[geos-commits] [SCM] GEOS branch master updated. 6b14044c691c7aa02177496686ef43f2a3911ade
git at osgeo.org
git at osgeo.org
Tue May 21 08:50:06 PDT 2019
the project "GEOS".
via 6b14044c691c7aa02177496686ef43f2a3911ade (commit)
from 4ebb2526bdfbf54febeccbcd7dc6fe592f48c223 (commit)
revisions in full, below.
commit 6b14044c691c7aa02177496686ef43f2a3911ade
Author: Daniel Baston <dbaston at gmail.com>
Date: Tue May 21 11:49:48 2019 -0400
Revert "Remove unstable API warnings for tests"
This reverts commit ae73bc45bbad44703ed0532b64ed0c2440a9cf90.
diff --git a/tests/bigtest/CMakeLists.txt b/tests/bigtest/CMakeLists.txt
index ebff39f..a809e5c 100644
--- a/tests/bigtest/CMakeLists.txt
+++ b/tests/bigtest/CMakeLists.txt
@@ -11,7 +11,6 @@
add_executable(test_bug234 bug234.cpp)
target_link_libraries(test_bug234 PRIVATE geos)
add_test(NAME test_bug234 COMMAND test_bug234)
-target_compile_definitions(test_bug234 PRIVATE "USE_UNSTABLE_GEOS_CPP_API")
add_executable(test_sweep_line_speed)
target_sources(test_sweep_line_speed
@@ -19,4 +18,3 @@ target_sources(test_sweep_line_speed
TestSweepLineSpeed.cpp
GeometryTestFactory.cpp)
target_link_libraries(test_sweep_line_speed PRIVATE geos)
-target_compile_definitions(test_sweep_line_speed PRIVATE "USE_UNSTABLE_GEOS_CPP_API")
diff --git a/tests/perf/CMakeLists.txt b/tests/perf/CMakeLists.txt
index 378f744..11dc524 100644
--- a/tests/perf/CMakeLists.txt
+++ b/tests/perf/CMakeLists.txt
@@ -11,7 +11,6 @@
add_executable(test_perf_class_sizes ClassSizes.cpp)
target_link_libraries(test_perf_class_sizes PRIVATE geos)
add_test(NAME test_perf_class_sizes COMMAND test_perf_class_sizes)
-target_compile_definitions(test_perf_class_sizes PRIVATE "USE_UNSTABLE_GEOS_CPP_API")
add_subdirectory(operation)
add_subdirectory(capi)
diff --git a/tests/perf/capi/CMakeLists.txt b/tests/perf/capi/CMakeLists.txt
index 014a4cc..3b85d89 100644
--- a/tests/perf/capi/CMakeLists.txt
+++ b/tests/perf/capi/CMakeLists.txt
@@ -17,4 +17,3 @@ target_include_directories(test_perf_memleak_mp_prep
$<BUILD_INTERFACE:${CMAKE_BINARY_DIR}/include>)
target_link_libraries(test_perf_memleak_mp_prep PRIVATE geos_c)
add_test(NAME test_perf_memleak_mp_prep COMMAND test_perf_memleak_mp_prep)
-target_compile_definitions(test_perf_memleak_mp_prep PRIVATE "USE_UNSTABLE_GEOS_CPP_API")
diff --git a/tests/perf/operation/buffer/CMakeLists.txt b/tests/perf/operation/buffer/CMakeLists.txt
index b09efe9..de937de 100644
--- a/tests/perf/operation/buffer/CMakeLists.txt
+++ b/tests/perf/operation/buffer/CMakeLists.txt
@@ -11,4 +11,3 @@
add_executable(test_perf_iterated_buffer IteratedBufferStressTest.cpp)
target_link_libraries(test_perf_iterated_buffer PRIVATE geos)
add_test(NAME test_perf_iterated_buffer COMMAND test_perf_iterated_buffer)
-target_compile_definitions(test_perf_iterated_buffer PRIVATE "USE_UNSTABLE_GEOS_CPP_API")
diff --git a/tests/perf/operation/predicate/CMakeLists.txt b/tests/perf/operation/predicate/CMakeLists.txt
index 72f7a8a..2ce3624 100644
--- a/tests/perf/operation/predicate/CMakeLists.txt
+++ b/tests/perf/operation/predicate/CMakeLists.txt
@@ -11,4 +11,3 @@
add_executable(test_perf_rectangle_intersects RectangleIntersectsPerfTest.cpp)
target_link_libraries(test_perf_rectangle_intersects PRIVATE geos)
add_test(NAME test_perf_rectangle_intersects COMMAND test_perf_rectangle_intersects)
-target_compile_definitions(test_perf_rectangle_intersects PRIVATE "USE_UNSTABLE_GEOS_CPP_API")
diff --git a/tests/unit/CMakeLists.txt b/tests/unit/CMakeLists.txt
index 5926cef..307b561 100644
--- a/tests/unit/CMakeLists.txt
+++ b/tests/unit/CMakeLists.txt
@@ -17,6 +17,4 @@ target_include_directories(test_geos_unit
PRIVATE
$<BUILD_INTERFACE:${CMAKE_CURRENT_LIST_DIR}>)
-target_compile_definitions(test_geos_unit PRIVATE "USE_UNSTABLE_GEOS_CPP_API")
add_test(NAME test_geos_unit COMMAND test_geos_unit)
diff --git a/tests/xmltester/CMakeLists.txt b/tests/xmltester/CMakeLists.txt
index 3d41ce2..9fea5aa 100644
--- a/tests/xmltester/CMakeLists.txt
+++ b/tests/xmltester/CMakeLists.txt
@@ -11,7 +11,6 @@
add_executable(test_simplewkttester SimpleWKTTester.cpp)
target_link_libraries(test_simplewkttester PRIVATE geos)
-target_compile_definitions(test_simplewkttester PRIVATE "USE_UNSTABLE_GEOS_CPP_API")
add_executable(test_xmltester)
target_sources(test_xmltester
@@ -25,7 +24,6 @@ target_link_libraries(test_xmltester PRIVATE geos)
target_include_directories(test_xmltester
PRIVATE
$<BUILD_INTERFACE:${CMAKE_CURRENT_LIST_DIR}>/tinyxml)
-target_compile_definitions(test_xmltester PRIVATE "USE_UNSTABLE_GEOS_CPP_API")
file(GLOB_RECURSE _tests ${CMAKE_CURRENT_LIST_DIR}/tests/*.xml CONFIGURE_DEPEND)
list(FILTER _tests EXCLUDE REGEX failure)
Summary of changes:
tests/bigtest/CMakeLists.txt | 2 --
tests/perf/CMakeLists.txt | 1 -
tests/perf/capi/CMakeLists.txt | 1 -
tests/perf/operation/buffer/CMakeLists.txt | 1 -
tests/perf/operation/predicate/CMakeLists.txt | 1 -
tests/unit/CMakeLists.txt | 2 --
tests/xmltester/CMakeLists.txt | 2 --
7 files changed, 10 deletions(-)
hooks/post-receive
More information about the geos-commits
