[geos-commits] [SCM] GEOS branch master updated. 7a30a2650452a1594ebb9d805633b9f0770980ba
git at osgeo.org
git at osgeo.org
Tue Jan 29 13:53:13 PST 2019
the project "GEOS".
via 7a30a2650452a1594ebb9d805633b9f0770980ba (commit)
from af778396870b07582bd0371de66879964be4cbb2 (commit)
revisions in full, below.
commit 7a30a2650452a1594ebb9d805633b9f0770980ba
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Tue Jan 29 13:52:59 2019 -0800
Clean ups for make dist and build bots
diff --git a/Makefile.am b/Makefile.am
index d4e45d2..8a2176a 100644
--- a/Makefile.am
+++ b/Makefile.am
@@ -24,8 +24,8 @@ SUBDIRS = \
BUILT_SOURCES = geos_revision.h
-EXTRA_DIST = acsite.m4 .editorconfig makefile.vc \
- Version.txt nmake.opt autogen.bat CMakeLists.txt \
+EXTRA_DIST = acsite.m4 .editorconfig \
+ Version.txt CMakeLists.txt \
cmake/modules/CheckPrototypeExists.cmake \
cmake/modules/COPYING-CMAKE-SCRIPTS \
cmake/modules/GenerateSourceGroups.cmake \
diff --git a/include/geos/Makefile.am b/include/geos/Makefile.am
index f9fe788..8fa3be0 100644
--- a/include/geos/Makefile.am
+++ b/include/geos/Makefile.am
@@ -16,7 +16,7 @@ SUBDIRS = \
triangulate \
util
-EXTRA_DIST = version.h.vc
+EXTRA_DIST =
geosdir = $(includedir)/geos
diff --git a/include/geos/algorithm/Makefile.am b/include/geos/algorithm/Makefile.am
index 711ffc1..e4c22f1 100644
--- a/include/geos/algorithm/Makefile.am
+++ b/include/geos/algorithm/Makefile.am
@@ -26,6 +26,7 @@ geos_HEADERS = \
InteriorPointPoint.h \
Length.h \
LineIntersector.h \
+ MinimumBoundingCircle.h \
MinimumDiameter.h \
NotRepresentableException.h \
Orientation.h \
diff --git a/include/geos/noding/IntersectionAdder.h b/include/geos/noding/IntersectionAdder.h
index 58d9090..f9b49b3 100644
--- a/include/geos/noding/IntersectionAdder.h
+++ b/include/geos/noding/IntersectionAdder.h
@@ -72,8 +72,8 @@ private:
const geom::Coordinate* properIntersectionPoint;
algorithm::LineIntersector& li;
- bool isSelfIntersection;
- //bool intersectionFound;
+ // bool isSelfIntersection;
+ // bool intersectionFound;
* A trivial intersection is an apparent self-intersection which
diff --git a/include/geos/version.h.vc b/include/geos/version.h.vc
deleted file mode 100644
index 368fcfe..0000000
--- a/include/geos/version.h.vc
+++ /dev/null
@@ -1,48 +0,0 @@
- * GEOS - Geometry Engine Open Source
- * http://geos.osgeo.org
- * Copyright (C) 2007 Refractions Research Inc.
- * This is free software; you can redistribute and/or modify it under
- * the terms of the GNU Lesser General Public Licence as published
- * by the Free Software Foundation.
- * See the COPYING file for more information.
- * This is a version header dedicated for use with Microsoft Visual C++
- * compiler.
- * NOTE: Remember to update this file manually when version
- * number changes.
-#ifndef GEOS_VERSION_H_INCLUDED
-#define GEOS_VERSION_H_INCLUDED
-#ifndef _MSC_VER
-#error "This version.h intended for use with MS Visual C++"
-#endif
-#ifndef GEOS_VERSION_MAJOR
-#define GEOS_VERSION_MAJOR 3
-#endif
-#ifndef GEOS_VERSION_MINOR
-#define GEOS_VERSION_MINOR 8
-#endif
-#ifndef GEOS_VERSION_PATCH
-#define GEOS_VERSION_PATCH 0dev
-#endif
-#define GEOS_VERSION "3.8.0dev"
-#endif
-#ifndef GEOS_JTS_PORT
-#define GEOS_JTS_PORT "1.13.0"
-#endif
-#endif // GEOS_VERSION_H_INCLUDED
diff --git a/makefile.vc b/makefile.vc
index 37262a3..0000000
--- a/makefile.vc
+++ /dev/null
@@ -1,31 +0,0 @@
-# NMAKE Makefile to build GEOS on Windows
-# This makefile.vc delegates making targets to src\makefile.vc
-# so it's just a thin wrapper.
-# Building on Win32 with Visual Studio
-# 1) Requires Visual C++ 2002 or later
-# 2) Build running command "nmake /f makefile.vc" in top-level directory
-# Produces:
-# src\geos.dll: DLL - only exports the C API
-# src\geos_i.lib: Stub library to link against for use of geos.dll.
-# src\geos.lib: static library for use of C or C++ API.
-GEOS_ROOT=.
-!INCLUDE $(GEOS_ROOT)\nmake.opt
-default: src_dir
-src_dir:
- cd src
- $(MAKE) /f makefile.vc
- cd ..
-clean:
- cd src
- $(MAKE) /f makefile.vc clean
- cd ..
diff --git a/src/Makefile.am b/src/Makefile.am
index 27dce43..1bba8e8 100644
--- a/src/Makefile.am
+++ b/src/Makefile.am
triangulate \
util
-EXTRA_DIST = Makefile.vc dirlist.mk CMakeLists.txt info.plist.in
+EXTRA_DIST = dirlist.mk CMakeLists.txt info.plist.in
AM_CPPFLAGS = -I$(top_srcdir)/include
diff --git a/src/algorithm/MinimumBoundingCircle.cpp b/src/algorithm/MinimumBoundingCircle.cpp
index f178ae0..0928d66 100644
--- a/src/algorithm/MinimumBoundingCircle.cpp
+++ b/src/algorithm/MinimumBoundingCircle.cpp
@@ -213,7 +213,8 @@ MinimumBoundingCircle::computeCirclePoints()
* at most <tt>pts.length</tt> iterations are required to terminate
* with a correct result.
- for (auto p: pts) {
+ size_t i = 0, n = pts.size();
+ while (i++ < n) {
Coordinate R = pointWithMinAngleWithSegment(pts, P, Q);
// if PRQ is obtuse, then MBC is determined by P and Q
diff --git a/tests/xmltester/makefile.vc b/tests/xmltester/makefile.vc
index 340871b..0000000
--- a/tests/xmltester/makefile.vc
+++ /dev/null
@@ -1,77 +0,0 @@
-GEOS_ROOT=../..
-!IFNDEF XMLTESTER
-XMLTESTER=xmltester.exe
-!ENDIF
-SAFE_XMLTESTS= \
- $(GEOS_ROOT)/tests/xmltester/tests/testLeaksBig.xml \
- $(GEOS_ROOT)/tests/xmltester/tests/split.xml \
- $(GEOS_ROOT)/tests/xmltester/tests/hexwkb.xml \
- $(GEOS_ROOT)/tests/xmltester/tests/test.xml \
- $(GEOS_ROOT)/tests/xmltester/tests/linemerge.xml \
- $(GEOS_ROOT)/tests/xmltester/tests/TestIsValid.xml \
- $(GEOS_ROOT)/tests/xmltester/tests/robustness.xml \
- $(GEOS_ROOT)/tests/xmltester/tests/singlesidedbuffer.xml \
- $(GEOS_ROOT)/tests/xmltester/tests/bug176.xml \
- $(GEOS_ROOT)/tests/xmltester/tests/bug188.xml \
- $(GEOS_ROOT)/tests/xmltester/tests/bug244.xml \
- $(GEOS_ROOT)/tests/xmltester/tests/bug275.xml \
- $(GEOS_ROOT)/tests/xmltester/tests/general/TestBoundary.xml \
- $(GEOS_ROOT)/tests/xmltester/tests/general/TestBuffer.xml \
- $(GEOS_ROOT)/tests/xmltester/tests/general/TestBufferMitredJoin.xml \
- $(GEOS_ROOT)/tests/xmltester/tests/general/TestCentroid.xml \
- $(GEOS_ROOT)/tests/xmltester/tests/general/TestConvexHull.xml \
- $(GEOS_ROOT)/tests/xmltester/tests/general/TestConvexHull-big.xml \
- $(GEOS_ROOT)/tests/xmltester/tests/general/TestFunctionAAPrec.xml \
- $(GEOS_ROOT)/tests/xmltester/tests/general/TestFunctionAA.xml \
- $(GEOS_ROOT)/tests/xmltester/tests/general/TestFunctionLAPrec.xml \
- $(GEOS_ROOT)/tests/xmltester/tests/general/TestFunctionLA.xml \
- $(GEOS_ROOT)/tests/xmltester/tests/general/TestFunctionLLPrec.xml \
- $(GEOS_ROOT)/tests/xmltester/tests/general/TestFunctionLL.xml \
- $(GEOS_ROOT)/tests/xmltester/tests/general/TestFunctionPA.xml \
- $(GEOS_ROOT)/tests/xmltester/tests/general/TestFunctionPLPrec.xml \
- $(GEOS_ROOT)/tests/xmltester/tests/general/TestFunctionPL.xml \
- $(GEOS_ROOT)/tests/xmltester/tests/general/TestFunctionPP.xml \
- $(GEOS_ROOT)/tests/xmltester/tests/general/TestInteriorPoint.xml \
- $(GEOS_ROOT)/tests/xmltester/tests/general/TestRectanglePredicate.xml \
- $(GEOS_ROOT)/tests/xmltester/tests/general/TestRelateAA.xml \
- $(GEOS_ROOT)/tests/xmltester/tests/general/TestRelateLA.xml \
- $(GEOS_ROOT)/tests/xmltester/tests/general/TestRelateLL.xml \
- $(GEOS_ROOT)/tests/xmltester/tests/general/TestRelatePL.xml \
- $(GEOS_ROOT)/tests/xmltester/tests/general/TestRelateAC.xml \
- $(GEOS_ROOT)/tests/xmltester/tests/general/TestRelateLC.xml \
- $(GEOS_ROOT)/tests/xmltester/tests/general/TestRelatePA.xml \
- $(GEOS_ROOT)/tests/xmltester/tests/general/TestRelatePP.xml \
- $(GEOS_ROOT)/tests/xmltester/tests/general/TestSimple.xml \
- $(GEOS_ROOT)/tests/xmltester/tests/general/TestValid.xml \
- $(GEOS_ROOT)/tests/xmltester/tests/general/TestValid2.xml \
- $(GEOS_ROOT)/tests/xmltester/tests/general/TestValid2-big.xml \
- $(GEOS_ROOT)/tests/xmltester/tests/general/TestWithinDistance.xml \
- $(GEOS_ROOT)/tests/xmltester/tests/stmlf/stmlf-cases-20061020.xml \
- $(GEOS_ROOT)/tests/xmltester/tests/stmlf/stmlf-cases-20070119.xml \
- $(GEOS_ROOT)/tests/xmltester/tests/robust/TestRobustOverlayFixed.xml \
- $(GEOS_ROOT)/tests/xmltester/tests/robust/TestRobustRelate.xml \
- $(GEOS_ROOT)/tests/xmltester/tests/fme.xml \
- $(GEOS_ROOT)/tests/xmltester/tests/TestBufferExternal.xml \
- $(GEOS_ROOT)/tests/xmltester/tests/TestBufferExternal2.xml \
- $(GEOS_ROOT)/tests/xmltester/tests/heisenbugs.xml \
- $(GEOS_ROOT)/tests/xmltester/tests/badguy3.xml \
- $(GEOS_ROOT)/tests/xmltester/tests/hole_from_shell.xml \
- $(GEOS_ROOT)/tests/xmltester/tests/hole_red.xml \
- $(GEOS_ROOT)/tests/xmltester/tests/safe/16595.xml \
- $(GEOS_ROOT)/tests/xmltester/tests/safe/16596.xml
-all:
- @echo Usage:
- @echo 1) Run XMLTester.exe program from current directory:
- @echo " nmake /f makefile.vc"
- @echo 2) Run XMLTester.exe program from specified location:
- @echo " nmake /f makefile.vc XMLTESTER=C:\path\to\XMLTester.exe"
- @echo
-test:
- @echo ====== Running GEOX XMLTester test cases ======
- @echo ====== XMLTester program: $(XMLTESTER)
- @for %t in ( $(SAFE_XMLTESTS) ) do \
- $(XMLTESTER) %t
Summary of changes:
Makefile.am | 4 +-
include/geos/Makefile.am | 2 +-
include/geos/algorithm/Makefile.am | 1 +
include/geos/noding/IntersectionAdder.h | 4 +-
include/geos/version.h.vc | 48 --------------------
makefile.vc | 31 -------------
src/Makefile.am | 2 +-
src/algorithm/MinimumBoundingCircle.cpp | 3 +-
tests/xmltester/makefile.vc | 77 ---------------------------------
9 files changed, 9 insertions(+), 163 deletions(-)
delete mode 100644 include/geos/version.h.vc
delete mode 100644 makefile.vc
delete mode 100644 tests/xmltester/makefile.vc
hooks/post-receive
More information about the geos-commits
