[geos-commits] [SCM] GEOS branch master updated. 5694dec1baa9408493cab4b1a502eabf6916e824
git at osgeo.org
git at osgeo.org
Wed May 22 09:11:58 PDT 2019
the project "GEOS".
via 5694dec1baa9408493cab4b1a502eabf6916e824 (commit)
from c9542e6211d3e32d63f329e703636a3433009958 (commit)
revisions in full, below.
commit 5694dec1baa9408493cab4b1a502eabf6916e824
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Wed May 22 09:11:32 2019 -0700
First step to fixing geos-config, generate from separate
input files (cmake and in) to avoid crosstalk
References #971
diff --git a/tools/CMakeLists.txt b/tools/CMakeLists.txt
index 62393e0..1f27b80 100644
--- a/tools/CMakeLists.txt
+++ b/tools/CMakeLists.txt
@@ -12,7 +12,7 @@
-configure_file(${CMAKE_CURRENT_SOURCE_DIR}/geos-config.in
+configure_file(${CMAKE_CURRENT_SOURCE_DIR}/geos-config.cmake
${CMAKE_CURRENT_BINARY_DIR}/geos-config)
diff --git a/tools/geos-config.in b/tools/geos-config.cmake
similarity index 100%
copy from tools/geos-config.in
copy to tools/geos-config.cmake
diff --git a/tools/geos-config.in b/tools/geos-config.in
index 412ee67..b7638d2 100644
--- a/tools/geos-config.in
+++ b/tools/geos-config.in
@@ -1,8 +1,7 @@
#!/bin/sh
-prefix=@CMAKE_INSTALL_PREFIX@
-exec_prefix=@CMAKE_INSTALL_PREFIX@/bin
-libdir=@CMAKE_INSTALL_PREFIX@/lib
+prefix=@prefix@
+exec_prefix=@exec_prefix@
+libdir=@libdir@
usage()
@@ -23,11 +22,9 @@ Options:
EOF
exit $1
if test $# -eq 0; then
usage 1 1>&2
fi
while test $# -gt 0; do
case "$1" in
-*=*) optarg=`echo "$1" | sed 's/[-_a-zA-Z0-9]*=//'` ;;
@@ -35,34 +32,36 @@ case "$1" in
esac
case $1 in
--prefix)
- echo @CMAKE_INSTALL_PREFIX@
+ echo @prefix@
--version)
- echo @GEOS_VERSION@
+ echo @VERSION@
--cflags)
- echo -I at CMAKE_INSTALL_PREFIX@/include
+ echo -I at prefix@/include
--libs)
- echo -L at CMAKE_INSTALL_PREFIX@/lib -lgeos- at GEOS_VERSION_MAJOR@
+ # TODO: make an alias for --clibs
+ # see http://trac.osgeo.org/geos/ticket/497
+ echo -L at libdir@ -lgeos- at VERSION_RELEASE@
--clibs)
- echo -L at CMAKE_INSTALL_PREFIX@/lib -lgeos_c
+ echo -L at libdir@ -lgeos_c
--cclibs)
--static-clibs)
- echo -L at CMAKE_INSTALL_PREFIX@/lib -lgeos_c -lgeos -lm
+ echo -L at libdir@ -lgeos_c -lgeos -lm
--static-cclibs)
- echo -L at CMAKE_INSTALL_PREFIX@/lib -lgeos -lm
+ echo -L at libdir@ -lgeos -lm
--ldflags)
--includes)
- echo @CMAKE_INSTALL_PREFIX@/include
+ echo @prefix@/include
--jtsport)
echo @JTS_PORT@
Summary of changes:
tools/CMakeLists.txt | 2 +-
tools/{geos-config.in => geos-config.cmake} | 0
tools/geos-config.in | 35 ++++++++++++++---------------
3 files changed, 18 insertions(+), 19 deletions(-)
copy tools/{geos-config.in => geos-config.cmake} (100%)
hooks/post-receive
More information about the geos-commits
