[geos-commits] [SCM] GEOS branch master updated. 4075390d72d384a8474d5d3e60c91bfb445c1753
git at osgeo.org
git at osgeo.org
Thu Jun 20 13:06:07 PDT 2019
the project "GEOS".
via 4075390d72d384a8474d5d3e60c91bfb445c1753 (commit)
from 8b0f5862761ac62c3437be8b96286728068754d4 (commit)
revisions in full, below.
commit 4075390d72d384a8474d5d3e60c91bfb445c1753
Author: Daniel Baston <dbaston at gmail.com>
Date: Thu Jun 20 16:05:11 2019 -0400
Remove commented-out code
diff --git a/src/geom/Geometry.cpp b/src/geom/Geometry.cpp
index 823a11f..aa99659 100644
--- a/src/geom/Geometry.cpp
+++ b/src/geom/Geometry.cpp
@@ -154,8 +154,7 @@ Geometry::isWithinDistance(const Geometry* geom, double cDistance) const
const Envelope* env0 = getEnvelopeInternal();
const Envelope* env1 = geom->getEnvelopeInternal();
double envDist = env0->distance(env1);
- //delete env0;
- //delete env1;
if(envDist > cDistance) {
return false;
@@ -242,7 +241,6 @@ Geometry::geometryChanged()
void
Geometry::geometryChangedAction()
- //delete envelope;
envelope.reset(nullptr);
diff --git a/src/geom/LineString.cpp b/src/geom/LineString.cpp
index be5e22d..c40a1ee 100644
--- a/src/geom/LineString.cpp
+++ b/src/geom/LineString.cpp
@@ -104,10 +104,7 @@ LineString::LineString(CoordinateSequence::Ptr newCoords,
-LineString::~LineString()
- //delete points;
+LineString::~LineString() = default;
std::unique_ptr<CoordinateSequence>
LineString::getCoordinates() const
diff --git a/src/geomgraph/Depth.cpp b/src/geomgraph/Depth.cpp
index a9bd7d2..0e67a9c 100644
--- a/src/geomgraph/Depth.cpp
+++ b/src/geomgraph/Depth.cpp
@@ -55,10 +55,7 @@ Depth::Depth()
-Depth::~Depth()
-// delete[] &depth;
+Depth::~Depth() = default;
int
Depth::getDepth(int geomIndex, int posIndex) const
diff --git a/src/geomgraph/index/SimpleMCSweepLineIntersector.cpp b/src/geomgraph/index/SimpleMCSweepLineIntersector.cpp
index c11fd27..f97938a 100644
--- a/src/geomgraph/index/SimpleMCSweepLineIntersector.cpp
+++ b/src/geomgraph/index/SimpleMCSweepLineIntersector.cpp
@@ -30,7 +30,6 @@ namespace geomgraph { // geos.geomgraph
namespace index { // geos.geomgraph.index
SimpleMCSweepLineIntersector::SimpleMCSweepLineIntersector()
-//events(new vector<SweepLineEvent*>())
@@ -42,7 +41,6 @@ SimpleMCSweepLineIntersector::~SimpleMCSweepLineIntersector()
delete sle;
- //delete events;
void
diff --git a/src/geomgraph/index/SimpleSweepLineIntersector.cpp b/src/geomgraph/index/SimpleSweepLineIntersector.cpp
index c2972fe..bd8eea6 100644
--- a/src/geomgraph/index/SimpleSweepLineIntersector.cpp
+++ b/src/geomgraph/index/SimpleSweepLineIntersector.cpp
@@ -40,7 +40,6 @@ SimpleSweepLineIntersector::~SimpleSweepLineIntersector()
for(unsigned int i = 0; i < events.size(); ++i) {
delete events[i];
- //delete events;
void
diff --git a/src/index/sweepline/SweepLineIndex.cpp b/src/index/sweepline/SweepLineIndex.cpp
index 6dabf8e..cccbc3b 100644
--- a/src/index/sweepline/SweepLineIndex.cpp
+++ b/src/index/sweepline/SweepLineIndex.cpp
@@ -31,14 +31,9 @@ SweepLineIndex::SweepLineIndex()
indexBuilt(false),
nOverlaps(0)
- //events=new vector<SweepLineEvent*>();
- //nOverlaps=0;
-SweepLineIndex::~SweepLineIndex()
- //delete events;
+SweepLineIndex::~SweepLineIndex() = default;
void
SweepLineIndex::add(SweepLineInterval* sweepInt)
diff --git a/src/operation/buffer/OffsetCurveSetBuilder.cpp b/src/operation/buffer/OffsetCurveSetBuilder.cpp
index bbc50b3..56f59c0 100644
--- a/src/operation/buffer/OffsetCurveSetBuilder.cpp
+++ b/src/operation/buffer/OffsetCurveSetBuilder.cpp
@@ -191,7 +191,6 @@ OffsetCurveSetBuilder::addPoint(const Point* p)
curveBuilder.getLineCurve(coord, distance, lineList);
addCurves(lineList, Location::EXTERIOR, Location::INTERIOR);
- //delete lineList;
/*private*/
diff --git a/src/operation/overlay/OverlayOp.cpp b/src/operation/overlay/OverlayOp.cpp
index 13361a1..c7debee 100644
--- a/src/operation/overlay/OverlayOp.cpp
+++ b/src/operation/overlay/OverlayOp.cpp
@@ -172,7 +172,6 @@ OverlayOp::OverlayOp(const Geometry* g0, const Geometry* g1)
OverlayOp::~OverlayOp()
- //delete edgeList;
delete resultPolyList;
delete resultLineList;
delete resultPointList;
diff --git a/src/operation/valid/IndexedNestedRingTester.cpp b/src/operation/valid/IndexedNestedRingTester.cpp
index ee33478..26f7ea4 100644
--- a/src/operation/valid/IndexedNestedRingTester.cpp
+++ b/src/operation/valid/IndexedNestedRingTester.cpp
@@ -98,7 +98,6 @@ IndexedNestedRingTester::isNonNested()
IndexedNestedRingTester::~IndexedNestedRingTester()
delete index;
- //delete totalEnv;
void
diff --git a/src/operation/valid/QuadtreeNestedRingTester.cpp b/src/operation/valid/QuadtreeNestedRingTester.cpp
index ecad166..2f8706b 100644
--- a/src/operation/valid/QuadtreeNestedRingTester.cpp
+++ b/src/operation/valid/QuadtreeNestedRingTester.cpp
@@ -49,8 +49,6 @@ QuadtreeNestedRingTester::QuadtreeNestedRingTester(GeometryGraph* newGraph):
QuadtreeNestedRingTester::~QuadtreeNestedRingTester()
- //delete rings;
delete qt;
Summary of changes:
src/geom/Geometry.cpp | 4 +---
src/geom/LineString.cpp | 5 +----
src/geomgraph/Depth.cpp | 5 +----
src/geomgraph/index/SimpleMCSweepLineIntersector.cpp | 2 --
src/geomgraph/index/SimpleSweepLineIntersector.cpp | 1 -
src/index/sweepline/SweepLineIndex.cpp | 7 +------
src/operation/buffer/OffsetCurveSetBuilder.cpp | 1 -
src/operation/overlay/OverlayOp.cpp | 1 -
src/operation/valid/IndexedNestedRingTester.cpp | 1 -
src/operation/valid/QuadtreeNestedRingTester.cpp | 2 --
10 files changed, 4 insertions(+), 25 deletions(-)
hooks/post-receive
More information about the geos-commits
