[geos-commits] [SCM] GEOS branch master updated. 93b3eb637e75e96f223e6e440b4aa6ec960fa914
Wed Mar 13 16:05:56 PDT 2019
the project "GEOS".
       via  93b3eb637e75e96f223e6e440b4aa6ec960fa914 (commit)
       via  5c16f28e6a2856146d9b46742cc7ca3dd6cc75d0 (commit)
       via  8e0dd71e5931b98a22c756f36126255c001d8768 (commit)
      from  fd45dabbbb28857a534ef62e798f5916466f8815 (commit)
revisions in full, below.
commit 93b3eb637e75e96f223e6e440b4aa6ec960fa914
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Wed Mar 13 16:05:46 2019 -0700
    Reorganize tests some more
diff --git a/tests/xmltester/CMakeLists.txt b/tests/xmltester/CMakeLists.txt
index 56029a4..3e909ed 100644
--- a/tests/xmltester/CMakeLists.txt
+++ b/tests/xmltester/CMakeLists.txt
@@ -46,24 +46,6 @@ if(GEOS_ENABLE_TESTS)
   set(XMLTESTS_DIR ${CMAKE_CURRENT_SOURCE_DIR}/tests)
   set(SAVE_XMLTESTS
-    ${XMLTESTS_DIR}/TestBufferExternal.xml
-    ${XMLTESTS_DIR}/TestBufferExternal2.xml
-    ${XMLTESTS_DIR}/TestIsValid.xml
-    ${XMLTESTS_DIR}/badguy3.xml
-    ${XMLTESTS_DIR}/buffer.xml
-    ${XMLTESTS_DIR}/fme.xml
-    ${XMLTESTS_DIR}/heisenbugs.xml
-    ${XMLTESTS_DIR}/hexwkb.xml
-    ${XMLTESTS_DIR}/hole_from_shell.xml
-    ${XMLTESTS_DIR}/hole_red.xml
-    ${XMLTESTS_DIR}/linemerge.xml
-    ${XMLTESTS_DIR}/robustness.xml
-    ${XMLTESTS_DIR}/singlesidedbuffer.xml
-    ${XMLTESTS_DIR}/split.xml
-    ${XMLTESTS_DIR}/test.xml
-    ${XMLTESTS_DIR}/testLeaksBig.xml
-    ${XMLTESTS_DIR}/buildarea.xml
-    ${XMLTESTS_DIR}/makevalid.xml
     ${XMLTESTS_DIR}/general/TestBoundary.xml
     ${XMLTESTS_DIR}/general/TestBuffer.xml
     ${XMLTESTS_DIR}/general/TestBufferMitredJoin.xml
@@ -104,12 +86,30 @@ if(GEOS_ENABLE_TESTS)
     ${XMLTESTS_DIR}/general/TestValid2-big.xml
     ${XMLTESTS_DIR}/general/TestValid2.xml
     ${XMLTESTS_DIR}/general/TestWithinDistance.xml
+    ${XMLTESTS_DIR}/misc/TestBufferExternal.xml
+    ${XMLTESTS_DIR}/misc/TestBufferExternal2.xml
+    ${XMLTESTS_DIR}/misc/TestIsValid.xml
+    ${XMLTESTS_DIR}/misc/badguy3.xml
+    ${XMLTESTS_DIR}/misc/buildarea.xml
+    ${XMLTESTS_DIR}/misc/buffer.xml
+    ${XMLTESTS_DIR}/misc/fme.xml
+    ${XMLTESTS_DIR}/misc/heisenbugs.xml
+    ${XMLTESTS_DIR}/misc/hexwkb.xml
+    ${XMLTESTS_DIR}/misc/hole_from_shell.xml
+    ${XMLTESTS_DIR}/misc/hole_red.xml
+    ${XMLTESTS_DIR}/misc/linemerge.xml
+    ${XMLTESTS_DIR}/misc/makevalid.xml
+    ${XMLTESTS_DIR}/misc/robustness.xml
     ${XMLTESTS_DIR}/misc/safe-16595.xml
     ${XMLTESTS_DIR}/misc/safe-16596.xml
     ${XMLTESTS_DIR}/misc/safe-TestBufferJagged.xml
+    ${XMLTESTS_DIR}/misc/singlesidedbuffer.xml
     ${XMLTESTS_DIR}/misc/stmlf-cases-20061020-invalid-output.xml
     ${XMLTESTS_DIR}/misc/stmlf-cases-20061020.xml
     ${XMLTESTS_DIR}/misc/stmlf-cases-20070119.xml
+    ${XMLTESTS_DIR}/misc/split.xml
+    ${XMLTESTS_DIR}/misc/test.xml
+    ${XMLTESTS_DIR}/misc/testLeaksBig.xml
     ${XMLTESTS_DIR}/robust/TestRobustOverlayFixed.xml
     ${XMLTESTS_DIR}/robust/TestRobustRelate.xml
     ${XMLTESTS_DIR}/ticket/ticket-geos-176.xml
@@ -147,11 +147,12 @@ if(GEOS_ENABLE_TESTS)
   set(FAILING_XMLTESTS
-    ${XMLTESTS_DIR}/ticket/bug488.xml
-    ${XMLTESTS_DIR}/ticket/bug344.xml
+    ${XMLTESTS_DIR}/ticket/ticket-geos-488.xml
+    ${XMLTESTS_DIR}/ticket/ticket-geos-344.xml
     ${XMLTESTS_DIR}/robust/TestRobustRelateFloat.xml
-    ${XMLTESTS_DIR}/TestBigNastyBuffer.xml
     ${XMLTESTS_DIR}/failure/TestOverlay.xml
+    ${XMLTESTS_DIR}/misc/TestBigNastyBuffer.xml
+    ${XMLTESTS_DIR}/misc/TestSameDirection.xml
   add_test(test_xmltester ${CMAKE_RUNTIME_OUTPUT_DIRECTORY}/test_xmltester -v --test-valid-output ${SAVE_XMLTESTS})
diff --git a/tests/xmltester/Makefile.am b/tests/xmltester/Makefile.am
index b030da1..bfd06bf 100644
--- a/tests/xmltester/Makefile.am
+++ b/tests/xmltester/Makefile.am
@@ -14,24 +14,6 @@ CLEANFILES = testrunner
 EXTRA_DIST = testrunner.sh CMakeLists.txt
 SAFE_XMLTESTS= \
-	$(srcdir)/tests/TestBufferExternal.xml \
-	$(srcdir)/tests/TestBufferExternal2.xml \
-	$(srcdir)/tests/TestIsValid.xml \
-	$(srcdir)/tests/badguy3.xml \
-	$(srcdir)/tests/buffer.xml \
-	$(srcdir)/tests/fme.xml \
-	$(srcdir)/tests/heisenbugs.xml \
-	$(srcdir)/tests/hexwkb.xml \
-	$(srcdir)/tests/hole_from_shell.xml \
-	$(srcdir)/tests/hole_red.xml \
-	$(srcdir)/tests/linemerge.xml \
-	$(srcdir)/tests/robustness.xml \
-	$(srcdir)/tests/singlesidedbuffer.xml \
-	$(srcdir)/tests/split.xml \
-	$(srcdir)/tests/test.xml \
-	$(srcdir)/tests/testLeaksBig.xml \
-	$(srcdir)/tests/buildarea.xml \
-	$(srcdir)/tests/makevalid.xml \
 	$(srcdir)/tests/general/TestBoundary.xml \
 	$(srcdir)/tests/general/TestBuffer.xml \
 	$(srcdir)/tests/general/TestBufferMitredJoin.xml \
@@ -72,12 +54,30 @@ SAFE_XMLTESTS= \
 	$(srcdir)/tests/general/TestValid2-big.xml \
 	$(srcdir)/tests/general/TestValid2.xml \
 	$(srcdir)/tests/general/TestWithinDistance.xml \
+	$(srcdir)/tests/misc/TestBufferExternal.xml \
+	$(srcdir)/tests/misc/TestBufferExternal2.xml \
+	$(srcdir)/tests/misc/TestIsValid.xml \
+	$(srcdir)/tests/misc/badguy3.xml \
+	$(srcdir)/tests/misc/buffer.xml \
+	$(srcdir)/tests/misc/buildarea.xml \
+	$(srcdir)/tests/misc/fme.xml \
+	$(srcdir)/tests/misc/heisenbugs.xml \
+	$(srcdir)/tests/misc/hexwkb.xml \
+	$(srcdir)/tests/misc/hole_from_shell.xml \
+	$(srcdir)/tests/misc/hole_red.xml \
+	$(srcdir)/tests/misc/linemerge.xml \
+	$(srcdir)/tests/misc/makevalid.xml \
+	$(srcdir)/tests/misc/robustness.xml \
 	$(srcdir)/tests/misc/safe-16595.xml \
 	$(srcdir)/tests/misc/safe-16596.xml \
 	$(srcdir)/tests/misc/safe-TestBufferJagged.xml \
+	$(srcdir)/tests/misc/singlesidedbuffer.xml \
 	$(srcdir)/tests/misc/stmlf-cases-20061020-invalid-output.xml \
 	$(srcdir)/tests/misc/stmlf-cases-20061020.xml \
 	$(srcdir)/tests/misc/stmlf-cases-20070119.xml \
+	$(srcdir)/tests/misc/split.xml \
+	$(srcdir)/tests/misc/test.xml \
+	$(srcdir)/tests/misc/testLeaksBig.xml \
 	$(srcdir)/tests/robust/TestRobustOverlayFixed.xml \
 	$(srcdir)/tests/robust/TestRobustRelate.xml \
 	$(srcdir)/tests/ticket/ticket-geos-176.xml \
@@ -117,10 +117,13 @@ INVALID_OUTPUT_XMLTESTS =
 FAILING_XMLTESTS = \
 	$(srcdir)/tests/failure/TestOverlay.xml \
-	$(srcdir)/tests/ticket/bug488.xml \
-	$(srcdir)/tests/ticket/bug344.xml \
+	$(srcdir)/tests/ticket/ticket-geos-488.xml \
+	$(srcdir)/tests/ticket/ticket-geos-344.xml \
 	$(srcdir)/tests/robust/TestRobustRelateFloat.xml \
-	$(srcdir)/tests/TestBigNastyBuffer.xml
+	$(srcdir)/misc/TestBigNastyBuffer.xml \
+	$(srcdir)/misc/TestSameDirection.xml
 XMLTESTS=$(SAFE_XMLTESTS) $(INVALID_OUTPUT_XMLTESTS) $(FAILING_XMLTESTS)
diff --git a/tests/xmltester/tests/TestBigNastyBuffer.xml b/tests/xmltester/tests/misc/TestBigNastyBuffer.xml
similarity index 100%
rename from tests/xmltester/tests/TestBigNastyBuffer.xml
rename to tests/xmltester/tests/misc/TestBigNastyBuffer.xml
diff --git a/tests/xmltester/tests/TestBufferExternal.xml b/tests/xmltester/tests/misc/TestBufferExternal.xml
rename from tests/xmltester/tests/TestBufferExternal.xml
rename to tests/xmltester/tests/misc/TestBufferExternal.xml
diff --git a/tests/xmltester/tests/TestBufferExternal2.xml b/tests/xmltester/tests/misc/TestBufferExternal2.xml
rename from tests/xmltester/tests/TestBufferExternal2.xml
rename to tests/xmltester/tests/misc/TestBufferExternal2.xml
diff --git a/tests/xmltester/tests/TestIsValid.xml b/tests/xmltester/tests/misc/TestIsValid.xml
rename from tests/xmltester/tests/TestIsValid.xml
rename to tests/xmltester/tests/misc/TestIsValid.xml
diff --git a/tests/xmltester/tests/rt/TestSameDirection.xml b/tests/xmltester/tests/misc/TestSameDirection.xml
rename from tests/xmltester/tests/rt/TestSameDirection.xml
rename to tests/xmltester/tests/misc/TestSameDirection.xml
diff --git a/tests/xmltester/tests/badguy3.xml b/tests/xmltester/tests/misc/badguy3.xml
rename from tests/xmltester/tests/badguy3.xml
rename to tests/xmltester/tests/misc/badguy3.xml
diff --git a/tests/xmltester/tests/buffer.xml b/tests/xmltester/tests/misc/buffer.xml
rename from tests/xmltester/tests/buffer.xml
rename to tests/xmltester/tests/misc/buffer.xml
diff --git a/tests/xmltester/tests/buildarea.xml b/tests/xmltester/tests/misc/buildarea.xml
rename from tests/xmltester/tests/buildarea.xml
rename to tests/xmltester/tests/misc/buildarea.xml
diff --git a/tests/xmltester/tests/fme.xml b/tests/xmltester/tests/misc/fme.xml
rename from tests/xmltester/tests/fme.xml
rename to tests/xmltester/tests/misc/fme.xml
diff --git a/tests/xmltester/tests/heisenbugs.xml b/tests/xmltester/tests/misc/heisenbugs.xml
rename from tests/xmltester/tests/heisenbugs.xml
rename to tests/xmltester/tests/misc/heisenbugs.xml
diff --git a/tests/xmltester/tests/hexwkb.xml b/tests/xmltester/tests/misc/hexwkb.xml
rename from tests/xmltester/tests/hexwkb.xml
rename to tests/xmltester/tests/misc/hexwkb.xml
diff --git a/tests/xmltester/tests/hole_from_shell.xml b/tests/xmltester/tests/misc/hole_from_shell.xml
rename from tests/xmltester/tests/hole_from_shell.xml
rename to tests/xmltester/tests/misc/hole_from_shell.xml
diff --git a/tests/xmltester/tests/hole_red.xml b/tests/xmltester/tests/misc/hole_red.xml
rename from tests/xmltester/tests/hole_red.xml
rename to tests/xmltester/tests/misc/hole_red.xml
diff --git a/tests/xmltester/tests/linemerge.xml b/tests/xmltester/tests/misc/linemerge.xml
rename from tests/xmltester/tests/linemerge.xml
rename to tests/xmltester/tests/misc/linemerge.xml
diff --git a/tests/xmltester/tests/makevalid.xml b/tests/xmltester/tests/misc/makevalid.xml
rename from tests/xmltester/tests/makevalid.xml
rename to tests/xmltester/tests/misc/makevalid.xml
diff --git a/tests/xmltester/tests/robustness.xml b/tests/xmltester/tests/misc/robustness.xml
rename from tests/xmltester/tests/robustness.xml
rename to tests/xmltester/tests/misc/robustness.xml
diff --git a/tests/xmltester/tests/singlesidedbuffer.xml b/tests/xmltester/tests/misc/singlesidedbuffer.xml
rename from tests/xmltester/tests/singlesidedbuffer.xml
rename to tests/xmltester/tests/misc/singlesidedbuffer.xml
diff --git a/tests/xmltester/tests/split.xml b/tests/xmltester/tests/misc/split.xml
rename from tests/xmltester/tests/split.xml
rename to tests/xmltester/tests/misc/split.xml
diff --git a/tests/xmltester/tests/test.xml b/tests/xmltester/tests/misc/test.xml
rename from tests/xmltester/tests/test.xml
rename to tests/xmltester/tests/misc/test.xml
diff --git a/tests/xmltester/tests/testLeaksBig.xml b/tests/xmltester/tests/misc/testLeaksBig.xml
rename from tests/xmltester/tests/testLeaksBig.xml
rename to tests/xmltester/tests/misc/testLeaksBig.xml
commit 5c16f28e6a2856146d9b46742cc7ca3dd6cc75d0
Date:   Wed Mar 13 14:58:20 2019 -0700
    Reorganize some tests and the makefiles
index a3eed66..56029a4 100644
@@ -104,37 +104,37 @@ if(GEOS_ENABLE_TESTS)
+    ${XMLTESTS_DIR}/misc/safe-16595.xml
+    ${XMLTESTS_DIR}/misc/safe-16596.xml
+    ${XMLTESTS_DIR}/misc/safe-TestBufferJagged.xml
+    ${XMLTESTS_DIR}/misc/stmlf-cases-20061020-invalid-output.xml
+    ${XMLTESTS_DIR}/misc/stmlf-cases-20061020.xml
+    ${XMLTESTS_DIR}/misc/stmlf-cases-20070119.xml
-    ${XMLTESTS_DIR}/safe/16595.xml
-    ${XMLTESTS_DIR}/safe/16596.xml
-    ${XMLTESTS_DIR}/safe/TestBufferJagged.xml
-    ${XMLTESTS_DIR}/stmlf/stmlf-cases-20061020-invalid-output.xml
-    ${XMLTESTS_DIR}/stmlf/stmlf-cases-20061020.xml
-    ${XMLTESTS_DIR}/stmlf/stmlf-cases-20070119.xml
-    ${XMLTESTS_DIR}/ticket/bug176.xml
-    ${XMLTESTS_DIR}/ticket/bug188.xml
-    ${XMLTESTS_DIR}/ticket/bug244.xml
-    ${XMLTESTS_DIR}/ticket/bug275.xml
-    ${XMLTESTS_DIR}/ticket/bug350.xml
-    ${XMLTESTS_DIR}/ticket/bug356.xml
-    ${XMLTESTS_DIR}/ticket/bug358.xml
-    ${XMLTESTS_DIR}/ticket/bug360.xml
-    ${XMLTESTS_DIR}/ticket/bug366.xml
-    ${XMLTESTS_DIR}/ticket/bug392.xml
-    ${XMLTESTS_DIR}/ticket/bug398.xml
-    ${XMLTESTS_DIR}/ticket/bug434.xml
-    ${XMLTESTS_DIR}/ticket/bug459.xml
-    ${XMLTESTS_DIR}/ticket/bug527.xml
-    ${XMLTESTS_DIR}/ticket/bug569.xml
-    ${XMLTESTS_DIR}/ticket/bug582.xml
-    ${XMLTESTS_DIR}/ticket/bug586.xml
-    ${XMLTESTS_DIR}/ticket/bug599.xml
-    ${XMLTESTS_DIR}/ticket/bug605.xml
-    ${XMLTESTS_DIR}/ticket/bug615.xml
-    ${XMLTESTS_DIR}/ticket/bug716.xml
-    ${XMLTESTS_DIR}/ticket/bug837.xml
-    ${XMLTESTS_DIR}/ticket/bug838.xml
+    ${XMLTESTS_DIR}/ticket/ticket-geos-176.xml
+    ${XMLTESTS_DIR}/ticket/ticket-geos-188.xml
+    ${XMLTESTS_DIR}/ticket/ticket-geos-244.xml
+    ${XMLTESTS_DIR}/ticket/ticket-geos-275.xml
+    ${XMLTESTS_DIR}/ticket/ticket-geos-350.xml
+    ${XMLTESTS_DIR}/ticket/ticket-geos-356.xml
+    ${XMLTESTS_DIR}/ticket/ticket-geos-358.xml
+    ${XMLTESTS_DIR}/ticket/ticket-geos-360.xml
+    ${XMLTESTS_DIR}/ticket/ticket-geos-366.xml
+    ${XMLTESTS_DIR}/ticket/ticket-geos-392.xml
+    ${XMLTESTS_DIR}/ticket/ticket-geos-398.xml
+    ${XMLTESTS_DIR}/ticket/ticket-geos-434.xml
+    ${XMLTESTS_DIR}/ticket/ticket-geos-459.xml
+    ${XMLTESTS_DIR}/ticket/ticket-geos-527.xml
+    ${XMLTESTS_DIR}/ticket/ticket-geos-569.xml
+    ${XMLTESTS_DIR}/ticket/ticket-geos-582.xml
+    ${XMLTESTS_DIR}/ticket/ticket-geos-586.xml
+    ${XMLTESTS_DIR}/ticket/ticket-geos-599.xml
+    ${XMLTESTS_DIR}/ticket/ticket-geos-605.xml
+    ${XMLTESTS_DIR}/ticket/ticket-geos-615.xml
+    ${XMLTESTS_DIR}/ticket/ticket-geos-716.xml
+    ${XMLTESTS_DIR}/ticket/ticket-geos-837.xml
+    ${XMLTESTS_DIR}/ticket/ticket-geos-838.xml
     ${XMLTESTS_DIR}/validate/TestRelateAA-big.xml
     ${XMLTESTS_DIR}/validate/TestRelateAA.xml
     ${XMLTESTS_DIR}/validate/TestRelateAC.xml
index 6289e3d..b030da1 100644
@@ -72,37 +72,37 @@ SAFE_XMLTESTS= \
+	$(srcdir)/tests/misc/safe-16595.xml \
+	$(srcdir)/tests/misc/safe-16596.xml \
+	$(srcdir)/tests/misc/safe-TestBufferJagged.xml \
+	$(srcdir)/tests/misc/stmlf-cases-20061020-invalid-output.xml \
+	$(srcdir)/tests/misc/stmlf-cases-20061020.xml \
+	$(srcdir)/tests/misc/stmlf-cases-20070119.xml \
-	$(srcdir)/tests/safe/16595.xml \
-	$(srcdir)/tests/safe/16596.xml \
-	$(srcdir)/tests/safe/TestBufferJagged.xml \
-	$(srcdir)/tests/stmlf/stmlf-cases-20061020-invalid-output.xml \
-	$(srcdir)/tests/stmlf/stmlf-cases-20061020.xml \
-	$(srcdir)/tests/stmlf/stmlf-cases-20070119.xml \
-	$(srcdir)/tests/ticket/bug176.xml \
-	$(srcdir)/tests/ticket/bug188.xml \
-	$(srcdir)/tests/ticket/bug244.xml \
-	$(srcdir)/tests/ticket/bug275.xml \
-	$(srcdir)/tests/ticket/bug350.xml \
-	$(srcdir)/tests/ticket/bug356.xml \
-	$(srcdir)/tests/ticket/bug358.xml \
-	$(srcdir)/tests/ticket/bug360.xml \
-	$(srcdir)/tests/ticket/bug366.xml \
-	$(srcdir)/tests/ticket/bug392.xml \
-	$(srcdir)/tests/ticket/bug398.xml \
-	$(srcdir)/tests/ticket/bug434.xml \
-	$(srcdir)/tests/ticket/bug459.xml \
-	$(srcdir)/tests/ticket/bug527.xml \
-	$(srcdir)/tests/ticket/bug569.xml \
-	$(srcdir)/tests/ticket/bug582.xml \
-	$(srcdir)/tests/ticket/bug586.xml \
-	$(srcdir)/tests/ticket/bug599.xml \
-	$(srcdir)/tests/ticket/bug605.xml \
-	$(srcdir)/tests/ticket/bug615.xml \
-	$(srcdir)/tests/ticket/bug716.xml \
-	$(srcdir)/tests/ticket/bug837.xml \
-	$(srcdir)/tests/ticket/bug838.xml \
+	$(srcdir)/tests/ticket/ticket-geos-176.xml \
+	$(srcdir)/tests/ticket/ticket-geos-188.xml \
+	$(srcdir)/tests/ticket/ticket-geos-244.xml \
+	$(srcdir)/tests/ticket/ticket-geos-275.xml \
+	$(srcdir)/tests/ticket/ticket-geos-350.xml \
+	$(srcdir)/tests/ticket/ticket-geos-356.xml \
+	$(srcdir)/tests/ticket/ticket-geos-358.xml \
+	$(srcdir)/tests/ticket/ticket-geos-360.xml \
+	$(srcdir)/tests/ticket/ticket-geos-366.xml \
+	$(srcdir)/tests/ticket/ticket-geos-392.xml \
+	$(srcdir)/tests/ticket/ticket-geos-398.xml \
+	$(srcdir)/tests/ticket/ticket-geos-434.xml \
+	$(srcdir)/tests/ticket/ticket-geos-459.xml \
+	$(srcdir)/tests/ticket/ticket-geos-527.xml \
+	$(srcdir)/tests/ticket/ticket-geos-569.xml \
+	$(srcdir)/tests/ticket/ticket-geos-582.xml \
+	$(srcdir)/tests/ticket/ticket-geos-586.xml \
+	$(srcdir)/tests/ticket/ticket-geos-599.xml \
+	$(srcdir)/tests/ticket/ticket-geos-605.xml \
+	$(srcdir)/tests/ticket/ticket-geos-615.xml \
+	$(srcdir)/tests/ticket/ticket-geos-716.xml \
+	$(srcdir)/tests/ticket/ticket-geos-837.xml \
+	$(srcdir)/tests/ticket/ticket-geos-838.xml \
 	$(srcdir)/tests/validate/TestRelateAA-big.xml \
 	$(srcdir)/tests/validate/TestRelateAA.xml \
 	$(srcdir)/tests/validate/TestRelateAC.xml \
diff --git a/tests/xmltester/tests/safe/16595.xml b/tests/xmltester/tests/misc/safe-16595.xml
rename from tests/xmltester/tests/safe/16595.xml
rename to tests/xmltester/tests/misc/safe-16595.xml
diff --git a/tests/xmltester/tests/safe/16596.xml b/tests/xmltester/tests/misc/safe-16596.xml
rename from tests/xmltester/tests/safe/16596.xml
rename to tests/xmltester/tests/misc/safe-16596.xml
diff --git a/tests/xmltester/tests/safe/TestBufferJagged.xml b/tests/xmltester/tests/misc/safe-TestBufferJagged.xml
rename from tests/xmltester/tests/safe/TestBufferJagged.xml
rename to tests/xmltester/tests/misc/safe-TestBufferJagged.xml
diff --git a/tests/xmltester/tests/stmlf/stmlf-cases-20061020-invalid-output.xml b/tests/xmltester/tests/misc/stmlf-cases-20061020-invalid-output.xml
rename from tests/xmltester/tests/stmlf/stmlf-cases-20061020-invalid-output.xml
rename to tests/xmltester/tests/misc/stmlf-cases-20061020-invalid-output.xml
diff --git a/tests/xmltester/tests/stmlf/stmlf-cases-20061020.xml b/tests/xmltester/tests/misc/stmlf-cases-20061020.xml
rename from tests/xmltester/tests/stmlf/stmlf-cases-20061020.xml
rename to tests/xmltester/tests/misc/stmlf-cases-20061020.xml
diff --git a/tests/xmltester/tests/stmlf/stmlf-cases-20070119.xml b/tests/xmltester/tests/misc/stmlf-cases-20070119.xml
rename from tests/xmltester/tests/stmlf/stmlf-cases-20070119.xml
rename to tests/xmltester/tests/misc/stmlf-cases-20070119.xml
diff --git a/tests/xmltester/tests/ticket/bug176.xml b/tests/xmltester/tests/ticket/ticket-geos-176.xml
rename from tests/xmltester/tests/ticket/bug176.xml
rename to tests/xmltester/tests/ticket/ticket-geos-176.xml
diff --git a/tests/xmltester/tests/ticket/bug188.xml b/tests/xmltester/tests/ticket/ticket-geos-188.xml
rename from tests/xmltester/tests/ticket/bug188.xml
rename to tests/xmltester/tests/ticket/ticket-geos-188.xml
diff --git a/tests/xmltester/tests/ticket/bug244.xml b/tests/xmltester/tests/ticket/ticket-geos-244.xml
rename from tests/xmltester/tests/ticket/bug244.xml
rename to tests/xmltester/tests/ticket/ticket-geos-244.xml
diff --git a/tests/xmltester/tests/ticket/bug275.xml b/tests/xmltester/tests/ticket/ticket-geos-275.xml
rename from tests/xmltester/tests/ticket/bug275.xml
rename to tests/xmltester/tests/ticket/ticket-geos-275.xml
diff --git a/tests/xmltester/tests/ticket/bug344.xml b/tests/xmltester/tests/ticket/ticket-geos-344.xml
rename from tests/xmltester/tests/ticket/bug344.xml
rename to tests/xmltester/tests/ticket/ticket-geos-344.xml
diff --git a/tests/xmltester/tests/ticket/bug350.xml b/tests/xmltester/tests/ticket/ticket-geos-350.xml
rename from tests/xmltester/tests/ticket/bug350.xml
rename to tests/xmltester/tests/ticket/ticket-geos-350.xml
diff --git a/tests/xmltester/tests/ticket/bug356.xml b/tests/xmltester/tests/ticket/ticket-geos-356.xml
rename from tests/xmltester/tests/ticket/bug356.xml
rename to tests/xmltester/tests/ticket/ticket-geos-356.xml
diff --git a/tests/xmltester/tests/ticket/bug358.xml b/tests/xmltester/tests/ticket/ticket-geos-358.xml
rename from tests/xmltester/tests/ticket/bug358.xml
rename to tests/xmltester/tests/ticket/ticket-geos-358.xml
diff --git a/tests/xmltester/tests/ticket/bug360.xml b/tests/xmltester/tests/ticket/ticket-geos-360.xml
rename from tests/xmltester/tests/ticket/bug360.xml
rename to tests/xmltester/tests/ticket/ticket-geos-360.xml
diff --git a/tests/xmltester/tests/ticket/bug366.xml b/tests/xmltester/tests/ticket/ticket-geos-366.xml
rename from tests/xmltester/tests/ticket/bug366.xml
rename to tests/xmltester/tests/ticket/ticket-geos-366.xml
diff --git a/tests/xmltester/tests/ticket/bug392.xml b/tests/xmltester/tests/ticket/ticket-geos-392.xml
rename from tests/xmltester/tests/ticket/bug392.xml
rename to tests/xmltester/tests/ticket/ticket-geos-392.xml
diff --git a/tests/xmltester/tests/ticket/bug398.xml b/tests/xmltester/tests/ticket/ticket-geos-398.xml
rename from tests/xmltester/tests/ticket/bug398.xml
rename to tests/xmltester/tests/ticket/ticket-geos-398.xml
diff --git a/tests/xmltester/tests/ticket/bug434.xml b/tests/xmltester/tests/ticket/ticket-geos-434.xml
rename from tests/xmltester/tests/ticket/bug434.xml
rename to tests/xmltester/tests/ticket/ticket-geos-434.xml
diff --git a/tests/xmltester/tests/ticket/bug459.xml b/tests/xmltester/tests/ticket/ticket-geos-459.xml
rename from tests/xmltester/tests/ticket/bug459.xml
rename to tests/xmltester/tests/ticket/ticket-geos-459.xml
diff --git a/tests/xmltester/tests/ticket/bug488.xml b/tests/xmltester/tests/ticket/ticket-geos-488.xml
rename from tests/xmltester/tests/ticket/bug488.xml
rename to tests/xmltester/tests/ticket/ticket-geos-488.xml
diff --git a/tests/xmltester/tests/ticket/bug527.xml b/tests/xmltester/tests/ticket/ticket-geos-527.xml
rename from tests/xmltester/tests/ticket/bug527.xml
rename to tests/xmltester/tests/ticket/ticket-geos-527.xml
diff --git a/tests/xmltester/tests/ticket/bug569.xml b/tests/xmltester/tests/ticket/ticket-geos-569.xml
rename from tests/xmltester/tests/ticket/bug569.xml
rename to tests/xmltester/tests/ticket/ticket-geos-569.xml
diff --git a/tests/xmltester/tests/ticket/bug582.xml b/tests/xmltester/tests/ticket/ticket-geos-582.xml
rename from tests/xmltester/tests/ticket/bug582.xml
rename to tests/xmltester/tests/ticket/ticket-geos-582.xml
diff --git a/tests/xmltester/tests/ticket/bug586.xml b/tests/xmltester/tests/ticket/ticket-geos-586.xml
rename from tests/xmltester/tests/ticket/bug586.xml
rename to tests/xmltester/tests/ticket/ticket-geos-586.xml
diff --git a/tests/xmltester/tests/ticket/bug599.xml b/tests/xmltester/tests/ticket/ticket-geos-599.xml
rename from tests/xmltester/tests/ticket/bug599.xml
rename to tests/xmltester/tests/ticket/ticket-geos-599.xml
diff --git a/tests/xmltester/tests/ticket/bug605.xml b/tests/xmltester/tests/ticket/ticket-geos-605.xml
rename from tests/xmltester/tests/ticket/bug605.xml
rename to tests/xmltester/tests/ticket/ticket-geos-605.xml
diff --git a/tests/xmltester/tests/ticket/bug615.xml b/tests/xmltester/tests/ticket/ticket-geos-615.xml
rename from tests/xmltester/tests/ticket/bug615.xml
rename to tests/xmltester/tests/ticket/ticket-geos-615.xml
diff --git a/tests/xmltester/tests/ticket/bug716.xml b/tests/xmltester/tests/ticket/ticket-geos-716.xml
rename from tests/xmltester/tests/ticket/bug716.xml
rename to tests/xmltester/tests/ticket/ticket-geos-716.xml
diff --git a/tests/xmltester/tests/ticket/bug837.xml b/tests/xmltester/tests/ticket/ticket-geos-837.xml
rename from tests/xmltester/tests/ticket/bug837.xml
rename to tests/xmltester/tests/ticket/ticket-geos-837.xml
diff --git a/tests/xmltester/tests/ticket/bug838.xml b/tests/xmltester/tests/ticket/ticket-geos-838.xml
rename from tests/xmltester/tests/ticket/bug838.xml
rename to tests/xmltester/tests/ticket/ticket-geos-838.xml
commit 8e0dd71e5931b98a22c756f36126255c001d8768
Date:   Wed Mar 13 12:38:13 2019 -0700
    Update to latest JTS version of test file
diff --git a/tests/xmltester/tests/general/TestValid.xml b/tests/xmltester/tests/general/TestValid.xml
index fba702d..5a937a0 100644
--- a/tests/xmltester/tests/general/TestValid.xml
+++ b/tests/xmltester/tests/general/TestValid.xml
@@ -70,6 +70,16 @@
    </case>
    <case>
+      <desc>L - empty</desc>
+      <a>
+LINESTRING EMPTY
+  </a>
+      <test>
+         <op name="isValid" arg1="A">    true  </op>
+      </test>
+   </case>
+   <case>
       <desc>L - no repeated points</desc>
       <a>
 LINESTRING (40 180, 120 120, 140 200, 200 140, 240 200)
@@ -124,6 +134,14 @@ LINESTRING (40 180, 120 120, 140 200, 140 200, 200 140, 240 200)
    </case>
    <case>
+      <desc>mL - MultiLinestring with empty component</desc>
+      <a>MULTILINESTRING((1 1, 0 0), EMPTY)</a>
+      <test>
+      </test>
+   </case>
+   <case>
       <desc>A - zero-area polygon </desc>
       <a>POLYGON ((0 0, 0 0, 0 0, 0 0, 0 0))</a>
       <test>
@@ -293,13 +311,21 @@ LINESTRING (40 180, 120 120, 140 200, 140 200, 200 140, 240 200)
       </test>
    </case>
    <case>
+      <desc>A - non-empty shell and empty hole (valid)</desc>
+      <a>POLYGON ((60 280, 260 180, 60 80, 60 280), EMPTY)</a>
+      <test>
+         <op name="isValid" arg1="A">true</op>
+      </test>
+   </case>
+   <case>
       <desc>A - empty shell and holes (valid)</desc>
       <a>POLYGON (EMPTY, EMPTY, EMPTY)</a>
       <test>
       </test>
    </case>
    <case>
       <desc>A - hole overlapping shell at non-vertex</desc>
       <a>
@@ -742,5 +768,12 @@ MULTIPOLYGON (((0 0, 0 8, 8 8, 8 0, 0 0),
       </test>
    </case>
+   <case>
+      <desc>mA - non-empty and empty polygon </desc>
+      <a> MULTIPOLYGON (((30 10, 40 40, 20 40, 10 20, 30 10)), EMPTY)  </a>
+      <test>
+      </test>
+   </case>
 </run>
Summary of changes:
 tests/xmltester/CMakeLists.txt                     | 101 ++++++++++----------
 tests/xmltester/Makefile.am                        | 103 +++++++++++----------
 tests/xmltester/tests/general/TestValid.xml        |  35 ++++++-
 .../tests/{ => misc}/TestBigNastyBuffer.xml        |   0
 .../tests/{ => misc}/TestBufferExternal.xml        |   0
 .../tests/{ => misc}/TestBufferExternal2.xml       |   0
 tests/xmltester/tests/{ => misc}/TestIsValid.xml   |   0
 .../tests/{rt => misc}/TestSameDirection.xml       |   0
 tests/xmltester/tests/{ => misc}/badguy3.xml       |   0
 tests/xmltester/tests/{ => misc}/buffer.xml        |   0
 tests/xmltester/tests/{ => misc}/buildarea.xml     |   0
 tests/xmltester/tests/{ => misc}/fme.xml           |   0
 tests/xmltester/tests/{ => misc}/heisenbugs.xml    |   0
 tests/xmltester/tests/{ => misc}/hexwkb.xml        |   0
 .../xmltester/tests/{ => misc}/hole_from_shell.xml |   0
 tests/xmltester/tests/{ => misc}/hole_red.xml      |   0
 tests/xmltester/tests/{ => misc}/linemerge.xml     |   0
 tests/xmltester/tests/{ => misc}/makevalid.xml     |   0
 tests/xmltester/tests/{ => misc}/robustness.xml    |   0
 .../tests/{safe/16595.xml => misc/safe-16595.xml}  |   0
 .../tests/{safe/16596.xml => misc/safe-16596.xml}  |   0
 .../safe-TestBufferJagged.xml}                     |   0
 .../tests/{ => misc}/singlesidedbuffer.xml         |   0
 tests/xmltester/tests/{ => misc}/split.xml         |   0
 .../stmlf-cases-20061020-invalid-output.xml        |   0
 .../tests/{stmlf => misc}/stmlf-cases-20061020.xml |   0
 .../tests/{stmlf => misc}/stmlf-cases-20070119.xml |   0
 tests/xmltester/tests/{ => misc}/test.xml          |   0
 tests/xmltester/tests/{ => misc}/testLeaksBig.xml  |   0
 .../ticket/{bug176.xml => ticket-geos-176.xml}     |   0
 .../ticket/{bug188.xml => ticket-geos-188.xml}     |   0
 .../ticket/{bug244.xml => ticket-geos-244.xml}     |   0
 .../ticket/{bug275.xml => ticket-geos-275.xml}     |   0
 .../ticket/{bug344.xml => ticket-geos-344.xml}     |   0
 .../ticket/{bug350.xml => ticket-geos-350.xml}     |   0
 .../ticket/{bug356.xml => ticket-geos-356.xml}     |   0
 .../ticket/{bug358.xml => ticket-geos-358.xml}     |   0
 .../ticket/{bug360.xml => ticket-geos-360.xml}     |   0
 .../ticket/{bug366.xml => ticket-geos-366.xml}     |   0
 .../ticket/{bug392.xml => ticket-geos-392.xml}     |   0
 .../ticket/{bug398.xml => ticket-geos-398.xml}     |   0
 .../ticket/{bug434.xml => ticket-geos-434.xml}     |   0
 .../ticket/{bug459.xml => ticket-geos-459.xml}     |   0
 .../ticket/{bug488.xml => ticket-geos-488.xml}     |   0
 .../ticket/{bug527.xml => ticket-geos-527.xml}     |   0
 .../ticket/{bug569.xml => ticket-geos-569.xml}     |   0
 .../ticket/{bug582.xml => ticket-geos-582.xml}     |   0
 .../ticket/{bug586.xml => ticket-geos-586.xml}     |   0
 .../ticket/{bug599.xml => ticket-geos-599.xml}     |   0
 .../ticket/{bug605.xml => ticket-geos-605.xml}     |   0
 .../ticket/{bug615.xml => ticket-geos-615.xml}     |   0
 .../ticket/{bug716.xml => ticket-geos-716.xml}     |   0
 .../ticket/{bug837.xml => ticket-geos-837.xml}     |   0
 .../ticket/{bug838.xml => ticket-geos-838.xml}     |   0
 54 files changed, 138 insertions(+), 101 deletions(-)
 rename tests/xmltester/tests/{ => misc}/TestBigNastyBuffer.xml (100%)
 rename tests/xmltester/tests/{ => misc}/TestBufferExternal.xml (100%)
 rename tests/xmltester/tests/{ => misc}/TestBufferExternal2.xml (100%)
 rename tests/xmltester/tests/{ => misc}/TestIsValid.xml (100%)
 rename tests/xmltester/tests/{rt => misc}/TestSameDirection.xml (100%)
 rename tests/xmltester/tests/{ => misc}/badguy3.xml (100%)
 rename tests/xmltester/tests/{ => misc}/buffer.xml (100%)
 rename tests/xmltester/tests/{ => misc}/buildarea.xml (100%)
 rename tests/xmltester/tests/{ => misc}/fme.xml (100%)
 rename tests/xmltester/tests/{ => misc}/heisenbugs.xml (100%)
 rename tests/xmltester/tests/{ => misc}/hexwkb.xml (100%)
 rename tests/xmltester/tests/{ => misc}/hole_from_shell.xml (100%)
 rename tests/xmltester/tests/{ => misc}/hole_red.xml (100%)
 rename tests/xmltester/tests/{ => misc}/linemerge.xml (100%)
 rename tests/xmltester/tests/{ => misc}/makevalid.xml (100%)
 rename tests/xmltester/tests/{ => misc}/robustness.xml (100%)
 rename tests/xmltester/tests/{safe/16595.xml => misc/safe-16595.xml} (100%)
 rename tests/xmltester/tests/{safe/16596.xml => misc/safe-16596.xml} (100%)
 rename tests/xmltester/tests/{safe/TestBufferJagged.xml => misc/safe-TestBufferJagged.xml} (100%)
 rename tests/xmltester/tests/{ => misc}/singlesidedbuffer.xml (100%)
 rename tests/xmltester/tests/{ => misc}/split.xml (100%)
 rename tests/xmltester/tests/{stmlf => misc}/stmlf-cases-20061020-invalid-output.xml (100%)
 rename tests/xmltester/tests/{stmlf => misc}/stmlf-cases-20061020.xml (100%)
 rename tests/xmltester/tests/{stmlf => misc}/stmlf-cases-20070119.xml (100%)
 rename tests/xmltester/tests/{ => misc}/test.xml (100%)
 rename tests/xmltester/tests/{ => misc}/testLeaksBig.xml (100%)
 rename tests/xmltester/tests/ticket/{bug176.xml => ticket-geos-176.xml} (100%)
 rename tests/xmltester/tests/ticket/{bug188.xml => ticket-geos-188.xml} (100%)
 rename tests/xmltester/tests/ticket/{bug244.xml => ticket-geos-244.xml} (100%)
 rename tests/xmltester/tests/ticket/{bug275.xml => ticket-geos-275.xml} (100%)
 rename tests/xmltester/tests/ticket/{bug344.xml => ticket-geos-344.xml} (100%)
 rename tests/xmltester/tests/ticket/{bug350.xml => ticket-geos-350.xml} (100%)
 rename tests/xmltester/tests/ticket/{bug356.xml => ticket-geos-356.xml} (100%)
 rename tests/xmltester/tests/ticket/{bug358.xml => ticket-geos-358.xml} (100%)
 rename tests/xmltester/tests/ticket/{bug360.xml => ticket-geos-360.xml} (100%)
 rename tests/xmltester/tests/ticket/{bug366.xml => ticket-geos-366.xml} (100%)
 rename tests/xmltester/tests/ticket/{bug392.xml => ticket-geos-392.xml} (100%)
 rename tests/xmltester/tests/ticket/{bug398.xml => ticket-geos-398.xml} (100%)
 rename tests/xmltester/tests/ticket/{bug434.xml => ticket-geos-434.xml} (100%)
 rename tests/xmltester/tests/ticket/{bug459.xml => ticket-geos-459.xml} (100%)
 rename tests/xmltester/tests/ticket/{bug488.xml => ticket-geos-488.xml} (100%)
 rename tests/xmltester/tests/ticket/{bug527.xml => ticket-geos-527.xml} (100%)
 rename tests/xmltester/tests/ticket/{bug569.xml => ticket-geos-569.xml} (100%)
 rename tests/xmltester/tests/ticket/{bug582.xml => ticket-geos-582.xml} (100%)
 rename tests/xmltester/tests/ticket/{bug586.xml => ticket-geos-586.xml} (100%)
 rename tests/xmltester/tests/ticket/{bug599.xml => ticket-geos-599.xml} (100%)
 rename tests/xmltester/tests/ticket/{bug605.xml => ticket-geos-605.xml} (100%)
 rename tests/xmltester/tests/ticket/{bug615.xml => ticket-geos-615.xml} (100%)
 rename tests/xmltester/tests/ticket/{bug716.xml => ticket-geos-716.xml} (100%)
 rename tests/xmltester/tests/ticket/{bug837.xml => ticket-geos-837.xml} (100%)
 rename tests/xmltester/tests/ticket/{bug838.xml => ticket-geos-838.xml} (100%)
hooks/post-receive
More information about the geos-commits mailing list
