[geos-commits] [SCM] GEOS branch master updated. 5ee72f3fa7232c23eec10f5dd7ba3e0560bfc4d0
git at osgeo.org
git at osgeo.org
Sat Jun 15 07:40:38 PDT 2019
the project "GEOS".
via 5ee72f3fa7232c23eec10f5dd7ba3e0560bfc4d0 (commit)
from 0817209fb4347e9dd265b2c37c252c94b1dd0941 (commit)
revisions in full, below.
commit 5ee72f3fa7232c23eec10f5dd7ba3e0560bfc4d0
Author: Sandro Santilli <strk at kbt.io>
Date: Sat Jun 15 16:40:23 2019 +0200
Update dronie badges to use 1.0
diff --git a/README.md b/README.md
index 9488768..acaba8b 100644
--- a/README.md
+++ b/README.md
@@ -14,9 +14,9 @@ More information is available the [project homepage](https://trac.osgeo.org/geos
| branch / CI | Debbie | Winnie | Dronie | Travis CI | GitLab CI | AppVeyor | Bessie | Bessie32 |
-| master | [](https://debbie.postgis.net/view/GEOS/job/GEOS_Master/) | [](https://winnie.postgis.net:444/view/GEOS/job/GEOS_Master/) | [](https://drone.osgeo.org/geos/geos?branch=master) | [](https://travis-ci.com/libgeos/geos?branch=master) | [](https://gitlab.com/geos/libgeos/commits/master) | [](https://ci.appveyor.com/project/dbaston/geos/branch/master) | [](https://debbie.postgis.net/view/GEOS/job/GEOS_Worker_Run/label=bessie)
| [](https://debbie.postgis.net/view/GEOS/job/GEOS_Worker_Run/label=bessie32) ||
-| 3.7 | [](https://debbie.postgis.net/view/GEOS/job/GEOS_Branch_3.7/) | [](https://winnie.postgis.net:444/view/GEOS/job/GEOS_Branch_3.7/) | [](https://drone.osgeo.org/geos/geos?branch=3.7) | [](https://travis-ci.com/libgeos/geos?branch=3.7) | [](https://gitlab.com/geos/libgeos/commits/3.7) | [](https://ci.appveyor.com/project/dbaston/geos/branch/3.7) ||
-| 3.6 | [](https://debbie.postgis.net/view/GEOS/job/GEOS_Branch_3.6/) | [](https://winnie.postgis.net:444/view/GEOS/job/GEOS_Branch_3.6/) | [](https://drone.osgeo.org/geos/geos?branch=svn-3.6) | [](https://travis-ci.com/libgeos/geos?branch=svn-3.6) | [](https://gitlab.com/geos/libgeos/commits/svn-3.6) | [](https://ci.appveyor.com/project/dbaston/geos/branch/svn-3.6) |
+| master | [](https://debbie.postgis.net/view/GEOS/job/GEOS_Master/) | [](https://winnie.postgis.net:444/view/GEOS/job/GEOS_Master/) | [](https://dronie.osgeo.org/geos/geos?branch=master) | [](https://travis-ci.com/libgeos/geos?branch=master) | [](https://gitlab.com/geos/libgeos/commits/master) | [](https://ci.appveyor.com/project/dbaston/geos/branch/master) | [](https://debbie.postgis.net/view/GEOS/job/GEOS_Worker_Run/label=bessi
e) | [](https://debbie.postgis.net/view/GEOS/job/GEOS_Worker_Run/label=bessie32) ||
+| 3.7 | [](https://debbie.postgis.net/view/GEOS/job/GEOS_Branch_3.7/) | [](https://winnie.postgis.net:444/view/GEOS/job/GEOS_Branch_3.7/) | [](https://dronie.osgeo.org/geos/geos?branch=3.7) | [](https://travis-ci.com/libgeos/geos?branch=3.7) | [](https://gitlab.com/geos/libgeos/commits/3.7) | [](https://ci.appveyor.com/project/dbaston/geos/branch/3.7) ||
+| 3.6 | [](https://debbie.postgis.net/view/GEOS/job/GEOS_Branch_3.6/) | [](https://winnie.postgis.net:444/view/GEOS/job/GEOS_Branch_3.6/) | [](https://dronie.osgeo.org/geos/geos?branch=svn-3.6) | [](https://travis-ci.com/libgeos/geos?branch=svn-3.6) | [](https://gitlab.com/geos/libgeos/commits/svn-3.6) | [](https://ci.appveyor.com/project/dbaston/geos/branch/svn-3.6) |
## Building GEOS From Source
@@ -126,9 +126,9 @@ linker flags for building against the C library:
All functionality of the C API is available through the `geos_c.h` header file.
-Documentation for the C API is provided via comments in the `geos_c.h` header
-file. C API usage examples can be found in the GEOS unit tests and in the
-source code of software that uses GEOS, such as PostGIS and the sf package
+Documentation for the C API is provided via comments in the `geos_c.h` header
+file. C API usage examples can be found in the GEOS unit tests and in the
+source code of software that uses GEOS, such as PostGIS and the sf package
for R.
### Using the C++ interface
@@ -148,17 +148,17 @@ linker flags for building against the C++ library:
CFLAGS += `geos-config --cflags`
LDFLAGS += `geos-config --ldflags` -lgeos
-A compiler warning may be issued when building against the C++ library. To
-remove the compiler warning, define `USE_UNSTABLE_GEOS_CPP_API` somewhere
+A compiler warning may be issued when building against the C++ library. To
+remove the compiler warning, define `USE_UNSTABLE_GEOS_CPP_API` somewhere
in the program.
-Commonly-used functionality of GEOS is available in the `geos.h` header file.
-Less-common functionality can be accessed by including headers for individual
+Commonly-used functionality of GEOS is available in the `geos.h` header file.
+Less-common functionality can be accessed by including headers for individual
classes, e.g. `#include <geos/algorithm/distance/DiscreteHausdorffDistance.h>`.
#include <geos.h>
-Documentation for the C++ API is available at https://geos.osgeo.org/doxygen/,
+Documentation for the C++ API is available at https://geos.osgeo.org/doxygen/,
and basic C++ usage examples can be found in `doc/example.cpp`.
@@ -173,7 +173,7 @@ when configuring:
#### PHP
-PHP bindings for GEOS are available separately from
+PHP bindings for GEOS are available separately from
[php-geos](https://git.osgeo.org/gitea/geos/php-geos).
#### Python
Summary of changes:
README.md | 24 ++++++++++++------------
1 file changed, 12 insertions(+), 12 deletions(-)
hooks/post-receive
More information about the geos-commits
