[geos-commits] [SCM] GEOS branch master updated. f7315189af5400fb6e4e2cfd2595ac2584e647be
git at osgeo.org
git at osgeo.org
Thu Jun 6 06:04:36 PDT 2019
the project "GEOS".
via f7315189af5400fb6e4e2cfd2595ac2584e647be (commit)
via 0dde4c4991fdd918b25ba1630e3eb7e7da79404d (commit)
from 5de2e8b66796c847050cf8ec4bd5c94234df0a86 (commit)
revisions in full, below.
commit f7315189af5400fb6e4e2cfd2595ac2584e647be
Author: Daniel Baston <dbaston at gmail.com>
Date: Wed Jun 5 14:29:25 2019 -0400
Remove additional unnecessary Coordinate copies
Located by checking usages of CoordinateSequence::getAt(size_t,
Coordinate&);
diff --git a/include/geos/operation/predicate/SegmentIntersectionTester.h b/include/geos/operation/predicate/SegmentIntersectionTester.h
index 3a4d49c..877419c 100644
--- a/include/geos/operation/predicate/SegmentIntersectionTester.h
+++ b/include/geos/operation/predicate/SegmentIntersectionTester.h
@@ -57,12 +57,6 @@ private:
bool hasIntersectionVar;
- geom::Coordinate pt10;
- geom::Coordinate pt11;
- geom::Coordinate pt00;
- geom::Coordinate pt01;
public:
SegmentIntersectionTester(): hasIntersectionVar(false) {}
diff --git a/src/operation/distance/FacetSequence.cpp b/src/operation/distance/FacetSequence.cpp
index 0d2e9ab..6633e81 100644
--- a/src/operation/distance/FacetSequence.cpp
+++ b/src/operation/distance/FacetSequence.cpp
@@ -87,22 +87,21 @@ FacetSequence::distance(const FacetSequence& facetSeq) const
std::vector<GeometryLocation>
FacetSequence::nearestLocations(const FacetSequence& facetSeq) const
- Coordinate pt, seqPt;
bool isPointThis = isPoint();
bool isPointOther = facetSeq.isPoint();
std::vector<GeometryLocation> locs;
if (isPointThis && isPointOther) {
- pts->getAt(start, pt);
- facetSeq.pts->getAt(facetSeq.start, seqPt);
+ const Coordinate& pt = pts->getAt(start);
+ const Coordinate& seqPt = facetSeq.pts->getAt(facetSeq.start);
GeometryLocation gl1(geom, start, pt);
GeometryLocation gl2(facetSeq.geom, facetSeq.start, seqPt);
else if (isPointThis) {
computeDistancePointLine(pt, facetSeq, &locs);
else if (isPointOther) {
computeDistancePointLine(seqPt, *this, &locs);
// unflip the locations
GeometryLocation tmp = locs[0];
@@ -122,12 +121,10 @@ FacetSequence::computeDistancePointLine(const Coordinate& pt,
double minDistance = std::numeric_limits<double>::infinity();
double dist;
- Coordinate q0;
- Coordinate q1;
for(size_t i = facetSeq.start; i < facetSeq.end - 1; i++) {
- facetSeq.pts->getAt(i, q0);
- facetSeq.pts->getAt(i + 1, q1);
+ const Coordinate& q0 = facetSeq.pts->getAt(i);
+ const Coordinate& q1 = facetSeq.pts->getAt(i + 1);
dist = Distance::pointToSegment(pt, q0, q1);
if(dist == 0.0) {
return dist;
@@ -168,15 +165,14 @@ FacetSequence::computeDistanceLineLine(const FacetSequence& facetSeq, std::vecto
double dist;
- Coordinate p0, p1, q0, q1;
for(size_t i = start; i < end - 1; i++) {
- pts->getAt(i, p0);
- pts->getAt(i + 1, p1);
+ const Coordinate& p0 = pts->getAt(i);
+ const Coordinate& p1 = pts->getAt(i + 1);
for(size_t j = facetSeq.start; j < facetSeq.end - 1; j++) {
- facetSeq.pts->getAt(j, q0);
- facetSeq.pts->getAt(j + 1, q1);
+ const Coordinate& q0 = facetSeq.pts->getAt(j);
+ const Coordinate& q1 = facetSeq.pts->getAt(j + 1);
dist = Distance::segmentToSegment(p0, p1, q0, q1);
if(dist <= minDistance) {
diff --git a/src/operation/intersection/RectangleIntersectionBuilder.cpp b/src/operation/intersection/RectangleIntersectionBuilder.cpp
index 0d0c105..daf8b6c 100644
--- a/src/operation/intersection/RectangleIntersectionBuilder.cpp
+++ b/src/operation/intersection/RectangleIntersectionBuilder.cpp
@@ -487,8 +487,7 @@ RectangleIntersectionBuilder::reconnectPolygons(const Rectangle& rect)
else {
using geos::algorithm::PointLocation;
- geom::Coordinate c;
- hole->getCoordinatesRO()->getAt(0, c);
+ const geom::Coordinate& c = hole->getCoordinatesRO()->getAt(0);
for(ShellAndHolesList::iterator p_i = exterior.begin(), p_e = exterior.end(); p_i != p_e; ++p_i) {
ShellAndHoles& p = *p_i;
const CoordinateSequence* shell_cs = p.first->getCoordinatesRO();
diff --git a/src/operation/predicate/SegmentIntersectionTester.cpp b/src/operation/predicate/SegmentIntersectionTester.cpp
index 1b503d3..e2250c7 100644
--- a/src/operation/predicate/SegmentIntersectionTester.cpp
+++ b/src/operation/predicate/SegmentIntersectionTester.cpp
@@ -57,12 +57,12 @@ SegmentIntersectionTester::hasIntersection(
size_type seq1size = seq1.getSize();
for(size_type i = 1; i < seq0size && !hasIntersectionVar; ++i) {
- seq0.getAt(i - 1, pt00);
- seq0.getAt(i, pt01);
+ const Coordinate& pt00 = seq0.getAt(i - 1);
+ const Coordinate& pt01 = seq0.getAt(i);
for(size_type j = 1; j < seq1size && !hasIntersectionVar; ++j) {
- seq1.getAt(j - 1, pt10);
- seq1.getAt(j, pt11);
+ const Coordinate& pt10 = seq1.getAt(j - 1);
+ const Coordinate& pt11 = seq1.getAt(j);
li.computeIntersection(pt00, pt01, pt10, pt11);
if(li.hasIntersection()) {
@@ -91,8 +91,8 @@ SegmentIntersectionTester::hasIntersectionWithEnvelopeFilter(
typedef std::size_t size_type;
for(size_type i = 1; i < seq1size && !hasIntersectionVar; ++i) {
- seq1.getAt(i - 1, pt10);
- seq1.getAt(i, pt11);
+ const Coordinate& pt10 = seq1.getAt(i - 1);
+ const Coordinate& pt11 = seq1.getAt(i);
// skip test if segment does not intersect query envelope
if(! lineEnv->intersects(Envelope(pt10, pt11))) {
@@ -100,8 +100,8 @@ SegmentIntersectionTester::hasIntersectionWithEnvelopeFilter(
for(size_type j = 1; j < seq0size && !hasIntersectionVar; ++j) {
- seq0.getAt(j - 1, pt00);
- seq0.getAt(j, pt01);
+ const Coordinate& pt00 = seq0.getAt(j - 1);
+ const Coordinate& pt01 = seq0.getAt(j);
commit 0dde4c4991fdd918b25ba1630e3eb7e7da79404d
Date: Wed Jun 5 14:16:03 2019 -0400
Remove some unnecessary Coordinate copies
Located using a quick check of egrep -Rn "Coordinate .*="
diff --git a/src/algorithm/LineIntersector.cpp b/src/algorithm/LineIntersector.cpp
index 2be486f..e928e5b 100644
--- a/src/algorithm/LineIntersector.cpp
+++ b/src/algorithm/LineIntersector.cpp
@@ -77,25 +77,25 @@ Coordinate
nearestEndpoint(const Coordinate& p1, const Coordinate& p2,
const Coordinate& q1, const Coordinate& q2)
- Coordinate nearestPt = p1;
+ const Coordinate* nearestPt = &p1;
double minDist = Distance::pointToSegment(p1, q1, q2);
double dist = Distance::pointToSegment(p2, q1, q2);
if(dist < minDist) {
minDist = dist;
- nearestPt = p2;
+ nearestPt = &p2;
dist = Distance::pointToSegment(q1, p1, p2);
minDist = dist;
- nearestPt = q1;
+ nearestPt = &q1;
dist = Distance::pointToSegment(q2, p1, p2);
minDist = dist;
- nearestPt = q2;
+ nearestPt = &q2;
- return nearestPt;
+ return *nearestPt;
diff --git a/src/geom/CoordinateSequence.cpp b/src/geom/CoordinateSequence.cpp
index ba942ad..00985cb 100644
--- a/src/geom/CoordinateSequence.cpp
+++ b/src/geom/CoordinateSequence.cpp
@@ -145,7 +145,6 @@ CoordinateSequence::increasingDirection(const CoordinateSequence& pts)
void
CoordinateSequence::reverse(CoordinateSequence* cl)
// FIXME: use a standard algorithm
auto last = cl->size() - 1;
auto mid = last / 2;
diff --git a/src/geom/prep/PreparedLineStringIntersects.cpp b/src/geom/prep/PreparedLineStringIntersects.cpp
index 0e9189a..4d128ba 100644
--- a/src/geom/prep/PreparedLineStringIntersects.cpp
+++ b/src/geom/prep/PreparedLineStringIntersects.cpp
@@ -45,7 +45,7 @@ PreparedLineStringIntersects::isAnyTestPointInTarget(const geom::Geometry* testG
ComponentCoordinateExtracter::getCoordinates(*testGeom, coords);
for(size_t i = 0, n = coords.size(); i < n; i++) {
- geom::Coordinate c = *(coords[i]);
+ const geom::Coordinate& c = *(coords[i]);
if(locator.intersects(c, &(prepLine.getGeometry()))) {
return true;
index 5729ca4..0d2e9ab 100644
@@ -62,16 +62,16 @@ FacetSequence::distance(const FacetSequence& facetSeq) const
if(isPointThis && isPointOther) {
- Coordinate pt = pts->getAt(start);
- Coordinate seqPt = facetSeq.pts->getAt(facetSeq.start);
return pt.distance(seqPt);
else if(isPointThis) {
return computeDistancePointLine(pt, facetSeq, nullptr);
else if(isPointOther) {
return computeDistancePointLine(seqPt, *this, nullptr);
else {
diff --git a/src/operation/overlay/PolygonBuilder.cpp b/src/operation/overlay/PolygonBuilder.cpp
index 38a12d8..551c7e1 100644
--- a/src/operation/overlay/PolygonBuilder.cpp
+++ b/src/operation/overlay/PolygonBuilder.cpp
@@ -339,7 +339,7 @@ PolygonBuilder::findEdgeRingContaining(EdgeRing* testEr,
const CoordinateSequence* tsrcs = tryShellRing->getCoordinatesRO();
- Coordinate testPt = operation::polygonize::EdgeRing::ptNotInList(testRing->getCoordinatesRO(), tsrcs);
+ const Coordinate& testPt = operation::polygonize::EdgeRing::ptNotInList(testRing->getCoordinatesRO(), tsrcs);
bool isContained = false;
if(tryShell.pipLocator->locate(&testPt) != Location::EXTERIOR) {
diff --git a/src/operation/polygonize/EdgeRing.cpp b/src/operation/polygonize/EdgeRing.cpp
index dc223ec..f6d998e 100644
--- a/src/operation/polygonize/EdgeRing.cpp
+++ b/src/operation/polygonize/EdgeRing.cpp
@@ -75,7 +75,7 @@ EdgeRing::findEdgeRingContaining(const std::vector<EdgeRing*> & erList)
auto tryCoords = tryRing->getCoordinatesRO();
- Coordinate testPt = ptNotInList(testRing->getCoordinatesRO(), tryCoords); // TODO: don't copy testPt !
+ const Coordinate& testPt = ptNotInList(testRing->getCoordinatesRO(), tryCoords);
// check if this new containing ring is smaller than the current minimum ring
if(tryEdgeRing->isInRing(testPt)) {
diff --git a/src/precision/PrecisionReducerCoordinateOperation.cpp b/src/precision/PrecisionReducerCoordinateOperation.cpp
index 2c710ff..b907f6f 100644
--- a/src/precision/PrecisionReducerCoordinateOperation.cpp
+++ b/src/precision/PrecisionReducerCoordinateOperation.cpp
@@ -48,9 +48,8 @@ PrecisionReducerCoordinateOperation::edit(const CoordinateSequence* cs,
// copy coordinates and reduce
for(size_t i = 0; i < csSize; ++i) {
- Coordinate coord = cs->getAt(i);
- targetPM.makePrecise(&coord);
- (*vc)[i] = coord;
+ (*vc)[i] = cs->getAt(i);
+ targetPM.makePrecise((*vc)[i]);
// reducedCoords take ownership of 'vc'
diff --git a/src/precision/SimpleGeometryPrecisionReducer.cpp b/src/precision/SimpleGeometryPrecisionReducer.cpp
index 3be653b..9ab876a 100644
--- a/src/precision/SimpleGeometryPrecisionReducer.cpp
+++ b/src/precision/SimpleGeometryPrecisionReducer.cpp
@@ -78,10 +78,8 @@ PrecisionReducerCoordinateOperation::edit(const CoordinateSequence* cs,
for(unsigned int i = 0; i < csSize; ++i) {
- sgpr->getPrecisionModel()->makePrecise(&coord);
- //reducedCoords->setAt(*coord,i);
- (*vc)[i] = coord;
+ sgpr->getPrecisionModel()->makePrecise((*vc)[i]);
Summary of changes:
.../predicate/SegmentIntersectionTester.h | 6 ----
src/algorithm/LineIntersector.cpp | 10 +++----
src/geom/CoordinateSequence.cpp | 1 -
src/geom/prep/PreparedLineStringIntersects.cpp | 2 +-
src/operation/distance/FacetSequence.cpp | 32 ++++++++++------------
.../intersection/RectangleIntersectionBuilder.cpp | 3 +-
src/operation/overlay/PolygonBuilder.cpp | 2 +-
src/operation/polygonize/EdgeRing.cpp | 2 +-
.../predicate/SegmentIntersectionTester.cpp | 16 +++++------
.../PrecisionReducerCoordinateOperation.cpp | 5 ++--
src/precision/SimpleGeometryPrecisionReducer.cpp | 6 ++--
11 files changed, 35 insertions(+), 50 deletions(-)
hooks/post-receive
More information about the geos-commits
