[geos-commits] [SCM] GEOS branch master updated. 44acf18e52a6ed07e6074c99ddd75f9994d806a6
Tue May 21 15:03:11 PDT 2019
the project "GEOS".
       via  44acf18e52a6ed07e6074c99ddd75f9994d806a6 (commit)
       via  0b86731eae275bd3b09a581d11e3778d9770aa7d (commit)
       via  740c984fc32ffbfba265c803854824358cb5a20b (commit)
      from  2ba3d4a30721e7c04b4abf58938236eb34c9584f (commit)
revisions in full, below.
commit 44acf18e52a6ed07e6074c99ddd75f9994d806a6
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Tue May 21 15:02:58 2019 -0700
    Add prototype 'make distcheck' target
diff --git a/CMakeLists.txt b/CMakeLists.txt
index f6e9d8e..e84b445 100644
--- a/CMakeLists.txt
+++ b/CMakeLists.txt
@@ -19,7 +19,7 @@ if(${CMAKE_GENERATOR} MATCHES "Visual Studio")
   cmake_minimum_required(VERSION 3.13 FATAL_ERROR)
 endif()
-list(APPEND CMAKE_MODULE_PATH "${PROJECT_SOURCE_DIR}/cmake")
+list(APPEND CMAKE_MODULE_PATH "${CMAKE_SOURCE_DIR}/cmake")
 # TODO: Follow CMake detection of git and version tagging
 #       https://gitlab.kitware.com/cmake/cmake/blob/master/Source/CMakeVersionSource.cmake
@@ -102,7 +102,7 @@ project(GEOS VERSION "${_version_major}.${_version_minor}.${_version_patch}"
 if("${_version_patch_word}" STREQUAL "")
   set(GEOS_VERSION_FULL "${GEOS_VERSION}")
 else()
-  set(GEOS_VERSION_FULL "${GEOS_VERSION}-${_version_patch_word}")
+  set(GEOS_VERSION_FULL "${GEOS_VERSION}${_version_patch_word}")
 endif()
 unset(_version_major)
@@ -267,7 +267,7 @@ add_custom_target(uninstall
   "${CMAKE_COMMAND}" -P "${PROJECT_BINARY_DIR}/cmake/cmake_uninstall.cmake")
-# Make Dist
+# "make dist" workalike
 set(CPACK_PACKAGE_DESCRIPTION_SUMMARY "GEOS Computational Geometry Library")
@@ -277,30 +277,31 @@ set(CPACK_SOURCE_GENERATOR "TBZ2")
 set(CPACK_PACKAGE_VERSION_MAJOR ${GEOS_VERSION_MAJOR})
 set(CPACK_PACKAGE_VERSION_MINOR ${GEOS_VERSION_MINOR})
 set(CPACK_PACKAGE_VERSION_PATCH ${GEOS_VERSION_PATCH})
-set(CPACK_SOURCE_PACKAGE_FILE_NAME
-  "geos-${GEOS_VERSION}")
+set(CPACK_SOURCE_PACKAGE_FILE_NAME "geos-${GEOS_VERSION_FULL}")
-#  ".*\.yml"
 set(CPACK_SOURCE_IGNORE_FILES
   "/\\\\.git"
   "/autogen\\\\.sh"
   "/tools/ci"
   "/HOWTO_RELEASE"
   "/autom4te\\\\.cache"
-  ".yml\$"
-  ".deps"
+  "\\\\.yml\$"
+  "\\\\.deps"
   "/debian/"
   "/php/"
-# set(CPACK_SOURCE_IGNORE_FILES
-#   ".git"
-#   "autogen.sh"
-#   "HOWTO_RELEASE"
-#   "autom4te.cache"
-#   "debian"
-#   "php"
+message(STATUS "GEOS: CPACK_SOURCE_PACKAGE_FILE_NAME: ${CPACK_SOURCE_PACKAGE_FILE_NAME}")
 message(STATUS "GEOS: CPACK_SOURCE_IGNORE_FILES: ${CPACK_SOURCE_IGNORE_FILES}")
+message(STATUS "GEOS: CMAKE_MODULE_PATH: ${CMAKE_MODULE_PATH}")
 include(CPack)
 add_custom_target(dist COMMAND ${CMAKE_MAKE_PROGRAM} package_source)
+# "make distcheck" workalike
+find_package(MakeDistCheck)
+AddMakeDistCheck()
diff --git a/cmake/FindMakeDistCheck.cmake b/cmake/FindMakeDistCheck.cmake
new file mode 100644
index 0000000..78096c2
--- /dev/null
+++ b/cmake/FindMakeDistCheck.cmake
@@ -0,0 +1,61 @@
+# Inspired by CMake Distcheck for LAAS-CNRS
+# DEFINE_DISTCHECK
+# Add a distcheck target to check the generated tarball.
+# This step calls `make dist' to generate a copy of the sources as it
+# stands in the current git HEAD i.e., unversioned files are skipped.
+# Then:
+# - create _build and _inst to respectively create a build
+#   and an installation directory.
+# - run cmake with _inst as the installation prefix
+# - run make, make check, make install and make uninstall
+# - remove _build and _inst.
+# - remove dist directory and confirm success.
+# During the compilation phase, all files in the source tree are modified
+# to *not* be writeable to detect bad compilation steps which tries to modify
+# the source tree. Permissions are reverted at the end of the check.
+macro(AddMakeDistCheck)
+  find_program(_tar tar)
+  find_program(_bzip2 bzip2)
+  string(TOLOWER "${CPACK_SOURCE_PACKAGE_FILE_NAME}" _distbasename)
+  set(_distname "${_distbasename}.tar.bz2")
+  set(_builddir "${CMAKE_BINARY_DIR}/${_distbasename}/_build")
+  set(_instdir  "${CMAKE_BINARY_DIR}/${_distbasename}/_inst")
+  # message(STATUS "GEOS: _distbasename: ${_distbasename}")
+  # message(STATUS "GEOS: _distname: ${_distname}")
+  # message(STATUS "GEOS: _builddir: ${_builddir}")
+  # message(STATUS "GEOS: _instdir: ${_instdir}")
+  add_custom_target(distcheck
+    COMMAND rm -rf "${_distbasename}"
+      && \(${_bzip2} -d -c "${_distname}" | ${_tar} xf -\)
+      && mkdir -vp "${_builddir}"
+      && mkdir -vp "${_instdir}"
+      && cd "${_builddir}"
+      && ${CMAKE_COMMAND} -DCMAKE_INSTALL_PREFIX:PATH="${_instdir}" ..
+        || \(echo "ERROR: the cmake configuration failed." && false\)
+      && make
+        || \(echo "ERROR: the compilation failed." && false\)
+      && make test
+        || \(echo "ERROR: the test suite failed." && false\)
+      && make install
+        || \(echo "ERROR: the install target failed." && false\)
+      && make uninstall
+        || \(echo "ERROR: the uninstall target failed." && false\)
+      && make clean
+        || \(echo "ERROR: the clean target failed." && false\)
+      && cd ../..
+      && rm -rf "${_distbasename}"
+      && echo "=============================================================="
+      && echo "${_distname} is ready for distribution."
+  add_dependencies(distcheck dist)
+endmacro()
commit 0b86731eae275bd3b09a581d11e3778d9770aa7d
Merge: 740c984 2ba3d4a
Date:   Tue May 21 09:12:53 2019 -0700
    Merge branch 'master' of https://git.osgeo.org/gogs/geos/geos
commit 740c984fc32ffbfba265c803854824358cb5a20b
Date:   Tue May 21 09:12:14 2019 -0700
    Work on cmake patterns for 'dist' target
index fc344e2..e5b9aa6 100644
@@ -283,13 +283,15 @@ set(CPACK_SOURCE_PACKAGE_FILE_NAME
 #  ".*\.yml"
-  "/\.git/"
-  "autogen.sh"
-  "HOWTO_RELEASE"
-  "autom4te.cache"
-  "/.*\.yml/"
-  "/\/debian\//"
-  "/\/php\//"
+  "/\\\\.git"
+  "/autogen\\\\.sh"
+  "/tools/ci"
+  "/HOWTO_RELEASE"
+  "/autom4te\\\\.cache"
+  ".yml\$"
+  ".deps"
+  "/debian/"
+  "/php/"
 #   ".git"
Summary of changes:
 CMakeLists.txt                | 45 ++++++++++++++++---------------
 cmake/FindMakeDistCheck.cmake | 61 +++++++++++++++++++++++++++++++++++++++++++
 2 files changed, 85 insertions(+), 21 deletions(-)
 create mode 100644 cmake/FindMakeDistCheck.cmake
hooks/post-receive
More information about the geos-commits mailing list
