[geos-commits] [SCM] GEOS branch 3.7 updated. 291a818bdccd2c986a88aab79b2b87805a579d53
Thu May 2 15:48:33 PDT 2019
the project "GEOS".
The branch, 3.7 has been updated
       via  291a818bdccd2c986a88aab79b2b87805a579d53 (commit)
       via  b55d21254ab667f942c5ce0c85e937509992d3ee (commit)
      from  0cd06b20e07c291d976c5f27ee99d9ac95c8e2ea (commit)
revisions in full, below.
commit 291a818bdccd2c986a88aab79b2b87805a579d53
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Thu May 2 15:47:41 2019 -0700
    Bump up version numbers for 3.7.3dev
diff --git a/CMakeLists.txt b/CMakeLists.txt
index 5d03bd3..81153c7 100644
--- a/CMakeLists.txt
+++ b/CMakeLists.txt
@@ -23,7 +23,7 @@ endif()
 # Set GEOS project
-project(GEOS VERSION 3.7.2 LANGUAGES C CXX)
+project(GEOS VERSION 3.7.3 LANGUAGES C CXX)
 # Add custom GEOS modules for CMake
 list(APPEND CMAKE_MODULE_PATH "${PROJECT_SOURCE_DIR}/cmake/modules")
@@ -58,7 +58,7 @@ message(STATUS "Setting GEOS version ${VERSION} as port of JTS ${JTS_PORT}")
 # GEOS C API version
 set(CAPI_INTERFACE_CURRENT 12)
-set(CAPI_INTERFACE_REVISION 0)
+set(CAPI_INTERFACE_REVISION 3)
 set(CAPI_INTERFACE_AGE 11)
 math(EXPR CAPI_VERSION_MAJOR "${CAPI_INTERFACE_CURRENT} - ${CAPI_INTERFACE_AGE}")
diff --git a/HOWTO_RELEASE b/HOWTO_RELEASE
index 5a7bbea..39a4b93 100644
--- a/HOWTO_RELEASE
+++ b/HOWTO_RELEASE
@@ -12,7 +12,7 @@
    $ git tag MAJOR.MINOR.PATCH
 6. Run 'make dist-bzip2'.
-   $ ./autogen.sh && ./configure && make dist-bzip2
+   $ make distclean && ./autogen.sh && ./configure && make dist-bzip2
 7. Verify that you can unpack and build the tarball
diff --git a/NEWS b/NEWS
index 1388a18..ac2eb64 100644
--- a/NEWS
+++ b/NEWS
@@ -1,5 +1,12 @@
 Changes in 3.7.2
-2018-05-02
+2019-XX-XX
+- Bug fixes / improvements
+Changes in 3.7.2
+2019-05-02
   - Envelope constructor using strtod (#875 Paul Ramsey)
diff --git a/capi/geos_c.h.in b/capi/geos_c.h.in
index b06b68b..f665e1c 100644
--- a/capi/geos_c.h.in
+++ b/capi/geos_c.h.in
@@ -61,7 +61,7 @@ extern "C" {
 #define GEOS_CAPI_VERSION_MAJOR 1
 #define GEOS_CAPI_VERSION_MINOR 11
 #define GEOS_CAPI_VERSION_PATCH 0
-#define GEOS_CAPI_VERSION "3.7.2-CAPI-1.11.0"
+#define GEOS_CAPI_VERSION "3.7.3-CAPI-1.11.0"
 #else
 #ifndef GEOS_VERSION_MAJOR
 #define GEOS_VERSION_MAJOR @VERSION_MAJOR@
diff --git a/configure.ac b/configure.ac
index 7bf3d6c..659c612 100644
--- a/configure.ac
+++ b/configure.ac
@@ -15,7 +15,7 @@ JTS_PORT=1.13.0
 dnl -- Version info for the CAPI
 CAPI_INTERFACE_CURRENT=12
-CAPI_INTERFACE_REVISION=2
+CAPI_INTERFACE_REVISION=3
 CAPI_INTERFACE_AGE=11
 dnl
@@ -24,7 +24,7 @@ dnl -- encoding ABI break at every release
 dnl
 VERSION_MAJOR=3
 VERSION_MINOR=7
-VERSION_PATCH=2dev
+VERSION_PATCH=3dev
 VERSION="$VERSION_MAJOR.$VERSION_MINOR.$VERSION_PATCH"
 VERSION_RELEASE=`echo "$VERSION" | sed -E 's/^([[0-9]+\.[0-9]+\.[0-9]+]).*$/\1/'`
diff --git a/include/geos/version.h.vc b/include/geos/version.h.vc
index de10989..313c2fa 100644
--- a/include/geos/version.h.vc
+++ b/include/geos/version.h.vc
@@ -34,11 +34,11 @@
 #endif
 #ifndef GEOS_VERSION_PATCH
-#define GEOS_VERSION_PATCH 2
+#define GEOS_VERSION_PATCH 3
 #endif
-#define GEOS_VERSION "3.7.2"
+#define GEOS_VERSION "3.7.3"
 #endif
 #ifndef GEOS_JTS_PORT
commit b55d21254ab667f942c5ce0c85e937509992d3ee
Date:   Thu May 2 15:23:56 2019 -0700
    Set date for 3.7.2 release
index 72fa921..1388a18 100644
--- a/NEWS
+++ b/NEWS
@@ -1,5 +1,5 @@
 Changes in 3.7.2
-2018-XX-XX
+2018-05-02
@@ -8,7 +8,6 @@ Changes in 3.7.2
   - Invalid union result from valid polygon inputs (#838)
 Changes in 3.7.1
 2018-11-29
Summary of changes:
 CMakeLists.txt            |  4 ++--
 HOWTO_RELEASE             |  2 +-
 NEWS                      | 10 ++++++++--
 capi/geos_c.h.in          |  2 +-
 configure.ac              |  4 ++--
 include/geos/version.h.vc |  4 ++--
 6 files changed, 16 insertions(+), 10 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
