geos {
namespace io {
diff --git a/include/geos/platform.h.in b/include/geos/platform.h.in
deleted file mode 100644
index e2cfbf2..0000000
--- a/include/geos/platform.h.in
+++ /dev/null
@@ -1,116 +0,0 @@
-/* Set to 1 if you have `int64_t' type */
-#undef HAVE_INT64_T_64
-/* Set to 1 if `long int' is 64 bits */
-#undef HAVE_LONG_INT_64
-/* Set to 1 if `long long int' is 64 bits */
-#undef HAVE_LONG_LONG_INT_64
-#undef HAVE_IEEEFP_H
-/* Has finite */
-#undef HAVE_FINITE
-/* Has isfinite */
-#undef HAVE_ISFINITE
-/* Has isnan */
-#undef HAVE_ISNAN
-#ifdef HAVE_IEEEFP_H
-extern "C"
-#include <ieeefp.h>
-#endif
-#ifdef HAVE_INT64_T_64
-extern "C"
-#include <inttypes.h>
-#endif
-#if defined(__GNUC__) && defined(_WIN32)
-/* For MingW the appropriate definitions are included in
- math.h and float.h but the definitions in
- math.h are only included if __STRICT_ANSI__
- is not defined. Since GEOS is compiled with -ansi that
- means those definitions are not available. */
-#include <float.h>
-#endif
-#include <limits> // for std::numeric_limits
-//Defines NaN for intel platforms
-#define DoubleNotANumber std::numeric_limits<double>::quiet_NaN()
-//Don't forget to define infinities
-#define DoubleInfinity std::numeric_limits<double>::infinity()
-#define DoubleNegInfinity -std::numeric_limits<double>::infinity()
-#define DoubleMax std::numeric_limits<double>::max()
- typedef int64_t int64;
-#else
-# ifdef HAVE_LONG_LONG_INT_64
- typedef long long int int64;
-# else
- typedef long int int64;
-# ifndef HAVE_LONG_INT_64
-# define INT64_IS_REALLY32 1
-# warning "Could not find 64bit integer definition!"
-# endif
-# endif
-#endif
-#if defined(HAVE_FINITE) && !defined(HAVE_ISFINITE)
-# define FINITE(x) (finite(x))
-#else
-# if defined(_MSC_VER)
-# define FINITE(x) _finite(static_cast<double>(x))
-# elif defined(__hpux__) && defined(__ia64__)
-# define FINITE(x) (_Isfinite(x))
-# else
-# define FINITE(x) (std::isfinite(x))
-# endif
-#endif
-#if defined(HAVE_ISNAN)
-# define ISNAN(x) (std::isnan(x))
-#else
-# define ISNAN(x) _isnan(x)
-# elif defined(__MINGW32__) || defined(__CYGWIN__)
-// sandro furieri: sanitizing MinGW32
-# elif defined(__OSX__) || defined(__APPLE__) || \
- defined(__NetBSD__) || defined(__DragonFly__) || defined (__OpenBSD__) || \
- (defined(__sun) && defined(__GNUC__))
- // Hack for OS/X <cmath> incorrectly re-defining isnan() into oblivion.
- // It does leave a version in std.
-# elif (defined(__sun) || defined(__sun__)) && defined(__SUNPRO_CC)
-# include <math.h>
-# define ISNAN(x) (::isnan(x))
-# endif
-#endif
-#ifndef FINITE
-#error "Can not compile without finite or isfinite function or macro"
-#endif
-#ifndef ISNAN
-#error "Can not compile without isnan function or macro"
-#endif
-#endif
diff --git a/include/geos/platform.h.vc b/include/geos/platform.h.vc
deleted file mode 100755
index a4fd567..0000000
--- a/include/geos/platform.h.vc
+++ /dev/null
@@ -1,60 +0,0 @@
- * GEOS - Geometry Engine Open Source
- * http://geos.osgeo.org
- * Copyright (C) 2001-2004 Vivid Solutions Inc.
- * This is free software; you can redistribute and/or modify it under
- * the terms of the GNU Lesser General Public Licence as published
- * See the COPYING file for more information.
- * Manually created platform.h for use with x86 Microsoft Visual C++
-#ifndef _MSC_VER
-#error "This platform.h intended for use with MS Visual C++"
-#endif
-#ifndef WIN32
-#define WIN32
-#endif
-#ifndef NOMINMAX
-#define NOMINMAX
-#endif
-#include <float.h>
-// We need M_PI, but on MSVC you need to define _USE_MATH_DEFINES before
-// including math.h to get it. If we are too late (math.h already included)
-// we will define it manually.
-#define _USE_MATH_DEFINES
-#include <math.h>
-#ifndef M_PI
-#endif
-#define ISNAN(x) _isnan(x)
-#define DoubleMax (std::numeric_limits<double>::max)()
-#define FINITE(x) _finite(static_cast<double>(x))
-#define finite(x) _finite(static_cast<double>(x))
-typedef __int64 int64;
-#endif
diff --git a/include/geos/precision/CommonBits.h b/include/geos/precision/CommonBits.h
index 66c12a7..10637bd 100644
--- a/include/geos/precision/CommonBits.h
+++ b/include/geos/precision/CommonBits.h
@@ -16,7 +16,7 @@
#define GEOS_PRECISION_COMMONBITS_H
namespace geos {
namespace precision { // geos.precision
diff --git a/include/geos/precision/EnhancedPrecisionOp.h b/include/geos/precision/EnhancedPrecisionOp.h
index 0bbeb0e..50f691e 100644
--- a/include/geos/precision/EnhancedPrecisionOp.h
+++ b/include/geos/precision/EnhancedPrecisionOp.h
@@ -20,7 +20,7 @@
#define GEOS_PRECISION_ENHANCEDPRECISIONOP_H
// Forward declarations
namespace geos {
diff --git a/src/Makefile.vc b/src/Makefile.vc
index 28beef0..0000000
--- a/src/Makefile.vc
+++ /dev/null
@@ -1,394 +0,0 @@
-# Building on Win32 with Visual C++ 7.0, 7.1, 8.0 or 9.0
-# Produces:
-# geos.lib: static library for use of C or C++ API.
-# geos.dll: DLL - only exports the C API
-# geos_i.lib: stub library to link against for use of geos.dll.
-# geos_d.lib: debug static library for use of C or C++ API.
-# geos_d.dll: debug DLL - only exports the C API
-# geos_i_d.lib: debug stub library to link against for use of geos.dll.
-# This makefile mostly maintained by Frank Warmerdam <warmerdam at pobox.com>
-# with support by Mateusz Loskot <mateusz at loskot.net>
-GEOS_ROOT=..
-!INCLUDE $(GEOS_ROOT)\nmake.opt
-!INCLUDE dirlist.mk
-# Output location
-# TODO: not yet supported
-#OUT_DIR = $(GEOS_ROOT)\bin\$(BUILD_DIR)
-# List of objects
-OBJ_EXT = obj
-EXT = $(OBJ_EXT)
-OBJ = \
- algorithm\Angle.$(EXT) \
- algorithm\BoundaryNodeRule.$(EXT) \
- algorithm\Centroid.$(EXT) \
- algorithm\CGAlgorithms.$(EXT) \
- algorithm\ConvexHull.$(EXT) \
- algorithm\HCoordinate.$(EXT) \
- algorithm\InteriorPointArea.$(EXT) \
- algorithm\InteriorPointLine.$(EXT) \
- algorithm\InteriorPointPoint.$(EXT) \
- algorithm\LineIntersector.$(EXT) \
- algorithm\MinimumDiameter.$(EXT) \
- algorithm\NotRepresentableException.$(EXT) \
- algorithm\PointLocator.$(EXT) \
- algorithm\RayCrossingCounter.$(EXT) \
- algorithm\RobustDeterminant.$(EXT) \
- algorithm\distance\DiscreteHausdorffDistance.$(EXT) \
- algorithm\distance\DiscreteFrechetDistance.$(EXT) \
- algorithm\distance\DistanceToPoint.$(EXT) \
- algorithm\locate\IndexedPointInAreaLocator.$(EXT) \
- algorithm\locate\PointOnGeometryLocator.$(EXT) \
- algorithm\locate\SimplePointInAreaLocator.$(EXT) \
- geom\Coordinate.$(EXT) \
- geom\CoordinateArraySequence.$(EXT) \
- geom\CoordinateArraySequenceFactory.$(EXT) \
- geom\CoordinateSequence.$(EXT) \
- geom\CoordinateSequenceFactory.$(EXT) \
- geom\Dimension.$(EXT) \
- geom\Envelope.$(EXT) \
- geom\Geometry.$(EXT) \
- geom\GeometryCollection.$(EXT) \
- geom\GeometryComponentFilter.$(EXT) \
- geom\GeometryFactory.$(EXT) \
- geom\IntersectionMatrix.$(EXT) \
- geom\LinearRing.$(EXT) \
- geom\LineSegment.$(EXT) \
- geom\LineString.$(EXT) \
- geom\Location.$(EXT) \
- geom\MultiLineString.$(EXT) \
- geom\MultiPoint.$(EXT) \
- geom\MultiPolygon.$(EXT) \
- geom\Point.$(EXT) \
- geom\Polygon.$(EXT) \
- geom\PrecisionModel.$(EXT) \
- geom\Triangle.$(EXT) \
- geom\util\ComponentCoordinateExtracter.$(EXT) \
- geom\util\CoordinateOperation.$(EXT) \
- geom\util\GeometryEditor.$(EXT) \
- geom\util\GeometryTransformer.$(EXT) \
- geom\util\GeometryCombiner.$(EXT) \
- geom\util\ShortCircuitedGeometryVisitor.$(EXT) \
- geom\util\SineStarFactory.$(EXT) \
- geom\util\LinearComponentExtracter.$(EXT) \
- geom\util\PolygonExtracter.$(EXT) \
- geom\util\PointExtracter.$(EXT) \
- geom\prep\AbstractPreparedPolygonContains.$(EXT) \
- geom\prep\BasicPreparedGeometry.$(EXT) \
- geom\prep\PreparedGeometry.$(EXT) \
- geom\prep\PreparedGeometryFactory.$(EXT) \
- geom\prep\PreparedLineString.$(EXT) \
- geom\prep\PreparedLineStringIntersects.$(EXT) \
- geom\prep\PreparedPoint.$(EXT) \
- geom\prep\PreparedPolygon.$(EXT) \
- geom\prep\PreparedPolygonContains.$(EXT) \
- geom\prep\PreparedPolygonContainsProperly.$(EXT) \
- geom\prep\PreparedPolygonCovers.$(EXT) \
- geom\prep\PreparedPolygonIntersects.$(EXT) \
- geom\prep\PreparedPolygonPredicate.$(EXT) \
- geomgraph\Depth.$(EXT) \
- geomgraph\DirectedEdge.$(EXT) \
- geomgraph\DirectedEdgeStar.$(EXT) \
- geomgraph\Edge.$(EXT) \
- geomgraph\EdgeEnd.$(EXT) \
- geomgraph\EdgeEndStar.$(EXT) \
- geomgraph\EdgeIntersectionList.$(EXT) \
- geomgraph\EdgeList.$(EXT) \
- geomgraph\EdgeNodingValidator.$(EXT) \
- geomgraph\EdgeRing.$(EXT) \
- geomgraph\GeometryGraph.$(EXT) \
- geomgraph\GraphComponent.$(EXT) \
- geomgraph\Label.$(EXT) \
- geomgraph\Node.$(EXT) \
- geomgraph\NodeFactory.$(EXT) \
- geomgraph\NodeMap.$(EXT) \
- geomgraph\PlanarGraph.$(EXT) \
- geomgraph\Position.$(EXT) \
- geomgraph\Quadrant.$(EXT) \
- geomgraph\TopologyLocation.$(EXT) \
- geomgraph\index\MonotoneChainEdge.$(EXT) \
- geomgraph\index\MonotoneChainIndexer.$(EXT) \
- geomgraph\index\SegmentIntersector.$(EXT) \
- geomgraph\index\SimpleEdgeSetIntersector.$(EXT) \
- geomgraph\index\SimpleMCSweepLineIntersector.$(EXT) \
- geomgraph\index\SimpleSweepLineIntersector.$(EXT) \
- geomgraph\index\SweepLineEvent.$(EXT) \
- geomgraph\index\SweepLineSegment.$(EXT) \
- index\bintree\Bintree.$(EXT) \
- index\bintree\Interval.$(EXT) \
- index\bintree\Key.$(EXT) \
- index\bintree\Node.$(EXT) \
- index\bintree\NodeBase.$(EXT) \
- index\bintree\Root.$(EXT) \
- index\chain\MonotoneChain.$(EXT) \
- index\chain\MonotoneChainBuilder.$(EXT) \
- index\chain\MonotoneChainOverlapAction.$(EXT) \
- index\chain\MonotoneChainSelectAction.$(EXT) \
- index\intervalrtree\IntervalRTreeBranchNode.$(EXT) \
- index\intervalrtree\IntervalRTreeLeafNode.$(EXT) \
- index\intervalrtree\SortedPackedIntervalRTree.$(EXT) \
- index\quadtree\DoubleBits.$(EXT) \
- index\quadtree\IntervalSize.$(EXT) \
- index\quadtree\Key.$(EXT) \
- index\quadtree\Node.$(EXT) \
- index\quadtree\NodeBase.$(EXT) \
- index\quadtree\Root.$(EXT) \
- index\quadtree\Quadtree.$(EXT) \
- index\strtree\AbstractNode.$(EXT) \
- index\strtree\AbstractSTRtree.$(EXT) \
- index\strtree\BoundablePair.$(EXT) \
- index\strtree\GeometryItemDistance.$(EXT) \
- index\strtree\Interval.$(EXT) \
- index\strtree\ItemBoundable.$(EXT) \
- index\strtree\SIRtree.$(EXT) \
- index\strtree\STRtree.$(EXT) \
- index\sweepline\SweepLineEvent.$(EXT) \
- index\sweepline\SweepLineIndex.$(EXT) \
- index\sweepline\SweepLineInterval.$(EXT) \
- io\ByteOrderDataInStream.$(EXT) \
- io\ByteOrderValues.$(EXT) \
- io\CLocalizer.$(EXT) \
- io\ParseException.$(EXT) \
- io\StringTokenizer.$(EXT) \
- io\Unload.$(EXT) \
- io\WKBReader.$(EXT) \
- io\WKBWriter.$(EXT) \
- io\WKTReader.$(EXT) \
- io\WKTWriter.$(EXT) \
- io\Writer.$(EXT) \
- noding\BasicSegmentString.$(EXT) \
- noding\FastNodingValidator.$(EXT) \
- noding\FastSegmentSetIntersectionFinder.$(EXT) \
- noding\GeometryNoder.$(EXT) \
- noding\IntersectionAdder.$(EXT) \
- noding\IntersectionFinderAdder.$(EXT) \
- noding\IteratedNoder.$(EXT) \
- noding\MCIndexNoder.$(EXT) \
- noding\MCIndexSegmentSetMutualIntersector.$(EXT) \
- noding\NodedSegmentString.$(EXT) \
- noding\NodingValidator.$(EXT) \
- noding\Octant.$(EXT) \
- noding\OrientedCoordinateArray.$(EXT) \
- noding\ScaledNoder.$(EXT) \
- noding\SegmentIntersectionDetector.$(EXT) \
- noding\SegmentNode.$(EXT) \
- noding\SegmentNodeList.$(EXT) \
- noding\SegmentString.$(EXT) \
- noding\SegmentStringUtil.$(EXT) \
- noding\SimpleNoder.$(EXT) \
- noding\NodingIntersectionFinder.$(EXT) \
- noding\snapround\HotPixel.$(EXT) \
- noding\snapround\MCIndexPointSnapper.$(EXT) \
- noding\snapround\MCIndexSnapRounder.$(EXT) \
- noding\snapround\SimpleSnapRounder.$(EXT) \
- operation\GeometryGraphOperation.$(EXT) \
- operation\IsSimpleOp.$(EXT) \
- operation\buffer\BufferBuilder.$(EXT) \
- operation\buffer\BufferInputLineSimplifier.$(EXT) \
- operation\buffer\BufferParameters.$(EXT) \
- operation\buffer\BufferOp.$(EXT) \
- operation\buffer\BufferSubgraph.$(EXT) \
- operation\buffer\OffsetCurveBuilder.$(EXT) \
- operation\buffer\OffsetCurveSetBuilder.$(EXT) \
- operation\buffer\OffsetSegmentGenerator.$(EXT) \
- operation\buffer\RightmostEdgeFinder.$(EXT) \
- operation\buffer\SubgraphDepthLocater.$(EXT) \
- operation\distance\ConnectedElementLocationFilter.$(EXT) \
- operation\distance\ConnectedElementPointFilter.$(EXT) \
- operation\distance\DistanceOp.$(EXT) \
- operation\distance\FacetSequence.$(EXT) \
- operation\distance\FacetSequenceTreeBuilder.$(EXT) \
- operation\distance\GeometryLocation.$(EXT) \
- operation\distance\IndexedFacetDistance.$(EXT) \
- operation\intersection\Rectangle.$(EXT) \
- operation\intersection\RectangleIntersection.$(EXT) \
- operation\intersection\RectangleIntersectionBuilder.$(EXT) \
- operation\linemerge\EdgeString.$(EXT) \
- operation\linemerge\LineMergeDirectedEdge.$(EXT) \
- operation\linemerge\LineMergeEdge.$(EXT) \
- operation\linemerge\LineMergeGraph.$(EXT) \
- operation\linemerge\LineMerger.$(EXT) \
- operation\linemerge\LineSequencer.$(EXT) \
- operation\overlay\EdgeSetNoder.$(EXT) \
- operation\overlay\ElevationMatrix.$(EXT) \
- operation\overlay\ElevationMatrixCell.$(EXT) \
- operation\overlay\LineBuilder.$(EXT) \
- operation\overlay\MaximalEdgeRing.$(EXT) \
- operation\overlay\MinimalEdgeRing.$(EXT) \
- operation\overlay\OverlayNodeFactory.$(EXT) \
- operation\overlay\OverlayOp.$(EXT) \
- operation\overlay\PointBuilder.$(EXT) \
- operation\overlay\PolygonBuilder.$(EXT) \
- operation\overlay\snap\GeometrySnapper.$(EXT) \
- operation\overlay\snap\LineStringSnapper.$(EXT) \
- operation\overlay\snap\SnapOverlayOp.$(EXT) \
- operation\overlay\snap\SnapIfNeededOverlayOp.$(EXT) \
- operation\overlay\validate\FuzzyPointLocator.$(EXT) \
- operation\overlay\validate\OffsetPointGenerator.$(EXT) \
- operation\overlay\validate\OverlayResultValidator.$(EXT) \
- operation\polygonize\PolygonizeDirectedEdge.$(EXT) \
- operation\polygonize\PolygonizeEdge.$(EXT) \
- operation\polygonize\EdgeRing.$(EXT) \
- operation\polygonize\PolygonizeGraph.$(EXT) \
- operation\polygonize\Polygonizer.$(EXT) \
- operation\predicate\RectangleContains.$(EXT) \
- operation\predicate\RectangleIntersects.$(EXT) \
- operation\predicate\SegmentIntersectionTester.$(EXT) \
- operation\relate\EdgeEndBuilder.$(EXT) \
- operation\relate\EdgeEndBundle.$(EXT) \
- operation\relate\EdgeEndBundleStar.$(EXT) \
- operation\relate\RelateComputer.$(EXT) \
- operation\relate\RelateNode.$(EXT) \
- operation\relate\RelateNodeFactory.$(EXT) \
- operation\relate\RelateNodeGraph.$(EXT) \
- operation\relate\RelateOp.$(EXT) \
- operation\sharedpaths\SharedPathsOp.$(EXT) \
- operation\union\CascadedPolygonUnion.$(EXT) \
- operation\union\CascadedUnion.$(EXT) \
- operation\union\PointGeometryUnion.$(EXT) \
- operation\union\UnaryUnionOp.$(EXT) \
- operation\valid\ConnectedInteriorTester.$(EXT) \
- operation\valid\ConsistentAreaTester.$(EXT) \
- operation\valid\IndexedNestedRingTester.$(EXT) \
- operation\valid\IsValidOp.$(EXT) \
- operation\valid\QuadtreeNestedRingTester.$(EXT) \
- operation\valid\RepeatedPointTester.$(EXT) \
- operation\valid\SimpleNestedRingTester.$(EXT) \
- operation\valid\SweeplineNestedRingTester.$(EXT) \
- operation\valid\TopologyValidationError.$(EXT) \
- planargraph\DirectedEdge.$(EXT) \
- planargraph\DirectedEdgeStar.$(EXT) \
- planargraph\Edge.$(EXT) \
- planargraph\Node.$(EXT) \
- planargraph\NodeMap.$(EXT) \
- planargraph\PlanarGraph.$(EXT) \
- planargraph\Subgraph.$(EXT) \
- planargraph\algorithm\ConnectedSubgraphFinder.$(EXT) \
- precision\CommonBits.$(EXT) \
- precision\CommonBitsOp.$(EXT) \
- precision\CommonBitsRemover.$(EXT) \
- precision\EnhancedPrecisionOp.$(EXT) \
- precision\GeometryPrecisionReducer.$(EXT) \
- precision\MinimumClearance.$(EXT) \
- precision\PrecisionReducerCoordinateOperation.$(EXT) \
- precision\SimpleGeometryPrecisionReducer.$(EXT) \
- simplify\DouglasPeuckerLineSimplifier.$(EXT) \
- simplify\DouglasPeuckerSimplifier.$(EXT) \
- simplify\LineSegmentIndex.$(EXT) \
- simplify\TaggedLineSegment.$(EXT) \
- simplify\TaggedLinesSimplifier.$(EXT) \
- simplify\TaggedLineString.$(EXT) \
- simplify\TaggedLineStringSimplifier.$(EXT) \
- simplify\TopologyPreservingSimplifier.$(EXT) \
- triangulate\DelaunayTriangulationBuilder.$(EXT) \
- triangulate\IncrementalDelaunayTriangulator.$(EXT) \
- triangulate\VoronoiDiagramBuilder.$(EXT) \
- triangulate\quadedge\LastFoundQuadEdgeLocator.$(EXT) \
- triangulate\quadedge\LocateFailureException.$(EXT) \
- triangulate\quadedge\QuadEdge.$(EXT) \
- triangulate\quadedge\QuadEdgeLocator.$(EXT) \
- triangulate\quadedge\QuadEdgeSubdivision.$(EXT) \
- triangulate\quadedge\TrianglePredicate.$(EXT) \
- triangulate\quadedge\TriangleVisitor.$(EXT) \
- triangulate\quadedge\Vertex.$(EXT) \
- util\Assert.$(EXT) \
- util\GeometricShapeFactory.$(EXT) \
- util\Interrupt.$(EXT) \
- util\math.$(EXT) \
- util\Profiler.$(EXT) \
- linearref\ExtractLineByLocation.$(EXT) \
- linearref\LengthIndexOfPoint.$(EXT) \
- linearref\LengthIndexedLine.$(EXT) \
- linearref\LengthLocationMap.$(EXT) \
- linearref\LinearGeometryBuilder.$(EXT) \
- linearref\LinearIterator.$(EXT) \
- linearref\LinearLocation.$(EXT) \
- linearref\LocationIndexOfLine.$(EXT) \
- linearref\LocationIndexOfPoint.$(EXT) \
- ..\capi\geos_c.$(EXT) \
- ..\capi\geos_ts_c.$(EXT) \
- inlines.$(EXT)
-TEST_EXE = TestSweepLineSpeed.exe
-# Build targets
-default: $(LIBNAME) $(DLLNAME) $(CDLLNAME)
-all: $(LIBNAME) $(DLLNAME) $(CDLLNAME) TestSweepLineSpeed.exe geostest.exe
-check: all
- TestSweepLineSpeed.exe
-$(LIBNAME): $(GEOS_ROOT)\include\geos\platform.h $(GEOS_ROOT)\include\geos\version.h ..\capi\geos_c.h $(OBJ)
- if exist $(LIBNAME) del $(LIBNAME)
- $(LINK) /lib /out:$(LIBNAME) $(OBJ)
-$(DLLNAME): $(OBJ)
- $(LINK) /dll /debug $(LINKER_FLAGS) $(OBJ) /out:$(DLLNAME) /implib:$(SLIBNAME)
- if exist $(DLLNAME).manifest mt -manifest $(DLLNAME).manifest -outputresource:$(DLLNAME);2
-$(CDLLNAME): ..\capi\geos_c.obj ..\capi\geos_ts_c.obj $(DLLNAME)
- $(LINK) /dll /debug $(LINKER_FLAGS) ..\capi\geos_c.obj ..\capi\geos_ts_c.obj $(LIBNAME) /out:$(CDLLNAME) /implib:$(CLIBNAME)
- if exist $(CDLLNAME).manifest mt -manifest $(CDLLNAME).manifest -outputresource:$(CDLLNAME);2
-$(GEOS_ROOT)\include\geos\platform.h: $(GEOS_ROOT)\include\geos\platform.h.vc
- $(CP) $(GEOS_ROOT)\include\geos\platform.h.vc $(GEOS_ROOT)\include\geos\platform.h
-$(GEOS_ROOT)\include\geos\version.h: $(GEOS_ROOT)\include\geos\version.h.vc
- if not exist $(GEOS_ROOT)\include\geos\version.h $(CP) $(GEOS_ROOT)\include\geos\version.h.vc $(GEOS_ROOT)\include\geos\version.h
-# geos_c.h should already be in distribution, if is not you'll
-# have to run ./configure to recreate
-../capi/geos_c.h: ../capi/geos_c.h.in.
- $(CP) ..\capi\geos_c.h.in ..\capi\geos_c.h
-.cpp.obj:
- $(CC) $(CFLAGS) /c $*.cpp /Fo$@
-{..\capi}.cpp.obj:
- $(CC) $(CFLAGS) /D "GEOS_DLL_EXPORT" /c $*.cpp /Fo$@
-.c.obj:
- $(CC) $(CFLAGS) /c $*.c /Fo$@
-clean:
- @ECHO "*** Cleaning GEOS source tree"
- @IF EXIST $(LIBNAME) $(RM) $(LIBNAME)
- @IF EXIST $(SLIBNAME) $(RM) $(SLIBNAME)
- @IF EXIST $(DLLNAME) $(RM) $(DLLNAME)
- @IF EXIST $(CLIBNAME) $(RM) $(CLIBNAME)
- @IF EXIST $(CDLLNAME) $(RM) $(CDLLNAME)
- - at del /s *.exe
- - at del /s *.exp
- - at del /s *.ilk
- - at del /s *.manifest
- - at del /s *.obj
- - at del /s *.pdb
-TestSweepLineSpeed.exe: $(LIBNAME) \
- ..\tests\bigtest\GeometryTestFactory.obj \
- ..\tests\bigtest\TestSweepLineSpeed.obj
- $(LINK) /debug /out:TestSweepLineSpeed.exe \
- ..\tests\bigtest\TestSweepLineSpeed.obj \
- $(LIBNAME)
-geostest.exe: $(CDLLNAME) ..\tests\unit\capi\geostest.obj
- $(LINK) /debug ..\tests\unit\capi\geostest.obj $(CLIBNAME)
-# EOF
diff --git a/src/algorithm/HCoordinate.cpp b/src/algorithm/HCoordinate.cpp
index a760cbf..6fc8e82 100644
--- a/src/algorithm/HCoordinate.cpp
+++ b/src/algorithm/HCoordinate.cpp
@@ -21,7 +21,6 @@
#include <geos/algorithm/HCoordinate.h>
#include <geos/algorithm/NotRepresentableException.h>
#include <memory>
#include <cmath>
@@ -71,7 +70,7 @@ HCoordinate::intersection(const Coordinate &p1, const Coordinate &p2,
double xInt = x/w;
double yInt = y/w;
- if ( (!FINITE(xInt)) || (!FINITE(yInt)) )
+ if ( (!std::isfinite(xInt)) || (!std::isfinite(yInt)) )
throw NotRepresentableException();
@@ -148,7 +147,7 @@ double
HCoordinate::getX() const
double a = x/w;
- if ( !FINITE(a) ) {
+ if ( !std::isfinite(a) ) {
return a;
@@ -159,7 +158,7 @@ double
HCoordinate::getY() const
double a = y/w;
return a;
diff --git a/src/algorithm/InteriorPointLine.cpp b/src/algorithm/InteriorPointLine.cpp
index f7af379..c199503 100644
--- a/src/algorithm/InteriorPointLine.cpp
+++ b/src/algorithm/InteriorPointLine.cpp
@@ -17,6 +17,7 @@
#include <geos/algorithm/InteriorPointLine.h>
diff --git a/src/algorithm/InteriorPointPoint.cpp b/src/algorithm/InteriorPointPoint.cpp
index 7e88315..22c8c25 100644
--- a/src/algorithm/InteriorPointPoint.cpp
+++ b/src/algorithm/InteriorPointPoint.cpp
@@ -13,7 +13,7 @@
#include <geos/algorithm/InteriorPointPoint.h>
diff --git a/src/algorithm/LineIntersector.cpp b/src/algorithm/LineIntersector.cpp
index 89b7219..f3b6cfb 100644
--- a/src/algorithm/LineIntersector.cpp
+++ b/src/algorithm/LineIntersector.cpp
@@ -17,7 +17,7 @@
#include <geos/algorithm/LineIntersector.h>
#include <geos/algorithm/Distance.h>
#include <geos/algorithm/Orientation.h>
@@ -267,7 +267,7 @@ LineIntersector::interpolateZ(const Coordinate &p,
cerr<<"LineIntersector::interpolateZ("<<p.toString()<<", "<<p1.toString()<<", "<<p2.toString()<<")"<<endl;
#endif
- if ( ISNAN(p1.z) )
+ if ( std::isnan(p1.z) )
#if GEOS_DEBUG
cerr<<" p1 do not have a Z"<<endl;
@@ -275,7 +275,7 @@ LineIntersector::interpolateZ(const Coordinate &p,
return p2.z; // might be DoubleNotANumber again
- if ( ISNAN(p2.z) )
+ if ( std::isnan(p2.z) )
#if GEOS_DEBUG
cerr<<" p2 do not have a Z"<<endl;
@@ -347,9 +347,9 @@ LineIntersector::computeIntersection(const Coordinate& p,const Coordinate& p1,co
cerr<<"RobustIntersector::computeIntersection(Coordinate,Coordinate,Coordinate) calling interpolateZ"<<endl;
#endif
double z = interpolateZ(p, p1, p2);
- if ( !ISNAN(z) )
+ if ( !std::isnan(z) )
- if ( ISNAN(intPt[0].z) )
+ if ( std::isnan(intPt[0].z) )
intPt[0].z = z;
else
intPt[0].z = (intPt[0].z+z)/2;
@@ -469,7 +469,7 @@ LineIntersector::computeIntersect(const Coordinate& p1,const Coordinate& p2,cons
if ( p1.equals2D(q1) || p1.equals2D(q2) ) {
intPt[0]=p1;
#if COMPUTE_Z
- if ( !ISNAN(p1.z) )
+ if ( !std::isnan(p1.z) )
z += p1.z;
hits++;
@@ -479,7 +479,7 @@ LineIntersector::computeIntersect(const Coordinate& p1,const Coordinate& p2,cons
else if ( p2.equals2D(q1) || p2.equals2D(q2) ) {
intPt[0]=p2;
#if COMPUTE_Z
- if ( !ISNAN(p2.z) )
+ if ( !std::isnan(p2.z) )
z += p2.z;
hits++;
@@ -493,7 +493,7 @@ LineIntersector::computeIntersect(const Coordinate& p1,const Coordinate& p2,cons
else if (Pq1==0) {
intPt[0]=q1;
#if COMPUTE_Z
- if ( !ISNAN(q1.z) )
+ if ( !std::isnan(q1.z) )
z += q1.z;
hits++;
@@ -503,7 +503,7 @@ LineIntersector::computeIntersect(const Coordinate& p1,const Coordinate& p2,cons
else if (Pq2==0) {
intPt[0]=q2;
#if COMPUTE_Z
- if ( !ISNAN(q2.z) )
+ if ( !std::isnan(q2.z) )
z += q2.z;
hits++;
@@ -513,7 +513,7 @@ LineIntersector::computeIntersect(const Coordinate& p1,const Coordinate& p2,cons
else if (Qp1==0) {
intPt[0]=p1;
#if COMPUTE_Z
z += p1.z;
hits++;
@@ -523,7 +523,7 @@ LineIntersector::computeIntersect(const Coordinate& p1,const Coordinate& p2,cons
else if (Qp2==0) {
intPt[0]=p2;
#if COMPUTE_Z
z += p2.z;
hits++;
@@ -578,8 +578,8 @@ LineIntersector::computeCollinearIntersection(const Coordinate& p1,const Coordin
ztot=0;
hits=0;
q1z = interpolateZ(q1, p1, p2);
- if (!ISNAN(q1z)) { ztot+=q1z; hits++; }
- if (!ISNAN(q1.z)) { ztot+=q1.z; hits++; }
+ if (!std::isnan(q1z)) { ztot+=q1z; hits++; }
+ if (!std::isnan(q1.z)) { ztot+=q1.z; hits++; }
if ( hits ) intPt[0].z = ztot/hits;
#endif
intPt[1]=q2;
@@ -587,8 +587,8 @@ LineIntersector::computeCollinearIntersection(const Coordinate& p1,const Coordin
ztot=0;
hits=0;
q2z = interpolateZ(q2, p1, p2);
- if (!ISNAN(q2z)) { ztot+=q2z; hits++; }
- if (!ISNAN(q2.z)) { ztot+=q2.z; hits++; }
+ if (!std::isnan(q2z)) { ztot+=q2z; hits++; }
+ if (!std::isnan(q2.z)) { ztot+=q2.z; hits++; }
if ( hits ) intPt[1].z = ztot/hits;
#endif
#if GEOS_DEBUG
@@ -606,8 +606,8 @@ LineIntersector::computeCollinearIntersection(const Coordinate& p1,const Coordin
ztot=0;
hits=0;
p1z = interpolateZ(p1, q1, q2);
- if (!ISNAN(p1z)) { ztot+=p1z; hits++; }
- if (!ISNAN(p1.z)) { ztot+=p1.z; hits++; }
+ if (!std::isnan(p1z)) { ztot+=p1z; hits++; }
+ if (!std::isnan(p1.z)) { ztot+=p1.z; hits++; }
#endif
intPt[1]=p2;
@@ -615,8 +615,8 @@ LineIntersector::computeCollinearIntersection(const Coordinate& p1,const Coordin
ztot=0;
hits=0;
p2z = interpolateZ(p2, q1, q2);
- if (!ISNAN(p2z)) { ztot+=p2z; hits++; }
- if (!ISNAN(p2.z)) { ztot+=p2.z; hits++; }
+ if (!std::isnan(p2z)) { ztot+=p2z; hits++; }
+ if (!std::isnan(p2.z)) { ztot+=p2.z; hits++; }
#endif
return COLLINEAR_INTERSECTION;
@@ -630,8 +630,8 @@ LineIntersector::computeCollinearIntersection(const Coordinate& p1,const Coordin
ztot=0;
hits=0;
#endif
intPt[1]=p1;
@@ -639,8 +639,8 @@ LineIntersector::computeCollinearIntersection(const Coordinate& p1,const Coordin
ztot=0;
hits=0;
#endif
#if GEOS_DEBUG
@@ -658,8 +658,8 @@ LineIntersector::computeCollinearIntersection(const Coordinate& p1,const Coordin
ztot=0;
hits=0;
#endif
intPt[1]=p2;
@@ -667,8 +667,8 @@ LineIntersector::computeCollinearIntersection(const Coordinate& p1,const Coordin
ztot=0;
hits=0;
#endif
#if GEOS_DEBUG
@@ -686,8 +686,8 @@ LineIntersector::computeCollinearIntersection(const Coordinate& p1,const Coordin
ztot=0;
hits=0;
#endif
intPt[1]=p1;
@@ -695,8 +695,8 @@ LineIntersector::computeCollinearIntersection(const Coordinate& p1,const Coordin
ztot=0;
hits=0;
#endif
#if GEOS_DEBUG
@@ -714,8 +714,8 @@ LineIntersector::computeCollinearIntersection(const Coordinate& p1,const Coordin
ztot=0;
hits=0;
#endif
intPt[1]=p2;
@@ -723,8 +723,8 @@ LineIntersector::computeCollinearIntersection(const Coordinate& p1,const Coordin
ztot=0;
hits=0;
#endif
#if GEOS_DEBUG
@@ -780,8 +780,8 @@ LineIntersector::intersection(const Coordinate& p1,
double zvals = 0;
double zp = interpolateZ(intPtOut, p1, p2);
double zq = interpolateZ(intPtOut, q1, q2);
- if ( !ISNAN(zp)) { ztot += zp; zvals++; }
- if ( !ISNAN(zq)) { ztot += zq; zvals++; }
+ if ( !std::isnan(zp)) { ztot += zp; zvals++; }
+ if ( !std::isnan(zq)) { ztot += zq; zvals++; }
if ( zvals ) intPtOut.z = ztot/zvals;
#endif // COMPUTE_Z
@@ -871,7 +871,7 @@ LineIntersector::normalizeToEnvCentre(Coordinate &n00, Coordinate &n01,
// Only do this if input does have Z
// See https://trac.osgeo.org/geos/ticket/811
- if( ISNAN(n00.z) ) return;
+ if( std::isnan(n00.z) ) return;
double minZ0 = n00.z < n01.z ? n00.z : n01.z;
double minZ1 = n10.z < n11.z ? n10.z : n11.z;
diff --git a/src/algorithm/MinimumDiameter.cpp b/src/algorithm/MinimumDiameter.cpp
index 6b1b6d2..1c51f1e 100644
--- a/src/algorithm/MinimumDiameter.cpp
+++ b/src/algorithm/MinimumDiameter.cpp
@@ -22,6 +22,7 @@
#include <geos/algorithm/MinimumDiameter.h>
#include <geos/algorithm/ConvexHull.h>
diff --git a/src/algorithm/RobustDeterminant.cpp b/src/algorithm/RobustDeterminant.cpp
index 84d7966..80cef7d 100644
--- a/src/algorithm/RobustDeterminant.cpp
+++ b/src/algorithm/RobustDeterminant.cpp
@@ -38,7 +38,6 @@
#include <cmath>
-#include <geos/platform.h> // for ISNAN, FINITE
#ifdef _MSC_VER
#pragma warning(disable : 4127)
@@ -59,7 +58,7 @@ int RobustDeterminant::signOfDet2x2(double x1,double y1,double x2,double y2) {
double k;
// Protect against non-finite numbers
- if ( !FINITE(x1) || !FINITE(y1) || !FINITE(x2) || !FINITE(y2) )
+ if ( !std::isfinite(x1) || !std::isfinite(y1) || !std::isfinite(x2) || !std::isfinite(y2) )
throw util::IllegalArgumentException("RobustDeterminant encountered non-finite numbers ");
diff --git a/src/geom/Coordinate.cpp b/src/geom/Coordinate.cpp
index fca94d8..685301e 100644
--- a/src/geom/Coordinate.cpp
+++ b/src/geom/Coordinate.cpp
@@ -13,11 +13,12 @@
+#include <geos/constants.h> // for std::isnan
#include <sstream>
#include <string>
#include <iomanip>
+#include <cmath>
#ifndef GEOS_INLINE
# include <geos/geom/Coordinate.inl>
@@ -46,7 +47,7 @@ Coordinate::toString() const
std::ostream& operator<< (std::ostream& os, const Coordinate& c)
- if ( ISNAN(c.z) )
+ if ( std::isnan(c.z) )
os << c.x << " " << c.y;
} else {
diff --git a/src/geom/CoordinateArraySequence.cpp b/src/geom/CoordinateArraySequence.cpp
index 04c786d..80c4aa5 100644
--- a/src/geom/CoordinateArraySequence.cpp
+++ b/src/geom/CoordinateArraySequence.cpp
@@ -98,7 +98,7 @@ CoordinateArraySequence::getDimension() const
if( vect->empty() )
return 3;
- if( ISNAN((*vect)[0].z) )
+ if( std::isnan((*vect)[0].z) )
dimension = 2;
else
dimension = 3;
diff --git a/src/geom/GeometryFactory.cpp b/src/geom/GeometryFactory.cpp
index 6640e25..e504a09 100644
--- a/src/geom/GeometryFactory.cpp
+++ b/src/geom/GeometryFactory.cpp
@@ -307,7 +307,7 @@ GeometryFactory::createPoint(const Coordinate& coordinate) const
if (coordinate.isNull()) {
return createPoint();
} else {
- std::size_t dim = ISNAN(coordinate.z) ? 2 : 3;
+ std::size_t dim = std::isnan(coordinate.z) ? 2 : 3;
CoordinateSequence *cl = coordinateListFactory->create(new vector<Coordinate>(1, coordinate), dim);
//cl->setAt(coordinate, 0);
Point *ret = createPoint(cl);
diff --git a/src/geom/LineSegment.cpp b/src/geom/LineSegment.cpp
index c7d29a2..0e75f7c 100644
--- a/src/geom/LineSegment.cpp
+++ b/src/geom/LineSegment.cpp
@@ -18,6 +18,7 @@
#include <geos/geom/LineSegment.h>
#include <geos/geom/LineString.h> // for toGeometry
diff --git a/src/geom/util/SineStarFactory.cpp b/src/geom/util/SineStarFactory.cpp
index 0689aaa..a734cc4 100644
--- a/src/geom/util/SineStarFactory.cpp
+++ b/src/geom/util/SineStarFactory.cpp
@@ -16,6 +16,7 @@
#include <geos/geom/util/SineStarFactory.h>
#include <geos/geom/CoordinateSequenceFactory.h>
@@ -29,10 +30,6 @@
#include <cmath>
#include <memory>
-#ifndef M_PI
-#endif
using namespace std;
//using namespace geos::geom;
diff --git a/src/geomgraph/Node.cpp b/src/geomgraph/Node.cpp
index f2a42df..6f4a609 100644
--- a/src/geomgraph/Node.cpp
+++ b/src/geomgraph/Node.cpp
@@ -18,7 +18,6 @@
#include <geos/geomgraph/Node.h>
#include <geos/geomgraph/Edge.h>
@@ -245,7 +244,7 @@ Node::addZ(double z)
#if GEOS_DEBUG
cerr<<"["<<this<<"] Node::addZ("<<z<<")";
#endif
- if ( ISNAN(z) )
+ if ( std::isnan(z) )
#if GEOS_DEBUG
cerr<<" skipped"<<endl;
diff --git a/src/io/ByteOrderValues.cpp b/src/io/ByteOrderValues.cpp
index 08e9129..c5be5b4 100644
--- a/src/io/ByteOrderValues.cpp
+++ b/src/io/ByteOrderValues.cpp
@@ -17,7 +17,7 @@
#include <geos/util.h>
#include <cstring>
diff --git a/src/io/WKTWriter.cpp b/src/io/WKTWriter.cpp
index 7880e11..f1704c5 100644
--- a/src/io/WKTWriter.cpp
+++ b/src/io/WKTWriter.cpp
@@ -18,7 +18,6 @@
#include <geos/io/WKTWriter.h>
#include <geos/io/Writer.h>
#include <geos/io/CLocalizer.h>
@@ -326,7 +325,7 @@ WKTWriter::appendCoordinate(const Coordinate* coordinate,
if( outputDimension == 3 )
writer->write(" ");
- if( ISNAN(coordinate->z) )
+ if( std::isnan(coordinate->z) )
writer->write(writeNumber(0.0));
else
writer->write(writeNumber(coordinate->z));
diff --git a/src/operation/buffer/BufferOp.cpp b/src/operation/buffer/BufferOp.cpp
index 872ce63..e34c2fb 100644
--- a/src/operation/buffer/BufferOp.cpp
+++ b/src/operation/buffer/BufferOp.cpp
@@ -21,7 +21,7 @@
#include <algorithm>
#include <cmath>
#include <geos/profiler.h>
#include <geos/precision/GeometryPrecisionReducer.h>
#include <geos/operation/buffer/BufferOp.h>
diff --git a/src/operation/buffer/BufferParameters.cpp b/src/operation/buffer/BufferParameters.cpp
index d9b1bee..f547c95 100644
--- a/src/operation/buffer/BufferParameters.cpp
+++ b/src/operation/buffer/BufferParameters.cpp
@@ -19,14 +19,10 @@
#include <cstdlib> // for std::abs()
#include <cmath> // for cos
#include <geos/operation/buffer/BufferParameters.h>
-#ifndef M_PI
-#endif
namespace geos {
namespace operation { // geos.operation
namespace buffer { // geos.operation.buffer
diff --git a/src/operation/buffer/OffsetCurveSetBuilder.cpp b/src/operation/buffer/OffsetCurveSetBuilder.cpp
index 44b758b..47bf9a3 100644
--- a/src/operation/buffer/OffsetCurveSetBuilder.cpp
+++ b/src/operation/buffer/OffsetCurveSetBuilder.cpp
@@ -18,7 +18,7 @@
diff --git a/src/operation/distance/DistanceOp.cpp b/src/operation/distance/DistanceOp.cpp
index a5fdcdb..93a2e5e 100644
--- a/src/operation/distance/DistanceOp.cpp
+++ b/src/operation/distance/DistanceOp.cpp
@@ -18,6 +18,7 @@
#include <geos/operation/distance/DistanceOp.h>
#include <geos/operation/distance/GeometryLocation.h>
#include <geos/operation/distance/ConnectedElementLocationFilter.h>
diff --git a/src/operation/overlay/ElevationMatrix.cpp b/src/operation/overlay/ElevationMatrix.cpp
index a5445ad..1bffeef 100644
--- a/src/operation/overlay/ElevationMatrix.cpp
+++ b/src/operation/overlay/ElevationMatrix.cpp
@@ -16,7 +16,7 @@
#include <geos/operation/overlay/ElevationMatrix.h>
@@ -61,14 +61,14 @@ ElevationMatrixFilter::filter_rw(Coordinate *c) const
#endif
// already has a Z value, nothing to do
- if ( ! ISNAN(c->z) ) return;
+ if ( ! std::isnan(c->z) ) return;
double p_avgElevation = em.getAvgElevation();
try {
const ElevationMatrixCell &emc = em.getCell(*c);
c->z = emc.getAvg();
- if ( ISNAN(c->z) ) c->z = p_avgElevation;
+ if ( std::isnan(c->z) ) c->z = p_avgElevation;
#if GEOS_DEBUG
cerr<<" z set to "<<c->z<<endl;
#endif
@@ -137,7 +137,7 @@ ElevationMatrix::add(const CoordinateSequence *cs)
void
ElevationMatrix::add(const Coordinate &c)
- if ( ISNAN(c.z) ) return;
+ if ( std::isnan(c.z) ) return;
try {
ElevationMatrixCell &emc = getCell(c);
emc.add(c);
@@ -200,7 +200,7 @@ ElevationMatrix::getAvgElevation() const
const ElevationMatrixCell &cell = cells[(r*cols)+c];
double e = cell.getAvg();
- if ( !ISNAN(e) )
+ if ( !std::isnan(e) )
zvals++;
ztot+=e;
@@ -236,7 +236,7 @@ ElevationMatrix::elevate(Geometry *g) const
// Nothing to do if no elevation info in matrix
- if ( ISNAN(getAvgElevation()) ) return;
+ if ( std::isnan(getAvgElevation()) ) return;
g->apply_rw(&filter);
diff --git a/src/operation/overlay/ElevationMatrixCell.cpp b/src/operation/overlay/ElevationMatrixCell.cpp
index d5aee46..e1b5548 100644
--- a/src/operation/overlay/ElevationMatrixCell.cpp
+++ b/src/operation/overlay/ElevationMatrixCell.cpp
@@ -16,7 +16,7 @@
#include <geos/operation/overlay/ElevationMatrixCell.h>
@@ -43,7 +43,7 @@ ElevationMatrixCell::~ElevationMatrixCell()
void
ElevationMatrixCell::add(const Coordinate &c)
- if ( !ISNAN(c.z) )
+ if ( !std::isnan(c.z) )
if ( zvals.insert(c.z).second )
@@ -55,7 +55,7 @@ ElevationMatrixCell::add(const Coordinate &c)
void
ElevationMatrixCell::add(double z)
- if ( !ISNAN(z) )
if ( zvals.insert(z).second )
diff --git a/src/operation/overlay/LineBuilder.cpp b/src/operation/overlay/LineBuilder.cpp
index 6b13d68..c39de10 100644
--- a/src/operation/overlay/LineBuilder.cpp
+++ b/src/operation/overlay/LineBuilder.cpp
@@ -17,7 +17,6 @@
#include <geos/operation/overlay/LineBuilder.h>
#include <geos/operation/overlay/OverlayOp.h>
#include <geos/algorithm/PointLocator.h>
@@ -218,7 +217,7 @@ LineBuilder::propagateZ(CoordinateSequence *cs)
size_t cssize = cs->getSize();
for (size_t i = 0; i < cssize; ++i)
- if ( !ISNAN(cs->getAt(i).z) ) v3d.push_back(i);
+ if ( !std::isnan(cs->getAt(i).z) ) v3d.push_back(i);
#if GEOS_DEBUG
diff --git a/src/operation/overlay/OverlayOp.cpp b/src/operation/overlay/OverlayOp.cpp
index e5a93c7..1621d3b 100644
--- a/src/operation/overlay/OverlayOp.cpp
+++ b/src/operation/overlay/OverlayOp.cpp
@@ -17,7 +17,7 @@
#include <geos/operation/overlay/validate/OverlayResultValidator.h>
@@ -461,7 +461,7 @@ OverlayOp::getAverageZ(const Polygon *poly)
for (size_t i=0; i<npts; ++i)
const Coordinate &c = pts->getAt(i);
totz += c.z;
zcount++;
index c7a3d18..dbcf4eb 100644
@@ -19,16 +19,13 @@
-#include "IndexedNestedRingTester.h" // TODO: private header>? --mloskot
+#include <geos/algorithm/CGAlgorithms.h>
+#include <geos/algorithm/MCPointInRing.h>
#include <geos/algorithm/PointLocation.h>
#include <geos/algorithm/locate/IndexedPointInAreaLocator.h>
-#include <geos/operation/valid/ConnectedInteriorTester.h>
-#include <geos/operation/valid/ConsistentAreaTester.h>
-#include <geos/operation/valid/IsValidOp.h>
@@ -41,6 +38,10 @@
#include <geos/geomgraph/index/SegmentIntersector.h>
+#include <geos/operation/valid/ConnectedInteriorTester.h>
+#include <geos/operation/valid/ConsistentAreaTester.h>
+#include <geos/operation/valid/IndexedNestedRingTester.h>
+#include <geos/operation/valid/IsValidOp.h>
@@ -95,9 +96,15 @@ IsValidOp::isValid()
bool
+<<<<<<< HEAD
return true;
+ return true;
+>>>>>>> Using constants.h and stop using platform.h (closes #925)
/* static public */
diff --git a/src/planargraph/algorithm/ConnectedSubgraphFinder.cpp b/src/planargraph/algorithm/ConnectedSubgraphFinder.cpp
index a0a5343..8e9f932 100644
--- a/src/planargraph/algorithm/ConnectedSubgraphFinder.cpp
+++ b/src/planargraph/algorithm/ConnectedSubgraphFinder.cpp
@@ -12,7 +12,7 @@
#include <geos/planargraph/algorithm/ConnectedSubgraphFinder.h>
#include <geos/planargraph/Subgraph.h>
#include <geos/planargraph/Edge.h>
diff --git a/src/precision/CommonBits.cpp b/src/precision/CommonBits.cpp
index e8e4fd8..a435a92 100644
--- a/src/precision/CommonBits.cpp
+++ b/src/precision/CommonBits.cpp
@@ -13,7 +13,7 @@
#include <geos/precision/CommonBits.h>
namespace geos {
diff --git a/src/util/GeometricShapeFactory.cpp b/src/util/GeometricShapeFactory.cpp
index a1b5eae..bfc80f7 100644
--- a/src/util/GeometricShapeFactory.cpp
+++ b/src/util/GeometricShapeFactory.cpp
@@ -17,6 +17,7 @@
#include <geos/util/GeometricShapeFactory.h>
@@ -28,9 +29,6 @@
#include <cmath>
#include <memory>
-#ifndef M_PI
-#endif
diff --git a/tests/perf/ClassSizes.cpp b/tests/perf/ClassSizes.cpp
index 9ae5e68..09ab4a9 100644
--- a/tests/perf/ClassSizes.cpp
+++ b/tests/perf/ClassSizes.cpp
@@ -25,7 +25,7 @@
#include <geos/geomgraph/PlanarGraph.h>
#include <geos/noding/NodedSegmentString.h>
#include <iostream>
diff --git a/tests/unit/algorithm/distance/DiscreteFrechetDistanceTest.cpp b/tests/unit/algorithm/distance/DiscreteFrechetDistanceTest.cpp
index d4d55a2..a1e74be 100644
--- a/tests/unit/algorithm/distance/DiscreteFrechetDistanceTest.cpp
+++ b/tests/unit/algorithm/distance/DiscreteFrechetDistanceTest.cpp
@@ -4,7 +4,7 @@
#include <tut/tut.hpp>
// geos
#include <geos/io/WKTReader.h>
#include <geos/algorithm/distance/DiscreteFrechetDistance.h>
#include <geos/geom/PrecisionModel.h>
diff --git a/tests/unit/algorithm/distance/DiscreteHausdorffDistanceTest.cpp b/tests/unit/algorithm/distance/DiscreteHausdorffDistanceTest.cpp
index 236ce39..15f01fe 100644
--- a/tests/unit/algorithm/distance/DiscreteHausdorffDistanceTest.cpp
+++ b/tests/unit/algorithm/distance/DiscreteHausdorffDistanceTest.cpp
@@ -5,7 +5,7 @@
// geos
#include <geos/algorithm/distance/DiscreteHausdorffDistance.h>
diff --git a/tests/unit/capi/GEOSDistanceTest.cpp b/tests/unit/capi/GEOSDistanceTest.cpp
index b66c668..1a2dae4 100644
--- a/tests/unit/capi/GEOSDistanceTest.cpp
+++ b/tests/unit/capi/GEOSDistanceTest.cpp
@@ -4,15 +4,13 @@
// geos
#include <geos_c.h>
// std
#include <cstdarg>
#include <cstdio>
#include <cstdlib>
#include <memory>
#include <math.h>
-#ifndef M_PI
-#endif
namespace tut
@@ -93,7 +91,7 @@ namespace tut
for (size_t i = 0; i < num_points; i++) {
- angle[i] = 2 * M_PI * std::rand() / RAND_MAX;
+ angle[i] = 2 * geos::M_PI * std::rand() / RAND_MAX;
radius[i] = r*std::rand() / RAND_MAX;
diff --git a/tests/unit/geom/CoordinateArraySequenceTest.cpp b/tests/unit/geom/CoordinateArraySequenceTest.cpp
index 238667b..71f9893 100644
--- a/tests/unit/geom/CoordinateArraySequenceTest.cpp
+++ b/tests/unit/geom/CoordinateArraySequenceTest.cpp
@@ -30,9 +30,9 @@ namespace tut
Filter() : is3d(false) {}
void filter_rw(geos::geom::Coordinate* c) const override {
if ( is3d ) {
- if ( ISNAN(c->z) ) c->z = 0.0;
+ if ( std::isnan(c->z) ) c->z = 0.0;
- else c->z = DoubleNotANumber;
+ else c->z = geos::DoubleNotANumber;
diff --git a/tests/unit/geom/CoordinateTest.cpp b/tests/unit/geom/CoordinateTest.cpp
index 07392cf..e7ba1db 100644
--- a/tests/unit/geom/CoordinateTest.cpp
+++ b/tests/unit/geom/CoordinateTest.cpp
@@ -3,7 +3,6 @@
// geos
// std
#include <cmath>
@@ -56,7 +55,7 @@ namespace tut
geos::geom::Coordinate coord;
ensure_equals( coord.x, 0.0 );
ensure_equals( coord.y, 0.0 );
- ensure(0 != ISNAN( coord.z ) );
+ ensure(0 != std::isnan( coord.z ) );
// Test of copy constructor and assignment operator
@@ -178,16 +177,16 @@ namespace tut
// Make it null and check
not_null_coord.setNull();
- ensure( 0 != ISNAN( not_null_coord.x ) );
- ensure( 0 != ISNAN( not_null_coord.y ) );
- ensure( 0 != ISNAN( not_null_coord.z ) );
+ ensure( 0 != std::isnan( not_null_coord.x ) );
+ ensure( 0 != std::isnan( not_null_coord.y ) );
+ ensure( 0 != std::isnan( not_null_coord.z ) );
// Build in static null instance
geos::geom::Coordinate null_coord;
null_coord = geos::geom::Coordinate::getNull();
- ensure( 0 != ISNAN( null_coord.x ) );
- ensure( 0 != ISNAN( null_coord.y ) );
- ensure( 0 != ISNAN( null_coord.z ) );
+ ensure( 0 != std::isnan( null_coord.x ) );
+ ensure( 0 != std::isnan( null_coord.y ) );
+ ensure( 0 != std::isnan( null_coord.z ) );
} // namespace tut
diff --git a/tests/unit/geom/TriangleTest.cpp b/tests/unit/geom/TriangleTest.cpp
index 380ad0c..31552ff 100644
--- a/tests/unit/geom/TriangleTest.cpp
+++ b/tests/unit/geom/TriangleTest.cpp
@@ -4,7 +4,6 @@
// tut
// geos
#include <geos/geom/Triangle.h>
// std
@@ -115,7 +114,7 @@ namespace tut
ensure( std::fabs(center.x - 6.0) < 1e-15 );
ensure( center.y > 4.2 );
ensure( center.y < 4.3 );
- ensure( 0 != ISNAN( center.z ) );
+ ensure( 0 != std::isnan( center.z ) );
// Test circumcentre()
template<>
@@ -148,14 +147,14 @@ namespace tut
t1.circumcentre(c1);
ensure_equals(c1.x ,2 );
ensure_equals(c1.y ,3 );
- ensure( 0 != ISNAN( c1.z ) );
+ ensure( 0 != std::isnan( c1.z ) );
//For t2:
Coordinate c2(0,0);
t2.circumcentre(c2);
ensure_equals(c2.x ,30.5 );
ensure_equals(c2.y ,- 14.5 );
- ensure( 0 != ISNAN( c2.z ) );
+ ensure( 0 != std::isnan( c2.z ) );
//For t3:
@@ -164,7 +163,7 @@ namespace tut
ensure( std::fabs(c3.x - 13.0) < 1 );
ensure( c3.y > 13.7 );
ensure( c3.y < 13.8 );
- ensure( 0 != ISNAN( c3.z ) );
+ ensure( 0 != std::isnan( c3.z ) );
// cout << "CicumCenter of triangle ABC:: " << c1.x << " " << c1.y << endl;
// std::cout << "CicumCenter of triangle DEF:: " << c2.x << " " << c2.y << std::endl;
diff --git a/tests/unit/geom/util/GeometryExtracterTest.cpp b/tests/unit/geom/util/GeometryExtracterTest.cpp
index 008d36d..6c0cbdd 100644
--- a/tests/unit/geom/util/GeometryExtracterTest.cpp
+++ b/tests/unit/geom/util/GeometryExtracterTest.cpp
@@ -4,7 +4,7 @@
// tut
// geos
#include <geos/geom/GeometryFactory.h>
diff --git a/tests/unit/io/ByteOrderValuesTest.cpp b/tests/unit/io/ByteOrderValuesTest.cpp
index ce5c73c..3ef25df 100644
--- a/tests/unit/io/ByteOrderValuesTest.cpp
+++ b/tests/unit/io/ByteOrderValuesTest.cpp
@@ -5,7 +5,7 @@
// geos
// std
#include <sstream>
#include <memory>
diff --git a/tests/unit/io/WKBWriterTest.cpp b/tests/unit/io/WKBWriterTest.cpp
index 3d94c60..8eb89d5 100644
--- a/tests/unit/io/WKBWriterTest.cpp
+++ b/tests/unit/io/WKBWriterTest.cpp
@@ -76,7 +76,7 @@ namespace tut
ensure( geom->getCoordinateDimension() == 2 );
ensure( geom->getCoordinate()->x == -117.0 );
ensure( geom->getCoordinate()->y == 33.0 );
- ensure( ISNAN(geom->getCoordinate()->z) != 0 );
+ ensure( std::isnan(geom->getCoordinate()->z) != 0 );
delete geom;
@@ -128,7 +128,7 @@ namespace tut
- ensure( ISNAN(geom->getCoordinate()->z) != 0);
+ ensure( std::isnan(geom->getCoordinate()->z) != 0);
delete geom;
diff --git a/tests/unit/linearref/LengthIndexedLineTest.cpp b/tests/unit/linearref/LengthIndexedLineTest.cpp
index 23c5e3a..df494aa 100644
--- a/tests/unit/linearref/LengthIndexedLineTest.cpp
+++ b/tests/unit/linearref/LengthIndexedLineTest.cpp
@@ -5,7 +5,6 @@
#include <utility.h>
// geos
@@ -399,7 +398,7 @@ void object::test<25>()
LengthIndexedLine indexedLine(linearGeom.get());
double projIndex = indexedLine.project(Coordinate(5, 5));
Coordinate projPt = indexedLine.extractPoint(projIndex);
- ensure(0 != ISNAN(projPt.z));
+ ensure(0 != std::isnan(projPt.z));
diff --git a/tests/unit/operation/buffer/BufferBuilderTest.cpp b/tests/unit/operation/buffer/BufferBuilderTest.cpp
index f18b59a..259d141 100644
--- a/tests/unit/operation/buffer/BufferBuilderTest.cpp
+++ b/tests/unit/operation/buffer/BufferBuilderTest.cpp
@@ -6,7 +6,7 @@
// geos
#include <geos/operation/buffer/BufferBuilder.h>
diff --git a/tests/unit/operation/buffer/BufferOpTest.cpp b/tests/unit/operation/buffer/BufferOpTest.cpp
index d4ba5ca..21370de 100644
--- a/tests/unit/operation/buffer/BufferOpTest.cpp
+++ b/tests/unit/operation/buffer/BufferOpTest.cpp
@@ -6,7 +6,7 @@
// geos
diff --git a/tests/unit/operation/buffer/BufferParametersTest.cpp b/tests/unit/operation/buffer/BufferParametersTest.cpp
index 2272dad..322aabd 100644
--- a/tests/unit/operation/buffer/BufferParametersTest.cpp
+++ b/tests/unit/operation/buffer/BufferParametersTest.cpp
@@ -5,7 +5,7 @@
// geos
// std
#include <memory>
diff --git a/tests/unit/operation/distance/DistanceOpTest.cpp b/tests/unit/operation/distance/DistanceOpTest.cpp
index 0e31553..f136da2 100644
--- a/tests/unit/operation/distance/DistanceOpTest.cpp
+++ b/tests/unit/operation/distance/DistanceOpTest.cpp
@@ -5,7 +5,7 @@
// geos
diff --git a/tests/unit/operation/linemerge/LineMergerTest.cpp b/tests/unit/operation/linemerge/LineMergerTest.cpp
index 46e7915..1f83205 100644
--- a/tests/unit/operation/linemerge/LineMergerTest.cpp
+++ b/tests/unit/operation/linemerge/LineMergerTest.cpp
@@ -5,7 +5,7 @@
// geos
#include <geos/operation/linemerge/LineMerger.h>
diff --git a/tests/unit/operation/linemerge/LineSequencerTest.cpp b/tests/unit/operation/linemerge/LineSequencerTest.cpp
index a8950aa..5da318c 100644
--- a/tests/unit/operation/linemerge/LineSequencerTest.cpp
+++ b/tests/unit/operation/linemerge/LineSequencerTest.cpp
@@ -5,7 +5,7 @@
// geos
#include <geos/operation/linemerge/LineSequencer.h>
diff --git a/tests/unit/operation/sharedpaths/SharedPathsOpTest.cpp b/tests/unit/operation/sharedpaths/SharedPathsOpTest.cpp
index 82647ba..e4f8396 100644
--- a/tests/unit/operation/sharedpaths/SharedPathsOpTest.cpp
+++ b/tests/unit/operation/sharedpaths/SharedPathsOpTest.cpp
@@ -5,7 +5,7 @@
// geos
#include <geos/operation/sharedpaths/SharedPathsOp.h>
diff --git a/tests/unit/operation/valid/IsValidTest.cpp b/tests/unit/operation/valid/IsValidTest.cpp
index 1cf3204..18d3cee 100644
--- a/tests/unit/operation/valid/IsValidTest.cpp
+++ b/tests/unit/operation/valid/IsValidTest.cpp
@@ -4,7 +4,7 @@
// geos
#include <geos/geom/CoordinateArraySequence.h>
@@ -14,7 +14,7 @@
#include <geos/operation/valid/TopologyValidationError.h>
// std
#include <cmath>
#include <string>
@@ -59,7 +59,7 @@ namespace tut
CoordinateSequence* cs = new CoordinateArraySequence();
cs->add(Coordinate(0.0, 0.0));
- cs->add(Coordinate(1.0, DoubleNotANumber));
+ cs->add(Coordinate(1.0, geos::DoubleNotANumber));
GeomPtr line ( factory_->createLineString(cs) );
@@ -73,7 +73,7 @@ namespace tut
ensure_equals( err->getErrorType(),
TopologyValidationError::eInvalidCoordinate );
- ensure(0 != ISNAN(errCoord.y));
+ ensure(0 != std::isnan(errCoord.y));
ensure_equals(valid, false);
diff --git a/tests/unit/operation/valid/ValidClosedRingTest.cpp b/tests/unit/operation/valid/ValidClosedRingTest.cpp
index 6a567e1..314a2ff 100644
--- a/tests/unit/operation/valid/ValidClosedRingTest.cpp
+++ b/tests/unit/operation/valid/ValidClosedRingTest.cpp
@@ -17,8 +17,8 @@
#include <geos/util/GEOSException.h>
// std
+#include <cmath>
#include <string>
#include <memory>
#include <iostream>
diff --git a/tests/unit/operation/valid/ValidSelfTouchingRingFormingHoleTest.cpp b/tests/unit/operation/valid/ValidSelfTouchingRingFormingHoleTest.cpp
index 4cb8787..122ffaf 100644
--- a/tests/unit/operation/valid/ValidSelfTouchingRingFormingHoleTest.cpp
+++ b/tests/unit/operation/valid/ValidSelfTouchingRingFormingHoleTest.cpp
@@ -17,8 +17,8 @@
// std
+#include <cmath>
#include <string>
#include <memory>
#include <iostream>
diff --git a/tests/unit/precision/CommonBitsTest.cpp b/tests/unit/precision/CommonBitsTest.cpp
index e3c0bf4..14fb1ef 100644
--- a/tests/unit/precision/CommonBitsTest.cpp
+++ b/tests/unit/precision/CommonBitsTest.cpp
@@ -3,7 +3,7 @@
// tut
// geos
// std
Summary of changes:
CMakeLists.txt | 25 +-
capi/geos_ts_c.cpp | 3 +-
configure.ac | 2 +-
doc/example.cpp | 5 +-
include/CMakeLists.txt | 11 +-
include/geos/Makefile.am | 8 +-
.../geos/algorithm/distance/PointPairDistance.h | 2 +-
include/geos/{platform.h.cmake => constants.h} | 32 +-
include/geos/geom/Coordinate.h | 2 +-
include/geos/geom/Coordinate.inl | 10 +-
include/geos/geom/CoordinateSequence.h | 1 -
include/geos/geom/Geometry.h | 1 -
include/geos/geom/GeometryCollection.h | 1 -
include/geos/geom/GeometryFilter.h | 1 -
include/geos/geom/LineString.h | 1 -
include/geos/geom/LinearRing.h | 1 -
include/geos/geom/MultiPoint.h | 1 -
include/geos/geom/MultiPolygon.h | 1 -
include/geos/geom/Point.h | 1 -
include/geos/geom/Polygon.h | 1 -
.../geos/geom/util/ComponentCoordinateExtracter.h | 1 -
include/geos/geom/util/GeometryExtracter.h | 1 -
include/geos/geom/util/LinearComponentExtracter.h | 1 -
include/geos/geom/util/PointExtracter.h | 1 -
include/geos/geom/util/PolygonExtracter.h | 1 -
.../geos/index/intervalrtree/IntervalRTreeNode.h | 2 +-
include/geos/index/quadtree/DoubleBits.h | 2 +-
include/geos/io/ByteOrderDataInStream.h | 1 -
include/geos/io/ByteOrderValues.h | 2 +-
include/geos/platform.h.in | 116 ------
include/geos/platform.h.vc | 60 ----
include/geos/precision/CommonBits.h | 2 +-
include/geos/precision/EnhancedPrecisionOp.h | 2 +-
src/Makefile.vc | 394 ---------------------
src/algorithm/CGAlgorithmsDD.cpp | 6 +-
src/algorithm/HCoordinate.cpp | 7 +-
src/algorithm/InteriorPointLine.cpp | 1 +
src/algorithm/InteriorPointPoint.cpp | 2 +-
src/algorithm/LineIntersector.cpp | 76 ++--
src/algorithm/MinimumDiameter.cpp | 1 +
src/algorithm/RobustDeterminant.cpp | 3 +-
src/geom/Coordinate.cpp | 5 +-
src/geom/CoordinateArraySequence.cpp | 2 +-
src/geom/GeometryFactory.cpp | 2 +-
src/geom/LineSegment.cpp | 1 +
src/geom/util/SineStarFactory.cpp | 5 +-
src/geomgraph/Node.cpp | 3 +-
src/io/ByteOrderValues.cpp | 2 +-
src/io/WKTWriter.cpp | 3 +-
src/operation/buffer/BufferOp.cpp | 2 +-
src/operation/buffer/BufferParameters.cpp | 6 +-
src/operation/buffer/OffsetCurveSetBuilder.cpp | 2 +-
src/operation/distance/DistanceOp.cpp | 1 +
src/operation/overlay/ElevationMatrix.cpp | 12 +-
src/operation/overlay/ElevationMatrixCell.cpp | 6 +-
src/operation/overlay/LineBuilder.cpp | 3 +-
src/operation/overlay/OverlayOp.cpp | 4 +-
src/operation/valid/IsValidOp.cpp | 16 +-
.../algorithm/ConnectedSubgraphFinder.cpp | 2 +-
src/precision/CommonBits.cpp | 2 +-
src/util/GeometricShapeFactory.cpp | 4 +-
tests/perf/ClassSizes.cpp | 2 +-
.../distance/DiscreteFrechetDistanceTest.cpp | 2 +-
.../distance/DiscreteHausdorffDistanceTest.cpp | 2 +-
tests/unit/capi/GEOSDistanceTest.cpp | 6 +-
tests/unit/geom/CoordinateArraySequenceTest.cpp | 4 +-
tests/unit/geom/CoordinateTest.cpp | 15 +-
tests/unit/geom/TriangleTest.cpp | 9 +-
tests/unit/geom/util/GeometryExtracterTest.cpp | 2 +-
tests/unit/io/ByteOrderValuesTest.cpp | 2 +-
tests/unit/io/WKBWriterTest.cpp | 4 +-
tests/unit/linearref/LengthIndexedLineTest.cpp | 3 +-
tests/unit/operation/buffer/BufferBuilderTest.cpp | 2 +-
tests/unit/operation/buffer/BufferOpTest.cpp | 2 +-
.../unit/operation/buffer/BufferParametersTest.cpp | 2 +-
tests/unit/operation/distance/DistanceOpTest.cpp | 2 +-
tests/unit/operation/linemerge/LineMergerTest.cpp | 2 +-
.../unit/operation/linemerge/LineSequencerTest.cpp | 2 +-
.../operation/sharedpaths/SharedPathsOpTest.cpp | 2 +-
tests/unit/operation/valid/IsValidTest.cpp | 8 +-
tests/unit/operation/valid/ValidClosedRingTest.cpp | 2 +-
.../valid/ValidSelfTouchingRingFormingHoleTest.cpp | 2 +-
tests/unit/precision/CommonBitsTest.cpp | 2 +-
83 files changed, 162 insertions(+), 792 deletions(-)
rename include/geos/{platform.h.cmake => constants.h} (69%)
delete mode 100644 include/geos/platform.h.in
delete mode 100755 include/geos/platform.h.vc
delete mode 100644 src/Makefile.vc
hooks/post-receive
More information about the geos-commits
