[geos-commits] [SCM] GEOS branch master updated. b15fd1171823d16195bee17f2c7b44778603258d
Thu May 16 19:47:20 PDT 2019
the project "GEOS".
       via  b15fd1171823d16195bee17f2c7b44778603258d (commit)
       via  57a795ca9ab9e6f6469326c9b02f2d73462dd67c (commit)
       via  952dc4f5c6fb76f6438f668bdf58a6d01973fda5 (commit)
       via  1aedfca497d6de23bd3a857191da10b98b6b01f0 (commit)
      from  2a6111a70dec2d31ff4fb133782783f7f857c4ee (commit)
revisions in full, below.
commit b15fd1171823d16195bee17f2c7b44778603258d
Merge: 2a6111a 57a795c
Author: pramsey <pramsey at cleverelephant.ca>
Date:   Thu May 16 19:47:19 2019 -0700
    Merge branch 'modern-cmake' of pramsey/geos into master
commit 57a795ca9ab9e6f6469326c9b02f2d73462dd67c
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Thu May 16 16:17:07 2019 -0500
    Add moved tests to autotools build, fix cmake versions.txt filename
diff --git a/CMakeLists.txt b/CMakeLists.txt
index 9e6c0ef..3a6ae79 100644
--- a/CMakeLists.txt
+++ b/CMakeLists.txt
@@ -44,7 +44,7 @@ mark_as_advanced(GEOS_BUILD_DEVELOPER)
 # Version
-file(READ version.txt _version_txt)
+file(READ Version.txt _version_txt)
 string(REGEX MATCH "GEOS_VERSION_MAJOR=([0-9]+)" _ ${_version_txt})
 set(_version_major ${CMAKE_MATCH_1})
diff --git a/tests/xmltester/Makefile.am b/tests/xmltester/Makefile.am
index fc34b9d..ff96f47 100644
--- a/tests/xmltester/Makefile.am
+++ b/tests/xmltester/Makefile.am
@@ -117,11 +117,11 @@ INVALID_OUTPUT_XMLTESTS =
 FAILING_XMLTESTS = \
 	$(srcdir)/tests/failure/TestOverlay.xml \
-	$(srcdir)/tests/issue/issue-geos-488.xml \
-	$(srcdir)/tests/issue/issue-geos-344.xml \
-	$(srcdir)/tests/robust/TestRobustRelateFloat.xml \
-	$(srcdir)/tests/misc/TestBigNastyBuffer.xml \
-	$(srcdir)/tests/misc/TestSameDirection.xml
+	$(srcdir)/tests/failure/issue-geos-488.xml \
+	$(srcdir)/tests/failure/issue-geos-344.xml \
+	$(srcdir)/tests/failure/robust-TestRobustRelateFloat.xml \
+	$(srcdir)/tests/failure/misc-TestBigNastyBuffer.xml \
+	$(srcdir)/tests/failure/misc-TestSameDirection.xml
commit 952dc4f5c6fb76f6438f668bdf58a6d01973fda5
Date:   Thu May 16 15:59:54 2019 -0500
    Add new Cmake files to autoconf file list.
    Remove deprecated Cmake files from autoconf.
diff --git a/Makefile.am b/Makefile.am
index de7728f..ee5c238 100644
--- a/Makefile.am
+++ b/Makefile.am
@@ -26,10 +26,10 @@ BUILT_SOURCES = geos_revision.h
 EXTRA_DIST = acsite.m4 .editorconfig \
 	Version.txt CMakeLists.txt \
-	cmake/modules/CheckPrototypeExists.cmake \
-	cmake/modules/COPYING-CMAKE-SCRIPTS \
-	cmake/modules/GenerateSourceGroups.cmake \
-	cmake/cmake_uninstall.cmake.in geos_revision.h \
+	cmake/GenerateRevisionHeader.cmake \
+	cmake/GetGitRevision.cmake \
+	cmake/cmake_uninstall.cmake.in \
+	cmake/geos-config.cmake \
 	README.md
 ACLOCAL_AMFLAGS = -I macros
commit 1aedfca497d6de23bd3a857191da10b98b6b01f0
Author: Mateusz Łoskot <mateusz at loskot.net>
Date:   Sat Oct 20 11:59:15 2018 +0200
    Modernize CMake configuration
    Refactoring based on practices of the Modern CMake approach:
    * Set project version based on `version.txt` spec.
    * Build shared libraries by default.
    * Build tools and `geos-config` script.
    * Add make `check` target to run `ctest` (no dependencies).
    * Move failing/overlarge tests into `failure` directory.
    * Add target to deploy Config-module with installed targets:
      `GEOS::geos`, `GEOS::geos_c`.
    * Add basic uninstall target
    * Add basic client example configured with CMake to use GEOS targets.
diff --git a/.editorconfig b/.editorconfig
index 9f4132e..4b4c95d 100644
--- a/.editorconfig
+++ b/.editorconfig
@@ -37,6 +37,8 @@ end_of_line = crlf
 [CMakeLists.txt]
 indent_style = space
 indent_size = 2
+trim_trailing_whitespace = true
+insert_final_newline = true
 # CMake modules
 [*.cmake]
diff --git a/.gitignore b/.gitignore
index 3539e0a..725d990 100644
--- a/.gitignore
+++ b/.gitignore
@@ -1,4 +1,5 @@
 /*build*
+/*install*
 aclocal.m4
 Makefile.in
 Makefile
index 2f00af5..9e6c0ef 100644
@@ -1,336 +1,263 @@
+# Part of CMake configuration for GEOS
-# Main GEOS build configuration file for CMake build system
-# Copyright (C) 2009 Mateusz Loskot <mateusz at loskot.net>
+# Copyright (C) 2018-2019 Mateusz Loskot <mateusz at loskot.net>
 # This is free software; you can redistribute and/or modify it under
 # the terms of the GNU Lesser General Public Licence as published
 # by the Free Software Foundation.
 # See the COPYING file for more information.
-cmake_minimum_required(VERSION 3.1.3)
-if(NOT CMAKE_VERSION)
-  set(CMAKE_VERSION
-    "${CMAKE_MAJOR_VERSION}.${CMAKE_MINOR_VERSION}.${CMAKE_PATCH_VERSION}")
-endif()
+# Require CMake 3.8+ with support for meta-features that request compiler
+# modes for specific C/C++ language standard levels.
+cmake_minimum_required(VERSION 3.8)
-if(POLICY CMP0048)
-  cmake_policy(SET CMP0048 NEW)
+# Require CMake 3.14+ with VS generator for complete support of VS versions.
+if(${CMAKE_GENERATOR} MATCHES "Visual Studio")
+  cmake_minimum_required(VERSION 3.14 FATAL_ERROR)
 endif()
-# Set GEOS project
-project(GEOS LANGUAGES C CXX)
-# Add custom GEOS modules for CMake
-list(APPEND CMAKE_MODULE_PATH "${PROJECT_SOURCE_DIR}/cmake/modules")
-# Set C++ standard
-set(CMAKE_CXX_STANDARD 11)
-set(CMAKE_CXX_STANDARD_REQUIRED ON)
-set(CMAKE_CXX_EXTENSIONS OFF)
-message(STATUS "Setting C++ requirement to C++${CMAKE_CXX_STANDARD}")
-# Setup GEOS version
-# READ GEOS VERSIONS FROM FILE
-file(READ "Version.txt" VERSION_TXT)
+list(APPEND CMAKE_MODULE_PATH "${PROJECT_SOURCE_DIR}/cmake")
-string(REGEX MATCH "GEOS_VERSION_MAJOR=([0-9]+)" _ ${VERSION_TXT})
-set(GEOS_VERSION_MAJOR ${CMAKE_MATCH_1})
-string(REGEX MATCH "GEOS_VERSION_MINOR=([0-9]+)" _ ${VERSION_TXT})
-set(GEOS_VERSION_MINOR ${CMAKE_MATCH_1})
-string(REGEX MATCH "GEOS_VERSION_PATCH=([0-9]+)" _ ${VERSION_TXT})
-set(GEOS_VERSION_PATCH ${CMAKE_MATCH_1})
+# TODO: Follow CMake detection of git and version tagging
+#       https://gitlab.kitware.com/cmake/cmake/blob/master/Source/CMakeVersionSource.cmake
+if(EXISTS ${CMAKE_SOURCE_DIR}/.git/HEAD)
+  set(GEOS_BUILD_FROM_GIT ON)
+endif()
+# Options
+include(CMakeDependentOption)
+## CMake global variables
+option(BUILD_SHARED_LIBS "Build GEOS with shared libraries" ON)
+set(CMAKE_CXX_STANDARD 11 CACHE STRING "C++ standard version to use (default is 11)")
+## GEOS custom variables
+cmake_dependent_option(GEOS_BUILD_DEVELOPER
+  "Build with compilation flags useful for development" ON
+  "GEOS_BUILD_FROM_GIT" OFF)
+mark_as_advanced(GEOS_BUILD_DEVELOPER)
+# Version
+file(READ version.txt _version_txt)
+string(REGEX MATCH "GEOS_VERSION_MAJOR=([0-9]+)" _ ${_version_txt})
+set(_version_major ${CMAKE_MATCH_1})
+string(REGEX MATCH "GEOS_VERSION_MINOR=([0-9]+)" _ ${_version_txt})
+set(_version_minor ${CMAKE_MATCH_1})
+string(REGEX MATCH "GEOS_VERSION_PATCH=([0-9]+)" _ ${_version_txt})
+set(_version_patch ${CMAKE_MATCH_1})
 # OPTIONS: "", "dev", "rc1" etc.
-string(REGEX MATCH "GEOS_PATCH_WORD=([a-zA-Z0-9]+)" _ ${VERSION_TXT})
-set(GEOS_PATCH_WORD ${CMAKE_MATCH_1})
-string(REGEX MATCH "CAPI_INTERFACE_CURRENT=([0-9]+)" _ ${VERSION_TXT})
-set(CAPI_INTERFACE_CURRENT ${CMAKE_MATCH_1})
-string(REGEX MATCH "CAPI_INTERFACE_REVISION=([0-9]+)" _ ${VERSION_TXT})
-set(CAPI_INTERFACE_REVISION ${CMAKE_MATCH_1})
-string(REGEX MATCH "CAPI_INTERFACE_AGE=([0-9]+)" _ ${VERSION_TXT})
-set(CAPI_INTERFACE_AGE ${CMAKE_MATCH_1})
-# GEOS release version
-# GEOS C++ library SONAME will use these encoding ABI break at every release
-set(GEOS_VERSION "${GEOS_VERSION_MAJOR}.${GEOS_VERSION_MINOR}.${GEOS_VERSION_PATCH}${GEOS_PATCH_WORD}")
-set(VERSION "${GEOS_VERSION}")
+string(REGEX MATCH "GEOS_PATCH_WORD=([a-zA-Z0-9]+)" _ ${_version_txt})
+set(_version_patch_word ${CMAKE_MATCH_1})
-# Copy version components into different variable names to match those used
-# by autotools for *.h.in files
-set(VERSION_MAJOR "${GEOS_VERSION_MAJOR}")
-set(VERSION_MINOR "${GEOS_VERSION_MINOR}")
-set(VERSION_PATCH "${GEOS_VERSION_PATCH}${GEOS_PATCH_WORD}")
-# JTS_PORT is the version of JTS this release is bound to
-string(REGEX MATCH "JTS_PORT=([0-9a-zA-Z\.]+)" _ ${VERSION_TXT})
+# Version of JTS this release is bound to
+string(REGEX MATCH "JTS_PORT=([0-9a-zA-Z\.]+)" _ ${_version_txt})
 set(JTS_PORT ${CMAKE_MATCH_1})
-message(STATUS "Setting GEOS version ${VERSION} as port of JTS ${JTS_PORT}")
-math(EXPR CAPI_VERSION_MAJOR "${CAPI_INTERFACE_CURRENT} - ${CAPI_INTERFACE_AGE}")
-set(CAPI_VERSION_MINOR ${CAPI_INTERFACE_AGE})
-set(CAPI_VERSION_PATCH ${CAPI_INTERFACE_REVISION})
-set(CAPI_VERSION "${CAPI_VERSION_MAJOR}.${CAPI_VERSION_MINOR}.${CAPI_VERSION_PATCH}")
-message(STATUS "Setting GEOS C API version ${CAPI_VERSION}")
-if (NOT WIN32)
-  set(CAPI_SOVERSION ${CAPI_VERSION_MAJOR})
-  message(STATUS "Setting GEOS C API soversion ${CAPI_SOVERSION}")
+# Version of public C API
+string(REGEX MATCH "CAPI_INTERFACE_CURRENT=([0-9]+)" _ ${_version_txt})
+set(_version_capi_current ${CMAKE_MATCH_1})
+string(REGEX MATCH "CAPI_INTERFACE_REVISION=([0-9]+)" _ ${_version_txt})
+set(_version_capi_revision ${CMAKE_MATCH_1})
+string(REGEX MATCH "CAPI_INTERFACE_AGE=([0-9]+)" _ ${_version_txt})
+set(_version_capi_age ${CMAKE_MATCH_1})
+unset(_version_txt)
+math(EXPR _version_capi_major "${_version_capi_current} - ${_version_capi_age}")
+set(CAPI_VERSION_MAJOR ${_version_capi_major})
+set(CAPI_VERSION_MINOR ${_version_capi_age})
+set(CAPI_VERSION_PATCH ${_version_capi_revision})
+set(CAPI_VERSION "${_version_capi_major}.${_version_capi_age}.${_version_capi_revision}")
+if(NOT WIN32)
+  set(CAPI_SOVERSION ${_version_capi_age})
 endif()
-# Check custom global options
-option(GEOS_ENABLE_INLINE
-  "Set to OFF|ON (default) to control GEOS compilation with small functions inlining" ON)
-if(NOT MSVC)
-  option(GEOS_ENABLE_ASSERT
-    "Set to ON|OFF (default) to build GEOS with assert() macro enabled" OFF)
-endif()
-option(GEOS_ENABLE_TESTS
-  "Set to OFF|ON (default) to control build of GEOS tests package" ON)
-option(GEOS_ENABLE_TESTS_UNIT2_ONLY
-  "Set to ON|OFF (default) to enable only new tests based on Catch (WIP: experimental)." OFF)
+unset(_version_capi_current)
+unset(_version_capi_major)
+unset(_version_capi_age)
+unset(_version_capi_revision)
-option(GEOS_BUILD_STATIC
-  "Set to OFF|ON (default) to build GEOS static libraries" ON)
-option(GEOS_BUILD_SHARED
-  "Set to OFF|ON (default) to build GEOS shared libraries" ON)
-if(CMAKE_COMPILER_IS_GNUCC OR CMAKE_COMPILER_IS_GNUCXX)
-  option(GEOS_ENABLE_FLOATSTORE
-    "Set to OFF|ON (default) to control IEEE754 conformance and remove extra precision" ON)
+# Project
+if(CMAKE_VERSION VERSION_GREATER_EQUAL 3.9)
+  list(APPEND _project_info DESCRIPTION "GEOS - C++ port of the Java Topology Suite (JTS)")
 endif()
-if(APPLE)
-  option(GEOS_ENABLE_MACOSX_FRAMEWORK
-    "Set to ON|OFF (default) to build GEOS as a Mac OS X framework" OFF)
-  option(GEOS_ENABLE_MACOSX_FRAMEWORK_UNIXCOMPAT
-    "Set to ON|OFF (default) to add Unix compatibility to the Mac OS X framework" OFF)
+if(CMAKE_VERSION VERSION_GREATER_EQUAL 3.12)
+  list(APPEND _project_info HOMEPAGE_URL "http://geos.osgeo.org")
 endif()
-# Setup C/C++ compiler options
-if(NOT MSVC_IDE)
-  if(NOT CMAKE_BUILD_TYPE)
-    set(CMAKE_BUILD_TYPE Debug CACHE STRING
-      "Choose the type of build, options are: None Debug Release" FORCE)
-  endif()
-  message(STATUS "Setting GEOS build type - ${CMAKE_BUILD_TYPE}")
-endif()
+project(GEOS VERSION "${_version_major}.${_version_minor}.${_version_patch}"
+  LANGUAGES C CXX
+  ${_project_info})
-if(CMAKE_BUILD_TYPE STREQUAL Debug)
-  add_definitions(-D_DEBUG)
+if("${_version_patch_word}" STREQUAL "")
+  set(GEOS_VERSION_FULL "${GEOS_VERSION}")
+else()
+  set(GEOS_VERSION_FULL "${GEOS_VERSION}-${_version_patch_word}")
 endif()
-add_definitions(-DUSE_UNSTABLE_GEOS_CPP_API)
+unset(_version_major)
+unset(_version_minor)
+unset(_version_patch)
+unset(_version_patch_word)
-  # General options
-  set(CMAKE_C_FLAGS "-pedantic -ansi ${CMAKE_C_FLAGS}")
+message(STATUS "GEOS: Version ${GEOS_VERSION_FULL}")
+message(STATUS "GEOS: C API soversion ${CAPI_SOVERSION}")
+message(STATUS "GEOS: JTS port ${JTS_PORT}")
-  # Numerical stability
-  if(GEOS_ENABLE_FLOATSTORE)
-    # Remove extra precision by forcing conformance to IEEE 754 rather than IEEE 854
-    set(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} -ffloat-store")
-  endif()
-  message(STATUS
-    "Forcing IEEE 754 using flag -ffloat-store - ${GEOS_ENABLE_FLOATSTORE}")
-  # Warnings specification
-  set(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} -Wall -Wno-long-long -fno-implicit-inline-templates -Wconversion -pedantic -W -Wunused -Wuninitialized -Wextra -Wdouble-promotion -Wshadow")
-  # Turn on Position Independent Code generation for GEOS C shared library
-  set(CMAKE_C_FLAGS "${CMAKE_C_FLAGS} -fPIC -Wall -Wconversion -pedantic -Wmissing-prototypes -W -Wunused -Wuninitialized -Wextra -Wdouble-promotion")
-  # Enable glibc ISO C99 features (macros isfinite, isnan)
-  set(CMAKE_REQUIRED_DEFINITIONS "${CMAKE_REQUIRED_DEFINITIONS} -D_ISOC99_SOURCE=1")
-  # For now, punt on ASM on MinGW (Windows+GCC)
-  if(WIN32)
-    set(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} -DTTMATH_NOASM")
-    message(STATUS "Setting TTMATH_NOASM")
-  endif()
-elseif(MSVC)
+# C++ language version and compilation flags
+message(STATUS "GEOS: Require C++${CMAKE_CXX_STANDARD}")
+set(CMAKE_CXX_STANDARD_REQUIRED ON)
+set(CMAKE_CXX_EXTENSIONS OFF)
-  # Set pedantic mode by default
-  #set(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} /W4")
-  string(REGEX REPLACE "/W[0-9]" "/W4" CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS}")
+# Target geos_cxx_flags: common compilation flags
+add_library(geos_cxx_flags INTERFACE)
+target_compile_features(geos_cxx_flags INTERFACE cxx_std_11)
+option(DISABLE_GEOS_INLINE "Disable inlining" OFF)
+if(NOT DISABLE_GEOS_INLINE)
+  target_compile_definitions(geos_cxx_flags INTERFACE GEOS_INLINE)
+endif()
-  if(MSVC)
-    set(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} /MP")
-    add_definitions(-D_SCL_SECURE_NO_WARNINGS)
-    add_definitions(-D_CRT_SECURE_NO_WARNINGS)
-    add_definitions(-DNOMINMAX)
-  endif()
+# Target geos_developer_cxx_flags: developer mode compilation flags
+# Do NOT install this target for end-users!
+add_library(geos_developer_cxx_flags INTERFACE)
+if(GEOS_BUILD_DEVELOPER)
+  message(STATUS "GEOS: Developer mode enabled")
 endif()
-if(GEOS_ENABLE_INLINE)
-  add_definitions(-DGEOS_INLINE)
+# geos_cxx_flags inherits properties from geos_developer_cxx_flags when
+# building as part of the GEOS repository or on explicit request for
+# developer compilation mode, as GEOS contributor.
+# The flags are intended only for GEOS itself and are not part of
+# usage requirements needed by GEOS consumers.
+  target_link_libraries(geos_cxx_flags
+    INTERFACE
+      $<BUILD_INTERFACE:geos_developer_cxx_flags>)
 endif()
-message(STATUS
-  "Setting GEOS compilation with small functions inlining - ${GEOS_ENABLE_INLINE}")
-if(NOT MSVC)
-  if(GEOS_ENABLE_ASSERT)
-    string(REGEX REPLACE "[-/]D.*NDEBUG" "-U NDEBUG"
-      CMAKE_CXX_FLAGS_RELEASE "${CMAKE_CXX_FLAGS_RELEASE}")
-  endif()
-  message(STATUS
-    "Setting GEOS compilation with assert() macro enabled - ${GEOS_ENABLE_ASSERT}")
+target_compile_definitions(geos_developer_cxx_flags
+  INTERFACE
+    USE_UNSTABLE_GEOS_CPP_API)
+  INTERFACE
+    $<$<CXX_COMPILER_ID:MSVC>:_CRT_NONSTDC_NO_DEPRECATE>
+    $<$<CXX_COMPILER_ID:MSVC>:_SCL_SECURE_NO_DEPRECATE>
+    $<$<CXX_COMPILER_ID:MSVC>:_CRT_SECURE_NO_WARNINGS>
+    $<$<CXX_COMPILER_ID:MSVC>:NOMINMAX>)
+target_compile_options(geos_developer_cxx_flags
+  INTERFACE
+    $<$<CXX_COMPILER_ID:MSVC>:-W4>
+    $<$<OR:$<CXX_COMPILER_ID:GNU>,$<CXX_COMPILER_ID:Clang>>:-pedantic -Wall -Wextra -Wno-long-long -Wcast-align -Wconversion -Wchar-subscripts -Wdouble-promotion -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wuninitialized -Wunused-parameter -fno-common>
+    $<$<CXX_COMPILER_ID:GNU>:-fno-implicit-inline-templates>)
+# Disable TTMath ASM support on MinGW (Windows+GCC)
+# due to build issues
+if(MINGW)
+    INTERFACE TTMATH_NOASM)
 endif()
-# Setup C/C++ library features
-if (false)
-# check header files
-include(CheckIncludeFiles)
-check_include_files(stdint.h HAVE_STDINT_H)
-check_include_files(inttypes.h HAVE_INTTYPES_H)
-check_include_files(ieeefp.h HAVE_IEEEFP_H)
-# check types and sizes
-include(CheckTypeSize)
+# Target geos: C++ API library
+add_library(geos "")
+target_link_libraries(geos PUBLIC geos_cxx_flags)
+add_subdirectory(include)
+add_subdirectory(src)
-if(MSVC)
-  check_type_size("__int64" HAVE_INT64_T_64)
-else()
-  if(HAVE_STDINT_H OR HAVE_INTTYPES_H)
-    check_type_size("int64_t" HAVE_INT64_T_64)
-  else()
-    check_type_size("long long int" HAVE_LONG_LONG_INT_64)
+if(BUILD_SHARED_LIBS)
+  set_target_properties(geos PROPERTIES VERSION ${GEOS_VERSION})
+  if(NOT WIN32)
+    set_target_properties(geos PROPERTIES SOVERSION ${GEOS_VERSION_MAJOR})
   endif()
 endif()
-endif()
-# Setup build directories
-# Put the libaries and binaries that get built into directories at the
-# top of the build tree rather than in hard-to-find leaf
-# directories. This simplifies manual testing and the use of the build
-# tree rather than installed Boost libraries.
-set(CMAKE_LIBRARY_OUTPUT_DIRECTORY ${CMAKE_BINARY_DIR}/lib)
-set(CMAKE_ARCHIVE_OUTPUT_DIRECTORY ${CMAKE_BINARY_DIR}/lib)
-set(CMAKE_RUNTIME_OUTPUT_DIRECTORY ${CMAKE_BINARY_DIR}/bin)
-# Setup include directories
-# for including GEOS C++ API headers
-include_directories(${PROJECT_SOURCE_DIR}/include)
-# for including build-specific GEOS C API headers
-include_directories(${PROJECT_BINARY_DIR}/capi)
-# for including build-specific version.h and geos_c.h
-include_directories(${PROJECT_BINARY_DIR}/include)
-# for geos_ts.cpp which does #include "../geos_revision.h" whereas
-# CMake generates geos_revision.h in build directory,
-# to not to pollute source tree.
-include_directories(${PROJECT_BINARY_DIR})
-# Setup checks and generate config headers
-find_package(Git)
-message(STATUS "Generating GEOS ${PROJECT_BINARY_DIR}/geos_revision.h")
-file(WRITE ${CMAKE_BINARY_DIR}/geos_revision.h.in "\#define GEOS_REVISION \"@GEOS_REVISION@\"\n")
-file(WRITE ${CMAKE_BINARY_DIR}/geos_revision.cmake
-execute_process(COMMAND \${GIT} describe --tags --always
-  WORKING_DIRECTORY \${CWD}
-  OUTPUT_VARIABLE GEOS_REVISION
-  OUTPUT_STRIP_TRAILING_WHITESPACE)
-configure_file(\${SRC} \${DST} @ONLY)
-add_custom_target(geos_revision
-  COMMAND ${CMAKE_COMMAND}
-    -D CWD=${CMAKE_CURRENT_SOURCE_DIR}
-    -D GIT=${GIT_EXECUTABLE}
-    -D SRC=${PROJECT_BINARY_DIR}/geos_revision.h.in
-    -D DST=${PROJECT_BINARY_DIR}/geos_revision.h
-    -P ${PROJECT_BINARY_DIR}/geos_revision.cmake)
-message(STATUS "Generating GEOS ${PROJECT_BINARY_DIR}/include/geos/version.h")
-configure_file(${PROJECT_SOURCE_DIR}/include/geos/version.h.in
-  ${PROJECT_BINARY_DIR}/include/geos/version.h @ONLY)
-message(STATUS "Generating GEOS ${PROJECT_BINARY_DIR}/capi/geos_c.h")
-configure_file(${PROJECT_SOURCE_DIR}/capi/geos_c.h.in
-  ${PROJECT_BINARY_DIR}/capi/geos_c.h @ONLY)
-# Configure tests
-if(GEOS_ENABLE_TESTS OR GEOS_ENABLE_TESTS_UNIT2_ONLY)
-  enable_testing()
-  # Define "make check" as alias for "make test"
-  add_custom_target(check COMMAND ctest)
-endif()
+# Target geos_c: C API library
+add_library(geos_c "")
+target_link_libraries(geos_c PRIVATE geos)
+add_subdirectory(capi)
-# IDE specifics
-if (MSVC_IDE)
-  # Visual Studio 2017 supports .editorconfig, copy it next to generated .sln
-  message(STATUS "Copying .editorconfig file to ${PROJECT_BINARY_DIR}")
-  file(COPY "${PROJECT_SOURCE_DIR}/.editorconfig"
-    DESTINATION "${PROJECT_BINARY_DIR}")
+  set_target_properties(geos_c PROPERTIES VERSION ${GEOS_VERSION})
+  if(NOT WIN32)
+    set_target_properties(geos_c PROPERTIES SOVERSION ${GEOS_VERSION_MAJOR})
+  endif()
 endif()
-include(GenerateSourceGroups)
+# Tests
+include(CTest)
+if(BUILD_TESTING)
+  add_subdirectory(tests)
+endif()
-# Enable target debugging for CMake Tools in Visual Studio Code
-# https://github.com/vector-of-bool/vscode-cmake-tools
-include(CMakeToolsHelpers OPTIONAL)
+# Install and export targets - support 'make install' or equivalent
+include(CMakePackageConfigHelpers)
+write_basic_package_version_file(
+  "${CMAKE_CURRENT_BINARY_DIR}/geos-config-version.cmake"
+  VERSION ${GEOS_VERSION}
+  COMPATIBILITY AnyNewerVersion)
+configure_file(cmake/geos-config.cmake
+  "${CMAKE_CURRENT_BINARY_DIR}/geos-config.cmake"
+  COPYONLY)
+install(TARGETS geos geos_c geos_cxx_flags
+  EXPORT geos-targets
+  LIBRARY DESTINATION lib
+  ARCHIVE DESTINATION lib
+  RUNTIME DESTINATION bin
+  INCLUDES DESTINATION include)
+install(EXPORT geos-targets
+  FILE geos-targets.cmake
+  NAMESPACE GEOS::
+  DESTINATION lib/cmake/GEOS)
+install(FILES
+install(DIRECTORY
+  "${CMAKE_CURRENT_LIST_DIR}/include/geos"
+  "${CMAKE_CURRENT_BINARY_DIR}/include/geos"
+  DESTINATION include
+  FILES_MATCHING PATTERN "*.h")
+install(FILES "${CMAKE_CURRENT_BINARY_DIR}/capi/geos_c.h"
+  DESTINATION include)
-# Configure subdirectories
-add_subdirectory(include)
-add_subdirectory(src)
-add_subdirectory(capi)
-add_subdirectory(tests)
 add_subdirectory(tools)
-# Install/Uninstall
+# Uninstall
 configure_file("${PROJECT_SOURCE_DIR}/cmake/cmake_uninstall.cmake.in"
   "${PROJECT_BINARY_DIR}/cmake/cmake_uninstall.cmake"
@@ -339,11 +266,3 @@ configure_file("${PROJECT_SOURCE_DIR}/cmake/cmake_uninstall.cmake.in"
 add_custom_target(uninstall
   "${CMAKE_COMMAND}" -P "${PROJECT_BINARY_DIR}/cmake/cmake_uninstall.cmake")
-# DEBUG settings - TODO: make a summary
-message(STATUS "CMake ${CMAKE_VERSION} successfully configured ${PROJECT_NAME} using ${CMAKE_GENERATOR} generator")
-#message(STATUS "XXX: CMAKE_CXX_FLAGS=${CMAKE_CXX_FLAGS}")
-#message(STATUS "XXX: CMAKE_CXX_FLAGS_DEBUG=${CMAKE_CXX_FLAGS_DEBUG}")
-#message(STATUS "XXX: CMAKE_CXX_FLAGS_RELEASE=${CMAKE_CXX_FLAGS_RELEASE}")
diff --git a/appveyor.yml b/appveyor.yml
index c761223..d1d637e 100644
--- a/appveyor.yml
+++ b/appveyor.yml
@@ -1,81 +1,81 @@
-version: 1.0.{build}
-image: Visual Studio 2017
-platform: x64
-configuration: Release
-shallow_clone: true
-clone_depth: 5
-matrix:
-  fast_finish: false # set this flag to immediately finish build once one of the jobs fails.
-environment:
-  matrix:
-    - PLATFORM: x64
-      BUILDER: CMake
-      GENERATOR: "Visual Studio 15 2017 Win64"
-      APPVEYOR_BUILD_WORKER_IMAGE: Visual Studio 2017
-#    - PLATFORM: x86
-#      BUILDER: CMake
-#      GENERATOR: "Visual Studio 15 2017"
-#      APPVEYOR_BUILD_WORKER_IMAGE: Visual Studio 2017
-#    - PLATFORM: x64
-#      BUILDER: CMake
-#      GENERATOR: "NMake Makefiles"
-#    - PLATFORM: x86
-#      BUILDER: CMake
-#    - PLATFORM: x64
-#      BUILDER: CMake
-#      GENERATOR: "Visual Studio 14 2015 Win64"
-#      APPVEYOR_BUILD_WORKER_IMAGE: Visual Studio 2015
-#    - PLATFORM: x86
-#      BUILDER: CMake
-#      GENERATOR: "Visual Studio 14 2015"
-#    - PLATFORM: x64
-#      BUILDER: CMake
-    - PLATFORM: x86
-      BUILDER: CMake
-      GENERATOR: "NMake Makefiles"
-      APPVEYOR_BUILD_WORKER_IMAGE: Visual Studio 2015
-init:
-  - ps: 'Write-Host "Building GEOS branch: $env:APPVEYOR_REPO_BRANCH" -ForegroundColor Magenta'
-  #- ps: |
-  #  Write-Host "Build worker environment variables:" -ForegroundColor Magenta
-  #      Get-ChildItem Env: | %{"{0}={1}" -f $_.Name,$_.Value}
-  - if "%APPVEYOR_BUILD_WORKER_IMAGE%"=="Visual Studio 2017" if "%GENERATOR%"=="NMake Makefiles" if "%PLATFORM%"=="x86" call "C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\VC\Auxiliary\Build\vcvars32.bat"
-  - if "%APPVEYOR_BUILD_WORKER_IMAGE%"=="Visual Studio 2017" if "%GENERATOR%"=="NMake Makefiles" if "%PLATFORM%"=="x64" call "C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\VC\Auxiliary\Build\vcvars64.bat"
-  - if "%APPVEYOR_BUILD_WORKER_IMAGE%"=="Visual Studio 2015" if "%GENERATOR%"=="NMake Makefiles" if "%PLATFORM%"=="x86" call "C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\vcvarsall.bat" x86
-  - if "%APPVEYOR_BUILD_WORKER_IMAGE%"=="Visual Studio 2015" if "%GENERATOR%"=="NMake Makefiles" if "%PLATFORM%"=="x64" call "C:\Program Files\Microsoft SDKs\Windows\v7.1\Bin\SetEnv.cmd" /x64
-  - if "%APPVEYOR_BUILD_WORKER_IMAGE%"=="Visual Studio 2015" if "%GENERATOR%"=="NMake Makefiles" if "%PLATFORM%"=="x64" call "C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\vcvarsall.bat" x86_amd64
-before_build:
-  - ps: 'Write-Host "Running $env:BUILDER with $env:GENERATOR" -ForegroundColor Magenta'
-  - if "%BUILDER%"=="CMake" cmake.exe -G "%GENERATOR%" -DCMAKE_BUILD_TYPE=%CONFIGURATION% %APPVEYOR_BUILD_FOLDER%
-  - if "%BUILDER%"=="NMake" .\autogen.bat
-build_script:
-  - ps: 'Write-Host "Running $env:BUILDER:" -ForegroundColor Magenta'
-  - if "%BUILDER%"=="CMake" cmake --build . --config %CONFIGURATION%
-  - if "%BUILDER%"=="NMake" nmake /f makefile.vc
-test_script:
-  - ps: 'Write-Host "Running tests:" -ForegroundColor Magenta'
-  - if "%BUILDER%"=="CMake" ctest --output-on-failure -C %CONFIGURATION%
-  - if "%BUILDER%"=="NMake" echo *** NMake does NOT build tests ***
-# If you need to debug AppVeyor session (https://www.appveyor.com/docs/how-to/rdp-to-build-worker), then:
-# 1. Uncomment the on_finish section below:
-#on_finish:
-#  - ps: $blockRdp = $true; iex ((new-object net.webclient).DownloadString('https://raw.githubusercontent.com/appveyor/ci/master/scripts/enable-rdp.ps1'))
-# 2. Add this line to the init section below
-#- ps: iex ((new-object net.webclient).DownloadString('https://raw.githubusercontent.com/appveyor/ci/master/scripts/enable-rdp.ps1'))
+version: 1.0.{build}
+image: Visual Studio 2017
+platform: x64
+configuration: Release
+shallow_clone: true
+clone_depth: 5
+matrix:
+  fast_finish: false # set this flag to immediately finish build once one of the jobs fails.
+environment:
+  matrix:
+    - PLATFORM: x64
+      BUILDER: CMake
+      GENERATOR: "Visual Studio 15 2017 Win64"
+      APPVEYOR_BUILD_WORKER_IMAGE: Visual Studio 2017
+#    - PLATFORM: x86
+#      BUILDER: CMake
+#      GENERATOR: "Visual Studio 15 2017"
+#      APPVEYOR_BUILD_WORKER_IMAGE: Visual Studio 2017
+#    - PLATFORM: x64
+#      BUILDER: CMake
+#      GENERATOR: "NMake Makefiles"
+#    - PLATFORM: x86
+#      BUILDER: CMake
+#    - PLATFORM: x64
+#      BUILDER: CMake
+#      GENERATOR: "Visual Studio 14 2015 Win64"
+#      APPVEYOR_BUILD_WORKER_IMAGE: Visual Studio 2015
+#    - PLATFORM: x86
+#      BUILDER: CMake
+#      GENERATOR: "Visual Studio 14 2015"
+#    - PLATFORM: x64
+#      BUILDER: CMake
+    - PLATFORM: x86
+      BUILDER: CMake
+      GENERATOR: "NMake Makefiles"
+      APPVEYOR_BUILD_WORKER_IMAGE: Visual Studio 2015
+init:
+  - ps: 'Write-Host "Building GEOS branch: $env:APPVEYOR_REPO_BRANCH" -ForegroundColor Magenta'
+  #- ps: |
+  #  Write-Host "Build worker environment variables:" -ForegroundColor Magenta
+  #      Get-ChildItem Env: | %{"{0}={1}" -f $_.Name,$_.Value}
+  - if "%APPVEYOR_BUILD_WORKER_IMAGE%"=="Visual Studio 2017" if "%GENERATOR%"=="NMake Makefiles" if "%PLATFORM%"=="x86" call "C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\VC\Auxiliary\Build\vcvars32.bat"
+  - if "%APPVEYOR_BUILD_WORKER_IMAGE%"=="Visual Studio 2017" if "%GENERATOR%"=="NMake Makefiles" if "%PLATFORM%"=="x64" call "C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\VC\Auxiliary\Build\vcvars64.bat"
+  - if "%APPVEYOR_BUILD_WORKER_IMAGE%"=="Visual Studio 2015" if "%GENERATOR%"=="NMake Makefiles" if "%PLATFORM%"=="x86" call "C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\vcvarsall.bat" x86
+  - if "%APPVEYOR_BUILD_WORKER_IMAGE%"=="Visual Studio 2015" if "%GENERATOR%"=="NMake Makefiles" if "%PLATFORM%"=="x64" call "C:\Program Files\Microsoft SDKs\Windows\v7.1\Bin\SetEnv.cmd" /x64
+  - if "%APPVEYOR_BUILD_WORKER_IMAGE%"=="Visual Studio 2015" if "%GENERATOR%"=="NMake Makefiles" if "%PLATFORM%"=="x64" call "C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\vcvarsall.bat" x86_amd64
+before_build:
+  - ps: 'Write-Host "Running $env:BUILDER with $env:GENERATOR" -ForegroundColor Magenta'
+  - if "%BUILDER%"=="CMake" cmake.exe -G "%GENERATOR%" -DCMAKE_BUILD_TYPE=%CONFIGURATION% %APPVEYOR_BUILD_FOLDER%
+  - if "%BUILDER%"=="NMake" .\autogen.bat
+build_script:
+  - ps: 'Write-Host "Running $env:BUILDER:" -ForegroundColor Magenta'
+  - if "%BUILDER%"=="CMake" cmake --build . --config %CONFIGURATION%
+  - if "%BUILDER%"=="NMake" nmake /f makefile.vc
+test_script:
+  - ps: 'Write-Host "Running tests:" -ForegroundColor Magenta'
+  - if "%BUILDER%"=="CMake" ctest --output-on-failure -C %CONFIGURATION%
+  - if "%BUILDER%"=="NMake" echo *** NMake does NOT build tests ***
+# If you need to debug AppVeyor session (https://www.appveyor.com/docs/how-to/rdp-to-build-worker), then:
+# 1. Uncomment the on_finish section below:
+#on_finish:
+#  - ps: $blockRdp = $true; iex ((new-object net.webclient).DownloadString('https://raw.githubusercontent.com/appveyor/ci/master/scripts/enable-rdp.ps1'))
+# 2. Add this line to the init section below
+#- ps: iex ((new-object net.webclient).DownloadString('https://raw.githubusercontent.com/appveyor/ci/master/scripts/enable-rdp.ps1'))
diff --git a/capi/CMakeLists.txt b/capi/CMakeLists.txt
index b388b55..066b149 100644
--- a/capi/CMakeLists.txt
+++ b/capi/CMakeLists.txt
@@ -1,75 +1,47 @@
-# GEOS C library build configuration for CMake build system
+# Copyright (C) 2018 Mateusz Loskot <mateusz at loskot.net>
-if(WIN32)
-    add_definitions("-DGEOS_DLL_EXPORT=1")
-endif()
-set(geos_c_SOURCES
-  geos_c.cpp
-  geos_ts_c.cpp)
-file(GLOB geos_capi_HEADERS ${CMAKE_BINARY_DIR}/capi/*.h) # fix source_group issue
-if(NOT GEOS_ENABLE_MACOSX_FRAMEWORK AND GEOS_BUILD_SHARED)
-  # if building OS X framework or only building static libs, CAPI built into C++ library
-  add_library(geos_c SHARED ${geos_c_SOURCES})
-  target_link_libraries(geos_c geos)
-  if (WIN32)
-    set_target_properties(geos_c
-      PROPERTIES
-      VERSION ${CAPI_VERSION}
-      CLEAN_DIRECT_OUTPUT 1)
-  else()
-      PROPERTIES
-      SOVERSION ${CAPI_SOVERSION}
-  endif()
-  add_dependencies(geos_c geos_revision)
+if(GEOS_BUILD_FROM_GIT)
+  add_custom_target(geos_revision_header
+    COMMAND ${CMAKE_COMMAND}
+    -D DST=${CMAKE_BINARY_DIR}/geos_revision.h
+    -D CMAKE_MODULE_PATH="${PROJECT_SOURCE_DIR}/cmake"
+    -P ${CMAKE_SOURCE_DIR}/cmake/GenerateRevisionHeader.cmake
+    WORKING_DIRECTORY ${CMAKE_SOURCE_DIR})
 else()
-  add_library(geos_c INTERFACE)
-  target_link_libraries(geos_c INTERFACE geos-static)
+  add_library(geos_revision_header INTERFACE)
 endif()
+add_dependencies(geos_c geos_revision_header)
-# Installation
+file(GLOB_RECURSE _headers ${CMAKE_CURRENT_LIST_DIR}/*.cpp  CONFIGURE_DEPEND)
+target_sources(geos_c PRIVATE ${_headers})
+unset(_headers)
-if(APPLE AND GEOS_ENABLE_MACOSX_FRAMEWORK)
-  install(FILES ${CMAKE_CURRENT_BINARY_DIR}/geos_c.h
-    DESTINATION GEOS.framework/Versions/${VERSION_MAJOR}/Headers)
-  install(CODE "execute_process(COMMAND sed -E -i \"\" \"s,# *include[[:space:]]+<geos/,#include <GEOS/,g\" \"$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/GEOS.framework/Versions/${VERSION_MAJOR}/Headers/geos_c.h\")")
-else()
-    DESTINATION include)
-endif()
+target_include_directories(geos_c
+  PUBLIC
+    $<BUILD_INTERFACE:${CMAKE_CURRENT_BINARY_DIR}>
+    $<INSTALL_INTERFACE:include/geos>)
-  install(TARGETS geos_c
-    RUNTIME DESTINATION bin
-    LIBRARY DESTINATION lib
-    ARCHIVE DESTINATION lib)
-endif()
+set(VERSION ${GEOS_VERSION})
+set(VERSION_MAJOR ${GEOS_VERSION_MAJOR})
+set(VERSION_MINOR ${GEOS_VERSION_MINOR})
+set(VERSION_PATCH ${GEOS_VERSION_PATCH})
-# Group source files for IDE source explorers (e.g. Visual Studio)
+configure_file(
+  ${CMAKE_CURRENT_LIST_DIR}/geos_c.h.in
+  ${CMAKE_CURRENT_BINARY_DIR}/geos_c.h
+  @ONLY)
-source_group("Header Files" FILES ${geos_capi_HEADERS})
+unset(VERSION)
+unset(VERSION_MAJOR)
+unset(VERSION_MINOR)
+unset(VERSION_PATCH)
diff --git a/cmake/GenerateRevisionHeader.cmake b/cmake/GenerateRevisionHeader.cmake
new file mode 100644
index 0000000..26072f9
--- /dev/null
+++ b/cmake/GenerateRevisionHeader.cmake
@@ -0,0 +1,26 @@
+# Copyright (C) 2018 Daniel Baston <dbaston at gmail.com>
+# This is free software; you can redistribute and/or modify it under
+# the terms of the GNU Lesser General Public Licence as published
+# by the Free Software Foundation.
+# See the COPYING file for more information.
+include(GetGitRevision)
+get_git_revision(
+  HASH_LENGTH 7
+  HASH  GEOS_GIT_HASH
+  DIRTY GEOS_GIT_IS_DIRTY)
+set(REV ${GEOS_GIT_HASH})
+if (${GEOS_GIT_IS_DIRTY})
+  set(REV "${REV} (dirty)")
+endif()
+message(STATUS "GEOS: GEOS_REVISION=${REV}")
+file(WRITE ${DST} "#define GEOS_REVISION \"${REV}\"
diff --git a/cmake/GetGitRevision.cmake b/cmake/GetGitRevision.cmake
index 0000000..65b3fb2
--- /dev/null
+++ b/cmake/GetGitRevision.cmake
@@ -0,0 +1,40 @@
+# Adapted from https://gitlab.kitware.com/cmake/cmake/blob/aec06dd4922187ce5346d20a9f0d53f01b6ce9fc/Source/CMakeVersionSource.cmake
+# Try to identify the current development source version.
+function(get_git_revision)
+  cmake_parse_arguments("ARG" "" "HASH;HASH_LENGTH;DIRTY" "" "${ARGN}")
+  if(EXISTS ${CMAKE_SOURCE_DIR}/.git/HEAD)
+    find_program(GIT_EXECUTABLE NAMES git git.cmd)
+    mark_as_advanced(GIT_EXECUTABLE)
+    if(GIT_EXECUTABLE)
+      execute_process(
+        COMMAND ${GIT_EXECUTABLE} rev-parse --verify -q --short=${ARG_HASH_LENGTH} HEAD
+        OUTPUT_VARIABLE head
+        OUTPUT_STRIP_TRAILING_WHITESPACE
+      if(head)
+        execute_process(
+          COMMAND ${GIT_EXECUTABLE} update-index -q --refresh
+        execute_process(
+          COMMAND ${GIT_EXECUTABLE} diff-index --name-only HEAD -- --ignore-space-at-eol
+          OUTPUT_VARIABLE dirty
+      endif()
+    endif()
+  endif()
+  set(${ARG_HASH} "${head}" PARENT_SCOPE)
+  if(dirty)
+    set(${ARG_DIRTY} 1 PARENT_SCOPE)
+  else()
+    set("${ARG_DIRTY}" 0 PARENT_SCOPE)
+  endif()
+endfunction()
diff --git a/cmake/cmake_uninstall.cmake.in b/cmake/cmake_uninstall.cmake.in
index 725ab7d..7c63427 100644
--- a/cmake/cmake_uninstall.cmake.in
+++ b/cmake/cmake_uninstall.cmake.in
@@ -4,12 +4,12 @@
 # Defines commands used by make uninstall target of CMake build configuration.
-# Author: Credit to the CMake mailing list archives for providing this solution.
+# Author: Credit to the CMake mailing list archives for providing this solution.
 # Modifications: Mateusz Loskot <mateusz at loskot.net>
 if(NOT EXISTS "@CMAKE_CURRENT_BINARY_DIR@/install_manifest.txt")
-  message(FATAL_ERROR
+  message(FATAL_ERROR
     "Cannot find install manifest:
 endif()
@@ -20,7 +20,7 @@ string(REGEX REPLACE "\n" ";" files "${files}")
 set(GEOS_INCLUDE_DIR)
 foreach(file ${files})
-  if(${file} MATCHES "geos.h")
+  if(${file} MATCHES "geom.h")
     get_filename_component(GEOS_INCLUDE_DIR ${file} PATH)
   endif()
@@ -39,7 +39,7 @@ foreach(file ${files})
 endforeach()
 message(STATUS "Deleting ${GEOS_INCLUDE_DIR} directory")
-exec_program("@CMAKE_COMMAND@"
+exec_program("@CMAKE_COMMAND@"
   ARGS "-E remove_directory \"${GEOS_INCLUDE_DIR}\""
   OUTPUT_VARIABLE rm_out
   RETURN_VALUE rm_retval)
diff --git a/tests/perf/operation/CMakeLists.txt b/cmake/geos-config.cmake
similarity index 63%
copy from tests/perf/operation/CMakeLists.txt
copy to cmake/geos-config.cmake
index 9a23175..402c4c1 100644
--- a/tests/perf/operation/CMakeLists.txt
+++ b/cmake/geos-config.cmake
@@ -1,15 +1,11 @@
-# CMake configuration for GEOS perf/operation tests
-# Copyright (C) 2017 Mateusz Loskot <mateusz at loskot.net>
-add_subdirectory(buffer)
-add_subdirectory(predicate)
+include("${CMAKE_CURRENT_LIST_DIR}/geos-targets.cmake")
diff --git a/cmake/modules/COPYING-CMAKE-SCRIPTS b/cmake/modules/COPYING-CMAKE-SCRIPTS
deleted file mode 100644
index 4b41776..0000000
--- a/cmake/modules/COPYING-CMAKE-SCRIPTS
+++ /dev/null
@@ -1,22 +0,0 @@
-Redistribution and use in source and binary forms, with or without
-modification, are permitted provided that the following conditions
-are met:
-1. Redistributions of source code must retain the copyright
-   notice, this list of conditions and the following disclaimer.
-2. Redistributions in binary form must reproduce the copyright
-   notice, this list of conditions and the following disclaimer in the
-   documentation and/or other materials provided with the distribution.
-3. The name of the author may not be used to endorse or promote products
-   derived from this software without specific prior written permission.
-THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR
-IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
-OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED.
-IN NO EVENT SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT,
-INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT
-NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
-DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
-THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
-(INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF
-THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
diff --git a/cmake/modules/CheckPrototypeExists.cmake b/cmake/modules/CheckPrototypeExists.cmake
index 4b720c5..0000000
--- a/cmake/modules/CheckPrototypeExists.cmake
+++ /dev/null
@@ -1,43 +0,0 @@
-# - Check if the prototype for a function exists.
-# CHECK_PROTOTYPE_EXISTS (FUNCTION HEADER VARIABLE)
-#  FUNCTION - the name of the function you are looking for
-#  HEADER - the header(s) where the prototype should be declared
-#  VARIABLE - variable to store the result
-# The following variables may be set before calling this macro to
-# modify the way the check is run:
-#  CMAKE_REQUIRED_FLAGS = string of compile command line flags
-#  CMAKE_REQUIRED_DEFINITIONS = list of macros to define (-DFOO=bar)
-#  CMAKE_REQUIRED_INCLUDES = list of include directories
-# Copyright (c) 2006, Alexander Neundorf, <neundorf at kde.org>
-# Redistribution and use is allowed according to the terms of the BSD license.
-# For details see the accompanying COPYING-CMAKE-SCRIPTS file.
-# Source: KDE/kdelibs
-# <http://websvn.kde.org/trunk/KDE/kdelibs/cmake/modules/CheckPrototypeExists.cmake?pathrev=776742>
-INCLUDE(CheckCXXSourceCompiles)
-MACRO(CHECK_PROTOTYPE_EXISTS _SYMBOL _HEADER _RESULT)
-  SET(_INCLUDE_FILES)
-  FOREACH (it ${_HEADER})
-    SET(_INCLUDE_FILES "${_INCLUDE_FILES}#include <${it}>\n")
-  ENDFOREACH (it)
-  SET(_CHECK_PROTO_EXISTS_SOURCE_CODE "
-${_INCLUDE_FILES}
-int main()
-#ifndef ${_SYMBOL}
-    int i = sizeof(&${_SYMBOL});
-#endif
-    return 0;
-  CHECK_CXX_SOURCE_COMPILES("${_CHECK_PROTO_EXISTS_SOURCE_CODE}" ${_RESULT})
-ENDMACRO(CHECK_PROTOTYPE_EXISTS _SYMBOL _HEADER _RESULT)
diff --git a/cmake/modules/GenerateSourceGroups.cmake b/cmake/modules/GenerateSourceGroups.cmake
index 0366996..0000000
--- a/cmake/modules/GenerateSourceGroups.cmake
+++ /dev/null
@@ -1,17 +0,0 @@
-# Macro generates tree of IDE source groups based on folders structure
-# Source: http://www.cmake.org/pipermail/cmake/2013-November/056332.html
-macro(GenerateSourceGroups curdir)
-  file(GLOB children RELATIVE ${PROJECT_SOURCE_DIR}/${curdir} ${PROJECT_SOURCE_DIR}/${curdir}/*)
-  foreach(child ${children})
-    if(IS_DIRECTORY ${PROJECT_SOURCE_DIR}/${curdir}/${child})
-      GenerateSourceGroups(${curdir}/${child})
-    else()
-      string(REPLACE "/" "\\" groupname ${curdir})
-      # I would like to call the src root folder in a different name, only in visual studio (not mandatory requirement)
-	  string(REPLACE "src" "Source Files" groupname ${groupname})
-      source_group(${groupname} FILES ${PROJECT_SOURCE_DIR}/${curdir}/${child})
-    endif()
-  endforeach()
-endmacro()
\ No newline at end of file
diff --git a/examples/client/CMakeLists.txt b/examples/client/CMakeLists.txt
index 0000000..b6106c6
--- /dev/null
+++ b/examples/client/CMakeLists.txt
@@ -0,0 +1,20 @@
+cmake_minimum_required(VERSION 3.12)
+project(GEOS VERSION 1.0.0 LANGUAGES C CXX)
+find_package(GEOS 3.8 REQUIRED)
+add_executable(geos_client geos_client.cpp)
+target_link_libraries(geos_client PRIVATE GEOS::geos)
+add_executable(geos_c_client geos_c_client.cpp)
+target_link_libraries(geos_c_client PRIVATE GEOS::geos_c)
diff --git a/examples/client/geos_c_client.cpp b/examples/client/geos_c_client.cpp
index 0000000..7b1be59
--- /dev/null
+++ b/examples/client/geos_c_client.cpp
@@ -0,0 +1,6 @@
+#include <geos_c.h>
+int main()
+    finishGEOS();
diff --git a/examples/client/geos_client.cpp b/examples/client/geos_client.cpp
index 0000000..d880ee0
--- /dev/null
+++ b/examples/client/geos_client.cpp
@@ -0,0 +1,8 @@
+#include <geos/geom/GeometryFactory.h>
+using namespace geos::geom;
+int main()
+    GeometryFactory::Ptr factory = GeometryFactory::create();
+    (void)factory;
diff --git a/include/CMakeLists.txt b/include/CMakeLists.txt
index 293e5dc..df8cd4d 100644
--- a/include/CMakeLists.txt
+++ b/include/CMakeLists.txt
@@ -1,54 +1,33 @@
-# GEOS C++ library build configuration for CMake build system
-# There is a builtin cmake way to get headers in the right location
-# for OS X framework, but it's not practical this complex tree
-  set(installdest GEOS.framework/Versions/${VERSION_MAJOR}/Headers)
-else()
-  set(installdest include/geos)
-endif()
-install(FILES geos.h
-  DESTINATION ${installdest})
-install(FILES ${CMAKE_CURRENT_BINARY_DIR}/geos/version.h
-install(DIRECTORY geos/
-  FILES_MATCHING
-  PATTERN "*.h"
-  PATTERN "*.inl"
-  PATTERN ".svn" EXCLUDE)
-# Some post-processing for the framework
-# luckily GEOS uses header subdir already, just need to change case
-  install(CODE
-    "execute_process(COMMAND find \"$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/${installdest}\" -name *.* -print0
-    COMMAND xargs -0 sed -E -i \"\" \"s,# *include[[:space:]]+<geos/,#include <GEOS/,g\")")
-  install(CODE
-    "execute_process(COMMAND ln -sfh Versions/Current/Headers \"$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/GEOS.framework/Headers\")")
-endif()
-GenerateSourceGroups(include)
+file(GLOB_RECURSE _headers ${CMAKE_CURRENT_LIST_DIR}/*.h  CONFIGURE_DEPEND)
+target_sources(geos PRIVATE ${_headers})
+unset(_headers)
+  PUBLIC
+    $<BUILD_INTERFACE:${CMAKE_CURRENT_LIST_DIR}>
+configure_file(${CMAKE_CURRENT_LIST_DIR}/geos/version.h.in
+  ${CMAKE_CURRENT_BINARY_DIR}/geos/version.h
+  @ONLY)
+unset(VERSION)
diff --git a/src/CMakeLists.txt b/src/CMakeLists.txt
index 5a7c7b5..6fbc982 100644
--- a/src/CMakeLists.txt
+++ b/src/CMakeLists.txt
@@ -1,125 +1,13 @@
-file(GLOB_RECURSE geos_SOURCES ${CMAKE_CURRENT_SOURCE_DIR}/*.cpp)
-file(GLOB_RECURSE geos_ALL_HEADERS ${CMAKE_SOURCE_DIR}/include/*.h) # fix source_group issue
-# Building with Visual C++ x86_64 needs to compile the asm utilities first
-if (MSVC AND (${CMAKE_SIZEOF_VOID_P} EQUAL 8))
-  set(TTMATH_MSVC64_ASM ttmathuint_x86_64_msvc.asm)
-  enable_language(ASM_MASM)
-  message(STATUS "Enabled MASM to compile '${TTMATH_MSVC64_ASM}'")
-  list(INSERT geos_SOURCES 0 ${CMAKE_SOURCE_DIR}/include/geos/algorithm/ttmath/${TTMATH_MSVC64_ASM})
-endif()
-# Include CAPI in OS X framework binary and in static libs
-set(geos_c_SOURCES
-  ${CMAKE_CURRENT_SOURCE_DIR}/../capi/geos_c.cpp
-  ${CMAKE_CURRENT_SOURCE_DIR}/../capi/geos_ts_c.cpp)
-if(GEOS_ENABLE_MACOSX_FRAMEWORK)
-  # OS X frameworks don't have static libs
-  # also 1 binary, so include CAPI here
-  # and, make name all caps
-  add_library(GEOS SHARED ${geos_SOURCES} ${geos_c_SOURCES})
-  math(EXPR CVERSION "${VERSION_MAJOR} + 1")
- 	# VERSION = current version, SOVERSION = compatibility version
-  set_target_properties(GEOS
-    PROPERTIES
-    FRAMEWORK 1
-    VERSION "${CVERSION}.${VERSION_MINOR}.${VERSION_PATCH}"
- 	  SOVERSION ${CVERSION}
-    FRAMEWORK_VERSION ${VERSION_MAJOR}
-    BUILD_WITH_INSTALL_RPATH TRUE
-    INSTALL_NAME_DIR "${CMAKE_INSTALL_PREFIX}"
-    MACOSX_FRAMEWORK_INFO_PLIST "${CMAKE_CURRENT_SOURCE_DIR}/Info.plist.in"
-    MACOSX_FRAMEWORK_BUNDLE_VERSION "GEOS ${VERSION}"
-    MACOSX_FRAMEWORK_SHORT_VERSION_STRING ${VERSION}
-    MACOSX_FRAMEWORK_IDENTIFIER org.osgeo.geos)
-  install(TARGETS GEOS FRAMEWORK DESTINATION .)
-  if(GEOS_ENABLE_MACOSX_FRAMEWORK_UNIXCOMPAT)
-    # Unix compatibility option, provides typical bin/lib/include folder
-    # structure for framework-challenged projects
-    set(GEOS_FWDIR "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/GEOS.framework")
-    set(GEOS_FWDIR_VER "${GEOS_FWDIR}/Versions/${VERSION_MAJOR}")
-    install(CODE "execute_process(COMMAND mkdir -p \"${GEOS_FWDIR_VER}/unix/bin\")")
-    install(CODE "execute_process(COMMAND mkdir -p \"${GEOS_FWDIR_VER}/unix/include\")")
-    install(CODE "execute_process(COMMAND mkdir -p \"${GEOS_FWDIR_VER}/unix/lib\")")
-    install(CODE "execute_process(COMMAND ln -sfh ../../Headers \"${GEOS_FWDIR_VER}/unix/include/geos\")")
-    install(CODE "execute_process(COMMAND ln -sf ../../Headers/geos_c.h \"${GEOS_FWDIR_VER}/unix/include/geos_c.h\")")
-    install(CODE "execute_process(COMMAND ln -sf ../../GEOS \"${GEOS_FWDIR_VER}/unix/lib/libgeos.dylib\")")
-    install(CODE "execute_process(COMMAND ln -sf ../../GEOS \"${GEOS_FWDIR_VER}/unix/lib/libgeos_c.dylib\")")
-    install(CODE "execute_process(COMMAND ln -sfh Versions/Current/unix \"${GEOS_FWDIR}/unix\")")
-  endif()
-else()
-  if(GEOS_BUILD_SHARED)
-    add_library(geos SHARED ${geos_SOURCES} ${geos_ALL_HEADERS})
-      PROPERTIES
-      DEFINE_SYMBOL GEOS_DLL_EXPORT
-      VERSION ${VERSION}
-  endif()
-  if(GEOS_BUILD_STATIC)
-    file(GLOB geos_capi_HEADERS ${CMAKE_CURRENT_SOURCE_DIR}/../capi/*.h) # fix source_group issue
-    add_library(geos-static STATIC ${geos_SOURCES} ${geos_c_SOURCES} ${geos_ALL_HEADERS} ${geos_capi_HEADERS})
-    set_target_properties(geos-static
-      PROPERTIES
-      OUTPUT_NAME "geos"
-      PREFIX "lib"
-    add_dependencies(geos-static geos_revision)
-    install(TARGETS geos-static
-  endif()
-  if(NOT GEOS_BUILD_SHARED)
-    add_library(geos INTERFACE)
-    target_link_libraries(geos INTERFACE geos-static)
-  endif()
-endif() # (GEOS_ENABLE_MACOSX_FRAMEWORK)
-# if(APPLE)
-#   set_target_properties(geos
-#     PROPERTIES
-#     BUILD_WITH_INSTALL_RPATH TRUE
-#     INSTALL_NAME_DIR "${CMAKE_INSTALL_PREFIX}")
-# endif()
-GenerateSourceGroups(src)
+file(GLOB_RECURSE _sources ${CMAKE_CURRENT_LIST_DIR}/*.cpp  CONFIGURE_DEPEND)
+target_sources(geos PRIVATE ${_sources})
+unset(_sources)
diff --git a/tests/CMakeLists.txt b/tests/CMakeLists.txt
index 9138fe3..bb996be 100644
--- a/tests/CMakeLists.txt
+++ b/tests/CMakeLists.txt
@@ -1,15 +1,14 @@
-# GEOS tests build configuration for CMake build system
+add_custom_target(check COMMAND ctest)
 add_subdirectory(unit)
 add_subdirectory(xmltester)
diff --git a/tests/bigtest/CMakeLists.txt b/tests/bigtest/CMakeLists.txt
index d4e25fa..a809e5c 100644
--- a/tests/bigtest/CMakeLists.txt
+++ b/tests/bigtest/CMakeLists.txt
@@ -1,45 +1,20 @@
-# CMake configuration for GEOS big test
-# Copyright (C) 2011 Mateusz Loskot <mateusz at loskot.net>
-set(STATUS_MESSAGE "Enable GEOS large geometry tests build")
-set(STATUS_RESULT "OFF")
-if(GEOS_ENABLE_TESTS)
-  include_directories(${CMAKE_CURRENT_SOURCE_DIR})
-  add_executable(test_bug234 bug234.cpp)
-  if(APPLE AND GEOS_ENABLE_MACOSX_FRAMEWORK)
-    target_link_libraries(test_bug234 GEOS)
-  else()
-    target_link_libraries(test_bug234 geos)
-  endif()
-  add_executable(test_sweep_line_speed
-	TestSweepLineSpeed.cpp
-	GeometryTestFactory.cpp
-	bigtest.h)
-    target_link_libraries(test_sweep_line_speed GEOS)
-  else()
-    target_link_libraries(test_sweep_line_speed geos)
-  endif()
-  add_test(test_bug234 ${CMAKE_RUNTIME_OUTPUT_DIRECTORY}/test_bug234)
-  add_test(test_sweep_line_speed ${CMAKE_RUNTIME_OUTPUT_DIRECTORY}/test_sweep_line_speed)
-  set(STATUS_RESULT "ON")
-endif()
-message(STATUS "${STATUS_MESSAGE} - ${STATUS_RESULT}")
+add_executable(test_bug234 bug234.cpp)
+target_link_libraries(test_bug234 PRIVATE geos)
+add_test(NAME test_bug234 COMMAND test_bug234)
+add_executable(test_sweep_line_speed)
+target_sources(test_sweep_line_speed
+  PRIVATE
+    TestSweepLineSpeed.cpp
+    GeometryTestFactory.cpp)
+target_link_libraries(test_sweep_line_speed PRIVATE geos)
diff --git a/tests/perf/CMakeLists.txt b/tests/perf/CMakeLists.txt
index 78c55ad..11dc524 100644
--- a/tests/perf/CMakeLists.txt
+++ b/tests/perf/CMakeLists.txt
@@ -1,34 +1,16 @@
-# CMake configuration for GEOS perf tests
-set(STATUS_MESSAGE "Enable GEOS performance tests build")
-  add_executable(perf_class_sizes ClassSizes.cpp)
-  target_link_libraries(perf_class_sizes geos)
-#  add_test(perf_class_sizes ${CMAKE_RUNTIME_OUTPUT_DIRECTORY}/perf_class_sizes)
-  add_subdirectory(algorithm)
-  add_subdirectory(operation)
-  add_subdirectory(capi)
-endif()
+add_executable(test_perf_class_sizes ClassSizes.cpp)
+target_link_libraries(test_perf_class_sizes PRIVATE geos)
+add_test(NAME test_perf_class_sizes COMMAND test_perf_class_sizes)
+add_subdirectory(operation)
diff --git a/tests/perf/capi/CMakeLists.txt b/tests/perf/capi/CMakeLists.txt
index f6d8315..3b85d89 100644
--- a/tests/perf/capi/CMakeLists.txt
+++ b/tests/perf/capi/CMakeLists.txt
@@ -1,18 +1,19 @@
-# CMake configuration for GEOS perf/capi tests
-add_executable(perf_memleak_mp_prep memleak_mp_prep.c)
-target_link_libraries(perf_memleak_mp_prep geos_c)
-#add_test(perf_memleak_mp_prep ${CMAKE_RUNTIME_OUTPUT_DIRECTORY}/perf_memleak_mp_prep)
+add_executable(test_perf_memleak_mp_prep memleak_mp_prep.c)
+# test_perf_memleak_mp_prep is not dependant against geos target,
+# but geos_c only, so need explicit include directories.
+target_include_directories(test_perf_memleak_mp_prep
+  PUBLIC
+    $<BUILD_INTERFACE:${CMAKE_SOURCE_DIR}/include>
+    $<BUILD_INTERFACE:${CMAKE_BINARY_DIR}/include>)
+target_link_libraries(test_perf_memleak_mp_prep PRIVATE geos_c)
+add_test(NAME test_perf_memleak_mp_prep COMMAND test_perf_memleak_mp_prep)
diff --git a/tests/perf/operation/CMakeLists.txt b/tests/perf/operation/CMakeLists.txt
index 9a23175..10b0eb4 100644
+++ b/tests/perf/operation/CMakeLists.txt
@@ -1,15 +1,12 @@
diff --git a/tests/perf/operation/buffer/CMakeLists.txt b/tests/perf/operation/buffer/CMakeLists.txt
index 57d2bd4..de937de 100644
--- a/tests/perf/operation/buffer/CMakeLists.txt
+++ b/tests/perf/operation/buffer/CMakeLists.txt
@@ -1,18 +1,13 @@
-# CMake configuration for GEOS perf/operation/buffer tests
-add_executable(perf_iterated_buffer IteratedBufferStressTest.cpp)
-target_link_libraries(perf_iterated_buffer geos)
-#add_test(perf_iterated_buffer ${CMAKE_RUNTIME_OUTPUT_DIRECTORY}/perf_iterated_buffer)
+add_executable(test_perf_iterated_buffer IteratedBufferStressTest.cpp)
+target_link_libraries(test_perf_iterated_buffer PRIVATE geos)
+add_test(NAME test_perf_iterated_buffer COMMAND test_perf_iterated_buffer)
diff --git a/tests/perf/operation/predicate/CMakeLists.txt b/tests/perf/operation/predicate/CMakeLists.txt
index 4260149..2ce3624 100644
--- a/tests/perf/operation/predicate/CMakeLists.txt
+++ b/tests/perf/operation/predicate/CMakeLists.txt
@@ -1,19 +1,13 @@
-# CMake configuration for GEOS perf/operation/predicate tests
-add_executable(perf_rectangle_intersects RectangleIntersectsPerfTest.cpp)
-target_link_libraries(perf_rectangle_intersects geos)
-#add_test(perf_rectangle_intersects ${CMAKE_RUNTIME_OUTPUT_DIRECTORY}/perf_rectangle_intersects)
+add_executable(test_perf_rectangle_intersects RectangleIntersectsPerfTest.cpp)
+target_link_libraries(test_perf_rectangle_intersects PRIVATE geos)
+add_test(NAME test_perf_rectangle_intersects COMMAND test_perf_rectangle_intersects)
diff --git a/tests/unit/CMakeLists.txt b/tests/unit/CMakeLists.txt
index 8bfc898..307b561 100644
--- a/tests/unit/CMakeLists.txt
+++ b/tests/unit/CMakeLists.txt
@@ -1,41 +1,20 @@
-# GEOS unit tests build configuration for CMake build system
-set(STATUS_MESSAGE "Enable GEOS unit tests build")
-  include_directories(${CMAKE_SOURCE_DIR}/capi)
-  file(GLOB_RECURSE geos_unit_SOURCES ${CMAKE_CURRENT_SOURCE_DIR}/*.cpp)
-  add_executable(test_geos_unit ${geos_unit_SOURCES})
-    target_link_libraries(test_geos_unit GEOS)
- 	else()
-    target_link_libraries(test_geos_unit geos geos_c)
- 	endif()
-  add_test(test_geos_unit ${CMAKE_RUNTIME_OUTPUT_DIRECTORY}/test_geos_unit)
-endif()
+add_executable(test_geos_unit ${_sources})
+unset(_sources)
+target_link_libraries(test_geos_unit PRIVATE geos geos_c)
+target_include_directories(test_geos_unit
+  PRIVATE
+    $<BUILD_INTERFACE:${CMAKE_CURRENT_LIST_DIR}>)
-GenerateSourceGroups(tests/unit)
+add_test(NAME test_geos_unit COMMAND test_geos_unit)
diff --git a/tests/xmltester/CMakeLists.txt b/tests/xmltester/CMakeLists.txt
index 9d1c9c9..9fea5aa 100644
--- a/tests/xmltester/CMakeLists.txt
+++ b/tests/xmltester/CMakeLists.txt
@@ -1,163 +1,31 @@
-# GEOS XML tests runner build configuration for CMake build system
-set(STATUS_MESSAGE "Enable GEOS XML tests build")
-  include_directories(${CMAKE_CURRENT_SOURCE_DIR}/tinyxml2)
+add_executable(test_simplewkttester SimpleWKTTester.cpp)
+target_link_libraries(test_simplewkttester PRIVATE geos)
-  set(simplewkttester_SOURCES SimpleWKTTester.cpp)
-  set(xmltester_SOURCES
+add_executable(test_xmltester)
+target_sources(test_xmltester
+  PRIVATE
     XMLTester.cpp
-    tinyxml2/tinyxml2.h
-    tinyxml2/tinyxml2.cpp
     BufferResultMatcher.cpp
-    SingleSidedBufferResultMatcher.cpp)
-  add_executable(test_simplewkttester ${simplewkttester_SOURCES})
-    target_link_libraries(test_simplewkttester GEOS)
- 	else()
-    target_link_libraries(test_simplewkttester geos)
- 	endif()
-  add_executable(test_xmltester ${xmltester_SOURCES})
-    target_link_libraries(test_xmltester GEOS)
- 	else()
-    target_link_libraries(test_xmltester geos)
-  endif()
-  set(XMLTESTS_DIR ${CMAKE_CURRENT_SOURCE_DIR}/tests)
-  set(SAVE_XMLTESTS
-    ${XMLTESTS_DIR}/general/TestBoundary.xml
-    ${XMLTESTS_DIR}/general/TestBuffer.xml
-    ${XMLTESTS_DIR}/general/TestBufferMitredJoin.xml
-    ${XMLTESTS_DIR}/general/TestCentroid.xml
-    ${XMLTESTS_DIR}/general/TestConvexHull-big.xml
-    ${XMLTESTS_DIR}/general/TestConvexHull.xml
-    ${XMLTESTS_DIR}/general/TestDensify.xml
-    ${XMLTESTS_DIR}/general/TestDistance.xml
-    ${XMLTESTS_DIR}/general/TestEqualsExact.xml
-    ${XMLTESTS_DIR}/general/TestFunctionAA.xml
-    ${XMLTESTS_DIR}/general/TestFunctionAAPrec.xml
-    ${XMLTESTS_DIR}/general/TestFunctionLA.xml
-    ${XMLTESTS_DIR}/general/TestFunctionLAPrec.xml
-    ${XMLTESTS_DIR}/general/TestFunctionLL.xml
-    ${XMLTESTS_DIR}/general/TestFunctionLLPrec.xml
-    ${XMLTESTS_DIR}/general/TestFunctionPA.xml
-    ${XMLTESTS_DIR}/general/TestFunctionPL.xml
-    ${XMLTESTS_DIR}/general/TestFunctionPLPrec.xml
-    ${XMLTESTS_DIR}/general/TestFunctionPP.xml
-    ${XMLTESTS_DIR}/general/TestInteriorPoint.xml
-    ${XMLTESTS_DIR}/general/TestMinimumClearance.xml
-    ${XMLTESTS_DIR}/general/TestPreparedPointPredicate.xml
-    ${XMLTESTS_DIR}/general/TestPreparedPolygonPredicate.xml
-    ${XMLTESTS_DIR}/general/TestPreparedPredicatesWithGeometryCollection.xml
-    ${XMLTESTS_DIR}/general/TestRectanglePredicate.xml
-    ${XMLTESTS_DIR}/general/TestRelateAA.xml
-    ${XMLTESTS_DIR}/general/TestRelateAC.xml
-    ${XMLTESTS_DIR}/general/TestRelateLA.xml
-    ${XMLTESTS_DIR}/general/TestRelateLC.xml
-    ${XMLTESTS_DIR}/general/TestRelateLL.xml
-    ${XMLTESTS_DIR}/general/TestRelatePA.xml
-    ${XMLTESTS_DIR}/general/TestRelatePL.xml
-    ${XMLTESTS_DIR}/general/TestRelatePP.xml
-    ${XMLTESTS_DIR}/general/TestSimple.xml
-    ${XMLTESTS_DIR}/general/TestUnaryUnion.xml
-    ${XMLTESTS_DIR}/general/TestUnaryUnionFloating.xml
-    ${XMLTESTS_DIR}/general/TestValid.xml
-    ${XMLTESTS_DIR}/general/TestValid2-big.xml
-    ${XMLTESTS_DIR}/general/TestValid2.xml
-    ${XMLTESTS_DIR}/general/TestWithinDistance.xml
-    ${XMLTESTS_DIR}/misc/Buffer-1.xml
-    ${XMLTESTS_DIR}/misc/Buffer-2.xml
-    ${XMLTESTS_DIR}/misc/InvalidRelates.xml
-    ${XMLTESTS_DIR}/misc/Segfaults.xml
-    ${XMLTESTS_DIR}/misc/TestBufferExternal-1.xml
-    ${XMLTESTS_DIR}/misc/TestBufferExternal-2.xml
-    ${XMLTESTS_DIR}/misc/TestIsValid.xml
-    ${XMLTESTS_DIR}/misc/buildarea.xml
-    ${XMLTESTS_DIR}/misc/fme.xml
-    ${XMLTESTS_DIR}/misc/heisenbugs.xml
-    ${XMLTESTS_DIR}/misc/hexwkb.xml
-    ${XMLTESTS_DIR}/misc/hole_from_shell.xml
-    ${XMLTESTS_DIR}/misc/hole_red.xml
-    ${XMLTESTS_DIR}/misc/linemerge.xml
-    ${XMLTESTS_DIR}/misc/makevalid.xml
-    ${XMLTESTS_DIR}/misc/robustness.xml
-    ${XMLTESTS_DIR}/misc/safe-16595.xml
-    ${XMLTESTS_DIR}/misc/safe-16596.xml
-    ${XMLTESTS_DIR}/misc/safe-TestBufferJagged.xml
-    ${XMLTESTS_DIR}/misc/singlesidedbuffer.xml
-    ${XMLTESTS_DIR}/misc/stmlf-20061020-invalid-output.xml
-    ${XMLTESTS_DIR}/misc/stmlf-20061020.xml
-    ${XMLTESTS_DIR}/misc/stmlf-20070119.xml
-    ${XMLTESTS_DIR}/misc/split.xml
-    ${XMLTESTS_DIR}/robust/TestRobustOverlayFixed.xml
-    ${XMLTESTS_DIR}/robust/TestRobustRelate.xml
-    ${XMLTESTS_DIR}/issue/issue-geos-176.xml
-    ${XMLTESTS_DIR}/issue/issue-geos-188.xml
-    ${XMLTESTS_DIR}/issue/issue-geos-244.xml
-    ${XMLTESTS_DIR}/issue/issue-geos-275.xml
-    ${XMLTESTS_DIR}/issue/issue-geos-350.xml
-    ${XMLTESTS_DIR}/issue/issue-geos-356.xml
-    ${XMLTESTS_DIR}/issue/issue-geos-358.xml
-    ${XMLTESTS_DIR}/issue/issue-geos-360.xml
-    ${XMLTESTS_DIR}/issue/issue-geos-366.xml
-    ${XMLTESTS_DIR}/issue/issue-geos-392.xml
-    ${XMLTESTS_DIR}/issue/issue-geos-398.xml
-    ${XMLTESTS_DIR}/issue/issue-geos-434.xml
-    ${XMLTESTS_DIR}/issue/issue-geos-459.xml
-    ${XMLTESTS_DIR}/issue/issue-geos-527.xml
-    ${XMLTESTS_DIR}/issue/issue-geos-569.xml
-    ${XMLTESTS_DIR}/issue/issue-geos-582.xml
-    ${XMLTESTS_DIR}/issue/issue-geos-586.xml
-    ${XMLTESTS_DIR}/issue/issue-geos-599.xml
-    ${XMLTESTS_DIR}/issue/issue-geos-605.xml
-    ${XMLTESTS_DIR}/issue/issue-geos-615.xml
-    ${XMLTESTS_DIR}/issue/issue-geos-716.xml
-    ${XMLTESTS_DIR}/issue/issue-geos-837.xml
-    ${XMLTESTS_DIR}/issue/issue-geos-838.xml
-    ${XMLTESTS_DIR}/validate/TestRelateAA-big.xml
-    ${XMLTESTS_DIR}/validate/TestRelateAA.xml
-    ${XMLTESTS_DIR}/validate/TestRelateAC.xml
-    ${XMLTESTS_DIR}/validate/TestRelateLA.xml
-    ${XMLTESTS_DIR}/validate/TestRelateLC.xml
-    ${XMLTESTS_DIR}/validate/TestRelateLL.xml
-    ${XMLTESTS_DIR}/validate/TestRelatePA.xml
-    ${XMLTESTS_DIR}/validate/TestRelatePL.xml
-    ${XMLTESTS_DIR}/validate/TestRelatePP.xml
-  set(FAILING_XMLTESTS
-    ${XMLTESTS_DIR}/issue/issue-geos-488.xml
-    ${XMLTESTS_DIR}/issue/issue-geos-344.xml
-    ${XMLTESTS_DIR}/robust/TestRobustRelateFloat.xml
-    ${XMLTESTS_DIR}/failure/TestOverlay.xml
-    ${XMLTESTS_DIR}/misc/TestBigNastyBuffer.xml
-    ${XMLTESTS_DIR}/misc/TestSameDirection.xml
-  add_test(test_xmltester ${CMAKE_RUNTIME_OUTPUT_DIRECTORY}/test_xmltester -v --test-valid-output ${SAVE_XMLTESTS})
-endif()
+    SingleSidedBufferResultMatcher.cpp
+    tinyxml2/tinyxml2.h
+    tinyxml2/tinyxml2.cpp)
+target_link_libraries(test_xmltester PRIVATE geos)
+target_include_directories(test_xmltester
+  PRIVATE
+    $<BUILD_INTERFACE:${CMAKE_CURRENT_LIST_DIR}>/tinyxml)
+file(GLOB_RECURSE _tests ${CMAKE_CURRENT_LIST_DIR}/tests/*.xml CONFIGURE_DEPEND)
+list(FILTER _tests EXCLUDE REGEX failure)
+add_test(NAME test_xmltester COMMAND test_xmltester --test-valid-output ${_tests})
+unset(_tests)
diff --git a/tests/xmltester/tests/issue/issue-geos-344.xml b/tests/xmltester/tests/failure/issue-geos-344.xml
similarity index 100%
rename from tests/xmltester/tests/issue/issue-geos-344.xml
rename to tests/xmltester/tests/failure/issue-geos-344.xml
diff --git a/tests/xmltester/tests/issue/issue-geos-488.xml b/tests/xmltester/tests/failure/issue-geos-488.xml
rename from tests/xmltester/tests/issue/issue-geos-488.xml
rename to tests/xmltester/tests/failure/issue-geos-488.xml
diff --git a/tests/xmltester/tests/misc/TestBigNastyBuffer.xml b/tests/xmltester/tests/failure/misc-TestBigNastyBuffer.xml
rename from tests/xmltester/tests/misc/TestBigNastyBuffer.xml
rename to tests/xmltester/tests/failure/misc-TestBigNastyBuffer.xml
diff --git a/tests/xmltester/tests/misc/TestSameDirection.xml b/tests/xmltester/tests/failure/misc-TestSameDirection.xml
rename from tests/xmltester/tests/misc/TestSameDirection.xml
rename to tests/xmltester/tests/failure/misc-TestSameDirection.xml
diff --git a/tests/xmltester/tests/robust/TestRobustRelateFloat.xml b/tests/xmltester/tests/failure/robust-TestRobustRelateFloat.xml
rename from tests/xmltester/tests/robust/TestRobustRelateFloat.xml
rename to tests/xmltester/tests/failure/robust-TestRobustRelateFloat.xml
diff --git a/tools/CMakeLists.txt b/tools/CMakeLists.txt
index c5356e3..62393e0 100644
--- a/tools/CMakeLists.txt
+++ b/tools/CMakeLists.txt
@@ -11,31 +11,43 @@
-if(UNIX OR MINGW)
-  if(APPLE AND GEOS_ENABLE_MACOSX_FRAMEWORK AND GEOS_ENABLE_MACOSX_FRAMEWORK_UNIXCOMPAT)
-    set(installdest GEOS.framework/Versions/${VERSION_MAJOR}/unix/bin)
-    set(prefix ${CMAKE_INSTALL_PREFIX}/GEOS.framework/Versions/${VERSION_MAJOR}/unix)
-  elseif(APPLE AND GEOS_ENABLE_MACOSX_FRAMEWORK)
-    # just a dummy so installdest not set
-    # want geos-config only for Mac unix build or framework+unixcompat
-  else()
-    set(installdest bin)
-    set(prefix ${CMAKE_INSTALL_PREFIX})
-  endif()
-  set(exec_prefix ${prefix}/bin)
-  set(libdir ${prefix}/lib)
-  if(installdest)
-    configure_file(${CMAKE_CURRENT_SOURCE_DIR}/geos-config.in
-                   ${CMAKE_CURRENT_BINARY_DIR}/geos-config @ONLY)
-    install(FILES ${CMAKE_CURRENT_BINARY_DIR}/geos-config
-      PERMISSIONS
-      OWNER_READ OWNER_EXECUTE GROUP_READ GROUP_EXECUTE WORLD_READ WORLD_EXECUTE)
-endif()
-endif()
+configure_file(${CMAKE_CURRENT_SOURCE_DIR}/geos-config.in
+               ${CMAKE_CURRENT_BINARY_DIR}/geos-config)
+install(FILES ${CMAKE_CURRENT_BINARY_DIR}/geos-config
+        DESTINATION bin
+        PERMISSIONS
+        OWNER_READ OWNER_EXECUTE GROUP_READ GROUP_EXECUTE WORLD_READ WORLD_EXECUTE)
 add_subdirectory(astyle)
+# if(UNIX OR MINGW)
+#   if(APPLE AND GEOS_ENABLE_MACOSX_FRAMEWORK AND GEOS_ENABLE_MACOSX_FRAMEWORK_UNIXCOMPAT)
+#     set(installdest GEOS.framework/Versions/${VERSION_MAJOR}/unix/bin)
+#     set(prefix ${CMAKE_INSTALL_PREFIX}/GEOS.framework/Versions/${VERSION_MAJOR}/unix)
+#   elseif(APPLE AND GEOS_ENABLE_MACOSX_FRAMEWORK)
+#     # just a dummy so installdest not set
+#     # want geos-config only for Mac unix build or framework+unixcompat
+#   else()
+#     set(installdest bin)
+#     set(prefix ${CMAKE_INSTALL_PREFIX})
+#   endif()
+#   set(exec_prefix ${prefix}/bin)
+#   set(libdir ${prefix}/lib)
+#   if(installdest)
+#     configure_file(${CMAKE_CURRENT_SOURCE_DIR}/geos-config.in
+#                    ${CMAKE_CURRENT_BINARY_DIR}/geos-config @ONLY)
+#     install(FILES ${CMAKE_CURRENT_BINARY_DIR}/geos-config
+#       DESTINATION ${installdest}
+#       PERMISSIONS
+#       OWNER_READ OWNER_EXECUTE GROUP_READ GROUP_EXECUTE WORLD_READ WORLD_EXECUTE)
+# endif()
+# endif()
diff --git a/tools/astyle/CMakeLists.txt b/tools/astyle/CMakeLists.txt
index e6ea8dc..a8bb0e2 100644
--- a/tools/astyle/CMakeLists.txt
+++ b/tools/astyle/CMakeLists.txt
@@ -14,7 +14,3 @@ file(GLOB_RECURSE astyle_SOURCES ${CMAKE_CURRENT_SOURCE_DIR}/*.cpp)
 add_executable(astyle ${astyle_SOURCES})
 # message(STATUS "Enable AStyle")
-GenerateSourceGroups(tools/astyle)
diff --git a/tools/geos-config.in b/tools/geos-config.in
index e6bef57..412ee67 100644
--- a/tools/geos-config.in
+++ b/tools/geos-config.in
@@ -1,7 +1,8 @@
 #!/bin/sh
-prefix=@prefix@
-exec_prefix=@exec_prefix@
-libdir=@libdir@
+prefix=@CMAKE_INSTALL_PREFIX@
+exec_prefix=@CMAKE_INSTALL_PREFIX@/bin
+libdir=@CMAKE_INSTALL_PREFIX@/lib
 usage()
@@ -22,9 +23,11 @@ Options:
 EOF
     exit $1
 if test $# -eq 0; then
   usage 1 1>&2
 fi
 while test $# -gt 0; do
 case "$1" in
     -*=*) optarg=`echo "$1" | sed 's/[-_a-zA-Z0-9]*=//'` ;;
@@ -32,36 +35,34 @@ case "$1" in
 esac
 case $1 in
     --prefix)
-    echo ${prefix}
+      echo @CMAKE_INSTALL_PREFIX@
     --version)
-    echo @VERSION@
+      echo @GEOS_VERSION@
     --cflags)
-    echo -I${prefix}/include
+      echo -I at CMAKE_INSTALL_PREFIX@/include
     --libs)
-      # TODO: make an alias for --clibs
-      # see http://trac.osgeo.org/geos/ticket/497
-      echo -L${libdir} -lgeos- at VERSION_RELEASE@
+      echo -L at CMAKE_INSTALL_PREFIX@/lib -lgeos- at GEOS_VERSION_MAJOR@
     --clibs)
-      echo -L${libdir} -lgeos_c
+      echo -L at CMAKE_INSTALL_PREFIX@/lib -lgeos_c
     --cclibs)
     --static-clibs)
-      echo -L${libdir} -lgeos_c -lgeos -lm
+      echo -L at CMAKE_INSTALL_PREFIX@/lib -lgeos_c -lgeos -lm
     --static-cclibs)
-      echo -L${libdir} -lgeos -lm
+      echo -L at CMAKE_INSTALL_PREFIX@/lib -lgeos -lm
     --ldflags)
-      echo -L${libdir}
     --includes)
-      echo ${prefix}/include
+      echo @CMAKE_INSTALL_PREFIX@/include
     --jtsport)
     echo @JTS_PORT@
Summary of changes:
 .editorconfig                                      |   2 +
 .gitignore                                         |   1 +
 CMakeLists.txt                                     | 507 +++++++++------------
 Makefile.am                                        |   8 +-
 appveyor.yml                                       | 162 +++----
 capi/CMakeLists.txt                                |  94 ++--
 cmake/GenerateRevisionHeader.cmake                 |  26 ++
 cmake/GetGitRevision.cmake                         |  40 ++
 cmake/cmake_uninstall.cmake.in                     |   8 +-
 .../CMakeLists.txt => cmake/geos-config.cmake      |  14 +-
 cmake/modules/COPYING-CMAKE-SCRIPTS                |  22 -
 cmake/modules/CheckPrototypeExists.cmake           |  43 --
 cmake/modules/GenerateSourceGroups.cmake           |  17 -
 examples/client/CMakeLists.txt                     |  20 +
 examples/client/geos_c_client.cpp                  |   6 +
 examples/client/geos_client.cpp                    |   8 +
 include/CMakeLists.txt                             |  75 ++-
 src/CMakeLists.txt                                 | 126 +----
 tests/CMakeLists.txt                               |  11 +-
 tests/bigtest/CMakeLists.txt                       |  53 +--
 tests/perf/CMakeLists.txt                          |  36 +-
 tests/perf/capi/CMakeLists.txt                     |  25 +-
 tests/perf/operation/CMakeLists.txt                |  11 +-
 tests/perf/operation/buffer/CMakeLists.txt         |  19 +-
 tests/perf/operation/predicate/CMakeLists.txt      |  20 +-
 tests/unit/CMakeLists.txt                          |  45 +-
 tests/xmltester/CMakeLists.txt                     | 174 +------
 tests/xmltester/Makefile.am                        |  10 +-
 .../tests/{issue => failure}/issue-geos-344.xml    |   0
 .../tests/{issue => failure}/issue-geos-488.xml    |   0
 .../misc-TestBigNastyBuffer.xml}                   |   0
 .../misc-TestSameDirection.xml}                    |   0
 .../robust-TestRobustRelateFloat.xml}              |   0
 tools/CMakeLists.txt                               |  66 +--
 tools/astyle/CMakeLists.txt                        |   4 -
 tools/geos-config.in                               |  35 +-
 36 files changed, 631 insertions(+), 1057 deletions(-)
 create mode 100644 cmake/GenerateRevisionHeader.cmake
 create mode 100644 cmake/GetGitRevision.cmake
 copy tests/perf/operation/CMakeLists.txt => cmake/geos-config.cmake (63%)
 delete mode 100644 cmake/modules/COPYING-CMAKE-SCRIPTS
 delete mode 100644 cmake/modules/CheckPrototypeExists.cmake
 delete mode 100644 cmake/modules/GenerateSourceGroups.cmake
 create mode 100644 examples/client/CMakeLists.txt
 create mode 100644 examples/client/geos_c_client.cpp
 create mode 100644 examples/client/geos_client.cpp
 rename tests/xmltester/tests/{issue => failure}/issue-geos-344.xml (100%)
 rename tests/xmltester/tests/{issue => failure}/issue-geos-488.xml (100%)
 rename tests/xmltester/tests/{misc/TestBigNastyBuffer.xml => failure/misc-TestBigNastyBuffer.xml} (100%)
 rename tests/xmltester/tests/{misc/TestSameDirection.xml => failure/misc-TestSameDirection.xml} (100%)
 rename tests/xmltester/tests/{robust/TestRobustRelateFloat.xml => failure/robust-TestRobustRelateFloat.xml} (100%)
hooks/post-receive
More information about the geos-commits mailing list
