[geos-commits] [SCM] GEOS branch master updated. 534da33a191e86371be607f21d707ef4d79c38b5
git at osgeo.org
git at osgeo.org
Thu May 23 09:43:26 PDT 2019
the project "GEOS".
via 534da33a191e86371be607f21d707ef4d79c38b5 (commit)
from a8f66c6fae42acf9e526747fa1ee745de293f428 (commit)
revisions in full, below.
commit 534da33a191e86371be607f21d707ef4d79c38b5
Author: Daniel Baston <dbaston at gmail.com>
Date: Thu May 23 12:38:14 2019 -0400
Remove leftover nmake.opt
NMake support was removed following discussion in
https://lists.osgeo.org/pipermail/geos-devel/2018-December/008787.html
diff --git a/nmake.opt b/nmake.opt
deleted file mode 100644
index 1850f6d..0000000
--- a/nmake.opt
+++ /dev/null
@@ -1,271 +0,0 @@
-# nmake.opt - main configuration file for NMAKE makefiles
-!MESSAGE **********************************************************************
-!MESSAGE *** GEOS Build Configuration ***
-# TODO: Confirm as redundant and remove, nmake /P displays _NMAKE_VER anyway.
-#!INCLUDE <ntwin32.mak>
-# For convenience, user may put custom settings to private mynmake.opt
-# and use EXT_NMAKE_OPT option while calling nmake.exe, as follows:
-# nmake -f makefile.vc EXT_NMAKE_OPT=mynmake.opt
-!IFDEF EXT_NMAKE_OPT
-!MESSAGE *** Setting EXT_NMAKE_OPT $(EXT_NMAKE_OPT)
-!INCLUDE $(EXT_NMAKE_OPT)
-!ENDIF
-# Set BUILD_DEBUG to YES if you want to make debug build
-# and to prepare not optimized binaries.
-!IFNDEF BUILD_DEBUG
-BUILD_DEBUG = NO
-!ENDIF
-!MESSAGE *** Setting BUILD_DEBUG $(BUILD_DEBUG)
-# Set ENABLE_INLINE to YES if you want to make debug build
-!IFNDEF ENABLE_INLINE
-ENABLE_INLINE = NO
-!ENDIF
-!MESSAGE *** Setting ENABLE_INLINE $(ENABLE_INLINE)
-# Set BUILD_BATCH to YES if you want feed compiler with all
-# source .c and .cpp files in single batch.
-!IFNDEF BUILD_BATCH
-BUILD_BATCH = NO
-!ENDIF
-!MESSAGE *** Setting BUILD_BATCH $(BUILD_BATCH)
-# Set WIN64=YES if you are building for 64-bit windows (x64).
-# Alternatively, pass WIN64=YES as NMAKE command line argument.
-!IFNDEF WIN64
-WIN64 = NO
-!ENDIF
-!MESSAGE *** Setting WIN64 $(WIN64)
-# Derive version of Visual C++ being used from NMAKE if not specified
-# WARNING:
-# If we should expect variety of NMAKE build versions, tests below may fail
-# and we will need to fall back to setting GEOS_MSVC as command line parameter.
-!IF "$(_NMAKE_VER)" == ""
-GEOS_MSVC = 4.0
-!ERROR *** Failed to determine version of Visual C++
-!ELSEIF "$(_NMAKE_VER)" == "162"
-GEOS_MSVC = 5.0
-!ERROR *** Detected Visual C++ 5.0 - NOT SUPPORTED
-!ELSEIF "$(_NMAKE_VER)" == "6.00.8168.0"
-GEOS_MSVC = 6.0
-GEOS_MSC = 1200
-!ERROR *** Detected Visual C++ 6.0 - NOT SUPPORTED
-!ELSEIF "$(_NMAKE_VER)" == "7.00.9466"
-GEOS_MSVC = 7.0
-GEOS_MSC = 1300
-!ELSEIF "$(_NMAKE_VER)" == "7.10.3077"
-GEOS_MSVC = 7.1
-GEOS_MSC = 1310
-!ELSEIF "$(_NMAKE_VER)" == "8.00.50727.42"
-GEOS_MSVC = 8.0
-GEOS_MSC = 1400
-!ELSEIF "$(_NMAKE_VER)" == "8.00.50727.762"
-GEOS_MSVC = 8.0
-GEOS_MSC = 1400
-!ELSEIF "$(_NMAKE_VER)" == "9.00.21022.08"
-GEOS_MSVC = 9.0
-GEOS_MSC = 1500
-!ELSEIF "$(_NMAKE_VER)" == "9.00.30729.01"
-GEOS_MSVC = 9.0
-GEOS_MSC = 1500
-!ELSEIF "$(_NMAKE_VER)" == "10.00.30128.01"
-GEOS_MSVC = 10.0
-GEOS_MSC = 1600
-!ELSEIF "$(_NMAKE_VER)" == "10.00.30319.01"
-GEOS_MSVC = 10.0
-GEOS_MSC = 1600
-!ELSEIF "$(_NMAKE_VER)" == "11.00.40825.2"
-GEOS_MSVC = 11.0
-GEOS_MSC = 1700
-!ELSEIF "$(_NMAKE_VER)" == "11.00.50522.1"
-GEOS_MSVC = 11.0
-GEOS_MSC = 1700
-!ELSEIF "$(_NMAKE_VER)" == "11.00.50727.1"
-GEOS_MSVC = 11.0
-GEOS_MSC = 1700
-!ELSEIF "$(_NMAKE_VER)" == "11.00.51106.1"
-GEOS_MSVC = 11.0
-GEOS_MSC = 1700
-!ELSEIF "$(_NMAKE_VER)" == "11.00.60315.1"
-GEOS_MSVC = 11.0
-GEOS_MSC = 1700
-!ELSEIF "$(_NMAKE_VER)" == "11.00.60430.2"
-GEOS_MSVC = 11.0
-GEOS_MSC = 1700
-!ELSEIF "$(_NMAKE_VER)" == "11.00.60521.0"
-GEOS_MSVC = 11.0
-GEOS_MSC = 1700
-!ELSEIF "$(_NMAKE_VER)" == "11.00.60610.1"
-GEOS_MSVC = 11.0
-GEOS_MSC = 1700
-!ELSEIF "$(_NMAKE_VER)" == "11.00.61030.0"
-GEOS_MSVC = 11.0
-GEOS_MSC = 1700
-!ELSEIF "$(_NMAKE_VER)" == "12.00.21005.1"
-GEOS_MSVC = 12.0
-GEOS_MSC = 1800
-!ELSEIF "$(_NMAKE_VER)" == "14.00.22816.0"
-GEOS_MSVC = 14.0
-GEOS_MSC = 1900
-!ELSEIF "$(_NMAKE_VER)" == "14.00.23026.0"
-GEOS_MSVC = 14.0
-GEOS_MSC = 1900
-!ELSEIF "$(_NMAKE_VER)" == "14.00.23506.0"
-GEOS_MSVC = 14.0
-GEOS_MSC = 1900
-!ELSEIF "$(_NMAKE_VER)" == "14.00.23918.0"
-GEOS_MSVC = 14.0
-GEOS_MSC = 1900
-!ELSEIF "$(_NMAKE_VER)" == "14.00.24210.0"
-GEOS_MSVC = 14.0
-GEOS_MSC = 1900
-!ELSEIF "$(_NMAKE_VER)" == "14.10.25017.0"
-GEOS_MSVC = 14.10
-GEOS_MSC = 1910
-!ELSEIF "$(_NMAKE_VER)" == "14.10.25019.0"
-GEOS_MSVC = 14.10
-GEOS_MSC = 1910
-!ELSEIF "$(_NMAKE_VER)" == "14.11.25506.0"
-GEOS_MSVC = 14.10
-GEOS_MSC = 1910
-!ELSEIF "$(_NMAKE_VER)" == "14.11.25507.1"
-GEOS_MSVC = 14.10
-GEOS_MSC = 1910
-!ELSEIF "$(_NMAKE_VER)" == "14.11.25508.2"
-GEOS_MSVC = 14.10
-GEOS_MSC = 1910
-!ELSEIF "$(_NMAKE_VER)" == "14.11.25547.0"
-GEOS_MSVC = 14.1
-GEOS_MSC = 1910
-!ELSE
-GEOS_MSVC = 0.0
-GEOS_MSC = 0
-!ENDIF
-!IF "$(GEOS_MSVC)" == "0.0" && "$(GEOS_MSC)" == "0"
-!MESSAGE *** Cannot determine Visual C++ version
-!ERROR *** Aborting make job
-!ELSE
-!MESSAGE *** Using Microsoft NMAKE version $(_NMAKE_VER)
-!MESSAGE *** Using Microsoft Visual C++ version $(GEOS_MSVC)
-!MESSAGE *** Using Microsoft C/C++ version $(GEOS_MSC)
-!ENDIF
-# Optional use of Visual Leak Detector (VLD) http://vld.codeplex.com/
-# Uncomment this line to use VLD in debug configuration only:
-#MSVC_VLD_DIR=$(EXTLIBDIR)\Source\vld\vld
-!IF "$(BUILD_DEBUG)" == "YES"
-!IFDEF MSVC_VLD_DIR
-MSVC_VLD_FLAGS=-DMSVC_USE_VLD=1 -I$(MSVC_VLD_DIR)\include
-!IFDEF WIN64
-MSVC_VLD_LIB=/LIBPATH:$(MSVC_VLD_DIR)/lib/Win64
-!ELSE
-MSVC_VLD_LIB=/LIBPATH:$(MSVC_VLD_DIR)/lib/Win32
-!ENDIF
-!ENDIF
-!ENDIF
-# Include directories
-GEOS_INCLUDE = -I..\include -I..\capi
-!MESSAGE *** Setting GEOS_INCLUDE $(GEOS_INCLUDE)
-!MESSAGE *** Setting INCLUDE $(INCLUDE)
-# Compilation flags for Release and Debug modes
-GEOS_CPPFLAGS = /D "NOMINMAX" /D "WIN32_LEAN_AND_MEAN" /D "NOGDI"
-GEOS_CPPFLAGS = $(GEOS_CPPFLAGS) /D "GEOS_DLL_EXPORT" $(MSVC_VLD_FLAGS)
-BUILD_PREFIX=_d
-GEOS_CFLAGS = /nologo /MDd /GR /Od /W4 /Zi
-GEOS_CPPFLAGS = /D "DEBUG" /D "_DEBUG" $(GEOS_CPPFLAGS)
-!ELSE
-GEOS_CFLAGS = /nologo /MD /GR /O2 /W3
-GEOS_CPPFLAGS = /D "NDEBUG" $(GEOS_CPPFLAGS)
-!ENDIF
-# Compiler version specific flags
-!IF $(GEOS_MSC) >= 1400
-GEOS_CFLAGS = $(GEOS_CFLAGS) /EHs
-GEOS_CPPFLAGS = $(GEOS_CPPFLAGS) /D "_CRT_SECURE_NO_DEPRECATE" /D "_CRT_NONSTDC_NO_DEPRECATE" /D "_SCL_SECURE_NO_DEPRECATE"
-!ELSE
-GEOS_CFLAGS = $(GEOS_CFLAGS) /GX
-!ENDIF
-# For Visual C++ 9.0+ use multiple process build
-!IF "$(BUILD_BATCH)" == "YES"
-!IF $(GEOS_MSC) > 1400
-MPFLAGS = /MP
-!MESSAGE *** Setting /MP flag to number of effective processors
-!ENDIF
-!ENDIF
-!IF "$(ENABLE_INLINE)" == "YES"
-GEOS_CFLAGS = /D "GEOS_INLINE"
-!ENDIF
-!MESSAGE *** Using GEOS_CFLAGS $(GEOS_CFLAGS)
-!MESSAGE *** Using GEOS_CPPFLAGS $(GEOS_CPPFLAGS)
-CFLAGS=$(MPFLAGS) $(GEOS_CFLAGS) $(GEOS_CPPFLAGS) $(GEOS_INCLUDE)
-!MESSAGE *** Complete CFLAGS $(CFLAGS)
-# Output location
-LIBNAME = geos$(BUILD_PREFIX).lib
-DLLNAME = geos$(BUILD_PREFIX).dll
-SLIBNAME = geos_i$(BUILD_PREFIX).lib
-CDLLNAME = geos_c$(BUILD_PREFIX).dll
-CLIBNAME = geos_c_i$(BUILD_PREFIX).lib
-# Building toolset programs
-MAKE = nmake
-CC = cl
-RM = del
-CP = copy
-# Linker executable
-# - Dynamic-Linked Libraries
-# $(LINK) /dll
-# - Static Libraries (use of lib.exe wrapper is not portable, see VC++ Toolkit 2003)
-# $(LINK) /lib
-LINK = link.exe
-LINKER_FLAGS = $(MSVC_VLD_LIB)
-# EOF
Summary of changes:
nmake.opt | 271 --------------------------------------------------------------
1 file changed, 271 deletions(-)
delete mode 100644 nmake.opt
hooks/post-receive
More information about the geos-commits
