[geos-commits] [SCM] GEOS branch master updated. d924cc7121cca892b1ee550b7cc6e91c6caf34bb
git at osgeo.org
git at osgeo.org
Wed Jun 19 23:16:54 PDT 2019
the project "GEOS".
via d924cc7121cca892b1ee550b7cc6e91c6caf34bb (commit)
via 84fdaf6a7e2303bc6b0718f665344f923c816827 (commit)
from 386a948d15bd0bde676e6d4a65e375d974d011a7 (commit)
revisions in full, below.
commit d924cc7121cca892b1ee550b7cc6e91c6caf34bb
Author: nila <n_larsson at yahoo.com>
Date: Wed Jun 19 20:05:00 2019 +0200
Move GEOS_DLL macro to beginning of declaration
diff --git a/include/geos/geom/Location.h b/include/geos/geom/Location.h
index 896a4dd..050b9d4 100644
--- a/include/geos/geom/Location.h
+++ b/include/geos/geom/Location.h
@@ -24,14 +24,13 @@ namespace geos {
namespace geom { // geos::geom
/** \brief
- * Constants representing the location of a point relative to a geometry.
+ * Constants representing the location of a point relative to a geometry.
- * They can also be thought of as the row or column index of a DE-9IM matrix.
- * For a description of the DE-9IM, see the <A
- * HREF="http://www.opengis.org/techno/specs.htm">OpenGIS Simple Features
- * Specification for SQL</A> .
+ * They can also be thought of as the row or column index of a DE-9IM matrix.
+ * For a description of the DE-9IM, see the
+ * [OpenGIS Simple Features Specification for SQL](http://www.opengis.org/techno/specs.htm").
-enum class GEOS_DLL Location : char {
+GEOS_DLL enum class Location : char {
* Used for uninitialized location values.
commit 84fdaf6a7e2303bc6b0718f665344f923c816827
Date: Wed Jun 19 19:54:02 2019 +0200
Fix broken doxygen links as a result of removal of Puntal, Lineal, and Polygonal classes
diff --git a/include/geos/algorithm/BoundaryNodeRule.h b/include/geos/algorithm/BoundaryNodeRule.h
index 85e4827..6391388 100644
--- a/include/geos/algorithm/BoundaryNodeRule.h
+++ b/include/geos/algorithm/BoundaryNodeRule.h
@@ -30,7 +30,7 @@ namespace algorithm { // geos::algorithm
/** \brief
* An interface for rules which determine whether node points which are
- * in boundaries of [Lineal](@ref geom::Lineal) geometry components
+ * in boundaries of lineal geometry components
* are in the boundary of the parent geometry collection.
* The SFS specifies a single kind of boundary node rule,
diff --git a/include/geos/algorithm/RayCrossingCounter.h b/include/geos/algorithm/RayCrossingCounter.h
index 1181013..ce2df3f 100644
--- a/include/geos/algorithm/RayCrossingCounter.h
+++ b/include/geos/algorithm/RayCrossingCounter.h
@@ -41,11 +41,10 @@ namespace algorithm {
* Counts the number of segments crossed by a horizontal ray extending to the
* right from a given point, in an incremental fashion.
- * This can be used to determine whether a point lies in a
- * [Polygonal](@ref geom::Polygonal) geometry. The class determines
- * the situation where the point lies exactly on a segment. When being
- * used for Point-In-Polygon determination, this case allows short-circuiting
- * the evaluation.
+ * This can be used to determine whether a point lies in a polygonal geometry.
+ * The class determines the situation where the point lies exactly on a segment.
+ * When being used for Point-In-Polygon determination, this case allows
+ * short-circuiting the evaluation.
* This class handles polygonal geometries with any number of shells and holes.
* The orientation of the shell and hole rings is unimportant.
@@ -57,13 +56,11 @@ namespace algorithm {
* The only exception is when the point-on-segment situation is detected, in
* which case no further processing is required.
- * The implication of the above rule is that segments
- * which can be a priori determined to *not* touch the ray
- * (i.e. by a test of their bounding box or Y-extent)
- * do not need to be counted. This allows for optimization by indexing.
+ * The implication of the above rule is that segments which can be a priori
+ * determined to *not* touch the ray (i.e. by a test of their bounding box or
+ * Y-extent) do not need to be counted. This allows for optimization by indexing.
* @author Martin Davis
class GEOS_DLL RayCrossingCounter {
private:
@@ -96,7 +93,7 @@ public:
const std::vector<const geom::Coordinate*>& ring);
RayCrossingCounter(const geom::Coordinate& p_point)
- : point(p_point),
+ : point(p_point),
crossingCount(0),
isPointOnSegment(false)
diff --git a/include/geos/algorithm/RayCrossingCounterDD.h b/include/geos/algorithm/RayCrossingCounterDD.h
index 2cb4f84..2328ab3 100644
--- a/include/geos/algorithm/RayCrossingCounterDD.h
+++ b/include/geos/algorithm/RayCrossingCounterDD.h
@@ -42,11 +42,10 @@ namespace algorithm {
* the right from a given point, in an incremental fashion.
- * the situation where the point lies exactly on a segment. When being used
- * for Point-In-Polygon determination, this case allows short-circuiting
- * the evaluation.
diff --git a/include/geos/algorithm/locate/IndexedPointInAreaLocator.h b/include/geos/algorithm/locate/IndexedPointInAreaLocator.h
index f1dc458..f66b9a4 100644
--- a/include/geos/algorithm/locate/IndexedPointInAreaLocator.h
+++ b/include/geos/algorithm/locate/IndexedPointInAreaLocator.h
@@ -41,15 +41,13 @@ namespace algorithm { // geos::algorithm
namespace locate { // geos::algorithm::locate
/** \brief
- * Determines the location of {@link geom::Coordinate}s relative to
+ * Determines the location of [Coordinates](@ref geom::Coordinate) relative to
* an areal geometry, using indexing for efficiency.
- * The Location is computed precisely, in that points
- * located on the geometry boundary or segments will
- * return {@link geom::Location.BOUNDARY}.
+ * The Location is computed precisely, in that points located on the geometry boundary
+ * or segments will return [Location::BOUNDARY](@ref geom::Location::BOUNDARY).
- * {@link geom::Polygonal} and {@link geom::LinearRing} geometries
- * are supported.
+ * Polygonal and [LinearRing](@ref geom::LinearRing) geometries are supported.
class IndexedPointInAreaLocator : public PointOnGeometryLocator {
private:
@@ -96,18 +94,18 @@ private:
IndexedPointInAreaLocator& operator=(const IndexedPointInAreaLocator& rhs) = delete;
public:
- * Creates a new locator for a given {@link geom::Geometry}
- * are supported.
+ /** \brief
+ * Creates a new locator for a given [Geometry](@ref geom::Geometry).
* @param g the Geometry to locate in
IndexedPointInAreaLocator(const geom::Geometry& g);
- * Determines the {@link geom::Location} of a point in an areal
- * {@link geom::Geometry}.
+ /** \brief
+ * Determines the [Location](@ref geom::Location) of a point in an areal
+ * [Geometry](@ref geom::Geometry).
* @param p the point to test
* @return the location of the point in the geometry
diff --git a/include/geos/algorithm/locate/SimplePointInAreaLocator.h b/include/geos/algorithm/locate/SimplePointInAreaLocator.h
index d1e84ef..8f0bd04 100644
--- a/include/geos/algorithm/locate/SimplePointInAreaLocator.h
+++ b/include/geos/algorithm/locate/SimplePointInAreaLocator.h
@@ -32,7 +32,7 @@ namespace algorithm { // geos::algorithm
/** \brief
- * Computes the location of points relative to a [Polygonal](@ref geom::Polygonal)
+ * Computes the location of points relative to a polygonal
* [Geometry](@ref geom::Geometry), using a simple `O(n)` algorithm.
* The algorithm used reports if a point lies in the interior, exterior,
@@ -56,9 +56,12 @@ public:
* The return value is one of:
- * - [Location::INTERIOR](@ref geom::Location::INTERIOR) if the point is in the geometry interior
- * - [Location::BOUNDARY](@ref geom::Location::BOUNDARY) if the point lies exactly on the boundary
- * - [Location::EXTERIOR](@ref geom::Location::EXTERIOR) if the point is outside the geometry
+ * - [Location::INTERIOR](@ref geom::Location::INTERIOR)
+ * if the point is in the geometry interior
+ * - [Location::BOUNDARY](@ref geom::Location::BOUNDARY)
+ * if the point lies exactly on the boundary
+ * - [Location::EXTERIOR](@ref geom::Location::EXTERIOR)
+ * if the point is outside the geometry
* Computes `Location::BOUNDARY` if the point lies exactly
* on the polygon boundary.
@@ -76,7 +79,7 @@ public:
* This is a convenience method for
- * Location.EXTERIOR != locate(p, geom)
+ * Location::EXTERIOR != locate(p, geom)
* @param geom the geometry to test
diff --git a/include/geos/geom/Geometry.h b/include/geos/geom/Geometry.h
index 3bed163..1228743 100644
--- a/include/geos/geom/Geometry.h
+++ b/include/geos/geom/Geometry.h
@@ -251,20 +251,15 @@ public:
return _userData;
- * \brief
- * Returns the ID of the Spatial Reference System used by the
- * <code>Geometry</code>.
+ /** \brief
+ * Returns the ID of the Spatial Reference System used by the Geometry.
* GEOS supports Spatial Reference System information in the simple way
* defined in the SFS. A Spatial Reference System ID (SRID) is present
- * in each <code>Geometry</code> object. <code>Geometry</code>
- * provides basic accessor operations for this field, but no others.
- * The SRID is represented as an integer.
- * @return the ID of the coordinate space in which the
- * <code>Geometry</code> is defined.
+ * in each Geometry object. Geometry provides basic accessor operations
+ * for this field, but no others. The SRID is represented as an integer.
+ * @return the ID of the coordinate space in which the Geometry is defined.
virtual int
getSRID() const
@@ -272,9 +267,8 @@ public:
return SRID;
- * Sets the ID of the Spatial Reference System used by the
+ /** \brief
+ * Sets the ID of the Spatial Reference System used by the Geometry.
virtual void
setSRID(int newSRID)
@@ -288,10 +282,7 @@ public:
const PrecisionModel* getPrecisionModel() const;
- /// \brief
- /// Returns a vertex of this Geometry,
- /// or NULL if this is the empty geometry
+ /// Returns a vertex of this Geometry, or NULL if this is the empty geometry.
virtual const Coordinate* getCoordinate() const = 0; //Abstract
@@ -321,7 +312,7 @@ public:
return 1;
- /// Returns a pointer to the nth Geometry in this collection
+ /// \brief Returns a pointer to the nth Geometry in this collection
/// (or self if this is not a collection)
virtual const Geometry*
getGeometryN(std::size_t /*n*/) const
@@ -649,7 +640,7 @@ public:
/// all the points in the Geometry.
virtual std::unique_ptr<Geometry> convexHull() const;
+ /** \brief
* Computes a new geometry which has all component coordinate sequences
* in reverse order (opposite orientation) to this one.
@@ -680,16 +671,16 @@ public:
std::unique_ptr<Geometry> Union(const Geometry* other) const;
// throw(IllegalArgumentException *, TopologyException *);
+ /** \brief
* Computes the union of all the elements of this geometry. Heterogeneous
- * {@link GeometryCollection}s are fully supported.
+ * [GeometryCollections](@ref GeometryCollection) are fully supported.
* The result obeys the following contract:
- * - Unioning a set of {@link LineString}s has the effect of fully noding
+ * - Unioning a set of [LineStrings](@ref LineString) has the effect of fully noding
* and dissolving the linework.
- * - Unioning a set of {@link Polygon}s will always
- * return a {@link Polygonal} geometry (unlike Geometry::Union(const Geometry* other) const),
+ * - Unioning a set of [Polygons](@ref Polygon) will always
+ * return a polygonal geometry (unlike Geometry::Union(const Geometry* other) const),
* which may return geometrys of lower dimension if a topology collapse
* occurred.
diff --git a/include/geos/geom/util/GeometryCombiner.h b/include/geos/geom/util/GeometryCombiner.h
index c40ea22..4ed3b8e 100644
--- a/include/geos/geom/util/GeometryCombiner.h
+++ b/include/geos/geom/util/GeometryCombiner.h
@@ -34,20 +34,21 @@ namespace geos {
namespace geom { // geos.geom
namespace util { // geos.geom.util
- * Combines {@link Geometry}s
- * to produce a {@link GeometryCollection} of the most appropriate type.
- * Input geometries which are already collections
- * will have their elements extracted first.
+/** \brief
+ * Combines [Geometrys](@ref Geometry) to produce a GeometryCollection
+ * of the most appropriate type.
+ * Input geometries which are already collections will have their elements
+ * extracted first.
* No validation of the result geometry is performed.
- * (The only case where invalidity is possible is where {@link Polygonal}
- * geometries are combined and result in a self-intersection).
+ * (The only case where invalidity is possible is where polygonal geometries
+ * are combined and result in a self-intersection).
* @see GeometryFactory#buildGeometry
class GeometryCombiner {
public:
+ /** \brief
* Combines a collection of geometries.
* @param geoms the geometries to combine (ownership left to caller)
@@ -55,7 +56,7 @@ public:
static std::unique_ptr<Geometry> combine(std::vector<Geometry*> const& geoms);
+ /** \brief
* Combines two geometries.
* @param g0 a geometry to combine (ownership left to caller)
@@ -64,7 +65,7 @@ public:
static std::unique_ptr<Geometry> combine(const Geometry* g0, const Geometry* g1);
+ /** \brief
* Combines three geometries.
@@ -80,24 +81,24 @@ private:
std::vector<Geometry*> const& inputGeoms;
public:
- * Creates a new combiner for a collection of geometries
+ /** \brief
+ * Creates a new combiner for a collection of geometries.
GeometryCombiner(std::vector<Geometry*> const& geoms);
- * Extracts the GeometryFactory used by the geometries in a collection
+ /** \brief
+ * Extracts the GeometryFactory used by the geometries in a collection.
* @param geoms
* @return a GeometryFactory
static GeometryFactory const* extractFactory(std::vector<Geometry*> const& geoms);
+ /** \brief
* Computes the combination of the input geometries
- * to produce the most appropriate {@link Geometry} or {@link GeometryCollection}
+ * to produce the most appropriate Geometry or GeometryCollection.
* @return a Geometry which is the combination of the inputs
diff --git a/include/geos/operation/union/CascadedPolygonUnion.h b/include/geos/operation/union/CascadedPolygonUnion.h
index 638cd64..a26bd52 100644
--- a/include/geos/operation/union/CascadedPolygonUnion.h
+++ b/include/geos/operation/union/CascadedPolygonUnion.h
@@ -51,23 +51,19 @@ namespace geounion { // geos::operation::geounion
* \brief
- * Provides an efficient method of unioning a collection of
- * [Polygonal](@ref geom::Polygonal) geometries.
+ * Provides an efficient method of unioning a collection of polygonal geometries.
- * This algorithm is faster and likely more robust than
- * the simple iterated approach of
- * repeatedly unioning each polygon to a result geometry.
+ * This algorithm is faster and likely more robust than the simple iterated
+ * approach of repeatedly unioning each polygon to a result geometry.
* The `buffer(0)` trick is sometimes faster, but can be less robust and
* can sometimes take an exceptionally long time to complete.
* This is particularly the case where there is a high degree of overlap
* between the polygons. In this case, `buffer(0)` is forced to compute
- * with *all* line segments from the outset,
- * whereas cascading can eliminate many segments
- * at each stage of processing.
- * The best case for buffer(0) is the trivial case
- * where there is `no` overlap between the input geometries.
- * However, this case is likely rare in practice.
+ * with *all* line segments from the outset, whereas cascading can eliminate
+ * many segments at each stage of processing.
+ * The best case for buffer(0) is the trivial case where there is `no` overlap
+ * between the input geometries. However, this case is likely rare in practice.
class GEOS_DLL CascadedPolygonUnion {
private:
@@ -83,11 +79,11 @@ private:
static int const STRTREE_NODE_CAPACITY = 4;
- * Computes a {@link Geometry} containing only [Polygonal](@ref geom::Polygonal) components.
+ /** \brief
+ * Computes a [Geometry](@ref geom::Geometry) containing only polygonal components.
- * Extracts the {@link Polygon}s from the input
- * and returns them as an appropriate [Polygonal](@ref geom::Polygonal) geometry.
+ * Extracts the [Polygons](@ref geom::Polygon) from the input
+ * and returns them as an appropriate polygonal geometry.
* If the input is already `Polygonal`, it is returned unchanged.
@@ -103,18 +99,15 @@ public:
CascadedPolygonUnion();
/** \brief
- * Computes the union of a collection of [Polygonal](@ref geom::Polygonal)
- * [Geometrys](@ref geom::Geometry).
+ * Computes the union of a collection of polygonal [Geometrys](@ref geom::Geometry).
- * @param polys a collection of [Polygonal](@ref geom::Polygonal)
- * ownership of elements _and_ vector are left to caller.
+ * @param polys a collection of polygonal [Geometrys](@ref geom::Geometry).
+ * ownership of elements *and* vector are left to caller.
static geom::Geometry* Union(std::vector<geom::Polygon*>* polys);
/** \brief
- * Computes the union of a set of [Polygonal](@ref geom::Polygonal)
+ * Computes the union of a set of polygonal [Geometrys](@ref geom::Geometry).
* @tparam T an iterator yelding something castable to const Polygon *
* @param start start iterator
@@ -133,21 +126,18 @@ public:
/** \brief
* Ownership of elements *and* vector are left to caller.
static geom::Geometry* Union(const geom::MultiPolygon* polys);
/** \brief
- * Creates a new instance to union
- * the given collection of {@link geom::Geometry}s.
+ * Creates a new instance to union the given collection of
+ * [Geometrys](@ref geom::Geometry).
CascadedPolygonUnion(std::vector<geom::Polygon*>* polys)
diff --git a/include/geos/operation/union/PointGeometryUnion.h b/include/geos/operation/union/PointGeometryUnion.h
index f618262..3c22459 100644
--- a/include/geos/operation/union/PointGeometryUnion.h
+++ b/include/geos/operation/union/PointGeometryUnion.h
@@ -37,8 +37,8 @@ namespace geounion { // geos::operation::geounion
* \brief
- * Computes the union of a [Puntal](@ref geom::Puntal) geometry with
- * another arbitrary [Geometry](@ref geom::Geometry).
+ * Computes the union of a puntal geometry with another
+ * arbitrary [Geometry](@ref geom::Geometry).
* Does not copy any component geometries.
Summary of changes:
include/geos/algorithm/BoundaryNodeRule.h | 2 +-
include/geos/algorithm/RayCrossingCounter.h | 19 ++++----
include/geos/algorithm/RayCrossingCounterDD.h | 9 ++--
.../algorithm/locate/IndexedPointInAreaLocator.h | 26 ++++++-----
.../algorithm/locate/SimplePointInAreaLocator.h | 13 +++---
include/geos/geom/Geometry.h | 39 +++++++----------
include/geos/geom/Location.h | 11 +++--
include/geos/geom/util/GeometryCombiner.h | 33 +++++++-------
.../geos/operation/union/CascadedPolygonUnion.h | 50 +++++++++-------------
include/geos/operation/union/PointGeometryUnion.h | 4 +-
10 files changed, 92 insertions(+), 114 deletions(-)
hooks/post-receive
More information about the geos-commits
