[geos-commits] [SCM] GEOS branch master updated. 37b405f4f7cf133c6833dd78dcac5501d861b8e8
git at osgeo.org
git at osgeo.org
Wed Jan 30 11:57:03 PST 2019
the project "GEOS".
via 37b405f4f7cf133c6833dd78dcac5501d861b8e8 (commit)
from 2e24b8ed7ba1a670318efb0526fb3392a0f44685 (commit)
revisions in full, below.
commit 37b405f4f7cf133c6833dd78dcac5501d861b8e8
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Wed Jan 30 11:56:39 2019 -0800
Quiet warnings, enable ASM build for win64?
diff --git a/include/geos/algorithm/CGAlgorithmsDD.h b/include/geos/algorithm/CGAlgorithmsDD.h
index 9ff8cff..3c46b23 100644
--- a/include/geos/algorithm/CGAlgorithmsDD.h
+++ b/include/geos/algorithm/CGAlgorithmsDD.h
@@ -22,6 +22,7 @@
#include <geos/algorithm/ttmath/ttmath.h>
// Close to DoubleDouble equivalent used by JTS
+// Usage: ttmath::Big<exponent, mantissa>
typedef ttmath::Big<TTMATH_BITS(32), TTMATH_BITS(128)> DD;
//typedef ttmath::Big<TTMATH_BITS(64), TTMATH_BITS(128)> DD;
//typedef ttmath::Big<TTMATH_BITS(32), TTMATH_BITS(256)> DD;
diff --git a/include/geos/algorithm/ttmath/Makefile.am b/include/geos/algorithm/ttmath/Makefile.am
index 7ed4dc9..e60a3bf 100644
--- a/include/geos/algorithm/ttmath/Makefile.am
+++ b/include/geos/algorithm/ttmath/Makefile.am
@@ -20,4 +20,5 @@ geos_HEADERS = \
ttmathuint.h \
ttmathuint_noasm.h \
ttmathuint_x86.h \
- ttmathuint_x86_64.h
+ ttmathuint_x86_64.h \
+ ttmathuint_x86_64_msvc.asm
diff --git a/include/geos/geom/util/GeometryTransformer.h b/include/geos/geom/util/GeometryTransformer.h
index cff3ea0..c26ac56 100644
--- a/include/geos/geom/util/GeometryTransformer.h
+++ b/include/geos/geom/util/GeometryTransformer.h
@@ -173,7 +173,7 @@ private:
* <code>true</code> if the output from a collection argument should still be a collection
- bool preserveCollections;
+ // bool preserveCollections;
* <code>true</code> if the type of the input should be preserved
diff --git a/src/CMakeLists.txt b/src/CMakeLists.txt
index 30a8426..323f2d9 100644
--- a/src/CMakeLists.txt
+++ b/src/CMakeLists.txt
@@ -15,7 +15,7 @@ file(GLOB_RECURSE geos_SOURCES ${CMAKE_CURRENT_SOURCE_DIR}/*.cpp)
file(GLOB_RECURSE geos_ALL_HEADERS ${CMAKE_SOURCE_DIR}/include/*.h) # fix source_group issue
# Building with Visual C++ x86_64 needs to compile the asm utilities first
-if (MSVC AND ("x${CMAKE_VS_PLATFORM_NAME}" STREQUAL "xx64"))
+if (MSVC AND ("x${CMAKE_VS_PLATFORM_NAME}" STREQUAL "x64"))
set(TTMATH_MSVC64_ASM ttmathuint_x86_64_msvc.asm)
enable_language(ASM_MASM)
message(STATUS "Enabled MASM to compile '${TTMATH_MSVC64_ASM}'")
diff --git a/src/geom/util/GeometryTransformer.cpp b/src/geom/util/GeometryTransformer.cpp
index 47e3dbc..cf95b5d 100644
--- a/src/geom/util/GeometryTransformer.cpp
+++ b/src/geom/util/GeometryTransformer.cpp
@@ -58,7 +58,7 @@ GeometryTransformer::GeometryTransformer()
inputGeom(nullptr),
pruneEmptyGeometry(true),
preserveGeometryCollectionType(true),
- preserveCollections(false),
+ // preserveCollections(false),
preserveType(false),
skipTransformedInvalidInteriorRings(false)
diff --git a/src/index/quadtree/Node.cpp b/src/index/quadtree/Node.cpp
index 20a3525..0268b93 100644
--- a/src/index/quadtree/Node.cpp
+++ b/src/index/quadtree/Node.cpp
@@ -24,6 +24,7 @@
#include <string>
#include <sstream>
#include <cassert>
+#include <memory>
#ifndef GEOS_DEBUG
#define GEOS_DEBUG 0
@@ -47,9 +48,9 @@ Node::createNode(const Envelope& env)
Key key(env);
std::unique_ptr<Envelope> envelope(new Envelope(key.getEnvelope()));
std::unique_ptr<Node> node (
- new Node(std::move(envelope), key.getLevel())
+ new Node(std::move(envelope), key.getLevel())
- return std::move(node);
+ return node;
/* static public */
Summary of changes:
include/geos/algorithm/CGAlgorithmsDD.h | 1 +
include/geos/algorithm/ttmath/Makefile.am | 3 ++-
include/geos/geom/util/GeometryTransformer.h | 2 +-
src/CMakeLists.txt | 2 +-
src/geom/util/GeometryTransformer.cpp | 2 +-
src/index/quadtree/Node.cpp | 5 +++--
6 files changed, 9 insertions(+), 6 deletions(-)
hooks/post-receive
More information about the geos-commits
